RK3399启动异常,卡住了,大神帮忙看看是什么原因
U-Boot 2017.09-gead7778 (Oct 15 2018 - 17:28:33 +0800)
Model: Firefly-RK3399 Board
DRAM: 3.8 GiB
Relocation Offset is: f7d14000
PMIC: RK808
vdd_center 900000 uV
vdd_cpu_l 900000 uV
pwm-regulator(vdd-log): init 950000 uV
vdd_log 950000 uV
regulator(vdd-log) init 950000 uV
MMC: dwmmc@fe320000: 1, sdhci@fe330000: 0
*** Warning - bad CRC, using default environment
In: serial@ff1a0000
Out: serial@ff1a0000
Err: serial@ff1a0000
mmc_init: -95, time 9
switch to partitions #0, OK
get part misc fail -1
Net: eth0: ethernet@fe300000
android_bootloader_boot_flow Could not find misc partition
Error: Bad gzipped data
FDT load addr 0x10f00000 size 223 KiB
Booting kernel at 0x207f800 with fdt at 3368e00…
## Booting Android Image at 0x0207f800 …
Kernel load addr 0x02080000 size 19361 KiB
## Flattened Device Tree blob at 03368e00
Booting using the fdt blob at 0x3368e00
XIP Kernel Image … OK
Loading Device Tree to 00000000081e5000, end 00000000081fffa6 … OK
Adding bank: start=0x00200000, size=0x08200000
Adding bank: start=0x0a200000, size=0xede00000
[ 0.000000] Linux version 4.4.154 (zhangxf@tchip14) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #4 SMP Sat Oct 13 10:34:01 CST 2018
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f7ed4000 s45800 r8192 d32024 u86016
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 991752
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.mode=emmc androidboot.slot_suffix= androidboot.serialno=12b9ff86e5095a33 rw rootwait earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 console=ttyFIQ0 root=PARTUUID=614e0000-0000 rootfstype=ext4
[ 0.000000] software IO TLB [mem 0xf7e8c000-0xf7ecc000] (0MB) mapped at [ffffffc0f7e8c000-ffffffc0f7ecbfff]
[ 0.000000] Memory: 3937000K/4030464K available (11838K kernel code, 1696K rwdata, 4608K rodata, 1152K init, 769K bss, 93464K reserved, 0K cma-reserved)
[ 0.000000] .init : 0xffffff80090a0000 - 0xffffff80091c0000 ( 1152 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008c10000 ( 11840 KB)
[ 0.000000] .rodata : 0xffffff8008c10000 - 0xffffff80090a0000 ( 4672 KB)
[ 0.000000] .data : 0xffffff80091c0000 - 0xffffff8009368008 ( 1697 KB)
[ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc3e00000 ( 61 MB actual)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc0f8000000 ( 3966 MB)
[ 0.000000] ITS: allocated 65536 Devices @a300000 (psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x000000000a290000
[ 0.000000] CPU0: using LPI pending table @0x000000000a2a0000
[ 0.002139] Console: colour dummy device 80x25
[ 0.002580] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.003569] pid_max: default: 32768 minimum: 301
[ 0.004097] Security Framework initialized
[ 0.004562] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.005203] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.006666] Initializing cgroup subsys devices
[ 0.007115] Initializing cgroup subsys freezer
[ 0.007560] ftrace: allocating 43088 entries in 169 pages
[ 0.114482] sched-energy: Sched-energy-costs installed from DT
[ 0.115049] CPU0: update cpu_capacity 401
[ 0.115501] ASID allocator initialised with 32768 entries
[ 0.119269] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.120605] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.122841] Detected VIPT I-cache on CPU1
[ 0.122874] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.122903] CPU1: using LPI pending table @0x0000000000330000
[ 0.122946] CPU1: update cpu_capacity 401
[ 0.122950] CPU1: Booted secondary processor [410fd034]
[ 0.123493] Detected VIPT I-cache on CPU2
[ 0.123514] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.123542] CPU2: using LPI pending table @0x0000000000360000
[ 0.123569] CPU2: update cpu_capacity 401
[ 0.123573] CPU2: Booted secondary processor [410fd034]
[ 0.124092] Detected VIPT I-cache on CPU3
[ 0.124112] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.124139] CPU3: using LPI pending table @0x00000000003b0000
[ 0.124165] CPU3: update cpu_capacity 401
[ 0.124169] CPU3: Booted secondary processor [410fd034]
[ 0.124714] Detected PIPT I-cache on CPU4
[ 0.124740] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.124782] CPU4: using LPI pending table @0x00000000003e0000
[ 0.124822] CPU4: update cpu_capacity 1024
[ 0.124825] CPU4: Booted secondary processor [410fd082]
[ 0.125377] Detected PIPT I-cache on CPU5
[ 0.125395] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.125432] CPU5: using LPI pending table @0x00000000f2c10000
[ 0.125458] CPU5: update cpu_capacity 1024
[ 0.125461] CPU5: Booted secondary processor [410fd082]
[ 0.125562] Brought up 6 CPUs
[ 0.137917] SMP: Total of 6 processors activated.
[ 0.138368] CPU features: detected feature: GIC system register CPU interface
[ 0.139060] CPU: All CPU(s) started at EL2
[ 0.139493] alternatives: patching kernel code
[ 0.141320] devtmpfs: initialized
[ 0.158492] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.159430] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.160518] pinctrl core: initialized pinctrl subsystem
[ 0.161765] NET: Registered protocol family 16
[ 0.167485] cpuidle: using governor ladder
[ 0.171493] cpuidle: using governor menu
[ 0.171903] Registered FIQ tty driver
[ 0.172580] vdso: 2 pages (1 code @ ffffff8008c16000, 1 data @ ffffff80091c4000)
[ 0.173307] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.174102] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.198428] console [ttyFIQ0] enabled
[ 0.199111] bootconsole [uart0] disabled
[ 0.200038] Registered fiq debugger ttyFIQ0
[ 0.232991] iommu: Adding device ff650000.vpu_service to group 0
[ 0.233588] iommu: Adding device ff660000.rkvdec to group 1
[ 0.234180] iommu: Adding device ff8f0000.vop to group 2
[ 0.234719] iommu: Adding device ff900000.vop to group 3
[ 0.236543] SCSI subsystem initialized
[ 0.237233] usbcore: registered new interface driver usbfs
[ 0.237760] usbcore: registered new interface driver hub
[ 0.238303] usbcore: registered new device driver usb
[ 0.238813] media: Linux media interface: v0.10
[ 0.239251] Linux video capture interface: v2.00
[ 0.239699] pps_core: LinuxPPS API ver. 1 registered
[ 0.240142] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.240967] PTP clock support registered
[ 0.242340] Advanced Linux Sound Architecture Driver Initialized.
[ 0.243364] Bluetooth: Core ver 2.21
[ 0.243702] NET: Registered protocol family 31
[ 0.244110] Bluetooth: HCI device and connection manager initialized
[ 0.244676] Bluetooth: HCI socket layer initialized
[ 0.245119] Bluetooth: L2CAP socket layer initialized
[ 0.245595] Bluetooth: SCO socket layer initialized
[ 0.246642] rockchip-cpuinfo cpuinfo: Serial : 12b9ff86e5095a33
[ 0.247748] clocksource: Switched to clocksource arch_sys_counter
[ 0.297175] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.298089] NET: Registered protocol family 2
[ 0.298929] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.299842] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes)
[ 0.301355] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.302057] UDP hash table entries: 2048 (order: 5, 196608 bytes)
[ 0.302778] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes)
[ 0.303800] NET: Registered protocol family 1
[ 0.304492] RPC: Registered named UNIX socket transport module.
[ 0.305034] RPC: Registered udp transport module.
[ 0.305454] RPC: Registered tcp transport module.
[ 0.305882] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.307545] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.308372] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.312206] Initialise system trusted keyring
[ 0.320709] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.322030] NFS: Registering the id_resolver key type
[ 0.322492] Key type id_resolver registered
[ 0.322880] Key type id_legacy registered
[ 0.323306] fuse init (API version 7.23)
[ 0.324053] SGI XFS with security attributes, no debug enabled
[ 0.329569] NET: Registered protocol family 38
[ 0.330008] Key type asymmetric registered
[ 0.330377] Asymmetric key parser ‘x509’ registered
[ 0.330972] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.331630] io scheduler noop registered
[ 0.331996] io scheduler deadline registered
[ 0.332493] io scheduler cfq registered (default)
[ 0.334497] phy phy-ff770000.syscon:usb2-phy@e450.1: Failed to get VBUS supply regulator
[ 0.336238] phy phy-ff770000.syscon:usb2-phy@e460.3: Failed to get VBUS supply regulator
[ 0.342052] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.342634] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.343227] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 0.885811] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 0.886530] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 0.888292] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 0.889184] rk-vcodec ff650000.vpu_service: probe device
[ 0.889958] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[ 0.891400] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 0.892037] rk-vcodec ff650000.vpu_service: init success
[ 0.892944] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 0.893993] rk-vcodec ff660000.rkvdec: probe device
[ 0.894636] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[ 0.895611] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 0.896203] rk-vcodec ff660000.rkvdec: init success
[ 0.898060] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.898730] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.901017] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.901685] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.903595] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 0.905820] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 35, base_baud = 1500000) is a 16550A
[ 0.906918] rockchip-pinctrl pinctrl: pin gpio4-19 already requested by fiq-debugger; cannot claim for ff1a0000.serial
[ 0.907869] rockchip-pinctrl pinctrl: pin-147 (ff1a0000.serial) status -22
[ 0.908479] rockchip-pinctrl pinctrl: could not request pin 147 (gpio4-19) from group uart2c-xfer on device rockchip-pinctrl
[ 0.909478] dw-apb-uart ff1a0000.serial: Error applying setting, reverse things back
[ 0.910464] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 36, base_baud = 1500000) is a 16550A
[ 0.912251] [drm] Initialized drm 1.1.0 20060810
[ 0.915575] [drm] Rockchip DRM driver version: v1.0.1
[ 0.916360] rockchip-drm display-subsystem: defer getting devfreq
[ 0.917197] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 0.918018] [drm] no mcu-timing node found in /vop@ff900000
[ 0.918517] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8008cb0858)
[ 0.919293] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 0.920035] [drm] no mcu-timing node found in /vop@ff8f0000
[ 0.920531] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8008cb0858)
[ 0.921485] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 0.922107] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 0.922895] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 0.924446] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffffff8008ca5bf8)
[ 0.925176] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.925767] [drm] No driver support for vblank timestamp query.
[ 0.926479] rockchip-drm display-subsystem: failed to parse loader memory
[ 1.295271] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11
[ 1.407502] Console: switching to colour frame buffer device 240x67
[ 1.443278] rockchip-drm display-subsystem: fb0: frame buffer device
[ 1.451546] mali ff9a0000.gpu: Failed to get regulator
[ 1.452019] mali ff9a0000.gpu: Power control initialization failed
[ 1.452929] Unable to detect cache hierarchy for CPU 0
[ 1.454135] brd: module loaded
[ 1.459831] loop: module loaded
[ 1.460700] zram: Added device: zram0
[ 1.461349] lkdtm: No crash points registered, enable through debugfs
[ 1.463292] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[ 1.463893] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[ 1.464478] rockchip-spi ff1d0000.spi: no high_speed pinctrl state
[ 1.465832] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[ 1.636798] wk2xxx_probe() GENA = 0xFF
[ 1.637139] spi driver error!!!
[ 1.637449] wk2xxxspi: probe of spi32766.0 failed with error 1
[ 1.637998] register spi return v = :0
[ 1.639143] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 1.639863] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.640485] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 1.641000] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[ 1.641518] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 1.642235] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 1.642864] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.648408] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.649021] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.649465] Ring mode enabled
[ 1.649746] DMA HW capability register supported
[ 1.650143] Normal descriptors
[ 1.650448] RX Checksum Offload Engine supported (type 2)
[ 1.650944] Wake-Up On Lan supported
[ 1.651305] Enable RX Mitigation via HW Watchdog Timer
[ 1.717044] libphy: stmmac: probed
[ 1.717354] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.717934] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.719638] usbcore: registered new interface driver rndis_wlan
[ 1.720448] Rockchip WiFi SYS interface (V1.00) …
[ 1.720978] usbcore: registered new interface driver rtl8150
[ 1.721512] usbcore: registered new interface driver r8152
[ 1.722053] usbcore: registered new interface driver asix
[ 1.722564] usbcore: registered new interface driver ax88179_178a
[ 1.723146] usbcore: registered new interface driver cdc_ether
[ 1.723693] usbcore: registered new interface driver rndis_host
[ 1.724288] usbcore: registered new interface driver cdc_ncm
[ 1.724832] usbcore: registered new interface driver qmi_wwan
[ 1.725376] usbcore: registered new interface driver cdc_mbim
[ 1.730590] rockchip-dwc3 usb@fe800000: fail to get drvdata hcd
[ 1.736244] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[ 1.737912] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.738496] ehci-pci: EHCI PCI platform driver
[ 1.738966] ehci-platform: EHCI generic platform driver
[ 1.742772] ehci-platform fe380000.usb: EHCI Host Controller
[ 1.743450] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[ 1.744260] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 1.750768] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 1.751467] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.752080] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.752723] usb usb1: Product: EHCI Host Controller
[ 1.753166] usb usb1: Manufacturer: Linux 4.4.154 ehci_hcd
[ 1.753657] usb usb1: SerialNumber: fe380000.usb
[ 1.754557] hub 1-0:1.0: USB hub found
[ 1.754935] hub 1-0:1.0: 1 port detected
[ 1.759188] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.759886] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[ 1.760673] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 1.766767] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.767454] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.768065] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.768708] usb usb2: Product: EHCI Host Controller
[ 1.769151] usb usb2: Manufacturer: Linux 4.4.154 ehci_hcd
[ 1.769642] usb usb2: SerialNumber: fe3c0000.usb
[ 1.770508] hub 2-0:1.0: USB hub found
[ 1.770892] hub 2-0:1.0: 1 port detected
[ 1.771784] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.772347] ohci-platform: OHCI generic platform driver
[ 1.773170] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 1.773951] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[ 1.774724] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 1.829908] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.830507] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.831161] usb usb3: Product: Generic Platform OHCI controller
[ 1.831688] usb usb3: Manufacturer: Linux 4.4.154 ohci_hcd
[ 1.832187] usb usb3: SerialNumber: fe3a0000.usb
[ 1.833227] hub 3-0:1.0: USB hub found
[ 1.833606] hub 3-0:1.0: 1 port detected
[ 1.834814] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.835717] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[ 1.836541] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 1.891978] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.892586] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.893242] usb usb4: Product: Generic Platform OHCI controller
[ 1.893781] usb usb4: Manufacturer: Linux 4.4.154 ohci_hcd
[ 1.894273] usb usb4: SerialNumber: fe3e0000.usb
[ 1.895303] hub 4-0:1.0: USB hub found
[ 1.895674] hub 4-0:1.0: 1 port detected
[ 1.897440] usbcore: registered new interface driver cdc_acm
[ 1.897956] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.898717] usbcore: registered new interface driver cdc_wdm
[ 1.899291] usbcore: registered new interface driver uas
[ 1.899931] usbcore: registered new interface driver usb-storage
[ 1.900567] usbcore: registered new interface driver usbserial
[ 1.901139] usbcore: registered new interface driver usbserial_generic
[ 1.901765] usbserial: USB Serial support registered for generic
[ 1.902351] usbcore: registered new interface driver cp210x
[ 1.902890] usbserial: USB Serial support registered for cp210x
[ 1.903505] usbcore: registered new interface driver ftdi_sio
[ 1.904063] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.904977] usbcore: registered new interface driver keyspan
[ 1.905509] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 1.906252] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 1.906944] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 1.907622] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 1.908342] usbcore: registered new interface driver option
[ 1.908879] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.909846] usbcore: registered new interface driver oti6858
[ 1.910377] usbserial: USB Serial support registered for oti6858
[ 1.910978] usbcore: registered new interface driver pl2303
[ 1.911498] usbserial: USB Serial support registered for pl2303
[ 1.912106] usbcore: registered new interface driver qcserial
[ 1.912648] usbserial: USB Serial support registered for Qualcomm USB modem
[ 1.913359] usbcore: registered new interface driver sierra
[ 1.913893] usbserial: USB Serial support registered for Sierra USB modem
[ 1.915592] ==gsl_ts_init==
[ 1.915897] ret=0
[ 1.916466] usbcore: registered new interface driver usbtouchscreen
[ 1.917453] .. rk pwm remotectl v1.1 init
[ 1.918167] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 1.919381] sensor_register_slave:mma8452,id=17
[ 1.919819] sensor_register_slave:lis3dh,id=7
[ 1.920214] sensor_register_slave:mma7660,id=18
[ 1.920630] sensor_register_slave:lsm303d,id=22
[ 1.921058] sensor_register_slave:gs_mc3230,id=23
[ 1.921478] [Gsensor] gsensor_init
[ 1.921815] sensor_register_slave:mpu6880_acc,id=24
[ 1.922255] sensor_register_slave:mpu6500_acc,id=25
[ 1.922694] sensor_register_slave:lsm330_acc,id=26
[ 1.923145] sensor_register_slave:akm8975,id=30
[ 1.923562] sensor_register_slave:akm8963,id=31
[ 1.923988] sensor_register_slave:l3g4200d,id=45
[ 1.924405] sensor_register_slave:l3g20d,id=46
[ 1.924820] sensor_register_slave:ewtsa,id=47
[ 1.925215] sensor_register_slave:lsm330_gyro,id=51
[ 1.925655] sensor_register_slave:cm3217,id=53
[ 1.926070] sensor_register_slave:cm3218,id=54
[ 1.927085] i2c /dev entries driver
[ 1.929009] fan53555-regulator 0-0040: Failed to get chip ID!
[ 1.930057] fan53555-regulator 0-0041: Failed to get chip ID!
[ 1.931485] rk808 0-001b: Pmic Chip id: 0x0
[ 1.935544] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.936178] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.936904] DCDC_REG1: supplied by vcc3v3_sys
[ 1.938229] DCDC_REG2: supplied by vcc3v3_sys
[ 1.939357] DCDC_REG3: supplied by vcc3v3_sys
[ 1.940193] DCDC_REG4: supplied by vcc3v3_sys
[ 1.941200] LDO_REG1: supplied by vcc3v3_sys
[ 1.942883] LDO_REG2: supplied by vcc3v3_sys
[ 1.943493] vcc2v8_dvp: Bringing 3000000uV into 2800000-2800000uV
[ 1.945134] LDO_REG3: supplied by vcc3v3_sys
[ 1.946677] LDO_REG4: supplied by vcc3v3_sys
[ 1.948251] LDO_REG5: supplied by vcc3v3_sys
[ 1.949821] LDO_REG6: supplied by vcc3v3_sys
[ 1.951376] LDO_REG7: supplied by vcc3v3_sys
[ 1.952942] LDO_REG8: supplied by vcc3v3_sys
[ 1.954495] SWITCH_REG1: supplied by vcc3v3_sys
[ 1.955373] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.959637] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 1.960872] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80095c8000
[ 1.962389] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80095ca000
[ 1.963763] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80095cc000
[ 1.966015] IR NEC protocol handler initialized
[ 1.966970] usbcore: registered new interface driver uvcvideo
[ 1.967481] USB Video Class driver (1.1.1)
[ 1.971393] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 1.972446] rockchip-thermal ff260000.tsadc: tsadc is probed successfully!
[ 1.973891] Bluetooth: Virtual HCI driver ver 1.5
[ 1.974504] Bluetooth: HCI UART driver ver 2.3
[ 1.974920] Bluetooth: HCI UART protocol H4 registered
[ 1.975376] Bluetooth: HCI UART protocol LL registered
[ 1.975843] Bluetooth: HCI UART protocol ATH3K registered
[ 1.976413] usbcore: registered new interface driver bfusb
[ 1.976990] usbcore: registered new interface driver btusb
[ 1.978149] cpu cpu0: leakage=28
[ 1.980400] cpu cpu4: leakage=50
[ 1.980827] cpu cpu4: Failed to get reg
[ 1.982786] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 1.984461] cpu cpu4: Failed to set regulator for cpu4: -517
[ 1.985326] cpu cpu5: Failed to set regulator for cpu5: -517
[ 1.986850] sdhci: Secure Digital Host Controller Interface driver
[ 1.987397] sdhci: Copyright(c) Pierre Ossman
[ 1.987807] Synopsys Designware Multimedia Card Interface Driver
[ 1.989604] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.990286] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.990917] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.991484] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.992376] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.993196] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.993762] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.995588] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.996319] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 1.996946] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 1.997503] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 1.998389] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.999256] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 2.000815] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.003350] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 2.003922] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 2.030846] mmc0: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 2.032906] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.033861] usbcore: registered new interface driver usbhid
[ 2.034359] usbhid: USB HID core driver
[ 2.034863] inv_mpu_iio: inv_mpu_init:746
[ 2.036524] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[ 2.040038] usbcore: registered new interface driver snd-usb-audio
[ 2.042086] rt5640 1-001c: Can not read property hp_det_gpio
[ 2.042591] rt5640 1-001c: Can not read property: linein-mute.
[ 2.087326] mmc0: MAN_BKOPS_EN bit is not set
[ 2.101022] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 2.102569] mmcblk0: mmc0:0001 DAY3XB 14.5 GiB
[ 2.103707] mmcblk0boot0: mmc0:0001 DAY3XB partition 1 4.00 MiB
[ 2.103907] rk-hdmi-dp-sound hdmi-dp-sound: i2s-hifi ↔ ff8a0000.i2s mapping ok
[ 2.105836] mmcblk0boot1: mmc0:0001 DAY3XB partition 2 4.00 MiB
[ 2.106795] Initializing XFRM netlink socket
[ 2.107032] mmcblk0rpmb: mmc0:0001 DAY3XB partition 3 4.00 MiB
[ 2.108382] NET: Registered protocol family 10
[ 2.110491] NET: Registered protocol family 17
[ 2.110944] NET: Registered protocol family 15
[ 2.111788] mmcblk0: p1 p2 p3 p4 p5
[ 2.111801] Bluetooth: RFCOMM socket layer initialized
[ 2.111823] Bluetooth: RFCOMM ver 1.11
[ 2.111851] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.111859] Bluetooth: HIDP socket layer initialized
[ 2.111929] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.112232] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 2.112279] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[ 2.112282] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 2.112285] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 2.112342] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 2.112349] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 2.112352] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 2.112357] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 2.112411] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.112759] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 2.112790] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 2.112813] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 2.112835] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 2.113793] [BT_RFKILL]: Request irq for bt wakeup host
[ 2.113845] [BT_RFKILL]: ** disable irq
[ 2.113995] [BT_RFKILL]: bt_default device registered.
[ 2.114087] Key type dns_resolver registered
[ 2.114519] sensor_register_slave:mpu6880_gyro,id=50
[ 2.114538] Error: Driver ‘ov4689’ is already registered, aborting…
[ 2.114549] Error: Driver ‘ov13850’ is already registered, aborting…
[ 2.115353] Registered cp15_barrier emulation handler
[ 2.115974] Registered setend emulation handler
[ 2.117724] vendor storage:20160801 ret = 0
[ 2.118197] Loading compiled-in X.509 certificates
[ 2.119234] mali ff9a0000.gpu: Failed to get regulator
[ 2.119239] mali ff9a0000.gpu: Power control initialization failed
[ 2.124335] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller
[ 2.124682] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 5
[ 2.124887] xhci-hcd xhci-hcd.7.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 2.124958] xhci-hcd xhci-hcd.7.auto: irq 229, io mem 0xfe800000
[ 2.125159] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.125167] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.125173] usb usb5: Product: xHCI Host Controller
[ 2.125179] usb usb5: Manufacturer: Linux 4.4.154 xhci-hcd
[ 2.125185] usb usb5: SerialNumber: xhci-hcd.7.auto
[ 2.125914] hub 5-0:1.0: USB hub found
[ 2.125955] hub 5-0:1.0: 1 port detected
[ 2.126366] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller
[ 2.126551] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 6
[ 2.126632] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 2.126780] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.126787] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.126793] usb usb6: Product: xHCI Host Controller
[ 2.126799] usb usb6: Manufacturer: Linux 4.4.154 xhci-hcd
[ 2.126805] usb usb6: SerialNumber: xhci-hcd.7.auto
[ 2.127399] hub 6-0:1.0: USB hub found
[ 2.127430] hub 6-0:1.0: 1 port detected
[ 2.132972] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller
[ 2.133235] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 7
[ 2.133409] xhci-hcd xhci-hcd.8.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 2.133472] xhci-hcd xhci-hcd.8.auto: irq 230, io mem 0xfe900000
[ 2.133667] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.133675] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.133681] usb usb7: Product: xHCI Host Controller
[ 2.133687] usb usb7: Manufacturer: Linux 4.4.154 xhci-hcd
[ 2.133693] usb usb7: SerialNumber: xhci-hcd.8.auto
[ 2.134344] hub 7-0:1.0: USB hub found
[ 2.134380] hub 7-0:1.0: 1 port detected
[ 2.134792] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller
[ 2.135013] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 8
[ 2.135092] usb usb8: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 2.135227] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.135235] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.135241] usb usb8: Product: xHCI Host Controller
[ 2.135247] usb usb8: Manufacturer: Linux 4.4.154 xhci-hcd
[ 2.135253] usb usb8: SerialNumber: xhci-hcd.8.auto
[ 2.135889] hub 8-0:1.0: USB hub found
[ 2.135922] hub 8-0:1.0: 1 port detected
[ 2.137833] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.137873] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 2.137886] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 2.137926] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.137947] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.138035] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 2.138040] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 2.138425] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 2.148874] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.159854] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 2.161896] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.162570] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 2.163190] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 2.163730] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 2.164629] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.165517] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 2.166550] dwmmc_rockchip fe320000.dwmmc: allocated mmc-pwrseq
[ 2.167277] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 2.168096] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 2.180148] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.186084] mmc_host mmc1: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[ 2.192033] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 2.193298] rockchip-dmc dmc: Failed to get leakage
[ 2.193832] rockchip-dmc dmc: Failed to get pvtm
[ 2.194831] rockchip-dmc dmc: could not find power_model node
[ 2.195694] rt5640 1-001c: Can not read property hp_det_gpio
[ 2.196216] rt5640 1-001c: Can not read property: linein-mute.
[ 2.224109] mmc_host mmc1: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[ 2.251085] rockchip-spdif ff870000.spdif: Missing dma channel for stream: 0
[ 2.251710] rockchip-spdif ff870000.spdif: ASoC: pcm constructor failed: -22
[ 2.252348] asoc-simple-card spdif-sound: ASoC: can’t create pcm ff870000.spdif-dit-hifi :-22
[ 2.253105] asoc-simple-card spdif-sound: ASoC: failed to instantiate card -22
[ 2.253936] asoc-simple-card: probe of spdif-sound failed with error -22
[ 2.254879] mali ff9a0000.gpu: Failed to get regulator
[ 2.255335] mali ff9a0000.gpu: Power control initialization failed
[ 2.256664]
[ 2.256779] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.2 (r)
[ 2.256784] ======== dhd_wlan_init_plat_data ========
[ 2.256787] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[ 2.256790] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[ 2.256793] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 2.256799] dhd_wlan_init_gpio: host_oob_irq: 68
[ 2.256802] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[ 2.256804] dhd_wifi_platform_load: Enter
[ 2.256823] Power-up adapter ‘DHD generic adapter’
[ 2.256862] wifi_platform_set_power = 1
[ 2.256865] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 2.256869] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 2.256872] [WLAN_RFKILL]: wifi turn on power. -1
[ 2.262604] =======================================================
[ 2.263158] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 2.263705] =======================================================
[ 2.264260] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver v5.2.2.3_24783.20171030) init.
[ 2.265057] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 2.265478] [WLAN_RFKILL]: wifi turn on power. -1
[ 2.265904] RTW: module init start
[ 2.266209] RTW: rtl8188eu v5.2.2.3_24783.20171030
[ 2.266630] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 2.267356] usbcore: registered new interface driver rtl8188eu
[ 2.267887] RTW: module init ret=0
[ 2.268936] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[ 2.270269] rt5640 1-001c: Can not read property hp_det_gpio
[ 2.270794] rt5640 1-001c: Can not read property: linein-mute.
[ 2.273089] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:55:20 UTC (1358499320)
u 2.303626]
[ 2.325057] mali ff9a0000.gpu: Failed to get regulator
[ 2.325517] mali ff9a0000.gpu: Power control initialization failed
启动到这儿就不往下跑了,大神帮忙看看是什么原因
