编译uboot报错rk3036-sdk.dtb.pre.tmp:77.1-10 syntax error
报错日志如下: 已排除是不是device-tree-compiler的问题;报语法错误的.tmp文件在尾部#include前面多了个"",删掉后编译会重新生成。。已经查了三天了 毫无头绪,求大神带带。
CC drivers/video/drm/rockchip_display.o
CC drivers/video/drm/rockchip_crtc.o
CC drivers/video/drm/rockchip_phy.o
CC drivers/video/drm/rockchip_bridge.o
CC drivers/video/drm/rockchip_vop.o
LD lib/built-in.o
CC drivers/video/drm/rockchip_vop_reg.o
CC drivers/video/drm/bmp_helper.o
CC drivers/video/drm/drm_mipi_dsi.o
CC drivers/video/drm/dw_mipi_dsi.o
CC drivers/video/drm/rockchip_dw_hdmi.o
CC drivers/video/drm/dw_hdmi.o
CC drivers/video/drm/analogix_dp.o
CC drivers/video/drm/analogix_dp_reg.o
CC drivers/video/drm/rockchip_panel.o
LD drivers/video/drm/built-in.o
LD drivers/video/built-in.o
LD drivers/built-in.o
CC examples/standalone/hello_world.o
CC examples/standalone/stubs.o
LD examples/standalone/libstubs.o
LD examples/standalone/hello_world
OBJCOPY examples/standalone/hello_world.srec
OBJCOPY examples/standalone/hello_world.bin
LD u-boot
OBJCOPY u-boot.srec
OBJCOPY u-boot-nodtb.bin
SYM u-boot.sym
DTC arch/arm/dts/rk3036-sdk.dtb
DTC arch/arm/dts/rk3188-radxarock.dtb
DTC arch/arm/dts/rk3288-miqi.dtb
DTC arch/arm/dts/rk3288-phycore-rdk.dtb
DTC arch/arm/dts/rk3288-popmetal.dtb
DTC arch/arm/dts/rk3288-rock2-square.dtb
start=$(/home/saflam/rk3399/rk3399-android-10/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-nm u-boot | grep __rel_dyn_start | cut -f 1 -d ’ '); end=$(/home/saflam/rk3399/rk3399-android-10/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-nm u-boot | grep __rel_dyn_end | cut -f 1 -d ’ '); tools/relocate-rela u-boot-nodtb.bin 0x00200000 $start $end
DTC arch/arm/dts/rk3288-tinker.dtb
Error: arch/arm/dts/.rk3036-sdk.dtb.pre.tmp:77.1-10 syntax error
FATAL ERROR: Unable to parse input tree
make[2]: *** [scripts/Makefile.lib:319:arch/arm/dts/rk3036-sdk.dtb] 错误 1
make[2]: *** 正在等待未完成的任务…
Error: arch/arm/dts/.rk3188-radxarock.dtb.pre.tmp:383.1-10 syntax error
make[2]: *** [scripts/Makefile.lib:319:arch/arm/dts/rk3188-radxarock.dtb] 错误 1
make[1]: *** [dts/Makefile:101:arch-dtbs] 错误 2
make: *** [Makefile:883:dts/dt.dtb] 错误 2
这是报错.tmp文件的部分内容
&usb_host {
vbus-supply = <&vcc5v0_host>;
status = “okay”;
&usb_otg {
vbus-supply = <&vcc5v0_otg>;
status = “okay”;
&pinctrl {
usb_otg {
otg_vbus_drv: host-vbus-drv {
rockchip,pins = <0 26 RK_FUNC_GPIO &pcfg_pull_none>;
usb_host {
	host_vbus_drv: host-vbus-drv {
		rockchip,pins = <2 23 RK_FUNC_GPIO &pcfg_pull_none>;
#include “rk3036-sdk-u-boot.dtsi”
有大神给分析下嘛
找到方法了 给同样困扰的朋友们借鉴下 https://blog.csdn.net/qq3965470/article/details/112419619
