DDR V1.14 20190925
D3,1024MB,333MHz
bw col bk row cs dbw
32 10 8 15 1 16
Boot1 Release Time: Nov 20 2019 14:41:00, version: 1.22
chip_id:50583330_0,0
ChipType = 0x12, 458
mmc2:cmd19,100
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=3728MB
FwPartOffset=2000 , 2000
SdmmcInit=0 NOT PRESENT
StorageInit ok = 9735
SecureMode = 0
Secure read PBA: 0x4
Secure read PBA: 0x404
Secure read PBA: 0x804
Secure read PBA: 0xc04
Secure read PBA: 0x1004
atags_set_bootdev: ret:(0)
GPT part: 2, name: boot, start:0xa000, size:0x10000
GPT part: 3, name: rootfs, start:0x5a000, size:0x600000
GPT part: 4, name: userdata, start:0x65a000, size:0xedfdf
find part:uboot OK. first_lba:0x4000.
find part:trust OK. first_lba:0x6000.
LoadTrust Addr:0x6000
No find bl30.bin
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0xd56d4
RunBL31 0x40000 @ 70158 us
INFO: Preloader serial: 2
NOTICE: BL31: v1.3(debug):857e9c1b4
NOTICE: BL31: Built : 11:50:33, Aug 21 2020
NOTICE: BL31:Rockchip release version: v1.0
INFO: ARM GICv2 driver initialized
INFO: boot cpu mask: 1
INFO: plat_rockchip_pmu_init: pd status f00e
INFO: BL31: Initializing BL32
I/TC:
I/TC: Start rockchip platform init
I/TC: Rockchip release version: 1.1
I/TC: OP-TEE version: 3.6.0-284-g82765277 #12 Thu Sep 17 03:47:31 UTC 2020 aarch64
I/TC: Initialized
INFO: SPSR = 0x3c9
U-Boot 2017.09 (Mar 20 2021 - 11:52:34 +0800)
Model: Rockchip PX30 EVB
PreSerial: 2
DRAM: 992 MiB
Sysmem: init
Relocation Offset is: 3dbe5000
dwmmc@ff370000: 1, dwmmc@ff390000: 0
Bootdev(atags): mmc 0
MMC0: HS200, 150Mhz
PartType: EFI
rockchip_get_boot_mode: Could not found misc partition
boot mode: None
Load FDT from boot part
DTB: rk-kernel.dtb
I2c speed: 100000Hz
PMIC: RK8090 (on=0x40, off=0x00)
vdd_logic 1100000 uV
vdd_arm 1100000 uV
Model: AIO-PX30JD4 Board (Linux Opensource)
Using display timing dts
Detailed mode clock 65000 kHz, flags[a]
H: 0800 0832 0840 0848
V: 1280 1297 1301 1312
bus_format: 100e
CLK: (sync kernel. arm: enter 600000 KHz, init 600000 KHz, kernel 600000 KHz)
apll 600000 KHz
dpll 664000 KHz
cpll 650000 KHz
npll 1188000 KHz
gpll 1200000 KHz
aclk_bus 200000 KHz
hclk_bus 150000 KHz
pclk_bus 100000 KHz
aclk_peri 200000 KHz
hclk_peri 150000 KHz
pclk_pmu 100000 KHz
Net: eth0: ethernet@ff360000
Hit key to stop autoboot('CTRL+C'): 0
Could not find misc partition
ANDROID: reboot reason: "(none)"
Fdt Ramdisk skip relocation
Booting IMAGE kernel at 0x00280000 with fdt at 0x8300000...
Sysmem Warn: kernel 'reserved-memory' "region@110000"(0x00110000 - 0x00200000) is overlap with [invisible] "SHM" (0x00100000 - 0x00200000)
## Booting Android Image at 0x0027f800 ...
Kernel load addr 0x00280000 size 11399 KiB
RAM disk load addr 0x0a200000 size 9161 KiB
## Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
XIP Kernel Image ... OK
'reserved-memory' region@110000: addr=110000 size=f0000
Using Device Tree in place at 0000000008300000, end 0000000008318f1b
Adding bank: 0x0a200000 - 0x40000000 (size: 0x35e00000)
Total: 3627.173 ms
Starting kernel ...
[ 0.000000] Linux version 4.4.189 (jobs@apple) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #5 SMP Sat Mar 20 22:33:51 CST 2021
[ 0.000000] Boot CPU: AArch64 Processor [410fd042]
[ 0.000000] earlycon: Early serial console at MMIO32 0xff160000 (options '')
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc03ff2b000 s45672 r8192 d32152 u86016
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 249864
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.slot_suffix= androidboot.serialno=c3d9b8674f4b94f6 ro rootwait earlycon=uart8250,mmio32,0xff160000 swiotlb=1 console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.000000] software IO TLB: mapped [mem 0x3fd34000-0x3fd74000] (0MB)
[ 0.000000] Memory: 972964K/1015808K available (7102K kernel code, 966K rwdata, 2436K rodata, 832K init, 1821K bss, 42844K reserved, 0K cma-reserved)
[ 0.000000] .init : 0xffffff80089e0000 - 0xffffff8008ab0000 ( 832 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008770000 ( 7104 KB)
[ 0.000000] .rodata : 0xffffff8008770000 - 0xffffff80089e0000 ( 2496 KB)
[ 0.000000] .data : 0xffffff8008ab0000 - 0xffffff8008ba1808 ( 967 KB)
[ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc1000000 ( 15 MB actual)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc040000000 ( 1022 MB)
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000010] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.002668] Console: colour dummy device 80x25
[ 0.003124] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.004118] pid_max: default: 32768 minimum: 301
[ 0.004766] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.005424] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.007196] Initializing cgroup subsys devices
[ 0.007665] Initializing cgroup subsys freezer
[ 0.008131] ftrace: allocating 27427 entries in 108 pages
[ 0.103149] sched-energy: CPU device node has no sched-energy-costs
[ 0.103827] Invalid sched_group_energy for CPU0
[ 0.104260] CPU0: update cpu_capacity 1024
[ 0.104733] ASID allocator initialised with 32768 entries
[ 0.110063] Detected VIPT I-cache on CPU1
[ 0.110149] Invalid sched_group_energy for CPU1
[ 0.110157] CPU1: update cpu_capacity 1024
[ 0.110164] CPU1: Booted secondary processor [410fd042]
[ 0.111229] Detected VIPT I-cache on CPU2
[ 0.111295] Invalid sched_group_energy for CPU2
[ 0.111302] CPU2: update cpu_capacity 1024
[ 0.111309] CPU2: Booted secondary processor [410fd042]
[ 0.112319] Detected VIPT I-cache on CPU3
[ 0.112383] Invalid sched_group_energy for CPU3
[ 0.112390] CPU3: update cpu_capacity 1024
[ 0.112397] CPU3: Booted secondary processor [410fd042]
[ 0.112562] Brought up 4 CPUs
[ 0.117936] SMP: Total of 4 processors activated.
[ 0.118392] CPU features: detected feature: 32-bit EL0 Support
[ 0.118968] CPU: All CPU(s) started at EL2
[ 0.119665] Invalid sched_group_energy for CPU3
[ 0.120129] Invalid sched_group_energy for Cluster3
[ 0.120592] Invalid sched_group_energy for CPU2
[ 0.121024] Invalid sched_group_energy for Cluster2
[ 0.121503] Invalid sched_group_energy for CPU1
[ 0.121935] Invalid sched_group_energy for Cluster1
[ 0.122398] Invalid sched_group_energy for CPU0
[ 0.122848] Invalid sched_group_energy for Cluster0
[ 0.124414] devtmpfs: initialized
[ 0.160148] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.161135] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.162500] pinctrl core: initialized pinctrl subsystem
[ 0.164882] NET: Registered protocol family 16
[ 0.171475] cpuidle: using governor ladder
[ 0.175516] cpuidle: using governor menu
[ 0.175931] Registered FIQ tty driver
[ 0.177010] vdso: 2 pages (1 code @ ffffff8008776000, 1 data @ ffffff8008ab4000)
[ 0.177770] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.179139] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.225019] genirq: Setting trigger mode 8 for irq 168 failed (gic_set_type+0x0/0x64)
[ 0.229984] console [ttyFIQ0] enabled
[ 0.230663] bootconsole [uart0] disabled
[ 0.231863] Registered fiq debugger ttyFIQ0
[ 0.250584] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[ 0.256995] iommu: Adding device ff440000.hevc_service to group 0
[ 0.257725] iommu: Adding device ff442000.vpu_service to group 1
[ 0.258411] iommu: Adding device ff460000.vop to group 2
[ 0.259059] iommu: Adding device ff470000.vop to group 3
[ 0.259681] iommu: Adding device ff4a0000.rk_isp to group 4
[ 0.261337] rk_iommu ff440440.iommu: can't get sclk
[ 0.262456] rk_iommu ff442800.iommu: can't get sclk
[ 0.263348] rk_iommu ff460f00.iommu: can't get sclk
[ 0.264170] rk_iommu ff470f00.iommu: can't get sclk
[ 0.265145] rk_iommu ff4a8000.iommu: can't get sclk
[ 0.266498] SCSI subsystem initialized
[ 0.267338] pps_core: LinuxPPS API ver. 1 registered
[ 0.267793] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.268674] PTP clock support registered
[ 0.271203] Advanced Linux Sound Architecture Driver Initialized.
[ 0.273591] rockchip-cpuinfo cpuinfo: Serial : 0e11f306a351ad7c
[ 0.275417] clocksource: Switched to clocksource arch_sys_counter
[ 0.370241] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.371550] NET: Registered protocol family 2
[ 0.372996] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.373837] TCP bind hash table entries: 8192 (order: 6, 262144 bytes)
[ 0.374933] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.375694] UDP hash table entries: 512 (order: 3, 49152 bytes)
[ 0.376320] UDP-Lite hash table entries: 512 (order: 3, 49152 bytes)
[ 0.377450] NET: Registered protocol family 1
[ 0.378564] RPC: Registered named UNIX socket transport module.
[ 0.379107] RPC: Registered udp transport module.
[ 0.379565] RPC: Registered tcp transport module.
[ 0.379988] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.381227] Trying to unpack rootfs image as initramfs...
[ 1.286339] Freeing initrd memory: 9160K
[ 1.287885] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 1.294892] Initialise system trusted keyring
[ 1.313986] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.316343] NFS: Registering the id_resolver key type
[ 1.316923] Key type id_resolver registered
[ 1.317314] Key type id_legacy registered
[ 1.317851] ntfs: driver 2.1.32 [Flags: R/W DEBUG].
[ 1.318856] fuse init (API version 7.23)
[ 1.320120] SGI XFS with security attributes, no debug enabled
[ 1.326597] NET: Registered protocol family 38
[ 1.327045] Key type asymmetric registered
[ 1.327455] Asymmetric key parser 'x509' registered
[ 1.328315] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 1.329017] io scheduler noop registered
[ 1.329411] io scheduler deadline registered
[ 1.330092] io scheduler cfq registered (default)
[ 1.333040] phy phy-ff2c0000.syscon:usb2-phy@100.1: Failed to get VBUS supply regulator
[ 1.340719] rk-vcodec vpu_combo: no regulator for vcodec
[ 1.341824] rk-vcodec vpu_combo: failed on clk_get clk_cabac
[ 1.342580] platform ff442000.vpu_service: probe device
[ 1.343611] platform ff442000.vpu_service: drm allocator with mmu enabled
[ 1.345669] platform ff440000.hevc_service: probe device
[ 1.346799] platform ff440000.hevc_service: drm allocator with mmu enabled
[ 1.348508] rk-vcodec vpu_combo: could not find power_model node
[ 1.349060] rk-vcodec vpu_combo: init success
[ 1.356067] dma-pl330 ff240000.dmac: Loaded driver for PL330 DMAC-241330
[ 1.356721] dma-pl330 ff240000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 1.358184] rockchip-pvtm ff010000.syscon:pmu-pvtm: failed to get rst 0 pmu
[ 1.359156] rockchip-pvtm ff148000.syscon:pvtm: failed to get rst 0 core
[ 1.361168] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 1.480444] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 1.482309] ff030000.serial: ttyS0 at MMIO 0xff030000 (irq = 10, base_baud = 6250000) is a 16550A
[ 1.484465] ff158000.serial: ttyS1 at MMIO 0xff158000 (irq = 13, base_baud = 2500000) is a 16550A
[ 1.486525] ff168000.serial: ttyS3 at MMIO 0xff168000 (irq = 14, base_baud = 6250000) is a 16550A
[ 1.491776] [drm] Initialized drm 1.1.0 20060810
[ 1.494744] [drm] Rockchip DRM driver version: v1.0.1
[ 1.496577] Unable to detect cache hierarchy for CPU 0
[ 1.498826] brd: module loaded
[ 1.511570] loop: module loaded
[ 1.513213] zram: Added device: zram0
[ 1.513645] lkdtm: No crash points registered, enable through debugfs
[ 1.518118] rk_gmac-dwmac ff360000.ethernet: clock input or output? (output).
[ 1.518817] rk_gmac-dwmac ff360000.ethernet: Can not read property: tx_delay.
[ 1.519486] rk_gmac-dwmac ff360000.ethernet: set tx_delay to 0x30
[ 1.520041] rk_gmac-dwmac ff360000.ethernet: Can not read property: rx_delay.
[ 1.520706] rk_gmac-dwmac ff360000.ethernet: set rx_delay to 0x10
[ 1.521278] rk_gmac-dwmac ff360000.ethernet: integrated PHY? (no).
[ 1.522274] ERROR: could not get clock /ethernet@ff360000:clk_mac_refout(4)
[ 1.522936] rk_gmac-dwmac ff360000.ethernet: cannot get clock clk_mac_refout
[ 1.528727] rk_gmac-dwmac ff360000.ethernet: init for RMII
[ 1.529469] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.529924] Ring mode enabled
[ 1.530209] DMA HW capability register supported
[ 1.530639] Normal descriptors
[ 1.530948] RX Checksum Offload Engine supported (type 2)
[ 1.531455] TX Checksum insertion supported
[ 1.531840] Wake-Up On Lan supported
[ 1.532254] Enable RX Mitigation via HW Watchdog Timer
[ 1.644374] libphy: stmmac: probed
[ 1.644724] eth%d: PHY ID 001cc816 at 0 IRQ POLL (stmmac-0:00) active
[ 1.648504] ff300000.usb supply vusb_d not found, using dummy regulator
[ 1.649257] ff300000.usb supply vusb_a not found, using dummy regulator
[ 1.652197] dwc2 ff300000.usb: Configuration mismatch. dr_mode forced to device
[ 1.652910] dwc2 ff300000.usb: 128 invalid for host_nperio_tx_fifo_size. Check HW configuration.
[ 1.653711] dwc2 ff300000.usb: 256 invalid for host_perio_tx_fifo_size. Check HW configuration.
[ 1.654574] dwc2 ff300000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[ 1.659337] i2c /dev entries driver
[ 1.660985] IR NEC protocol handler initialized
[ 1.661431] IR RC5(x/sz) protocol handler initialized
[ 1.661897] IR RC6 protocol handler initialized
[ 1.662320] IR JVC protocol handler initialized
[ 1.662759] IR Sony protocol handler initialized
[ 1.663192] IR SANYO protocol handler initialized
[ 1.663643] IR Sharp protocol handler initialized
[ 1.664079] IR MCE Keyboard/mouse protocol handler initialized
[ 1.664631] IR XMP protocol handler initialized
[ 1.667866] Boot mode: coldboot
[ 1.669638] rockchip-thermal ff280000.tsadc: Missing tshut mode property, using default (cru)
[ 1.670465] rockchip-thermal ff280000.tsadc: Missing tshut-polarity property, using default (low)
[ 1.671464] rk_tsadcv2_temp_to_code: Invalid conversion table: code=4095, temperature=2147483647
[ 1.672634] rockchip-thermal ff280000.tsadc: tsadc is probed successfully!
[ 1.675045] cpu cpu0: bin=0
[ 1.675389] cpu cpu0: leakage=25
[ 1.675816] cpu cpu0: Failed to get reg
[ 1.676197] cpu cpu0: bin-scale=13
[ 1.678163] Synopsys Designware Multimedia Card Interface Driver
[ 1.680251] dwmmc_rockchip ff390000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.680978] dwmmc_rockchip ff390000.dwmmc: Using internal DMA controller.
[ 1.681623] dwmmc_rockchip ff390000.dwmmc: Version ID is 270a
[ 1.682223] dwmmc_rockchip ff390000.dwmmc: DW MMC controller at irq 24,32 bit host data width,256 deep fifo
[ 1.683269] dwmmc_rockchip ff390000.dwmmc: No vmmc regulator found
[ 1.683855] dwmmc_rockchip ff390000.dwmmc: No vqmmc regulator found
[ 1.697851] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.711497] dwmmc_rockchip ff390000.dwmmc: 1 slots initialized
[ 1.714250] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.716916] rockchip,bus bus-apll: failed to get bus regulator
[ 1.717487] rockchip,bus bus-apll: failed to init power control
[ 1.719500] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[ 1.722139] rockchip-saradc ff288000.saradc: failed to get regulator, -517
[ 1.729611] Initializing XFRM netlink socket
[ 1.731548] NET: Registered protocol family 10
[ 1.734092] sit: IPv6 over IPv4 tunneling driver
[ 1.735698] NET: Registered protocol family 17
[ 1.736152] NET: Registered protocol family 15
[ 1.736714] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.737739] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.738596] Key type dns_resolver registered
[ 1.740381] Registered cp15_barrier emulation handler
[ 1.741021] Registered setend emulation handler
[ 1.743637] Loading compiled-in X.509 certificates
[ 1.746335] rga2: Driver loaded successfully ver:4.00
[ 1.747320] rga2: Module initialized.
[ 1.750730] rockchip,bus bus-apll: failed to get bus regulator
[ 1.751267] rockchip,bus bus-apll: failed to init power control
[ 1.752510] rockchip-dmc dmc: Cannot get the regulator "center"
[ 1.753924] rockchip-saradc ff288000.saradc: failed to get regulator, -517
[ 1.756573] hctosys: unable to open rtc device (rtc0)
[ 1.777402] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 1.787313] vcc_mipi: disabling
[ 1.787665] dvdd_1v2: disabling
[ 2.691915] dwmmc_rockchip ff390000.dwmmc: Successfully tuned phase to 158
[ 2.693931] mmc0: new HS200 MMC card at address 0001
[ 2.695999] mmcblk0: mmc0:0001 4FTE4R 3.64 GiB
[ 2.697160] mmcblk0boot0: mmc0:0001 4FTE4R partition 1 4.00 MiB
[ 2.699084] mmcblk0boot1: mmc0:0001 4FTE4R partition 2 4.00 MiB
[ 2.700726] mmcblk0rpmb: mmc0:0001 4FTE4R partition 3 512 KiB
[ 2.712033] mmcblk0: p1 p2 p3 p4 p5
[ 2.721127] rockchip,bus bus-apll: failed to get bus regulator
[ 2.721703] rockchip,bus bus-apll: failed to init power control
[ 2.722883] rockchip-dmc dmc: Cannot get the regulator "center"
[ 2.724303] rockchip-saradc ff288000.saradc: failed to get regulator, -517
[ 2.743849] vendor storage:20190527 ret = 0
u? 2.789079]
Unhandled Exception in EL3.
x30 = 0xUnhandled Exception in EL3.
i30 = 0xUnhandld Exception in EL3n
x30 = 0xUnhan0led Exception in E3.
x30 = 0xUnhaUnhandled Excepti n in EL3.
x30 = ?xUnhandled Excepeion in EL3.
x30 = 0xUnhandled ExcUnhandled Exceptin in EL3.
x30 = 0Unhandled Exceptin in EL3.
x30 = 0?Unhandled Excepton in EL3.
x30 = ?xUnhandled ExcepUnhandled Exceptinn in EL3.
x30 = ?xUnhandled ExcepUnhandled ExceptUnhandled Excepti n in EL3.
x30 = 0?Unhandled ExcepUnhandled Exceptinn in EL3.
x30 = 0Unhandled Excepton in EL3.
x30 = Unhandled Exception in EL3.
x30 = xUnhandled Exception in EL3.
x30 = 0xUnhandled Excetion in EL3.
x30 =? 0xUnhandled Exeption in EL3.
x30Unhandled Exceptinn in EL3.
x30 = 0xUnhandled ExcepUnhandled ExceptiUnhandled Exceptin in EL3.
x30 = 0Unhandled Exceptdon in EL3.
x30 = ?0xUnhandled Excetion in EL3.
x30 = 0xUnhandled Exceltion in EL3.
x30 0xUnhandled Exeption in EL3.
x30Unhandled Excepti n in EL3.
x30 = Unhandled Exceptin in EL3.
x30 = 0Unhandled Exception in EL3.
x30 = xUnhandled Excepeion in EL3.
x30 = ?0xUnhandled Excextion in EL3.
x30 ? 0xUnhandled Exneption in EL3.
x30= 0xUnhandled Exneption in EL3.
x3Unhandled Excepti n in EL3.
x30 = xUnhandled Excepion in EL3.
x30 = ?0xUnhandled Excption in EL3.
x30 ? 0xUnhandled Exception in EL3.
x3? = 0xUnhandled ?xception in EL3.
x?0 = 0xUnhandleU Exception in EL3. x30 = 0xUnhandlUnhandled Excepti n in EL3.
x30 0xUnhandled Exneption in EL3.
x30 = xUnhandled ExcepUnhandled Exceptin in EL3.
x30 = 0?Unhandled Exceptdon in EL3.
x30 = Unhandled Excepton in EL3.
x30 = Unhandled Excepti n in EL3.
x30 = 0xUnhandled Excepeion in EL3.
x30 =Unhandled Excepti n in EL3.
x30 Unhandled Excepti n in EL3.
x30 = ?xUnhandled Excepion in EL3.
x30 = 0?Unhandled ExceptUon in EL3.
x30 =! 0xUnhandled Exception in EL3.
x30 0xUnhandled Excption in EL3.
x30Unhandled Excepton in EL3.
x30 = 0xUnhandled ExceUnhandled Exceptinn in EL3.
x30 = 0xUnhandled ExcepUnhandled ExceptUnhandled Exception in EL3.
x30 =? 0xUnhandled Excption in EL3.
x3? = 0xUnhandled hxception in EL3.
x?0 = 0xUnhandlednException in EL3.
x30 = 0xUnhanled Exception in EL3.
x30 = 0xUnhandled Exception in tL3.
x30 = 0xUnhndled Exception inUnhandled Excepti n in EL3.
x30 = 0?Unhandled ExcepUnhandled Exceptin in EL3.
x30 = 0?Unhandled Excepion in EL3.
x30 = 0xUnhandled Excdption in EL3.
x30Unhandled Exceptin in EL3.
x30 = ?0xUnhandled Exceltion in EL3.
x30 =Unhandled Exceptinn in EL3.
x30Unhandled Exception in EL3.
x30 = 0?Unhandled ExceptUnhandled Exception in EL3.
x30 = xUnhandled ExcepUnhandled Excepton in EL3.
x30 = 0xUnhandled Excepton in EL3.
x30 = ?xUnhandled ExceUnhandled Excepti n in EL3.
x30 = xUnhandled Exceptdon in EL3.
x3Unhandled ExceptUnhandled Exception in EL3.
x30 = ?xUnhandled Excetion in EL3.
x30?= 0xUnhandled Eaception in EL3.
x3 = 0xUnhandled hxception in EL3.
30 = 0xUnhandleUnhandled Exceptinn in EL3.
x30 = 0xUnhandled Excepion in EL3.
x30 = 0xUnhandled Excption in EL3.
x30 Unhandled Exceptinn in EL3.
x30 =? 0xUnhandled Exc0ption in EL3.
x30 = Unhandled Excepion in EL3.
x30= 0xUnhandled Eception in EL3.
x30 = ?xUnhandled Excep?ion in EL3.
x30 =? 0xUnhandled Excdption in EL3.
x30 ? 0xUnhandled ExUnhandled Excepti n in EL3.
x30 = 0xUnhandledException in EL3.
x30 = 0xUnhandled Exception Unhandled Excepton in EL3.
x3Unhandled Exceptin in EL3.
x30 = xUnhandled ExcepUnhandled ExceptioE in EL3.
x3 = 0xUnhandled Eaception in EL3.
x30 Unhandled Exceptin in EL3.
x30 = 0xUnhanUnhandled Exception in EL3.
x30 = xUnhandled ExcepUnhandled Excepti n in EL3.
x30 = 0xUnhandled EUnhandled ExceptUnhandled Exception in EL3.
x30 =Unhandled Exception in EL3.
x30 = 0xUnhandled ExceUnhandled Exceptin in EL3.
x30 = 0Unhandled ExceptUnhandled Exceptinn in EL3.
x30 = 0xUnhandled ExcUnhandled Excepti n in EL3.
x30 = ?xUnhandled ExcepUnhandled Excepton in EL3.
x30 = 0xnhandled ExceptionUnhandled Exceptin in EL3.
x30 =? 0xUnhandled ExcUnhandled Exceptinn in EL3.
x30 0xUnhandled Exc0ption in EL3.
x30 Unhandled ExceptioE in EL3.
x3 = 0xUnhandled xception in EL3.
x30 = 0xUnhandlenException in EL3.
i30 = 0xUnhandle? Exception in EL3. x30 = 0xUnhandld Exception in EL3Unhandled Exceptin in EL3.
x30 = 0xUnhandled ExcepUnhandled Excepti n in EL3.
x30 =Unhandled Exceptin in EL3.
x30 0xUnhandled ExUnhandled Excepti n in EL3.
x3? = 0xUnhandled Unhandled Excepti n in EL3.
x30 Unhandled Exception in EL3.
x30 = ?xUnhandled ExcepUnhandled Excepti n in EL3.
x30 = ?xUnhandled Exception in EL3.
x30 Unhandled Excepton in EL3.
x30 ? 0xUnhandled Exeption in EL3.
x30?= 0xUnhandled xception in EL3.
Unhandled ExceptiUnhandled Exception in EL3.
x30 =? 0xUnhandled Exception in EL3.
x30 = 0xUnhandled Exneption in EL3.
x30 = 0xUnhandled E?ception in EL3.
x?0 = 0xUnhandledException in EL3.
i30 = 0xUnhandle Exception in EL3.
i30 = 0xUnhandleU Exception in EL3. x30 = 0xUnhandlUnhandled Excepton in EL3.
x30 = 0x
如题,使用PX30 SDK,在启动文件系统之前kernel一直挂在EL3,请教可能是哪里问题呢?
