烧入镜像后,板子上电,当内核运行到 NET: Registered protocol family 16 时停止运行
DDR Version 1.22 20190506
channel 0
CS = 0
MR0=0x18
MR4=0x2
MR5=0x1
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x2
MR5=0x1
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 416MHz 0,1
Channel 0: LPDDR4,416MHz
Channel 1: LPDDR4,416MHz
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x2
MR5=0x1
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x2
MR5=0x1
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0, cs 0, advanced training done
channel 1, cs 0, advanced training done
change freq to 856MHz 1,0
pmugrf_os_reg[2] = 0x3281F281, stride = 0x9
CPUId = 0x0
ChipType = 0x10, 225
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=15028MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 67209
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
GPT part: 2, name: misc, start:0x8000, size:0x2000
GPT part: 3, name: boot, start:0xa000, size:0x10000
GPT part: 4, name: recovery, start:0x1a000, size:0x10000
GPT part: 5, name: backup, start:0x2a000, size:0x10000
GPT part: 6, name: rootfs, start:0x5a000, size:0x1cfffdf
find partition:uboot OK. first_lba:0x4000.
find partition:trust OK. first_lba:0x6000.
LoadTrust Addr:0x6000
No find bl30.bin
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0xd22c8
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):51f2096
NOTICE: BL31: Built : 16:24:31, May 6 2019
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1181): pd status 3e
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-221-gda2bcfdc #139 Mon Jun 17 03:14:33 UTC 2019 aarch64)
INFO: SPSR = 0x3c9
U-Boot 2017.09-02783-g14ce716885 (Mar 11 2020 - 10:48:20 +0800)
Model: Rockchip RK3399 Evaluation Board
PreSerial: 2
DRAM: 2 GiB
Sysmem: init
Relocation Offset is: 7dbf4000
mmc_init: -95, time 9
switch to partitions #0, OK
Bootdev: mmc 0
PartType: EFI
boot mode: None
Load FDT from boot part
DTB: rk-kernel.dtb
I2c speed: 400000Hz
PMIC: RK8090 (on=0x00, off=0x00)
vdd_center 900000 uV
vdd_cpu_l 900000 uV
Model: RK3399pro-firefly-aiojd4 board
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 24000 KHz, init 24000 KHz, kernel 0N/A)
aplll 816000 KHz
apllb 24000 KHz
dpll 856000 KHz
cpll 24000 KHz
gpll 800000 KHz
npll 600000 KHz
vpll 24000 KHz
aclk_perihp 133333 KHz
hclk_perihp 66666 KHz
pclk_perihp 33333 KHz
aclk_perilp0 266666 KHz
hclk_perilp0 88888 KHz
pclk_perilp0 44444 KHz
hclk_perilp1 100000 KHz
pclk_perilp1 50000 KHz
Net: eth0: ethernet@fe300000
Fdt Ramdisk skip relocation
FDT load addr 0x10f00000 size 354 KiB
Booting kernel at 0x00280000 with fdt at 0x8300000…
## Booting Android Image at 0x0027f800 …
Kernel load addr 0x00280000 size 22107 KiB
## Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
XIP Kernel Image … OK
‘reserved-memory’ region@110000: addr=110000 size=f0000
Using Device Tree in place at 0000000008300000, end 000000000831c5ae
Total: 650.657 ms
[ 0.000000] Linux version 4.4.194 (jincheng@jincheng-H310M-H-2-0) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #350 SMP Fri Mar 20 10:39:17 CST 2020
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07fee0000 s46312 r8192 d31512 u86016
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.mode=normal androidboot.slot_suffix= androidboot.serialno=3de224ae869a3b30 rw rootwait earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 con0
[ 0.000000] software IO TLB: mapped [mem 0x7fe98000-0x7fed8000] (0MB)
[ 0.000000] Memory: 2001576K/2064384K available (13758K kernel code, 1946K rwdata, 5140K rodata, 1216K init, 2013K bss, 62808K reserved, 0K cma-reserved)
[ 0.000000] .init : 0xffffff8009300000 - 0xffffff8009430000 ( 1216 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008df0000 ( 13760 KB)
[ 0.000000] .rodata : 0xffffff8008df0000 - 0xffffff8009300000 ( 5184 KB)
[ 0.000000] .data : 0xffffff8009430000 - 0xffffff8009616808 ( 1947 KB)
[ 0.000000] ITS: allocated 65536 Devices @a280000 (psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x000000000a210000
[ 0.000000] CPU0: using LPI pending table @0x000000000a220000
[ 0.002310] Console: colour dummy device 80x25
[ 0.002754] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.003746] pid_max: default: 32768 minimum: 301
[ 0.004275] Security Framework initialized
[ 0.004741] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.005383] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.006797] Initializing cgroup subsys io
[ 0.007207] Initializing cgroup subsys memory
[ 0.007651] Initializing cgroup subsys devices
[ 0.008083] Initializing cgroup subsys freezer
[ 0.008524] Initializing cgroup subsys perf_event
[ 0.008980] Initializing cgroup subsys net_prio
[ 0.009420] Initializing cgroup subsys pids
[ 0.009853] ftrace: allocating 49610 entries in 194 pages
[ 0.140995] sched-energy: Sched-energy-costs installed from DT
[ 0.141564] CPU0: update cpu_capacity 401
[ 0.142010] ASID allocator initialised with 32768 entries
[ 0.145897] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.147346] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.149694] Detected VIPT I-cache on CPU1
[ 0.149729] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.149760] CPU1: using LPI pending table @0x000000007ccc0000
[ 0.149804] CPU1: update cpu_capacity 401
[ 0.149808] CPU1: Booted secondary processor [410fd034]
[ 0.150403] Detected VIPT I-cache on CPU2
[ 0.150424] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.150451] CPU2: using LPI pending table @0x000000007cce0000
[ 0.150478] CPU2: update cpu_capacity 401
[ 0.150482] CPU2: Booted secondary processor [410fd034]
[ 0.151028] Detected VIPT I-cache on CPU3
[ 0.151049] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.151076] CPU3: using LPI pending table @0x000000007cd40000
[ 0.151103] CPU3: update cpu_capacity 401
[ 0.151106] CPU3: Booted secondary processor [410fd034]
[ 0.151674] Detected PIPT I-cache on CPU4
[ 0.151700] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.151739] CPU4: using LPI pending table @0x000000007cd70000
[ 0.151778] CPU4: update cpu_capacity 1024
[ 0.151781] CPU4: Booted secondary processor [410fd082]
[ 0.152353] Detected PIPT I-cache on CPU5
[ 0.152371] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.152407] CPU5: using LPI pending table @0x000000007cda0000
[ 0.152434] CPU5: update cpu_capacity 1024
[ 0.152437] CPU5: Booted secondary processor [410fd082]
[ 0.152526] Brought up 6 CPUs
[ 0.164896] SMP: Total of 6 processors activated.
[ 0.165349] CPU features: detected feature: GIC system register CPU interface
[ 0.166038] CPU features: detected feature: 32-bit EL0 Support
[ 0.166598] CPU: All CPU(s) started at EL2
[ 0.167031] alternatives: patching kernel code
[ 0.168885] devtmpfs: initialized
[ 0.187583] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.188516] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.189596] xor: measuring software checksum speed
[ 0.199777] 8regs : 2860.000 MB/sec
[ 0.209834] 8regs_prefetch: 2564.000 MB/sec
[ 0.219888] 32regs : 3208.000 MB/sec
[ 0.229945] 32regs_prefetch: 2844.000 MB/sec
[ 0.230380] xor: using function: 32regs (3208.000 MB/sec)
[ 0.230904] pinctrl core: initialized pinctrl subsystem
[ 0.232182] NET: Registered protocol family 16
请问有没有大佬知道怎么才能正常运行?
