rk3128 移植rk816 开机失败
不知道是不是移植电源失败的原因,kernel 卡死
具体log:
DDR Version 2.04 20150121
1A1A1B1C 3
DDR3
1C1C1B1C F
mach:2
Boot1 Release Time: 2015-05-25, version: 2.25
ChipType = a 1365
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=e90000
FwPar▒*V▒k%▒▒▒▒0 20
StorageInit ok = 258541
theL
U-Boot 2014.10-RK3128-10 (Jan 13 2021 - 10:18:21)
CPU: rk3128
CPU’s clock information:
arm pll = 300000000HZ
periph pll = 594000000HZ
ddr pll = 600000000HZ
codec pll = 400000000HZ
Uboot as second level loader
DRAM: Found dram banks:1
128 MiB
rk dma▒storage init OK!
GetParam
check parameter success
power key: bank-3 pin-23
can’t find dts node for act8846
can’t find dts node for rk808
device rk818 is disabled
rk816_set_regulator_init vdd_arm init uV:1300000
cpu_det_gpio up
pmic:rk816
can’t find dts node for ADC
#Boot ver: 2021-01-13#2.25
empty serial no.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
read logo_on switch from dts [1]
failed to find part:logo
no fuel gauge found
got recovery cmd from misc.
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x62000000 (0x006b1838)
ramdisk @ 0x65bf0000 (0x002c8a08)
bootrk: do_bootm_linux…
Loading Device Tree to 65600000, end 65617027 … OK
Add bank:0000000060000000, 0000000040000000
[ 0.000000] Booting Linux on physical CPU 0xf00 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.0+ (hesson@hesson) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #4 SMP PREEMPT Tue Jan 12 10:02:45 HKT 2021 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: Rockchip RK3128, model: rockchip,rk3128 [ 0.000000] rockchip_uboot_logo_setup: mem: 2000000@9dc00000, offset:0 [ 0.000000] rockchip_uboot_mem_reserve: reserve 2000000@9dc00000 for uboot logo [ 0.000000] rockchip_ion_reserve [ 0.000000] ion heap(cma): base(0) size(800000) align(0) [ 0.000000] ion heap(vmalloc): base(0) size(0) align(0) [ 0.000000] cma: CMA: reserved 8 MiB at 9d400000 [ 0.000000] ion_reserve: cma reserved base 9d400000 size 8388608 [ 0.000000] cma: CMA: reserved 16 MiB at 7f000000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] Boot mode: RECOVERY (2) flag: RECOVER (0xc3524203) [ 0.000000] PERCPU: Embedded 9 pages/cpu @c1684000 s14016 r8192 d14656 u36864 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 261120 [ 0.000000] Kernel command line: vmalloc=496M rockchip_jtag console=ttyFIQ0 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00006000@0x0000E000(kernel),0x00006000@0x00014000(boot),0x00010000@0x0001A000(recovery),0x00020000@0x0002A000(backup),0x00040000@0x0004A000(cache),0x00008000@0x0008A000(metadata),0x00002000@0x00092000(kpanic),0x00200000@0x00094000(system),0x00020000@0x00294000(radical_update),-@0x002b4000(userdata) storagemedia=emmc uboot_logo=0x02000000@0x9dc00000 loader.timestamp=2021-01-13_10:18:21 pmic_mode=rk816 [ 0.000000] rockchip jtag enabled [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] allocated 2097152 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Memory: 1024MB = 1024MB total [ 0.000000] Memory: 962604k/962604k available, 85972k reserved, 483328K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB) [ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0bc28dc (12011 kB) [ 0.000000] .init : 0xc0bc3000 - 0xc0c1b6c0 ( 354 kB) [ 0.000000] .data : 0xc0c1c000 - 0xc0d369f8 (1131 kB) [ 0.000000] .bss : 0xc0d369f8 - 0xc0e59e7c (1166 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000 [ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1 [ 0.000000] rkclk_init_clks: cnt_parent = 25 [ 0.000000] rkclk_init_clks: cnt_rate = 17 [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] Switching to timer-based delay loop [ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns [ 0.000000] process version: 0 [ 0.000000] channel:0, lkg:21 [ 0.000000] target-temp:85 [ 0.000000] FirePrime hardware version: V01 [ 0.000000] channel:0, lkg:21 [ 0.000000] target-temp:85 [ 0.000000] channel:0, lkg:21 [ 0.000000] target-temp:85 [ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms [ 0.544887] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.544913] pid_max: default: 32768 minimum: 301 [ 0.545122] Security Framework initialized [ 0.545151] SELinux: Initializing. [ 0.545285] Mount-cache hash table entries: 512 [ 0.546496] Initializing cgroup subsys debug [ 0.546522] Initializing cgroup subsys memory [ 0.546575] Initializing cgroup subsys freezer [ 0.546636] CPU: Testing write buffer coherency: ok [ 0.547153] /cpus/cpu@0 missing clock-frequency property [ 0.547181] /cpus/cpu@1 missing clock-frequency property [ 0.547200] /cpus/cpu@2 missing clock-frequency property [ 0.547219] /cpus/cpu@3 missing clock-frequency property [ 0.547295] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00 [ 0.547365] Setting up static identity map for 0xc085e208 - 0xc085e260 [ 0.549262] last_log: 0x7e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x179d (version 3.0) [ 0.622734] CPU1: Booted secondary processor [ 0.622790] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01 [ 0.642424] CPU2: Booted secondary processor [ 0.642469] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02 [ 0.662186] CPU3: Booted secondary processor [ 0.662229] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03 [ 0.662411] Brought up 4 CPUs [ 0.662463] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 0.662479] CPU: All CPU(s) started in SVC mode. [ 0.663884] devtmpfs: initialized [ 0.674071] pinctrl core: initialized pinctrl subsystem [ 0.674566] regulator-dummy: no parameters [ 0.676080] NET: Registered protocol family 16 [ 0.679508] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.680068] ion_snapshot: 0x7ea18000 map to 0xe0907000 and copy to 0xc0e35384 (version 0.1) [ 0.680288] Registered FIQ tty driver [ 0.682643] console [ttyFIQ0] enabled [ 0.683051] Registered fiq debugger ttyFIQ0 [ 0.684825] rockchip_get_bank_data:name=/pinctrl@20008000/gpio0@2007c000 start=0x2007c000,end=0x2007c0ff [ 0.684955] rockchip_get_bank_data:name=/pinctrl@20008000/gpio1@20080000 start=0x20080000,end=0x200800ff [ 0.685039] rockchip_get_bank_data:name=/pinctrl@20008000/gpio2@20084000 start=0x20084000,end=0x200840ff [ 0.685116] rockchip_get_bank_data:name=/pinctrl@20008000/gpio3@20088000 start=0x20088000,end=0x200880ff [ 0.685204] rockchip_get_bank_data:name=/pinctrl@20008000/gpio15@2008A000 start=0x20086000,end=0x200860ff [ 0.685276] rockchip_pinctrl_probe:name=rk312x-GPIO,type=5 [ 0.685320] rockchip_pinctrl_probe:name=base start=0x20008000,end=0x200080a7 [ 0.685351] rockchip_pinctrl_probe:name=mux start=0x200080a8,end=0x200080f3 [ 0.685380] rockchip_pinctrl_probe:name=pull start=0x20008118,end=0x20008137 [ 0.685408] rockchip_pinctrl_probe:name=drv start=0x20008100,end=0x20008103 [ 0.688120] rockchip_pinctrl_probe:init ok [ 0.695442] rk_iommu 1010e300.vop_mmu: (vop) Enter [ 0.695496] rk_iommu 1010e300.vop_mmu: skip request vop mmu irq [ 0.695604] rk_iommu 1010e300.vop_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.695633] rk_iommu 1010e300.vop_mmu: (vop) Initialized [ 0.695921] rk_iommu 10104440.hevc_mmu: (hevc) Enter [ 0.696064] rk_iommu 10104440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.696095] rk_iommu 10104440.hevc_mmu: (hevc) Initialized [ 0.696369] rk_iommu 10106800.vpu_mmu: (vpu) Enter [ 0.696493] rk_iommu 10106800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.696523] rk_iommu 10106800.vpu_mmu: (vpu) Initialized [ 0.696779] rk_iommu 10108800.iep_mmu: (iep) Enter [ 0.696902] rk_iommu 10108800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.696932] rk_iommu 10108800.iep_mmu: (iep) Initialized [ 0.698262] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.698292] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.698585] DDR DEBUG: version 1.02 20140828 [ 0.698608] DDR DEBUG: DRAM Type:DDR3 [ 0.698633] DDR DEBUG: 1 CS, ROW=15, Bank=8, COL=10, Total Capability=1024MB [ 0.698679] DDR DEBUG: init success!!! freq=300MHz [ 0.751772] bio: create slab at 0 [ 0.752811] Rockchip hdmi driver version 2.0 . [ 0.754523] SCSI subsystem initialized [ 0.754883] usbcore: registered new interface driver usbfs [ 0.754988] usbcore: registered new interface driver hub [ 0.755204] usbcore: registered new device driver usb [ 0.756151] rk3126-usb-control usb_control.18: invalid host gpio-2 [ 0.757428] rockchip_i2c 20072000.i2c: i2c-0: Rockchip I2C adapter [ 0.759142] media: Linux media interface: v0.10 [ 0.759244] Linux video capture interface: v2.00 [ 0.759452] pps_core: LinuxPPS API ver. 1 registered [ 0.759478] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email]giometti@linux.it[/email]> [ 0.759526] PTP clock support registered [ 0.759622] i2c-core: driver [bq24296] using legacy suspend method [ 0.759645] i2c-core: driver [bq24296] using legacy resume method [ 0.760077] RK29 Watchdog Timer, (c) 2011 Rockchip Electronics [ 0.760530] ------------[ cut here ]------------ [ 0.760573] WARNING: at drivers/clk/clk.c:842 clk_disable+0x18/0x24() [ 0.760595] Modules linked in: [ 0.760624] CPU: 2 PID: 1 Comm: swapper/0 Not tainted 3.10.0+ #4 [ 0.760676] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14) [ 0.760717] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68) [ 0.760758] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_null+0x18/0x1c) [ 0.760798] [] (warn_slowpath_null+0x18/0x1c) from [] (clk_disable+0x18/0x24) [ 0.760842] [] (clk_disable+0x18/0x24) from [] (rk29_wdt_stop+0x28/0x38) [ 0.760882] [] (rk29_wdt_stop+0x28/0x38) from [] (rk29_wdt_probe+0x1f0/0x258) [ 0.760925] [] (rk29_wdt_probe+0x1f0/0x258) from [] (platform_drv_probe+0x14/0x18) [ 0.760969] [] (platform_drv_probe+0x14/0x18) from [] (really_probe+0xa8/0x20c) [ 0.761008] [] (really_probe+0xa8/0x20c) from [] (driver_probe_device+0x30/0x48) [ 0.761048] [] (driver_probe_device+0x30/0x48) from [] (__driver_attach+0x60/0x84) [ 0.761087] [] (__driver_attach+0x60/0x84) from [] (bus_for_each_dev+0x50/0x90) [ 0.761126] [] (bus_for_each_dev+0x50/0x90) from [] (bus_add_driver+0xac/0x20c) [ 0.761165] [] (bus_add_driver+0xac/0x20c) from [] (driver_register+0x9c/0x138) [ 0.761205] [] (driver_register+0x9c/0x138) from [] (do_one_initcall+0x34/0xc8) [ 0.761247] [] (do_one_initcall+0x34/0xc8) from [] (do_initcalls+0x70/0xa0) [ 0.761289] [] (do_initcalls+0x70/0xa0) from [] (kernel_init_freeable+0x90/0x130) [ 0.761331] [] (kernel_init_freeable+0x90/0x130) from [] (kernel_init+0x8/0xe4) [ 0.761372] [] (kernel_init+0x8/0xe4) from [] (ret_from_fork+0x14/0x3c) [ 0.761435] ---[ end trace 86de5666825a7981 ]--- [ 0.761494] ------------[ cut here ]------------ [ 0.761526] WARNING: at drivers/clk/clk.c:751 clk_unprepare+0x14/0x1c() [ 0.761546] Modules linked in: [ 0.761572] CPU: 2 PID: 1 Comm: swapper/0 Tainted: G W 3.10.0+ #4 [ 0.761613] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14) [ 0.761652] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68) [ 0.761691] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_null+0x18/0x1c) [ 0.761732] [] (warn_slowpath_null+0x18/0x1c) from [] (clk_unprepare+0x14/0x1c) [ 0.761774] [] (clk_unprepare+0x14/0x1c) from [] (rk29_wdt_probe+0x1f0/0x258) [ 0.761817] [] (rk29_wdt_probe+0x1f0/0x258) from [] (platform_drv_probe+0x14/0x18) [ 0.761858] [] (platform_drv_probe+0x14/0x18) from [] (really_probe+0xa8/0x20c) [ 0.761897] [] (really_probe+0xa8/0x20c) from [] (driver_probe_device+0x30/0x48) [ 0.761937] [] (driver_probe_device+0x30/0x48) from [] (__driver_attach+0x60/0x84) [ 0.761976] [] (__driver_attach+0x60/0x84) from [] (bus_for_each_dev+0x50/0x90) [ 0.762014] [] (bus_for_each_dev+0x50/0x90) from [] (bus_add_driver+0xac/0x20c) [ 0.762053] [] (bus_add_driver+0xac/0x20c) from [] (driver_register+0x9c/0x138) [ 0.762092] [] (driver_register+0x9c/0x138) from [] (do_one_initcall+0x34/0xc8) [ 0.762131] [] (do_one_initcall+0x34/0xc8) from [] (do_initcalls+0x70/0xa0) [ 0.762172] [] (do_initcalls+0x70/0xa0) from [] (kernel_init_freeable+0x90/0x130) [ 0.762212] [] (kernel_init_freeable+0x90/0x130) from [] (kernel_init+0x8/0xe4) [ 0.762253] [] (kernel_init+0x8/0xe4) from [] (ret_from_fork+0x14/0x3c) [ 0.762278] ---[ end trace 86de5666825a7982 ]--- [ 0.763368] Rockchip ion module is successfully loaded (v1.1) [ 0.763635] Advanced Linux Sound Architecture Driver Initialized. [ 0.764369] Bluetooth: Core ver 2.16 [ 0.764447] NET: Registered protocol family 31 [ 0.764470] Bluetooth: HCI device and connection manager initialized [ 0.764504] Bluetooth: HCI socket layer initialized [ 0.764534] Bluetooth: L2CAP socket layer initialized [ 0.764588] Bluetooth: SCO socket layer initialized [ 0.765038] cfg80211: Calling CRDA to update world regulatory domain [ 0.767283] rk816_i2c_probe,line=793 [ 0.767980] pmic is rk816, chip version is 8165 [ 0.768514] pmic on/off source: on=0x40, off=0x0 [ 0.773625] cpu_det_gpio up [ 0.773663] rk816_i2c_probe: rk816_pmic_sleep=0 [ 0.777307] rk816_regulator_probe: compatible rk816 [ 0.780875] vdd_arm: 712 <--> 1450 mV at 1300 mV [ 0.783953] vdd_logic: 712 <--> 1450 mV at 1100 mV [ 0.787048] vcc_ddr: 1200 mV [ 0.790066] vccio: 3000 <--> 3300 mV at 3300 mV [ 0.793346] rk816_ldo1: 2800 mV [ 0.796571] rk816_ldo2: 1800 mV [ 0.799771] rk816_ldo3: 1100 mV [ 0.802988] vcc_lan: 3300 mV [ 0.806209] rk816_ldo5: 3300 mV [ 0.809404] rk816_ldo6: 3300 mV [ 0.810392] rk816_i2c_probe success [ 0.810466] i2c-core: driver [rk816] using legacy suspend method [ 0.810488] i2c-core: driver [rk816] using legacy resume method [ 0.810569] i2c-core: driver [rk818] using legacy suspend method [ 0.810592] i2c-core: driver [rk818] using legacy resume method [ 0.811279] rk816_rtc_probe,line=463 [ 0.811323] rk8xx-rtc: probe of rk8xx-rtc failed with error -22 [ 0.812936] Switching to clocksource arch_sys_counter [ 0.849242] fb disp policy is box [ 0.849360] rk-fb rockchip-fb: rk fb ion client create success! [ 0.849387] rk-fb rockchip-fb: rockchip framebuffer driver probe [ 0.849802] rk-screen rk_screen.9: rockchip screen probe success [ 0.851193] pwr_ctr_name:lcd_en [ 0.851193] pwr_type:gpio [ 0.851193] gpio:66 [ 0.851193] atv_val:0 [ 0.851193] delay:100 [ 0.851193] [ 0.851784] graphics fb0: rockchip framebuffer registerd:fb0 [ 0.852557] graphics fb1: rockchip framebuffer registerd:fb1 [ 0.853024] graphics fb2: rockchip framebuffer registerd:fb2 [ 0.952075] rk312x-lcdc lcdc0: set lcdc0 dclk failed [ 0.952114] rk312x-lcdc lcdc0: lcdc0: dclk:59400000>>fps:70 [ 0.952141] rk312x-lcdc lcdc0: wakeup from standby! [ 0.966021] alloc_buffer:ion_phy_addr=0x10000000 [ 0.970767] fb0:phy:10000000>>vir:e0931000>>len:0x800000 [ 0.980919] rk312x-lcdc lcdc0: lcdc0 probe ok, iommu enabled [ 0.984188] NET: Registered protocol family 2 [ 0.985101] TCP established hash table entries: 4096 (order: 3, 32768 bytes) [ 0.985236] TCP bind hash table entries: 4096 (order: 3, 32768 bytes) [ 0.985348] TCP: Hash tables configured (established 4096 bind 4096) [ 0.985459] TCP: reno registered [ 0.985488] UDP hash table entries: 256 (order: 1, 8192 bytes) [ 0.985535] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [ 0.985921] NET: Registered protocol family 1 [ 0.986139] rk816_gpio_probe: compatible rk816 [ 0.986376] rk8xx-gpio rk8xx-gpio: driver success [ 0.986729] rk816-bat: support adc dc [ 1.002127] rk816-bat: save fcc: 4000 [ 1.003711] rk816-bat: first on: dsoc=100, rsoc=100 cap=4000, fcc=4000, ov=4248 [ 1.016783] rk816-bat: driver version 1.2 [ 1.017580] Unpacking initramfs... [ 1.264039] Freeing initrd memory: 2848K (c5bf0000 - c5eb8000) [ 1.265634] hw perfevents: enabled with ARMv7_Cortex_A7 PMU driver, 5 counters available [ 1.266359] vcodec_service: probe device vpu_combo.10 [ 1.266397] vcodec_service: No reset resource define [ 1.266416] vcodec_service: No reset resource define [ 1.266435] vcodec_service: No reset resource define [ 1.266556] vcodec vpu_combo.10: failed on clk_get clk_cabac [ 1.266663] vcodec_service: vpu_combo.10: power on [ 1.266815] vcodec_service: probe device 10106000.vpu_service [ 1.266874] vcodec_service: checking hw id 4831 [ 1.268207] vcodec_service: probe device 10104000.hevc_service [ 1.268273] vcodec_service: checking hw id 6867 [ 1.269223] vcodec_service: vpu_combo.10: power off... [ 1.269291] vcodec_service: done [ 1.269311] vcodec_service: init success [ 1.269473] rknandbase v1.0 2014-03-31 [ 1.269727] rknand_probe clk rate = 148500000 [ 1.269896] rknand_driver:ret = 0 [ 1.272060] audit: initializing netlink socket (disabled) [ 1.272135] type=2000 audit(0.730:1): initialized [ 1.273481] bounce pool size: 64 pages [ 1.283850] fuse init (API version 7.22) [ 1.284701] msgmni has been set to 973 [ 1.288431] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 1.288466] io scheduler noop registered [ 1.288487] io scheduler deadline registered [ 1.288692] io scheduler cfq registered (default) [ 1.294068] rga 1010c000.rga: rga ion client create success! [ 1.294409] rga: Driver loaded succesfully [ 1.294528] rga: Module initialized. [ 1.295866] IEP Power ON [ 1.295944] iep ion client create success! [ 1.296413] IEP Power OFF [ 1.296449] IEP Driver loaded succesfully [ 1.296596] Module initialized. [ 1.299711] dma-pl330 20078000.pdma: Loaded driver for PL330 DMAC-2364208 [ 1.299752] dma-pl330 20078000.pdma: DBUFF-64x8bytes Num_Chans-8 Num_Peri-16 Num_Events-16 [ 1.300607] rk_serial.c v1.8 2014-03-04 [ 1.300930] 20060000.serial: ttyS0 at MMIO 0x20060000 (irq = 52) is a rk29_serial.0 [ 1.301355] serial 20060000.serial: membase e3152000 [ 1.301565] 20064000.serial: ttyS1 at MMIO 0x20064000 (irq = 53) is a rk29_serial.1 [ 1.301969] serial 20064000.serial: membase e3154000 [ 1.308289] loop: module loaded [ 1.308422] i2c-core: driver [mpu6050B1] using legacy suspend method [ 1.308447] i2c-core: driver [mpu6050B1] using legacy resume method [ 1.308472] mpu_init: Probe name mpu6050B1 [ 1.308788] ak8963_mod_init: Probe name ak8963_mod [ 1.310062] SCSI Media Changer driver v0.25 [ 1.310779] tun: Universal TUN/TAP device driver, 1.6 [ 1.310805] tun: (C) 1999-2004 Max Krasnyansky <[email]maxk@qualcomm.com[/email]> [ 1.311088] vmac_init. [ 1.311489] PPP generic driver version 2.4.2 [ 1.311809] PPP BSD Compression module registered [ 1.311832] PPP Deflate Compression module registered [ 1.311868] PPP MPPE Compression module registered [ 1.311890] NET: Registered protocol family 24 [ 1.311944] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled). [ 1.311970] CSLIP: code copyright 1989 Regents of the University of California. [ 1.311992] Rockchip WiFi SYS interface (V1.00) ... [ 1.312066] esp_mem_init enter date Jan 11 2021 18:11:54 [ 1.312086] esp_mem_init VERSION [V2.5] [ 1.312162] esp_mem_init complete [ 1.312288] usbcore: registered new interface driver catc [ 1.312377] usbcore: registered new interface driver kaweth [ 1.312401] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver [ 1.312487] usbcore: registered new interface driver pegasus [ 1.312585] usbcore: registered new interface driver rtl8150 [ 1.312673] usbcore: registered new interface driver r8152 [ 1.312695] hso: drivers/net/usb/hso.c: Option Wireless [ 1.312848] usbcore: registered new interface driver hso [ 1.312954] usbcore: registered new interface driver asix [ 1.313044] usbcore: registered new interface driver ax88179_178a [ 1.313131] usbcore: registered new interface driver cdc_ether [ 1.313225] usbcore: registered new interface driver cdc_eem [ 1.313311] usbcore: registered new interface driver dm9601 [ 1.313397] usbcore: registered new interface driver dm9620 [ 1.313506] usbcore: registered new interface driver smsc75xx [ 1.313614] usbcore: registered new interface driver smsc95xx [ 1.313703] usbcore: registered new interface driver gl620a [ 1.313799] usbcore: registered new interface driver net1080 [ 1.313887] usbcore: registered new interface driver plusb [ 1.313976] usbcore: registered new interface driver rndis_host [ 1.314064] usbcore: registered new interface driver cdc_subset [ 1.314149] usbcore: registered new interface driver zaurus [ 1.314238] usbcore: registered new interface driver MOSCHIP usb-ethernet driver [ 1.314389] usbcore: registered new interface driver int51x1 [ 1.314474] usbcore: registered new interface driver kalmia [ 1.314564] usbcore: registered new interface driver ipheth [ 1.314650] usbcore: registered new interface driver sierra_net [ 1.314731] usbcore: registered new interface driver cx82310_eth [ 1.314828] usbcore: registered new interface driver cdc_ncm [ 1.314970] usbcore: registered new interface driver qmi_wwan [ 1.315056] usbcore: registered new interface driver cdc_mbim [ 1.315079] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.317027] EHCI: ehci_rk_probe e3180000 e3180010 [ 1.317063] rockchip_ehci_host 101c0000.usb: EHCI Host Controller [ 1.317116] rockchip_ehci_host 101c0000.usb: new USB bus registered, assigned bus number 1 [ 1.317761] rockchip_ehci_host 101c0000.usb: irq 43, io mem 0x101c0000 [ 1.334592] rockchip_ehci_host 101c0000.usb: USB 2.0 started, EHCI 1.00 [ 1.334741] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.334772] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.334798] usb usb1: Product: EHCI Host Controller [ 1.334822] usb usb1: Manufacturer: Linux 3.10.0+ ehci_hcd [ 1.334846] usb usb1: SerialNumber: 101c0000.usb [ 1.335724] hub 1-0:1.0: USB hub found [ 1.335772
uboot那边也要跟着修改嘛??
