DDR Version 1.00 20160530
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-10 (Aug 09 2017 - 17:10:43)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
pmic:act8846
can’t find dts node for pwm1
#Boot ver: 2017-08-09#2.30
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
pll_src = 0, dclk_hz = 205000000, dclk_div = 2
edp pll locked
Aux Transaction fail!
hw lt err:1
link train failed!
unable to config video
no fuel gauge found
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x02000000 (0x006a45a8)
ramdisk @ 0x05bf0000 (0x00146444)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0561c766 … OK
串口的数据是这样的,一直循环
