目前SDK使用firefly官方的sdk,分区之前是可以起来的,目前log信息如下:
[BEGIN] 2021/3/26 11:08:47
DDR Version 1.09 20201119
Channel a: DDR3 400MHz
Channel b: DDR3 400MHz
Memory OK
Memory OK
Boot1 Release Time: Nov 27 2019 15:30:08, version: 2.58
ChipType = 0x8, 252
mmc2:cmd19,100
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=14910MB
FwPartOffset=2000 , 2000
mmc0:cmd8,400
mmc0:cmd8,400
mmc0:cmd8,400
SdmmcInit=0 1
StorageInit ok = 26555
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
atags_set_bootdev: ret:(0)
GPT part: 2, name: misc, start:0x8000, size:0x2000
GPT part: 3, name: boot, start:0xa000, size:0x10000
GPT part: 4, name: recovery, start:0x1a000, size:0x10000
GPT part: 5, name: backup, start:0x2a000, size:0x10000
GPT part: 6, name: rootfs, start:0x5a000, size:0x3fe800
GPT part: 7, name: userdata, start:0x458800, size:0x18c67df
find part:uboot OK. first_lba:0x4000.
find part:trust OK. first_lba:0x6000.
LOADER Check OK! 0x4000, 138446
TOS Check OK! 0x6000, 174846
Enter Trust OS
INF [0x0] TEE-CORE:init_primary_helper:385: Core0 Initializing (1.1.0-432-gc99a453d #4 Mon Aug 17 09:16:49 UTC 2020 arm)
INF [0x0] TEE-CORE:init_primary_helper:386: Release version: 1.3
INF [0x0] TEE-CORE:init_primary_helper:387: Next entry point address: 0x200000
U-Boot 2017.09-g01c726e03f #xkkj (Mar 26 2021 - 10:22:11 +0800)
Model: Firefly-RK3288
PreSerial: 2
DRAM: 2 GiB
Sysmem: init
Relocation Offset: 00000000, fdt: 7be30878
dwmmc@ff0c0000: 1, dwmmc@ff0f0000: 0
Bootdev(atags): mmc 0
MMC0: High Speed, 52Mhz
PartType: EFI
boot mode: None
Found DTB in boot part
DTB: rk-kernel.dtb
HASH(s): OK
I2c0 speed: 400000Hz
vdd_log 1100000 uV
*** Warning - bad CRC, using default environment
In: serial@ff690000
Out: serial@ff690000
Err: serial@ff690000
Model: AIO-3288J Board (Linux Opensource)
xfer: num: 2, addr: 0x50
Monitor has basic audio support
mode:1920x1080
CEA mode used vic=16
final pixclk = 148500000 tmdsclk = 148500000
PHY powered down in 0 iterations
PHY PLL locked 1 iterations
sink has audio support
hdmi_set_clk_regenerator: fs=48000Hz ftdms=148.500MHz N=6144 cts=148500
CLK: (uboot. arm: enter 1000000 KHz, init 1000000 KHz, kernel 0N/A)
apll 1000000 KHz
dpll 396000 KHz
cpll 742000 KHz
gpll 594000 KHz
npll 24000 KHz
aclk_bus 297000 KHz
Net: eth0: ethernet@ff290000
Booting ZIMAGE kernel at 0x02008000(Uncompress to 0) with fdt at 0x08300000…
Fdt Ramdisk skip relocation
## Booting Android Image at 0x02007800 …
Kernel load addr 0x02008000 size 8046 KiB
RAM disk load addr 0x0a200000 size 8946 KiB
## Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
XIP Kernel Image from 0x02008000 to 0x02008000 … OK
‘reserved-memory’ dma-unusable@fe000000: addr=fe000000 size=1000000
‘reserved-memory’ ramoops@00000000: addr=8000000 size=f0000
Using Device Tree in place at 08300000, end 08316fbf
No file: logo_kernel.bmp
Adding bank: 0x00000000 - 0x08400000 (size: 0x08400000)
Adding bank: 0x09310000 - 0x80000000 (size: 0x76cf0000)
Total: 5032.991 ms
[ 0.000000] Linux version 4.4.194 (xkkj@ubuntu) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #1 SMP Wed Mar 17 17:55:13 CST 2021
[ 0.000000] Machine model: AIO-3288J Board (Linux Opensource)
[ 0.000000] cma: Reserved 16 MiB at 0x7f000000
[ 0.000000] psci: PSCIv65535.65535 detected in firmware.
[ 0.000000] PERCPU: Embedded 14 pages/cpu @eef77000 s24728 r8192 d24424 u57344
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 518896
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.slot_suffix= androidboot.serialno=6a3e94831fab85dc earlyprintk ro rootwait console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdate,fstype=ext4,mkfs=1 swiotlb=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1
[ 0.000000] Memory: 2016740K/2081728K available (12288K kernel code, 1005K rwdata, 3488K rodata, 1024K init, 1258K bss, 48604K reserved, 16384K cma-reserved, 1294068K highmem)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0d00000 (13280 kB)
[ 0.000000] .init : 0xc1200000 - 0xc1300000 (1024 kB)
[ 0.000000] .data : 0xc1300000 - 0xc13fb5ac (1006 kB)
[ 0.000000] .bss : 0xc13fd000 - 0xc1537b90 (1259 kB)
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000009] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000030] Switching to timer-based delay loop, resolution 41ns
[ 0.003999] Console: colour dummy device 80x30
[ 0.004043] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.004068] pid_max: default: 32768 minimum: 301
[ 0.004197] Security Framework initialized
[ 0.004215] Yama: becoming mindful.
[ 0.004307] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.004330] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.005487] Initializing cgroup subsys devices
[ 0.005518] Initializing cgroup subsys freezer
[ 0.005564] CPU: Testing write buffer coherency: ok
[ 0.005619] ftrace: allocating 44562 entries in 131 pages
[ 0.138405] CPU0: update cpu_capacity 430
[ 0.138427] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.138527] Setting up static identity map for 0x100000 - 0x100058
[ 0.141835] CPU1: update cpu_capacity 430
[ 0.141845] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.143063] CPU2: update cpu_capacity 430
[ 0.143072] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.144314] CPU3: update cpu_capacity 430
[ 0.144323] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.144485] Brought up 4 CPUs
[ 0.144528] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.144539] CPU: All CPU(s) started in SVC mode.
[ 0.146605] devtmpfs: initialized
[ 0.179237] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.179795] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.179840] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.181364] pinctrl core: initialized pinctrl subsystem
[ 0.182986] NET: Registered protocol family 16
[ 0.187203] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.218611] cpuidle: using governor ladder
[ 0.248660] cpuidle: using governor menu
[ 0.248713] Registered FIQ tty driver
[ 0.303547] console [pstore-1] enabled
[ 0.303561] pstore: Registered ramoops as persistent store backend
[ 0.303576] ramoops: attached 0xf0000@0x8000000, ecc: 0/0
[ 0.304741] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.304761] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.305905] fiq debugger fiq mode enabled
[ 0.789900] console [ttyFIQ0] enabled
[ 0.793961] Registered fiq debugger ttyFIQ0
[ 0.884652] vcc_flash: regulator get failed, ret=-517
[ 0.890505] vcc_sd: regulator get failed, ret=-517
[ 0.896012] vcc28_dvp: regulator get failed, ret=-517
[ 0.901817] dovdd_1v8: regulator get failed, ret=-517
[ 0.910571] iommu: Adding device ff910000.rkisp1 to group 0
[ 0.916351] iommu: Adding device ff930000.vop to group 1
[ 0.921806] iommu: Adding device ff940000.vop to group 2
[ 0.927336] iommu: Adding device ff9a0000.vpu-service to group 3
[ 0.933513] iommu: Adding device ff9c0000.hevc-service to group 4
[ 0.940510] rk_iommu ff914000.iommu: can’t get sclk
[ 0.946050] rk_iommu ff930300.iommu: can’t get sclk
[ 0.951439] rk_iommu ff940300.iommu: can’t get sclk
[ 0.956758] rk_iommu ff9a0800.iommu: can’t get sclk
[ 0.962198] rk_iommu ff9c0440.iommu: can’t get sclk
[ 0.968027] SCSI subsystem initialized
[ 0.972213] usbcore: registered new interface driver usbfs
[ 0.977793] usbcore: registered new interface driver hub
[ 0.983304] usbcore: registered new device driver usb
[ 0.988602] media: Linux media interface: v0.10
[ 0.993259] Linux video capture interface: v2.00
[ 0.998040] pps_core: LinuxPPS API ver. 1 registered
[ 1.003009] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.012213] PTP clock support registered
[ 1.018671] Advanced Linux Sound Architecture Driver Initialized.
[ 1.025855] Bluetooth: Core ver 2.21
[ 1.029496] NET: Registered protocol family 31
[ 1.033946] Bluetooth: HCI device and connection manager initialized
[ 1.040356] Bluetooth: HCI socket layer initialized
[ 1.045246] Bluetooth: L2CAP socket layer initialized
[ 1.050381] Bluetooth: SCO socket layer initialized
[ 1.056924] rockchip-cpuinfo cpuinfo: Serial : 6a3e94831fab85dc
[ 1.064951] clocksource: Switched to clocksource arch_sys_counter
[ 1.155740] NET: Registered protocol family 2
[ 1.161010] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 1.168220] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
[ 1.175073] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.181526] UDP hash table entries: 512 (order: 2, 24576 bytes)
[ 1.187556] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes)
[ 1.194267] NET: Registered protocol family 1
[ 1.199197] RPC: Registered named UNIX socket transport module.
[ 1.205176] RPC: Registered udp transport module.
[ 1.209890] RPC: Registered tcp transport module.
[ 1.214600] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.221406] Trying to unpack rootfs image as initramfs…
[ 1.974769] Freeing initrd memory: 8948K
[ 1.980744] hw perfevents: enabled with armv7_cortex_a12 PMU driver, 7 counters available
[ 1.992453] Initialise system trusted keyring
[ 2.012396] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.021634] NFS: Registering the id_resolver key type
[ 2.026800] Key type id_resolver registered
[ 2.030999] Key type id_legacy registered
[ 2.035098] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 2.042838] fuse init (API version 7.23)
[ 2.055892] NET: Registered protocol family 38
[ 2.060377] Key type asymmetric registered
[ 2.064485] Asymmetric key parser ‘x509’ registered
[ 2.069528] bounce: pool size: 64 pages
[ 2.073689] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 2.081141] io scheduler noop registered
[ 2.085113] io scheduler deadline registered
[ 2.089449] io scheduler cfq registered (default)
[ 2.103321] rk-vcodec ff9a0000.vpu-service: no regulator for vcodec
[ 2.110071] rk-vcodec ff9a0000.vpu-service: probe device
[ 2.115874] rk-vcodec ff9a0000.vpu-service: drm allocator with mmu enabled
[ 2.123876] rk-vcodec ff9a0000.vpu-service: could not find power_model node
[ 2.130901] rk-vcodec ff9a0000.vpu-service: init success
[ 2.136785] rk-vcodec ff9c0000.hevc-service: no regulator for vcodec
[ 2.143621] rk-vcodec ff9c0000.hevc-service: probe device
[ 2.149512] rk-vcodec ff9c0000.hevc-service: drm allocator with mmu enabled
[ 2.157362] rk-vcodec ff9c0000.hevc-service: could not find power_model node
[ 2.164422] rk-vcodec ff9c0000.hevc-service: init success
[ 2.173922] dma-pl330 ff250000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 2.181561] dma-pl330 ff250000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 2.192323] dma-pl330 ff600000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 2.199973] dma-pl330 ff600000.dma-controller: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 2.211182] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 2.219992] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 2.227528] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 37, base_baud = 1500000) is a 16550A
[ 2.237472] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 38, base_baud = 1500000) is a 16550A
[ 2.247436] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 39, base_baud = 1500000) is a 16550A
[ 2.259900] [drm] Initialized drm 1.1.0 20060810
[ 2.272006] [drm] Rockchip DRM driver version: v1.0.1
[ 2.277638] rockchip-drm display-subsystem: devfreq is not set
[ 2.285215] rockchip-drm display-subsystem: bound ff930000.vop (ops 0xc0d671d8)
[ 2.293773] rockchip-drm display-subsystem: bound ff940000.vop (ops 0xc0d671d8)
[ 2.301548] i2c i2c-6: of_i2c: modalias failure on /hdmi@ff980000/ports
[ 2.308227] dwhdmi-rockchip ff980000.hdmi: registered DesignWare HDMI I2C bus driver
[ 2.316145] dwhdmi-rockchip ff980000.hdmi: Detected HDMI TX controller v2.01a with HDCP (DWC HDMI 2.0 TX PHY)
[ 2.327596] rockchip-drm display-subsystem: bound ff980000.hdmi (ops 0xc0d5e120)
[ 2.335055] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.341670] [drm] No driver support for vblank timestamp query.
[ 2.624245] rockchip-drm display-subsystem: fb0: frame buffer device
[ 2.657795] usbcore: registered new interface driver udl
[ 2.668999] mali ffa30000.gpu: Failed to get regulator
[ 2.674158] mali ffa30000.gpu: Power control initialization failed
[ 2.682428] brd: module loaded
[ 2.696364] loop: module loaded
[ 2.700753] zram: Added device: zram0
[ 2.704472] lkdtm: No crash points registered, enable through debugfs
[ 2.712287] rockchip-spi ff110000.spi: no high_speed pinctrl state
[ 2.720503] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[ 2.897617] wk2xxx_serial_init()
[ 2.900860] wk2xxx_request_port
[ 2.904017] ttysWK0 at I/O 0x1 (irq = 81, base_baud = 460800) is a wk2xxx
[ 2.911297] uart_add_one_port success for line i:= 0 with right 0
[ 2.917459] wk2xxx_request_port
[ 2.920619] ttysWK1 at I/O 0x2 (irq = 81, base_baud = 460800) is a wk2xxx
[ 2.927881] uart_add_one_port success for line i:= 1 with right 0
[ 2.933981] wk2xxx_request_port
[ 2.937185] ttysWK2 at I/O 0x3 (irq = 81, base_baud = 460800) is a wk2xxx
[ 2.944381] uart_add_one_port success for line i:= 2 with right 0
[ 2.950525] wk2xxx_request_port
[ 2.953683] ttysWK3 at I/O 0x4 (irq = 81, base_baud = 460800) is a wk2xxx
[ 2.960916] uart_add_one_port success for line i:= 3 with right 0
[ 2.967062] uart_add_one_port = 0x0
[ 2.970614] register spi return v = :0
[ 2.974469] tun: Universal TUN/TAP device driver, 1.6
[ 2.979569] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.988339] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 2.995057] rk_gmac-dwmac ff290000.ethernet: phy regulator is not available yet, deferred probing
[ 3.005819] PPP generic driver version 2.4.2
[ 3.010573] usbcore: registered new interface driver rndis_wlan
[ 3.016956] usbcore: registered new interface driver rt2800usb
[ 3.022918] Rockchip WiFi SYS interface (V1.00) …
[ 3.028030] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 3.035571] usbcore: registered new interface driver pegasus
[ 3.041329] usbcore: registered new interface driver rtl8150
[ 3.047130] usbcore: registered new interface driver r8152
[ 3.052725] usbcore: registered new interface driver asix
[ 3.058250] usbcore: registered new interface driver ax88179_178a
[ 3.064445] usbcore: registered new interface driver cdc_ether
[ 3.070424] usbcore: registered new interface driver dm9601
[ 3.076154] usbcore: registered new interface driver smsc75xx
[ 3.082021] usbcore: registered new interface driver smsc95xx
[ 3.087907] usbcore: registered new interface driver net1080
[ 3.093661] usbcore: registered new interface driver rndis_host
[ 3.099728] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 3.107315] usbcore: registered new interface driver cdc_ncm
[ 3.113072] usbcore: registered new interface driver qmi_wwan
[ 3.118955] usbcore: registered new interface driver cdc_mbim
[ 3.125394] ff540000.usb supply vusb_d not found, using dummy regulator
[ 3.132147] ff540000.usb supply vusb_a not found, using dummy regulator
[ 3.255648] dwc2 ff540000.usb: DWC OTG Controller
[ 3.260402] dwc2 ff540000.usb: new USB bus registered, assigned bus number 1
[ 3.267550] dwc2 ff540000.usb: irq 45, io mem 0xff540000
[ 3.273269] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.280120] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.287377] usb usb1: Product: DWC OTG Controller
[ 3.292094] usb usb1: Manufacturer: Linux 4.4.194 dwc2_hsotg
[ 3.297786] usb usb1: SerialNumber: ff540000.usb
[ 3.303471] hub 1-0:1.0: USB hub found
[ 3.307345] hub 1-0:1.0: 1 port detected
[ 3.312260] ff580000.usb supply vusb_d not found, using dummy regulator
[ 3.319031] ff580000.usb supply vusb_a not found, using dummy regulator
[ 3.336560] dwc2 ff580000.usb: DWC OTG Controller
[ 3.341325] dwc2 ff580000.usb: new USB bus registered, assigned bus number 2
[ 3.348478] dwc2 ff580000.usb: irq 46, io mem 0xff580000
[ 3.354167] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.361009] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.368275] usb usb2: Product: DWC OTG Controller
[ 3.372991] usb usb2: Manufacturer: Linux 4.4.194 dwc2_hsotg
[ 3.378684] usb usb2: SerialNumber: ff580000.usb
[ 3.384371] hub 2-0:1.0: USB hub found
[ 3.388242] hub 2-0:1.0: 1 port detected
[ 3.394525] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 3.401131] ehci-platform: EHCI generic platform driver
[ 3.407034] ehci-platform ff500000.usb: EHCI Host Controller
[ 3.413111] ehci-platform ff500000.usb: new USB bus registered, assigned bus number 3
[ 3.421286] ehci-platform ff500000.usb: irq 43, io mem 0xff500000
[ 3.445014] ehci-platform ff500000.usb: USB 2.0 started, EHCI 1.00
[ 3.451531] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.458380] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.465647] usb usb3: Product: EHCI Host Controller
[ 3.470533] usb usb3: Manufacturer: Linux 4.4.194 ehci_hcd
[ 3.476056] usb usb3: SerialNumber: ff500000.usb
[ 3.481648] hub 3-0:1.0: USB hub found
[ 3.485719] hub 3-0:1.0: 1 port detected
[ 3.490762] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 3.497035] ohci-platform: OHCI generic platform driver
[ 3.502680] ohci-platform ff520000.usb: Generic Platform OHCI controller
[ 3.509988] ohci-platform ff520000.usb: new USB bus registered, assigned bus number 4
[ 3.518098] ohci-platform ff520000.usb: irq 44, io mem 0xff520000
[ 3.579365] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.586237] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.593471] usb usb4: Product: Generic Platform OHCI controller
[ 3.599440] usb usb4: Manufacturer: Linux 4.4.194 ohci_hcd
[ 3.604971] usb usb4: SerialNumber: ff520000.usb
[ 3.611442] hub 4-0:1.0: USB hub found
[ 3.615319] hub 4-0:1.0: 1 port detected
[ 3.620410] usbcore: registered new interface driver cdc_acm
[ 3.626145] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 3.634415] usbcore: registered new interface driver cdc_wdm
[ 3.640334] usbcore: registered new interface driver usb-storage
[ 3.646568] usbcore: registered new interface driver usbserial
[ 3.652487] usbcore: registered new interface driver usbserial_generic
[ 3.659106] usbserial: USB Serial support registered for generic
[ 3.665267] usbcore: registered new interface driver ch341
[ 3.670830] usbserial: USB Serial support registered for ch341-uart
[ 3.677257] usbcore: registered new interface driver cp210x
[ 3.682889] usbserial: USB Serial support registered for cp210x
[ 3.688952] usb 1-1: new high-speed USB device number 2 using dwc2
[ 3.695173] usbcore: registered new interface driver ftdi_sio
[ 3.695235] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 3.695516] usbcore: registered new interface driver keyspan
[ 3.695571] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 3.695621] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 3.695670] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 3.695720] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 3.695825] usbcore: registered new interface driver option
[ 3.695878] usbserial: USB Serial support registered for GSM modem (1-port)
[ 3.696238] usbcore: registered new interface driver oti6858
[ 3.696291] usbserial: USB Serial support registered for oti6858
[ 3.696401] usbcore: registered new interface driver pl2303
[ 3.696457] usbserial: USB Serial support registered for pl2303
[ 3.696569] usbcore: registered new interface driver qcserial
[ 3.696622] usbserial: USB Serial support registered for Qualcomm USB modem
[ 3.696747] usbcore: registered new interface driver sierra
[ 3.696800] usbserial: USB Serial support registered for Sierra USB modem
[ 3.698839] usbcore: registered new interface driver iforce
[ 3.698991] usbcore: registered new interface driver xpad
[ 3.699135] ==gsl_ts_init==
[ 3.699197] ret=0
[ 3.699689] usbcore: registered new interface driver usbtouchscreen
[ 3.700054] .. rk pwm remotectl v1.1 init
[ 3.700533] input: ff680000.pwm as /devices/platform/ff680000.pwm/input/input0
[ 3.701345] sensor_register_slave:mma8452,id=17
[ 3.701363] sensor_register_slave:lis3dh,id=7
[ 3.701378] sensor_register_slave:mma7660,id=18
[ 3.701392] sensor_register_slave:lsm303d,id=23
[ 3.701405] sensor_register_slave:gs_mc3230,id=24
[ 3.701408] [Gsensor] gsensor_init
[ 3.701423] sensor_register_slave:mpu6880_acc,id=25
[ 3.701437] sensor_register_slave:mpu6500_acc,id=26
[ 3.701452] sensor_register_slave:lsm330_acc,id=27
[ 3.701466] sensor_register_slave:akm8975,id=31
[ 3.701480] sensor_register_slave:akm8963,id=32
[ 3.701495] sensor_register_slave:l3g4200d,id=46
[ 3.701509] sensor_register_slave:l3g20d,id=47
[ 3.701522] sensor_register_slave:ewtsa,id=48
[ 3.701536] sensor_register_slave:lsm330_gyro,id=52
[ 3.701550] sensor_register_slave:cm3217,id=54
[ 3.701564] sensor_register_slave:cm3218,id=55
[ 3.702818] i2c /dev entries driver
[ 3.705002] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 3.705141] fan53555-reg: supplied by vcc_sys
[ 3.708593] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 3.708691] fan53555-reg: supplied by vcc_sys
[ 3.715524] rtc-hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 3.717042] REG1: supplied by vcc_sys
[ 3.718606] REG2: supplied by vcc_sys
[ 3.719932] vcc_flash: supplied by vcc_io
[ 3.720220] vcc_sd: supplied by vcc_io
[ 3.720481] vcc28_dvp: supplied by vcc_io
[ 3.720814] dovdd_1v8: supplied by vcc28_dvp
[ 3.720982] REG3: supplied by vcc_sys
[ 3.722549] REG4: supplied by vcc_sys
[ 3.723922] REG5: supplied by vcc_sys
[ 3.725599] REG6: supplied by vcc_sys
[ 3.726985] REG7: supplied by vcc_sys
[ 3.728385] REG8: supplied by vcc_sys
[ 3.729775] REG9: supplied by vcc_sys
[ 3.731144] REG10: supplied by vcc_20
[ 3.732638] REG11: supplied by vcc_20
[ 3.734144] REG12: supplied by vcc_20
[ 3.735670] rk3x-i2c ff650000.i2c: Initialized RK3xxx I2C bus at f12d4000
[ 3.736853] rk3x-i2c ff150000.i2c: Initialized RK3xxx I2C bus at f12d6000
[ 3.737901] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at f12d8000
[ 3.739215] rk3x-i2c ff660000.i2c: Initialized RK3xxx I2C bus at f12da000
[ 3.741853] rkisp1 ff910000.rkisp1: rkisp1 driver version: v00.01.05
[ 3.741898] rkisp1 ff910000.rkisp1: Missing rockchip,grf property
[ 3.745502] usbcore: registered new interface driver uvcvideo
[ 3.745506] USB Video Class driver (1.1.1)
[ 3.750469] Boot mode: coldboot
[ 3.751768] rockchip-thermal ff280000.tsadc: Missing rockchip,grf property
[ 3.751881] rk_tsadcv2_temp_to_code: Invalid conversion table: code=4095, temperature=2147483647
[ 3.752162] rockchip-thermal ff280000.tsadc: tsadc is probed successfully!
[ 3.754006] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 3.754336] Bluetooth: Virtual HCI driver ver 1.5
[ 3.754611] Bluetooth: HCI UART driver ver 2.3
[ 3.754620] Bluetooth: HCI UART protocol H4 registered
[ 3.754625] Bluetooth: HCI UART protocol LL registered
[ 3.754630] Bluetooth: HCI UART protocol ATH3K registered
[ 3.754767] usbcore: registered new interface driver bfusb
[ 3.754890] usbcore: registered new interface driver btusb
[ 3.755634] cpu cpu0: bin=1
[ 3.755839] cpu cpu0: leakage=13
[ 3.768608] cpu cpu0: temp=36818, pvtm=15943 (15961 + -18)
[ 3.768670] rockchip_cpuclk_pre_rate_change: Invalid rate : 500000000 for cpuclk
[ 3.768718] cpu cpu0: pvtm-volt-sel=1
[ 3.768841] cpu cpu0: bin-scale=25
[ 3.771679] cpu cpu0: avs=0
[ 3.771812] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[ 3.771838] cpu cpu0: failed to read out thermal zone (-22)
[ 3.773705] cpu cpu0: failed to find power_model node
[ 3.774182] sdhci: Secure Digital Host Controller Interface driver
[ 3.774186] sdhci: Copyright(c) Pierre Ossman
[ 3.774197] Synopsys Designware Multimedia Card Interface Driver
[ 3.776034] dwmmc_rockchip ff0c0000.dwmmc: IDMAC supports 32-bit address mode.
[ 3.776147] dwmmc_rockchip ff0c0000.dwmmc: Using internal DMA controller.
[ 3.776167] dwmmc_rockchip ff0c0000.dwmmc: Version ID is 270a
[ 3.776249] dwmmc_rockchip ff0c0000.dwmmc: DW MMC controller at irq 29,32 bit host data width,256 deep fifo
[ 3.776290] dwmmc_rockchip ff0c0000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 3.895322] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 3.895448] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 3.907981] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 3.920584] dwmmc_rockchip ff0c0000.dwmmc: 1 slots initialized
[ 3.920886] dwmmc_rockchip ff0d0000.dwmmc: IDMAC supports 32-bit address mode.
[ 3.920916] dwmmc_rockchip ff0d0000.dwmmc: Using internal DMA controller.
[ 3.920924] dwmmc_rockchip ff0d0000.dwmmc: Version ID is 270a
[ 3.920947] dwmmc_rockchip ff0d0000.dwmmc: DW MMC controller at irq 30,32 bit host data width,256 deep fifo
[ 3.920956] dwmmc_rockchip ff0d0000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 3.920980] dwmmc_rockchip ff0d0000.dwmmc: No vmmc regulator found
[ 3.920983] dwmmc_rockchip ff0d0000.dwmmc: No vqmmc regulator found
[ 3.921121] dwmmc_rockchip ff0d0000.dwmmc: allocated mmc-pwrseq
[ 3.933745] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 3.944974] dwmmc_rockchip ff0d0000.dwmmc: 1 slots initialized
[ 3.945269] dwmmc_rockchip ff0f0000.dwmmc: IDMAC supports 32-bit address mode.
[ 3.945297] dwmmc_rockchip ff0f0000.dwmmc: Using internal DMA controller.
[ 3.945305] dwmmc_rockchip ff0f0000.dwmmc: Version ID is 270a
[ 3.945326] dwmmc_rockchip ff0f0000.dwmmc: DW MMC controller at irq 31,32 bit host data width,256 deep fifo
[ 3.945335] dwmmc_rockchip ff0f0000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 3.945356] dwmmc_rockchip ff0f0000.dwmmc: No vmmc regulator found
[ 3.945358] dwmmc_rockchip ff0f0000.dwmmc: No vqmmc regulator found
[ 3.957992] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 3.970587] dwmmc_rockchip ff0f0000.dwmmc: 1 slots initialized
[ 3.970770] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.971239] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.971725] usbcore: registered new interface driver usbhid
[ 3.971727] usbhid: USB HID core driver
[ 3.971897] ashmem: initialized
[ 3.972337] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[ 3.973295] rknandbase v1.2 2018-05-08
[ 3.973707] usbcore: registered new interface driver snd-usb-audio
[ 3.976718] u32 classifier
[ 3.976724] Netfilter messages via NETLINK v0.30.
[ 3.976761] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 3.976962] ctnetlink v0.93: registering with nfnetlink.
[ 3.977026] ip_set: protocol 6
[ 3.977033] IPVS: Registered protocols ()
[ 3.977059] IPVS: Connection hash table configured (size=4096, memory=32Kbytes)
[ 3.977123] IPVS: Creating netns size=1104 id=0
[ 3.977145] IPVS: ipvs loaded.
[ 3.977346] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.977453] Initializing XFRM netlink socket
[ 3.977907] NET: Registered protocol family 10
[ 3.978396] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.978529] sit: IPv6 over IPv4 tunneling driver
[ 3.978863] NET: Registered protocol family 17
[ 3.978877] NET: Registered protocol family 15
[ 3.978900] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 3.978917] Bridge firewalling registered
[ 3.978978] Bluetooth: RFCOMM socket layer initialized
[ 3.978992] Bluetooth: RFCOMM ver 1.11
[ 3.979002] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.979007] Bluetooth: HIDP socket layer initialized
[ 3.979043] 8021q: 802.1Q VLAN Support v1.8
[ 3.979057] lib80211: common routines for IEEE802.11 drivers
[ 3.979079] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 3.979245] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 3.979265] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6212
[ 3.979267] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 3.979269] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 3.979302] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 150, flags = 0.
[ 3.979306] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 3.979308] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 3.979311] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 3.979356] [BT_RFKILL]: Enter rfkill_rk_init
[ 3.979615] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 139.
[ 3.979632] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 149.
[ 3.979644] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 146.
[ 3.979655] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 151.
[ 3.979658] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[ 3.979706] [BT_RFKILL]: Request irq for bt wakeup host
[ 3.979751] [BT_RFKILL]: ** disable irq
[ 3.979853] [BT_RFKILL]: bt_default device registered.
[ 3.979901] Key type dns_resolver registered
[ 3.979975] sensor_register_slave:mpu6880_gyro,id=51
[ 3.980052] ov13850 3-0010: driver version: 00.01.03
[ 3.980290] ov13850 3-0010: could not get default pinstate
[ 3.980293] ov13850 3-0010: could not get sleep pinstate
[ 3.982144] ov13850 3-0010: Unexpected sensor id(000000), ret(-5)
[ 3.982868] ThumbEE CPU extension supported.
[ 3.982879] Registering SWP/SWPB emulation handler
[ 3.983289] Loading compiled-in X.509 certificates
[ 3.983839] rga2: Driver loaded successfully ver:3.00
[ 3.983948] rga2: Module initialized.
[ 3.984526] mali ffa30000.gpu: bin=0
[ 3.984538] mali ffa30000.gpu: Failed to get leakage
[ 3.984688] mali ffa30000.gpu: Failed to get pvtm
[ 3.984699] mali ffa30000.gpu: bin-scale=55
[ 3.984887] mali ffa30000.gpu: avs=0
[ 3.984916] W : [File] : drivers/gpu/arm/midgard/platform/rk/mali_kbase_config_rk.c; [Line] : 114; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
[ 3.985146] mali ffa30000.gpu: GPU identified as 0x0750 r1p0 status 0
[ 3.985223] mali ffa30000.gpu: Protected mode not available
[ 3.985417] mali ffa30000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[ 3.985438] mali ffa30000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
[ 3.985518] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 423; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 3.985782] mali ffa30000.gpu: Probed as mali0
[ 3.986583] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 3.986584] rk_gmac-dwmac ff290000.ethernet: clock input or output? (input).
[ 3.986589] rk_gmac-dwmac ff290000.ethernet: TX delay(0x1d).
[ 3.986592] rk_gmac-dwmac ff290000.ethernet: RX delay(0x16).
[ 3.986604] rk_gmac-dwmac ff290000.ethernet: integrated PHY? (no).
[ 3.986670] rk_gmac-dwmac ff290000.ethernet: cannot get clock clk_mac_speed
[ 3.986673] rk_gmac-dwmac ff290000.ethernet: clock input from PHY
[ 3.989200] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 3.990704] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.991682] rk_gmac-dwmac ff290000.ethernet: init for RGMII
[ 3.991735] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 3.991737] Ring mode enabled
[ 3.991739] DMA HW capability register supported
[ 3.991739] Normal descriptors
[ 3.991740] RX Checksum Offload Engine supported (type 2)
[ 3.991741] Wake-Up On Lan supported
[ 3.991766] Enable RX Mitigation via HW Watchdog Timer
[ 3.992211] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.994914] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 3.998221] mmc1: queuing unknown CIS tuple 0x81 (9 bytes)
[ 4.003141] mmc_host mmc2: Bus speed (slot 0) = 99000000Hz (slot req 100000000Hz, actual 99000000HZ div = 0)
[ 4.015701] devfreq ffa30000.gpu: Couldn’t update frequency transition information.
[ 4.048352] mmc_host mmc1: Bus speed (slot 0) = 49500000Hz (slot req 50000000Hz, actual 49500000HZ div = 0)
[ 4.195911] dwmmc_rockchip ff0f0000.dwmmc: Successfully tuned phase to 187
[ 4.195962] mmc2: new HS200 MMC card at address 0001
[ 4.196280] mmcblk2: mmc2:0001 AJTD4R 14.6 GiB
[ 4.196414] mmcblk2boot0: mmc2:0001 AJTD4R partition 1 4.00 MiB
[ 4.196535] mmcblk2boot1: mmc2:0001 AJTD4R partition 2 4.00 MiB
[ 4.196643] mmcblk2rpmb: mmc2:0001 AJTD4R partition 3 4.00 MiB
[ 4.198642] mmcblk2: p1 p2 p3 p4 p5 p6 p7 p8
[ 4.495483] vendor storage:20190527 ret = 0
[ 4.770206] dwmmc_rockchip ff0d0000.dwmmc: Successfully tuned phase to 110
[ 4.772098] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 4.772115] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 5.031107] libphy: stmmac: probed
[ 5.034511] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 5.040967] eth%d: PHY ID 001cc915 at 5 IRQ POLL (stmmac-0:05)
[ 5.047485] input: adc-keys as /devices/platform/adc-keys/input/input1
[ 5.057434] rockchip-dmc dmc: Failed to get leakage
[ 5.062507] rockchip-dmc dmc: Failed to get pvtm
[ 5.067373] rockchip-dmc dmc: avs=0
[ 5.070877] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[ 5.077319] rockchip-dmc dmc: failed to get vop pn to msch rl
[ 5.083194] rockchip-dmc dmc: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[ 5.090882] rockchip-dmc dmc: could not find power_model node
[ 5.196463] usb 1-1: New USB device found, idVendor=1a40, idProduct=0201
[ 5.203219] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 5.210463] usb 1-1: Product: USB 2.0 Hub [MTT]
[ 5.216668] hub 1-1:1.0: USB hub found
[ 5.220617] hub 1-1:1.0: 7 ports detected
[ 5.229885] asoc-simple-card sound: ES8323 HiFi ↔ ff890000.i2s mapping ok
[ 5.238342] asoc-simple-card sound: i2s-hifi ↔ ff890000.i2s mapping ok
[ 5.245099] asoc-simple-card sound: ASoC: no sink widget found for MIC1
[ 5.251722] asoc-simple-card sound: ASoC: Failed to add route Microphone Jack → direct → MIC1
[ 5.260453] asoc-simple-card sound: ASoC: no sink widget found for MIC2
[ 5.267076] asoc-simple-card sound: ASoC: Failed to add route Microphone Jack → direct → MIC2
[ 5.275792] asoc-simple-card sound: ASoC: no source widget found for micbias1
[ 5.282920] asoc-simple-card sound: ASoC: Failed to add route micbias1 → direct → Microphone Jack
[ 5.291971] asoc-simple-card sound: ASoC: no source widget found for HPOL
[ 5.298778] asoc-simple-card sound: ASoC: Failed to add route HPOL → direct → Headphone Jack
[ 5.307392] asoc-simple-card sound: ASoC: no source widget found for HPOR
[ 5.314177] asoc-simple-card sound: ASoC: Failed to add route HPOR → direct → Headphone Jack
[ 5.325304] input: rockchip,firefly-codec Headphone Jack as /devices/platform/sound/sound/card0/input2
[ 5.334896] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.10 (r)
[ 5.334898]
[ 5.334902] =======================================================
[ 5.334903] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 5.334905] =======================================================
[ 5.334906] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver v5.2.2.3_24783.20171030) init.
[ 5.334909] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 5.334912] [WLAN_RFKILL]: wifi turn on power. -1
[ 5.334914] RTW: module init start
[ 5.334915] RTW: rtl8188eu v5.2.2.3_24783.20171030
[ 5.334917] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 5.335019] usbcore: registered new interface driver rtl8188eu
[ 5.335020] RTW: module init ret=0
[ 5.335522] input: gpio-keys as /devices/platform/gpio-keys/input/input3
[ 5.343639] rtc-hym8563 0-0051: setting system clock to 2017-01-01 12:00:02 UTC (1483272002)
[ 5.351871] vcc_sd: disabling
[ 5.351877] vcc_mipi: disabling
[ 5.351879] dvdd_1v2: disabling
[ 5.352552] ret 1024
[ 5.352840] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, built at ‘17:53:48’, on ‘Mar 17 2021’.
[ 5.353119] Mali: Mali device driver loaded
[ 5.353134] rkisp1 ff910000.rkisp1: clear unready subdev num: 1
[ 5.353348] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 5.353350] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 5.353351] rkisp1: update sensor failed
[ 5.353353] rkisp1: subdev link fail, remove isp device
[ 5.354136] iommu: Removing device ff910000.rkisp1 from group 0
[ 5.354422] ALSA device list:
[ 5.354424] #0: rockchip,firefly-codec
[ 5.495113] ======== dhd_wlan_init_plat_data ========
[ 5.495758] Freeing unused kernel memory: 1024K
[ 5.504692] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 5.510296] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=232, oob_irq_flags=0x414
[ 5.517780] dhd_wlan_init_gpio: WL_REG_ON=-1
[ 5.522049] dhd_wifi_platform_load: Enter
[ 5.526218] Power-up adapter ‘DHD generic adapter’
[ 5.531348] wifi_platform_set_power = 1
Loading, please [ 5.535206] ======== PULL WL_REG_ON(-1) HIGH! ========
wait…
[ 5.541695] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 5.547201] [WLAN_RFKILL]: wifi turn on power. -1
starting version 237
[ 5.652056] ES8323 exit line in mode
[ 5.855350] wifi_platform_bus_enumerate device present 1
[ 5.860681] ======== Card detection to detect SDIO card! ========
[ 5.866831] mmc1:mmc host rescan start!
[ 5.886753] bcmsdh_register: register client driver
[ 5.892597] bcmsdh_sdmmc_probe: Enter num=1
[ 5.897145] bcmsdh_sdmmc_probe: Enter num=2
[ 5.901328] bus num (host idx)=1, slot num (rca)=1
[ 5.906155] found adapter info ‘DHD generic adapter’
[ 5.911246] sdioh_attach: set sd_f2_blocksize 256
[ 5.916047] sdioh_attach: sd clock rate = 0
[ 5.920405] dhdsdio_probe : no mutex held. set lock
[ 5.925417] F1 signature read @0x18000000=0x15264345
[ 5.935444] F1 signature OK, socitype:0x1 chip:0x4345 rev:0x6 pkg:0x2
[ 5.943767] DHD: dongle ram size is set to 819200(orig 819200) at 0x198000
[ 5.950851] dhd_conf_set_chiprev: chip=0x4345, chiprev=6
[ 5.956416] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 5.963384] CFG80211-ERROR) wl_init_prof : wl_init_prof: No profile
[ 5.969913] wl_escan_attach: Enter
[ 5.973375] wl_escan_init: Enter
[ 5.976928] wl_create_event_handler(): thread:wl_escan_handler:d7 started
[ 5.977935] tsk Enter, tsk = 0xed0f0170
[ 5.987800] dhd_attach(): thread:dhd_watchdog_thread:d8 started
[ 5.993820] dhd_attach(): thread:dhd_dpc:d9 started
[ 5.998803] dhd_attach(): thread:dhd_rxf:da started
[ 6.003728] dhd_deferred_work_init: work queue initialized
[ 6.009220] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 → mode 2
[ 6.015811] dhd_bus_set_default_min_res_mask: Unhandled chip id
[ 6.021902] sdioh_cis_read: func_cis_ptr[0]=0x10ac
[ 6.035786] Dongle Host Driver, version 1.579.77.41.10 (r)
[ 6.041704] wl_ext_iapsta_attach_netdev: ifidx=0, bssidx=0
[ 6.047234] Register interface [wlan0] MAC: cc:4b:73:8a:f5:c6
[ 6.047234]
[ 6.054596] dhd_tcpack_suppress_set: TCP ACK Suppress mode 2 → mode 0
[ 6.061144] dhd_wl_ioctl: returning as busstate=0
[ 6.065873] dhd_dbg_detach_pkt_monitor, 2204
[ 6.070142] dhd_bus_devreset: == Power OFF ==
[ 6.074663] bcmsdh_oob_intr_unregister: Enter
[ 6.079042] bcmsdh_oob_intr_unregister: irq is not registered
[ 6.084787] dhd_txglom_enable: enable 0
[ 6.088632] dhd_conf_set_txglom_params: txglom_mode=copy
[ 6.093933] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0
[ 6.100543] dhd_conf_set_txglom_params: txinrx_thres=128, dhd_txminmax=-1
[ 6.107324] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=300
[ 6.114192] dhd_bus_devreset: WLAN OFF DONE
[ 6.118500] wifi_platform_set_power = 0
[ 6.122337] ======== PULL WL_REG_ON(-1) LOW! ========
[ 6.127391] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 6.132099] [WLAN_RFKILL]: wifi shut off power.
[ 6.136633] dhdsdio_probe : the lock is released.
[ 6.141397] dhd_module_init: Exit err=0
Begin: Loading essential drivers … done.
Begin: Running /scripts/init-premount … done.
Begin: Running /scripts/local-premount … done.
Warning: fsck not present, so skipping root file system
[ 7.720574] EXT4-fs (mmcblk2p7): INFO: recovery required on readonly filesystem
[ 7.728033] EXT4-fs (mmcblk2p7): write access will be enabled during recovery
[ 7.916457] random: nonblocking pool is initialized
[ 7.942880] EXT4-fs (mmcblk2p7): recovery complete
[ 7.949042] EXT4-fs (mmcblk2p7): mounted filesystem with ordered data mode. Opts: (null)
done.
Begin: Running /scripts/local-bottom … done.
Begin: Running /scripts/init-bottom … Failure: overlayroot: failed to convert PARTLABEL=userdate to a device
Failure: overlayroot: failed setup overlay for device:dev=PARTLABEL=userdate,fstype=ext4,mkfs=1 [dev=PARTLABEL=userdate,fstype=ext4,mkfs=1] (per kernel cmdline)
Warning: Something odd, no /lib/modules/4.4.194 in initramfs.
done.
[ 8.407618] systemd[1]: System time before build time, advancing clock.
[ 8.430035] cgroup: cgroup2: unknown option “nsdelegate”
[ 8.444301] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 8.466266] systemd[1]: Detected architecture arm.
Welcome to Ubuntu 18.04.4 LTS!
[ 8.477031] systemd[1]: Set hostname to .
[ 8.509190] systemd-fstab-generator[364]: Checking was requested for “uuid:614e0000-0000-4b53-8000-1d28000054a9”, but it is not a device.
[ 8.570549] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 8.588211] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 8.687001] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 8.693310] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 8.709599] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 8.715469] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 8.726292] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 8.737339] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 8.750279] systemd[1]: Starting Create Static Device Nodes in /dev…
[ 8.760158] systemd[1]: Starting Set the console keyboard layout…
[ 8.772424] systemd[1]: Starting Load Kernel Modules…
[ 8.781696] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 8.791095] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 8.801988] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 8.814468] systemd[1]: Starting Journal Service…
[ 8.821684] systemd[1]: Reached target User and Group Name Lookups.
[ OK ] Reached target User and Group Name Lookups.
[ 8.831407] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 8.841686] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 8.854552] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 8.868003] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 8.880826] systemd[1]: Starting udev Coldplug all Devices…
[ 8.891573] systemd[1]: Mounting Kernel Debug File System…
[ 8.900165] systemd[1]: Started Load Kernel Modules.
[ OK ] Started Load Kernel Modules.
[ 8.911204] systemd[1]: Started Create Static Device Nodes in /dev.
[ OK ] Started Create Static Device Nodes in /dev.
[ 8.922263] systemd[1]: Mounting FUSE Control File System…
[ 8.932577] systemd[1]: Starting Apply Kernel Variables…
[ 8.942498] systemd[1]: Mounting Kernel Configuration File System…
[ 8.956539] EXT4-fs (mmcblk2p7): re-mounted. Opts: errors=remount-ro
[ 8.956784] systemd[1]: Mounted Kernel Debug File System.
[ OK ] Mounted Kernel Debug File System.
[ 8.970961] systemd[1]: Started Remount Root and Kernel File Systems.
[ OK ] Started Remount Root and Kernel File Systems.
[ 8.980645] systemd[1]: Mounted FUSE Control File System.
[ OK ] Mounted FUSE Control File System.
[ OK ] Started Apply Kernel Variables.
[ OK ] Mounted Kernel Configuration File System.
Starting Load/Save Random Seed…
Starting udev Kernel Device Manager…
Activating swap /swapfile…
[ OK ] Started Load/Save Random Seed.
[ 9.029283] systemd[1]: Failed to activate swap /swapfile.
[FAILED] Failed to activate swap /swapfile.
See ‘systemctl status swapfile.swap’ for details.
[DEPEND] Dependency failed for Swap.
[ OK ] Started Journal Service.
Starting Flush Journal to Persistent Storage…
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Set the console keyboard layout.
[ OK ] Reached target Local File Systems (Pre).
[ OK ] Reached target Local File Systems.
Starting Set console font and keymap…
Starting Create Volatile Files and Directories…
Starting Tell Plymouth To Write Out Runtime Data…
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Reached target Local Encrypted Volumes.
[ OK ] Started Tell Plymouth To Write Out Runtime Data.
[ OK ] Started Set console font and keymap.
[ OK ] Started Create Volatile Files and Directories.
Starting Network Time Synchronization…
Starting Network Name Resolution…
Starting Update UTMP about System Boot/Shutdown…
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Found device /dev/ttyFIQ0.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Synchronized.
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ OK ] Reached target Sound Card.
[ OK ] Reached target System Initialization.
[ OK ] Started Daily apt download activities.
[ OK ] Reached target Paths.
[ OK ] Started Daily apt upgrade and clean activities.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Started Discard unused blocks once a week.
[ OK ] Reached target Timers.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting System Logging Service…
Starting Adbd for linux…
Starting rkisp 3A engine…
Starting Restore /etc/resolv.conf i…fore the ppp link was shut down…
Starting Accounts Service…
Starting LSB: automatic crash report generation…
Starting Login Service…
Starting Dispatcher daemon for systemd-networkd…
Starting Modem Manager…
[ OK ] Started Set the CPU Frequency Scaling governor.
Starting Save/Restore Sound Card State…
Starting Disk Manager…
[ OK ] Started D-Bus System Message Bus.
Starting Network Manager…
Starting WPA supplicant…
[ OK ] Started Regular background program processing daemon.
Starting Avahi mDNS/DNS-SD Stack…
[ OK ] Started Network Name Resolution.
[ OK ] Started System Logging Service.
[ OK ] Started Restore /etc/resolv.conf if…before the ppp link was shut down.
[ OK ] Started Adbd for linux.
[ OK ] Started rkisp 3A engine.
[ OK ] Started Save/Restore Sound Card State.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
Starting Authorization Manager…
Starting Load/Save RF Kill Switch Status…
[ OK ] Reached target Host and Network Name Lookups.
[ OK ] Started Login Service.
[ OK ] Started WPA supplicant.
[ OK ] Started Load/Save RF Kill Switch Status.
[ OK ] Started LSB: automatic crash report generation.
[ OK ] Started Authorization Manager.
[ OK ] Started Accounts Service.
[ OK ] Started Modem Manager.
Starting Hostname Service…
[ OK ] Started Disk Manager.
[ OK ] Started Dispatcher daemon for systemd-networkd.
[ OK ] Started Hostname Service.
Starting Network Manager Script Dispatcher Service…
[ OK ] Started Network Manager Script Dispatcher Service.
[ 12.129246] CONFIG-ERROR) dhd_conf_set_intiovar: txbf setting failed -23
[ OK ] Started Network Manager.
[ OK ] Reached target Network.
Starting OpenBSD Secure Shell server…
Starting /etc/rc.local Compatibility…
Starting Permit User Sessions…
[ OK ] Started /etc/rc.local Compatibility.
[ OK ] Started Permit User Sessions.
Starting Light Display Manager…
Starting Hold until boot process finishes up…
[ OK ] Started Hold until boot process finishes up.
Starting Set console scheme…
[ OK ] Started Serial Getty on ttyFIQ0.
[ OK ] Started Set console scheme.
[ OK ] Created slice system-getty.slice.
[ OK ] Started Getty on tty1.
[ OK ] Reached target Login Prompts.
[ OK ] Started OpenBSD Secure Shell server.
[ OK ] Reached target Multi-User System.
[ OK ] Started Light Display Manager.
[ OK ] Reached target Graphical Interface.
Starting Update UTMP about System Runlevel Changes…
[ OK ] Started Update UTMP about System Runlevel Changes.
Ubuntu 18.04.4 LTS firefly ttyFIQ0
firefly login: root (automatic login)
Last login: Sun Jan 28 23:58:21 CST 2018 on ttyFIQ0
| () __ ___ / | | _
| | | | '/ _ \ || | | | |
| | | | | | __/ | | || |
|| ||_| _|| ||_, |
|__/
Welcome to Ubuntu 18.04.4 LTS (GNU/Linux 4.4.194 armv7l)
System information as of Sun Jan 28 23:58:21 CST 2018
System load: 0.46 0.10 0.03 Up time: 0 min
Memory usage: 3 % of 1995MB IP:
Usage of /: 100% of 2.0G
root@firefly:~#
