eMMC驱动无法正常加载
各位,请教个问题,我们基于Firefly 3308开发版自己做了一块板子,唯一区别就是使用了RK816 PMIC (Firefly的板子用的是离散IC)。eMMC硬件跟Firefly相同,软件上eMMC部分也是跟Firefly的配置基本相同,结果eMMC驱动没有正常加载,报如下的错误。量了一下eMMC芯片的供电也没有问题,是3.3V。不知道哪里出现了问题,希望各位高手帮忙解答。感谢!
[ 0.629433] dwmmc_rockchip ff490000.dwmmc: No default pinctrl state
[ 0.629501] dwmmc_rockchip ff490000.dwmmc: No off pinctrl state
[ 0.629631] dwmmc_rockchip ff490000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.629685] dwmmc_rockchip ff490000.dwmmc: Using internal DMA controller.
[ 0.629708] dwmmc_rockchip ff490000.dwmmc: Version ID is 270a
[ 0.629782] dwmmc_rockchip ff490000.dwmmc: DW MMC controller at irq 23,32 bit host data width,256 deep fifo
[ 0.629867] dwmmc_rockchip ff490000.dwmmc: No vmmc regulator found
[ 0.629884] dwmmc_rockchip ff490000.dwmmc: No vqmmc regulator found
[ 0.640555] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div
[ 0.758522] mmc1: MAN_BKOPS_EN bit is not set
[ 0.764386] mmc_host mmc1: Bus speed (slot 0) = 147456000Hz (slot req 150000000Hz, actual 147456000HZ div = 0)
[ 0.765279] dwmmc_rockchip ff490000.dwmmc: All phases bad!
[ 0.765299] mmc1: tuning execution failed
[ 0.765317] mmc1: error -5 whilst initialising MMC card
[ 0.777577] mmc_host mmc1: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[ 0.838055] mmc1: MAN_BKOPS_EN bit is not set
[ 0.845878] mmc_host mmc1: Bus speed (slot 0) = 147456000Hz (slot req 150000000Hz, actual 147456000HZ div = 0)
[ 0.846791] dwmmc_rockchip ff490000.dwmmc: All phases bad!
[ 0.846813] mmc1: tuning execution failed
[ 0.846831] mmc1: error -5 whilst initialising MMC card
[ 0.859599] mmc_host mmc1: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0)
[ 0.948216] mmc1: MAN_BKOPS_EN bit is not set
[ 0.962585] mmc_host mmc1: Bus speed (slot 0) = 147456000Hz (slot req 150000000Hz, actual 147456000HZ div = 0)
[ 0.963747] dwmmc_rockchip ff490000.dwmmc: All phases bad!
[ 0.963788] mmc1: tuning execution failed
[ 0.963823] mmc1: error -5 whilst initialising MMC card
emmc dts 和完整kernel log如下:&emmc {
bus-width = <8>;
cap-mmc-highspeed;
mmc-hs200-1_8v;
supports-emmc;
disable-wp;
non-removable;
num-slots = <1>;
status = “disabled”;
[ 0.000000] Linux version 4.4.143 (jeff@jeff-VirtualBox) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) )
[ 0.000000] Boot CPU: AArch64 Processor [410fd042]
[ 0.000000] earlycon: Early serial console at MMIO32 0xff0c0000 (options ‘’)
[ 0.000000] PERCPU: Embedded 18 pages/cpu @ffffffc01ff55000 s35992 r8192 d29544 u73728
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 128520
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.slot_suffix= androidboot.serialno=c3d9b8674f4b94f6 rootwait earlycon=uart8250,mmio32,0xff0c0000 swiotlb=1 console=ttyFIQ0 root=PARTUUID=614e0000-0000 rootfstype=squashfs snd_aloop.index=7
[ 0.000000] PID hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.000000] software IO TLB [mem 0x1fe51000-0x1fe91000] (0MB) mapped at [ffffffc01fe51000-ffffffc01fe90fff]
[ 0.000000] Memory: 504440K/522240K available (4862K kernel code, 380K rwdata, 1680K rodata, 320K init, 467K bss, 17800K reserved, 0K cma-reserved)
[ 0.000000] .init : 0xffffff80086f0000 - 0xffffff8008740000 ( 320 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008540000 ( 4864 KB)
[ 0.000000] .rodata : 0xffffff8008540000 - 0xffffff80086f0000 ( 1728 KB)
[ 0.000000] .data : 0xffffff8008740000 - 0xffffff800879f008 ( 381 KB)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc020000000 ( 510 MB)
[ 0.001777] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.002729] pid_max: default: 32768 minimum: 301
[ 0.003296] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.003907] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.005422] sched-energy: CPU device node has no sched-energy-costs
[ 0.006040] Invalid sched_group_energy for CPU0
[ 0.006458] CPU0: update cpu_capacity 1024
[ 0.006883] ASID allocator initialised with 65536 entries
[ 0.016620] Detected VIPT I-cache on CPU1
[ 0.016678] Invalid sched_group_energy for CPU1
[ 0.016683] CPU1: update cpu_capacity 1024
[ 0.016687] CPU1: Booted secondary processor [410fd042]
[ 0.019637] Detected VIPT I-cache on CPU2
[ 0.019675] Invalid sched_group_energy for CPU2
[ 0.019679] CPU2: update cpu_capacity 1024
[ 0.019683] CPU2: Booted secondary processor [410fd042]
[ 0.022685] Detected VIPT I-cache on CPU3
[ 0.022720] Invalid sched_group_energy for CPU3
[ 0.022725] CPU3: update cpu_capacity 1024
[ 0.022729] CPU3: Booted secondary processor [410fd042]
[ 0.022798] Brought up 4 CPUs
[ 0.028008] SMP: Total of 4 processors activated.
[ 0.028447] CPU: All CPU(s) started at EL2
[ 0.028951] Invalid sched_group_energy for CPU3
[ 0.029373] Invalid sched_group_energy for Cluster3
[ 0.029820] Invalid sched_group_energy for CPU2
[ 0.030249] Invalid sched_group_energy for Cluster2
[ 0.030697] Invalid sched_group_energy for CPU1
[ 0.031113] Invalid sched_group_energy for Cluster1
[ 0.031571] Invalid sched_group_energy for CPU0
[ 0.031987] Invalid sched_group_energy for Cluster0
[ 0.033029] devtmpfs: initialized
[ 0.051820] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.052742] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.053754] pinctrl core: initialized pinctrl subsystem
[ 0.055318] NET: Registered protocol family 16
[ 0.060825] cpuidle: using governor menu
[ 0.061218] Registered FIQ tty driver
[ 0.061831] vdso: 2 pages (1 code @ ffffff8008546000, 1 data @ ffffff8008744000)
[ 0.062541] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.063407] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.065696] persistent_ram: found existing invalid buffer, size 1108344864, start 1141121056
[ 0.066524] persistent_ram: found existing invalid buffer, size 537945783, start 26295
[ 0.067780] console [pstore-1] enabled
[ 0.068132] pstore: Registered ramoops as persistent store backend
[ 0.068716] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.086309] fiq debugger fiq mode enabled
[[ 0.087119] console [ttyFIQ0] enabled
[ 0.087794] bootconsole [uart0] disabled
[ 0.088440] Registered fiq debugger ttyFIQ0
WARNING: suspend_mode_handler: Not support call: 0x4
[ 0.100692] vcc_phy supplying 0uV
[ 0.101478] vbus_host supplying 0uV
[ 0.101849] vcc_sys supplying 4000000uV
[ 0.102313] usbcore: registered new interface driver usbfs
[ 0.102418] usbcore: registered new interface driver hub
[ 0.102565] usbcore: registered new device driver usb
[ 0.103867] Advanced Linux Sound Architecture Driver Initialized.
[ 0.104590] Bluetooth: Core ver 2.21
[ 0.104659] NET: Registered protocol family 31
[ 0.104671] Bluetooth: HCI device and connection manager initialized
[ 0.104691] Bluetooth: HCI socket layer initialized
[ 0.104707] Bluetooth: L2CAP socket layer initialized
[ 0.104743] Bluetooth: SCO socket layer initialized
[ 0.105891] rockchip-cpuinfo cpuinfo: Serial : 50fcc4f0ffd11e12
[ 0.106450] clocksource: Switched to clocksource arch_sys_counter
[ 0.109006] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.109344] NET: Registered protocol family 2
[ 0.110081] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.110172] TCP bind hash table entries: 4096 (order: 4, 65536 bytes)
[ 0.110269] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.110370] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.110401] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.110686] NET: Registered protocol family 1
[ 0.111792] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.123297] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.126457] io scheduler noop registered (default)
[ 0.127676] phy phy-ff008000.syscon:usb2-phy@100.0: Failed to get VBUS supply regulator
[ 0.131906] dma-pl330 ff2c0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.131953] dma-pl330 ff2c0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.134426] dma-pl330 ff2d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.134498] dma-pl330 ff2d0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.134879] rockchip-pvtm ff000000.grf:pmu-pvtm: failed to get rst 0 pmu
[ 0.135038] rockchip-pvtm ff00c000.syscon:pvtm: failed to get rst 0 core
[ 0.135862] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 0.138302] ff0e0000.serial: ttyS4 at MMIO 0xff0e0000 (irq = 12, base_baud = 5078125) is a 16550A
[ 0.140200] [drm] Initialized drm 1.1.0 20060810
[ 0.140394] random: nonblocking pool is initialized
[ 0.142421] Unable to detect cache hierarchy for CPU 0
[ 0.142976] Rockchip WiFi SYS interface (V1.00) …
[ 0.143368] ff400000.usb supply vusb_d not found, using dummy regulator
[ 0.143490] ff400000.usb supply vusb_a not found, using dummy regulator
[ 0.256521] dwc2 ff400000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[ 0.257068] dwc2 ff400000.usb: DWC OTG Controller
[ 0.257121] dwc2 ff400000.usb: new USB bus registered, assigned bus number 1
[ 0.257170] dwc2 ff400000.usb: irq 19, io mem 0xff400000
[ 0.258192] hub 1-0:1.0: USB hub found
[ 0.258247] hub 1-0:1.0: 1 port detected
[ 0.481943] phy phy-ff008000.syscon:usb2-phy@100.0: charger = USB_SDP_CHARGER
[ 0.482142] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.482171] ehci-platform: EHCI generic platform driver
[ 0.486029] ehci-platform ff440000.usb: EHCI Host Controller
[ 0.486086] ehci-platform ff440000.usb: new USB bus registered, assigned bus number 2
[ 0.486251] ehci-platform ff440000.usb: irq 20, io mem 0xff440000
[ 0.491485] ehci-platform ff440000.usb: USB 2.0 started, EHCI 1.00
[ 0.492434] hub 2-0:1.0: USB hub found
[ 0.492529] hub 2-0:1.0: 1 port detected
[ 0.493105] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.493203] ohci-platform: OHCI generic platform driver
[ 0.493652] ohci-platform ff450000.usb: Generic Platform OHCI controller
[ 0.493704] ohci-platform ff450000.usb: new USB bus registered, assigned bus number 3
[ 0.493853] ohci-platform ff450000.usb: irq 21, io mem 0xff450000
[ 0.549367] hub 3-0:1.0: USB hub found
[ 0.549425] hub 3-0:1.0: 1 port detected
[ 0.550721] i2c /dev entries driver
[ 0.552526] rk808 0-001a: Pmic Chip id: 0x8160
[ 0.552927] rk808 0-001a: source: on=0x40, off=0x00
[ 0.558037] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 0.558146] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 0.558400] DCDC_REG1: supplied by vcc_sys
[ 0.559976] DCDC_REG2: supplied by vcc_sys
[ 0.561416] DCDC_REG3: supplied by vcc_sys
[ 0.562700] DCDC_REG4: supplied by vcc_sys
[ 0.563854] LDO_REG1: supplied by vcc_io
[ 0.565491] LDO_REG2: supplied by vcc_io
[ 0.567132] LDO_REG3: supplied by vcc_io
[ 0.568936] LDO_REG4: supplied by vcc_sys
[ 0.569283] ldo4: Bringing 3300000uV into 1800000-1800000uV
[ 0.570068] LDO_REG5: supplied by vcc_sys
[ 0.571308] LDO_REG6: supplied by vcc_sys
[ 0.572861] rk816-battery rk816-battery: fb_temperature missing!
[ 0.572901] rk816-battery rk816-battery: energy_mode missing!
[ 0.572929] rk816-bat: not support dc
[ 0.573523] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 0.577999] rk816-bat: save fcc: 2750
[ 0.578815] rk816-bat: first on: dsoc=30, rsoc=30 cap=814, fcc=2750, ov=3747
[ 0.584665] rk816-bat: receive extcon notifier event: OTG OFF…
[ 0.584689] rk816-bat: otg5v is off yet, ignore..
[ 0.584707] rk816-bat: receive extcon notifier event: USB…
[ 0.584734] rk816-bat: register extcon evt notifier
[ 0.585264] rk816-bat: set charger type: USB, current: input=450, chrg=1800
[ 0.586212] rk816-bat: set charger type: NONE DC, current: input=450, chrg=1800
[ 0.589104] rk816-bat: driver version 1.2
[ 0.591411] input: rk8xx_pwrkey as /devices/platform/ff040000.i2c/i2c-0/0-001a/input/input0
[ 0.594998] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 0.595612] rk3x-i2c ff040000.i2c: Initialized RK3xxx I2C bus at ffffff8008866000
[ 0.599293] rk_tsadcv2_temp_to_code: Invalid conversion table: code=4095, temperature=2147483647
[ 0.599597] rockchip-thermal ff1f0000.tsadc: tsadc is probed successfully!
[ 0.600075] Bluetooth: HCI UART driver ver 2.3
[ 0.600100] Bluetooth: HCI UART protocol H4 registered
[ 0.600111] Bluetooth: HCI UART protocol LL registered
[ 0.600388] cpu cpu0: leakage=19
[ 0.600715] cpu cpu0: Failed to get pvtm
[ 0.602254] cpu cpu0: l=0 h=55000 hyst=5000 l_limit=1200000000 h_limit=1008000000
[ 0.604204] Synopsys Designware Multimedia Card Interface Driver
[ 0.605352] dwmmc_rockchip ff480000.dwmmc: No default pinctrl state
[ 0.605393] dwmmc_rockchip ff480000.dwmmc: No off pinctrl state
[ 0.605415] dwmmc_rockchip ff480000.dwmmc: num-slots property not found, assuming 1 slot is available
[ 0.605597] dwmmc_rockchip ff480000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.605649] dwmmc_rockchip ff480000.dwmmc: Using internal DMA controller.
[ 0.605677] dwmmc_rockchip ff480000.dwmmc: Version ID is 270a
[ 0.605759] dwmmc_rockchip ff480000.dwmmc: DW MMC controller at irq 22,32 bit host data width,256 deep fifo
[ 0.617555] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.628613] vcc_1v8: voltage operation not allowed
[ 0.628636] vcc_1v8: voltage operation not allowed
[ 0.628647] set vqmmc to 3.3v, ret=-1
[ 0.629196] dwmmc_rockchip ff480000.dwmmc: 1 slots initialized
[ 2.182454] dwmmc_rockchip ff4a0000.dwmmc: Busy; trying anyway
[ 2.182490] mmc_host mmc2: Timeout sending command (cmd 0x202000 arg 0x0 status 0x0)
[ 2.195559] mmc_host mmc2: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[ 3.702502] vendor storage:20160801 ret = -1
[ 3.713452] dwmmc_rockchip ff4a0000.dwmmc: Busy; trying anyway
[ 3.713480] mmc_host mmc2: Timeout sending command (cmd 0x202000 arg 0x0 status 0x0)
[ 3.726572] mmc_host mmc2: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[ 5.246456] dwmmc_rockchip ff4a0000.dwmmc: Busy; trying anyway
[ 5.246491] mmc_host mmc2: Timeout sending command (cmd 0x202000 arg 0x0 status 0x0)
[ 5.259577] mmc_host mmc2: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0)
[ 5.596271] rk816-bat: changed: dsoc=30, rsoc=30, v=4639, ov=3747 c=0, cap=814, f=2750, st=cc cv, hotdie=0
[ 5.596335] rk816-bat: dl=30, rl=30, v=3238, halt=0, halt_n=0, max=0, init=0, sw=0, calib=0, below0=0, force=0
[ 5.720606] ret 1024
[ 5.722133] ALSA device list:
[ 5.722190] #7: Loopback 1
[ 5.722700] Waiting for root device PARTUUID=614e0000-0000…
[ 6.783459] dwmmc_rockchip ff4a0000.dwmmc: Busy; trying anyway
[ 6.783492] mmc_host mmc2: Timeout sending command (cmd 0x202000 arg 0x0 status 0x0)
已经搞定,原因是dts里面eMMC的配置写成1.8V了。
mmc-hs200-1_8v; ->mmc-hs200-3_3v;就可以了。:)
你好,请问更好emmc后,除了电压外,还需要修改什么吗?我这换了个emmc后,找不到rootfs
请问您换EMMC后,搞定了么?还需要修改什么么?
