Android5.1 sdk 下载问题
按照下面链接操作下载sdk
http://wiki.t-firefly.com/zh_CN/Firefly-RK3288/compile_android_firmware.html
服务器平台:ubuntu14.04
git remote add bitbucket https://bitbucket.org/T-Firefly/firenow-lollipop.git
fatal: remote bitbucket already exists.
git pull bitbucket Firefly-RK3288:Firefly-RK3288
fatal: unable to access ‘https://bitbucket.org/T-Firefly/firenow-lollipop.git/’: gnutls_handshake() failed: Handshake failed
请问这个是什么 问题,有帮忙指点下么,谢谢哦
请按照 http://wiki.t-firefly.com/zh_CN/Firefly-RK3288/prepare_compile_android.html 把相关的安装上
sudo apt-get install git-core gnupg flex bison gperf libsdl1.2-dev \
libesd0-dev libwxgtk2.8-dev squashfs-tools build-essential zip curl \
libncurses5-dev zlib1g-dev pngcrush schedtool libxml2 libxml2-utils \
xsltproc lzop libc6-dev schedtool g++-multilib lib32z1-dev lib32ncurses5-dev \
lib32readline-gplv2-dev gcc-multilib libswitch-perl \
libssl1.0.0 libssl-dev
全部都装了,而且还弄了两遍
xfwu@ubuntu:~/share/rk3288_a5$ sudo apt-get install git-core gnupg flex bison gperf libsdl1.2-dev \
xsltproc lzop libc6-dev schedtool g+±multilib lib32z1-dev lib32ncurses5-dev
[sudo] password for xfwu:
Reading package lists… Done
Building dependency tree
bison is already the newest version.
build-essential is already the newest version.
flex is already the newest version.
g+±multilib is already the newest version.
gcc-multilib is already the newest version.
gperf is already the newest version.
lib32ncurses5-dev is already the newest version.
lib32readline-gplv2-dev is already the newest version.
libesd0-dev is already the newest version.
libncurses5-dev is already the newest version.
zip is already the newest version.
libswitch-perl is already the newest version.
libwxgtk2.8-dev is already the newest version.
lzop is already the newest version.
pngcrush is already the newest version.
schedtool is already the newest version.
curl is already the newest version.
git-core is already the newest version.
gnupg is already the newest version.
libc6-dev is already the newest version.
libssl-dev is already the newest version.
libssl1.0.0 is already the newest version.
libxml2 is already the newest version.
libxml2-utils is already the newest version.
xsltproc is already the newest version.
lib32z1-dev is already the newest version.
libsdl1.2-dev is already the newest version.
squashfs-tools is already the newest version.
zlib1g-dev is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Allanwu 发表于 2021-3-11 18:02
xfwu@ubuntu:~/share/rk3288_a5$ sudo apt-get install git-core gnupg flex bison gperf libsdl1.2-dev …
参考如下修改
https://www.cnblogs.com/zidingliu/p/11496009.html
jpchen 发表于 2021-3-12 08:35
参考如下修改
chenjp,谢谢,可以了
