按照wiki教程编译buildroot固件
http://wiki.t-firefly.com/zh_CN/Firefly-RK3288/buildroot_compile.html
前6个分区不能挂载
DDR Version 1.08 20190523
Channel a: DDR3 400MHz
Channel b: DDR3 400MHz
Memory OK
Memory OK
Boot1 Release Time: Nov 27 2019 15:30:08, version: 2.58
ChipType = 0x8, 249
mmc2:cmd19,100
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=14910MB
FwPartOffset=2000 , 2000
mmc0:cmd8,400
mmc0:cmd8,400
mmc0:cmd8,400
SdmmcInit=0 1
StorageInit ok = 30473
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
atags_set_bootdev: ret:(0)
GPT part: 2, name: misc, start:0x8000, size:0x2000
GPT part: 3, name: boot, start:0xa000, size:0x10000
GPT part: 4, name: recovery, start:0x1a000, size:0x10000
GPT part: 5, name: backup, start:0x2a000, size:0x10000
GPT part: 6, name: oem, start:0x3a000, size:0x20000
GPT part: 7, name: rootfs, start:0x5a000, size:0x100000
GPT part: 8, name: userdata, start:0x15a000, size:0x1bc4fdf
find part:uboot OK. first_lba:0x4000.
find part:trust OK. first_lba:0x6000.
LOADER Check OK! 0x4000, 147476
TOS Check OK! 0x6000, 184183
Enter Trust OS
INF [0x0] TEE-CORE:init_primary_helper:385: Core0 Initializing (1.1.0-421-gd098c6d2 #4 Thu Feb 20 01:29:17 UTC 2020 arm)
INF [0x0] TEE-CORE:init_primary_helper:386: Release version: 1.3
INF [0x0] TEE-CORE:init_primary_helper:387: Next entry point address: 0x200000
U-Boot 2017.09 (Feb 10 2021 - 16:45:11 +0800)
Model: Firefly-RK3288
PreSerial: 2
DRAM: 2 GiB
Sysmem: init
Relocation Offset is: 00000000
dwmmc@ff0c0000: 1, dwmmc@ff0f0000: 0
Bootdev(atags): mmc 0
MMC0: High Speed, 52Mhz
PartType: EFI
boot mode: None
Load FDT from boot part
DTB: rk-kernel.dtb
I2c0 speed: 400000Hz
vdd_log 1100000 uV
*** Warning - bad CRC, using default environment
In: serial@ff690000
Out: serial@ff690000
Err: serial@ff690000
Model: Firefly-RK3288 Board (Linux Opensource)
xfer: num: 2, addr: 0x50
Monitor has basic audio support
mode:1280x720
CEA mode used vic=4
final pixclk = 74250000 tmdsclk = 74250000
PHY powered down in 0 iterations
PHY PLL locked 1 iterations
PHY powered down in 1 iterations
sink has audio support
hdmi_set_clk_regenerator: fs=48000Hz ftdms=74.250MHz N=6144 cts=74250
CLK: (uboot. arm: enter 1000000 KHz, init 1000000 KHz, kernel 0N/A)
apll 1000000 KHz
dpll 396000 KHz
cpll 668000 KHz
gpll 594000 KHz
npll 24000 KHz
aclk_bus 297000 KHz
Net: eth0: ethernet@ff290000
Booting ZIMAGE kernel at 0x02008000(Uncompress to 0) with fdt at 0x8300000…
## Booting Android Image at 0x02007800 …
Kernel load addr 0x02008000 size 8017 KiB
RAM disk load addr 0x0a200000 size 8946 KiB
## Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
XIP Kernel Image … OK
‘reserved-memory’ dma-unusable@fe000000: addr=fe000000 size=1000000
‘reserved-memory’ ramoops@00000000: addr=8000000 size=f0000
Loading Ramdisk to 0f743000, end 0ffff739 … OK
Loading Device Tree to 0f72c000, end 0f742e38 … OK
Can’t find file:logo_kernel.bmp
Adding bank: 0x00000000 - 0x08400000 (size: 0x08400000)
Adding bank: 0x09300000 - 0x80000000 (size: 0x76d00000)
Total: 5091.932 ms
[ 0.000000] Linux version 4.4.194 (xxx@xxx-virtual-machine) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #4 SMP Wed Feb 10 16:46:10 CST 2021
[ 0.000000] Machine model: Firefly-RK3288 Board (Linux Opensource)
[ 0.000000] cma: Reserved 16 MiB at 0x7f000000
[ 0.000000] psci: PSCIv65535.65535 detected in firmware.
[ 0.000000] PERCPU: Embedded 14 pages/cpu @eef77000 s24728 r8192 d24424 u57344
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 518912
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.slot_suffix= androidboot.serialno=c82e38b126432a22 earlyprintk ro rootwait console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 swiotlb=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1
[ 0.000000] Memory: 2016456K/2081792K available (12288K kernel code, 1005K rwdata, 3476K rodata, 1024K init, 1258K bss, 48952K reserved, 16384K cma-reserved, 1293716K highmem)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0d00000 (13280 kB)
[ 0.000000] .init : 0xc1200000 - 0xc1300000 (1024 kB)
[ 0.000000] .data : 0xc1300000 - 0xc13fb46c (1006 kB)
[ 0.000000] .bss : 0xc13fd000 - 0xc1537b90 (1259 kB)
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000030] Switching to timer-based delay loop, resolution 41ns
[ 0.003948] Console: colour dummy device 80x30
[ 0.003992] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.004017] pid_max: default: 32768 minimum: 301
[ 0.004146] Security Framework initialized
[ 0.004164] Yama: becoming mindful.
[ 0.004255] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.004279] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.005442] Initializing cgroup subsys devices
[ 0.005474] Initializing cgroup subsys freezer
[ 0.005522] CPU: Testing write buffer coherency: ok
[ 0.005578] ftrace: allocating 44444 entries in 131 pages
[ 0.138172] CPU0: update cpu_capacity 430
[ 0.138192] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.138289] Setting up static identity map for 0x100000 - 0x100058
[ 0.141596] CPU1: update cpu_capacity 430
[ 0.141606] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.142822] CPU2: update cpu_capacity 430
[ 0.142832] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.144036] CPU3: update cpu_capacity 430
[ 0.144046] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.144208] Brought up 4 CPUs
[ 0.144251] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.144261] CPU: All CPU(s) started in SVC mode.
[ 0.146353] devtmpfs: initialized
[ 0.179124] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.179706] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.179747] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.181292] pinctrl core: initialized pinctrl subsystem
[ 0.182915] NET: Registered protocol family 16
[ 0.187130] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.218520] cpuidle: using governor ladder
[ 0.248569] cpuidle: using governor menu
[ 0.248626] Registered FIQ tty driver
[ 0.303401] console [pstore-1] enabled
[ 0.303415] pstore: Registered ramoops as persistent store backend
[ 0.303430] ramoops: attached 0xf0000@0x8000000, ecc: 0/0
[ 0.304801] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.304821] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.305991] fiq debugger fiq mode enabled
[ 0.791751] console [ttyFIQ0] enabled
[ 0.795803] Registered fiq debugger ttyFIQ0
[ 0.886542] vcc_flash: regulator get failed, ret=-517
[ 0.892366] vcc_sd: regulator get failed, ret=-517
[ 0.897891] vcc28_dvp: regulator get failed, ret=-517
[ 0.903702] dovdd_1v8: regulator get failed, ret=-517
[ 0.909046] rockchip-pinctrl pinctrl: pin gpio0-11 already requested by vcc28-dvp-regulator; cannot claim for vcc-mipi
[ 0.919791] rockchip-pinctrl pinctrl: pin-11 (vcc-mipi) status -22
[ 0.925982] rockchip-pinctrl pinctrl: could not request pin 11 (gpio0-11) from group mipi-pwr on device rockchip-pinctrl
[ 0.936958] reg-fixed-voltage vcc-mipi: Error applying setting, reverse things back
[ 0.947147] iommu: Adding device ff910000.rkisp1 to group 0
[ 0.952881] iommu: Adding device ff930000.vop to group 1
[ 0.958383] iommu: Adding device ff940000.vop to group 2
[ 0.963858] iommu: Adding device ff9a0000.vpu-service to group 3
[ 0.970083] iommu: Adding device ff9c0000.hevc-service to group 4
[ 0.977052] rk_iommu ff914000.iommu: can’t get sclk
[ 0.982618] rk_iommu ff930300.iommu: can’t get sclk
[ 0.987951] rk_iommu ff940300.iommu: can’t get sclk
[ 0.993309] rk_iommu ff9a0800.iommu: can’t get sclk
[ 0.998701] rk_iommu ff9c0440.iommu: can’t get sclk
[ 1.004557] SCSI subsystem initialized
[ 1.008723] usbcore: registered new interface driver usbfs
[ 1.014371] usbcore: registered new interface driver hub
[ 1.019853] usbcore: registered new device driver usb
[ 1.025165] media: Linux media interface: v0.10
[ 1.029770] Linux video capture interface: v2.00
[ 1.034543] pps_core: LinuxPPS API ver. 1 registered
[ 1.039544] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.048718] PTP clock support registered
[ 1.055207] Advanced Linux Sound Architecture Driver Initialized.
[ 1.062362] Bluetooth: Core ver 2.21
[ 1.066049] NET: Registered protocol family 31
[ 1.070501] Bluetooth: HCI device and connection manager initialized
[ 1.076903] Bluetooth: HCI socket layer initialized
[ 1.081794] Bluetooth: L2CAP socket layer initialized
[ 1.086932] Bluetooth: SCO socket layer initialized
[ 1.093493] rockchip-cpuinfo cpuinfo: Serial : c82e38b126432a22
[ 1.101512] clocksource: Switched to clocksource arch_sys_counter
[ 1.194413] NET: Registered protocol family 2
[ 1.199686] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 1.206908] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
[ 1.213725] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.220173] UDP hash table entries: 512 (order: 2, 24576 bytes)
[ 1.226200] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes)
[ 1.232950] NET: Registered protocol family 1
[ 1.237898] RPC: Registered named UNIX socket transport module.
[ 1.243884] RPC: Registered udp transport module.
[ 1.248598] RPC: Registered tcp transport module.
[ 1.253338] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.260138] Trying to unpack rootfs image as initramfs…
[ 2.015000] Freeing initrd memory: 8948K
[ 2.020948] hw perfevents: enabled with armv7_cortex_a12 PMU driver, 7 counters available
[ 2.032803] Initialise system trusted keyring
[ 2.053095] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.062279] NFS: Registering the id_resolver key type
[ 2.067400] Key type id_resolver registered
[ 2.071640] Key type id_legacy registered
[ 2.075691] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 2.083462] fuse init (API version 7.23)
[ 2.096240] NET: Registered protocol family 38
[ 2.100732] Key type asymmetric registered
[ 2.104920] Asymmetric key parser ‘x509’ registered
[ 2.109930] bounce: pool size: 64 pages
[ 2.114135] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 2.121598] io scheduler noop registered
[ 2.125545] io scheduler deadline registered
[ 2.129880] io scheduler cfq registered (default)
[ 2.143887] rk-vcodec ff9a0000.vpu-service: no regulator for vcodec
[ 2.150600] rk-vcodec ff9a0000.vpu-service: probe device
[ 2.156416] rk-vcodec ff9a0000.vpu-service: drm allocator with mmu enabled
[ 2.164496] rk-vcodec ff9a0000.vpu-service: could not find power_model node
[ 2.171472] rk-vcodec ff9a0000.vpu-service: init success
[ 2.177361] rk-vcodec ff9c0000.hevc-service: no regulator for vcodec
[ 2.184232] rk-vcodec ff9c0000.hevc-service: probe device
[ 2.190081] rk-vcodec ff9c0000.hevc-service: drm allocator with mmu enabled
[ 2.197954] rk-vcodec ff9c0000.hevc-service: could not find power_model node
[ 2.205071] rk-vcodec ff9c0000.hevc-service: init success
[ 2.214577] dma-pl330 ff250000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 2.222196] dma-pl330 ff250000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 2.232882] dma-pl330 ff600000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 2.240463] dma-pl330 ff600000.dma-controller: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 2.251721] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 2.260441] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 2.267952] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 37, base_baud = 1500000) is a 16550A
[ 2.277907] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 38, base_baud = 1500000) is a 16550A
[ 2.289314] [drm] Initialized drm 1.1.0 20060810
[ 2.301410] [drm] Rockchip DRM driver version: v1.0.1
[ 2.307035] rockchip-drm display-subsystem: devfreq is not set
[ 2.314632] rockchip-drm display-subsystem: bound ff930000.vop (ops 0xc0d66d78)
[ 2.323241] rockchip-drm display-subsystem: bound ff940000.vop (ops 0xc0d66d78)
[ 2.330962] i2c i2c-6: of_i2c: modalias failure on /hdmi@ff980000/ports
[ 2.337644] dwhdmi-rockchip ff980000.hdmi: registered DesignWare HDMI I2C bus driver
[ 2.345576] dwhdmi-rockchip ff980000.hdmi: Detected HDMI TX controller v2.00a with HDCP (DWC MHL PHY)
[ 2.356415] rockchip-drm display-subsystem: bound ff980000.hdmi (ops 0xc0d5dca0)
[ 2.363887] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.370503] [drm] No driver support for vblank timestamp query.
[ 2.651301] rockchip-drm display-subsystem: fb0: frame buffer device
[ 2.684388] usbcore: registered new interface driver udl
[ 2.695676] mali ffa30000.gpu: Failed to get regulator
[ 2.700862] mali ffa30000.gpu: Power control initialization failed
[ 2.709103] brd: module loaded
[ 2.723319] loop: module loaded
[ 2.727724] zram: Added device: zram0
[ 2.731446] lkdtm: No crash points registered, enable through debugfs
[ 2.739327] rockchip-spi ff110000.spi: no high_speed pinctrl state
[ 2.747205] register spi return v = :0
[ 2.751095] tun: Universal TUN/TAP device driver, 1.6
[ 2.756205] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.765038] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 2.771747] rk_gmac-dwmac ff290000.ethernet: phy regulator is not available yet, deferred probing
[ 2.782545] PPP generic driver version 2.4.2
[ 2.787305] usbcore: registered new interface driver rndis_wlan
[ 2.793693] usbcore: registered new interface driver rt2800usb
[ 2.799691] Rockchip WiFi SYS interface (V1.00) …
[ 2.804790] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 2.812325] usbcore: registered new interface driver pegasus
[ 2.818111] usbcore: registered new interface driver rtl8150
[ 2.823914] usbcore: registered new interface driver r8152
[ 2.829513] usbcore: registered new interface driver asix
[ 2.835085] usbcore: registered new interface driver ax88179_178a
[ 2.841289] usbcore: registered new interface driver cdc_ether
[ 2.847273] usbcore: registered new interface driver dm9601
[ 2.853030] usbcore: registered new interface driver smsc75xx
[ 2.858888] usbcore: registered new interface driver smsc95xx
[ 2.864775] usbcore: registered new interface driver net1080
[ 2.870558] usbcore: registered new interface driver rndis_host
[ 2.876628] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 2.884269] usbcore: registered new interface driver cdc_ncm
[ 2.890030] usbcore: registered new interface driver qmi_wwan
[ 2.895921] usbcore: registered new interface driver cdc_mbim
[ 2.902351] ff540000.usb supply vusb_d not found, using dummy regulator
[ 2.909096] ff540000.usb supply vusb_a not found, using dummy regulator
[ 3.032226] dwc2 ff540000.usb: DWC OTG Controller
[ 3.036998] dwc2 ff540000.usb: new USB bus registered, assigned bus number 1
[ 3.044147] dwc2 ff540000.usb: irq 44, io mem 0xff540000
[ 3.049894] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.056741] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.064003] usb usb1: Product: DWC OTG Controller
[ 3.068741] usb usb1: Manufacturer: Linux 4.4.194 dwc2_hsotg
[ 3.074437] usb usb1: SerialNumber: ff540000.usb
[ 3.080104] hub 1-0:1.0: USB hub found
[ 3.083998] hub 1-0:1.0: 1 port detected
[ 3.088938] ff580000.usb supply vusb_d not found, using dummy regulator
[ 3.095709] ff580000.usb supply vusb_a not found, using dummy regulator
[ 3.221608] dwc2 ff580000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[ 3.229564] dwc2 ff580000.usb: DWC OTG Controller
[ 3.234398] dwc2 ff580000.usb: new USB bus registered, assigned bus number 2
[ 3.241550] dwc2 ff580000.usb: irq 45, io mem 0xff580000
[ 3.247175] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.254043] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.261276] usb usb2: Product: DWC OTG Controller
[ 3.266037] usb usb2: Manufacturer: Linux 4.4.194 dwc2_hsotg
[ 3.271733] usb usb2: SerialNumber: ff580000.usb
[ 3.277401] hub 2-0:1.0: USB hub found
[ 3.281229] hub 2-0:1.0: 1 port detected
[ 3.288039] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 3.294647] ehci-platform: EHCI generic platform driver
[ 3.300351] ehci-platform ff500000.usb: EHCI Host Controller
[ 3.306458] ehci-platform ff500000.usb: new USB bus registered, assigned bus number 3
[ 3.314625] ehci-platform ff500000.usb: irq 42, io mem 0xff500000
[ 3.461581] usb 1-1: new high-speed USB device number 2 using dwc2
[ 3.481606] ehci-platform ff500000.usb: USB 2.0 started, EHCI 1.00
[ 3.488156] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.495012] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.502298] usb usb3: Product: EHCI Host Controller
[ 3.507184] usb usb3: Manufacturer: Linux 4.4.194 ehci_hcd
[ 3.512709] usb usb3: SerialNumber: ff500000.usb
[ 3.518431] hub 3-0:1.0: USB hub found
[ 3.522305] hub 3-0:1.0: 1 port detected
[ 3.527410] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 3.533712] ohci-platform: OHCI generic platform driver
[ 3.539572] usbcore: registered new interface driver cdc_acm
[ 3.545296] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 3.553595] usbcore: registered new interface driver cdc_wdm
[ 3.559477] usbcore: registered new interface driver usb-storage
[ 3.565757] usbcore: registered new interface driver usbserial
[ 3.571795] usbcore: registered new interface driver usbserial_generic
[ 3.578383] usbserial: USB Serial support registered for generic
[ 3.584570] usbcore: registered new interface driver ch341
[ 3.590120] usbserial: USB Serial support registered for ch341-uart
[ 3.596547] usbcore: registered new interface driver cp210x
[ 3.602243] usbserial: USB Serial support registered for cp210x
[ 3.608304] usbcore: registered new interface driver ftdi_sio
[ 3.614327] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 3.622891] usbcore: registered new interface driver keyspan
[ 3.628613] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 3.636564] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 3.643970] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 3.651367] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 3.658837] usbcore: registered new interface driver option
[ 3.664513] usbserial: USB Serial support registered for GSM modem (1-port)
[ 3.671996] usbcore: registered new interface driver oti6858
[ 3.677718] usbserial: USB Serial support registered for oti6858
[ 3.683911] usbcore: registered new interface driver pl2303
[ 3.689557] usbserial: USB Serial support registered for pl2303
[ 3.696070] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101
[ 3.702860] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.703028] usbcore: registered new interface driver qcserial
[ 3.703093] usbserial: USB Serial support registered for Qualcomm USB modem
[ 3.703217] usbcore: registered new interface driver sierra
[ 3.703272] usbserial: USB Serial support registered for Sierra USB modem
[ 3.705280] usbcore: registered new interface driver iforce
[ 3.705411] usbcore: registered new interface driver xpad
[ 3.705538] ==gsl_ts_init==
[ 3.705586] ret=0
[ 3.706049] usbcore: registered new interface driver usbtouchscreen
[ 3.706393] .. rk pwm remotectl v1.1 init
[ 3.706876] input: ff680000.pwm as /devices/platform/ff680000.pwm/input/input0
[ 3.707699] sensor_register_slave:mma8452,id=17
[ 3.707713] sensor_register_slave:lis3dh,id=7
[ 3.707727] sensor_register_slave:mma7660,id=18
[ 3.707739] sensor_register_slave:lsm303d,id=22
[ 3.707751] sensor_register_slave:gs_mc3230,id=23
[ 3.707754] [Gsensor] gsensor_init
[ 3.707767] sensor_register_slave:mpu6880_acc,id=24
[ 3.707779] sensor_register_slave:mpu6500_acc,id=25
[ 3.707791] sensor_register_slave:lsm330_acc,id=26
[ 3.707803] sensor_register_slave:akm8975,id=30
[ 3.707815] sensor_register_slave:akm8963,id=31
[ 3.707827] sensor_register_slave:l3g4200d,id=45
[ 3.707838] sensor_register_slave:l3g20d,id=46
[ 3.707849] sensor_register_slave:ewtsa,id=47
[ 3.707861] sensor_register_slave:lsm330_gyro,id=51
[ 3.707873] sensor_register_slave:cm3217,id=53
[ 3.707885] sensor_register_slave:cm3218,id=54
[ 3.709114] i2c /dev entries driver
[ 3.735265] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 3.735376] fan53555-reg: supplied by vcc_sys
[ 3.860902] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 3.860919] usb 1-1: Product: USB 2.0 Hub [MTT]
[ 3.861995] hub 1-1:1.0: USB hub found
[ 3.862108] hub 1-1:1.0: 4 ports detected
[ 3.880272] fan53555-reg: supplied by vcc_sys
[ 3.891161] rtc-hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 3.899118] REG1: supplied by vcc_sys
[ 3.904459] REG2: supplied by vcc_sys
[ 3.909512] vcc_flash: supplied by vcc_io
[ 3.913887] vcc_sd: supplied by vcc_io
[ 3.917916] vcc28_dvp: supplied by vcc_io
[ 3.922333] dovdd_1v8: supplied by vcc28_dvp
[ 3.926784] REG3: supplied by vcc_sys
[ 3.932137] REG4: supplied by vcc_sys
[ 3.937246] REG5: supplied by vcc_sys
[ 3.942563] REG6: supplied by vcc_sys
[ 3.947692] REG7: supplied by vcc_sys
[ 3.952827] REG8: supplied by vcc_sys
[ 3.957953] REG9: supplied by vcc_sys
[ 3.963196] REG10: supplied by vcc_20
[ 3.968442] REG11: supplied by vcc_20
[ 3.973755] REG12: supplied by vcc_20
[ 3.978993] rk3x-i2c ff650000.i2c: Initialized RK3xxx I2C bus at f12cc000
[ 3.987048] rk3x-i2c ff150000.i2c: Initialized RK3xxx I2C bus at f12ce000
[ 3.994966] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at f12d0000
[ 4.003157] rk3x-i2c ff660000.i2c: Initialized RK3xxx I2C bus at f12d2000
[ 4.012707] rkisp1 ff910000.rkisp1: rkisp1 driver version: v00.01.05
[ 4.019111] rkisp1 ff910000.rkisp1: Missing rockchip,grf property
[ 4.028979] usbcore: registered new interface driver uvcvideo
[ 4.034777] USB Video Class driver (1.1.1)
[ 4.043942] Boot mode: coldboot
[ 4.048429] rockchip-thermal ff280000.tsadc: Missing rockchip,grf property
[ 4.055473] rk_tsadcv2_temp_to_code: Invalid conversion table: code=4095, temperature=2147483647
[ 4.064584] rockchip-thermal ff280000.tsadc: tsadc is probed successfully!
[ 4.073409] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 4.082297] Bluetooth: Virtual HCI driver ver 1.5
[ 4.087299] Bluetooth: HCI UART driver ver 2.3
[ 4.091813] Bluetooth: HCI UART protocol H4 registered
[ 4.096960] Bluetooth: HCI UART protocol LL registered
[ 4.102134] Bluetooth: HCI UART protocol ATH3K registered
[ 4.107691] usbcore: registered new interface driver bfusb
[ 4.113368] usbcore: registered new interface driver btusb
[ 4.119444] cpu cpu0: bin=1
[ 4.122502] cpu cpu0: leakage=38
[ 4.138607] cpu cpu0: temp=44545, pvtm=17146 (17308 + -162)
[ 4.141569] usb 1-1.1: new full-speed USB device number 3 using dwc2
[ 4.150644] rockchip_cpuclk_pre_rate_change: Invalid rate : 500000000 for cpuclk
[ 4.158115] cpu cpu0: pvtm-volt-sel=3
[ 4.161933] cpu cpu0: bin-scale=25
[ 4.168179] cpu cpu0: avs=0
[ 4.171116] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[ 4.178171] cpu cpu0: failed to read out thermal zone (-22)
[ 4.185670] cpu cpu0: failed to find power_model node
[ 4.191214] sdhci: Secure Digital Host Controller Interface driver
[ 4.197459] sdhci: Copyright(c) Pierre Ossman
[ 4.201910] Synopsys Designware Multimedia Card Interface Driver
[ 4.208697] dwmmc_rockchip ff0c0000.dwmmc: IDMAC supports 32-bit address mode.
[ 4.215979] dwmmc_rockchip ff0c0000.dwmmc: Using internal DMA controller.
[ 4.222796] dwmmc_rockchip ff0c0000.dwmmc: Version ID is 270a
[ 4.228574] dwmmc_rockchip ff0c0000.dwmmc: DW MMC controller at irq 29,32 bit host data width,256 deep fifo
[ 4.238336] dwmmc_rockchip ff0c0000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 4.242958] usb 1-1.1: New USB device found, idVendor=222a, idProduct=0001
[ 4.242963] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.242967] usb 1-1.1: Product: ILITEK-TP
[ 4.242976] usb 1-1.1: Manufacturer: ILITEK
[ 4.242979] usb 1-1.1: SerialNumber: V06.00.00.00
[ 4.382888] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 4.390776] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 4.411176] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 4.433721] dwmmc_rockchip ff0c0000.dwmmc: 1 slots initialized
[ 4.443133] dwmmc_rockchip ff0d0000.dwmmc: IDMAC supports 32-bit address mode.
[ 4.450723] dwmmc_rockchip ff0d0000.dwmmc: Using internal DMA controller.
[ 4.457795] dwmmc_rockchip ff0d0000.dwmmc: Version ID is 270a
[ 4.463607] dwmmc_rockchip ff0d0000.dwmmc: DW MMC controller at irq 30,32 bit host data width,256 deep fifo
[ 4.473370] dwmmc_rockchip ff0d0000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 4.481507] dwmmc_rockchip ff0d0000.dwmmc: No vmmc regulator found
[ 4.487683] dwmmc_rockchip ff0d0000.dwmmc: No vqmmc regulator found
[ 4.494215] dwmmc_rockchip ff0d0000.dwmmc: allocated mmc-pwrseq
[ 4.512787] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 4.534649] dwmmc_rockchip ff0d0000.dwmmc: 1 slots initialized
[ 4.541233] dwmmc_rockchip ff0f0000.dwmmc: IDMAC supports 32-bit address mode.
[ 4.548581] dwmmc_rockchip ff0f0000.dwmmc: Using internal DMA controller.
[ 4.555425] dwmmc_rockchip ff0f0000.dwmmc: Version ID is 270a
[ 4.561215] dwmmc_rockchip ff0f0000.dwmmc: DW MMC controller at irq 31,32 bit host data width,256 deep fifo
[ 4.570986] dwmmc_rockchip ff0f0000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 4.579144] dwmmc_rockchip ff0f0000.dwmmc: No vmmc regulator found
[ 4.585334] dwmmc_rockchip ff0f0000.dwmmc: No vqmmc regulator found
[ 4.604321] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 4.624304] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 4.629850] dwmmc_rockchip ff0f0000.dwmmc: 1 slots initialized
[ 4.636157] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.642498] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 4.648388] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.654811] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 4.662052] input: ILITEK ILITEK-TP as /devices/platform/ff540000.usb/usb1/1-1/1-1.1/1-1.1:1.0/0003:222A:0001.0001/input/input1
[ 4.674522] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 4.706624] mmc_host mmc2: Bus speed (slot 0) = 99000000Hz (slot req 100000000Hz, actual 99000000HZ div = 0)
[ 4.732070] hid-multitouch 0003:222A:0001.0001: input,hidraw0: USB HID v1.10 Device [ILITEK ILITEK-TP] on usb-ff540000.usb-1.1/input0
[ 4.746772] dwmmc_rockchip ff0f0000.dwmmc: Successfully tuned phase to 73
[ 4.748230] input: ILITEK ILITEK-TP as /devices/platform/ff540000.usb/usb1/1-1/1-1.1/1-1.1:1.1/0003:222A:0001.0002/input/input2
[ 4.765244] mmc2: new HS200 MMC card at address 0001
[ 4.770980] mmcblk2: mmc2:0001 AWMB3R 14.6 GiB
[ 4.775944] mmcblk2boot0: mmc2:0001 AWMB3R partition 1 4.00 MiB
[ 4.782111] mmcblk2boot1: mmc2:0001 AWMB3R partition 2 4.00 MiB
[ 4.788237] mmcblk2rpmb: mmc2:0001 AWMB3R partition 3 4.00 MiB
[ 4.795397] random: nonblocking pool is initialized
[ 4.801957] hid-generic 0003:222A:0001.0002: input,hiddev0,hidraw1: USB HID v1.10 Mouse [ILITEK ILITEK-TP] on usb-ff540000.usb-1.1/input1
[ 4.814445] usbcore: registered new interface driver usbhid
[ 4.820073] usbhid: USB HID core driver
[ 4.824503] ashmem: initialized
[ 4.828356] mmcblk2: p1 p2 p3 p4 p5 p6 p7 p8 p9
[ 4.828695] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[ 4.830077] rknandbase v1.2 2018-05-08
[ 4.830691] usbcore: registered new interface driver snd-usb-audio
[ 4.831506] ES8323 2-0010: Can not read property spk_ctl_gpio
[ 4.831754] ES8323 2-0010: Can not read property aux_det_gpio
[ 4.835019] u32 classifier
[ 4.835027] Netfilter messages via NETLINK v0.30.
[ 4.835079] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 4.835330] ctnetlink v0.93: registering with nfnetlink.
[ 4.835445] ip_set: protocol 6
[ 4.835456] IPVS: Registered protocols ()
[ 4.835501] IPVS: Connection hash table configured (size=4096, memory=32Kbytes)
[ 4.835582] IPVS: Creating netns size=1104 id=0
[ 4.835622] IPVS: ipvs loaded.
[ 4.835924] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 4.836077] Initializing XFRM netlink socket
[ 4.836710] NET: Registered protocol family 10
[ 4.837313] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 4.837446] sit: IPv6 over IPv4 tunneling driver
[ 4.837942] NET: Registered protocol family 17
[ 4.837959] NET: Registered protocol family 15
[ 4.837992] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 4.838012] Bridge firewalling registered
[ 4.838090] Bluetooth: RFCOMM socket layer initialized
[ 4.838111] Bluetooth: RFCOMM ver 1.11
[ 4.838125] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.838132] Bluetooth: HIDP socket layer initialized
[ 4.838177] 8021q: 802.1Q VLAN Support v1.8
[ 4.838197] lib80211: common routines for IEEE802.11 drivers
[ 4.838233] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 4.838437] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 4.838458] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6212
[ 4.838461] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 4.838463] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 4.838518] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 150, flags = 0.
[ 4.838524] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 4.838526] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 4.838530] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 4.838582] [BT_RFKILL]: Enter rfkill_rk_init
[ 4.838907] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 139.
[ 4.838930] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 149.
[ 4.838946] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 146.
[ 4.838961] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 151.
[ 4.838965] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[ 4.839017] [BT_RFKILL]: Request irq for bt wakeup host
[ 4.839053] [BT_RFKILL]: ** disable irq
[ 4.839177] [BT_RFKILL]: bt_default device registered.
[ 4.839245] Key type dns_resolver registered
[ 4.839328] sensor_register_slave:mpu6880_gyro,id=50
[ 4.839411] ov13850 3-0010: driver version: 00.01.03
[ 4.839768] ov13850 3-0010: could not get default pinstate
[ 4.839772] ov13850 3-0010: could not get sleep pinstate
[ 4.840421] vendor storage:20190527 ret = 0
[ 4.841814] ov13850 3-0010: Unexpected sensor id(000000), ret(-5)
[ 4.842768] ThumbEE CPU extension supported.
[ 4.842780] Registering SWP/SWPB emulation handler
[ 4.843321] Loading compiled-in X.509 certificates
[ 4.844007] rga2: Driver loaded successfully ver:2.00
[ 4.844124] rga2: Module initialized.
[ 4.844832] mali ffa30000.gpu: bin=0
[ 4.844849] mali ffa30000.gpu: Failed to get leakage
[ 4.845011] mali ffa30000.gpu: Failed to get pvtm
[ 4.845025] mali ffa30000.gpu: bin-scale=59
[ 4.845271] mali ffa30000.gpu: avs=0
[ 4.845311] W : [File] : drivers/gpu/arm/midgard_for_linux/platform/rk/mali_kbase_config_rk.c; [Line] : 114; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
[ 4.845585] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
[ 4.846013] mali ffa30000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[ 4.846134] I : [File] : drivers/gpu/arm/midgard_for_linux/backend/gpu/mali_kbase_devfreq.c; [Line] : 315; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 4.846478] mali ffa30000.gpu: Probed as mali0
[ 4.847436] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 4.847437] rk_gmac-dwmac ff290000.ethernet: clock input or output? (input).
[ 4.847443] rk_gmac-dwmac ff290000.ethernet: TX delay(0x1d).
[ 4.847448] rk_gmac-dwmac ff290000.ethernet: RX delay(0x16).
[ 4.847463] rk_gmac-dwmac ff290000.ethernet: integrated PHY? (no).
[ 4.847550] rk_gmac-dwmac ff290000.ethernet: cannot get clock clk_mac_speed
[ 4.847554] rk_gmac-dwmac ff290000.ethernet: clock input from PHY
[ 4.852565] rk_gmac-dwmac ff290000.ethernet: init for RGMII
[ 4.852652] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 4.852654] Ring mode enabled
[ 4.852657] DMA HW capability register supported
[ 4.852657] Normal descriptors
[ 4.852659] RX Checksum Offload Engine supported (type 2)
[ 4.852660] Wake-Up On Lan supported
[ 4.852690] Enable RX Mitigation via HW Watchdog Timer
[ 4.862314] devfreq ffa30000.gpu: Couldn’t update frequency transition information.
[ 5.315742] mmc_host mmc1: Bus speed (slot 0) = 49500000Hz (slot req 50000000Hz, actual 49500000HZ div = 0)
[ 5.332493] dwmmc_rockchip ff0d0000.dwmmc: Successfully tuned phase to 39
[ 5.341275] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 5.346780] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 5.890006] libphy: stmmac: probed
[ 5.893441] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 5.899881] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 5.906666] input: adc-keys as /devices/platform/adc-keys/input/input3
[ 5.917003] rockchip-dmc dmc: Failed to get leakage
[ 5.922891] rockchip-dmc dmc: Failed to get pvtm
[ 5.927808] rockchip-dmc dmc: avs=0
[ 5.931318] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[ 5.937773] rockchip-dmc dmc: failed to get vop pn to msch rl
[ 5.943708] rockchip-dmc dmc: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[ 5.951373] rockchip-dmc dmc: could not find power_model node
[ 6.085753] asoc-simple-card sound: ES8323 HiFi ↔ ff890000.i2s mapping ok
[ 6.093336] asoc-simple-card sound: i2s-hifi ↔ ff890000.i2s mapping ok
[ 6.100036] asoc-simple-card sound: ASoC: no sink widget found for MIC1
[ 6.106659] asoc-simple-card sound: ASoC: Failed to add route Microphone Jack → direct → MIC1
[ 6.115378] asoc-simple-card sound: ASoC: no sink widget found for MIC2
[ 6.121995] asoc-simple-card sound: ASoC: Failed to add route Microphone Jack → direct → MIC2
[ 6.130681] asoc-simple-card sound: ASoC: no source widget found for micbias1
[ 6.137824] asoc-simple-card sound: ASoC: Failed to add route micbias1 → direct → Microphone Jack
[ 6.146862] asoc-simple-card sound: ASoC: no source widget found for HPOL
[ 6.153654] asoc-simple-card sound: ASoC: Failed to add route HPOL → direct → Headphone Jack
[ 6.162258] asoc-simple-card sound: ASoC: no source widget found for HPOR
[ 6.169040] asoc-simple-card sound: ASoC: Failed to add route HPOR → direct → Headphone Jack
[ 6.180021] input: rockchip,firefly-codec Headphone Jack as /devices/platform/sound/sound/card0/input4
[ 6.190240] asoc-simple-card spdif-sound: dit-hifi ↔ ff8b0000.sound mapping ok
[ 6.198088] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.10 (r)
[ 6.198089]
[ 6.198093] =======================================================
[ 6.198099] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 6.198100] =======================================================
[ 6.198102] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver v5.2.2.3_24783.20171030) init.
[ 6.198105] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 6.198108] [WLAN_RFKILL]: wifi turn on power. -1
[ 6.198109] RTW: module init start
[ 6.198110] RTW: rtl8188eu v5.2.2.3_24783.20171030
[ 6.198112] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 6.198194] usbcore: registered new interface driver rtl8188eu
[ 6.198196] RTW: module init ret=0
[ 6.198675] input: gpio-keys as /devices/platform/gpio-keys/input/input5
[ 6.205317] rtc-hym8563 0-0051: setting system clock to 2021-02-11 09:07:50 UTC (1613034470)
[ 6.213465] vcc_sd: disabling
[ 6.213482] vcc_mipi: disabling
[ 6.213485] dvdd_1v2: disabling
[ 6.213643] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, built at ‘03:06:22’, on ‘Aug 11 2020’.
[ 6.213947] Mali: Mali device driver loaded
[ 6.213961] rkisp1 ff910000.rkisp1: clear unready subdev num: 1
[ 6.214217] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 6.214223] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 6.214224] rkisp1: update sensor failed
[ 6.214226] rkisp1: subdev link fail, remove isp device
[ 6.215052] iommu: Removing device ff910000.rkisp1 from group 0
[ 6.215338] ALSA device list:
[ 6.215340] #0: rockchip,firefly-codec
[ 6.215342] #1: ROCKCHIP,SPDIF
[ 6.359089] ======== dhd_wlan_init_plat_data ========
[ 6.364149] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 6.369720] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=232, oob_irq_flags=0x414
[ 6.377209] dhd_wlan_init_gpio: WL_REG_ON=-1
[ 6.381475] dhd_wifi_platform_load: Enter
[ 6.385580] Power-up adapter ‘DHD generic adapter’
[ 6.386205] Freeing unused kernel memory: 1024K
[ 6.395223] wifi_platform_set_power = 1
[ 6.399066] ======== PULL WL_REG_ON(-1) HIGH! ========
Loading, please wait…
[ 6.404222] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 6.411062] [WLAN_RFKILL]: wifi turn on power. -1
starting version 237
[ 6.721549] wifi_platform_bus_enumerate device present 1
[ 6.726874] ======== Card detection to detect SDIO card! ========
[ 6.733023] mmc1:mmc host rescan start!
[ 6.753010] bcmsdh_register: register client driver
[ 6.758810] bcmsdh_sdmmc_probe: Enter num=1
[ 6.763225] bcmsdh_sdmmc_probe: Enter num=2
[ 6.767406] bus num (host idx)=1, slot num (rca)=1
[ 6.772356] found adapter info ‘DHD generic adapter’
[ 6.777434] sdioh_attach: set sd_f2_blocksize 256
[ 6.783179] sdioh_attach: sd clock rate = 0
[ 6.787648] dhdsdio_probe : no mutex held. set lock
[ 6.792635] F1 signature read @0x18000000=0x16224335
[ 6.800079] F1 signature OK, socitype:0x1 chip:0x4339 rev:0x1 pkg:0x2
[ 6.807021] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 6.814062] dhd_conf_set_chiprev: chip=0x4339, chiprev=1
[ 6.819529] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 6.827219] CFG80211-ERROR) wl_init_prof : wl_init_prof: No profile
[ 6.833763] wl_escan_attach: Enter
[ 6.837533] wl_escan_init: Enter
[ 6.840877] wl_create_event_handler(): thread:wl_escan_handler:d5 started
[ 6.841577] tsk Enter, tsk = 0xed010170
[ 6.851706] dhd_attach(): thread:dhd_watchdog_thread:d6 started
[ 6.857704] dhd_attach(): thread:dhd_dpc:d7 started
[ 6.862675] dhd_attach(): thread:dhd_rxf:d8 started
[ 6.867572] dhd_deferred_work_init: work queue initialized
[ 6.873069] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 → mode 2
[ 6.879803] sdioh_cis_read: func_cis_ptr[0]=0x10ac
[ 6.893977] Dongle Host Driver, version 1.579.77.41.10 (r)
[ 6.899904] wl_ext_iapsta_attach_netdev: ifidx=0, bssidx=0
[ 6.905438] Register interface [wlan0] MAC: 94:a1:a2:4a:c9:fb
[ 6.905438]
[ 6.912811] dhd_tcpack_suppress_set: TCP ACK Suppress mode 2 → mode 0
[ 6.919338] dhd_wl_ioctl: returning as busstate=0
[ 6.924066] dhd_dbg_detach_pkt_monitor, 2204
[ 6.928334] dhd_bus_devreset: == Power OFF ==
[ 6.932878] bcmsdh_oob_intr_unregister: Enter
[ 6.937228] bcmsdh_oob_intr_unregister: irq is not registered
[ 6.942989] dhd_txglom_enable: enable 0
[ 6.946826] dhd_conf_set_txglom_params: txglom_mode=copy
[ 6.952141] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0
[ 6.958743] dhd_conf_set_txglom_params: txinrx_thres=128, dhd_txminmax=-1
[ 6.965526] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=300
[ 6.972403] dhd_bus_devreset: WLAN OFF DONE
[ 6.976702] wifi_platform_set_power = 0
[ 6.980538] ======== PULL WL_REG_ON(-1) LOW! ========
[ 6.985598] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 6.990307] [WLAN_RFKILL]: wifi shut off power.
[ 6.994842] dhdsdio_probe : the lock is released.
[ 6.999606] dhd_module_init: Exit err=0
Begin: Loading essential drivers … done.
Begin: Running /scripts/init-premount … done.
Begin: Running /scripts/local-premount … done.
Warning: fsck not present, so skipping root file system
[ 8.592634] EXT4-fs (mmcblk2p8): mounted filesystem with ordered data mode. Opts: (null)
done.
Begin: Running /scripts/local-bottom … done.
Begin: Running /scripts/init-bottom … Warning: overlayroot: configuring overlayroot with driver=overlay mode=device opts=‘dev=PARTLABEL=userdata,fstype=ext4,mkfs=1’ per kernel cmdline
[ 8.805620] EXT4-fs (mmcblk2p9): recovery complete
[ 8.811094] EXT4-fs (mmcblk2p9): mounted filesystem with ordered data mode. Opts: (null)
[[: missing ]]
ln: /root/var/lib/docker: File exists
Success: overlayroot: configured root with ‘device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1’ using overlay per kernel cmdline
Warning: Something odd, no /lib/modules/4.4.194 in initramfs.
done.
mount: /proc: proc already mounted on /proc.
NAME=Buildroot
VERSION=2018.02-rc3-g30db81275-dirty
ID=buildroot
VERSION_ID=2018.02-rc3
PRETTY_NAME=“Buildroot 2018.02-rc3”
Starting logging: OK
Populating /dev using udev: [ 9.155743] udevd[395]: starting version 3.2.7
[ 9.169361] udevd[395]: specified group ‘kvm’ unknown
[ 9.192207] udevd[396]: starting eudev-3.2.7
[ 9.214878] udevd[396]: specified group ‘kvm’ unknown
done
Initializing random number generator… done.
Will now mount all partitions in /etc/fstab
Note: Create /.skip_fsck to skip fsck
The check might take a while if didn’t shutdown properly!
Handling /dev/mmcblk2p3 /misc emmc defaults 0
Unsupported file system emmc for /dev/mmcblk2p3
Handling /dev/mmcblk2p7 /oem ext2 defaults 2
Checking /dev/mmcblk2p7(ext2)
e2fsck 1.43.9 (8-Feb-2018)
oem was not cleanly unmounted, check forced.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
oem: 16/10240 files (0.0% non-contiguous), 7441/65536 blocks
Mounting /dev/mmcblk2p7(ext2) on /oem
[ 9.867069] EXT4-fs (mmcblk2p7): couldn’t mount as ext3 due to feature incompatibilities
[ 9.876421] EXT4-fs (mmcblk2p7): mounting ext2 file system using the ext4 subsystem
[ 9.887955] EXT4-fs (mmcblk2p7): mounted filesystem without journal. Opts: (null)
Log saved to /tmp/mountall.log
Starting network: OK
ls: cannot access ‘/dev/media*’: No such file or directory
Starting dhcpcd…
dev: loaded udev
[ 9.990844] dhd_ioctl_entry: Interface is down
[ 9.995476] Error getting the SSID
no interfaces have a carrier
forked to background, child pid 645
Starting ntpd: [ 10.116088] dhd_open: Enter ed904000
[ 10.119676] dhd_open : no mutex held. set lock
[ 10.124196]
[ 10.124196] Dongle Host Driver, version 1.579.77.41.10 (r)
[ 10.131165] wl_ext_iapsta_attach_netdev: ifidx=0, bssidx=0
[ 10.136678] wl_android_wifi_on in 1
[ 10.140180] wl_android_wifi_on in 2: g_wifi_on=0
OK
[ 10.144839] wifi_platform_set_power = 1
[ 10.148979] ======== PULL WL_REG_ON(-1) HIGH! ========
Starting launche[ 10.154150] [WLAN_RFKILL]: rockchip_wifi_power: 1
r[ 10.160203] [WLAN_RFKILL]: wifi turn on power. -1
: Starting sshd: librga:RGA_GET_VERSION:2.00,2.000000
ctx=0xa76f10,ctx->rgaFd=3
Rga built version:version:+2017-09-28 10:12:42
Date: 2021-02-11 UTC
[09:07:54.543] weston 3.0.0
http://wayland.freedesktop.org
Bug reports to: https://bugs.freedesktop.org/enter_bug.cgi?product=Wayland&component=weston&version=3.0.0
Build: unknown (not built from git or tarball)
[09:07:54.564] Command line: weston --tty=2 --idle-time=0
[09:07:54.569] OS: Linux, 4.4.194, #4 SMP Wed Feb 10 16:46:10 CST 2021, armv7l
[09:07:54.577] Using config file ‘/etc/xdg/weston/weston.ini’
[09:07:54.585] Output repaint window is 15 ms maximum.
[09:07:54.587] Loading module ‘/usr/lib/libweston-3/drm-backend.so’
[09:07:54.663] initializing drm backend
[09:07:54.665] using /dev/dri/card0
[09:07:54.665] Loading module ‘/usr/lib/libweston-3/gl-renderer.so’
[09:07:54.679] EGL client extensions: EGL_EXT_client_extensions
EGL_EXT_platform_base EGL_KHR_client_get_all_proc_addresses
EGL_KHR_platform_gbm EGL_MESA_platform_gbm
EGL_KHR_platform_wayland EGL_EXT_platform_wayland
[09:07:54.707] warning: EGL_EXT_buffer_age not supported. Performance could be affected.
[09:07:54.709] warning: neither EGL_EXT_swap_buffers_with_damage or EGL_KHR_swap_buffers_with_damage is supported. Performance could be affected.
[09:07:54.722] EGL_KHR_surfaceless_context available
[09:07:54.736] EGL version: 1.4 Midgard-“r14p0-01rel0”
[09:07:54.736] EGL vendor: ARM
[09:07:54.738] EGL client APIs: OpenGL_ES
[09:07:54.742] EGL extensions: EGL_WL_bind_wayland_display
EGL_KHR_partial_update EGL_KHR_image_pixmap
EGL_EXT_image_dma_buf_import EGL_KHR_config_attribs
EGL_KHR_image EGL_KHR_image_base EGL_KHR_fence_sync
EGL_KHR_wait_sync EGL_KHR_gl_colorspace
EGL_KHR_get_all_pro[ 10.471506] sdio_reset_comm():
c_addresses EGL_IMG_context_priority
EGL_ARM_pixmap_multisample_discard EGL_KHR_gl_texture_2D_image
EGL_KHR_gl_renderbuffer_image EGL_KHR_create_context
EGL_KHR_surfaceless_context EGL_KHR_gl_text[ 10.495322] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
ure_cubemap_image
EGL_EXT_create_context_robustness EGL_KHR_cl_event2
[09:07:54.813] GL version: OpenGL ES 3.2 v1.r14p0-01rel0-git(a79caef).e0da4197590de42ee4ea4dc9a5058df6
[09:07:54.822] GLSL version: OpenGL ES GLSL ES 3.20
[09:07:54.826] [ 10.526711] mmc_host mmc1: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
GL vendor: ARM
[09:07:54.842] GL renderer: Mali-T760
[09:07:54.843] GL extensions: GL_ARM_rgba8 GL_ARM_mali_shader_binary
GL_OES_depth24 GL_OES_depth_texture
GL_OES_depth_texture_cube_map GL_OES_packed_depth_stencil
GL_OES_rgb8_rgba8 GL_EXT_read_format_bgra
GL_OES_compressed_paletted_texture
GL_OES_compressed_ETC1_RGB8_texture GL_OES_standard_derivatives
GL_OES_EGL_image GL_OES_EGL_image_external
GL_OES_EGL_image_external_essl3 GL_OES_EGL_sync
GL_OES_texture_npot GL_OES_vertex_half_float
GL_OES_required_internalformat GL_OES_vertex_array_object
GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888[ 10.602500] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)GL_EXT_texture_rg GL_EXT_texture_type_2_10_10_10_REV GL_OES_fbo_render_mipmap GL_OES_element_index_uint GL[ 10.621299] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
_EXT_shadow_samplers GL_OES_texture_compression_astc
GL_KHR_texture_compression_astc_ldr
GL_KHR_texture_compression_astc_hdr
[ 10.640363] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
GL_KHR_texture_compression_astc_sliced_3d GL_KHR_debug
GL_EXT_occlusion_query_boolean GL_EXT_disjoint_timer_query
GL_EXT_blend_minmax GL_EXT_discard_framebuffer[ 10.663975] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
GL_OES_get_program_binary GL_OES_texture_3D
GL_EXT_texture_storage GL_EXT_multisampled_render_to_texture
GL_OES_surfaceless_context GL_OES_texture_stencil8
GL_EXT_shader_pixel_local_storage
GL_ARM_shader_framebuffer_fetch
GL_ARM_shader_framebuffer_fetch_depth_stencil
GL_ARM_mali_program_binary GL_EXT_sRGB
GL_EXT_sRGB_write_control GL_EXT_texture_sRGB_decode
GL_KHR_blend_equation_advanced
GL_KHR_blend_equation_advanced_coherent
GL_OES_texture_storage_multisample_2d_array
GL_OES_shader_image_atomic GL_EXT_robustness
GL_EXT_draw_buffers_indexed GL_OES_draw_buffers_indexed
GL_EXT_texture_border_clamp GL_OES_texture_border_clamp
GL_EXT_texture_cube_map_array GL_OES_texture_cube_map_array
GL_OES_sample_variables GL_OES_sample_shading
GL_OES_shader_multisample_interpolation GL_EXT_shader_io_blocks
GL_OES_shader_io_blocks GL_EXT_tessellation_shader
GL_OES_tessellation_shader GL_EXT_primitive_bounding_box
GL_OES_primitive_bounding_box GL_EXT_geometry_shader
GL_OES_geometry_shader GL_ANDROID_extension_pack_es31a
GL_EXT_gpu_shader5 GL_OES_gpu_shader5 GL_EXT_texture_buffer
GL_OES_texture_buffer GL_EXT_copy_image GL_OES_copy_image
GL_EXT_color_buffer_half_float GL_EXT_color_buffer_float
GL_EXT_YUV_target GL_OVR_multiview GL_OVR_multiview2
GL_OVR_multiview_multisampled_render_to_texture
GL_KHR_robustness GL_KHR_robust_buffer_access_behavior
GL_EXT_draw_elements_base_vertex
GL_OES_draw_elements_base_vertex
[09:07:55.133] GL ES 2 renderer features:
read-back format: BGRA
wl_shm sub-image to texture: no
EGL Wayland extension: yes
[09:07:55.150] event3 - [09:07:55.150] adc-keys: [09:07:55.152] is tagged by udev as: Keyboard
[09:07:55.156] event3 - [09:07:55.158] adc-keys: [09:07:55.160] device is a keyboard
[09:07:55.164] event1 - [09:07:55.166] ILITEK ILITEK-TP: [09:07:55.169] is tagged by udev as: Touchscreen
[09:07:55.173] event1 - [09:07:55.175] ILITEK ILITEK-TP: [09:07:55.178] device is a touch device
[09:07:55.182] event2 - [09:07:55.184] ILITEK ILITEK-TP: [09:07:55.187] is tagged by udev as: Mouse
[09:07:55.190] event2 - [09:07:55.193] ILITEK ILITEK-TP: [09:07:55.195] device is a pointer
[09:07:55.199] event0 - [09:07:55.201] ff680000.pwm: [09:07:55.203] is tagged by ude[ 10.904380] mmc_host mmc1: Bus speed (slot 0) = 49500000Hz (slot req 50000000Hz, actual 49500000HZ div = 0)
v as: Keyboard
[09:07:55.221] event0 - [09:07:55.221] ff680000.pwm: [09:07:55.222] device is a keyboard
[09:07:55.226] event5 - [09:07:55.227] gpio-keys: [09:07:55.229] is tagged by udev as: Keyboard
[09:07:55.233] event5 - [09:07:55.236] gpio-keys: [09:07:55.238] device is a keyboard
[09:07:55.242] event4 - [09:07:55.243] rockchip,firefly-codec Headphone Jack: [09:07:55.248] is tagged by udev as: Switch
[ 10.956335] dwmmc_rockchip ff0d0000.dwmmc: Successfully tuned phase to 39
[ 10.964022] sdioh_start: set sd_f2_blocksize 256
[ 10.968897]
[ 10.968897]
[ 10.968897] dhd_bus_devreset: == WLAN ON ==
[ 10.976141] F1 signature read @0x18000000=0x16224335
[ 10.983601] F1 signature OK, socitype:0x1 chip:0x4339 rev:0x1 pkg:0x2
[ 10.990378] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 10.998343] dhd_conf_read_config: Ignore config file /system/etc/firmware/config.txt
[ 11.006119] Final fw_path=/system/etc/firmware/fw_bcm4339a0_ag.bin
[ 11.012310] Final nv_path=/system/etc/firmware/nvram_AP6335.txt
[ 11.018230] Final clm_path=/system/etc/firmware/clm.blob
[ 11.023545] Final conf_path=/system/etc/firmware/config.txt
[ 11.029463] dhd_os_open_image: /system/etc/firmware/fw_bcm4339a0_ag.bin (541314 bytes) open success
[ 11.097359] dhd_os_open_image: /system/etc/firmware/nvram_AP6335.txt (2366 bytes) open success
[ 11.106674] NVRAM version: AP6335_NVRAM_V1.7_04102014
[ 11.112358] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 11.317733] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 11.324947] bcmsdh_oob_intr_register: HW_OOB irq=232 flags=0x4
[ 11.332558] dhd_get_memdump_info: File [/data/misc/wifi/.memdump.info] doesn’t exist
[ 11.340369] dhd_get_memdump_info: MEMDUMP ENABLED = 2
[ 11.349180] Disable tdls_auto_op failed. -1
[ 11.353539] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 → mode 1
[ 11.360725] dhd_apply_default_clm: Ignore clm file /system/etc/firmware/clm.blob
[ 11.378773] Firmware up: op_mode=0x0005, MAC=94:a1:a2:4a:c9:fb
[ 11.400894] dhd_preinit_ioctls event_msgs_ext not support or version mismatch -23
[ 11.416770] Driver: 1.579.77.41.10 (r)
[ 11.416770] Firmware: wl0: Apr 3 2014 12:12:42 version 6.37.32.28.2_ip (r424058)
[ 11.416770] CLM: 6.8.1
[09:07:55.722] Registered plugin API ‘weston_drm_output_api_v1’ of size 12[ 11.431625] dhd_txglom_enable: enable 1
[ 11.441188] dhd_conf_set_txglom_params: txglom_mode=copy
[09:07:55.742] [ 11.446699] dhd_conf_set_txglom_params: txglomsize=36, deferred_tx_len=0
Chosen EGL confi[ 11.454713] dhd_conf_set_txglom_params: txinrx_thres=128, dhd_txminmax=-1
g[ 11.462833] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=300
details:
[ 11.469769] dhd_conf_get_disable_proptx: fw_proptx=1, disable_proptx=-1
RGBA bits: 8 8 8 8
swap interval range: 0 - 1[ 11.478229] dhd_wlfc_hostreorder_init(): successful bdcv2 tlv signaling, 64
[09:07:55.792] Failed to initialize backlight
[09:07:55.792] EDID data ‘TXD’, ‘HDMI’, ‘16843009’
[09:07:55.795] Output HDMI-A-1, (connector 84, crtc 60)
mode 1920x1080@60.0, preferred, current
mode 1280x720@60.0
mode 720x480@59.9
[09:07:55.811] Compositor capabilities:
arbitrary surface rotation: yes
screen capture uses y-flip: yes
presentation clock: CLOCK_MONOTONIC, id 1
presentation clock resolution: 0.000000001 s
[09:07:55.834] Loading module ‘/usr/lib/weston/desktop-shell.so’
[ 11.538634] dhd_wlfc_enable: ret=0
[09:07:55.842] [ 11.547023] CFG80211-ERROR) wl_cfg80211_event : launching ‘/usr/Event handler is not created
l[ 11.556887] CFG80211-ERROR) wl_cfg80211_event : ibexec/weston-keEvent handler is not created
yboard’
[ 11.565487] CFG80211-ERROR) wl_cfg80211_event : [09:07:55.867] Event handler is not created
launching ‘/usr/libexec/weston-desktop-shell’
[ 11.574630] rtt_do_get_ioctl: failed to send getbuf proxd iovar (CMD ID : 1), status=-23
[ 11.586633] dhd_rtt_init : FTM is not supported
[ 11.591162] dhd_preinit_ioctls: SensorHub diabled 0
[ 11.599024] dhd_preinit_ioctls failed to set ShubHub disable
[ 11.607909] dhd_wl_ioctl_get_intiovar: get int iovar wnm_bsstrans_resp failed, ERR -23
[ 11.615858] failed to get wnm_bsstrans_resp
[ 11.622888] failed to set WNM capabilities
[ 11.627210] dhd_wlfc_enable: ret=0
[ 11.630621] CFG80211-ERROR) wl_cfg80211_event : Event handler is not created
[ 11.637840] dhd_conf_set_country: set country CN, revision 38
librga:RGA_GET_VERSION:2.00,2.0000[ 11.643732] CFG80211-ERROR) wl_cfg80211_event : 00 Event handler is not created
ctx=0x496030,ctx->rgaFd=0
[ 11.657404] CFG80211-ERROR) wl_cfg80211_event : ctx=0x13b7030,ctEvent handler is not created
x->rgaFd=0
Rga built versio[ 11.669006] Country code: CN (CN/38)
[ 11.680427] wl_android_wifi_on: Success
[ 11.686294] dhd_wlfc_enable: ret=0
[ 11.698319] rockchip-vop ff930000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11
[ 11.703211] dhd_open : the lock is released.
[ 11.703213] dhd_open: Exit ret=0
OK
[ 11.749215] Freeing drm_logo memory: 616K
Debug: configfs_init
could not load cursor ‘dnd-move’
could not load cursor ‘dnd-copy’
could not load cursor ‘dnd-none’
mkdir: cannot create directory ‘/sys/kernel/config/usb_gadget/rockchip/functions/uac1.gs0’: No such file or directory
mkdir: cannot create directory ‘/sys/kernel/config/usb_gadget/rockchip/functions/uac2.gs0’: No such file or directory
[ 11.802920] file system registered
mkdir: cannot create directory ‘/sys/kernel/config/usb_gadget/rockchip/functions/mtp.gs0’: No such file or directory
mkdir: cannot create directory ‘/sys/kernel/config/usb_gadget/rockchip/functions/rndis.gs0’: No such file or directory
[ 11.837641] Mass Storage Function, version: 2009/09/11
[ 11.842929] LUN: removable file: (no medium)
mkdir: cannot create directory ‘/sys/kernel/config/usb_gadget/rockchip/functions/uvc.gs6’: No such file or directory
[ 11.902627] read descriptors
[ 11.905551] read strings
xkbcommon: ERROR: couldn’t find a Compose file for locale “zh_CN.utf8”
could not create XKB compose table for locale ‘zh_CN.utf8’. Disabiling compose
QLauncher available size : 1920 x 1080
Using Wayland-EGL
[ 12.101838] rk_gmac-dwmac ff290000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Using the ‘xdg-shell-v6’ shell integration
[ 12.895884] dwc2 ff580000.usb: bound driver configfs-gadget
load wifi modules: Rockchip Linux WifiBt init
BT TTY: /dev/ttyS0
Wifi driver is ready for now…
wifibt_load_driver
uevent path:/sys/bus/sdio/devices/./uevent
uevent path:/sys/bus/sdio/devices/../uevent
uevent path:/sys/bus/sdio/devices/mmc1:0001:1/uevent
line: DRIVER=bcmsdh_sdmmc
, prefix: SDIO_ID=.
line: SDIO_CLASS=00
, prefix: SDIO_ID=.
line: SDIO_ID=02D0:4335
, prefix: SDIO_ID=.
pid:vid : 02d0:4335
found device pid:vid : 02d0:4335
wifi detectd return ret:0
SDIO WIFI identify sucess
check_wifi_chip_type_string: AP6335
/data/wifi_chip is exit
wifibt_load_driver matched ko file path /system/lib/modules/bcmdhd.ko
wifibt_load_driver insmod /system/lib/modules/bcmdhd.ko
insmod: can’t insert ‘/system/lib/modules/bcmdhd.ko’: No such file or directory
wifibt_load_driver insmod /system/lib/modules/bcmdhd.ko failed
OK
Starting dnsmasq: OK
Trying to reconnect Wifi
Starting input-event-daemon: input-event-daemon: Start parsing /etc/input-event-daemon.conf…
input-event-daemon: Adding device: /dev/input/event0…
input-event-daemon: Adding device: /dev/input/event1…[ 13.060926] dwc2 ff580000.usb: new device is high-speed
input-event-daemon: Adding device: /dev/input/event2…
input-event-daemon: Adding device: /dev/input/event3…
input-event-daemon: Adding device: /dev/input/event4…
input-event-daemon: Adding device: /dev/input/event5…
input-event-daemon: Start listening on 6 devices…
done
[ 13.094146] dwc2 ff580000.usb: new address 4
[root@rk3288:/]# [ 13.117750] android_work: sent uevent USB_STATE=CONNECTED
[root@rk3288:/]#
[root@rk3288:/]# mkdir /tmp/boot
[root@rk3288:/]# cd /dev
[root@rk3288:/dev]# ls
ashmem loop0 ppp tty21 tty48 usb-ffs
autofs loop1 ptmx tty22 tty49 usbmon0
block loop2 pts tty23 tty5 usbmon1
bus loop3 ram0 tty24 tty50 usbmon2
cec0 loop4 random tty25 tty51 usbmon3
char loop5 rfkill tty26 tty52 vcs
console loop6 rga tty27 tty53 vcs1
cpu_dma_latency loop7 rtc tty28 tty54 vcs2
disk mali0 rtc0 tty29 tty55 vcs3
dri mapper shm tty3 tty56 vcs4
fb0 mem snd tty30 tty57 vcs5
fd memory_bandwidth stderr tty31 tty58 vcs6
full mmcblk2 stdin tty32 tty59 vcsa
fuse mmcblk2boot0 stdout tty33 tty6 vcsa1
hdmi_hdcp1x mmcblk2boot1 tty tty34 tty60 vcsa2
hevc-service mmcblk2p1 tty0 tty35 tty61 vcsa3
hidraw0 mmcblk2p2 tty1 tty36 tty62 vcsa4
hidraw1 mmcblk2p3 tty10 tty37 tty63 vcsa5
hwrng mmcblk2p4 tty11 tty38 tty7 vcsa6
i2c-0 mmcblk2p5 tty12 tty39 tty8 vendor_storage
i2c-2 mmcblk2p6 tty13 tty4 tty9 vhci
i2c-3 mmcblk2p7 tty14 tty40 ttyFIQ0 vpu-service
i2c-4 mmcblk2p8 tty15 tty41 ttyGS0 zero
i2c-6 mmcblk2p9 tty16 tty42 ttyS0 zram0
iio:device0 mmcblk2rpmb tty17 tty43 ttyS1
input net tty18 tty44 uhid
kmsg network_latency tty19 tty45 uinput
log network_throughput tty2 tty46 urandom
loop-control null tty20 tty47 usb
[root@rk3288:/dev]# mount /d[ 43.419805] android_work: sent uevent USB_STATE=DISCONNECTED
[ 43.470804] dwc2 ff580000.usb: new device is high-speed
[ 43.504394] dwc2 ff580000.usb: new address 5
[ 43.521723] android_work: sent uevent USB_STATE=CONNECTED
[ 43.544862] configfs-gadget gadget: high-speed config #1: b
[ 43.550942] android_work: sent uevent USB_STATE=CONFIGURED
[root@rk3288:/dev]# mount -t ext4 /dev/mmcblk2p1 /tmp/boot/
[ 79.475581] EXT4-fs (mmcblk2p1): VFS: Can’t find ext4 filesystem
mount: /tmp/boot: wrong fs type, bad option, bad superblock on /dev/mmcblk2p1, missing codepage or helper program, or other error.
[root@rk3288:/dev]# mount -t auto /dev/mmcblk2p1 /tmp/boot/
[ 90.861366] UDF-fs: warning (device mmcblk2p1): udf_fill_super: No partition found (2)
[root@rk3288:/dev]# mount -t auto /dev/mmcblk2p2 /tmp/boot/
[ 99.730731] UDF-fs: warning (device mmcblk2p2): udf_fill_super: No partition found (2)
mount: /tmp/boot: wrong fs type, bad option, bad superblock on /dev/mmcblk2p2, missing codepage or helper program, or other error.
[root@rk3288:/dev]# mount -t auto /dev/mmcblk2p3 /tmp/boot/
[ 104.152921] UDF-fs: warning (device mmcblk2p3): udf_fill_super: No partition found (2)
mount: /tmp/boot: wrong fs type, bad option, bad superblock on /dev/mmcblk2p3, missing codepage or helper program, or other error.
[root@rk3288:/dev]# mount -t auto /dev/mmcblk2p4 /tmp/boot/
[ 110.279969] UDF-fs: warning (device mmcblk2p4): udf_fill_super: No partition found (2)
mount: /tmp/boot: wrong fs type, bad option, bad superblock on /dev/mmcblk2p4, missing codepage or helper program, or other error.
[root@rk3288:/dev]# mount -t auto /dev/mmcblk2p5 /tmp/boot/
[ 115.204402] UDF-fs: warning (device mmcblk2p5): udf_fill_super: No partition found (2)
mount: /tmp/boot: wrong fs type, bad option, bad superblock on /dev/mmcblk2p5, missing codepage or helper program, or other error.
[root@rk3288:/dev]# mount -t auto /dev/mmcblk2p6 /tmp/boot/
[ 120.114177] UDF-fs: warning (device mmcblk2p6): udf_fill_super: No partition found (2)
mount: /tmp/boot: wrong fs type, bad option, bad superblock on /dev/mmcblk2p6, missing codepage or helper program, or other error.
[root@rk3288:/dev]# mount -t auto /dev/mmcblk2p7 /tmp/boot/
[root@rk3288:/dev]# ls /tmp/boot/
200frames_count.h264 SampleVideo_1280x720_5mb.mp4 lost+found
SampleJPGImage_500kbmb.jpg belle-nuit-testchart-1080p.png piano2-CoolEdit.mp3
[root@rk3288:/dev]# umount /tmp/boot/
[root@rk3288:/dev]# mount -t auto /dev/mmcblk2p9 /tmp/boot/
bin docker overlay recovery wifi_chip
cfg lost+found overlay-workdir setting.cfg
