RK3308 UAC功能不稳定
RK3308平台,USB 启用了UAC(录音跟放音2种功能)+adb,采用1.2m的USB线材连接部分笔记本电脑,触碰一下线材USB会重新识别驱动或者一直刷High speed 的log。测试了眼图,眼图勉强能够PASS的,还有什么方向可以查询?
附件为测试的USB眼图
USB Device-0128-ok-眼图.zip (452 KB)
这是抓取的log
[BEGIN] 2021/1/29/周五 17:09:18
[ 237.385520] rk816-bat: pmic: plug in
[ 237.508141] phy phy-ff008000.syscon:usb2-phy@100.0: charger = USB_SDP_CHARGER
[ 237.518090] rk816-bat: receive extcon notifier event: USB…
[ 237.519976] rk816-bat: set charger type: USB, current: input=450, chrg=1000
[ 237.520821] ar700_write_proc:1628:cmd=charge_mode_low_power
[ 237.661758] dwc2 ff400000.usb: new device is high-speed
[ 237.844492] dwc2 ff400000.usb: new device is high-speed
[ 238.028698] dwc2 ff400000.usb: new device is high-speed
[ 238.205991] dwc2 ff400000.usb: new device is high-speed
[ 238.382890] dwc2 ff400000.usb: new device is high-speed
[ 238.566186] dwc2 ff400000.usb: new device is high-speed
[ 238.743301] dwc2 ff400000.usb: new device is high-speed
[ 238.920469] dwc2 ff400000.usb: new device is high-speed
[ 239.097484] dwc2 ff400000.usb: new device is high-speed
[ 239.274994] dwc2 ff400000.usb: new device is high-speed
[ 239.451982] dwc2 ff400000.usb: new device is high-speed
[ 239.629146] dwc2 ff400000.usb: new device is high-speed
[ 239.806478] dwc2 ff400000.usb: new device is high-speed
[ 239.989704] dwc2 ff400000.usb: new device is high-speed
[ 240.170668] dwc2 ff400000.usb: new device is high-speed
[ 240.351565] dwc2 ff400000.usb: new device is high-speed
[ 240.534077] dwc2 ff400000.usb: new device is high-speed
[ 240.718749] dwc2 ff400000.usb: new device is high-speed
[ 240.898506] dwc2 ff400000.usb: new device is high-speed
[ 241.081080] dwc2 ff400000.usb: new device is high-speed
[ 241.261980] dwc2 ff400000.usb: new device is high-speed
[ 241.440484] dwc2 ff400000.usb: new device is high-speed
[ 241.623332] dwc2 ff400000.usb: new device is high-speed
[ 241.803335] dwc2 ff400000.usb: new device is high-speed
[ 241.983692] dwc2 ff400000.usb: new device is high-speed
[ 242.163970] dwc2 ff400000.usb: new device is high-speed
[ 242.344631] dwc2 ff400000.usb: new device is high-speed
[ 242.399883] ar700_write_proc:1628:cmd=charge_mode_low_power
[ 242.521727] dwc2 ff400000.usb: new device is high-speed
[ 242.704622] dwc2 ff400000.usb: new device is high-speed
[ 242.883045] dwc2 ff400000.usb: new device is high-speed
[ 243.061060] dwc2 ff400000.usb: new device is high-speed
[ 243.238581] dwc2 ff400000.usb: new device is high-speed
[ 243.416099] dwc2 ff400000.usb: new device is high-speed
[ 243.593047] dwc2 ff400000.usb: new device is high-speed
[ 243.770564] dwc2 ff400000.usb: new device is high-speed
[ 243.955531] dwc2 ff400000.usb: new device is high-speed
[ 244.140505] dwc2 ff400000.usb: new device is high-speed
[ 244.321562] dwc2 ff400000.usb: new device is high-speed
[ 244.499840] dwc2 ff400000.usb: new device is high-speed
[ 244.680515] dwc2 ff400000.usb: new device is high-speed
[ 244.857322] dwc2 ff400000.usb: new device is high-speed
[ 245.034738] dwc2 ff400000.usb: new device is high-speed
[ 245.211760] dwc2 ff400000.usb: new device is high-speed
[ 245.388786] dwc2 ff400000.usb: new device is high-speed
[ 245.566294] dwc2 ff400000.usb: new device is high-speed
[ 245.743931] dwc2 ff400000.usb: new device is high-speed
[ 245.921447] dwc2 ff400000.usb: new device is high-speed
[ 246.098963] dwc2 ff400000.usb: new device is high-speed
[ 246.276983] dwc2 ff400000.usb: new device is high-speed
[ 246.454495] dwc2 ff400000.usb: new device is high-speed
[ 246.631517] dwc2 ff400000.usb: new device is high-speed
[ 246.808495] dwc2 ff400000.usb: new device is high-speed
[ 246.988755] dwc2 ff400000.usb: new device is high-speed
[ 247.166524] dwc2 ff400000.usb: new device is high-speed
[ 247.349032] dwc2 ff400000.usb: new device is high-speed
[ 247.527483] dwc2 ff400000.usb: new device is high-speed
[ 247.707772] dwc2 ff400000.usb: new device is high-speed
[ 247.888500] dwc2 ff400000.usb: new device is high-speed
[ 248.069220] dwc2 ff400000.usb: new device is high-speed
[ 248.252068] dwc2 ff400000.usb: new device is high-speed
[ 248.436916] dwc2 ff400000.usb: new device is high-speed
[ 248.619722] dwc2 ff400000.usb: new device is high-speed
[ 248.800781] dwc2 ff400000.usb: new device is high-speed
[ 248.978279] dwc2 ff400000.usb: new device is high-speed
[ 249.155792] dwc2 ff400000.usb: new device is high-speed
[ 249.332811] dwc2 ff400000.usb: new device is high-speed
[ 249.510323] dwc2 ff400000.usb: new device is high-speed
[ 249.688338] dwc2 ff400000.usb: new device is high-speed
[ 249.865358] dwc2 ff400000.usb: new device is high-speed
[ 250.042870] dwc2 ff400000.usb: new device is high-speed
[ 250.220314] dwc2 ff400000.usb: new device is high-speed
[ 250.397347] dwc2 ff400000.usb: new device is high-speed
[ 250.575359] dwc2 ff400000.usb: new device is high-speed
[ 250.752871] dwc2 ff400000.usb: new device is high-speed
[ 250.930389] dwc2 ff400000.usb: new device is high-speed
[ 251.107905] dwc2 ff400000.usb: new device is high-speed
[ 251.285420] dwc2 ff400000.usb: new device is high-speed
[ 251.462434] dwc2 ff400000.usb: new device is high-speed
[ 251.639448] dwc2 ff400000.usb: new device is high-speed
[ 251.816407] dwc2 ff400000.usb: new device is high-speed
[ 251.997598] dwc2 ff400000.usb: new device is high-speed
[ 252.182487] dwc2 ff400000.usb: new device is high-speed
[ 252.363176] dwc2 ff400000.usb: new device is high-speed
[ 252.540675] dwc2 ff400000.usb: new device is high-speed
[ 252.725280] dwc2 ff400000.usb: new device is high-speed
[ 252.908174] dwc2 ff400000.usb: new device is high-speed
[ 253.092768] dwc2 ff400000.usb: new device is high-speed
[ 253.269668] dwc2 ff400000.usb: new device is high-speed
[ 253.451650] dwc2 ff400000.usb: new device is high-speed
[ 253.628648] dwc2 ff400000.usb: new device is high-speed
[ 253.811063] dwc2 ff400000.usb: new device is high-speed
[ 253.991839] dwc2 ff400000.usb: new device is high-speed
[ 254.175806] dwc2 ff400000.usb: new device is high-speed
[ 254.360372] dwc2 ff400000.usb: new device is high-speed
[ 254.543221] dwc2 ff400000.usb: new device is high-speed
[ 254.720997] dwc2 ff400000.usb: new device is high-speed
[ 254.898064] dwc2 ff400000.usb: new device is high-speed
[ 255.075580] dwc2 ff400000.usb: new device is high-speed
[ 255.253095] dwc2 ff400000.usb: new device is high-speed
[ 255.430611] dwc2 ff400000.usb: new device is high-speed
[ 255.608125] dwc2 ff400000.usb: new device is high-speed
[ 255.785267] dwc2 ff400000.usb: new device is high-speed
[ 255.962284] dwc2 ff400000.usb: new device is high-speed
[ 256.139230] dwc2 ff400000.usb: new device is high-speed
[ 256.316258] dwc2 ff400000.usb: new device is high-speed
[ 256.493268] dwc2 ff400000.usb: new device is high-speed
[ 256.670291] dwc2 ff400000.usb: new device is high-speed
[ 256.847809] dwc2 ff400000.usb: new device is high-speed
[ 257.024827] dwc2 ff400000.usb: new device is high-speed
[ 257.202342] dwc2 ff400000.usb: new device is high-speed
[ 257.379860] dwc2 ff400000.usb: new device is high-speed
[ 257.557375] dwc2 ff400000.usb: new device is high-speed
[ 257.734891] dwc2 ff400000.usb: new device is high-speed
[ 257.914516] dwc2 ff400000.usb: new device is high-speed
[ 258.093552] dwc2 ff400000.usb: new device is high-speed
[ 258.274663] dwc2 ff400000.usb: new device is high-speed
[ 258.466953] rk816-bat: pmic: plug out
[ 258.560062] rk816-bat: receive extcon notifier event: DISCNT…
[ 258.562058] rk816-bat: set charger type: NONE USB, current: input=450, chrg=1000
[ 258.562090] rk816-bat: receive extcon notifier event: NONE…
[ 258.563912] rk816-bat: set charger type: NONE USB, current: input=450, chrg=1000
[ 258.573436] ar700_write_proc:1628:cmd=uac_stop_capture
[ 258.573436] {ѝÿÿ.ÿÿÿ󿼓ÿÿ.ÿÿÿ@Ѧ
[ 258.587925] ar700_write_proc:1628:cmd=uac_out
[ 258.587925]ÿÿÿϻѝÿÿ.ÿÿÿ󿼓ÿÿ.ÿÿÿ@Ѧ
[ 258.597453] android_work: did not send uevent (0 0 (null))
[ 258.597500] configfs-gadget gadget: unbind function ‘uac1_func’/ffffffc01ddc2238
[ 258.600224] configfs-gadget gadget: unbind function ‘Function FS Gadget’/ffffffc01ddc3038
[ 259.675839] ffs_data_put(): freeing
[ 259.688218] read descriptors
[ 259.688267] read strings
[ 260.695152] dwc2 ff400000.usb: bound driver configfs-gadget
[ 260.726188] ar700_write_proc:1628:cmd=uac_stop_capture
[ 260.726188] {ӝÿÿ.ÿÿÿ󿼕ÿÿ.ÿÿÿ@Ѧ
[ 260.741127] ar700_write_proc:1628:cmd=uac_out
[ 260.741127]ÿÿÿϻӝÿÿ.ÿÿÿ󿼕ÿÿ.ÿÿÿ@Ѧ
[ 260.750061] android_work: did not send uevent (0 0 (null))
[ 260.750108] configfs-gadget gadget: unbind function ‘uac1_func’/ffffffc01e1c2838
[ 260.752435] configfs-gadget gadget: unbind function ‘Function FS Gadget’/ffffffc01e1c2638
[ 261.830088] ffs_data_put(): freeing
[ 261.842449] read descriptors
[ 261.842505] read strings
[ 262.146566] rk816-bat: pmic: plug in
[ 262.269152] phy phy-ff008000.syscon:usb2-phy@100.0: charger = USB_SDP_CHARGER
[ 262.279077] rk816-bat: receive extcon notifier event: USB…
[ 262.280972] rk816-bat: set charger type: USB, current: input=450, chrg=1000
[ 262.281803] ar700_write_proc:1628:cmd=charge_mode_low_power
[ 262.847559] dwc2 ff400000.usb: bound driver configfs-gadget
[ 263.012822] dwc2 ff400000.usb: new device is high-speed
[ 263.193416] dwc2 ff400000.usb: new device is high-speed
[ 263.370553] dwc2 ff400000.usb: new device is high-speed
[ 263.552880] dwc2 ff400000.usb: new device is high-speed
[ 263.737246] dwc2 ff400000.usb: new device is high-speed
[ 263.915011] dwc2 ff400000.usb: new device is high-speed
[ 264.092031] dwc2 ff400000.usb: new device is high-speed
[ 264.269553] dwc2 ff400000.usb: new device is high-speed
[ 264.448066] dwc2 ff400000.usb: new device is high-speed
[ 264.625579] dwc2 ff400000.usb: new device is high-speed
[ 264.803097] dwc2 ff400000.usb: new device is high-speed
[ 264.987798] dwc2 ff400000.usb: new device is high-speed
[ 265.166618] dwc2 ff400000.usb: new device is high-speed
[ 265.348349] dwc2 ff400000.usb: new device is high-speed
[ 265.532593] dwc2 ff400000.usb: new device is high-speed
[ 265.711006] dwc2 ff400000.usb: new device is high-speed
[ 265.893839] dwc2 ff400000.usb: new device is high-speed
[ 266.071270] dwc2 ff400000.usb: new device is high-speed
[ 266.255108] dwc2 ff400000.usb: new device is high-speed
[ 266.438481] dwc2 ff400000.usb: new device is high-speed
[ 266.621360] dwc2 ff400000.usb: new device is high-speed
[ 266.798488] dwc2 ff400000.usb: new device is high-speed
[ 266.975995] dwc2 ff400000.usb: new device is high-speed
[ 267.153510] dwc2 ff400000.usb: new device is high-speed
[ 267.331029] dwc2 ff400000.usb: new device is high-speed
[ 267.508042] dwc2 ff400000.usb: new device is high-speed
[ 267.685057] dwc2 ff400000.usb: new device is high-speed
[ 267.862067] dwc2 ff400000.usb: new device is high-speed
[ 268.039581] dwc2 ff400000.usb: new device is high-speed
[ 268.217100] dwc2 ff400000.usb: new device is high-speed
[ 268.394622] dwc2 ff400000.usb: new device is high-speed
[ 268.572132] dwc2 ff400000.usb: new device is high-speed
[ 268.750147] dwc2 ff400000.usb: new device is high-speed
[ 268.927664] dwc2 ff400000.usb: new device is high-speed
[ 269.104677] dwc2 ff400000.usb: new device is high-speed
[ 269.281698] dwc2 ff400000.usb: new device is high-speed
[ 269.458716] dwc2 ff400000.usb: new device is high-speed
[ 269.635688] dwc2 ff400000.usb: new device is high-speed
[ 269.812650] dwc2 ff400000.usb: new device is high-speed
[ 269.990171] dwc2 ff400000.usb: new device is high-speed
[ 270.167186] dwc2 ff400000.usb: new device is high-speed
[ 270.344210] dwc2 ff400000.usb: new device is high-speed
[ 270.521218] dwc2 ff400000.usb: new device is high-speed
[ 270.698732] dwc2 ff400000.usb: new device is high-speed
[ 270.876405] dwc2 ff400000.usb: new device is high-speed
[ 271.057008] dwc2 ff400000.usb: new device is high-speed
[ 271.239417] dwc2 ff400000.usb: new device is high-speed
[ 271.420017] dwc2 ff400000.usb: new device is high-speed
[ 271.602602] dwc2 ff400000.usb: new device is high-speed
[ 271.787180] dwc2 ff400000.usb: new device is high-speed
[ 271.967775] dwc2 ff400000.usb: new device is high-speed
[ 272.147221] dwc2 ff400000.usb: new device is high-speed
[ 272.331636] dwc2 ff400000.usb: new device is high-speed
[ 272.516724] dwc2 ff400000.usb: new device is high-speed
[ 272.695402] dwc2 ff400000.usb: new device is high-speed
[ 272.872606] dwc2 ff400000.usb: new device is high-speed
[ 273.049618] dwc2 ff400000.usb: new device is high-speed
[ 273.227137] dwc2 ff400000.usb: new device is high-speed
[ 273.404157] dwc2 ff400000.usb: new device is high-speed
[ 273.581665] dwc2 ff400000.usb: new device is high-speed
[ 273.758683] dwc2 ff400000.usb: new device is high-speed
[ 273.935698] dwc2 ff400000.usb: new device is high-speed
[ 274.113217] dwc2 ff400000.usb: new device is high-speed
[ 274.290735] dwc2 ff400000.usb: new device is high-speed
[ 274.467751] dwc2 ff400000.usb: new device is high-speed
[ 274.644721] dwc2 ff400000.usb: new device is high-speed
[ 274.822291] dwc2 ff400000.usb: new device is high-speed
[ 275.002082] dwc2 ff400000.usb: new device is high-speed
[ 275.180829] dwc2 ff400000.usb: new device is high-speed
[ 275.363222] dwc2 ff400000.usb: new device is high-speed
[ 275.547430] dwc2 ff400000.usb: new device is high-speed
[ 275.725969] dwc2 ff400000.usb: new device is high-speed
[ 275.903267] dwc2 ff400000.usb: new device is high-speed
[ 276.080782] dwc2 ff400000.usb: new device is high-speed
[ 276.257806] dwc2 ff400000.usb: new device is high-speed
[ 276.435321] dwc2 ff400000.usb: new device is high-speed
[ 276.613336] dwc2 ff400000.usb: new device is high-speed
[ 276.790849] dwc2 ff400000.usb: new device is high-speed
[ 276.975860] dwc2 ff400000.usb: new device is high-speed
[ 277.154526] dwc2 ff400000.usb: new device is high-speed
[ 277.335187] dwc2 ff400000.usb: new device is high-speed
[ 277.519674] dwc2 ff400000.usb: new device is high-speed
[ 277.697271] dwc2 ff400000.usb: new device is high-speed
[ 277.874649] dwc2 ff400000.usb: new device is high-speed
[ 278.050388] dwc2 ff400000.usb: new device is high-speed
[ 278.197877] rk816-bat: pmic: plug out
[ 278.310060] rk816-bat: receive extcon notifier event: DISCNT…
[ 278.311882] rk816-bat: set charger type: NONE USB, current: input=450, chrg=1000
[ 278.311910] rk816-bat: receive extcon notifier event: NONE…
[ 278.316311] rk816-bat: set charger type: NONE USB, current: input=450, chrg=1000
[ 278.323103] ar700_write_proc:1628:cmd=uac_stop_capture
[ 278.323103] ;ˉÿÿ.ÿÿÿ󾻯ÿÿ.ÿÿÿ@Ѧ
[ 278.338363] ar700_write_proc:1628:cmd=uac_out
[ 278.338363]ÿÿÿλˉÿÿ.ÿÿÿ󾻯ÿÿ.ÿÿÿ@Ѧ
[ 278.347372] android_work: did not send uevent (0 0 (null))
[ 278.347422] configfs-gadget gadget: unbind function ‘uac1_func’/ffffffc01ddc3238
[ 278.348583] configfs-gadget gadget: unbind function ‘Function FS Gadget’/ffffffc01ddc2038
[ 279.426340] ffs_data_put(): freeing
[ 279.438477] read descriptors
[ 279.438529] read strings
[ 280.445108] dwc2 ff400000.usb: bound driver configfs-gadget
[ 280.476241] ar700_write_proc:1628:cmd=uac_stop_capture
[ 280.476241] »Νÿÿ.ÿÿÿ༐ÿÿ.ÿÿÿ@Ѧ
[ 280.491373] ar700_write_proc:1628:cmd=uac_out
[ 280.491373]ÿÿÿлΝÿÿ.ÿÿÿ༐ÿÿ.ÿÿÿ@Ѧ
[ 280.500384] android_work: did not send uevent (0 0 (null))
[ 280.500432] configfs-gadget gadget: unbind function ‘uac1_func’/ffffffc01dd6c238
[ 280.501870] configfs-gadget gadget: unbind function ‘Function FS Gadget’/ffffffc01dd6dc38
[ 281.578552] ffs_data_put(): freeing
[ 281.591510] read descriptors
[ 281.591564] read strings
[ 282.597090] dwc2 ff400000.usb: bound driver configfs-gadget
[bft]process_report_electricity:2364: 不用上报battery = 0.
大神们,有用过RK3308的UAC功能的么?小白在线求助!
换根线试一下呗,试一下单独adb或者uac有没有问题
