我下载了这个网络上FirePrime最新的SDK,fireprime_android5.1_git_20170624.7z,编译以后,MiPi屏点不亮,跟踪代码,发现都没有调用rk32_dsi_enable函数,
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Linux version 3.10.0 (root@ubuntu) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #18 SMP PREEMPT Thu Jun 29 01:25:51 PDT 2017
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] Machine: Rockchip RK3128, model: rockchip,rk3128
[ 0.000000] rockchip_uboot_logo_setup: mem: 2000000@9dc00000, offset:0
[ 0.000000] rockchip_uboot_mem_reserve: reserve 2000000@9dc00000 for uboot logo
[ 0.000000] ion heap(cma): base(0) size(800000) align(0)
[ 0.000000] cma: CMA: reserved 8 MiB at 9d400000
[ 0.000000] ion_reserve: cma reserved base 9d400000 size 8388608
[ 0.000000] cma: CMA: reserved 16 MiB at 7f000000
[ 0.000000] Boot mode: REBOOT (6) flag: LOADER (0xc3524201)
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1662000 s14016 r8192 d14656 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 261120
[ 0.000000] Kernel command line: vmalloc=496M rockchip_jtag console=ttyFIQ0,115200 earlyprintk androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00006000@0x0000E000(kernel),0x00006000@0x00014000(boot),0x00010000@0x0001A000(recovery),0x00020000@0x0002A000(backup),0x00040000@0x0004A000(cache),0x001FE000@0x0008A000(userdata),0x00008000@0x00288000(metadata),0x00002000@0x00290000(kpanic),0x00200000@0x00292000(system),0x00020000@0x00492000(radical_update),-@0x004B2000(user) storagemedia=emmc uboot_logo=0x02000000@0x9dc00000 loader.timestamp=2015-12-28_14:53:17
[ 0.000000] rockchip jtag enabled
[ 0.000000] allocated 2097152 bytes of page_cgroup
[ 0.000000] Memory: 1024MB = 1024MB total
[ 0.000000] Memory: 964124k/964124k available, 84452k reserved, 483328K highmem
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0b9d234 (11861 kB)
[ 0.000000] .init : 0xc0b9e000 - 0xc0bf66c0 ( 354 kB)
[ 0.000000] .data : 0xc0bf8000 - 0xc0d117b8 (1126 kB)
[ 0.000000] .bss : 0xc0d117b8 - 0xc0e32a3c (1157 kB)
[ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000
[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1
[ 0.000000] rkclk_init_clks: cnt_parent = 25
[ 0.000000] rkclk_init_clks: cnt_rate = 17
[ 0.000000] process version: 0
[ 0.000000] channel:0, lkg:27
[ 0.000000] target-temp:85
[ 0.000000] FirePrime hardware version: V01
[ 0.549136] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.549163] pid_max: default: 32768 minimum: 301
[ 0.549370] Security Framework initialized
[ 0.549398] SELinux: Initializing.
[ 0.549535] Mount-cache hash table entries: 512
[ 0.550754] Initializing cgroup subsys debug
[ 0.550781] Initializing cgroup subsys memory
[ 0.550831] Initializing cgroup subsys freezer
[ 0.550891] CPU: Testing write buffer coherency: ok
[ 0.551413] /cpus/cpu@0 missing clock-frequency property
[ 0.551442] /cpus/cpu@1 missing clock-frequency property
[ 0.551461] /cpus/cpu@2 missing clock-frequency property
[ 0.551480] /cpus/cpu@3 missing clock-frequency property
[ 0.551583] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.551655] Setting up static identity map for 0xc0849648 - 0xc08496a0
[ 0.553781] last_log: 0x7e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x1796 (version 3.0)
[ 0.626831] CPU1: Booted secondary processor
[ 0.626886] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.646528] CPU2: Booted secondary processor
[ 0.646574] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.666286] CPU3: Booted secondary processor
[ 0.666330] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.666515] Brought up 4 CPUs
[ 0.666567] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.666582] CPU: All CPU(s) started in SVC mode.
[ 0.667995] devtmpfs: initialized
[ 0.678159] pinctrl core: initialized pinctrl subsystem
[ 0.678660] regulator-dummy: no parameters
[ 0.680174] NET: Registered protocol family 16
[ 0.683614] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.684257] ion_snapshot: 0x7e990000 map to 0xe0907000 and copy to 0xc0e0df44 (version 0.1)
[ 0.684484] Registered FIQ tty driver
[ 0.686883] console [ttyFIQ0] enabled
[ 0.687217] Registered fiq debugger ttyFIQ0
[ 0.688988] rockchip_get_bank_data:name=/pinctrl@20008000/gpio0@2007c000 start=0x2007c000,end=0x2007c0ff
[ 0.689126] rockchip_get_bank_data:name=/pinctrl@20008000/gpio1@20080000 start=0x20080000,end=0x200800ff
[ 0.689210] rockchip_get_bank_data:name=/pinctrl@20008000/gpio2@20084000 start=0x20084000,end=0x200840ff
[ 0.689287] rockchip_get_bank_data:name=/pinctrl@20008000/gpio3@20088000 start=0x20088000,end=0x200880ff
[ 0.689374] rockchip_get_bank_data:name=/pinctrl@20008000/gpio15@2008A000 start=0x20086000,end=0x200860ff
[ 0.689447] rockchip_pinctrl_probe:name=rk312x-GPIO,type=5
[ 0.689477] rockchip_pinctrl_probe:name=base start=0x20008000,end=0x200080a7
[ 0.689506] rockchip_pinctrl_probe:name=mux start=0x200080a8,end=0x200080f3
[ 0.689535] rockchip_pinctrl_probe:name=pull start=0x20008118,end=0x20008137
[ 0.689563] rockchip_pinctrl_probe:name=drv start=0x20008100,end=0x20008103
[ 0.692236] rockchip_pinctrl_probe:init ok
[ 0.699598] rk_iommu 1010e300.vop_mmu: (vop) Enter
[ 0.699652] rk_iommu 1010e300.vop mmu irq
[ 0.699744] rk_iommu 1010e300.vop_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.699774] rk_iommu 1010e300.vop_mmu: (vop) Initialized
[ 0.700045] rk_iommu 10104440.hevc_mmu: (hevc) Enter
[ 0.700187] rk_iommu 10104440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.700219] rk_iommu 10104440.hevc_mmu: (hevc) Initialized
[ 0.700495] rk_iommu 10106800.vpu_mmu: (vpu) Enter
[ 0.700620] rk_iommu 10106800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.700650] rk_iommu 10106800.vpu_mmu: (vpu) Initialized
[ 0.700909] rk_iommu 10108800.iep_mmu: (iep) Enter
[ 0.701033] rk_iommu 10108800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.701062] rk_iommu 10108800.iep_mmu: (iep) Initialized
[ 0.703137] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.703168] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.703454] DDR DEBUG: version 1.02 20140828
[ 0.703478] DDR DEBUG: DRAM Type:DDR3
[ 0.703503] DDR DEBUG: 1 CS, ROW=15, Bank=8, COL=10, Total Capability=1024MB
[ 0.703549] DDR DEBUG: init success!!! freq=300MHz
[ 0.757130] bio: create slab at 0
[ 0.758255] Rockchip hdmi driver version 2.0
[ 0.760107] SCSI subsystem initialized
[ 0.760475] usbcore: registered new interface driver usbfs
[ 0.760593] usbcore: registered new interface driver hub
[ 0.760808] usbcore: registered new device driver usb
[ 0.761837] gpiod_request: flags 0, gpio 32, desc c0dfa558
[ 0.761918] gpiod_request: flags 0, gpio 32, desc c0dfa150
[ 0.762774] gpiod_request: flags 0, gpio 32, desc c0df9ff4
[ 0.762835] gpiod_request: flags 0, gpio 32, desc c0df9fe8
[ 0.763092] rockchip_i2c 20072000.i2c: i2c-0: Rockchip I2C adapter
[ 0.765265] media: Linux media interface: v0.10
[ 0.765355] Linux video capture interface: v2.00
[ 0.765582] pps_core: LinuxPPS API ver. 1 registered
[ 0.765608] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.765656] PTP clock support registered
[ 0.765751] i2c-core: driver [bq24296] using legacy suspend method
[ 0.765776] i2c-core: driver [bq24296] using legacy resume method
[ 0.767155] Rockchip ion module is successfully loaded (v1.1)
[ 0.767435] Advanced Linux Sound Architecture Driver Initialized.
[ 0.768190] Bluetooth: Core ver 2.16
[ 0.768268] NET: Registered protocol family 31
[ 0.768289] Bluetooth: HCI device and connection manager initialized
[ 0.768324] Bluetooth: HCI socket layer initialized
[ 0.768354] Bluetooth: L2CAP socket layer initialized
[ 0.768408] Bluetooth: SCO socket layer initialized
[ 0.768840] cfg80211: Calling CRDA to update world regulatory domain
[ 0.770810] rk_mipi_screen_init_dt: lcd->screen_init = 1.
[ 0.770843] rk_mipi_screen_init_dt: mipi_lcd->dsi_lane = 2.
[ 0.770866] rk_mipi_screen_init_dt: lcd->screen->hs_tx_clk = 500000000.
[ 0.770889] rk_mipi_screen_init_dt: lcd->screen.mipi_dsi_num = 1.
[ 0.770976] rk_mipi_screen_init_dt: lcd->screen->lcd_rst_delay = 10.
[ 0.771038] gpiod_request: flags 0, gpio 32, desc c0dfa1bc
[ 0.771073] lcd->lcd_rst_gpio=39,dsi->lcd_rst_atv_val=1
[ 0.771095] rk_mipi_screen_init_dt: Can not read property: mipi_lcd_en.
[ 0.771177]
[ 0.771177] childnode->name =rockchip,on-cmds1:length=7
[ 0.771208] cmd[1]=39,
[ 0.771224] cmd[2]=ff,cmd[3]=ff,
[ 0.771251] cmd[4]=98,cmd[5]=06,
[ 0.771276] cmd[6]=04,cmd[7]=01,
[ 0.771301] dcs_cmd->dcs_cmd.cmd_len=7
[ 0.771327]
[ 0.771327] childnode->name =rockchip,on-cmds2:length=3
[ 0.771357] cmd[1]=15,
[ 0.771373] cmd[2]=08,cmd[3]=10,
[ 0.771398] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.771423]
[ 0.771423] childnode->name =rockchip,on-cmds3:length=3
[ 0.771452] cmd[1]=15,
[ 0.771468] cmd[2]=21,cmd[3]=01,
[ 0.771493] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.771517]
[ 0.771517] childnode->name =rockchip,on-cmds4:length=3
[ 0.771547] cmd[1]=15,
[ 0.771563] cmd[2]=30,cmd[3]=02,
[ 0.771588] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.771613]
[ 0.771613] childnode->name =rockchip,on-cmds5:length=3
[ 0.771643] cmd[1]=15,
[ 0.771658] cmd[2]=31,cmd[3]=02,
[ 0.771684] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.771709]
[ 0.771709] childnode->name =rockchip,on-cmds6:length=3
[ 0.771739] cmd[1]=15,
[ 0.771755] cmd[2]=40,cmd[3]=15,
[ 0.771780] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.771804]
[ 0.771804] childnode->name =rockchip,on-cmds7:length=3
[ 0.771834] cmd[1]=15,
[ 0.771850] cmd[2]=41,cmd[3]=33,
[ 0.771875] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.771900]
[ 0.771900] childnode->name =rockchip,on-cmds8:length=3
[ 0.771930] cmd[1]=15,
[ 0.771946] cmd[2]=42,cmd[3]=03,
[ 0.771971] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.771995]
[ 0.771995] childnode->name =rockchip,on-cmds9:length=3
[ 0.772025] cmd[1]=15,
[ 0.772040] cmd[2]=43,cmd[3]=09,
[ 0.772066] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.772090]
[ 0.772090] childnode->name =rockchip,on-cmds10:length=3
[ 0.772120] cmd[1]=15,
[ 0.772136] cmd[2]=44,cmd[3]=09,
[ 0.772161] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.772186]
[ 0.772186] childnode->name =rockchip,on-cmds11:length=3
[ 0.772216] cmd[1]=15,
[ 0.772232] cmd[2]=50,cmd[3]=78,
[ 0.772257] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.772282]
[ 0.772282] childnode->name =rockchip,on-cmds12:length=3
[ 0.772311] cmd[1]=15,
[ 0.772327] cmd[2]=51,cmd[3]=78,
[ 0.772352] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.772377]
[ 0.772377] childnode->name =rockchip,on-cmds13:length=3
[ 0.772407] cmd[1]=15,
[ 0.772423] cmd[2]=52,cmd[3]=00,
[ 0.772448] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.772472]
[ 0.772472] childnode->name =rockchip,on-cmds14:length=3
[ 0.772503] cmd[1]=15,
[ 0.772518] cmd[2]=53,cmd[3]=79,
[ 0.772543] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.772568]
[ 0.772568] childnode->name =rockchip,on-cmds15:length=3
[ 0.772598] cmd[1]=15,
[ 0.772614] cmd[2]=54,cmd[3]=00,
[ 0.772639] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.772664]
[ 0.772664] childnode->name =rockchip,on-cmds16:length=3
[ 0.772694] cmd[1]=15,
[ 0.772709] cmd[2]=55,cmd[3]=83,
[ 0.772735] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.772770]
[ 0.772770] childnode->name =rockchip,on-cmds17:length=3
[ 0.772801] cmd[1]=15,
[ 0.772817] cmd[2]=57,cmd[3]=50,
[ 0.772843] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.772867]
[ 0.772867] childnode->name =rockchip,on-cmds18:length=3
[ 0.772897] cmd[1]=15,
[ 0.772913] cmd[2]=60,cmd[3]=07,
[ 0.772938] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.772963]
[ 0.772963] childnode->name =rockchip,on-cmds19:length=3
[ 0.772993] cmd[1]=15,
[ 0.773008] cmd[2]=61,cmd[3]=00,
[ 0.773033] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.773058]
[ 0.773058] childnode->name =rockchip,on-cmds20:length=3
[ 0.773087] cmd[1]=15,
[ 0.773103] cmd[2]=62,cmd[3]=08,
[ 0.773128] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.773153]
[ 0.773153] childnode->name =rockchip,on-cmds21:length=3
[ 0.773183] cmd[1]=15,
[ 0.773199] cmd[2]=63,cmd[3]=00,
[ 0.773224] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.773248]
[ 0.773248] childnode->name =rockchip,on-cmds22:length=3
[ 0.773279] cmd[1]=15,
[ 0.773295] cmd[2]=a0,cmd[3]=00,
[ 0.773320] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.773344]
[ 0.773344] childnode->name =rockchip,on-cmds23:length=3
[ 0.773374] cmd[1]=15,
[ 0.773390] cmd[2]=a1,cmd[3]=07,
[ 0.773415] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.773439]
[ 0.773439] childnode->name =rockchip,on-cmds24:length=3
[ 0.773469] cmd[1]=15,
[ 0.773485] cmd[2]=a2,cmd[3]=11,
[ 0.773510] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.773535]
[ 0.773535] childnode->name =rockchip,on-cmds25:length=3
[ 0.773566] cmd[1]=15,
[ 0.773581] cmd[2]=a3,cmd[3]=10,
[ 0.773607] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.773631]
[ 0.773631] childnode->name =rockchip,on-cmds26:length=3
[ 0.773661] cmd[1]=15,
[ 0.773677] cmd[2]=a4,cmd[3]=0a,
[ 0.773702] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.773727]
[ 0.773727] childnode->name =rockchip,on-cmds27:length=3
[ 0.773757] cmd[1]=15,
[ 0.773772] cmd[2]=a5,cmd[3]=17,
[ 0.773799] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.773823]
[ 0.773823] childnode->name =rockchip,on-cmds28:length=3
[ 0.773853] cmd[1]=15,
[ 0.773868] cmd[2]=a6,cmd[3]=0a,
[ 0.773893] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.773918]
[ 0.773918] childnode->name =rockchip,on-cmds29:length=3
[ 0.773948] cmd[1]=15,
[ 0.773964] cmd[2]=a7,cmd[3]=0a,
[ 0.773990] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.774014]
[ 0.774014] childnode->name =rockchip,on-cmds30:length=3
[ 0.774045] cmd[1]=15,
[ 0.774060] cmd[2]=a8,cmd[3]=01,
[ 0.774085] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.774110]
[ 0.774110] childnode->name =rockchip,on-cmds31:length=3
[ 0.774140] cmd[1]=15,
[ 0.774156] cmd[2]=a9,cmd[3]=05,
[ 0.774181] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.774206]
[ 0.774206] childnode->name =rockchip,on-cmds32:length=3
[ 0.774236] cmd[1]=15,
[ 0.774251] cmd[2]=aa,cmd[3]=0c,
[ 0.774276] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.774301]
[ 0.774301] childnode->name =rockchip,on-cmds33:length=3
[ 0.774331] cmd[1]=15,
[ 0.774347] cmd[2]=ab,cmd[3]=08,
[ 0.774372] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.774397]
[ 0.774397] childnode->name =rockchip,on-cmds34:length=3
[ 0.774427] cmd[1]=15,
[ 0.774442] cmd[2]=ac,cmd[3]=17,
[ 0.774468] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.774492]
[ 0.774492] childnode->name =rockchip,on-cmds35:length=3
[ 0.774522] cmd[1]=15,
[ 0.774538] cmd[2]=ad,cmd[3]=2b,
[ 0.774563] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.774588]
[ 0.774588] childnode->name =rockchip,on-cmds36:length=3
[ 0.774618] cmd[1]=15,
[ 0.774634] cmd[2]=ae,cmd[3]=25,
[ 0.774660] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.774721]
[ 0.774721] childnode->name =rockchip,on-cmds37:length=3
[ 0.774755] cmd[1]=15,
[ 0.774771] cmd[2]=af,cmd[3]=00,
[ 0.774797] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.774828]
[ 0.774828] childnode->name =rockchip,on-cmds38:length=3
[ 0.774859] cmd[1]=15,
[ 0.774874] cmd[2]=c0,cmd[3]=00,
[ 0.774900] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.774925]
[ 0.774925] childnode->name =rockchip,on-cmds39:length=3
[ 0.774955] cmd[1]=15,
[ 0.774970] cmd[2]=c1,cmd[3]=05,
[ 0.774996] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.775021]
[ 0.775021] childnode->name =rockchip,on-cmds40:length=3
[ 0.775051] cmd[1]=15,
[ 0.775066] cmd[2]=c2,cmd[3]=0d,
[ 0.775092] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.775116]
[ 0.775116] childnode->name =rockchip,on-cmds41:length=3
[ 0.775146] cmd[1]=15,
[ 0.775162] cmd[2]=c3,cmd[3]=0f,
[ 0.775187] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.775211]
[ 0.775211] childnode->name =rockchip,on-cmds42:length=3
[ 0.775242] cmd[1]=15,
[ 0.775257] cmd[2]=c4,cmd[3]=08,
[ 0.775282] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.775307]
[ 0.775307] childnode->name =rockchip,on-cmds43:length=3
[ 0.775338] cmd[1]=15,
[ 0.775353] cmd[2]=c5,cmd[3]=17,
[ 0.775379] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.775403]
[ 0.775403] childnode->name =rockchip,on-cmds44:length=3
[ 0.775433] cmd[1]=15,
[ 0.775448] cmd[2]=c6,cmd[3]=08,
[ 0.775474] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.775498]
[ 0.775498] childnode->name =rockchip,on-cmds45:length=3
[ 0.775528] cmd[1]=15,
[ 0.775544] cmd[2]=c7,cmd[3]=08,
[ 0.775569] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.775594]
[ 0.775594] childnode->name =rockchip,on-cmds46:length=3
[ 0.775624] cmd[1]=15,
[ 0.775639] cmd[2]=c8,cmd[3]=04,
[ 0.775665] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.775689]
[ 0.775689] childnode->name =rockchip,on-cmds47:length=3
[ 0.775719] cmd[1]=15,
[ 0.775735] cmd[2]=c9,cmd[3]=0a,
[ 0.775760] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.775785]
[ 0.775785] childnode->name =rockchip,on-cmds48:length=3
[ 0.775814] cmd[1]=15,
[ 0.775830] cmd[2]=ca,cmd[3]=03,
[ 0.775856] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.775880]
[ 0.775880] childnode->name =rockchip,on-cmds49:length=3
[ 0.775910] cmd[1]=15,
[ 0.775926] cmd[2]=cb,cmd[3]=00,
[ 0.775951] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.775976]
[ 0.775976] childnode->name =rockchip,on-cmds50:length=3
[ 0.776006] cmd[1]=15,
[ 0.776022] cmd[2]=cc,cmd[3]=00,
[ 0.776047] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.776071]
[ 0.776071] childnode->name =rockchip,on-cmds51:length=3
[ 0.776101] cmd[1]=15,
[ 0.776117] cmd[2]=cd,cmd[3]=2a,
[ 0.776143] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.776167]
[ 0.776167] childnode->name =rockchip,on-cmds52:length=3
[ 0.776197] cmd[1]=15,
[ 0.776213] cmd[2]=ce,cmd[3]=25,
[ 0.776238] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.776263]
[ 0.776263] childnode->name =rockchip,on-cmds53:length=3
[ 0.776292] cmd[1]=15,
[ 0.776308] cmd[2]=cf,cmd[3]=00,
[ 0.776333] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.776358]
[ 0.776358] childnode->name =rockchip,on-cmds54:length=7
[ 0.776388] cmd[1]=39,
[ 0.776403] cmd[2]=ff,cmd[3]=ff,
[ 0.776430] cmd[4]=98,cmd[5]=06,
[ 0.776455] cmd[6]=04,cmd[7]=06,
[ 0.776480] dcs_cmd->dcs_cmd.cmd_len=7
[ 0.776504]
[ 0.776504] childnode->name =rockchip,on-cmds55:length=3
[ 0.776535] cmd[1]=15,
[ 0.776551] cmd[2]=00,cmd[3]=21,
[ 0.776576] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.776600]
[ 0.776600] childnode->name =rockchip,on-cmds56:length=3
[ 0.776630] cmd[1]=15,
[ 0.776646] cmd[2]=01,cmd[3]=09,
[ 0.776671] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.776695]
[ 0.776695] childnode->name =rockchip,on-cmds57:length=3
[ 0.776725] cmd[1]=15,
[ 0.776741] cmd[2]=02,cmd[3]=00,
[ 0.776766] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.776790]
[ 0.776790] childnode->name =rockchip,on-cmds58:length=3
[ 0.776820] cmd[1]=15,
[ 0.776835] cmd[2]=03,cmd[3]=00,
[ 0.776861] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.776890]
[ 0.776890] childnode->name =rockchip,on-cmds59:length=3
[ 0.776920] cmd[1]=15,
[ 0.776936] cmd[2]=04,cmd[3]=01,
[ 0.776962] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.776986]
[ 0.776986] childnode->name =rockchip,on-cmds60:length=3
[ 0.777016] cmd[1]=15,
[ 0.777032] cmd[2]=05,cmd[3]=01,
[ 0.777057] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.777082]
[ 0.777082] childnode->name =rockchip,on-cmds61:length=3
[ 0.777111] cmd[1]=15,
[ 0.777127] cmd[2]=06,cmd[3]=80,
[ 0.777152] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.777177]
[ 0.777177] childnode->name =rockchip,on-cmds62:length=3
[ 0.777207] cmd[1]=15,
[ 0.777222] cmd[2]=07,cmd[3]=05,
[ 0.777247] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.777272]
[ 0.777272] childnode->name =rockchip,on-cmds63:length=3
[ 0.777302] cmd[1]=15,
[ 0.777318] cmd[2]=08,cmd[3]=02,
[ 0.777343] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.777367]
[ 0.777367] childnode->name =rockchip,on-cmds64:length=3
[ 0.777398] cmd[1]=15,
[ 0.777413] cmd[2]=09,cmd[3]=80,
[ 0.777439] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.777464]
[ 0.777464] childnode->name =rockchip,on-cmds65:length=3
[ 0.777493] cmd[1]=15,
[ 0.777509] cmd[2]=0a,cmd[3]=00,
[ 0.777534] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.777559]
[ 0.777559] childnode->name =rockchip,on-cmds66:length=3
[ 0.777588] cmd[1]=15,
[ 0.777604] cmd[2]=0b,cmd[3]=00,
[ 0.777629] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.777654]
[ 0.777654] childnode->name =rockchip,on-cmds67:length=3
[ 0.777684] cmd[1]=15,
[ 0.777699] cmd[2]=0c,cmd[3]=0a,
[ 0.777724] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.777749]
[ 0.777749] childnode->name =rockchip,on-cmds68:length=3
[ 0.777779] cmd[1]=15,
[ 0.777794] cmd[2]=0d,cmd[3]=0a,
[ 0.777819] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.777844]
[ 0.777844] childnode->name =rockchip,on-cmds69:length=3
[ 0.777874] cmd[1]=15,
[ 0.777890] cmd[2]=0e,cmd[3]=00,
[ 0.777915] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.777939]
[ 0.777939] childnode->name =rockchip,on-cmds70:length=3
[ 0.777970] cmd[1]=15,
[ 0.777986] cmd[2]=0f,cmd[3]=00,
[ 0.778011] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.778035]
[ 0.778035] childnode->name =rockchip,on-cmds71:length=3
[ 0.778065] cmd[1]=15,
[ 0.778081] cmd[2]=10,cmd[3]=e0,
[ 0.778106] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.778131]
[ 0.778131] childnode->name =rockchip,on-cmds72:length=3
[ 0.778161] cmd[1]=15,
[ 0.778177] cmd[2]=11,cmd[3]=e4,
[ 0.778202] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.778226]
[ 0.778226] childnode->name =rockchip,on-cmds73:length=3
[ 0.778257] cmd[1]=15,
[ 0.778272] cmd[2]=12,cmd[3]=04,
[ 0.778298] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.778322]
[ 0.778322] childnode->name =rockchip,on-cmds74:length=3
[ 0.778352] cmd[1]=15,
[ 0.778367] cmd[2]=13,cmd[3]=00,
[ 0.778393] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.778417]
[ 0.778417] childnode->name =rockchip,on-cmds75:length=3
[ 0.778447] cmd[1]=15,
[ 0.778463] cmd[2]=14,cmd[3]=00,
[ 0.778488] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.778513]
[ 0.778513] childnode->name =rockchip,on-cmds76:length=3
[ 0.778542] cmd[1]=15,
[ 0.778558] cmd[2]=15,cmd[3]=c0,
[ 0.778584] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.778608]
[ 0.778608] childnode->name =rockchip,on-cmds77:length=3
[ 0.778638] cmd[1]=15,
[ 0.778654] cmd[2]=16,cmd[3]=08,
[ 0.778680] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.778704]
[ 0.778704] childnode->name =rockchip,on-cmds78:length=3
[ 0.778734] cmd[1]=15,
[ 0.778750] cmd[2]=17,cmd[3]=00,
[ 0.778775] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.778800]
[ 0.778800] childnode->name =rockchip,on-cmds79:length=3
[ 0.778830] cmd[1]=15,
[ 0.778846] cmd[2]=18,cmd[3]=00,
[ 0.778870shell@fireprime:/ $ ] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.778900]
[ 0.778900] childnode->name =rockchip,on-cmds80:length=3
[ 0.778930] cmd[1]=15,
[ 0.778946] cmd[2]=19,cmd[3]=00,
[ 0.778971] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.778997]
[ 0.778997] childnode->name =rockchip,on-cmds81:length=3
[ 0.779027] cmd[1]=15,
[ 0.779042] cmd[2]=1a,cmd[3]=00,
[ 0.779068] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.779093]
[ 0.779093] childnode->name =rockchip,on-cmds82:length=3
[ 0.779122] cmd[1]=15,
[ 0.779138] cmd[2]=1b,cmd[3]=00,
[ 0.779164] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.779188]
[ 0.779188] childnode->name =rockchip,on-cmds83:length=3
[ 0.779218] cmd[1]=15,
[ 0.779234] cmd[2]=1c,cmd[3]=00,
[ 0.779259] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.779283]
[ 0.779283] childnode->name =rockchip,on-cmds84:length=3
[ 0.779313] cmd[1]=15,
[ 0.779329] cmd[2]=1d,cmd[3]=00,
[ 0.779354] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.779378]
[ 0.779378] childnode->name =rockchip,on-cmds85:length=3
[ 0.779408] cmd[1]=15,
[ 0.779424] cmd[2]=20,cmd[3]=01,
[ 0.779450] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.779474]
[ 0.779474] childnode->name =rockchip,on-cmds86:length=3
[ 0.779505] cmd[1]=15,
[ 0.779521] cmd[2]=21,cmd[3]=23,
[ 0.779546] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.779570]
[ 0.779570] childnode->name =rockchip,on-cmds87:length=3
[ 0.779601] cmd[1]=15,
[ 0.779616] cmd[2]=22,cmd[3]=45,
[ 0.779642] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.779666]
[ 0.779666] childnode->name =rockchip,on-cmds88:length=3
[ 0.779696] cmd[1]=15,
[ 0.779711] cmd[2]=23,cmd[3]=67,
[ 0.779737] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.779761]
[ 0.779761] childnode->name =rockchip,on-cmds89:length=3
[ 0.779792] cmd[1]=15,
[ 0.779807] cmd[2]=24,cmd[3]=01,
[ 0.779833] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.779857]
[ 0.779857] childnode->name =rockchip,on-cmds90:length=3
[ 0.779887] cmd[1]=15,
[ 0.779903] cmd[2]=25,cmd[3]=23,
[ 0.779928] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.779953]
[ 0.779953] childnode->name =rockchip,on-cmds91:length=3
[ 0.779983] cmd[1]=15,
[ 0.779998] cmd[2]=26,cmd[3]=45,
[ 0.780025] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.780049]
[ 0.780049] childnode->name =rockchip,on-cmds92:length=3
[ 0.780079] cmd[1]=15,
[ 0.780094] cmd[2]=27,cmd[3]=67,
[ 0.780120] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.780144]
[ 0.780144] childnode->name =rockchip,on-cmds93:length=3
[ 0.780175] cmd[1]=15,
[ 0.780190] cmd[2]=30,cmd[3]=01,
[ 0.780216] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.780240]
[ 0.780240] childnode->name =rockchip,on-cmds94:length=3
[ 0.780270] cmd[1]=15,
[ 0.780286] cmd[2]=31,cmd[3]=11,
[ 0.780311] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.780336]
[ 0.780336] childnode->name =rockchip,on-cmds95:length=3
[ 0.780366] cmd[1]=15,
[ 0.780382] cmd[2]=32,cmd[3]=00,
[ 0.780407] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.780431]
[ 0.780431] childnode->name =rockchip,on-cmds96:length=3
[ 0.780461] cmd[1]=15,
[ 0.780477] cmd[2]=33,cmd[3]=ee,
[ 0.780502] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.780526]
[ 0.780526] childnode->name =rockchip,on-cmds97:length=3
[ 0.780557] cmd[1]=15,
[ 0.780572] cmd[2]=34,cmd[3]=ff,
[ 0.780598] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.780622]
[ 0.780622] childnode->name =rockchip,on-cmds98:length=3
[ 0.780652] cmd[1]=15,
[ 0.780668] cmd[2]=35,cmd[3]=cb,
[ 0.780693] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.780718]
[ 0.780718] childnode->name =rockchip,on-cmds99:length=3
[ 0.780748] cmd[1]=15,
[ 0.780764] cmd[2]=36,cmd[3]=da,
[ 0.780789] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.780813]
[ 0.780813] childnode->name =rockchip,on-cmds100:length=3
[ 0.780843] cmd[1]=15,
[ 0.780859] cmd[2]=37,cmd[3]=ad,
[ 0.780884] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.780914]
[ 0.780914] childnode->name =rockchip,on-cmds101:length=3
[ 0.780944] cmd[1]=15,
[ 0.780960] cmd[2]=38,cmd[3]=bc,
[ 0.780985] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.781010]
[ 0.781010] childnode->name =rockchip,on-cmds102:length=3
[ 0.781040] cmd[1]=15,
[ 0.781056] cmd[2]=39,cmd[3]=76,
[ 0.781082] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.781106]
[ 0.781106] childnode->name =rockchip,on-cmds103:length=3
[ 0.781136] cmd[1]=15,
[ 0.781152] cmd[2]=3a,cmd[3]=67,
[ 0.781177] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.781202]
[ 0.781202] childnode->name =rockchip,on-cmds104:length=3
[ 0.781232] cmd[1]=15,
[ 0.781248] cmd[2]=3b,cmd[3]=22,
[ 0.781273] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.781298]
[ 0.781298] childnode->name =rockchip,on-cmds105:length=3
[ 0.781328] cmd[1]=15,
[ 0.781344] cmd[2]=3c,cmd[3]=22,
[ 0.781369] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.781394]
[ 0.781394] childnode->name =rockchip,on-cmds106:length=3
[ 0.781424] cmd[1]=15,
[ 0.781440] cmd[2]=3d,cmd[3]=22,
[ 0.781466] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.781490]
[ 0.781490] childnode->name =rockchip,on-cmds107:length=3
[ 0.781520] cmd[1]=15,
[ 0.781536] cmd[2]=3e,cmd[3]=22,
[ 0.781562] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.781586]
[ 0.781586] childnode->name =rockchip,on-cmds108:length=3
[ 0.781616] cmd[1]=15,
[ 0.781632] cmd[2]=3f,cmd[3]=22,
[ 0.781657] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.781682]
[ 0.781682] childnode->name =rockchip,on-cmds109:length=3
[ 0.781712] cmd[1]=15,
[ 0.781728] cmd[2]=40,cmd[3]=22,
[ 0.781753] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.781778]
[ 0.781778] childnode->name =rockchip,on-cmds110:length=3
[ 0.781809] cmd[1]=15,
[ 0.781824] cmd[2]=52,cmd[3]=10,
[ 0.781850] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.781874]
[ 0.781874] childnode->name =rockchip,on-cmds111:length=3
[ 0.781904] cmd[1]=15,
[ 0.781920] cmd[2]=53,cmd[3]=10,
[ 0.781945] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.781970]
[ 0.781970] childnode->name =rockchip,on-cmds112:length=7
[ 0.782000] cmd[1]=39,
[ 0.782016] cmd[2]=ff,cmd[3]=ff,
[ 0.782042] cmd[4]=98,cmd[5]=06,
[ 0.782067] cmd[6]=04,cmd[7]=07,
[ 0.782092] dcs_cmd->dcs_cmd.cmd_len=7
[ 0.782117]
[ 0.782117] childnode->name =rockchip,on-cmds113:length=3
[ 0.782147] cmd[1]=15,
[ 0.782164] cmd[2]=17,cmd[3]=22,
[ 0.782189] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.782214]
[ 0.782214] childnode->name =rockchip,on-cmds114:length=3
[ 0.782244] cmd[1]=15,
[ 0.782259] cmd[2]=02,cmd[3]=77,
[ 0.782284] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.782309]
[ 0.782309] childnode->name =rockchip,on-cmds115:length=3
[ 0.782339] cmd[1]=15,
[ 0.782354] cmd[2]=e1,cmd[3]=79,
[ 0.782380] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.782405]
[ 0.782405] childnode->name =rockchip,on-cmds116:length=7
[ 0.782434] cmd[1]=39,
[ 0.782450] cmd[2]=ff,cmd[3]=ff,
[ 0.782476] cmd[4]=98,cmd[5]=06,
[ 0.782502] cmd[6]=04,cmd[7]=00,
[ 0.782527] dcs_cmd->dcs_cmd.cmd_len=7
[ 0.782551]
[ 0.782551] childnode->name =rockchip,on-cmds117:length=2
[ 0.782581] cmd[1]=05,
[ 0.782597] cmd[2]=35,[ 0.782610] dcs_cmd->dcs_cmd.cmd_len=2
[ 0.782634]
[ 0.782634] childnode->name =rockchip,on-cmds118:length=2
[ 0.782663] cmd[1]=05,
[ 0.782679] cmd[2]=11,[ 0.782692] dcs_cmd->dcs_cmd.cmd_len=2
[ 0.782716]
[ 0.782716] childnode->name =rockchip,on-cmds119:length=2
[ 0.782746] cmd[1]=05,
[ 0.782762] cmd[2]=29,[ 0.782775] dcs_cmd->dcs_cmd.cmd_len=2
[ 0.782801]
[ 0.782801] dcs_name:rockchip,on-cmds1,dcs_type:1,side_id:0,cmd_len:7,delay:0
[ 0.782801]
[ 0.782840] [1]=39,[2]=ff,[3]=ff,[4]=98,[5]=06,[6]=04,[7]=01,
dcs_name:rockchip,on-cmds2,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.782909] [1]=15,[2]=08,[3]=10,
dcs_name:rockchip,on-cmds3,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.782958] [1]=15,[2]=21,[3]=01,
dcs_name:rockchip,on-cmds4,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.783006] [1]=15,[2]=30,[3]=02,
dcs_name:rockchip,on-cmds5,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.783055] [1]=15,[2]=31,[3]=02,
dcs_name:rockchip,on-cmds6,dcs_type:1,side_id:0,cmd_len:3,delay:120
[ 0.783104] [1]=15,[2]=40,[3]=15,
dcs_name:rockchip,on-cmds7,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.783153] [1]=15,[2]=41,[3]=33,
dcs_name:rockchip,on-cmds8,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.783201] [1]=15,[2]=42,[3]=03,
dcs_name:rockchip,on-cmds9,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.783250] [1]=15,[2]=43,[3]=09,
dcs_name:rockchip,on-cmds10,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.783299] [1]=15,[2]=44,[3]=09,
dcs_name:rockchip,on-cmds11,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.783347] [1]=15,[2]=50,[3]=78,
dcs_name:rockchip,on-cmds12,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.783396] [1]=15,[2]=51,[3]=78,
dcs_name:rockchip,on-cmds13,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.783444] [1]=15,[2]=52,[3]=00,
dcs_name:rockchip,on-cmds14,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.783493] [1]=15,[2]=53,[3]=79,
dcs_name:rockchip,on-cmds15,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.783541] [1]=15,[2]=54,[3]=00,
dcs_name:rockchip,on-cmds16,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.783590] [1]=15,[2]=55,[3]=83,
dcs_name:rockchip,on-cmds17,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.783638] [1]=15,[2]=57,[3]=50,
dcs_name:rockchip,on-cmds18,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.783687] [1]=15,[2]=60,[3]=07,
dcs_name:rockchip,on-cmds19,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.783735] [1]=15,[2]=61,[3]=00,
dcs_name:rockchip,on-cmds20,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.783783] [1]=15,[2]=62,[3]=08,
dcs_name:rockchip,on-cmds21,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.783831] [1]=15,[2]=63,[3]=00,
dcs_name:rockchip,on-cmds22,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.783879] [1]=15,[2]=a0,[3]=00,
dcs_name:rockchip,on-cmds23,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.783928] [1]=15,[2]=a1,[3]=07,
dcs_name:rockchip,on-cmds24,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.783977] [1]=15,[2]=a2,[3]=11,
dcs_name:rockchip,on-cmds25,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.784026] [1]=15,[2]=a3,[3]=10,
dcs_name:rockchip,on-cmds26,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.784075] [1]=15,[2]=a4,[3]=0a,
dcs_name:rockchip,on-cmds27,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.784124] [1]=15,[2]=a5,[3]=17,
dcs_name:rockchip,on-cmds28,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.784172] [1]=15,[2]=a6,[3]=0a,
dcs_name:rockchip,on-cmds29,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.784220] [1]=15,[2]=a7,[3]=0a,
dcs_name:rockchip,on-cmds30,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.784268] [1]=15,[2]=a8,[3]=01,
dcs_name:rockchip,on-cmds31,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.784317] [1]=15,[2]=a9,[3]=05,
dcs_name:rockchip,on-cmds32,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.784365] [1]=15,[2]=aa,[3]=0c,
dcs_name:rockchip,on-cmds33,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.784414] [1]=15,[2]=ab,[3]=08,
dcs_name:rockchip,on-cmds34,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.784462] [1]=15,[2]=ac,[3]=17,
dcs_name:rockchip,on-cmds35,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.784511] [1]=15,[2]=ad,[3]=2b,
dcs_name:rockchip,on-cmds36,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.784629] [1]=15,[2]=ae,[3]=25,
dcs_name:rockchip,on-cmds37,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.784684] [1]=15,[2]=af,[3]=00,
dcs_name:rockchip,on-cmds38,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.784733] [1]=15,[2]=c0,[3]=00,
dcs_name:rockchip,on-cmds39,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.784782] [1]=15,[2]=c1,[3]=05,
dcs_name:rockchip,on-cmds40,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.784831] [1]=15,[2]=c2,[3]=0d,
dcs_name:rockchip,on-cmds41,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.784879] [1]=15,[2]=c3,[3]=0f,
dcs_name:rockchip,on-cmds42,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.784927] [1]=15,[2]=c4,[3]=08,
dcs_name:rockchip,on-cmds43,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.784976] [1]=15,[2]=c5,[3]=17,
dcs_name:rockchip,on-cmds44,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.785025] [1]=15,[2]=c6,[3]=08,
dcs_name:rockchip,on-cmds45,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.785073] [1]=15,[2]=c7,[3]=08,
dcs_name:rockchip,on-cmds46,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.785122] [1]=15,[2]=c8,[3]=04,
dcs_name:rockchip,on-cmds47,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.785170] [1]=15,[2]=c9,[3]=0a,
dcs_name:rockchip,on-cmds48,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.785218] [1]=15,[2]=ca,[3]=03,
dcs_name:rockchip,on-cmds49,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.785266] [1]=15,[2]=cb,[3]=00,
dcs_name:rockchip,on-cmds50,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.785315] [1]=15,[2]=cc,[3]=00,
dcs_name:rockchip,on-cmds51,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.785363] [1]=15,[2]=cd,[3]=2a,
dcs_name:rockchip,on-cmds52,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.785411] [1]=15,[2]=ce,[3]=25,
dcs_name:rockchip,on-cmds53,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.785460] [1]=15,[2]=cf,[3]=00,
dcs_name:rockchip,on-cmds54,dcs_type:1,side_id:0,cmd_len:7,delay:10
[ 0.785509] [1]=39,[2]=ff,[3]=ff,[4]=98,[5]=06,[6]=04,[7]=06,
dcs_name:rockchip,on-cmds55,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.785577] [1]=15,[2]=00,[3]=21,
dcs_name:rockchip,on-cmds56,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.785626] [1]=15,[2]=01,[3]=09,
dcs_name:rockchip,on-cmds57,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.785674] [1]=15,[2]=02,[3]=00,
dcs_name:rockchip,on-cmds58,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.785722] [1]=15,[2]=03,[3]=00,
dcs_name:rockchip,on-cmds59,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.785771] [1]=15,[2]=04,[3]=01,
dcs_name:rockchip,on-cmds60,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.785819] [1]=15,[2]=05,[3]=01,
dcs_name:rockchip,on-cmds61,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.785868] [1]=15,[2]=06,[3]=80,
dcs_name:rockchip,on-cmds62,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.785916] [1]=15,[2]=07,[3]=05,
dcs_name:rockchip,on-cmds63,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.785964] [1]=15,[2]=08,[3]=02,
dcs_name:rockchip,on-cmds64,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.786013] [1]=15,[2]=09,[3]=80,
dcs_name:rockchip,on-cmds65,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.786061] [1]=15,[2]=0a,[3]=00,
dcs_name:rockchip,on-cmds66,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.786109] [1]=15,[2]=0b,[3]=00,
dcs_name:rockchip,on-cmds67,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.786158] [1]=15,[2]=0c,[3]=0a,
dcs_name:rockchip,on-cmds68,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.786206] [1]=15,[2]=0d,[3]=0a,
dcs_name:rockchip,on-cmds69,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.786254] [1]=15,[2]=0e,[3]=00,
dcs_name:rockchip,on-cmds70,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.786302] [1]=15,[2]=0f,[3]=00,
dcs_name:rockchip,on-cmds71,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.786350] [1]=15,[2]=10,[3]=e0,
dcs_name:rockchip,on-cmds72,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.786399] [1]=15,[2]=11,[3]=e4,
dcs_name:rockchip,on-cmds73,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.786448] [1]=15,[2]=12,[3]=04,
dcs_name:rockchip,on-cmds74,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.786497] [1]=15,[2]=13,[3]=00,
dcs_name:rockchip,on-cmds75,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.786545] [1]=15,[2]=14,[3]=00,
dcs_name:rockchip,on-cmds76,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.786594] [1]=15,[2]=15,[3]=c0,
dcs_name:rockchip,on-cmds77,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.786643] [1]=15,[2]=16,[3]=08,
dcs_name:rockchip,on-cmds78,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.786691] [1]=15,[2]=17,[3]=00,
dcs_name:rockchip,on-cmds79,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.786740] [1]=15,[2]=18,[3]=00,
dcs_name:rockchip,on-cmds80,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.786789] [1]=15,[2]=19,[3]=00,
dcs_name:rockchip,on-cmds81,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.786838] [1]=15,[2]=1a,[3]=00,
dcs_name:rockchip,on-cmds82,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.786886] [1]=15,[2]=1b,[3]=00,
dcs_name:rockchip,on-cmds83,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.786935] [1]=15,[2]=1c,[3]=00,
dcs_name:rockchip,on-cmds84,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.786984] [1]=15,[2]=1d,[3]=00,
dcs_name:rockchip,on-cmds85,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.787032] [1]=15,[2]=20,[3]=01,
dcs_name:rockchip,on-cmds86,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.787081] [1]=15,[2]=21,[3]=23,
dcs_name:rockchip,on-cmds87,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.787129] [1]=15,[2]=22,[3]=45,
dcs_name:rockchip,on-cmds88,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.787178] [1]=15,[2]=23,[3]=67,
dcs_name:rockchip,on-cmds89,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.787227] [1]=15,[2]=24,[3]=01,
dcs_name:rockchip,on-cmds90,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.787275] [1]=15,[2]=25,[3]=23,
dcs_name:rockchip,on-cmds91,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.787324] [1]=15,[2]=26,[3]=45,
dcs_name:rockchip,on-cmds92,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.787373] [1]=15,[2]=27,[3]=67,
dcs_name:rockchip,on-cmds93,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.787421] [1]=15,[2]=30,[3]=01,
dcs_name:rockchip,on-cmds94,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.787470] [1]=15,[2]=31,[3]=11,
dcs_name:rockchip,on-cmds95,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.787519] [1]=15,[2]=32,[3]=00,
dcs_name:rockchip,on-cmds96,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.787568] [1]=15,[2]=33,[3]=ee,
dcs_name:rockchip,on-cmds97,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.787616] [1]=15,[2]=34,[3]=ff,
dcs_name:rockchip,on-cmds98,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.787665] [1]=15,[2]=35,[3]=cb,
dcs_name:rockchip,on-cmds99,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.787714] [1]=15,[2]=36,[3]=da,
dcs_name:rockchip,on-cmds100,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.787763] [1]=15,[2]=37,[3]=ad,
dcs_name:rockchip,on-cmds101,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.787811] [1]=15,[2]=38,[3]=bc,
dcs_name:rockchip,on-cmds102,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.787861] [1]=15,[2]=39,[3]=76,
dcs_name:rockchip,on-cmds103,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.787910] [1]=15,[2]=3a,[3]=67,
dcs_name:rockchip,on-cmds104,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.787958] [1]=15,[2]=3b,[3]=22,
dcs_name:rockchip,on-cmds105,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.788007] [1]=15,[2]=3c,[3]=22,
dcs_name:rockchip,on-cmds106,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.788056] [1]=15,[2]=3d,[3]=22,
dcs_name:rockchip,on-cmds107,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.788104] [1]=15,[2]=3e,[3]=22,
dcs_name:rockchip,on-cmds108,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.788153] [1]=15,[2]=3f,[3]=22,
dcs_name:rockchip,on-cmds109,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.788203] [1]=15,[2]=40,[3]=22,
dcs_name:rockchip,on-cmds110,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.788251] [1]=15,[2]=52,[3]=10,
dcs_name:rockchip,on-cmds111,dcs_type:1,side_id:0,cmd_len:3,delay:10
[ 0.788300] [1]=15,[2]=53,[3]=10,
dcs_name:rockchip,on-cmds112,dcs_type:1,side_id:0,cmd_len:7,delay:0
[ 0.788349] [1]=39,[2]=ff,[3]=ff,[4]=98,[5]=06,[6]=04,[7]=07,
dcs_name:rockchip,on-cmds113,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.788417] [1]=15,[2]=17,[3]=22,
dcs_name:rockchip,on-cmds114,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.788466] [1]=15,[2]=02,[3]=77,
dcs_name:rockchip,on-cmds115,dcs_type:1,side_id:0,cmd_len:3,delay:0
[ 0.788515] [1]=15,[2]=e1,[3]=79,
dcs_name:rockchip,on-cmds116,dcs_type:1,side_id:0,cmd_len:7,delay:0
[ 0.788564] [1]=39,[2]=ff,[3]=ff,[4]=98,[5]=06,[6]=04,[7]=00,
dcs_name:rockchip,on-cmds117,dcs_type:1,side_id:0,cmd_len:2,delay:0
[ 0.788632] [1]=05,[2]=35,
dcs_name:rockchip,on-cmds118,dcs_type:1,side_id:0,cmd_len:2,delay:120
[ 0.788676] [1]=05,[2]=11,
dcs_name:rockchip,on-cmds119,dcs_type:1,side_id:0,cmd_len:2,delay:10
[ 0.788720] [1]=05,[2]=29,
[ 0.788740] —rk_mipi_screen_probe–end
[ 0.788891] act8931_i2c_probe,line=715
[ 0.789671] The device is not act8931
[ 0.790349] rk818_i2c_probe,line=1286
[ 0.790648] rk818_pre_init,line=1201
[ 0.798341] gpiod_request: flags 0, gpio 32, desc c0dfa114cpu_det_gpio up
[ 0.798415] gpiod_request: flags 0, gpio 32, desc c0dfa2e8power_hold_gpio up
[ 0.798454] gpiod_request: flags 0, gpio 32, desc c0dfa534
[ 0.798490] rk818_i2c_probe: rk818_pmic_sleep=0
[ 0.802257] vdd_arm: 712 ↔ 1500 mV at 1175 mV
[ 0.806420] vdd_logic: 712 ↔ 1500 mV at 1250 mV
[ 0.810076] rk818_dcdc3: 1200 mV
[ 0.814180] vccio: 1800 ↔ 3300 mV at 3000 mV
[ 0.817937] rk818_ldo1: 3300 mV
[ 0.821579] rk818_ldo2: 3000 mV
[ 0.825257] rk818_ldo3: 1100 mV
[ 0.828922] rk818_ldo4: 2800 mV
[ 0.832562] rk818_ldo5: 3000 mV
[ 0.836199] rk818_ldo6: 1200 mV
[ 0.839844] rk818_ldo7: 1800 mV
[ 0.843478] rk818_ldo8: 1800 mV
[ 0.846302] vcc_sd: 1800 ↔ 3000 mV at 3000 mV
[ 0.847721] rk818_ldo10: at 3000 mV
[ 0.849417] gpiod_request: flags 0, gpio 32, desc c0dfa570
[ 0.849466] rk818_irq_init: rk818_pmic_irq=1
[ 0.850122] fireprime_rk818_hdmi_5v_en enable:1
[ 0.850920] i2c-core: driver [rk818] using legacy suspend method
[ 0.850946] i2c-core: driver [rk818] using legacy resume method
[ 0.853138] Switching to clocksource arch_sys_counter
[ 0.856189] rk_battery_charger_detect_cb , battery_charger_detect 1
[ 0.889589] fb disp policy is sdk
[ 0.889692] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.889720] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.890190] rk-screen rk_screen.9: rockchip screen probe success
[ 0.891004] rk312-dsi
[ 0.891163] dsi->host.irq =51
[ 0.891198] load mipi dsi chip:rk_mipi_dsi.0 id:3132312a
[ 0.891218] mipi_dsi v1.3 2014-04-17
[ 0.891237] rk_fb_trsm_ops_register: transmitter:7!
[ 0.891347] rk32-mipi 10110000.mipi: rk mipi_dsi probe success!
[ 0.891374] rk32-mipi 10110000.mipi: rockchip mipi_dsi v1.1 2014-06-17
[ 0.892273] rk-fb rockchip-fb: rk_fb_register, name , id 0, num 0
[ 0.892311] rk312x-lcdc lcdc0: init_lcdc_device_driver, index 0, disp_mode 0, prop 1
[ 0.892934] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.893677] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.894081] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.894113] rk312x-lcdc lcdc0: rk312x_lcdc_open begin
[ 0.894698] rk312x-lcdc lcdc0: rk312x_lcdc_open 0
[ 0.894732] rk312x-lcdc lcdc0: lcdc0: dclk:24750000>>fps:55
[ 0.894759] rk312x-lcdc lcdc0: wakeup from standby!
[ 0.903431] alloc_buffer:ion_phy_addr=0x10000000
[ 0.906342] fb0:phy:10000000>>vir:e093d000>>len:0x500000
[ 0.922148] rk312x-lcdc lcdc0: lcdc0 probe ok, iommu enabled
[ 0.925406] NET: Registered protocol family 2
[ 0.926317] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.926454] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.926570] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.926674] TCP: reno registered
[ 0.926704] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.926751] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.927126] NET: Registered protocol family 1
[ 0.929378] rk818-battery rk818-battery: not battery, enter test power mode
[ 0.949735] rk818-battery rk818-battery: v=4200, ov=4200, rv=0, c=0, pwroff_min=0
[ 0.955572] rk818-battery rk818-battery: c=0, v=4200, relax=0, ocv=4200, est=4200, calib=-1
[ 0.956290] rk818-battery rk818-battery: reg soc=0, init soc = 0, init cap=0
[ 0.983373] rk818-battery rk818-battery: battery driver version 4.0.0
[ 0.984140] Unpacking initramfs…
[ 1.120716] Freeing initrd memory: 1456K (c5bf0000 - c5d5c000)
[ 1.122295] hw perfevents: enabled with ARMv7_Cortex_A7 PMU driver, 5 counters available
[ 1.122983] vcodec_service: probe device vpu_combo.10
[ 1.123017] vcodec_service: No reset resource define
[ 1.123036] vcodec_service: No reset resource define
[ 1.123053] vcodec_service: No reset resource define
[ 1.123175] vcodec vpu_combo.10: failed on clk_get clk_cabac
[ 1.123284] vcodec_service: vpu_combo.10: power on
[ 1.123429] vcodec_service: probe device 10106000.vpu_service
[ 1.123493] vcodec_service: checking hw id 4831
[ 1.124859] vcodec_service: probe device 10104000.hevc_service
[ 1.124924] vcodec_service: checking hw id 6867
[ 1.125864] vcodec_service: vpu_combo.10: power off…
[ 1.125934] vcodec_service: done
[ 1.125954] vcodec_service: init success
[ 1.126127] rknandbase v1.0 2014-03-31
[ 1.126403] rknand_probe clk rate = 148500000
[ 1.126586] rknand_driver:ret = 0
[ 1.128031] rk_dts_sensor_probe:Get s5k4ec rockchip,power failed!
[ 1.128072] s5k4ec_io==1
[ 1.128124] the gpiorst1 is 107
[ 1.128149] gpiod_request: flags 0, gpio 32, desc c0dfa4ecthe gpiorst2 is 107
[ 1.128226] rk_dts_sensor_probe:Get ov2659 rockchip,power failed!
[ 1.128256] s5k4ec_io==2
[ 1.128293] rk_dts_sensor_probe:Get gc0329 rockchip,power failed!
[ 1.128322] s5k4ec_io==2
[ 1.128357] rk_dts_sensor_probe:Get gc2035 rockchip,powerdown failed!
[ 1.128387] s5k4ec_io==2
[ 1.128430] s5k4ec_io==2
[ 1.130198] audit: initializing netlink socket (disabled)
[ 1.130298] type=2000 audit(0.590:1): initialized
[ 1.131661] bounce pool size: 64 pages
[ 1.142144] fuse init (API version 7.22)
[ 1.143022] msgmni has been set to 973
[ 1.146578] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.146613] io scheduler noop registered
[ 1.146634] io scheduler deadline registered
[ 1.146844] io scheduler cfq registered (default)
[ 1.152707] rga 1010c000.rga: rga ion client create success!
[ 1.153048] rga: Driver loaded succesfully
[ 1.153185] rga: Module initialized.
[ 1.154585] IEP Power ON
[ 1.154665] iep ion client create success!
[ 1.155117] IEP Power OFF
[ 1.155153] IEP Driver loaded succesfully
[ 1.155304] Module initialized.
[ 1.158208] dma-pl330 20078000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.158249] dma-pl330 20078000.pdma: DBUFF-64x8bytes Num_Chans-8 Num_Peri-16 Num_Events-16
[ 1.159169] rk_serial.c v1.8 2014-03-04
[ 1.159507] 20060000.serial: ttyS0 at MMIO 0x20060000 (irq = 52) is a rk29_serial.0
[ 1.159940] serial 20060000.serial: membase e2e46000
[ 1.166219] loop: module loaded
[ 1.166346] i2c-core: driver [mpu6050B1] using legacy suspend method
[ 1.166371] i2c-core: driver [mpu6050B1] using legacy resume method
[ 1.166398] mpu_init: Probe name mpu6050B1
[ 1.166714] ak8963_mod_init: Probe name ak8963_mod
[ 1.167986] SCSI Media Changer driver v0.25
[ 1.168716] tun: Universal TUN/TAP device driver, 1.6
[ 1.168747] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.169063] vmac_init.
[ 1.170183] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 1.170216] stmmac_probe_config_dt: Can not read property: pmu_enable_level.
[ 1.170241] stmmac_probe_config_dt: clock input or output? (input).
[ 1.170265] stmmac_probe_config_dt: TX delay(0x30).
[ 1.170286] stmmac_probe_config_dt: RX delay(0x10).
[ 1.170386] stmmac_probe_config_dt: is rockchip,rk312x-gmac
[ 1.170406] stmmc_pltfr_init:
[ 1.170425] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[ 1.170450] gpiod_request: flags 0, gpio 32, desc c0dfa408
[ 1.170482] gpiod_request: flags 0, gpio 32, desc c0dfa108[ 1.170565] stmmc_pltfr_init: init for RGMII
[ 1.170588] tx delay=0x30
[ 1.170588] rx delay=0x10
[ 1.170821] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.170843] Normal descriptors
[ 1.170859] Ring mode enabled
[ 1.170877] DMA HW capability register supported
[ 1.170896] RX Checksum Offload Engine supported (type 2)
[ 1.170916] TX Checksum insertion supported
[ 1.170933] Wake-Up On Lan supported
[ 1.171020] Enable RX Mitigation via HW Watchdog Timer
[ 1.171941] PPP generic driver version 2.4.2
[ 1.172312] PPP BSD Compression module registered
[ 1.172339] PPP Deflate Compression module registered
[ 1.172374] PPP MPPE Compression module registered
[ 1.172397] NET: Registered protocol family 24
[ 1.172452] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.172477] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.172500] Rockchip WiFi SYS interface (V1.00) …
[ 1.172571] esp_mem_init enter date Jun 29 2017 01:25:32
[ 1.172592] esp_mem_init VERSION [V2.5]
[ 1.172667] esp_mem_init complete
[ 1.172791] usbcore: registered new interface driver catc
[ 1.172876] usbcore: registered new interface driver kaweth
[ 1.172900] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.172979] usbcore: registered new interface driver pegasus
[ 1.173068] usbcore: registered new interface driver rtl8150
[ 1.173149] usbcore: registered new interface driver r8152
[ 1.173171] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.173308] usbcore: registered new interface driver hso
[ 1.173404] usbcore: registered new interface driver asix
[ 1.173486] usbcore: registered new interface driver ax88179_178a
[ 1.173565] usbcore: registered new interface driver cdc_ether
[ 1.173669] usbcore: registered new interface driver cdc_eem
[ 1.173749] usbcore: registered new interface driver dm9601
[ 1.173828] usbcore: registered new interface driver dm9620
[ 1.173927] usbcore: registered new interface driver smsc75xx
[ 1.174025] usbcore: registered new interface driver smsc95xx
[ 1.174104] usbcore: registered new interface driver gl620a
[ 1.174200] usbcore: registered new interface driver net1080
[ 1.174282] usbcore: registered new interface driver plusb
[ 1.174363] usbcore: registered new interface driver rndis_host
[ 1.174444] usbcore: registered new interface driver cdc_subset
[ 1.174521] usbcore: registered new interface driver zaurus
[ 1.174603] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.174726] usbcore: registered new interface driver int51x1
[ 1.174808] usbcore: registered new interface driver kalmia
[ 1.174897] usbcore: registered new interface driver ipheth
[ 1.174986] usbcore: registered new interface driver sierra_net
[ 1.175069] usbcore: registered new interface driver cx82310_eth
[ 1.175169] usbcore: registered new interface driver cdc_ncm
[ 1.175250] usbcore: registered new interface driver qmi_wwan
[ 1.175332] usbcore: registered new interface driver cdc_mbim
[ 1.175355] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.177296] EHCI: ehci_rk_probe e2e80000 e2e80010
[ 1.177331] rockchip_ehci_host 101c0000.usb: EHCI Host Controller
[ 1.177383] rockchip_ehci_host 101c0000.usb: new USB bus registered, assigned bus number 1
[ 1.178095] rockchip_ehci_host 101c0000.usb: irq 43, io mem 0x101c0000
[ 1.197672] rockchip_ehci_host 101c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.197832] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.197865] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.197892] usb usb1: Product: EHCI Host Controller
[ 1.197917] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 1.197941] usb usb1: SerialNumber: 101c0000.usb
[ 1.198815] hub 1-0:1.0: USB hub found
[ 1.198864] hub 1-0:1.0: 1 port detected
[ 1.199228] EHCI: ehci_rk_probe ok
[ 1.199410] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.199646] ohci-rockchip 101e0000.usb: RK OHCI Host Controller
[ 1.199707] ohci-rockchip 101e0000.usb: new USB bus registered, assigned bus number 2
[ 1.199790] ohci-rockchip 101e0000.usb: irq 64, io mem 0x101e0000
[ 1.260736] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.260771] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.260798] usb usb2: Product: RK OHCI Host Controller
[ 1.260822] usb usb2: Manufacturer: Linux 3.10.0 ohci_hcd
[ 1.260847] usb usb2: SerialNumber: 101e0000.usb
[ 1.261672] hub 2-0:1.0: USB hub found
[ 1.261720] hub 2-0:1.0: 1 port detected
[ 1.262348] usbcore: registered new interface driver cdc_acm
[ 1.262373] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.262505] usbcore: registered new interface driver usblp
[ 1.262602] usbcore: registered new interface driver cdc_wdm
[ 1.262750] usbcore: registered new interface driver usb-storage
[ 1.262833] usbcore: registered new interface driver ums-alauda
[ 1.262912] usbcore: registered new interface driver ums-cypress
[ 1.262994] usbcore: registered new interface driver ums-datafab
[ 1.263072] usbcore: registered new interface driver ums_eneub6250
[ 1.263151] usbcore: registered new interface driver ums-freecom
[ 1.263240] usbcore: registered new interface driver ums-isd200
[ 1.263323] usbcore: registered new interface driver ums-jumpshot
[ 1.263402] usbcore: registered new interface driver ums-karma
[ 1.263482] usbcore: registered new interface driver ums-onetouch
[ 1.263563] usbcore: registered new interface driver ums-sddr09
[ 1.263645] usbcore: registered new interface driver ums-sddr55
[ 1.263736] usbcore: registered new interface driver ums-usbat
[ 1.263924] usbcore: registered new interface driver usbserial
[ 1.264010] usbcore: registered new interface driver usbserial_generic
[ 1.264090] usbserial: USB Serial support registered for generic
[ 1.264178] usbcore: registered new interface driver option
[ 1.264247] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.264466] usbcore: registered new interface driver trancevibrator
[ 1.264491] usb20_otg: version 3.10a 21-DEC-2012
[ 1.265094] e2f00040
[ 1.265121] Core Release: 2.91a
[ 1.265142] Setting default values for core params
[ 1.265410] Using Buffer DMA mode
[ 1.265436] Periodic Transfer Interrupt Enhancement - disabled
[ 1.265456] Multiprocessor Interrupt Enhancement - disabled
[ 1.265478] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.265496] ^^^^^^^^^^^^^^^^^Device Mode
[ 1.265521] Dedicated Tx FIFOs mode
[ 1.265555] pcd_init otg_dev = c5a2c8c0
[ 1.265884] usb20_otg 10180000.usb: DWC OTG Controller
[ 1.265940] usb20_otg 10180000.usb: new USB bus registered, assigned bus number 3
[ 1.266008] usb20_otg 10180000.usb: irq 42, io mem 0x00000000
[ 1.266138] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.266169] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.266195] usb usb3: Product: DWC OTG Controller
[ 1.266219] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 1.266244] usb usb3: SerialNumber: 10180000.usb
[ 1.267173] hub 3-0:1.0: USB hub found
[ 1.267222] hub 3-0:1.0: 1 port detected
[ 1.267860] usb20_host: version 3.10a 21-DEC-2012
[ 1.268796] usbcore: registered new interface driver xpad
[ 1.268916] usbcore: registered new interface driver usb_acecad
[ 1.269015] usbcore: registered new interface driver aiptek
[ 1.269110] usbcore: registered new interface driver gtco
[ 1.269206] usbcore: registered new interface driver hanwang
[ 1.269301] usbcore: registered new interface driver kbtab
[ 1.269426] usbcore: registered new interface driver wacom
[ 1.270251] sensor_register_slave:mma8452,id=17
[ 1.270282] sensor_register_slave:gs_mc3230,id=23
[ 1.270301] gsensor_init
[ 1.270320] sensor_register_slave:mpu6880_acc,id=24
[ 1.270341] sensor_register_slave:cm3217,id=47
[ 1.270361] sensor_register_slave:cm3218,id=48
[ 1.270737] .. rk pwm remotectl v1.1 init
[ 1.271150] input: 20050030.pwm as /devices/20050030.pwm/input/input0
[ 1.277242] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 1.277326] i2c /dev entries driver
[ 1.277918] IR NEC protocol handler initialized
[ 1.277945] IR RC5(x) protocol handler initialized
[ 1.277964] IR RC6 protocol handler initialized
[ 1.277982] IR JVC protocol handler initialized
[ 1.278000] IR Sony protocol handler initialized
[ 1.278018] IR RC5 (streamzap) protocol handler initialized
[ 1.278037] IR SANYO protocol handler initialized
[ 1.278056] IR MCE Keyboard/mouse protocol handler initialized
[ 1.278529] usbcore: registered new interface driver uvcvideo
[ 1.278554] USB Video Class driver (1.1.1)
[ 1.278578] CamSys driver version: v0.27.1, CamSys head file version: v0.10.0
[ 1.278604] E:camsys_soc_init(87): camsys isn’t support soc: 0x31260001!
[ 1.280678] i2c-core: driver [bq27320] using legacy suspend method
[ 1.280708] i2c-core: driver [bq27320] using legacy resume method
[ 1.281473] device-mapper: uevent: version 1.0.3
[ 1.281984] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 1.282626] Bluetooth: HCI UART driver ver 2.2
[ 1.282654] Bluetooth: HCI H4 protocol initialized
[ 1.282675] Bluetooth: HCILL protocol initialized
[ 1.282695] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.19
[ 1.282716] rtk_btusb: Register usb char device interface for BT driver
[ 1.283132] usbcore: registered new interface driver rtk_btusb
[ 1.287154] cpufreq version 1.0, suspend freq 1008 MHz
[ 1.287511] cpuidle: using governor ladder
[ 1.287536] cpuidle: using governor menu
[ 1.287627] Synopsys Designware Multimedia Card Interface Driver
[ 1.287650] MHSC version = Ver 2.00 2015-06-10
[ 1.288088] dw cru_regsbase addr 0x124.
[ 1.288113] dw cru_reset_offset val 3.
[ 1.288142] dwmmc_rockchip 1021c000.rksdmmc: Version ID is 270a
[ 1.288203] dwmmc_rockchip 1021c000.rksdmmc: failed to get hpclk_mmc
[ 1.288665] dwmmc_rockchip 1021c000.rksdmmc: Using external DMA controller.
[ 1.289074] dw_mci_init_slot: fmin=400000, fmax=50000000 [mmc0]
[ 1.289331] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.305922] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.325671] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 1.325705] dwmmc_rockchip 1021c000.rksdmmc: DW MMC controller at irq 48, 32 bit host data width, 256 deep fifo
[ 1.325723] dwmmc_rockchip 1021c000.rksdmmc: 1 slots initialized
[ 1.326249] dw cru_regsbase addr 0x124.
[ 1.326274] dw cru_reset_offset val 1.
[ 1.326302] dwmmc_rockchip 10214000.rksdmmc: Version ID is 270a
[ 1.326363] dwmmc_rockchip 10214000.rksdmmc: failed to get hpclk_mmc
[ 1.327162] dwmmc_rockchip 10214000.rksdmmc: Using external DMA controller.
[ 1.327510] dw_mci_init_slot: fmin=400000, fmax=37500000 [mmc1]
[ 1.328162] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.345284] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.357846] mmc0: BKOPS_EN bit is not set
[ 1.359814] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 1.359849] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 1.359869] rk_sdmmc: BOOT dw_mci_setup_bus: workaround div = 1, host->bus_hz = 100000000 [mmc0]
[ 1.359983] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=8bits.[mmc0]
[ 1.360188] mmc0: new high speed DDR MMC card at address 0001
[ 1.360782] mmcblk0: mmc0:0001 8GND3R 7.28 GiB
[ 1.361416] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 1.361440] misc: 0x000800000 – 0x000c00000 (4 MB)
[ 1.361460] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 1.361478] kernel: 0x001c00000 – 0x002800000 (12 MB)
[ 1.361496] boot: 0x002800000 – 0x003400000 (12 MB)
[ 1.361514] recovery: 0x003400000 – 0x005400000 (32 MB)
[ 1.361532] backup: 0x005400000 – 0x009400000 (64 MB)
[ 1.361551] cache: 0x009400000 – 0x011400000 (128 MB)
[ 1.361569] userdata: 0x011400000 – 0x051000000 (1020 MB)
[ 1.361588] metadata: 0x051000000 – 0x052000000 (16 MB)
[ 1.361606] kpanic: 0x052000000 – 0x052400000 (4 MB)
[ 1.361625] system: 0x052400000 – 0x092400000 (1024 MB)
[ 1.361644] radical_update: 0x092400000 – 0x096400000 (64 MB)
[ 1.361663] user: 0x096400000 – 0x1d1c00000 (5048 MB)
[ 1.361721] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14[ 1.365116] dwc_otg_hcd_suspend, usb device mode
[ 1.365184] dwmmc_rockchip 10214000.rksdmmc: DW MMC controller at irq 46, 32 bit host data width, 256 deep fifo
[ 1.365218] dwmmc_rockchip 10214000.rksdmmc: 1 slots initialized
[ 1.365649] dw cru_regsbase addr 0x124.
[ 1.365668] dw cru_reset_offset val 2.
[ 1.365689] dwmmc_rockchip 10218000.rksdmmc: Version ID is 270a
[ 1.365742] dwmmc_rockchip 10218000.rksdmmc: failed to get hpclk_mmc
[ 1.366159] dwmmc_rockchip 10218000.rksdmmc: Using external DMA controller.
[ 1.366786] dw_mci_init_slot: fmin=200000, fmax=37500000 [mmc2]
[ 1.367008] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.384624] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.404310] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.404338] dwmmc_rockchip 10218000.rksdmmc: DW MMC controller at irq 47, 32 bit host data width, 256 deep fifo
[ 1.404355] dwmmc_rockchip 10218000.rksdmmc: 1 slots initialized
[ 1.404631] leds-gpio leds.22: pins are not configured from the driver
[ 1.404724] gpiod_request: flags 0, gpio 32, desc c0dfa27c
[ 1.404874] gpiod_request: flags 0, gpio 32, desc c0dfa30c
[ 1.405082] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.407400] usbcore: registered new interface driver usbhid
[ 1.407418] usbhid: USB HID core driver
[ 1.407951] zram: Created 1 device(s) …
[ 1.408517] ashmem: initialized
[ 1.408724] logger: created 256K log ‘log_main’
[ 1.408897] logger: created 256K log ‘log_events’
[ 1.409064] logger: created 256K log ‘log_radio’
[ 1.409222] logger: created 256K log ‘log_system’
[ 1.410409] gpiod_request: flags 0, gpio 32, desc c0dfa57c
[ 1.410757] input: rk29-keypad as /devices/2006c000.adc/key.25/input/input1
[ 1.412140] gpiod_request: flags 0, gpio 32, desc c0dfa564
[ 1.412192] ------------[ cut here ]------------
[ 1.412212] WARNING: at drivers/gpio/gpiolib.c:160 gpio_ensure_requested+0x4c/0xb4()
[ 1.412223] autorequest GPIO-27
[ 1.412232] Modules linked in:
[ 1.412247] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 3.10.0 #18
[ 1.412278] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 1.412300] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68)
[ 1.412320] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_fmt+0x2c/0x3c)
[ 1.412340] [] (warn_slowpath_fmt+0x2c/0x3c) from [] (gpio_ensure_requested+0x4c/0xb4)
[ 1.412361] [] (gpio_ensure_requested+0x4c/0xb4) from [] (gpiod_direction_input+0x58/0x1f0)
[ 1.412384] [] (gpiod_direction_input+0x58/0x1f0) from [] (rk312x_platform_probe+0x46c/0x5a4)
[ 1.412407] [] (rk312x_platform_probe+0x46c/0x5a4) from [] (platform_drv_probe+0x14/0x18)
[ 1.412429] [] (platform_drv_probe+0x14/0x18) from [] (really_probe+0xa8/0x20c)
[ 1.412450] [] (really_probe+0xa8/0x20c) from [] (driver_probe_device+0x30/0x48)
[ 1.412469] [] (driver_probe_device+0x30/0x48) from [] (__driver_attach+0x60/0x84)
[ 1.412489] [] (__driver_attach+0x60/0x84) from [] (bus_for_each_dev+0x50/0x90)
[ 1.412508] [] (bus_for_each_dev+0x50/0x90) from [] (bus_add_driver+0xac/0x20c)
[ 1.412528] [] (bus_add_driver+0xac/0x20c) from [] (driver_register+0x9c/0x138)
[ 1.412548] [] (driver_register+0x9c/0x138) from [] (do_one_initcall+0x34/0xc8)
[ 1.412569] [] (do_one_initcall+0x34/0xc8) from [] (do_initcalls+0x70/0xa0)
[ 1.412589] [] (do_initcalls+0x70/0xa0) from [] (kernel_init_freeable+0x90/0x130)
[ 1.412610] [] (kernel_init_freeable+0x90/0x130) from [] (kernel_init+0x8/0xe4)
[ 1.412633] [] (kernel_init+0x8/0xe4) from [] (ret_from_fork+0x14/0x3c)
[ 1.412673] —[ end trace efb7c902a4c65bc0 ]—
[ 1.412945] This platfrom have not i2s_mclk,no need to set i2s_mclk.
[ 1.413427] rockchip-spdif 10204000.spdif: spdif ready.
[ 1.415497] audio-rk312x audio-rk312x.14: rk312x-hifi ↔ rockchip-i2s.1 mapping ok
[ 1.416217] audio-rk312x audio-rk312x.14: rk312x-voice ↔ rockchip-i2s.1 mapping ok
[ 1.416258] audio-rk312x audio-rk312x.14: ASoC: no sink widget found for Mic Bias
[ 1.416273] audio-rk312x audio-rk312x.14: ASoC: Failed to add route Mic Jack → direct → Mic Bias
[ 1.416288] audio-rk312x audio-rk312x.14: ASoC: no source widget found for Mic Bias
[ 1.416302] audio-rk312x audio-rk312x.14: ASoC: Failed to add route Mic Bias → direct → MICP
[ 1.416317] audio-rk312x audio-rk312x.14: ASoC: no source widget found for Mic Bias
[ 1.416331] audio-rk312x audio-rk312x.14: ASoC: Failed to add route Mic Bias → direct → MICN
[ 1.416345] audio-rk312x audio-rk312x.14: ASoC: no sink widget found for Mic Bias
[ 1.416359] audio-rk312x audio-rk312x.14: ASoC: Failed to add route Headset Jack → direct → Mic Bias
[ 1.416374] audio-rk312x audio-rk312x.14: ASoC: no source widget found for HPOUTR
[ 1.416387] audio-rk312x audio-rk312x.14: ASoC: Failed to add route HPOUTR → direct → Ext Spk
[ 1.416401] audio-rk312x audio-rk312x.14: ASoC: no source widget found for HPOUTL
[ 1.416415] audio-rk312x audio-rk312x.14: ASoC: Failed to add route HPOUTL → direct → Ext Spk
[ 1.416429] audio-rk312x audio-rk312x.14: ASoC: no source widget found for HPOUTR
[ 1.416443] audio-rk312x audio-rk312x.14: ASoC: Failed to add route HPOUTR → direct → Headphone Jack
[ 1.416457] audio-rk312x audio-rk312x.14: ASoC: no source widget found for HPOUTL
[ 1.416471] audio-rk312x audio-rk312x.14: ASoC: Failed to add route HPOUTL → direct → Headphone Jack
[ 1.417850] u32 classifier
[ 1.417867] Actions configured
[ 1.417881] Netfilter messages via NETLINK v0.30.
[ 1.417964] nf_conntrack version 0.5.0 (15471 buckets, 61884 max)
[ 1.418468] ctnetlink v0.93: registering with nfnetlink.
[ 1.418563] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 1.418575] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 1.419074] xt_time: kernel timezone is -0000
[ 1.419374] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.419588] arp_tables: (C) 2002 David S. Miller
[[ [ 1.[ [ 1.430424] ddrfreq: verion 1.2 20140526
[ 1.430449] [ 1.444576] rk818_ldo8: disabling
[ 1.445460] rk818_ldo4: disabling
[ 1.446107] regulator-dummy: disabling
[ 1.446282] ====================================================[[[[[ 1.447905] [[ [ [ 1.[ 1.456252] rockchip-spdif-card rockchip-spdif-card.23: rk-hdmi-spdif-hifi ↔ 10[ 1.457633] us[ 1[ 1.512548] usb 1-1: new high-speed USB device number 2 using rockchip_ehci_host
[ 1.532210] Cam_Powerdowm
[ 1.532313] rk818_ldo8: operation not allowed
[ 1.551883] [WLAN_RFKILL]: wifi turn on power. 43
[ 1.601174] rk818_ldo4: operation not allowed
[ 1.640482] ret: 0
[ 1.660693] min_w = 800,min_h = 600 ,max_real_w = 2592,max_real_h = 1944,max_w = 2592,max_h =1944
[ 1.660811] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101
[ 1.660832] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.660849] usb 1-1: Product: USB 2.0 Hub [MTT]
[ 1.661560] hub 1-1:1.0: USB hub found
[ 1.661664] hub 1-1:1.0: 4 ports detected
[ 1.662222] s5k4ec_back_3(rk_cam_sensor:169): write reg(0xfcfc, val:0xd000) failed, try to write again!
[ 1.663716] s5k4ec_back_3(rk_cam_sensor:169): write reg(0xfcfc, val:0xd000) failed, try to write again!
[ 1.665201] s5k4ec_back_3(rk_cam_sensor:169): write reg(0xfcfc, val:0xd000) failed, try to write again!
[ 1.665228] s5k4ec_back_3(rk_cam_sensor:387): write array failed!
[ 1.665242] s5k4ec_back_3(rk_cam_sensor:671): soft reset failed
[ 1.665242]
[ 1.681270] s5k4ec_back_3(rk_cam_sensor:169): write reg(0x2c, val:0x7000) failed, try to write again!
[ 1.682745] s5k4ec_back_3(rk_cam_sensor:169): write reg(0x2c, val:0x7000) failed, try to write again!
[ 1.684217] s5k4ec_back_3(rk_cam_sensor:169): write reg(0x2c, val:0x7000) failed, try to write again!
[ 1.685691] s5k4ec_back_3(rk_cam_sensor:169): write reg(0x2e, val:0x1a4) failed, try to write again!
[ 1.687164] s5k4ec_back_3(rk_cam_sensor:169): write reg(0x2e, val:0x1a4) failed, try to write again!
[ 1.688636] s5k4ec_back_3(rk_cam_sensor:169): write reg(0x2e, val:0x1a4) failed, try to write again!
[ 1.690430] s5k4ec_back_3(rk_cam_sensor:335): read reg(0xf12 val:0x0) failed, try to read again!
[ 1.690459] s5k4ec_back_3(rk_cam_sensor:718): error: mismatched pid = 0xffff
[ 1.690459]
[ 1.758553] wifi_platform_bus_enumerate device present 1
[ 1.758572] ======== Card detection to detect SDIO card! ========
[ 1.758579] ret: 0
[ 1.758597] mmc2:mmc host rescan start!
[ 1.843822] type=1403 audit(1293894565.890:2): policy loaded auid=4294967295 ses=4294967295
[ 1.886500] Cam_Powerdowm
[ 1.896464] soc-camera-pdrv ov2659_front_4: Probing ov2659_front_4
[ 1.896477] init: could not import file ‘init.box.samba.rc’ from ‘/init.rk30board.rc’
[ 1.901276] init: invalid gid ‘trace’
[ 1.965206] ret: 0
[ 1.975048] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2]
[ 2.010398] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.012002] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.013599] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.016470] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.019947] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
[ 2.105565] mmc_host mmc2: Bus speed (slot 0) = 37500000Hz (slot req 37500000Hz, actual 37500000HZ div = 0)
[ 2.105602] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
[ 2.105746] rk_sdmmc: BOOT Bus speed=37500000Hz,Bus width=4bits.[mmc2]
[ 2.108257] mmc2: new high speed SDIO card at address 0001
[ 2.112795] Cam_Powerdowm
[ 2.113423] min_w = 800,min_h = 600 ,max_real_w = 1600,max_real_h = 1200,max_w = 1600,max_h =1200
[ 2.114706] ov2659_front_4(rk_cam_sensor:169): write reg(0x103, val:0x1) failed, try to write again!
[ 2.115957] ov2659_front_4(rk_cam_sensor:169): write reg(0x103, val:0x1) failed, try to write again!
[ 2.117204] ov2659_front_4(rk_cam_sensor:169): write reg(0x103, val:0x1) failed, try to write again!
[ 2.117236] ov2659_front_4(rk_cam_sensor:387): write array failed!
[ 2.117250] ov2659_front_4(rk_cam_sensor:671): soft reset failed
[ 2.117250]
[ 2.124843] bcmsdh_register: register client driver
[ 2.125011] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2.125150] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2.125169] bus num (host idx)=2, slot num (rca)=1
[ 2.125184] found adapter info ‘DHD generic adapter’
[ 2.125659] F1 signature read @0x18000000=0x1541a9a6
[ 2.128291] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x1 pkg:0x4
[ 2.128498] init: /dev/hw_random not found
[ 2.128618] keychord: using input dev 20050030.pwm for fevent
[ 2.128640] keychord: using input dev rk29-keypad for fevent
[ 2.129350] DHD: dongle ram size is set to 524288(orig 524288) at 0x0
[ 2.129515] wifi_platform_get_mac_addr
[ 2.129533] ======== bcm_wlan_get_mac_address ========
[ 2.129547] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
[ 2.129578] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
[ 2.129589] [WLAN_RFKILL]: This mac address is not valid, ignored…
[ 2.129603] dhd_conf_set_chiprev: chip=0xa9a6, chiprev=1
[ 2.129676] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txt
[ 2.130401] wl_create_event_handler(): thread:wl_event_handler:6f started
[ 2.130663] tsk Enter, tsk = 0xddd6149c
[ 2.130727] dhd_attach(): thread:dhd_watchdog_thread:70 started
[ 2.130828] dhd_attach(): thread:dhd_dpc:71 started
[ 2.130885] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
[ 2.130952] dhd_attach(): thread:dhd_rxf:72 started
[ 2.130977] dhd_deferred_work_init: work queue initialized
[ 2.131247] dhdsdio_probe_init: set use_rxchain 0 from config.txt
[ 2.134055] ov2659_front_4(rk_cam_sensor:335): read reg(0x300a val:0x0) failed, try to read again!
[ 2.134091] ov2659_front_4(rk_cam_sensor:699): read chip id failed
[ 2.141731] init: /dev/hw_random not found
[ 2.143651] Dongle Host Driver, version 1.201.59.5 (r506368)
[ 2.143651] Compiled in drivers/net/wireless/bcmdhd on Jun 29 2017 at 01:25:43
[ 2.144299] fs_mgr: Running /sbin/resize2fs on /dev/block/platform/1021c000.rksdmmc/by-name/system
[ 2.144580] Register interface [wlan0] MAC: cc:b8:a8:19:c2:66
[ 2.144580]
[ 2.144614] dhd_prot_ioctl : bus is down. we have nothing to do
[ 2.145832] bcmsdh_oob_intr_unregister: Enter
[ 2.145856] bcmsdh_oob_intr_unregister: irq is not registered
[ 2.145878] dhd_txglom_enable: enable 0
[ 2.145895] dhd_bus_devreset: WLAN OFF DONE
[ 2.146031] wifi_platform_set_power = 0
[ 2.146050] ======== PULL WL_REG_ON LOW! ========
[ 2.146070] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 2.147151] resize2fs: resize2fs 1.42.9 (28-Dec-2013)resize2fs: The filesystem is already 262144 blocks long. Nothing to do!resize2fs:
[ 2.155089] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 2.155278] fs_mgr: __mount(source=/dev/block/platform/1021c000.rksdmmc/by-name/system,target=/system,type=ext4)=0
[ 2.163684] EXT4-fs (mmcblk0p8): recovery complete
[ 2.164077] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.164245] fs_mgr: __mount(source=/dev/block/platform/1021c000.rksdmmc/by-name/cache,target=/cache,type=ext4)=0
[ 2.169160] EXT4-fs (mmcblk0p10): recovery complete
[ 2.169193] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.169340] fs_mgr: __mount(source=/dev/block/platform/1021c000.rksdmmc/by-name/metadata,target=/metadata,type=ext4)=0
[ 2.240702] Cam_Powerdowm
[ 2.250520] [WLAN_RFKILL]: wifi shut off power.
[ 2.250542] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
[ 2.250557] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 2.250674] dhd_module_init: Exit err=0
[ 2.255832] EXT4-fs (mmcblk0p9): recovery complete
[ 2.256224] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.256389] fs_mgr: __mount(source=/dev/block/platform/1021c000.rksdmmc/by-name/userdata,target=/data,type=ext4)=0
[ 2.309607] ret: 0
[ 2.319131] Adding 65532k swap on /dev/block/zram0. Priority:-1 extents:1 across:65532k SS
[ 2.335603] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 382; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘-6e9f168’, rk_ko_ver is ‘5’, built at ‘18:04:38’, on ‘Sep 7 2015’.
[ 2.335831] mali-utgard 10091000.gpu: mali_platform_device->num_resources = 13
[ 2.335856] mali-utgard 10091000.gpu: mali_platform_device->resource[0].start = 0x10091000
[ 2.335876] mali-utgard 10091000.gpu: mali_platform_device->resource[1].start = 0x10090000
[ 2.335895] mali-utgard 10091000.gpu: mali_platform_device->resource[2].start = 0x10093000
[ 2.335915] mali-utgard 10091000.gpu: mali_platform_device->resource[3].start = 0x10098000
[ 2.335935] mali-utgard 10091000.gpu: mali_platform_device->resource[4].start = 0x10094000
[ 2.335954] mali-utgard 10091000.gpu: mali_platform_device->resource[5].start = 0x1009a000
[ 2.335974] mali-utgard 10091000.gpu: mali_platform_device->resource[6].start = 0x10095000
[ 2.335993] mali-utgard 10091000.gpu: mali_platform_device->resource[7].start = 0x00000023
[ 2.336012] mali-utgard 10091000.gpu: mali_platform_device->resource[8].start = 0x00000024
[ 2.336030] mali-utgard 10091000.gpu: mali_platform_device->resource[9].start = 0x00000025
[ 2.336049] mali-utgard 10091000.gpu: mali_platform_device->resource[10].start = 0x00000024
[ 2.336067] mali-utgard 10091000.gpu: mali_platform_device->resource[11].start = 0x00000025
[ 2.336086] mali-utgard 10091000.gpu: mali_platform_device->resource[12].start = 0x00000024
[ 2.336163] mali-utgard 10091000.gpu: freq: 200000000, min_threshold: 0, max_threshold: 70
[ 2.336184] mali-utgard 10091000.gpu: freq: 297000000, min_threshold: 61, max_threshold: 85
[ 2.336204] mali-utgard 10091000.gpu: freq: 400000000, min_threshold: 73, max_threshold: 100
[ 2.336310] mali-utgard 10091000.gpu: initial freq = 200000000
[ 2.338982] Mali: Mali device driver loaded
[ 2.339139] soc-camera-pdrv gc0329_front_5: Probing gc0329_front_5
[ 2.340390] rk29_ipp: version magic ‘3.0.8+ SMP preempt m[ 2.3412[ 2.342[ 2.34[ 2.356515] fs_mgr: swapon failed for /dev/block/zram0
[ 2.397624] EXT4-fs (mmcblk0p9): Unrecognized mount option “background_gc=on” or missing value
[ 2.407993] ret: 0
[ 2.416205] bat_cap: oldcap path is /sys/devices/2006c000.adc
[ 2.416338] bat_cap: oldcap_path no exist
[ 2.416903] binder: 129:129 transaction failed 29189, size 0-0
[ 2.428742] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 2.428791] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
[ 2.429471] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
[ 2.431051] rtk_btusb: btchr_open: BT usb char device is opening
[ 2.431080] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 2.431123] rtk_btusb: btchr_open: BT usb char device is opening
[ 2.431144] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 2.431197] rtk_btusb: btchr_open: BT usb char device is opening
[ 2.431213] [[ 2.450234] init: cannot find ‘/system/bin/debuggerd64’, disabling ‘debuggerd64’
[ 2.454344] init: cannot find ‘/system/bin/install-recovery.sh’, disabling ‘flash_recovery’
[ 2.455667] init: cannot find ‘/system/bin/bplus_helper’, disabling ‘bplus_helper’
[ 2.456487] i[ 2.457838] [ 2.464715] android_usb: already disabled
[ 2.475201] read descriptors
[ 2.475235] read strings
[ 2.475308] pcd_pullup, is_on 1
[ 2.555620] Cam_Powerdowm
[ 2.556310] min_w = 640,min_h = 480 ,max_real_w = 640,max_real_h = 480,max_w = 640,max_h =480
[ 2.576283] gc0329_front_5(rk_cam_sensor:169): write reg(0xfc, val:0x16) failed, try to write again!
[ 2.577256] gc0329_front_5(rk_cam_sensor:169): write reg(0xfc, val:0x16) failed, try to write again!
[ 2.578221] gc0329_front_5(rk_cam_sensor:169): write reg(0xfc, val:0x16) failed, try to write again!
[ 2.607044] gc0329_front_5(rk_cam_sensor:335): read reg(0x0 val:0x0) failed, try to read again!
[ 2.607080] gc0329(917): gc0329 read chip id high byte failed
[ 2.607080]
[ 2.607102] gc0329(924): error: gc0329 mismatched pid = 0x0
[ 2.607102]
[ 2.607124] gc0329_front_5(rk_cam_sensor:718): error: mismatched pid = 0x0
[ 2.607124]
[ 2.713051] Cam_Powerdowm
[ 2.781952] ret: 0
[ 2.811485] soc-camera-pdrv gc2035_back_6: Probing gc2035_back_6
[ 2.900030] ret: 0
[ 2.953302] logd.auditd: start
[ 3.047628] Cam_Powerdowm
[ 3.047660] rk_cam_io(1128):SENSOR_PWRSEQ_PWRDN failed
[ 3.047784] soc-camera-pdrv gc2035_back_6: Cannot get I2C adapter #2. No driver?
[ 3.155837] Cam_Powerdowm
[ 3.155868] rk_cam_io(1128):SENSOR_PWRSEQ_PWRDN failed
[ 3.155885] rk_cam_io(1117):SENSOR_PWRSEQ_HWRST failed
[ 3.180503] EHCI: rk_ehci_hcd_enable, enable host controller
[ 3.250636] rk312x-lcdc lcdc0: blank mode:0
[ 3.273929] ret: 0
[ 3.311329] soc-camera-pdrv gc0308_front_7: Probing gc0308_front_7
[ 3.441253] ret: 0
[ 3.588827] Cam_Powerdowm
[ 3.588959] soc-camera-pdrv gc0308_front_7: Cannot get I2C adapter #2. No driver?
[ 3.697074] Cam_Powerdowm
[ 3.765985] ret: 0
[ 4.376082] rk312x_delay_workq
[ 4.494172] [off]
[ 5.258562] warning: `system_server’ uses 32-bit capabilities (legacy support in use)
[ 5.921225] rk818-battery rk818-battery: changed: dsoc=0, rsoc=0
[ 6.914823] rk818-battery rk818-battery: changed: dsoc=0, rsoc=0
[ 6.915916] rk818-battery rk818-battery: set charge to digital termination mode
[ 9.158273] [otg id chg] last id -1 current id 256
[ 9.158318] PortPower off
[ 9.259402] Using Buffer DMA mode
[ 9.259452] Periodic Transfer Interrupt Enhancement - disabled
[ 9.259469] Multiprocessor Interrupt Enhancement - disabled
[ 9.259484] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 9.259497] ^^^^^^^^^^^^^^^^^Device Mode
[ 9.748693] vbus detect**
[ 9.911735] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
[ 9.911780] lowmemorykiller: oom_adj 0 => oom_score_adj 0
[ 9.911798] lowmemorykiller: oom_adj 1 => oom_score_adj 58
[ 9.911812] lowmemorykiller: oom_adj 2 => oom_score_adj 117
[ 9.911826] lowmemorykiller: oom_adj 3 => oom_score_adj 176
[ 9.911840] lowmemorykiller: oom_adj 9 => oom_score_adj 529
[ 9.911853] lowmemorykiller: oom_adj 15 => oom_score_adj 1000
[ 9.926810] Using Buffer DMA mode
[ 9.926842] Periodic Transfer Interrupt Enhancement - disabled
[ 9.926857] Multiprocessor Interrupt Enhancement - disabled
[ 9.926872] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 9.926884] ^^^^^^^^^^^^^^^^^Device Mode
[ 9.926937] soft connect!!!
[ 10.025756] USB RESET
[ 10.096230] android_work: sent uevent USB_STATE=CONNECTED
[ 10.204566] android_usb gadget: high-speed config #1: android
[ 10.204835] android_work: sent uevent USB_STATE=CONFIGURED
[ 10.674554] acc_open
[ 10.674624] acc_release
[ 11.901505] phy_power_on: enable = 1
[ 11.941004] Read the Ethernet MAC address from IDB:00:00:00:00:00:00
[ 11.941089] eth0: device MAC address 86:51:32:f8:25:ea
[ 11.946178] libphy: stmmac: probed
[ 11.946201] eth0: PHY ID 001cc915 at 0 IRQ 165 (stmmac-0:00) active
[ 11.946215] eth0: PHY ID 001cc915 at 1 IRQ 165 (stmmac-0:01) active
[ 12.291751] dwc_otg_hcd_resume, usb device mode
[ 12.396550] dwc_otg_hcd_suspend, usb device mode
[ 12.576432] FAT-fs (mmcblk0p14): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 12.665197] init: no such service ‘fuse_internal_sd’
这是我的Log,能否帮忙看一下问题在哪里吗?
