前一段时间购买了AIO-RK3288J主板,编写驱动模块遇到如下问题
1.编译好AIO-RK3288J板的SDK,并下载到板子上,板子可以正常启动。
2.创建mydriver目录,编写Makefile代码如下:
CROSS_COMPLE:=arm-linux-gnueabihf-
ARCH:=arm
CC:=$(CROSS_COMPILE)gcc
LD:=$(CROSS_COMPILE)ld
obj-m := spi-nfc-fm175xx.o
module-objs = spi-nfc-fm175xx.o leds-aw2013.o
KDIR := /home/xk/firefly-rk3288-linux/kernel
PWD := $(shell pwd)
defaule:
make -C $(KDIR) M=$(PWD) modules ARCH=arm
clean:
rm -f *.ko *.o *.mod.c *.symvers
3.编写模块代码如下:
#include <linux/init.h>
#include <linux/module.h>
static int __init spi_fm175xx_init(void)
printk(“insmod success!\n”);
return 0;
module_init(spi_fm175xx_init);
static void __exit spi_fm175xx_exit(void)
printk(“rmmod success!\n”);
module_exit(spi_fm175xx_exit);
MODULE_AUTHOR(“WJ Wang <wangwenjun@inmyshow.com>”);
MODULE_DESCRIPTION(“IMS NFC FM175XX Driver”);
MODULE_LICENSE(“GPL”);
MODULE_ALIAS(“spi:fm175xx”);
4.但是目前下载到板子里面,用insmod命令装载后,printk没有打印log信息。
也就是说__init和__exit没有执行
dmesg 看看
我查了一下,是printk打印等级不够,使用echo 7 > /proc/sys/kernel/printk可以解决这个问题,但是probe函数里的printk也打印不出来不知道该怎么解决?
[ 本帖最后由 八龄先生 于 2020-12-2 18:12 编辑 ]\n\n完全用官方的 spidev.c文件改的,只是在,__init(), __exit, probe函数里面添加了几条printk,怎么能看到打印信息呢?有没有更改默认printk权限的方式?
 * Simple synchronous userspace interface to SPI devices
 * Copyright (C) 2006 SWAPP
 *	Andrea Paterniani <a.paterniani@swapp-eng.it>
 * Copyright (C) 2007 David Brownell (simplification, cleanup)
 * This program is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation; either version 2 of the License, or
 * (at your option) any later version.
 * This program is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 * GNU General Public License for more details.
#include <linux/ioctl.h>
#include <linux/fs.h>
#include <linux/device.h>
#include <linux/err.h>
#include <linux/list.h>
#include <linux/errno.h>
#include <linux/mutex.h>
#include <linux/slab.h>
#include <linux/compat.h>
#include <linux/of.h>
#include <linux/of_device.h>
#include <linux/spi/spi.h>
#include <linux/spi/spidev.h>
#include <linux/uaccess.h>
 * This supports access to SPI devices using normal userspace I/O calls.
 * Note that while traditional UNIX/POSIX I/O semantics are half duplex,
 * and often mask message boundaries, full SPI support requires full duplex
 * transfers.  There are several kinds of internal message boundaries to
 * handle chipselect management and other protocol options.
 * SPI has a character major number assigned.  We allocate minor numbers
 * dynamically using a bitmask.  You must use hotplug tools, such as udev
 * (or mdev with busybox) to create and destroy the /dev/spidevB.C device
 * nodes, since there is no fixed association of minor numbers with any
 * particular SPI bus or device.
#define SPIDEV_MAJOR			153	/* assigned */
#define N_SPI_MINORS			32	/* ... up to 256 */
static DECLARE_BITMAP(minors, N_SPI_MINORS);
/* Bit masks for spi_device.mode management.  Note that incorrect
 * settings for some settings can cause *lots* of trouble for other
 * devices on a shared bus:
 *  - CS_HIGH ... this device will be active when it shouldn't be
 *  - 3WIRE ... when active, it won't behave as it should
 *  - NO_CS ... there will be no explicit message boundaries; this
 *	is completely incompatible with the shared bus model
 *  - READY ... transfers may proceed when they shouldn't.
 * REVISIT should changing those flags be privileged?
#define SPI_MODE_MASK		(SPI_CPHA | SPI_CPOL | SPI_CS_HIGH \
				| SPI_LSB_FIRST | SPI_3WIRE | SPI_LOOP \
				| SPI_NO_CS | SPI_READY | SPI_TX_DUAL \
				| SPI_TX_QUAD | SPI_RX_DUAL | SPI_RX_QUAD)
struct spidev_data {
	dev_t			devt;
	spinlock_t		spi_lock;
	struct spi_device	*spi;
	struct list_head	device_entry;
	/* TX/RX buffers are NULL unless this device is open (users > 0) */
	struct mutex		buf_lock;
	unsigned		users;
	u8			*tx_buffer;
	u8			*rx_buffer;
	u32			speed_hz;
static LIST_HEAD(device_list);
static DEFINE_MUTEX(device_list_lock);
static unsigned bufsiz = 4096;
module_param(bufsiz, uint, S_IRUGO);
MODULE_PARM_DESC(bufsiz, "data bytes in biggest supported SPI message");
static ssize_t
spidev_sync(struct spidev_data *spidev, struct spi_message *message)
	DECLARE_COMPLETION_ONSTACK(done);
	int status;
	spin_lock_irq(&spidev->spi_lock);
	spi = spidev->spi;
	spin_unlock_irq(&spidev->spi_lock);
	if (spi == NULL)
		status = -ESHUTDOWN;
	else
		status = spi_sync(spi, message);
	if (status == 0)
		status = message->actual_length;
	return status;
static inline ssize_t
spidev_sync_write(struct spidev_data *spidev, size_t len)
	struct spi_transfer	t = {
			.tx_buf		= spidev->tx_buffer,
			.len		= len,
			.speed_hz	= spidev->speed_hz,
	struct spi_message	m;
	spi_message_init(&m);
	spi_message_add_tail(&t, &m);
	return spidev_sync(spidev, &m);
spidev_sync_read(struct spidev_data *spidev, size_t len)
			.rx_buf		= spidev->rx_buffer,
			.len		= len,
/* Read-only message with current device setup */
static ssize_t
spidev_read(struct file *filp, char __user *buf, size_t count, loff_t *f_pos)
	struct spidev_data	*spidev;
	ssize_t			status = 0;
	/* chipselect only toggles at start or end of operation */
	if (count > bufsiz)
		return -EMSGSIZE;
	spidev = filp->private_data;
	mutex_lock(&spidev->buf_lock);
	status = spidev_sync_read(spidev, count);
	if (status > 0) {
		unsigned long	missing;
		missing = copy_to_user(buf, spidev->rx_buffer, status);
		if (missing == status)
			status = -EFAULT;
		else
			status = status - missing;
	mutex_unlock(&spidev->buf_lock);
	return status;
/* Write-only message with current device setup */
static ssize_t
spidev_write(struct file *filp, const char __user *buf,
	ssize_t			status = 0;
	if (count > bufsiz)
		return -EMSGSIZE;
	missing = copy_from_user(spidev->tx_buffer, buf, count);
	if (missing == 0)
		status = spidev_sync_write(spidev, count);
	else
		status = -EFAULT;
	return status;
static int spidev_message(struct spidev_data *spidev,
		struct spi_ioc_transfer *u_xfers, unsigned n_xfers)
	struct spi_message	msg;
	struct spi_transfer	*k_xfers;
	struct spi_transfer	*k_tmp;
	struct spi_ioc_transfer *u_tmp;
	unsigned		n, total, tx_total, rx_total;
	u8			*tx_buf, *rx_buf;
	int			status = -EFAULT;
	spi_message_init(&msg);
	k_xfers = kcalloc(n_xfers, sizeof(*k_tmp), GFP_KERNEL);
	if (k_xfers == NULL)
		return -ENOMEM;
	/* Construct spi_message, copying any tx data to bounce buffer.
	 * We walk the array of user-provided transfers, using each one
	 * to initialize a kernel version of the same transfer.
	tx_buf = spidev->tx_buffer;
	rx_buf = spidev->rx_buffer;
	total = 0;
	tx_total = 0;
	rx_total = 0;
	for (n = n_xfers, k_tmp = k_xfers, u_tmp = u_xfers;
			n;
			n--, k_tmp++, u_tmp++) {
		k_tmp->len = u_tmp->len;
		total += k_tmp->len;
		/* Since the function returns the total length of transfers
		 * on success, restrict the total to positive int values to
		 * avoid the return value looking like an error.  Also check
		 * each transfer length to avoid arithmetic overflow.
		if (total > INT_MAX || k_tmp->len > INT_MAX) {
			status = -EMSGSIZE;
			goto done;
		if (u_tmp->rx_buf) {
			/* this transfer needs space in RX bounce buffer */
			rx_total += k_tmp->len;
			if (rx_total > bufsiz) {
				status = -EMSGSIZE;
				goto done;
			k_tmp->rx_buf = rx_buf;
			if (!access_ok(VERIFY_WRITE, (u8 __user *)
						(uintptr_t) u_tmp->rx_buf,
						u_tmp->len))
				goto done;
			rx_buf += k_tmp->len;
		if (u_tmp->tx_buf) {
			/* this transfer needs space in TX bounce buffer */
			tx_total += k_tmp->len;
			if (tx_total > bufsiz) {
				status = -EMSGSIZE;
				goto done;
			k_tmp->tx_buf = tx_buf;
			if (copy_from_user(tx_buf, (const u8 __user *)
						(uintptr_t) u_tmp->tx_buf,
					u_tmp->len))
				goto done;
			tx_buf += k_tmp->len;
		k_tmp->cs_change = !!u_tmp->cs_change;
		k_tmp->tx_nbits = u_tmp->tx_nbits;
		k_tmp->rx_nbits = u_tmp->rx_nbits;
		k_tmp->bits_per_word = u_tmp->bits_per_word;
		k_tmp->delay_usecs = u_tmp->delay_usecs;
		k_tmp->speed_hz = u_tmp->speed_hz;
		if (!k_tmp->speed_hz)
			k_tmp->speed_hz = spidev->speed_hz;
#ifdef VERBOSE
		dev_dbg(&spidev->spi->dev,
			"  xfer len %zd %s%s%s%dbits %u usec %uHz\n",
			u_tmp->len,
			u_tmp->rx_buf ? "rx " : "",
			u_tmp->tx_buf ? "tx " : "",
			u_tmp->cs_change ? "cs " : "",
			u_tmp->bits_per_word ? : spidev->spi->bits_per_word,
			u_tmp->delay_usecs,
			u_tmp->speed_hz ? : spidev->spi->max_speed_hz);
#endif
		spi_message_add_tail(k_tmp, &msg);
	status = spidev_sync(spidev, &msg);
	if (status < 0)
		goto done;
	/* copy any rx data out of bounce buffer */
	for (n = n_xfers, u_tmp = u_xfers; n; n--, u_tmp++) {
			if (__copy_to_user((u8 __user *)
					(uintptr_t) u_tmp->rx_buf, rx_buf,
					u_tmp->len)) {
				status = -EFAULT;
				goto done;
			rx_buf += u_tmp->len;
	status = total;
done:
	kfree(k_xfers);
	return status;
static struct spi_ioc_transfer *spidev_get_ioc_message(unsigned int cmd, struct spi_ioc_transfer __user *u_ioc,
		unsigned *n_ioc)
	struct spi_ioc_transfer	*ioc;
	u32	tmp;
	/* Check type, command number and direction */
	if (_IOC_TYPE(cmd) != SPI_IOC_MAGIC
			|| _IOC_NR(cmd) != _IOC_NR(SPI_IOC_MESSAGE(0))
			|| _IOC_DIR(cmd) != _IOC_WRITE)
		return ERR_PTR(-ENOTTY);
	tmp = _IOC_SIZE(cmd);
	if ((tmp % sizeof(struct spi_ioc_transfer)) != 0)
		return ERR_PTR(-EINVAL);
	*n_ioc = tmp / sizeof(struct spi_ioc_transfer);
	if (*n_ioc == 0)
		return NULL;
	/* copy into scratch area */
	ioc = kmalloc(tmp, GFP_KERNEL);
	if (!ioc)
		return ERR_PTR(-ENOMEM);
	if (__copy_from_user(ioc, u_ioc, tmp)) {
		kfree(ioc);
		return ERR_PTR(-EFAULT);
	return ioc;
static long spidev_ioctl(struct file *filp, unsigned int cmd, unsigned long arg)
	int			err = 0;
	int			retval = 0;
	u32			tmp;
	unsigned		n_ioc;
	/* Check type and command number */
	if (_IOC_TYPE(cmd) != SPI_IOC_MAGIC)
		return -ENOTTY;
	/* Check access direction once here; don't repeat below.
	 * IOC_DIR is from the user perspective, while access_ok is
	 * from the kernel perspective; so they look reversed.
	if (_IOC_DIR(cmd) & _IOC_READ)
		err = !access_ok(VERIFY_WRITE,
				(void __user *)arg, _IOC_SIZE(cmd));
	if (err == 0 && _IOC_DIR(cmd) & _IOC_WRITE)
		err = !access_ok(VERIFY_READ,
	if (err)
		return -EFAULT;
	/* guard against device removal before, or while,
	 * we issue this ioctl.
	spi = spi_dev_get(spidev->spi);
	if (spi == NULL)
		return -ESHUTDOWN;
	/* use the buffer lock here for triple duty:
	 *  - prevent I/O (from us) so calling spi_setup() is safe;
	 *  - prevent concurrent SPI_IOC_WR_* from morphing
	 *    data fields while SPI_IOC_RD_* reads them;
	 *  - SPI_IOC_MESSAGE needs the buffer locked "normally".
	switch (cmd) {
	/* read requests */
	case SPI_IOC_RD_MODE:
		retval = __put_user(spi->mode & SPI_MODE_MASK,
					(__u8 __user *)arg);
		break;
	case SPI_IOC_RD_MODE32:
					(__u32 __user *)arg);
		break;
	case SPI_IOC_RD_LSB_FIRST:
		retval = __put_user((spi->mode & SPI_LSB_FIRST) ?  1 : 0,
		break;
	case SPI_IOC_RD_BITS_PER_WORD:
		retval = __put_user(spi->bits_per_word, (__u8 __user *)arg);
		break;
	case SPI_IOC_RD_MAX_SPEED_HZ:
		retval = __put_user(spidev->speed_hz, (__u32 __user *)arg);
		break;
	/* write requests */
	case SPI_IOC_WR_MODE:
	case SPI_IOC_WR_MODE32:
		if (cmd == SPI_IOC_WR_MODE)
			retval = __get_user(tmp, (u8 __user *)arg);
		else
			retval = __get_user(tmp, (u32 __user *)arg);
		if (retval == 0) {
			u32	save = spi->mode;
			if (tmp & ~SPI_MODE_MASK) {
				retval = -EINVAL;
				break;
			tmp |= spi->mode & ~SPI_MODE_MASK;
			spi->mode = (u16)tmp;
			retval = spi_setup(spi);
			if (retval < 0)
				spi->mode = save;
			else
				dev_dbg(&spi->dev, "spi mode %x\n", tmp);
		break;
	case SPI_IOC_WR_LSB_FIRST:
		retval = __get_user(tmp, (__u8 __user *)arg);
		if (retval == 0) {
			if (tmp)
				spi->mode |= SPI_LSB_FIRST;
			else
				spi->mode &= ~SPI_LSB_FIRST;
			if (retval < 0)
				spi->mode = save;
			else
				dev_dbg(&spi->dev, "%csb first\n",
						tmp ? 'l' : 'm');
		break;
	case SPI_IOC_WR_BITS_PER_WORD:
		if (retval == 0) {
			u8	save = spi->bits_per_word;
			spi->bits_per_word = tmp;
			if (retval < 0)
				spi->bits_per_word = save;
			else
				dev_dbg(&spi->dev, "%d bits per word\n", tmp);
		break;
	case SPI_IOC_WR_MAX_SPEED_HZ:
		retval = __get_user(tmp, (__u32 __user *)arg);
		if (retval == 0) {
			u32	save = spi->max_speed_hz;
			spi->max_speed_hz = tmp;
			if (retval >= 0)
				spidev->speed_hz = tmp;
			else
				dev_dbg(&spi->dev, "%d Hz (max)\n", tmp);
			spi->max_speed_hz = save;
		break;
	default:
		/* segmented and/or full-duplex I/O request */
		/* Check message and copy into scratch area */
		ioc = spidev_get_ioc_message(cmd,
				(struct spi_ioc_transfer __user *)arg, &n_ioc);
		if (IS_ERR(ioc)) {
			retval = PTR_ERR(ioc);
			break;
		if (!ioc)
			break;	/* n_ioc is also 0 */
		/* translate to spi_message, execute */
		retval = spidev_message(spidev, ioc, n_ioc);
		kfree(ioc);
		break;
	spi_dev_put(spi);
	return retval;
#ifdef CONFIG_COMPAT
static long
spidev_compat_ioc_message(struct file *filp, unsigned int cmd,
		unsigned long arg)
	struct spi_ioc_transfer __user	*u_ioc;
	int				retval = 0;
	unsigned			n_ioc, n;
	u_ioc = (struct spi_ioc_transfer __user *) compat_ptr(arg);
	if (!access_ok(VERIFY_READ, u_ioc, _IOC_SIZE(cmd)))
		return -EFAULT;
	if (spi == NULL)
		return -ESHUTDOWN;
	/* SPI_IOC_MESSAGE needs the buffer locked "normally" */
	ioc = spidev_get_ioc_message(cmd, u_ioc, &n_ioc);
	if (IS_ERR(ioc)) {
		goto done;
	if (!ioc)
		goto done;	/* n_ioc is also 0 */
	/* Convert buffer pointers */
	for (n = 0; n < n_ioc; n++) {
		ioc[n].rx_buf = (uintptr_t) compat_ptr(ioc[n].rx_buf);
		ioc[n].tx_buf = (uintptr_t) compat_ptr(ioc[n].tx_buf);
	kfree(ioc);
done:
	spi_dev_put(spi);
	return retval;
static long
spidev_compat_ioctl(struct file *filp, unsigned int cmd, unsigned long arg)
	if (_IOC_TYPE(cmd) == SPI_IOC_MAGIC
			&& _IOC_NR(cmd) == _IOC_NR(SPI_IOC_MESSAGE(0))
			&& _IOC_DIR(cmd) == _IOC_WRITE)
		return spidev_compat_ioc_message(filp, cmd, arg);
	return spidev_ioctl(filp, cmd, (unsigned long)compat_ptr(arg));
#else
#define spidev_compat_ioctl NULL
#endif /* CONFIG_COMPAT */
static int spidev_open(struct inode *inode, struct file *filp)
	int			status = -ENXIO;
	mutex_lock(&device_list_lock);
	list_for_each_entry(spidev, &device_list, device_entry) {
		if (spidev->devt == inode->i_rdev) {
			status = 0;
			break;
	if (status) {
		pr_debug("spidev: nothing for minor %d\n", iminor(inode));
		goto err_find_dev;
	if (!spidev->tx_buffer) {
		spidev->tx_buffer = kmalloc(bufsiz, GFP_KERNEL);
			dev_dbg(&spidev->spi->dev, "open/ENOMEM\n");
			status = -ENOMEM;
			goto err_find_dev;
	if (!spidev->rx_buffer) {
		spidev->rx_buffer = kmalloc(bufsiz, GFP_KERNEL);
			status = -ENOMEM;
			goto err_alloc_rx_buf;
	spidev->users++;
	filp->private_data = spidev;
	nonseekable_open(inode, filp);
	mutex_unlock(&device_list_lock);
	return 0;
err_alloc_rx_buf:
	kfree(spidev->tx_buffer);
	spidev->tx_buffer = NULL;
err_find_dev:
	return status;
static int spidev_release(struct inode *inode, struct file *filp)
	filp->private_data = NULL;
	/* last close? */
	spidev->users--;
	if (!spidev->users) {
		int		dofree;
		kfree(spidev->rx_buffer);
		spidev->rx_buffer = NULL;
		if (spidev->spi)
			spidev->speed_hz = spidev->spi->max_speed_hz;
		/* ... after we unbound from the underlying device? */
		dofree = (spidev->spi == NULL);
		if (dofree)
			kfree(spidev);
	return 0;
static const struct file_operations spidev_fops = {
	.owner =	THIS_MODULE,
	/* REVISIT switch to aio primitives, so that userspace
	 * gets more complete API coverage.  It'll simplify things
	 * too, except for the locking.
	.write =	spidev_write,
	.read =		spidev_read,
	.unlocked_ioctl = spidev_ioctl,
	.compat_ioctl = spidev_compat_ioctl,
	.open =		spidev_open,
	.release =	spidev_release,
	.llseek =	no_llseek,
/* The main reason to have this class is to make mdev/udev create the
 * /dev/spidevB.C character device nodes exposing our userspace API.
 * It also simplifies memory management.
static struct class *spidev_class;
//#ifdef CONFIG_OF
static const struct of_device_id fm175xx_dt_ids[] = {
	{ .compatible = "fdw,nfc_fm175xx" },
MODULE_DEVICE_TABLE(of, fm175xx_dt_ids);
//#endif
static int fm175xx_probe(struct spi_device *spi)
	int			status;
	unsigned long		minor;
	 * spidev should never be referenced in DT without a specific
	 * compatible string, it is a Linux implementation thing
	 * rather than a description of the hardware.
	if (spi->dev.of_node && !of_match_device(fm175xx_dt_ids, &spi->dev)) {
		dev_err(&spi->dev, "buggy DT: spidev listed directly in DT\n");
		WARN_ON(spi->dev.of_node &&
			!of_match_device(fm175xx_dt_ids, &spi->dev));
	printk("probe function successful!\n");
	/* Allocate driver data */
	spidev = kzalloc(sizeof(*spidev), GFP_KERNEL);
	if (!spidev)
		return -ENOMEM;
	/* Initialize the driver data */
	spidev->spi = spi;
	spin_lock_init(&spidev->spi_lock);
	mutex_init(&spidev->buf_lock);
	INIT_LIST_HEAD(&spidev->device_entry);
	/* If we can allocate a minor number, hook up this device.
	 * Reusing minors is fine so long as udev or mdev is working.
	minor = find_first_zero_bit(minors, N_SPI_MINORS);
	if (minor < N_SPI_MINORS) {
		struct device *dev;
		spidev->devt = MKDEV(SPIDEV_MAJOR, minor);
		dev = device_create(spidev_class, &spi->dev, spidev->devt,
				    spidev, "spidev%d.%d",
				    spi->master->bus_num, spi->chip_select);
		status = PTR_ERR_OR_ZERO(dev);
	} else {
		dev_dbg(&spi->dev, "no minor number available!\n");
		status = -ENODEV;
	if (status == 0) {
		set_bit(minor, minors);
		list_add(&spidev->device_entry, &device_list);
	spidev->speed_hz = spi->max_speed_hz;
	if (status == 0)
		spi_set_drvdata(spi, spidev);
	else
		kfree(spidev);
	return status;
static int fm175xx_remove(struct spi_device *spi)
	struct spidev_data	*spidev = spi_get_drvdata(spi);
	/* make sure ops on existing fds can abort cleanly */
	spidev->spi = NULL;
	/* prevent new opens */
	list_del(&spidev->device_entry);
	device_destroy(spidev_class, spidev->devt);
	clear_bit(MINOR(spidev->devt), minors);
	if (spidev->users == 0)
		kfree(spidev);
	return 0;
static struct spi_driver spidev_spi_driver = {
	.driver = {
		.name =		"fdw,nfc_fm175xx",
		.of_match_table = of_match_ptr(fm175xx_dt_ids),
	.probe =	fm175xx_probe,
	.remove =	fm175xx_remove,
	/* NOTE:  suspend/resume methods are not necessary here.
	 * We don't do anything except pass the requests to/from
	 * the underlying controller.  The refrigerator handles
	 * most issues; the controller driver handles the rest.
static int __init spidev_init(void)
	int status;
	/* Claim our 256 reserved device numbers.  Then register a class
	 * that will key udev/mdev to add/remove /dev nodes.  Last, register
	 * the driver which manages those device numbers.
	BUILD_BUG_ON(N_SPI_MINORS > 256);
	status = register_chrdev(SPIDEV_MAJOR, "spi", &spidev_fops);
	if (status < 0)
		return status;
	spidev_class = class_create(THIS_MODULE, "spidev");
	if (IS_ERR(spidev_class)) {
		unregister_chrdev(SPIDEV_MAJOR, spidev_spi_driver.driver.name);
		return PTR_ERR(spidev_class);
	status = spi_register_driver(&spidev_spi_driver);
	if (status < 0) {
		class_destroy(spidev_class);
	printk("spi module init successful.\n");
	return status;
module_init(spidev_init);
static void __exit spidev_exit(void)
	spi_unregister_driver(&spidev_spi_driver);
	printk("spi module exit successful.\n");
module_exit(spidev_exit);
MODULE_AUTHOR("WJ wang<wangwenjun@inmyshow.com>");
MODULE_DESCRIPTION("User mode nfc fm175xx interface");
MODULE_LICENSE("GPL");
