在ubuntu18.04版本,3399pro,安装tensorflow总失败
cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C
creating None
creating None/tmp
creating None/tmp/tmpcxy6_mcv
aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/usr/include/python3.6m -c /tmp/tmpcxy6_mcv/a.c -o None/tmp/tmpcxy6_mcv/a.o
File “/usr/lib/python3.6/distutils/unixccompiler.py”, line 118, in _compile
extra_postargs)
File “/tmp/pip-build-u5si8erx/grpcio/src/python/grpcio/_spawn_patch.py”, line 54, in _commandfile_spawn
_classic_spawn(self, command)
File “/usr/lib/python3.6/distutils/ccompiler.py”, line 909, in spawn
spawn(cmd, dry_run=self.dry_run)
File “/usr/lib/python3.6/distutils/spawn.py”, line 36, in spawn
_spawn_posix(cmd, search_path, dry_run=dry_run)
File “/usr/lib/python3.6/distutils/spawn.py”, line 159, in _spawn_posix
% (cmd, exit_status))
distutils.errors.DistutilsExecError: command ‘aarch64-linux-gnu-gcc’ failed with exit status 4
During handling of the above exception, another exception occurred:
File “/tmp/pip-build-u5si8erx/grpcio/src/python/grpcio/commands.py”, line 267, in build_extensions
build_ext.build_ext.build_extensions(self)
File “/usr/lib/python3.6/distutils/command/build_ext.py”, line 448, in build_extensions
self._build_extensions_serial()
File “/usr/lib/python3.6/distutils/command/build_ext.py”, line 473, in _build_extensions_serial
self.build_extension(ext)
File “/usr/lib/python3/dist-packages/setuptools/command/build_ext.py”, line 199, in build_extension
_build_ext.build_extension(self, ext)
File “/usr/lib/python3.6/distutils/command/build_ext.py”, line 533, in build_extension
depends=ext.depends)
File “/tmp/pip-build-u5si8erx/grpcio/src/python/grpcio/_parallel_compile_patch.py”, line 59, in _parallel_compile
_compile_single_file, objects)
File “/usr/lib/python3.6/multiprocessing/pool.py”, line 266, in map
return self._map_async(func, iterable, mapstar, chunksize).get()
File “/usr/lib/python3.6/multiprocessing/pool.py”, line 644, in get
raise self._value
File “/usr/lib/python3.6/multiprocessing/pool.py”, line 119, in worker
result = (True, func(*args, **kwds))
File “/usr/lib/python3.6/multiprocessing/pool.py”, line 44, in mapstar
return list(map(*args))
File “/tmp/pip-build-u5si8erx/grpcio/src/python/grpcio/_parallel_compile_patch.py”, line 54, in _compile_single_file
self._compile(obj, src, ext, cc_args, extra_postargs, pp_opts)
File “/usr/lib/python3.6/distutils/unixccompiler.py”, line 120, in _compile
raise CompileError(msg)
distutils.errors.CompileError: command ‘aarch64-linux-gnu-gcc’ failed with exit status 4
File “”, line 1, in
File “/tmp/pip-build-u5si8erx/grpcio/setup.py”, line 488, in
cmdclass=COMMAND_CLASS,
File “/usr/lib/python3/dist-packages/setuptools/init.py”, line 129, in setup
return distutils.core.setup(**attrs)
File “/usr/lib/python3.6/distutils/core.py”, line 148, in setup
dist.run_commands()
File “/usr/lib/python3.6/distutils/dist.py”, line 955, in run_commands
self.run_command(cmd)
File “/usr/lib/python3.6/distutils/dist.py”, line 974, in run_command
cmd_obj.run()
File “/usr/lib/python3/dist-packages/wheel/bdist_wheel.py”, line 204, in run
self.run_command(‘build’)
File “/usr/lib/python3.6/distutils/cmd.py”, line 313, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File “/usr/lib/python3.6/distutils/command/build.py”, line 135, in run
self.run_command(cmd_name)
cmd_obj.run()
File “/usr/lib/python3/dist-packages/setuptools/command/build_ext.py”, line 78, in run
_build_ext.run(self)
File “/usr/lib/python3.6/distutils/command/build_ext.py”, line 339, in run
self.build_extensions()
File “/tmp/pip-build-u5si8erx/grpcio/src/python/grpcio/commands.py”, line 272, in build_extensions
“Failed build_ext step:\n{}”.format(formatted_exception))
commands.CommandError: Failed build_ext step:
extra_postargs)
raise self._value
Failed building wheel for grpcio
Running setup.py clean for grpcio
Failed to build grpcio
Installing collected packages: grpcio, tensorflow
按着安装文档来的,16G+3G ,
pip3 install
numpy==1.14.5
protobuf==3.11.2
onnx
scipy-1.2.0-cp36-cp36m-linux_aarch64.whl
tensorflow-1.10.1-cp36-cp36m-linux_aarch64.whl
前面几个部分都安装成功
