编译时 限显示Can’t found build config, please check again 找不到mk文件
user@user-virtual-machine:/home/rk3308/Firefly-RK3308$ ./build.sh roc-rk3308b-cc-plus_release_BoardConfig.mk
====USAGE: build.sh modules====
uboot -build uboot
kernel -build kernel
modules -build kernel modules
rootfs -build default rootfs, currently build buildroot as default
buildroot -build buildroot rootfs
ramboot -build ramboot image
yocto -build yocto rootfs, currently build ros as default
ros -build ros rootfs
debian -build debian rootfs
pcba -build pcba
recovery -build recovery
all -build uboot, kernel, rootfs, recovery image
cleanall -clean uboot, kernel, rootfs, recovery
firmware -pack all the image we need to boot up system
updateimg -pack update image
otapackage -pack ab update otapackage image
save -save images, patches, commands used to debug
default -build all modules
user@user-virtual-machine:/home/rk3308/Firefly-RK3308$ ./build.sh ../Firefly-RK3308/device/rockchip/rk3308/roc-rk3308
roc-rk3308b-cc_release_BoardConfig.mk roc-rk3308-cc_release_BoardConfig.mk
device里面也没有开发板cc plus 的config文件
device/rockchip/rk3308/roc-rk3308b-cc_release_BoardConfig.mk
我只找到了 这个mk文件
