更换 华存 8G eMMC,重烧系统,不能启动
[BEGIN] 2020-12-21 23:08:33
DDR Version 1.08 20170320
Channel 0: DDR3, 800MHz
Channel 1: DDR3, 800MHz
256B stride
pmugrf_os_reg[2] = 0x3AA17AA1, stride = 0xD
Boot1: 2017-06-09, version: 1.09
CPUId = 0x0
ChipType = 0x10, 1835
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=7456MB
FwPartOffset=2000 , 100000
SdmmcInit=0 20
StorageInit ok = 67806
LoadTrustBL
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0x77d6c
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):9f93abc
NOTICE: BL31: Built : 10:18:20, Jul 27 2017
INFO: plat_rockchip_pmu_init(1089): pd status 3e
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-96-g3fbe315-dev #4 Fri Jun 30 00:35:17 UTC 2017 aarch64)
INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.1
INFO: SPSR = 0x3c9
U-Boot 2014.10-RK3399-06 (Jan 26 2018 - 10:04:18)
CPU: rk3399
cpu version = 0
CPU’s clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
aclk_periph_l0 = 100000000HZ, hclk_periph_l0 = 100000000HZ, pclk_periph_l0 = 50000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
Reserve memory for trust os.
dram reserve bank: base = 0x08400000, size = 0x01000000
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
remotectl v0.1
pwm freq=0xb8320
pwm_freq_nstime=0x52d
Load FDT from resource image.
power key: bank-0 pin-5
can’t find dts node for fixed
dwc_otg_check_dpdm: usb bc disconnected
pmic:rk808
can’t find dts node for pwm1
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
#Boot ver: 2018-01-26#1.09
empty serial no.
normal boot.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
failed to find phy node
failed to find panel driver
no fuel gauge found
can’t find dts node for deviceinfo
dw_rk_hdmi_register:fail to read deviceinfo
hdmi baseparamer 0x0@0-0
[EDID] extensions block checksum error
[HDMI] parse edid block 1 error-3
no edid message:use default vic config:4
hdmi_dev->video.vic is 4
rk lcdc - 0 dclk set: dclk = 74250000HZ, pll select = 0, div = 1
rockchip_panel_prepare: failed to find panel prepare funcs
hdmi_dev_config_video vic 4 color_output 1 color_output_depth 8
pixel clk is 74250000 tmds clk is 74250000
hsync_pol 1 vsync_pol 1
[HDMI] sucess output HDMI.
PHY PLL not locked: PCLK_ON=1,TMDSCLK_ON=0
rockchip_panel_enable: failed to find panel prepare funcs
failed to display kernel logo
checkKey
vbus = 0
got recovery cmd from misc.
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x00280000 (0x01325008)
ramdisk @ 0x05bf0000 (0x007b1abc)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000005600000, end 0000000005615f13 … OK
Add bank:0000000009400000, 00000000eec00000
[ 0.000000] Linux version 4.4.83 (omy@tchipserver2) (gcc version 4.9 20150123 (prerelease) (GCC) ) #47 SMP PREEMPT Fri Jan 26 09:22:49 CST 2018
[ 0.000000] cma: Reserved 16 MiB at 0x00000000f7000000
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f6eef000 s45696 r8192 d32128 u86016
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 995336
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x0000C000@0x00010000(kernel),0x00010000@0x0001C000(boot),0x00010000@0x0002C000(recovery),0x00038000@0x0003C000(backup),0x00040000@0x00074000(cache),0x00300000@0x000B4000(system),0x00008000@0x003B4000(metadata),0x00002000@0x003BC000(baseparamer),-@0x003BE000(userdata) storagemedia=emmc uboot_logo=0x02000000@0xf5c00000 loader.timestamp=2018-01-26_10:04:18 hdmi.vic=-1 SecureBootCheckOk=0
[ 0.000000] software IO TLB [mem 0xf6ea6000-0xf6ee6000] (0MB) mapped at [ffffffc0f6ea6000-ffffffc0f6ee5fff]
[ 0.000000] Memory: 3926108K/4044800K available (11838K kernel code, 1428K rwdata, 5440K rodata, 832K init, 1116K bss, 102308K reserved, 16384K cma-reserved)
[ 0.000000] .init : 0xffffff8009170000 - 0xffffff8009240000 ( 832 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008c10000 ( 11840 KB)
[ 0.000000] .rodata : 0xffffff8008c10000 - 0xffffff8009170000 ( 5504 KB)
[ 0.000000] .data : 0xffffff8009240000 - 0xffffff80093a5008 ( 1429 KB)
[ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc3e00000 ( 61 MB actual)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc0f8000000 ( 3966 MB)
[ 0.000000] ITS: allocated 65536 Devices @f2000000 (psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x00000000f2080000
[ 0.000000] CPU0: using LPI pending table @0x00000000f2090000
[ 0.001852] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.002814] pid_max: default: 32768 minimum: 301
[ 0.003310] Security Framework initialized
[ 0.003698] SELinux: Initializing.
[ 0.004129] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.004757] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.006250] Initializing cgroup subsys freezer
[ 0.006677] Initializing cgroup subsys debug
[ 0.007951] sched-energy: Sched-energy-costs installed from DT
[ 0.008501] CPU0: update cpu_capacity 401
[ 0.008952] ASID allocator initialised with 65536 entries
[ 0.025776] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.027004] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.039170] Detected VIPT I-cache on CPU1
[ 0.039200] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.039237] CPU1: using LPI pending table @0x00000000f2200000
[ 0.039280] CPU1: update cpu_capacity 401
[ 0.039283] CPU1: Booted secondary processor [410fd034]
[ 0.049165] Detected VIPT I-cache on CPU2
[ 0.049184] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.049216] CPU2: using LPI pending table @0x00000000f2230000
[ 0.049243] CPU2: update cpu_capacity 401
[ 0.049246] CPU2: Booted secondary processor [410fd034]
[ 0.059201] Detected VIPT I-cache on CPU3
[ 0.059220] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.059252] CPU3: using LPI pending table @0x00000000f2270000
[ 0.059278] CPU3: update cpu_capacity 401
[ 0.059281] CPU3: Booted secondary processor [410fd034]
[ 0.069243] Detected PIPT I-cache on CPU4
[ 0.069272] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.069311] CPU4: using LPI pending table @0x00000000f22b0000
[ 0.069353] CPU4: update cpu_capacity 1024
[ 0.069356] CPU4: Booted secondary processor [410fd082]
[ 0.079268] Detected PIPT I-cache on CPU5
[ 0.079286] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.079323] CPU5: using LPI pending table @0x00000000f22e0000
[ 0.079351] CPU5: update cpu_capacity 1024
[ 0.079353] CPU5: Booted secondary processor [410fd082]
[ 0.079435] Brought up 6 CPUs
[ 0.091534] SMP: Total of 6 processors activated.
[ 0.091976] CPU features: detected feature: GIC system register CPU interface
[ 0.092645] CPU: All CPU(s) started at EL2
[ 0.093066] alternatives: patching kernel code
[ 0.095155] devtmpfs: initialized
[ 0.115291] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.116263] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.117897] pinctrl core: initialized pinctrl subsystem
[ 0.120998] Failed to find legacy iommu devices
[ 0.121939] NET: Registered protocol family 16
[ 0.123060] schedtune: init normalization constants…
[ 0.123546] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[ 0.124157] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 0.124785] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[ 0.125395] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 0.126006] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 0.126669] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[ 0.127304] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[ 0.127937] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[ 0.128570] schedtune: SYSTEM min_pwr: 121 max_pwr: 4434
[ 0.129203] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[ 0.129950] schedtune: verify normalization constants…
[ 0.130466] schedtune: max_pwr/2^0: 4313 => norm_pwr: 1024
[ 0.131006] schedtune: max_pwr/2^1: 2156 => norm_pwr: 511
[ 0.131545] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[ 0.132084] schedtune: max_pwr/2^3: 539 => norm_pwr: 127
[ 0.132624] schedtune: max_pwr/2^4: 269 => norm_pwr: 63
[ 0.133164] schedtune: max_pwr/2^5: 134 => norm_pwr: 31
[ 0.133710] schedtune: configured to support 5 boost groups
[ 0.143757] cpuidle: using governor ladder
[ 0.154865] cpuidle: using governor menu
[ 0.155278] Registered FIQ tty driver
[ 0.156006] vdso: 2 pages (1 code @ ffffff8008c16000, 1 data @ ffffff8009244000)
[ 0.156759] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.158143] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.177747] console [pstore0] enabled
[ 0.178346] pstore: Registered ramoops as persistent store backend
[ 0.178949] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.181628] sip_fiq_debugger_uart_irq_tf_init error: -2
[ 0.182140] fiq debugger bind fiq to trustzone failed: -2
[ 0.183043] console [ttyFIQ0] enabled
[ [ 0.183043] console [ttyFIQ0] enabled
[ 0.183607] bootconsole [uart0] disabled
[ 0.184844] Registered fiq debugger ttyFIQ0
[ 0.224744] Rockchip hdmi driver version 2.0
[ 0.226892] iommu: Adding device ff650000.vpu_service to group 0
[ 0.226972] iommu: Adding device ff660000.rkvdec to group 1
[ 0.227060] iommu: Adding device ff670000.iep to group 2
[ 0.227157] iommu: Adding device ff8f0000.vop to group 3
[ 0.227238] iommu: Adding device ff900000.vop to group 4
[ 0.227335] iommu: Adding device ff910000.isp to group 5
[ 0.227410] iommu: Adding device ff920000.isp to group 6
[ 0.228078] rk_iommu ff670800.iommu: can’t get aclk
[ 0.228098] rk_iommu ff670800.iommu: can’t get hclk
[ 0.228936] SCSI subsystem initialized
[ 0.229273] usbcore: registered new interface driver usbfs
[ 0.229319] usbcore: registered new interface driver hub
[ 0.229398] usbcore: registered new device driver usb
[ 0.229740] media: Linux media interface: v0.10
[ 0.229780] Linux video capture interface: v2.00
[ 0.229909] pps_core: LinuxPPS API ver. 1 registered
[ 0.229920] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.229947] PTP clock support registered
[ 0.231351] Advanced Linux Sound Architecture Driver Initialized.
[ 0.231824] Bluetooth: Core ver 2.21
[ 0.231860] NET: Registered protocol family 31
[ 0.231871] Bluetooth: HCI device and connection manager initialized
[ 0.231888] Bluetooth: HCI socket layer initialized
[ 0.231902] Bluetooth: L2CAP socket layer initialized
[ 0.231931] Bluetooth: SCO socket layer initialized
[ 0.232893] rockchip-cpuinfo cpuinfo: Serial : fb18f439e4b31347
[ 0.233405] clocksource: Switched to clocksource arch_sys_counter
[ 0.272631] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.272864] NET: Registered protocol family 2
[ 0.273278] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.273486] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.273865] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.273953] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.274001] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.274194] NET: Registered protocol family 1
[ 0.274671] Trying to unpack rootfs image as initramfs…
[ 0.610170] Freeing initrd memory: 7876K
[ 0.610723] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.610813] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.613309] audit: initializing netlink subsys (disabled)
[ 0.613369] audit: type=2000 audit(0.606:1): initialized
[ 0.618465] VFS: Disk quotas dquot_6.6.0
[ 0.618585] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.619925] fuse init (API version 7.23)
[ 0.620977]
[ 0.620977] TEE Core Framework initialization (ver 1:0.1)
[ 0.621008] TEE armv7 Driver initialization
[ 0.621336] tz_tee_probe: name=“armv7sec”, id=0, pdev_name=“armv7sec.0”
[ 0.621352] TEE core: Alloc the misc device “opteearmtz00” (id=0)
[ 0.621531] TEE Core: Register the misc device “opteearmtz00” (id=0,minor=62)
[ 0.625602] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.625631] io scheduler noop registered
[ 0.625801] io scheduler cfq registered (default)
[ 0.627043] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned
[ 0.631555] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.631585] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.631608] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 1.153449] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 1.154193] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 1.156285] iep: failed to find iep power down clock source.
[ 1.157391] IEP Power ON
[ 1.157842] IEP Power OFF
[ 1.158194] IEP Driver loaded succesfully
[ 1.158775] Module initialized.
[ 1.159367] rk-vcodec ff650000.vpu_service: probe device
[ 1.159423] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc0f18f9410
[ 1.159593] rk-vcodec ff650000.vpu_service: allocator is drm
[ 1.159654] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 1.160123] rk-vcodec ff650000.vpu_service: init success
[ 1.160673] rk-vcodec ff660000.rkvdec: probe device
[ 1.160716] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc0f18f9c10
[ 1.160862] rk-vcodec ff660000.rkvdec: allocator is drm
[ 1.160920] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 1.161226] rk-vcodec ff660000.rkvdec: init success
[ 1.162567] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.162586] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 1.163952] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.163970] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.165298] Serial: 8250/1.? driver, 5 ports, IRQ sharing disabled
[ 1.166879] console [ttyS0] disabled
[ 1.166926] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
[ 1.167499] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 37, base_baud = 1500000) is a 16550A
[ 1.168058] ff370000.serial: ttyS4 at MMIO 0xff370000 (irq = 40, base_baud = 1500000) is a 16550A
[ 1.168415] [drm:drm_core_init] Initialized drm 1.1.0 20060810
[ 1.172709] mali ff9a0000.gpu: Failed to get regulator
[ 1.172730] mali ff9a0000.gpu: Power control initialization failed
[ 1.173012] Unable to detect cache hierarchy from DT for CPU 0
[ 1.180817] brd: module loaded
[ 1.198866] loop: module loaded
[ 1.199393] zram: Added device: zram0
[ 1.199932] SCSI Media Changer driver v0.25
[ 1.200951] rockchip-pinctrl pinctrl: pin gpio1-8 already requested by ff370000.serial; cannot claim for ff1d0000.spi
[ 1.200979] rockchip-pinctrl pinctrl: pin-40 (ff1d0000.spi) status -22
[ 1.200995] rockchip-pinctrl pinctrl: could not request pin 40 (gpio1-8) from group spi1-tx on device rockchip-pinctrl
[ 1.201012] rockchip-spi ff1d0000.spi: Error applying setting, reverse things back
[ 1.201147] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[ 1.201162] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[ 1.201727] register spi return v = :0
[ 1.201791] tun: Universal TUN/TAP device driver, 1.6
[ 1.201801] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.202773] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.202791] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 1.202804] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[ 1.202835] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 1.202998] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.208016] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.208137] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.208148] Ring mode enabled
[ 1.208156] DMA HW capability register supported
[ 1.208165] Normal descriptors
[ 1.208175] RX Checksum Offload Engine supported (type 2)
[ 1.208184] TX Checksum insertion supported
[ 1.208193] Wake-Up On Lan supported
[ 1.208234] Enable RX Mitigation via HW Watchdog Timer
[ 1.276116] libphy: stmmac: probed
[ 1.276139] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.276153] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.278261] PPP generic driver version 2.4.2
[ 1.278787] PPP BSD Compression module registered
[ 1.278811] PPP Deflate Compression module registered
[ 1.278841] PPP MPPE Compression module registered
[ 1.278865] NET: Registered protocol family 24
[ 1.278915] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.278927] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.278948] Rockchip WiFi SYS interface (V1.00) …
[ 1.279036] usbcore: registered new interface driver catc
[ 1.279081] usbcore: registered new interface driver kaweth
[ 1.279099] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.279137] usbcore: registered new interface driver pegasus
[ 1.279182] usbcore: registered new interface driver rtl8150
[ 1.279226] usbcore: registered new interface driver r8152
[ 1.279244] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.279304] usbcore: registered new interface driver hso
[ 1.279355] usbcore: registered new interface driver asix
[ 1.279399] usbcore: registered new interface driver ax88179_178a
[ 1.279443] usbcore: registered new interface driver cdc_ether
[ 1.279486] usbcore: registered new interface driver cdc_eem
[ 1.279532] usbcore: registered new interface driver dm9601
[ 1.279585] usbcore: registered new interface driver smsc75xx
[ 1.279637] usbcore: registered new interface driver smsc95xx
[ 1.279680] usbcore: registered new interface driver gl620a
[ 1.279724] usbcore: registered new interface driver net1080
[ 1.279769] usbcore: registered new interface driver plusb
[ 1.279813] usbcore: registered new interface driver rndis_host
[ 1.279857] usbcore: registered new interface driver cdc_subset
[ 1.279901] usbcore: registered new interface driver zaurus
[ 1.279946] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.280007] usbcore: registered new interface driver int51x1
[ 1.280053] usbcore: registered new interface driver kalmia
[ 1.280116] usbcore: registered new interface driver ipheth
[ 1.280159] usbcore: registered new interface driver sierra_net
[ 1.280199] usbcore: registered new interface driver cx82310_eth
[ 1.280250] usbcore: registered new interface driver cdc_ncm
[ 1.280292] usbcore: registered new interface driver qmi_wwan
[ 1.280334] usbcore: registered new interface driver cdc_mbim
[ 1.281445] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[ 1.298829] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[ 1.299681] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.299702] ehci-pci: EHCI PCI platform driver
[ 1.299785] ehci-platform: EHCI generic platform driver
[ 1.303455] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.303502] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 1.303725] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 1.313426] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.313572] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.313588] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.313601] usb usb1: Product: EHCI Host Controller
[ 1.313613] usb usb1: Manufacturer: Linux 4.4.83 ehci_hcd
[ 1.313624] usb usb1: SerialNumber: fe3c0000.usb
[ 1.314140] hub 1-0:1.0: USB hub found
[ 1.314179] hub 1-0:1.0: 1 port detected
[ 1.314669] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.314703] ohci-platform: OHCI generic platform driver
[ 1.315148] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.315174] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 1.315296] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 1.370905] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.370946] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.370961] usb usb2: Product: Generic Platform OHCI controller
[ 1.370975] usb usb2: Manufacturer: Linux 4.4.83 ohci_hcd
[ 1.370986] usb usb2: SerialNumber: fe3e0000.usb
[ 1.371599] hub 2-0:1.0: USB hub found
[ 1.371647] hub 2-0:1.0: 1 port detected
[ 1.373005] usbcore: registered new interface driver cdc_acm
[ 1.373018] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.373101] usbcore: registered new interface driver usblp
[ 1.373161] usbcore: registered new interface driver cdc_wdm
[ 1.373219] usbcore: registered new interface driver uas
[ 1.373322] usbcore: registered new interface driver usb-storage
[ 1.373375] usbcore: registered new interface driver ums-alauda
[ 1.373479] usbcore: registered new interface driver ums-cypress
[ 1.373534] usbcore: registered new interface driver ums-datafab
[ 1.373590] usbcore: registered new interface driver ums_eneub6250
[ 1.373643] usbcore: registered new interface driver ums-freecom
[ 1.373697] usbcore: registered new interface driver ums-isd200
[ 1.373749] usbcore: registered new interface driver ums-jumpshot
[ 1.373801] usbcore: registered new interface driver ums-karma
[ 1.373854] usbcore: registered new interface driver ums-onetouch
[ 1.373911] usbcore: registered new interface driver ums-sddr09
[ 1.373965] usbcore: registered new interface driver ums-sddr55
[ 1.374018] usbcore: registered new interface driver ums-usbat
[ 1.374127] usbcore: registered new interface driver usbserial
[ 1.374179] usbcore: registered new interface driver usbserial_generic
[ 1.374220] usbserial: USB Serial support registered for generic
[ 1.374276] usbcore: registered new interface driver ch341
[ 1.374316] usbserial: USB Serial support registered for ch341-uart
[ 1.374372] usbcore: registered new interface driver cp210x
[ 1.374410] usbserial: USB Serial support registered for cp210x
[ 1.374479] usbcore: registered new interface driver option
[ 1.374516] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.374680] usbcore: registered new interface driver pl2303
[ 1.374721] usbserial: USB Serial support registered for pl2303
[ 1.374790] usbcore: registered new interface driver trancevibrator
[ 1.374808] usb20_otg: version 3.10a 21-DEC-2012
[ 1.375063] usb20_host: version 3.10a 21-DEC-2012
[ 1.375606] usbcore: registered new interface driver xpad
[ 1.375660] usbcore: registered new interface driver usb_acecad
[ 1.375712] usbcore: registered new interface driver aiptek
[ 1.375760] usbcore: registered new interface driver gtco
[ 1.375806] usbcore: registered new interface driver hanwang
[ 1.375851] usbcore: registered new interface driver kbtab
[ 1.375866] ==gsl_ts_init==
[ 1.375895] ret=0
[ 1.380348] .. rk pwm remotectl v1.1 init
[ 1.380567] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 1.380893] remotectl-pwm ff420030.pwm: set irq err, set support_psci to 0 !!
[ 1.381004] sensor_register_slave:mma8452,id=17
[ 1.381019] sensor_register_slave:lis3dh,id=7
[ 1.381033] sensor_register_slave:mma7660,id=18
[ 1.381046] sensor_register_slave:lsm303d,id=22
[ 1.381060] sensor_register_slave:mpu6880_acc,id=24
[ 1.381073] sensor_register_slave:mpu6500_acc,id=25
[ 1.381087] sensor_register_slave:lsm330_acc,id=26
[ 1.381102] sensor_register_slave:akm8975,id=28
[ 1.381115] sensor_register_slave:akm8963,id=29
[ 1.381129] sensor_register_slave:l3g4200d,id=43
[ 1.381142] sensor_register_slave:l3g20d,id=44
[ 1.381156] sensor_register_slave:ewtsa,id=45
[ 1.381169] sensor_register_slave:lsm330_gyro,id=48
[ 1.381183] sensor_register_slave:cm3217,id=50
[ 1.381196] sensor_register_slave:cm3218,id=51
[ 1.381828] i2c /dev entries driver
[ 1.382885] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 1.382950] fan53555-reg: supplied by vcc5v0_sys
[ 1.385148] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 1.385259] fan53555-reg: supplied by vcc5v0_sys
[ 1.387441] rk808 0-001b: Pmic Chip id: 0x0
[ 1.391109] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.391177] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.391283] DCDC_REG1: supplied by vcc3v3_sys
[ 1.392083] DCDC_REG2: supplied by vcc3v3_sys
[ 1.392657] DCDC_REG3: supplied by vcc3v3_sys
[ 1.392919] DCDC_REG4: supplied by vcc3v3_sys
[ 1.393449] LDO_REG1: supplied by vcc3v3_sys
[ 1.394607] LDO_REG2: supplied by vcc3v3_sys
[ 1.395602] LDO_REG3: supplied by vcc3v3_sys
[ 1.396631] LDO_REG4: supplied by vcc3v3_sys
[ 1.397629] LDO_REG5: supplied by vcc3v3_sys
[ 1.398629] LDO_REG6: supplied by vcc3v3_sys
[ 1.399658] LDO_REG7: supplied by vcc3v3_sys
[ 1.400657] LDO_REG8: supplied by vcc3v3_sys
[ 1.401661] SWITCH_REG1: supplied by vcc3v3_sys
[ 1.401943] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.405787] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 1.406422] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80096fc000
[ 1.407292] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80096fe000
[ 1.407413] rockchip-pinctrl pinctrl: pin gpio4-17 already requested by ff940000.hdmi; cannot claim for ff130000.i2c
[ 1.407432] rockchip-pinctrl pinctrl: pin-145 (ff130000.i2c) status -22
[ 1.407448] rockchip-pinctrl pinctrl: could not request pin 145 (gpio4-17) from group i2c3-xfer on device rockchip-pinctrl
[ 1.407464] rk3x-i2c ff130000.i2c: Error applying setting, reverse things back
[ 1.407954] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff80097d2000
[ 1.418904] fusb302 4-0022: port 0 probe success
[ 1.418958] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80097d4000
[ 1.420251] IR NEC protocol handler initialized
[ 1.420287] IR RC5(x/sz) protocol handler initialized
[ 1.420308] IR RC6 protocol handler initialized
[ 1.420327] IR JVC protocol handler initialized
[ 1.420346] IR Sony protocol handler initialized
[ 1.420363] IR SANYO protocol handler initialized
[ 1.420380] IR Sharp protocol handler initialized
[ 1.420399] IR MCE Keyboard/mouse protocol handler initialized
[ 1.420416] IR XMP protocol handler initialized
[ 1.420544] usbcore: registered new interface driver uvcvideo
[ 1.420555] USB Video Class driver (1.1.1)
[ 1.420577] CamSys driver version: v0.34.3, CamSys head file version: v0.13.0
[ 1.426489] __power_supply_register: Expected proper parent device for ‘test_ac’
[ 1.426673] __power_supply_register: Expected proper parent device for ‘test_battery’
[ 1.427049] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 1.427178] __power_supply_register: Expected proper parent device for ‘test_usb’
[ 1.430178] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 1.431129] device-mapper: uevent: version 1.0.3
[ 1.431575] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 1.431716] Bluetooth: HCI UART driver ver 2.3
[ 1.431732] Bluetooth: HCI UART protocol H4 registered
[ 1.431743] Bluetooth: HCI UART protocol LL registered
[ 1.431758] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 1.431768] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[ 1.431778] rtk_btusb: Register usb char device interface for BT driver
[ 1.432030] usbcore: registered new interface driver rtk_btusb
[ 1.432513] cpu cpu0: leakage=24
[ 1.450309] cpu cpu0: temp=43888, pvtm=150621 (150489 + 132)
[ 1.450746] cpu cpu0: pvtm-sel=2
[ 1.451158] cpu cpu4: leakage=41
[ 1.463467] cpu cpu4: temp=42777, pvtm=155590 (155555 + 35)
[ 1.463596] cpu cpu4: pvtm-sel=2
[ 1.468982] sdhci: Secure Digital Host Controller Interface driver
[ 1.469021] sdhci: Copyright(c) Pierre Ossman
[ 1.469038] Synopsys Designware Multimedia Card Interface Driver
[ 1.470269] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.470427] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.470449] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.470518] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.470560] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.470613] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.470627] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.471752] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.471836] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 1.471857] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 1.471905] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 1.471933] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.472039] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 1.472351] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.480539] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.493480] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.506851] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 1.507332] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.509391] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 1.509434] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 1.536859] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 1.540459] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.545061] usbcore: registered new interface driver usbhid
[ 1.545100] usbhid: USB HID core driver
[ 1.545275] inv_mpu_iio: inv_mpu_init:746
[ 1.548287] ashmem: initialized
[ 1.551850] ff100000.saradc supply vref not found, using dummy regulator
[ 1.554468] rknandbase v1.1 2016-11-08
[ 1.555476] usbcore: registered new interface driver snd-usb-audio
[ 1.557322] rt5640 1-001c: rt5640 have no aux_det_adc_value defined
[ 1.573719] u32 classifier
[ 1.573772] Actions configured
[ 1.573821] Netfilter messages via NETLINK v0.30.
[ 1.573892] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.574290] ctnetlink v0.93: registering with nfnetlink.
[ 1.575178] xt_time: kernel timezone is -0000
[ 1.576416] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.576622] arp_tables: (C) 2002 David S. Miller
[ 1.577320] Initializing XFRM netlink socket
[ 1.577792] NET: Registered protocol family 10
[ 1.579026] mip6: Mobile IPv6
[ 1.579068] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.581082] sit: IPv6 over IPv4 tunneling driver
[ 1.581607] NET: Registered protocol family 17
[ 1.581642] NET: Registered protocol family 15
[ 1.581688] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 1.582309] mmc1: MAN_BKOPS_EN bit is not set
[ 1.582423] Bridge firewalling registered
[ 1.582438] Ebtables v2.0 registered
[ 1.582726] Bluetooth: RFCOMM TTY layer initialized
[ 1.582752] Bluetooth: RFCOMM socket layer initialized
[ 1.582790] Bluetooth: RFCOMM ver 1.11
[ 1.582811] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.582821] Bluetooth: BNEP filters: protocol multicast
[ 1.582845] Bluetooth: BNEP socket layer initialized
[ 1.582859] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.582872] Bluetooth: HIDP socket layer initialized
[ 1.582908] l2tp_core: L2TP core driver, V2.0
[ 1.582928] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.582944] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.583375] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.583499] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[ 1.583511] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.583521] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.583596] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 1.583606] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.583618] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.583690] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.584201] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 1.584245] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 1.584276] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 1.584307] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 1.584688] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.584731] [BT_RFKILL]: BT_WAKE_HOST IRQ fired
[ 1.584751] [BT_RFKILL]: ** disable irq
[ 1.584893] [BT_RFKILL]: bt_default device registered.
[ 1.585044] sensor_register_slave:mpu6880_gyro,id=47
[ 1.585507] Registered cp15_barrier emulation handler
[ 1.585598] Registered setend emulation handler
[ 1.586668] registered taskstats version 1
[ 1.593482] rockchip ion idev is NULL
[ 1.593502] rga2 ff680000.rga: rga ion client create success!
[ 1.593815] rga: Driver loaded successfully ver:3.02
[ 1.595819] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not assigned
[ 1.599655] mmc1: new HS400 MMC card at address 0001
[ 1.600215] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 1.600616] mmcblk1: mmc1:0001 MMC8GB 7.28 GiB
[ 1.600656] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 1.601209] mmcblk1boot0: mmc1:0001 MMC8GB partition 1 4.00 MiB
[ 1.601468] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 1.601520] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 1.601660] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 1.601780] mmcblk1boot1: mmc1:0001 MMC8GB partition 2 4.00 MiB
[ 1.602336] mmcblk1rpmb: mmc1:0001 MMC8GB partition 3 4.00 MiB
[ 1.602752] rkpart: partition size too small (4)
[ 1.602767] parameter: 0x000000000 – 0x000400000 (4 MB)
[ 1.602778] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 1.602788] trust: 0x000800000 – 0x000c00000 (4 MB)
[ 1.602798] misc: 0x000c00000 – 0x001000000 (4 MB)
[ 1.602808] resource: 0x001000000 – 0x002000000 (16 MB)
[ 1.602818] kernel: 0x002000000 – 0x003800000 (24 MB)
[ 1.602828] boot: 0x003800000 – 0x005800000 (32 MB)
[ 1.602838] recovery: 0x005800000 – 0x007800000 (32 MB)
[ 1.602849] backup: 0x007800000 – 0x00e800000 (112 MB)
[ 1.602859] cache: 0x00e800000 – 0x016800000 (128 MB)
[ 1.602868] system: 0x016800000 – 0x076800000 (1536 MB)
[ 1.602879] metadata: 0x076800000 – 0x077800000 (16 MB)
[ 1.602889] baseparamer: 0x077800000 – 0x077c00000 (4 MB)
[ 1.602899] userdata: 0x077c00000 – 0x1d1c00000 (5536 MB)
[ 1.602957] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 1.607095] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[ 1.608127] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops)
[ 1.608165] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.608192] [drm:drm_vblank_init] No driver support for vblank timestamp query.
[ 1.609026] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 1.623627] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 1.750137] usb 1-1: New USB device found, idVendor=1a40, idProduct=0201
[ 1.750239] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.750268] usb 1-1: Product: USB 2.0 Hub [MTT]
[ 1.751573] hub 1-1:1.0: USB hub found
[ 1.751897] hub 1-1:1.0: 7 ports detected
[ 2.091896] vendor storage:20160801 ret = 0
[ 2.093376] rockchip-drm display-subsystem: fb0: frame buffer device
[ 2.109183] mali ff9a0000.gpu: leakage=30
[ 2.133037] mali ff9a0000.gpu: temp=41666, pvtm=122130 (122130 + 0)
[ 2.134549] mali ff9a0000.gpu: pvtm-sel=1
[ 2.136257] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 2.137537] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 284; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 2.139141] mali ff9a0000.gpu: Probed as mali0
[ 2.147527] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 2.147668] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 3
[ 2.148097] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 2.148218] xhci-hcd xhci-hcd.10.auto: irq 233, io mem 0xfe800000
[ 2.148550] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.148584] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.148612] usb usb3: Product: xHCI Host Controller
[ 2.148637] usb usb3: Manufacturer: Linux 4.4.83 xhci-hcd
[ 2.148662] usb usb3: SerialNumber: xhci-hcd.10.auto
[ 2.149934] hub 3-0:1.0: USB hub found
[ 2.150016] hub 3-0:1.0: 1 port detected
[ 2.150750] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 2.150795] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 4
[ 2.150955] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 2.151205] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.151238] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.151264] usb usb4: Product: xHCI Host Controller
[ 2.151289] usb usb4: Manufacturer: Linux 4.4.83 xhci-hcd
[ 2.151314] usb usb4: SerialNumber: xhci-hcd.10.auto
[ 2.152624] hub 4-0:1.0: USB hub found
[ 2.152704] hub 4-0:1.0: 1 port detected
[ 2.155962] xhci-hcd xhci-hcd.10.auto: remove, state 1
[ 2.156025] usb usb4: USB disconnect, device number 1
[ 2.180809] xhci-hcd xhci-hcd.10.auto: Host not halted after 16000 microseconds.
[ 2.180913] xhci-hcd xhci-hcd.10.auto: Host controller not halted, aborting reset.
[ 2.181040] xhci-hcd xhci-hcd.10.auto: USB bus 4 deregistered
[ 2.181080] xhci-hcd xhci-hcd.10.auto: remove, state 1
[ 2.181126] usb usb3: USB disconnect, device number 1
[ 2.182072] xhci-hcd xhci-hcd.10.auto: USB bus 3 deregistered
[ 2.189557] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 2.189658] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 3
[ 2.189982] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 2.190162] xhci-hcd xhci-hcd.11.auto: irq 234, io mem 0xfe900000
[ 2.190413] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.190437] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.190456] usb usb3: Product: xHCI Host Controller
[ 2.190473] usb usb3: Manufacturer: Linux 4.4.83 xhci-hcd
[ 2.190490] usb usb3: SerialNumber: xhci-hcd.11.auto
[ 2.191396] hub 3-0:1.0: USB hub found
[ 2.191453] hub 3-0:1.0: 1 port detected
[ 2.191892] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 2.191924] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 4
[ 2.192035] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 2.192204] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.192226] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.192245] usb usb4: Product: xHCI Host Controller
[ 2.192262] usb usb4: Manufacturer: Linux 4.4.83 xhci-hcd
[ 2.192279] usb usb4: SerialNumber: xhci-hcd.11.auto
[ 2.193093] hub 4-0:1.0: USB hub found
[ 2.193146] hub 4-0:1.0: 1 port detected
[ 2.198051] ehci-platform fe380000.usb: EHCI Host Controller
[ 2.198098] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
[ 2.198379] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 2.207073] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 2.207421] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.207444] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.207463] usb usb5: Product: EHCI Host Controller
[ 2.207480] usb usb5: Manufacturer: Linux 4.4.83 ehci_hcd
[ 2.207497] usb usb5: SerialNumber: fe380000.usb
[ 2.208552] hub 5-0:1.0: USB hub found
[ 2.208655] hub 5-0:1.0: 1 port detected
[ 2.209978] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 2.210022] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6
[ 2.210327] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 2.268108] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.268238] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.268268] usb usb6: Product: Generic Platform OHCI controller
[ 2.268295] usb usb6: Manufacturer: Linux 4.4.83 ohci_hcd
[ 2.268319] usb usb6: SerialNumber: fe3a0000.usb
[ 2.269748] hub 6-0:1.0: USB hub found
[ 2.269831] hub 6-0:1.0: 1 port detected
[ 2.272608] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.272877] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 2.272918] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 2.272982] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.273034] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.273136] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 2.273162] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 2.273833] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 2.287132] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.300573] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 2.318051] asoc-simple-card rt5640-sound: rt5640-aif1 ↔ ff890000.i2s mapping ok
[ 2.325675] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card0/input1
[ 2.328479] asoc-simple-card spdif-sound: dit-hifi ↔ ff870000.spdif mapping ok
[ 2.332547] rk-hdmi-dp-sound hdmi-dp-sound: control 3:0:0:ELD:0 is already present
[ 2.332648] hdmi-audio-codec hdmi-audio-codec.9.auto: ASoC: Failed to add ELD: -16
[ 2.333876] rk-hdmi-dp-sound hdmi-dp-sound: multicodec ↔ ff8a0000.i2s mapping ok
[ 2.333972] hdmi-audio-codec hdmi-audio-codec.9.auto: ASoC: Failed to create Playback debugfs file
[ 2.337198]
[ 2.337290] =======================================================
[ 2.337310] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 2.337328] =======================================================
[ 2.337347] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver 2.20.WFD) init.
[ 2.337369] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 2.337389] [WLAN_RFKILL]: wifi turn on power. -1
[ 2.337405] RTL871X: module init start
[ 2.337422] RTL871X: rtl8188eu v4.3.24_16705.20160509
[ 2.337588] dhd_module_init: in Dongle Host Driver, version 1.363.59.144.10 (r)
[ 2.337631] ======== dhd_wlan_init_plat_data ========
[ 2.337653] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[ 2.337674] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[ 2.337696] usbcore: registered new interface driver rtl8188eu
[ 2.337701] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 2.337714] dhd_wlan_init_gpio: host_oob_irq: 73
[ 2.337719] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[ 2.337723] dhd_wifi_platform_load: Enter
[ 2.337758] Power-up adapter ‘DHD generic adapter’
[ 2.337791] RTL871X: module init ret=0
[ 2.337822] otg_wakelock_init: No USB transceiver found
[ 2.337842] wifi_platform_set_power = 1
[ 2.337863] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 2.337884] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 2.337903] [WLAN_RFKILL]: wifi turn on power. -1
[ 2.338041] sensor_init: Probe name sensors
[ 2.338072] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 2.339674] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:03 UTC (1358499003)
[ 2.341915] It doesn’t contain Rogue gpu
[ 2.347282] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.348945] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.350601] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.353559] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
u?
[ 2.408554] mmc_host mmc2: Bus speed (slot 0) = 200000000Hz (slot req 208000000Hz, actual 200000000HZ div = 0)
