PX30 SDK uboot uart2m0_xfer 串口终端无法输入
U-Boot 2017.09 (Mar 15 2021 - 17:56:33 +0800)
Model: Rockchip PX30 EVB
PreSerial: 2
DRAM:  992 MiB
Sysmem: init
Relocation Offset is: 3dbe5000
dwmmc@ff370000: 1, dwmmc@ff390000: 0
Bootdev(atags): mmc 0
MMC0: HS200, 150Mhz
PartType: EFI
boot mode: None
Load FDT from boot part
DTB: rk-kernel.dtb
I2c speed: 100000Hz
PMIC:  RK8090 (on=0x40, off=0x00)
vdd_logic 1100000 uV
vdd_arm 1100000 uV
Failed to found available display route
Model: AIO-PX30JD4 Board (Linux Opensource)
CLK: (sync kernel. arm: enter 600000 KHz, init 600000 KHz, kernel 600000 KHz)
  apll 600000 KHz
  dpll 664000 KHz
  cpll 24000 KHz
  npll 1188000 KHz
  gpll 1200000 KHz
  aclk_bus 200000 KHz
  hclk_bus 150000 KHz
  pclk_bus 100000 KHz
  aclk_peri 200000 KHz
  hclk_peri 150000 KHz
  pclk_pmu 100000 KHz
Net:   eth0: ethernet@ff360000
Hit key to stop autoboot('CTRL+C'):  0
ANDROID: reboot reason: "(none)"
Fdt Ramdisk skip relocation
Booting IMAGE kernel at 0x00280000 with fdt at 0x8300000...
以上是启动信息,无法CTRL+C终止autoboot,我们自己做的硬件debug口是GPIO1_D2、GPIO1_D3刚好对应uart2m0_xfer
https://dev.t-firefly.com/thread-102310-1-1.html
感谢,已解决!
