板子是ROC-RK3399-PC-PLUS,未插emmc。使用发布的三个ubuntu的固件,station p1 ubuntu 20200306/20200622/20200731,用SD_Firmware_Tool_v1.56烧写到tf卡,启动都提示错误,进入boot,无法进入系统。
Net: eth0: ethernet@fe300000
mmc_bread: Re-init mmc_read_blocks error
Re-init retry timeout
android_image_load_separate: read kernel failed, ret=0
Android image load failed
boot mode: recovery
do_boot_rockchip boot from Recovery partition!
=Booting Rockchip format image=
boot_rockchip_image kernel or boot part info error
switch to partitions #0, OK
mmc1 is current device
** fs_devread read error - block
Failed to mount ext2 filesystem…
** Unrecognized filesystem type **
mmc_init: -95, time 62
Device 0: unknown device
ethernet@fe300000 Waiting for PHY auto negotiation to complete… TIMEOUT !
Could not initialize PHY ethernet@fe300000
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/01-c6-0a-52-99-fe-f0
Retrieving file: pxelinux.cfg/00000000
ethernet@fe300000 Waiting for PHY auto negotiation to complete. done
Speed: 100, full duplex
*** ERROR: serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/000000 Speed: 100, full duplex *** ERROR: serverip’ not set
*** ERROR: serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000 Speed: 100, full duplex *** ERROR: serverip’ not set
*** ERROR: serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/00 Speed: 100, full duplex *** ERROR: serverip’ not set
*** ERROR: serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm-rockchip Speed: 100, full duplex *** ERROR: serverip’ not set
*** ERROR: serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/default Speed: 100, full duplex *** ERROR: serverip’ not set
Config file not found
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
Retry time exceeded; starting again
