以下为启动信息
U-Boot 2017.09 (Jan 20 2021 - 14:56:47 +0800)
Model: Firefly ROC-RK3328-CC
PreSerial: 2
DRAM: 2 GiB
Sysmem: init
Relocation Offset is: 7dbf2000
rksdmmc@ff500000: 1, rksdmmc@ff520000: 0
Bootdev(atags): mmc 0
MMC0: High Speed, 52Mhz
PartType: EFI
boot mode: None
Load FDT from boot part
DTB: rk-kernel.dtb
start get public phy
use default hdmi phy table
inno hdmi phy init success, save it
Warn: can't find connect driver
In: serial
Out: serial
Err: serial
Model: Firefly rk3328-firefly-aiojd4
xfer: num: 2, addr: 0x50
Monitor has basic audio support
mode:1920x1080
CEA mode used vic=16
final pixclk = 148500000 tmdsclk = 148500000
start Inno HDMI PHY Power On
tmdsclock = 148500000; chipversion = 2
sink has audio support
hdmi_set_clk_regenerator: fs=48000Hz ftdms=148.500MHz N=6144 cts=148500
CLK: (sync kernel. arm: enter 600000 KHz, init 600000 KHz, kernel 0N/A)
apll 400000 KHz
dpll 664000 KHz
cpll 1200000 KHz
gpll 491009 KHz
npll 600000 KHz
armclk 600000 KHz
aclk_bus 150000 KHz
hclk_bus 75000 KHz
pclk_bus 75000 KHz
aclk_peri 150000 KHz
hclk_peri 75000 KHz
pclk_peri 75000 KHz
Net: No ethernet found.
Hit key to stop autoboot('CTRL+C'): 0
=> setenv ipaddr 192.168.10.110
=> print ipaddr
ipaddr=192.168.10.110
=> ping 192.168.10.126
No ethernet found.
ping failed; host 192.168.10.126 is not alive
如果不中断引导,进入系统后,网络使用正常。但在uboot里面无论如何都显示:No ethernet found.
