各位大佬,麻烦帮忙看一下这是什么原因导致的,log如下:
# pulseaudio --system -vvvv &
# W: [pulseaudio] main.c: Running in system mode, but --disallow-exit not set.
W: [pulseaudio] main.c: Running in system mode, but --disallow-module-loading not set.
N: [pulseaudio] main.c: Running in system mode, forcibly disabling SHM mode.
N: [pulseaudio] main.c: Running in system mode, forcibly disabling exit idle time.
D: [pulseaudio] core-rtclock.c: Timer slack is set to 50 us.
D: [pulseaudio] core-util.c: setpriority() worked.
I: [pulseaudio] core-util.c: Successfully gained nice level -11.
I: [pulseaudio] main.c: Found user ‘pulse’ (UID 1001) and group ‘pulse’ (GID 1002).
I: [pulseaudio] main.c: Successfully changed user to “pulse”.
I: [pulseaudio] main.c: This is PulseAudio 13.0
D: [pulseaudio] main.c: Compilation host: aarch64-rockchip-linux-gnu
D: [pulseaudio] main.c: Compilation CFLAGS: -I/home/ray/firefly_rockchip/pulseaudio/include -Wall -W -Wextra -pipe -Wno-long-long -Wno-overlength-strings -Wunsafe-loop-optimizations -Wundef -Wformat=2 -Wlogical-op -Wsign-compare -Wformat-security -Wmissing-include-dirs -Wformat-nonliteral -Wpointer-arith -Winit-self -Wdeclaration-after-statement -Wfloat-equal -Wmissing-prototypes -Wredundant-decls -Wmissing-declarations -Wmissing-noreturn -Wshadow -Wendif-labels -Wcast-align -Wstrict-aliasing -Wwrite-strings -Wno-unused-parameter -fno-common -fdiagnostics-show-option -fdiagnostics-color=auto
D: [pulseaudio] main.c: Running on host: Linux aarch64 4.4.143 #3 SMP PREEMPT Fri Dec 11 09:16:25 CST 2020
D: [pulseaudio] main.c: Found 4 CPUs.
I: [pulseaudio] main.c: Page size is 4096 bytes
D: [pulseaudio] main.c: Compiled with Valgrind support: no
D: [pulseaudio] main.c: Running in valgrind mode: no
D: [pulseaudio] main.c: Running in VM: no
D: [pulseaudio] main.c: Running from build tree: no
D: [pulseaudio] main.c: Optimized build: no
D: [pulseaudio] main.c: FASTPATH defined, only fast path asserts disabled.
I: [pulseaudio] main.c: Machine ID is 7514f5d8e8bd5777ab807c7b00000008.
I: [pulseaudio] main.c: Using runtime directory /var/run/pulse.
I: [pulseaudio] main.c: Using state directory /var/lib/pulse.
I: [pulseaudio] main.c: Using modules directory /lib/pulse-13.0/modules.
I: [pulseaudio] main.c: Running in system mode: yes
W: [pulseaudio] main.c: OK, so you are running PA in system mode. Please make sure that you actually do want to do that.
W: [pulseaudio] main.c: Please read http://www.freedesktop.org/wiki/Software/PulseAudio/Documentation/User/WhatIsWrongWithSystemWide/ for an explanation why system mode is usually a bad idea.
W: [pulseaudio] pid.c: Stale PID file, overwriting.
I: [pulseaudio] main.c: System supports high resolution timers
D: [pulseaudio] memblock.c: Using private memory pool with 1024 slots of size 64.0 KiB each, total size is 64.0 MiB, maximum usable slot size is 65472
D: [pulseaudio] module.c: Checking for existence of ‘/lib/pulse-13.0/modules/module-udev-detect.so’: success
D: [pulseaudio] module-udev-detect.c: /dev/snd/controlC1 is accessible: yes
D: [pulseaudio] module-udev-detect.c: /devices/platform/bluetooth-sound/sound/card1 is busy: no
D: [pulseaudio] module-udev-detect.c: Loading module-alsa-card with arguments ‘device_id=“1” name=“1” card_name=“alsa_card.1” namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties=“module-udev-detect.discovered=1”’
I: [pulseaudio] (alsa-lib)utils.c: could not open configuration file /home/ray/firefly_rockchip/bluez-alsa/share/alsa/ucm/rockchip,rk3308-pcm/rockchip,rk3308-pcm.conf
I: [pulseaudio] (alsa-lib)parser.c: error: could not parse configuration for card rockchip,rk3308-pcm
I: [pulseaudio] (alsa-lib)main.c: error: failed to import rockchip,rk3308-pcm use case configuration -2
I: [pulseaudio] alsa-ucm.c: UCM not available for card rockchip,rk3308-pcm
D: [pulseaudio] conf-parser.c: Parsing configuration file ‘/usr/share/pulseaudio/alsa-mixer/profile-sets/default.conf’
D: [pulseaudio] alsa-mixer.c: Looking at profile input:analog-mono
D: [pulseaudio] alsa-mixer.c: Checking for recording on Analog Mono (analog-mono)
D: [pulseaudio] alsa-util.c: Trying hw:1 with SND_PCM_NO_AUTO_FORMAT …
D: [pulseaudio] alsa-util.c: Managed to open hw:1
I: [pulseaudio] alsa-util.c: Disabling tsched mode since BATCH flag is set
D: [pulseaudio] alsa-util.c: snd_pcm_hw_params_set_channels(1) failed: Invalid argument
D: [pulseaudio] alsa-util.c: Trying hw:1 without SND_PCM_NO_AUTO_FORMAT …
D: [pulseaudio] alsa-util.c: Trying plug:hw:1 with SND_PCM_NO_AUTO_FORMAT …
D: [pulseaudio] alsa-util.c: Managed to open plug:hw:1
D: [pulseaudio] alsa-util.c: Trying plug:hw:1 without SND_PCM_NO_AUTO_FORMAT …
I: [pulseaudio] alsa-util.c: Failed to set hardware parameters on plug:hw:1: Invalid argument
D: [pulseaudio] alsa-mixer.c: Caching failure to open input:analog-mono
D: [pulseaudio] alsa-mixer.c: Looking at profile input:analog-stereo
D: [pulseaudio] alsa-mixer.c: Checking for recording on Analog Stereo (analog-stereo)
D: [pulseaudio] alsa-util.c: Trying front:1 with SND_PCM_NO_AUTO_FORMAT …
I: [pulseaudio] (alsa-lib)confmisc.c: Unable to find definition ‘cards.rockchip_rk3308.pcm.front.0:CARD=1’
I: [pulseaudio] (alsa-lib)conf.c: function snd_func_refer returned error: No such file or directory
I: [pulseaudio] (alsa-lib)conf.c: Evaluate error: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM front:1
I: [pulseaudio] alsa-util.c: Error opening PCM device front:1: No such file or directory
D: [pulseaudio] alsa-util.c: Maximum hw buffer size is 2972 ms
D: [pulseaudio] alsa-util.c: Set buffer size first (to 4408 samples), period size second (to 1102 samples).
D: [pulseaudio] alsa-mixer.c: Profile input:analog-stereo supported.
D: [pulseaudio] conf-parser.c: Parsing configuration file ‘/usr/share/pulseaudio/alsa-mixer/paths/analog-input-front-mic.conf’
已解决,以上错误可以忽略,可以正常使用pulseaudio
请问解决方法是什么呢? 有点急,如果解决可以有偿,麻烦看到加下我vx:zyzyz824
