ROC-RK3399-PC 使用dsi1过程, drm_framebuffer_free 异常
您好:
请帮忙分析dsi1发送指令后,drm释放framebuffer异常,
dsi1 log :
[ 3.646520] init: Starting service ‘bootanim’…
[ 3.649002] dw-mipi-dsi ff968000.dsi: vop BIG output to dsi0
[ 3.649078] dw-mipi-dsi ff968000.dsi: final DSI-Link bandwidth: 432 x 4 Mbps
[ 3.653858] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 3.654048] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 3.660115] dw-mipi-dsi ff968000.dsi: failed to wait for phy lock state
panel_simple_disable-511:Enter
[ 3.660197] panel_simple_disable-522:p->desc->delay.disable=50
---- (CSI1 &DSI1 ) ---- [ 3.653858] E:camsys_i2c_write(84)
drm_framebuffer_free异常代码段如下
[ 4.092079] Call trace:
[ 4.092092] [] dump_backtrace+0x0/0x1cc
[ 4.092102] [] show_stack+0x14/0x1c
[ 4.092113] [] dump_stack+0x94/0xb4
[ 4.092124] [] bad_page+0xec/0x114
[ 4.092131] [] free_pages_prepare+0x100/0x260
[ 4.092141] [] free_hot_cold_page+0x34/0x178
[ 4.092149] [] __free_pages+0x34/0x44
[ 4.092158] [] free_reserved_area+0xc0/0x10c
[ 4.092169] [] rockchip_free_loader_memory+0xe0/0xfc
[ 4.092177] [] rockchip_drm_fb_destroy+0xc4/0xe4
[ 4.092187] [] drm_framebuffer_free+0x70/0x84
[ 4.092194] [] drm_framebuffer_unreference+0x6c/0x78
[ 4.092204] [] vop_fb_unref_worker+0x20/0x28
[ 4.092212] [] flip_worker+0xa8/0xe8
[ 4.092223] [] process_one_work+0x228/0x3f4
[ 4.092232] [] worker_thread+0x304/0x418
[ 4.092241] [] kthread+0xe8/0xf0
[ 4.092250] [] ret_from_fork+0x10/0x40
完整的log如下
Welcome to minicom 2.7.1
OPTIONS: I18n
Compiled on Aug 13 2017, 15:25:34.
Port /dev/ttyUSB0, 18:43:28
Press CTRL-A Z for help on special keys
�^�|Y�����?�y}�^3��9��?���ߧ���Ͼ�>������y��~��LM�p���˭�y��z��������-��1�~�~׹�x��E^*>�ݯ�%�W���
\��E��U�oG^�
�r��z/dy���^�r��ܞ�O����n���Oݙ��Y����FF�t��e�V�wW��r�#o�z����ѹ��x��$F+
�F>V����
�����������Ϟ���˗�������0������0.��JVd �"�����������爗��������,2fQ���������ϟ�������������Ï�������������������������ǐˆ�������������㟇����˖������·��������烏���������������������������� �
K’t{bˉ �S��W�;a_90O�s��^�/28d�9��7z^��A;8\�;�{x ��t���N�����x�V �
��������������������ǐ�3��@P�)4���Ã��������
������?���������������가�ږ��������A�p��
�������������f���������������������������������������[[ 0.182309] console [ttyFIQ0] enabled
[[ 0.189996] bootconsole [uart0] disabled
[ 0.198403] Registered fiq debugger ttyFIQ0
[ 0.225958] Rockchip hdmi driver version 2.0
[ 0.228893] iommu: Adding device ff650000.vpu_service to group 0
[ 0.228969] iommu: Adding device ff660000.rkvdec to group 1
[ 0.229041] iommu: Adding device ff670000.iep to group 2
[ 0.229141] iommu: Adding device ff8f0000.vop to group 3
[ 0.229221] iommu: Adding device ff900000.vop to group 4
[ 0.229335] iommu: Adding device ff910000.isp to group 5
[ 0.229413] iommu: Adding device ff920000.isp to group 6
[ 0.230120] rk_iommu ff670800.iommu: can’t get aclk
[ 0.230137] rk_iommu ff670800.iommu: can’t get hclk
[ 0.231018] SCSI subsystem initialized
[ 0.231362] usbcore: registered new interface driver usbfs
[ 0.231408] usbcore: registered new interface driver hub
[ 0.231486] usbcore: registered new device driver usb
[ 0.232017] pps_core: LinuxPPS API ver. 1 registered
[ 0.232030] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.232056] PTP clock support registered
[ 0.233675] Advanced Linux Sound Architecture Driver Initialized.
[ 0.234219] Bluetooth: Core ver 2.21
[ 0.234253] NET: Registered protocol family 31
[ 0.234265] Bluetooth: HCI device and connection manager initialized
[ 0.234283] Bluetooth: HCI socket layer initialized
[ 0.234300] Bluetooth: L2CAP socket layer initialized
[ 0.234329] Bluetooth: SCO socket layer initialized
[ 0.235405] rockchip-cpuinfo cpuinfo: Serial : 4da7e0c159fb2607
[ 0.235827] clocksource: Switched to clocksource arch_sys_counter
[ 0.275044] uboot-logo-on:1
[ 0.275066] rockchip ion idev is NULL
[ 0.275081] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.275248] logo: base=0xf5c00000, size=0x7a508, offset=0x0
[ 0.275262] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.278358] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.278591] NET: Registered protocol family 2
[ 0.279020] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.279307] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.279844] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.279927] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.280037] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.280278] NET: Registered protocol family 1
[ 0.280830] Trying to unpack rootfs image as initramfs…
[ 0.370684] Freeing initrd memory: 1716K
[ 0.371165] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.371254] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.374081] audit: initializing netlink subsys (disabled)
[ 0.374146] audit: type=2000 audit(0.370:1): initialized
[ 0.379247] VFS: Disk quotas dquot_6.6.0
[ 0.379370] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.380763] fuse init (API version 7.23)
[ 0.381897]
[ 0.381897] TEE Core Framework initialization (ver 1:0.1)
[ 0.381925] TEE armv7 Driver initialization
[ 0.382303] tz_tee_probe: name=“armv7sec”, id=0, pdev_name=“armv7sec.0”
[ 0.382320] TEE core: Alloc the misc device “opteearmtz00” (id=0)
[ 0.382544] TEE Core: Register the misc device “opteearmtz00” (id=0,minor=62)
[ 0.387102] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.387126] io scheduler noop registered
[ 0.387293] io scheduler cfq registered (default)
[ 0.392678] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.392700] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.392718] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 0.915880] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 0.916065] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 0.916899] backlight supply power not found, using dummy regulator
[ 0.917951] iep: failed to find iep power down clock source.
[ 0.918549] IEP Powe�z95
[ 0.918757] IEP Power OFF
[ 0.918872] IEP Driver loaded succesfully
[ 0.919105] Module initialized.
[ 0.923085] rk-vcodec ff650000.vpu_service: probe device
[ 0.923139] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc0f1f06810
[ 0.923305] rk-vcodec ff650000.vpu_service: allocator is drm
[ 0.923361] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 0.923912] rk-vcodec ff650000.vpu_service: init success
[ 0.936140] rk-vcodec ff660000.rkvdec: probe device
[ 0.936186] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc0f1f07010
[ 0.936326] rk-vcodec ff660000.rkvdec: allocator is drm
[ 0.936386] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 0.936747] rk-vcodec ff660000.rkvdec: init success
[ 0.938432] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.938451] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.939808] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.939826] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.941314] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 0.942906] console [ttyS0] disabled
[ 0.942950] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
[ 0.943529] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 37, base_baud = 1500000) is a 16550A
[ 0.943958] [drm:drm_core_init] Initialized drm 1.1.0 20060810
[ 0.949113] panel_simple_dsi_parse_pclist-242:enter
[ 0.949214] panel_simple: parse lcd-en: gpio=36, atv_val=1, delay=10ms
[ 0.949227] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 0.949459] panel-simple-dsi ff968000.dsi.0: panel_simple_dsi_parse_dcs_cmds: dcs_cmd=15 len=120, cmd_cnt=24
[ 0.949478] panel-simple-dsi ff968000.dsi.0: panel_simple_dsi_parse_dcs_cmds: dcs_cmd=5 len=8, cmd_cnt=2
[ 0.949892] mali ff9a0000.gpu: Failed to get regulator
[ 0.949905] mali ff9a0000.gpu: Power control initialization failed
[ 0.950209] Unable to detect cache hierarchy from DT for CPU 0
[ 0.968072] brd: module loaded
[ 0.972813] loop: module loaded
[ 0.973352] zram: Added device: zram0
[ 0.973939] SCSI Media Changer driver v0.25
[ 0.975295] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[ 0.975314] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[ 0.975873] m25p80 spi0.0: w25q128 (16384 Kbytes)
[ 0.976886] register spi return v = :0
[ 0.976939] tun: Universal TUN/TAP device driver, 1.6
[ 0.976950] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.977874] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 0.977970] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 0.977990] rk_gmac-dwmac fe300000.ethernet: TX delay(0x2e).
[ 0.978004] rk_gmac-dwmac fe300000.ethernet: RX delay(0x23).
[ 0.978032] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 0.978209] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 0.983228] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 0.983356] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.983367] Ring mode enabled
[ 0.983376] DMA HW capability register supported
[ 0.983385] Normal descriptors
[ 0.983396] RX Checksum Offload Engine supported (type 2)
[ 0.983406] Wake-Up On Lan supported
[ 0.983447] Enable RX Mitigation via HW Watchdog Timer
[ 1.051912] libphy: stmmac: probed
[ 1.051928] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.051941] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.052842] PPP generic driver version 2.4.2
[ 1.053003] PPP BSD Compression module registered
[ 1.053018] PPP Deflate Compression module registered
[ 1.053047] PPP MPPE Compression module registered
[ 1.053065] NET: Registered protocol family 24
[ 1.053103] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.053116] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.053184] usbcore: registered new interface driver mt7601u
[ 1.053205] Rockchip WiFi SYS interface (V1.00) …
[ 1.053266] usbcore: registered new interface driver catc
[ 1.053308] usbcore: registered new interface driver kaweth
[ 1.053324] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.053362] usbcore: registered new interface driver pegasus
[ 1.053405] usbcore: registered new interface driver rtl8150
[ 1.053450] usbcore: registered new interface driver r8152
[ 1.053464] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.053522] usbcore: registered new interface driver hso
[ 1.053570] usbcore: registered new interface driver asix
[ 1.053612] usbcore: registered new interface driver ax88179_178a
[ 1.053657] usbcore: registered new interface driver cdc_ether
[ 1.053698] usbcore: registered new interface driver cdc_eem
[ 1.053739] usbcore: registered new interface driver dm9601
[ 1.053790] usbcore: registered new interface driver smsc75xx
[ 1.053841] usbcore: registered new interface driver smsc95xx
[ 1.053884] usbcore: registered new interface driver gl620a
[ 1.053927] usbcore: registered new interface driver net1080
[ 1.053968] usbcore: registered new interface driver plusb
[ 1.054010] usbcore: registered new interface driver rndis_host
[ 1.054053] usbcore: registered new interface driver cdc_subset
[ 1.054094] usbcore: registered new interface driver zaurus
[ 1.054139] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.054196] usbcore: registered new interface driver int51x1
[ 1.054237] usbcore: registered new interface driver kalmia
[ 1.054278] usbcore: registered new interface driver ipheth
[ 1.054322] usbcore: registered new interface driver sierra_net
[ 1.054367] usbcore: registered new interface driver cx82310_eth
[ 1.054419] usbcore: registered new interface driver cdc_ncm
[ 1.054462] usbcore: registered new interface driver qmi_wwan
[ 1.054505] usbcore: registered new interface driver cdc_mbim
[ 1.055717] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[ 1.056576] rockchip-dwc3 usb@fe900000: failed to get drvdata dwc3
[ 1.057039] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.057057] ehci-pci: EHCI PCI platform driver
[ 1.057112] ehci-platform: EHCI generic platform driver
[ 1.057701] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.057738] ohci-platform: OHCI generic platform driver
[ 1.058606] usbcore: registered new interface driver cdc_acm
[ 1.058619] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.058676] usbcore: registered new interface driver usblp
[ 1.058722] usbcore: registered new interface driver cdc_wdm
[ 1.058765] usbcore: registered new interface driver uas
[ 1.058819] usbcore: registered new interface driver usb-storage
[ 1.058863] usbcore: registered new interface driver ums-alauda
[ 1.058903] usbcore: registered new interface driver ums-cypress
[ 1.058945] usbcore: registered new interface driver ums-datafab
[ 1.058985] usbcore: registered new interface driver ums_eneub6250
[ 1.059025] usbcore: registered new interface driver ums-freecom
[ 1.059064] usbcore: registered new interface driver ums-isd200
[ 1.059105] usbcore: registered new interface driver ums-jumpshot
[ 1.059145] usbcore: registered new interface driver ums-karma
[ 1.059225] usbcore: registered new interface driver ums-onetouch
[ 1.059269] usbcore: registered new interface driver ums-sddr09
[ 1.059310] usbcore: registered new interface driver ums-sddr55
[ 1.059351] usbcore: registered new interface driver ums-usbat
[ 1.059431] usbcore: registered new interface driver usbserial
[ 1.059467] usbcore: registered new interface driver usbserial_generic
[ 1.059498] usbserial: USB Serial support registered for generic
[ 1.059540] usbcore: registered new interface driver ch341
[ 1.059572] usbserial: USB Serial support registered for ch341-uart
[ 1.059614] usbcore: registered new interface driver cp210x
[ 1.059643] usbserial: USB Serial support registered for cp210x
[ 1.059684] usbcore: registered new interface driver option
[ 1.059714] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.059757] usbcore: registered new interface driver pl2303
[ 1.059786] usbserial: USB Serial support registered for pl2303
[ 1.059833] usbcore: registered new interface driver trancevibrator
[ 1.059851] usb20_otg: version 3.10a 21-DEC-2012
[ 1.060039] usb20_host: version 3.10a 21-DEC-2012
[ 1.063846] usbcore: registered new interface driver xpad
[ 1.063900] usbcore: registered new interface driver usb_acecad
[ 1.063947] usbcore: registered new interface driver aiptek
[ 1.063992] usbcore: registered new interface driver gtco
[ 1.064037] usbcore: registered new interface driver hanwang
[ 1.064083] usbcore: registered new interface driver kbtab
[ 1.064099] ==gsl_ts_init==
[ 1.064129] ret=0
[ 1.067885] .. rk pwm remotectl v1.1 init
[ 1.068126] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 1.068543] sensor_register_slave:mma8452,id=17
[ 1.068562] sensor_register_slave:lis3dh,id=7
[ 1.068577] sensor_register_slave:mma7660,id=18
[ 1.068593] sensor_register_slave:lsm303d,id=22
[ 1.068608] sensor_register_slave:gs_mc3230,id=23
[ 1.068618] [Gsensor] gsensor_init
[ 1.068633] sensor_register_slave:mpu6880_acc,id=24
[ 1.068649] sensor_register_slave:mpu6500_acc,id=25
[ 1.068664] sensor_register_slave:lsm330_acc,id=26
[ 1.068680] sensor_register_slave:akm8975,id=29
[ 1.068696] sensor_register_slave:akm8963,id=30
[ 1.068711] sensor_register_slave:l3g4200d,id=44
[ 1.068726] sensor_register_slave:l3g20d,id=45
[ 1.068741] sensor_register_slave:ewtsa,id=46
[ 1.068757] sensor_register_slave:lsm330_gyro,id=50
[ 1.068772] sensor_register_slave:cm3217,id=52
[ 1.068788] sensor_register_slave:cm3218,id=53
[ 1.069533] i2c /dev entries driver
[ 1.070595] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 1.070671] fan53555-reg: supplied by vcc5v0_sys
[ 1.072341] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 1.072398] fan53555-reg: supplied by vcc5v0_sys
[ 1.074183] rk808 0-001b: Pmic Chip id: 0x0
[ 1.077465] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.077529] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.077624] DCDC_REG1: supplied by vcc3v3_sys
[ 1.078294] DCDC_REG2: supplied by vcc3v3_sys
[ 1.078811] DCDC_REG3: supplied by vcc3v3_sys
[ 1.079028] DCDC_REG4: supplied by vcc3v3_sys
[ 1.079412] LDO_REG1: supplied by vcc3v3_sys
[ 1.080481] LDO_REG2: supplied by vcc3v3_sys
[ 1.081388] LDO_REG3: supplied by vcc3v3_sys
[ 1.082294] LDO_REG4: supplied by vcc3v3_sys
[ 1.083216] LDO_REG5: supplied by vcc3v3_sys
[ 1.084121] LDO_REG6: supplied by vcc3v3_sys
[ 1.085021] LDO_REG7: supplied by vcc3v3_sys
[ 1.085959] LDO_REG8: supplied by vcc3v3_sys
[ 1.086863] SWITCH_REG1: supplied by vcc3v3_sys
[ 1.087078] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.090433] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 1.090916] rk808 0-001b: Can not read property pmic,stby-gpio
[ 1.090947] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80093fc000
[ 1.091424] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80093fe000
[ 1.091924] rk3x-i2c ff120000.i2c: Initialized RK3xxx I2C bus at ffffff80096de000
[ 1.092997] fusb302 7-0022: Can’t get property of role, set role to default DRP
[ 1.093166] fusb302 7-0022: fusb302 send extcon to disable vbus 5v
[ 1.095871] fusb302 7-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 1.096940] mp8859 7-0066: set mp8859 out 12v ok
[ 1.096954] mp8859 7-0066: register ext0 dev0
[ 1.097078] mp8859 7-0066: mp8859 probe successful
[ 1.097105] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at ffffff80096fa000
[ 1.101669] fusb302 4-0022: Can’t get property of role, set role to default DRP
[ 1.109982] fusb302 4-0022: port 1 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 1.110016] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80096fc000
[ 1.111016] IR NEC protocol handler initialized
[ 1.111032] IR RC5(x/sz) protocol handler initialized
[ 1.111046] IR RC6 protocol handler initialized
[ 1.111060] IR JVC protocol handler initialized
[ 1.111073] IR Sony protocol handler initialized
[ 1.111106] IR SANYO protocol handler initialized
[ 1.111122] IR Sharp protocol handler initialized
[ 1.111135] IR MCE Keyboard/mouse protocol handler initialized
[ 1.111149] IR XMP protocol handler initialized
[ 1.111165] CamSys driver version: v0.38.0, CamSys head file version: v1.0.0
[ 1.115928] __power_supply_register: Expected proper parent device for ‘test_ac’
[ 1.116071] __power_supply_register: Expected proper parent device for ‘test_battery’
[ 1.116309] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 1.116420] __power_supply_register: Expected proper parent device for ‘test_usb’
[ 1.116819] cw_bat_probe cw_init error
[ 1.119144] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 1.120055] device-mapper: uevent: version 1.0.3
[ 1.120398] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 1.120535] Bluetooth: HCI UART driver ver 2.3
[ 1.120549] Bluetooth: HCI UART protocol H4 registered
[ 1.120561] Bluetooth: HCI UART protocol LL registered
[ 1.120576] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 1.120587] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[ 1.120598] rtk_btusb: Register usb char device interface for BT driver
[ 1.120812] usbcore: registered new interface driver rtk_btusb
[ 1.121211] cpu cpu0: leakage=16
[ 1.137674] cpu cpu0: temp=39375, pvtm=143412 (143642 + -230)
[ 1.137934] cpu cpu0: pvtm-sel=0
[ 1.138270] cpu cpu4: leakage=26
[ 1.150556] cpu cpu4: temp=39375, pvtm=149216 (149358 + -142)
[ 1.150703] cpu cpu4: pvtm-sel=1
[ 1.155312] sdhci: Secure Digital Host Controller Interface driver
[ 1.155330] sdhci: Copyright(c) Pierre Ossman
[ 1.155345] Synopsys Designware Multimedia Card Interface Driver
[ 1.156372] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.156576] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 1.156600] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 1.156649] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.156683] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.157157] vccio_sd: unsupportable voltage range: 3300000-3000000uV
[ 1.157182] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 1.157198] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 1.169213] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.183615] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 1.183951] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.185668] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 1.185682] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 1.212571] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 1.214778] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.219257] usbcore: registered new interface driver usbhid
[ 1.219278] usbhid: USB HID core driver
[ 1.219475] inv_mpu_iio: inv_mpu_init:746
[ 1.220462] ashmem: initialized
[ 1.222006] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[ 1.223368] ff100000.saradc supply vref not found, using dummy regulator
[ 1.224794] rknandbase v1.1 2016-11-08
[ 1.225368] usbcore: registered new interface driver snd-usb-audio
[ 1.231441] rockchip-cdndp-sound dp-sound: ASoC: CODEC DAI spdif-hifi not registered
[ 1.231468] rockchip-cdndp-sound dp-sound: rockchip_sound_probe snd_soc_register_card fail -517
[ 1.231692] u32 classifier
[ 1.231704] Actions configured
[ 1.231770] Netfilter messages via NETLINK v0.30.
[ 1.231852] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.232303] ctnetlink v0.93: registering with nfnetlink.
[ 1.233324] xt_time: kernel timezone is -0000
[ 1.234146] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.234374] arp_tables: (C) 2002 David S. Miller
[ 1.234718] Initializing XFRM netlink socket
[ 1.235286] NET: Registered protocol family 10
[ 1.236362] mip6: Mobile IPv6
[ 1.236401] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.237593] sit: IPv6 over IPv4 tunneling driver
[ 1.238189] NET: Registered protocol family 17
[ 1.238224] NET: Registered protocol family 15
[ 1.238273] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 1.238428] Bridge firewalling registered
[ 1.238448] Ebtables v2.0 registered
[ 1.238605] Bluetooth: RFCOMM TTY layer initialized
[ 1.238629] Bluetooth: RFCOMM socket layer initialized
[ 1.238685] Bluetooth: RFCOMM ver 1.11
[ 1.238707] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.238729] Bluetooth: BNEP filters: protocol multicast
[ 1.238747] Bluetooth: BNEP socket layer initialized
[ 1.238759] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.238770] Bluetooth: HIDP socket layer initialized
[ 1.238798] l2tp_core: L2TP core driver, V2.0
[ 1.238816] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.R238C2_R83399LA_PC:/ $ LL]: Enter rfkill_wlan_init
[ 1.239013] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.239297] sensor_register_slave:mpu6880_gyro,id=49
[ 1.239540] Registered cp15_barrier emulation handler
[ 1.239657] Registered setend emulation handler
[ 1.240410] registered taskstats version 1
[ 1.241135] rockchip ion idev is NULL
[ 1.241147] rga2 ff680000.rga: rga ion client create success!
[ 1.241398] rga: Driver loaded successfully ver:3.02
[ 1.241614] Freeing logo memory: 488K
[ 1.242726] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not assigned
[ 1.243365] fusb302 7-0022: CC connected in CC1 as UFP
[ 1.244377] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned
[ 1.247463] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 1.247723] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 1.248192] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 1.248219] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 1.248292] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 1.252969] mmc1: MAN_BKOPS_EN bit is not set
[ 1.253078] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[ 1.253732] i2c i2c-10: of_i2c: modalias failure on /dp@fec00000/ports
[ 1.254092] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops)
[ 1.254231] rockchip-drm display-subsystem: bound ff968000.dsi (ops dw_mipi_dsi_ops)
[ 1.254247] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.254257] [drm:drm_vblank_init] No driver support for vblank timestamp query.
[ 1.254653] rockchip-drm display-subsystem: connector[HDMI-A-1] can’t found any modes
[ 1.255811] dw-mipi-dsi ff968000.dsi: vop BIG output to dsi0
[ 1.255905] dw-mipi-dsi ff968000.dsi: final DSI-Link bandwidth: 432 x 4 Mbps
[ 1.256717] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 1.265225] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[ 1.265694] mmcblk1: mmc1:0001 AJTD4R 14.6 GiB
[ 1.265956] mmcblk1boot0: mmc1:0001 AJTD4R partition 1 4.00 MiB
[ 1.266171] mmcblk1boot1: mmc1:0001 AJTD4R partition 2 4.00 MiB
[ 1.266854] dw-mipi-dsi ff968000.dsi: failed to wait for phy lock state
panel_simple_prepare-616:enter
[ 1.269760] mmcblk1rpmb: mmc1:0001 AJTD4R partition 3 4.00 MiB
[ 1.270055] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 1.270066] trust: 0x000800000 – 0x000c00000 (4 MB)
[ 1.270075] misc: 0x000c00000 – 0x001000000 (4 MB)
[ 1.270084] resource: 0x001000000 – 0x002000000 (16 MB)
[ 1.270092] kernel: 0x002000000 – 0x003800000 (24 MB)
[ 1.270100] boot: 0x003800000 – 0x005800000 (32 MB)
[ 1.270109] recovery: 0x005800000 – 0x007800000 (32 MB)
[ 1.270116] backup: 0x007800000 – 0x00e800000 (112 MB)
[ 1.270125] cache: 0x00e800000 – 0x016800000 (128 MB)
[ 1.270133] system: 0x016800000 – 0x076800000 (1536 MB)
[ 1.270141] metadata: 0x076800000 – 0x077800000 (16 MB)
[ 1.270149] baseparamer: 0x077800000 – 0x077c00000 (4 MB)
[ 1.270157] userdata: 0x077c00000 – 0x3a3a00000 (12990 MB)
[ 1.270190] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13
[ 1.319306] [ 1.342738] mp8859 7-0066: mp8859 get notify
[ 1.342785] mp8859 7-0066: mp8859 get ufp 1 dp 0
[ 1.345358] mp8859 7-0066: set mp8859 out 12v ok
panel_simple: set lcd-en(36) active=1,delay:10ms
panel_simple: set lcd-rst(157) active=1,delay:6ms
panel_simple_enable-677:enter
[ 1.389062] panel_simple_dsi_send_cmds-322:cmd: type=0x15, len=2, data[0]=0x7a, wait=0ms
panel_simple_dsi_send_cmds-322:cmd: type=0x15, len=2, data[0]=0x20, wait=0ms
panel_simple_dsi_send_cmds-322:cmd: type=0x15, len=2, data[0]=0x21, wait=0ms
panel_simple_dsi_send_cmds-322:cmd: type=0x15, len=2, data[0]=0x22, wait=0ms
panel_simple_dsi_send_cmds-322:cmd: type=0x15, len=2, data[0]=0x23, wait=0ms
panel_simple_dsi_send_cmds-322:cmd: type=0x15, len=2, data[0]=0x24, wait=0ms
panel_simple_dsi_send_cmds-322:cmd: type=0x15, len=2, data[0]=0x25, wait=0ms
panel_simple_dsi_send_cmds-322:cmd: type=0x15, len=2, data[0]=0x26, wait=0ms
panel_simple_dsi_send_cmds-322:cmd: type=0x15, len=2, data[0]=0x27, wait=0ms
panel_simple_dsi_send_cmds-322:cmd: type=0x15, len=2, data[0]=0x28, wait=0ms
panel_simple_dsi_send_cmds-322:cmd: type=0x15, len=2, data[0]=0x29, wait=0ms
panel_simple_dsi_send_cmds-322:cmd: type=0x15, len=2, data[0]=0x34, wait=0ms
panel_simple_dsi_send_cmds-322:cmd: type=0x15, len=2, data[0]=0xb5, wait=0ms
panel_simple_dsi_send_cmds-322:cmd: type=0x15, len=2, data[0]=0x5c, wait=0ms
panel_simple_dsi_send_cmds-322:cmd: type=0x15, len=2, data[0]=0x87, wait=0ms
panel_simple_dsi_send_cmds-322:cmd: type=0x15, len=2, data[0]=0x2a, wait=0ms
panel_simple_dsi_send_cmds-322:cmd: type=0x15, len=2, data[0]=0x56, wait=0ms
panel_simple_dsi_send_cmds-322:cmd: type=0x15, len=2, data[0]=0x6b, wait=0ms
panel_simple_dsi_send_cmds-322:cmd: type=0x15, len=2, data[0]=0x69, wait=0ms
panel_simple_dsi_send_cmds-322:cmd: type=0x15, len=2, data[0]=0x10, wait=0ms
panel_simple_dsi_send_cmds-322:cmd: type=0x15, len=2, data[0]=0x11, wait=0ms
panel_simple_dsi_send_cmds-322:cmd: type=0x15, len=2, data[0]=0xb6, wait=0ms
panel_simple_dsi_send_cmds-322:cmd: type=0x15, len=2, data[0]=0x51, wait=0ms
panel_simple_dsi_send_cmds-322:cmd: type=0x15, len=2, data[0]=0x9, wait=0ms
panel_simple_enable-686:p->desc->delay.enable=10
[ 1.415991] rockchip-drm display-subsystem: fb0: frame buffer device
[ 1.430435] mali ff9a0000.gpu: leakage=21
[ 1.444634] mali ff9a0000.gpu: temp=39375, pvtm=119769 (119861 + -92)
[ 1.447332] mali ff9a0000.gpu: pvtm-sel=0
[ 1.449773] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 1.452057] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 284; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 1.453762] mali ff9a0000.gpu: Probed as mali0
[ 1.460482] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 1.460549] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 1
[ 1.461165] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 1.461270] xhci-hcd xhci-hcd.10.auto: irq 231, io mem 0xfe800000
[ 1.461596] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.461628] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.461655] usb usb1: Product: xHCI Host Controller
[ 1.461679] usb usb1: Manufacturer: Linux 4.4.103 xhci-hcd
[ 1.461704] usb usb1: SerialNumber: xhci-hcd.10.auto
[ 1.463011] hub 1-0:1.0: USB hub found
[ 1.463091] hub 1-0:1.0: 1 port detected
[ 1.463710] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 1.463755] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 2
[ 1.463908] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.464153] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.464185] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.464211] usb usb2: Product: xHCI Host Controller
[ 1.464236] usb usb2: Manufacturer: Linux 4.4.103 xhci-hcd
[ 1.464260] usb usb2: SerialNumber: xhci-hcd.10.auto
[ 1.465457] hub 2-0:1.0: USB hub found
[ 1.465534] hub 2-0:1.0: 1 port detected
[ 1.469049] xhci-hcd xhci-hcd.10.auto: remove, state 1
[ 1.469109] usb usb2: USB disconnect, device number 1
[ 1.493788] xhci-hcd xhci-hcd.10.auto: Host not halted after 16000 microseconds.
[ 1.493822] xhci-hcd xhci-hcd.10.auto: Host controller not halted, aborting reset.
[ 1.493906] xhci-hcd xhci-hcd.10.auto: USB bus 2 deregistered
[ 1.493935] xhci-hcd xhci-hcd.10.auto: remove, state 1
[ 1.493969] usb usb1: USB disconnect, device number 1
[ 1.494837] xhci-hcd xhci-hcd.10.auto: USB bus 1 deregistered
[ 1.501021] rockchip-dwc3 usb@fe800000: USB peripheral connected
[ 1.501957] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 1.501976] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 1
[ 1.502186] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 1.502220] xhci-hcd xhci-hcd.11.auto: irq 232, io mem 0xfe900000
[ 1.502296] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.502304] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.502311] usb usb1: Product: xHCI Host Controller
[ 1.502317] usb usb1: Manufacturer: Linux 4.4.103 xhci-hcd
[ 1.502323] usb usb1: SerialNumber: xhci-hcd.11.auto
[ 1.502611] hub 1-0:1.0: USB hub found
[ 1.502629] hub 1-0:1.0: 1 port detected
[ 1.502762] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 1.502773] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 2
[ 1.502802] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.502843] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.502851] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.502857] usb usb2: Product: xHCI Host Controller
[ 1.502863] usb usb2: Manufacturer: Linux 4.4.103 xhci-hcd
[ 1.502869] usb usb2: SerialNumber: xhci-hcd.11.auto
[ 1.503063] hub 2-0:1.0: USB hub found
[ 1.503078] hub 2-0:1.0: 1 port detected
[ 1.503332] xhci-hcd xhci-hcd.11.auto: remove, state 1
[ 1.503345] usb usb2: USB disconnect, device number 1
[ 1.503573] xhci-hcd xhci-hcd.11.auto: USB bus 2 deregistered
[ 1.503582] xhci-hcd xhci-hcd.11.auto: remove, state 1
[ 1.503592] usb usb1: USB disconnect, device number 1
[ 1.503790] xhci-hcd xhci-hcd.11.auto: USB bus 1 deregistered
[ 1.505851] ehci-platform fe380000.usb: EHCI Host Controller
[ 1.505866] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[ 1.505992] ehci-platform fe380000.usb: irq 27, io mem 0xfe380000
[ 1.515890] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 1.515962] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.515970] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.515978] usb usb1: Product: EHCI Host Controller
[ 1.515984] usb usb1: Manufacturer: Linux 4.4.103 ehci_hcd
[ 1.515990] usb usb1: SerialNumber: fe380000.usb
[ 1.516252] hub 1-0:1.0: USB hub found
[ 1.516268] hub 1-0:1.0: 1 port detected
[ 1.520016] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.520038] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[ 1.520149] ehci-platform fe3c0000.usb: irq 29, io mem 0xfe3c0000
[ 1.529216] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.529282] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.529290] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.529297] usb usb2: Product: EHCI Host Controller
[ 1.529303] usb usb2: Manufacturer: Linux 4.4.103 ehci_hcd
[ 1.529310] usb usb2: SerialNumber: fe3c0000.usb
[ 1.529541] hub 2-0:1.0: USB hub found
[ 1.529557] hub 2-0:1.0: 1 port detected
[ 1.529911] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 1.529926] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[ 1.530020] ohci-platform fe3a0000.usb: irq 28, io mem 0xfe3a0000
[ 1.586627] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.586637] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.586645] usb usb3: Product: Generic Platform OHCI controller
[ 1.586651] usb usb3: Manufacturer: Linux 4.4.103 ohci_hcd
[ 1.586658] usb usb3: SerialNumber: fe3a0000.usb
[ 1.586900] hub 3-0:1.0: USB hub found
[ 1.586918] hub 3-0:1.0: 1 port detected
[ 1.587279] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.587294] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[ 1.587397] ohci-platform fe3e0000.usb: irq 30, io mem 0xfe3e0000
[ 1.643283] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.643293] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.643301] usb usb4: Product: Generic Platform OHCI controller
[ 1.643308] usb usb4: Manufacturer: Linux 4.4.103 ohci_hcd
[ 1.643314] usb usb4: SerialNumber: fe3e0000.usb
[ 1.643557] hub 4-0:1.0: USB hub found
[ 1.643575] hub 4-0:1.0: 1 port detected
[ 1.644115] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[ 1.644194] rockchip-dmc dmc: fail to register notify to vop.
[ 1.644766] asoc-simple-card hdmi-sound: i2s-hifi ↔ ff8a0000.i2s mapping ok
[ 1.645570] rockchip-cdndp-sound dp-sound: spdif-hifi ↔ ff870000.spdif mapping ok
[ 1.645594] hdmi-audio-codec hdmi-audio-codec.9.auto: ASoC: Failed to create Playback debugfs file
[ 1.645865] input: rockchip-cdndp-sound DP Jack as /devices/platform/dp-sound/sound/card1/input1
[ 1.646036] otg_wakelock_init: No USB transceiver found
[ 1.648393] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:03 UTC (1358499003)
[ 1.648943] It doesn’t contain Rogue gpu
[ 1.658234] vcc_sd: disabling
[ 1.659465] ret 1024
[ 1.659729] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 414; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘-8a72451d34’, rk_ko_ver is ‘5’.
[ 1.659926] Mali: Mali device driver loaded
[ 1.660215] input: rk29-keypad as /devices/platform/rockchip-key/input/input2
[ 1.660671] rockchip-pinctrl pinctrl: unsupported driver strength 20
[ 1.660681] rockchip-pinctrl pinctrl: pin_config_set op failed for pin 122
[ 1.660688] usb-ext-charge usb-charge: Error applying setting, reverse things back
[ 1.661127] usb-ext-charge usb-charge: register ext0 dev0
[ 1.661138] usb-ext-charge usb-charge: uec get notify
[ 1.661146] usb-ext-charge usb-charge: uec get ufp 1 pd 0
[ 1.661153] usb-ext-charge usb-charge: usb status 1 battery_online 0 poe_online 0
[ 1.661166] usb-ext-charge usb-charge: probe success
[ 1.662024] ALSA device list:
[ 1.662032] #0: rockchip,hdmi
[ 1.662037] #1: rockchip-cdndp-sound
[ 1.662471] Freeing unused kernel memory: 832K
[ 1.664917] init: init first stage started!
[ 1.701692] audit: type=1403 audit(1358499003.550:2): policy loaded auid=4294967295 ses=4294967295
[ 1.702110] init: (Initializing SELinux non-enforcing took 0.04s.)
[ 1.704217] init: init second stage started!
[ 1.706661] init: Setting ro.rk.soc=rk3399
[ 1.706717] init: OK,EMMC DRIVERS INIT OK
[ 1.706735] init: property_set(“ro.boot.mode”, “emmc”) failed
[ 1.706771] init: property_set(“ro.hardware”, “rk30board”) failed
[ 1.707926] init: Running restorecon…
[ 1.745345] init: waitpid failed: No child processes
[ 1.745563] init: (Loading properties from /default.prop took 0.00s.)
[ 1.746837] init: /init.rc: 588: invalid keyword ‘echo’
[ 1.747100] init: (Parsing /init.environ.rc took 0.00s.)
[ 1.747321] init: (Parsing /init.usb.rc took 0.00s.)
[ 1.747865] init: (Parsing init.rk30board.bootmode.emmc.rc took 0.00s.)
[ 1.748277] init: (Parsing init.rk30board.usb.rc took 0.00s.)
[ 1.748312] init: (Parsing init.rk30board.environment.rc took 0.00s.)
[ 1.748363] init: could not import file ‘/init.stt_trace.rc’ from ‘/init.debug.rc’: No such file or directory
[ 1.748385] init: could not import file ‘/init.logs.rc’ from ‘/init.debug.rc’: No such file or directory
[ 1.748407] init: could not import file ‘/init.crashlogd.rc’ from ‘/init.debug.rc’: No such file or directory
[ 1.748429] init: could not import file ‘/init.coredump.rc’ from ‘/init.debug.rc’: No such file or directory
[ 1.748450] init: could not import file ‘/init.log-watch.rc’ from ‘/init.debug.rc’: No such file or directory
[ 1.748488] init: (Parsing /init.kernel.rc took 0.00s.)
[ 1.748559] init: (Parsing /init.debug-charging.rc took 0.00s.)
[ 1.748571] init: (Parsing /init.debug.rc took 0.00s.)
[ 1.748581] init: (Parsing init.rockchip.rc took 0.00s.)
[ 1.748830] init: (Parsing init.connectivity.rc took 0.00s.)
[ 1.748853] init: could not import file ‘init.box.samba.rc’ from ‘/init.rk30board.rc’: No such file or directory
[ 1.748923] init: (Parsing init.rk3399.rc took 0.00s.)
[ 1.748973] init: init.tablet.rc: 22: invalid keyword ‘ioprio’
[ 1.748992] init: (Parsing init.tablet.rc took 0.00s.)
[ 1.749013] init: could not import file ‘init.car.rc’ from ‘/init.rk30board.rc’: No such file or directory
[ 1.749034] init: could not import file ‘init.optee.rc’ from ‘/init.rk30board.rc’: No such file or directory
[ 1.749047] init: (Parsing /init.rk30board.rc took 0.00s.)
[ 1.749478] init: (Parsing /init.usb.configfs.rc took 0.00s.)
[ 1.749542] init: (Parsing /init.zygote64_32.rc took 0.00s.)
[ 1.749553] init: (Parsing /init.rc took 0.00s.)
[ 1.749899] init: Starting service ‘ueventd’…
[ 1.752185] audit: type=1400 audit(1358499003.600:3): avc: denied { getattr } for pid=1 comm=“init” path=“/sys/kernel/debug/tracing/trace_marker” dev=“tracefs” ino=3094 scontext=u:r:init:s0 tcont1
[ 1.755525] ueventd: ueventd started!
[ 1.757746] ueventd: invalid gid ‘trace’
[ 1.770170] vendor storage:20160801 ret = 0
[ 1.835909] usb 2-1: new high-speed USB device number 2 using ehci-platform
[ 1.935592] init: write_file: Unable to open ‘/proc/sys/kernel/panic_on_stackoverflow’: No such file or directory
[ 1.935630] init: Waiting for /dev/.coldboot_done…
[ 1.960676] usb 2-1: New USB device found, idVendor=1a40, idProduct=0101
[ 1.960700] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.960708] usb 2-1: Product: USB 2.0 Hub [MTT]
[ 1.961455] hub 2-1:1.0: USB hub found
[ 1.961600] hub 2-1:1.0: 4 ports detected
[ 1.991439] ueventd: Coldboot took 0.23s.
[ 1.996417] init: Waiting for /dev/.coldboot_done took 0.06s.
[ 1.996518] init: /dev/hw_random not found
[ 1.997215] keychord: using input dev ff420030.pwm for fevent
[ 1.997226] keychord: using input dev rk29-keypad for fevent
[ 2.003137] init: write_file: Unable to open ‘/proc/cpu/alignment’: No such file or directory
[ 2.017691] Registered swp emulation handler
[ 2.017960] init: write_file: Unable to open ‘/sys/module/rockchip_pm/parameters/policy’: No such file or directory
[ 2.019302] fs_mgr: Warning: unknown flag resize
[ 2.019470] init: /dev/hw_random not found
[ 2.019627] init: write_file: Unable to open ‘/sys/block/mmcblk0/bdi/read_ahead_kb’: No such file or directory
[ 2.020403] fs_mgr: Warning: unknown flag resize
[ 2.024293] EXT4-fs (mmcblk1p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 2.024487] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/system,target=/system,type=ext4)=0
[ 2.025022] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/cache,/cache,ext4)=-1: No such file or directory
[ 2.025922] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/cache
[ 2.032766] random: e2fsck: uninitialized urandom read (40 bytes read, 38 bits of entropy available)
[ 2.079317] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.079317]
[ 2.079352] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/cache: recovering journal
[ 2.079352]
[ 2.079364] e2fsck: Superblock last mount time is in the future.
[ 2.079364]
[ 2.079375] e2fsck: (by less than a day, probably due to the hardware clock being incorrectly set) Fix? yes
[ 2.079375]
[ 2.079386] e2fsck:
[ 2.079386]
[ 2.079394] e2fsck: Setting free inodes count to 8159 (was 8160)
[ 2.079394]
[ 2.079403] e2fsck: Setting free blocks count to 30901 (was 30904)
[ 2.079403]
[ 2.079413] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/cache: clean, 33/8192 files, 1867/32768 blocks
[ 2.079413]
[ 2.083366] EXT4-fs (mmcblk1p9): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.083432] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/cache,target=/cache,type=ext4)=0
[ 2.084540] EXT4-fs (mmcblk1p11): Ignoring removed nomblk_io_submit option
[ 2.086098] EXT4-fs (mmcblk1p11): recovery complete
[ 2.086110] EXT4-fs (mmcblk1p11): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[ 2.086150] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/metadata,/metadata,ext4)=0: Success
[ 2.097193] fs_mgr: check_fs(): unmount(/metadata) succeeded
[ 2.097220] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/metadata
[ 2.098271] random: e2fsck: uninitialized urandom read (40 bytes read, 42 bits of entropy available)
[ 2.109532] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.109532]
[ 2.109563] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/metadata: clean, 11/1024 files, 1102/4096 blocks (check after next mount)
[ 2.109563]
[ 2.112612] EXT4-fs (mmcblk1p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.112673] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/metadata,target=/metadata,type=ext4)=0
[ 2.112741] fs_mgr: Running /system/bin/fsck.f2fs -a /dev/block/platform/fe330000.sdhci/by-name/userdata
[ 2.116053] fsck.f2fs: executing /system/bin/fsck.f2fs failed: No such file or directory
[ 2.116053]
[ 2.116079] fsck.f2fs: fsck.f2fs terminated by exit(255)
[ 2.116079]
[ 2.161850] F2FS-fs (mmcblk1p13): Mounted with checkpoint version = 6b
[ 2.162322] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/userdata,target=/data,type=f2fs)=0
[ 2.168352] init: (Parsing /system/etc/init/atrace.rc took 0.00s.)
[ 2.169226] init: (Parsing /system/etc/init/audioserver.rc took 0.00s.)
[ 2.169826] init: (Parsing /system/etc/init/bootanim.rc took 0.00s.)
[ 2.170542] init: (Parsing /system/etc/init/bootstat.rc took 0.00s.)
[ 2.171244] init: (Parsing /system/etc/init/cameraserver.rc took 0.00s.)
[ 2.171899] init: (Parsing /system/etc/init/debuggerd.rc took 0.00s.)
[ 2.172568] init: (Parsing /system/etc/init/debuggerd64.rc took 0.00s.)
[ 2.173325] init: (Parsing /system/etc/init/drmserver.rc took 0.00s.)
[ 2.174294] init: (Parsing /system/etc/init/dumpstate.rc took 0.00s.)
[ 2.174940] init: (Parsing /system/etc/init/gatekeeperd.rc took 0.00s.)
[ 2.175668] init: (Parsing /system/etc/init/init-debug.rc took 0.00s.)
[ 2.176386] init: (Parsing /system/etc/init/installd.rc took 0.00s.)
[ 2.177071] init: (Parsing /system/etc/init/keystore.rc took 0.00s.)
[ 2.177726] init: (Parsing /system/etc/init/lmkd.rc took 0.00s.)
[ 2.178969] init: (Parsing /system/etc/init/logcatd.rc took 0.00s.)
[ 2.179855] init: (Parsing /system/etc/init/logd.rc took 0.00s.)
[ 2.180540] init: (Parsing /system/etc/init/mdnsd.rc took 0.00s.)
[ 2.181199] init: (Parsing /system/etc/init/mediacodec.rc took 0.00s.)
[ 2.181849] init: (Parsing /system/etc/init/mediadrmserver.rc took 0.00s.)
[ 2.182549] init: (Parsing /system/etc/init/mediaextractor.rc took 0.00s.)
[ 2.183285] init: (Parsing /system/etc/init/mediaserver.rc took 0.00s.)
[ 2.183962] init: (Parsing /system/etc/init/mtpd.rc took 0.00s.)
[ 2.184632] init: (Parsing /system/etc/init/netd.rc took 0.00s.)
[ 2.185276] init: (Parsing /system/etc/init/perfprofd.rc took 0.00s.)
[ 2.185990] init: (Parsing /system/etc/init/racoon.rc took 0.00s.)
[ 2.186684] init: ignored duplicate definition of service 'ril-daemon’init: (Parsing /system/etc/init/rild.rc took 0.00s.)
[ 2.187518] init: (Parsing /system/etc/init/servicemanager.rc took 0.00s.)
[ 2.188191] init: (Parsing /system/etc/init/surfaceflinger.rc took 0.00s.)
[ 2.188911] init: (Parsing /system/etc/init/uncrypt.rc took 0.00s.)
[ 2.189651] init: (Parsing /system/etc/init/vdc.rc took 0.00s.)
[ 2.190429] init: (Parsing /system/etc/init/vold.rc took 0.00s.)
[ 2.192960] init: property_set(“ro.board.platform”, “rk3399”) failed
[ 2.194309] init: property_set(“ro.rk.screenoff_time”, “60000”) failed
[ 2.194840] init: property_set(“ro.rk.screenshot_enable”, “true”) failed
[ 2.195169] init: (Loading properties from /system/build.prop took 0.00s.)
[ 2.195312] init: (Loading properties from /vendor/build.prop took 0.00s.)
[ 2.195409] init: (Loading properties from /factory/factory.prop took 0.00s.)
[ 2.195655] fs_mgr: Warning: unknown flag resize
[ 2.195992] init: /recovery not specified in fstab
[ 2.196265] init: Starting service ‘healthd’…
[ 2.197182] init: cannot find ‘/system/bin/displayd’ (No such file or directory), disabling ‘displayd’
[ 2.199633] binder: 202:202 transaction failed 29189/-22, size 0-0 line 2951
[ 2.200976] init: Starting service ‘lmkd’…
[ 2.202553] init: Starting service ‘servicemanager’…
[ 2.204079] init: Starting service ‘surfaceflinger’…
[ 2.205904] init: Starting service ‘vold’…
[ 2.207566] random: surfaceflinger: uninitialized urandom read (40 bytes read, 46 bits of entropy available)
[ 2.210005] random: servicemanager: uninitialized urandom read (40 bytes read, 46 bits of entropy available)
[ 2.215151] random: lmkd: uninitialized urandom read (40 bytes read, 46 bits of entropy available)
[ 2.222707] init: insmod: open(“/system/lib/modules/ump.ko”) failed: No such file or directory
[ 2.222816] random: vold: uninitialized urandom read (40 bytes read, 47 bits of entropy available)
[ 2.222889] init: insmod: open(“/system/lib/modules/mali.ko”) failed: No such file or directoryinit: insmod: open(“/system/lib/modules/mali_kbase.ko”) failed: No such file or directoryinit: insmod: e
[ 2.227006] zram0: detected capacity change from 0 to 533413888
[ 2.229492] random: mkswap: uninitialized urandom read (40 bytes read, 49 bits of entropy available)
[ 2.244231] random: mkswap: uninitialized urandom read (16 bytes read, 50 bits of entropy available)
[ 2.249700] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
[ 2.251124] init: Starting service ‘debuggerd’…
[ 2.251709] init: Starting service ‘debuggerd64’…
[ 2.252852] init: Not bootcharting.
[ 2.264450] random: debuggerd64: uninitialized urandom read (40 bytes read, 52 bits of entropy available)
[ 2.271194] random: debuggerd: uninitialized urandom read (40 bytes read, 53 bits of entropy available)
[ 2.415113] fs_mgr: Warning: unknown flag resize
[ 2.438034] init: Starting service ‘exec 1 (/system/bin/tzdatacheck)’…
[ 2.453140] init: Service ‘exec 1 (/system/bin/tzdatacheck)’ (pid 221) exited with status 0
[ 2.455945] audit: type=1400 audit(1358499004.306:4): avc: denied { setattr } for pid=1 comm=“init” name=“cifsmanager” dev=“mmcblk1p13” ino=86 scontext=u:r:init:s0 tcontext=u:object_r:cifsmanager1
[ 2.457317] F2FS-fs (mmcblk1p13): acl options not supported
[ 2.457331] F2FS-fs (mmcblk1p13): Unrecognized mount option “errors=panic” or missing value
[ 2.458520] init: (Loading properties from /data/local.prop took 0.00s.)
[ 2.465331] init: Starting service ‘logd’…
[ 2.466058] init: Starting service ‘logd-reinit’…
[ 2.466967] init: write_file: Unable to open ‘/proc/sys/vm/min_free_order_shift’: No such file or directory
[ 2.468184] init: SELinux: Could not stat /sys/devices/system/cpu/cpufreq/interactive: No such file or directory.
[ 2.469012] init: write_file: Unable to open ‘/proc/sys/vm/lazy_vfree_tlb_flush_all_threshold’: No such file or directory
[ 2.470622] audit: type=1400 audit(1358499004.320:5): avc: denied { relabelto } for pid=1 comm=“init” name=“recovery” dev=“tmpfs” ino=15274 scontext=u:r:init:s0 tcontext=u:object_r:recovery_block1
[ 2.470698] audit: type=1400 audit(1358499004.320:6): avc: denied { relabelto } for pid=1 comm=“init” name=“boot” dev=“tmpfs” ino=15270 scontext=u:r:init:s0 tcontext=u:object_r:boot_block_device:1
[ 2.471690] audit: type=1400 audit(1358499004.320:7): avc: denied { getattr } for pid=1 comm=“init” path=“/system/xbin/fsu” dev=“mmcblk1p10” ino=2689 scontext=u:r:init:s0 tcontext=u:object_r:su_e1
[ 2.471730] init: Starting service ‘fsud’…
[ 2.472179] init: Starting service ‘vm_daemon’…
[ 2.473658] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 2.473678] init: write: cannot expand ‘${ro.serialno}’
[ 2.473983] audit: type=1400 audit(1358499004.323:12): avc: denied { transition } for pid=236 comm=“init” path=“/system/xbin/fsu” dev=“mmcblk1p10” ino=2689 scontext=u:r:init:s0 tcontext=u:r:syste1
[ 2.474033] audit: type=1400 audit(1358499004.323:13): avc: denied { entrypoint } for pid=236 comm=“init” path=“/system/xbin/fsu” dev=“mmcblk1p10” ino=2689 scontext=u:r:systemdaemon:s0 tcontext=u1
[ 2.474309] file system registered
[ 2.475456] audit: type=1400 audit(1358499004.323:17): avc: denied { rlimitinh } for pid=236 comm=“fsu” scontext=u:r:init:s0 tcontext=u:r:systemdaemon:s0 tclass=process permissive=1
[ 2.478310] using random self ethernet address
[ 2.478323] using random host ethernet address
[ 2.478369] init: write_file: Unable to open ‘/config/usb_gadget/g1/functions/rndis.gs4/wceis’: Permission denied
[ 2.483574] init: Starting service ‘console’…
[ 2.484203] init: Starting service ‘adbd’…
[ 2.484896] init: cannot find ‘/system/bin/update_verifier’ (No such file or directory), disabling ‘exec 2 (/system/bin/update_verifier)’
[ 2.485173] init: Starting service ‘ril-daemon’…
[ 2.485678] init: cannot find ‘/system/bin/install-recovery.sh’ (No such file or directory), disabling ‘flash_recovery’
[ 2.486014] init: Starting service ‘drmservice’…
[ 2.486649] init: cannot find ‘/system/bin/bplus_helper’ (No such file or directory), disabling ‘bplus_helper’
[ 2.487073] init: Service up_eth0 does not have a SELinux domain defined.
[ 2.487091] init: cannot find ‘/system/bin/rk_store_keybox’ (No such file or directory), disabling ‘rk_store_keybox’
[ 2.487290] init: Starting service ‘akmd’…
[ 2.488312] init: Starting service ‘zygote’…
[ 2.489105] init: Starting service ‘zygote_secondary’…
[ 2.490173] init: Starting service ‘audioserver’…
[ 2.491144] init: Starting service ‘cameraserver’…
[ 2.491737] init: couldn’t write 248 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[ 2.492079] init: Starting service ‘drm’…
[ 2.495514] init: Starting service ‘installd’…
[ 2.496640] init: Starting service ‘keystore’…
[ 2.497485] init: Starting service ‘mediacodec’…
[ 2.498314] init: Starting service ‘mediadrm’…
[ 2.499013] init: Starting service ‘mediaextractor’…
[ 2.500177] init: Starting service ‘media’…
[ 2.501036] init: Starting service ‘netd’…
[ 2.501846] init: Service ‘logd-reinit’ (pid 235) exited with status 145
[ 2.502428] init: Starting service ‘gatekeeperd’…
[ 2.503653] logd.auditd: start
[ 2.503733] logd.klogd: 2501223184
[ 2.506318] init: Starting service ‘perfprofd’…
[ 2.524404] ret = ffffffffffffffff
[ 2.526555] init: property ‘sys.serialno’ doesn’t exist while expanding ‘${sys.serialno}’
[ 2.526595] init: setprop: cannot expand ‘${sys.serialno}’
[ 2.527014] init: Service ‘akmd’ (pid 243) exited with status 254
[ 2.537305] init: avc: denied { set } for property=telephony.lteOnCdmaDevice pid=241 uid=0 gid=1001 scontext=u:r:rild:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=1
[ 2.541392] init: Service ‘drmservice’ (pid 242) exited with status 0
[ 2.691268] read descriptors
[ 2.691300] read strings
[ 2.768561] type=1400 audit(1358499004.616:35): avc: denied { execute } for pid=281 comm=“audioserver” name=“sh” dev=“mmcblk1p10” ino=386 scontext=u:r:audioserver:s0 tcontext=u:object_r:shell_exec:sf
[ 2.769108] type=1400 audit(1358499004.616:36): avc: denied { read open } for pid=281 comm=“audioserver” path=“/system/bin/sh” dev=“mmcblk1p10” ino=386 scontext=u:r:audioserver:s0 tcontext=u:object_f
[ 2.796217] type=1400 audit(1358499004.623:37): avc: denied { execute_no_trans } for pid=281 comm=“audioserver” path=“/system/bin/sh” dev=“mmcblk1p10” ino=386 scontext=u:r:audioserver:s0 tcontext=u:f
[ 2.796324] type=1400 audit(1358499004.623:38): avc: denied { getattr } for pid=281 comm=“sh” path=“/system/bin/sh” dev=“mmcblk1p10” ino=386 scontext=u:r:audioserver:s0 tcontext=u:object_r:shell_exef
[ 2.796396] type=1400 audit(1358499004.636:39): avc: denied { getattr } for pid=281 comm=“sh” path=“/system/bin/toybox” dev=“mmcblk1p10” ino=419 scontext=u:r:audioserver:s0 tcontext=u:object_r:toolbf
[ 2.796466] type=1400 audit(1358499004.636:40): avc: denied { execute } for pid=281 comm=“sh” name=“toybox” dev=“mmcblk1p10” ino=419 scontext=u:r:audioserver:s0 tcontext=u:object_r:toolbox_exec:s0 tf
[ 2.796533] type=1400 audit(1358499004.636:41): avc: denied { read open } for pid=281 comm=“sh” path=“/system/bin/toybox” dev=“mmcblk1p10” ino=419 scontext=u:r:audioserver:s0 tcontext=u:object_r:toof
[ 2.796602] type=1400 audit(1358499004.636:42): avc: denied { execute_no_trans } for pid=281 comm=“sh” path=“/system/bin/toybox” dev=“mmcblk1p10” ino=419 scontext=u:r:audioserver:s0 tcontext=u:objecf
[ 2.882660] type=1400 audit(1358499004.730:43): avc: denied { create } for pid=247 comm=“audioserver” scontext=u:r:audioserver:s0 tcontext=u:r:audioserver:s0 tclass=netlink_kobject_uevent_soc
[ 2.882835] type=1400 audit(1358499004.730:44): avc: denied { setopt } for pid=247 comm=“audioserver” scontext=u:r:audioserver:s0 tcontext=u:r:audioserver:s0 tclass=netlink_kobject_uevent_soc
[ 2.882909] type=1400 audit(1358499004.730:45): avc: denied { bind } for pid=247 comm=“audioserver” scontext=u:r:audioserver:s0 tcontext=u:r:audioserver:s0 tclass=netlink_kobject_uevent_soc
[ 3.062974] android_work: sent uevent USB_STATE=CONNECTED
[ 3.066315] type=1400 audit(1358499004.913:46): avc: denied { read } for pid=247 comm=“audioserver” scontext=u:r:audioserver:s0 tcontext=u:r:audioserver:s0 tclass=netlink_kobject_uevent_soc
[ 3.066624] android_work: sent uevent USB_STATE=DISCONNECTED
[ 3.202261] healthd: BatteryCurrentNowPath not found
[ 3.202295] healthd: BatteryCycleCountPath not found
[ 3.211022] android_work: sent uevent USB_STATE=CONNECTED
[ 3.215482] configfs-gadget gadget: high-speed config #1: b
[ 3.215756] android_work: sent uevent USB_STATE=CONFIGURED
[ 3.467974] phy phy-ff770000.syscon:usb2-phy@e450.2: charger = USB_SDP_CHARGER
[ 3.541800] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 3.541991] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 3.553439] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 3.553457] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 3.553467] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 3.553478] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 3.553485] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 3.564706] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 3.564918] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 3.595348] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 3.595539] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 3.607701] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 3.607714] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 3.607725] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 3.607735] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 3.607883] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 3.611610] android_work: sent uevent USB_STATE=DISCONNECTED
[ 3.614009] configfs-gadget gadget: unbind function ‘mtp’/ffffffc0eedbe200
[ 3.614105] android_work: did not send uevent (0 0 (null))
[ 3.614144] configfs-gadget gadget: unbind function ‘Function FS Gadget’/ffffffc0eedd1038
[ 3.619468] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 3.619714] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 3.665150] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 3.665164] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 3.665174] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 3.665184] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 3.665192] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 3.676142] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 3.676325] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 3.679243] usb-ext-charge usb-charge: adc value = 355
[ 3.679272] usb-ext-charge usb-charge: usb status 1 battery_online 1 poe_online 0
[ 3.712532] panel_simple_dsi_send_cmds-322:cmd: type=0x5, len=1, data[0]=0x28, wait=5ms
panel_simple_dsi_send_cmds-322:cmd: type=0x5, len=1, data[0]=0x10, wait=120ms
[ 3.750774] android_work: did not send uevent (0 0 (null))
[ 3.752882] random: nonblocking pool is initialized
panel_simple: set lcd-en(36) active=0
panel_simple: set lcd-rst(157) active=0
[ 4.018905] android_work: sent uevent USB_STATE=CONNECTED
[ 4.019676] type=1400 audit(1358499005.870:47): avc: denied { read } for pid=247 comm=“audioserver” scontext=u:r:audioserver:s0 tcontext=u:r:audioserver:s0 tclass=netlink_kobject_uevent_soc
[ 4.022472] android_work: sent uevent USB_STATE=DISCONNECTED
[ 4.091958] BUG: Bad page state in process kworker/u12:1 pfn:f5c00
[ 4.091988] page:ffffffbdc3d70000 count:0 mapcount:0 mapping:ffffffc0f07696b8 index:0x0
[ 4.091995] flags: 0x1002c(referenced|uptodate|lru|mappedtodisk)
[ 4.092016] page dumped because: PAGE_FLAGS_CHECK_AT_FREE flag(s) set
[ 4.092021] bad because of flags:
[ 4.092026] flags: 0x20(lru)
[ 4.092257] Disabling lock debugging due to kernel taint
[ 4.092265] BUG: Bad page state in process kworker/u12:1 pfn:f5c01
[ 4.092273] page:ffffffbdc3d70040 count:0 mapcount:0 mapping:ffffffc0f07292a0 index:0x2e
[ 4.092279] flags: 0x10028(uptodate|lru|mappedtodisk)
[ 4.092293] page dumped because: PAGE_FLAGS_CHECK_AT_FREE flag(s) set
[ 4.092299] bad because of flags:
[ 4.092313] flags: 0x20(lru)
[ 4.092364] Call trace:
[ 4.092372] [] dump_backtrace+0x0/0x1cc
[ 4.092381] [] show_stack+0x14/0x1c
[ 4.092391] [] dump_stack+0x94/0xb4
[ 4.092399] [] bad_page+0xec/0x114
[ 4.092406] [] free_pages_prepare+0x100/0x260
[ 4.092415] [] free_hot_cold_page+0x34/0x178
[ 4.092423] [] __free_pages+0x34/0x44
[ 4.092430] [] free_reserved_area+0xc0/0x10c
[ 4.092440] [] rockchip_free_loader_memory+0xe0/0xfc
[ 4.092449] [] rockchip_drm_fb_destroy+0xc4/0xe4
[ 4.092458] [] drm_framebuffer_free+0x70/0x84
[ 4.092465] [] drm_framebuffer_unreference+0x6c/0x78
[ 4.092475] [] vop_fb_unref_worker+0x20/0x28
[ 4.092482] [] flip_worker+0xa8/0xe8
[ 4.092492] [] process_one_work+0x228/0x3f4
[ 4.092500] [] worker_thread+0x304/0x418
[ 4.092508] [] kthread+0xe8/0xf0
[ 4.092516] [] ret_from_fork+0x10/0x40
[ 4.103900] BUG: Bad page state in process kworker/u12:1 pfn:f5c02
[ 4.103930] page:ffffffbdc3d70080 count:0 mapcount:0 mapping:ffffffc0f07292a0 index:0x2d
[ 4.103937] flags: 0x10028(uptodate|lru|mappedtodisk)
[ 4.103957] page dumped because: PAGE_FLAGS_CHECK_AT_FREE flag(s) set
[ 4.103963] bad because of flags:
[ 4.103968] flags: 0x20(lru)
[ 4.104020] Call trace:
[ 4.104034] [] dump_backtrace+0x0/0x1cc
[ 4.104044] [] show_stack+0x14/0x1c
[ 4.104055] [] dump_stack+0x94/0xb4
[ 4.104066] [] bad_page+0xec/0x114
[ 4.104073] [] free_pages_prepare+0x100/0x260
[ 4.104083] [] free_hot_cold_page+0x34/0x178
[ 4.104091] [] __free_pages+0x34/0x44
[ 4.104099] [] free_reserved_area+0xc0/0x10c
[ 4.104110] [] rockchip_free_loader_memory+0xe0/0xfc
[ 4.104118] [] rockchip_drm_fb_destroy+0xc4/0xe4
[ 4.104128] [] drm_framebuffer_free+0x70/0x84
[ 4.104135] [] drm_framebuffer_unreference+0x6c/0x78
[ 4.104145] [] vop_fb_unref_worker+0x20/0x28
[ 4.104154] [] flip_worker+0xa8/0xe8
[ 4.104165] [] process_one_work+0x228/0x3f4
[ 4.104180] [] worker_thread+0x304/0x418
[ 4.104194] [] kthread+0xe8/0xf0
[ 4.104203] [] ret_from_fork+0x10/0x40
[ 4.104210] BUG: Bad page state in process kworker/u12:1 pfn:f5c03
[ 4.104218] page:ffffffbdc3d700c0 count:0 mapcount:0 mapping:ffffffc0f07292a0 index:0x2c
[ 4.104224] flags: 0x10268(uptodate|lru|active|arch_1|mappedtodisk)
[ 4.104245] page dumped because: PAGE_FLAGS_CHECK_AT_FREE flag(s) set
[ 4.104250] bad because of flags:
[ 4.104255] flags: 0x60(lru|active)
[ 4.104294] Call trace:
[ 4.104302] [] dump_backtrace+0x0/0x1cc
[ 4.104310] [] show_stack+0x14/0x1c
[ 4.104319] [] dump_stack+0x94/0xb4
[ 4.104328] [] bad_page+0xec/0x114
[ 4.104336] [] free_pages_prepare+0x100/0x260
[ 4.104344] [] free_hot_cold_page+0x34/0x178
[ 4.104352] [] __free_pages+0x34/0x44
[ 4.104360] [] free_reserved_area+0xc0/0x10c
[ 4.104370] [] rockchip_free_loader_memory+0xe0/0xfc
[ 4.104378] [] rockchip_drm_fb_destroy+0xc4/0xe4
[ 4.104389] [] drm_framebuffer_free+0x70/0x84
[ 4.104397] [] drm_framebuffer_unreference+0x6c/0x78
[ 4.104405] [] vop_fb_unref_worker+0x20/0x28
[ 4.104413] [] flip_worker+0xa8/0xe8
[ 4.104421] [] process_one_work+0x228/0x3f4
[ 4.104430] [] worker_thread+0x304/0x418
[ 4.104438] [] kthread+0xe8/0xf0
[ 4.104446] [] ret_from_fork+0x10/0x40
[ 4.104453] BUG: Bad page state in process kworker/u12:1 pfn:f5c04
[ 4.104461] page:ffffffbdc3d70100 count:0 mapcount:0 mapping:ffffffc0f07292a0 index:0x2b
[ 4.104467] flags: 0x10268(uptodate|lru|active|arch_1|mappedtodisk)
[ 4.104487] page dumped because: PAGE_FLAGS_CHECK_AT_FREE flag(s) set
[ 4.104492] bad because of flags:
[ 4.104497] flags: 0x60(lru|active)
[ 4.104536] Call trace:
[ 4.104544] [] dump_backtrace+0x0/0x1cc
[ 4.104553] [] show_stack+0x14/0x1c
[ 4.104563] [] dump_stack+0x94/0xb4
[ 4.104571] [] bad_page+0xec/0x114
[ 4.104578] [] free_pages_prepare+0x100/0x260
[ 4.104586] [] free_hot_cold_page+0x34/0x178
[ 4.104594] [] __free_pages+0x34/0x44
[ 4.104602] [] free_reserved_area+0xc0/0x10c
[ 4.104611] [] rockchip_free_loader_memory+0xe0/0xfc
[ 4.104619] [] rockchip_drm_fb_destroy+0xc4/0xe4
[ 4.104627] [] drm_framebuffer_free+0x70/0x84
[ 4.104635] [] drm_framebuffer_unreference+0x6c/0x78
[ 4.104644] [] vop_fb_unref_worker+0x20/0x28
[ 4.104652] [] flip_worker+0xa8/0xe8
[ 4.104661] [] process_one_work+0x228/0x3f4
[ 4.104669] [] worker_thread+0x304/0x418
[ 4.104676] [] kthread+0xe8/0xf0
[ 4.104684] [] ret_from_fork+0x10/0x40
[ 4.104691] BUG: Bad page state in process kworker/u12:1 pfn:f5c05
[ 4.104699] page:ffffffbdc3d70140 count:0 mapcount:0 mapping:ffffffc0f07292a0 index:0x2a
[ 4.104705] flags: 0x10268(uptodate|lru|active|arch_1|mappedtodisk)
[ 4.104724] page dumped because: PAGE_FLAGS_CHECK_AT_FREE flag(s) set
[ 4.104729] bad because of flags:
[ 4.104734] flags: 0x60(lru|active)
[ 4.104773] Call trace:
[ 4.104782] [] dump_backtrace+0x0/0x1cc
[ 4.104790] [] show_stack+0x14/0x1c
[ 4.104799] [] dump_stack+0x94/0xb4
[ 4.104806] [] bad_page+0xec/0x114
[ 4.104814] [] free_pages_prepare+0x100/0x260
[ 4.104823] [] free_hot_cold_page+0x34/0x178
[ 4.104831] [] __free_pages+0x34/0x44
[ 4.104839] [] free_reserved_area+0xc0/0x10c
[ 4.104847] [] rockchip_free_loader_memory+0xe0/0xfc
[ 4.104856] [] rockchip_drm_fb_destroy+0xc4/0xe4
[ 4.104863] [] drm_framebuffer_free+0x70/0x84
[ 4.104871] [] drm_framebuffer_unreference+0x6c/0x78
[ 4.104879] [] vop_fb_unref_worker+0x20/0x28
[ 4.104887] [] flip_worker+0xa8/0xe8
[ 4.104895] [] process_one_work+0x228/0x3f4
[ 4.104903] [] worker_thread+0x304/0x418
[ 4.104910] [] kthread+0xe8/0xf0
[ 4.104917] [] ret_from_fork+0x10/0x40
[ 4.104923] BUG: Bad page state in process kworker/u12:1 pfn:f5c06
[ 4.104930] page:ffffffbdc3d70180 count:0 mapcount:0 mapping:ffffffc0f07292a0 index:0x29
[ 4.104936] flags: 0x10268(uptodate|lru|active|arch_1|mappedtodisk)
[ 4.104956] page dumped because: PAGE_FLAGS_CHECK_AT_FREE flag(s) set
[ 4.104961] bad because of flags:
[ 4.104966] flags: 0x60(lru|active)
[ 4.105004] Call trace:
[ 4.105011] [] dump_backtrace+0x0/0x1cc
[ 4.105020] [] show_stack+0x14/0x1c
[ 4.105027] [] dump_stack+0x94/0xb4
[ 4.105036] [] bad_page+0xec/0x114
[ 4.105043] [] free_pages_prepare+0x100/0x260
[ 4.105051] [] free_hot_cold_page+0x34/0x178
[ 4.105059] [] __free_pages+0x34/0x44
[ 4.105067] [] free_reserved_area+0xc0/0x10c
[ 4.105075] [] rockchip_free_loader_memory+0xe0/0xfc
[ 4.105084] [] rockchip_drm_fb_destroy+0xc4/0xe4
[ 4.105092] [] drm_framebuffer_free+0x70/0x84
[ 4.105100] [] drm_framebuffer_unreference+0x6c/0x78
[ 4.105109] [] vop_fb_unref_worker+0x20/0x28
[ 4.105116] [] flip_worker+0xa8/0xe8
[ 4.105125] [] process_one_work+0x228/0x3f4
[ 4.105133] [] worker_thread+0x304/0x418
[ 4.105141] [] kthread+0xe8/0xf0
[ 4.105148] [] ret_from_fork+0x10/0x40
[ 4.105155] BUG: Bad page state in process kworker/u12:1 pfn:f5c07
[ 4.105163] page:ffffffbdc3d701c0 count:0 mapcount:0 mapping:ffffffc0f07292a0 index:0x28
[ 4.105168] flags: 0x10268(uptodate|lru|active|arch_1|mappedtodisk)
[ 4.105187] page dumped because: PAGE_FLAGS_CHECK_AT_FREE flag(s) set
[ 4.105193] bad because of flags:
[ 4.105198] flags: 0x60(lru|active)
[ 4.105235] Call trace:
[ 4.105243] [] dump_backtrace+0x0/0x1cc
[ 4.105251] [] show_stack+0x14/0x1c
[ 4.105259] [] dump_stack+0x94/0xb4
[ 4.105267] [] bad_page+0xec/0x114
[ 4.105275] [] free_pages_prepare+0x100/0x260
[ 4.105283] [] free_hot_cold_page+0x34/0x178
[ 4.105291] [] __free_pages+0x34/0x44
[ 4.105298] [] free_reserved_area+0xc0/0x10c
[ 4.105307] [] rockchip_free_loader_memory+0xe0/0xfc
[ 4.105315] [] rockchip_drm_fb_destroy+0xc4/0xe4
[ 4.105323] [] drm_framebuffer_free+0x70/0x84
[ 4.105330] [] drm_framebuffer_unreference+0x6c/0x78
[ 4.105339] [] vop_fb_unref_worker+0x20/0x28
[ 4.105347] [] flip_worker+0xa8/0xe8
[ 4.105354] [] process_one_work+0x228/0x3f4
[ 4.105362] [] worker_thread+0x304/0x418
[ 4.105369] [] kthread+0xe8/0xf0
[ 4.105376] [] ret_from_fork+0x10/0x40
[ 4.105383] BUG: Bad page state in process kworker/u12:1 pfn:f5c08
[ 4.105390] page:ffffffbdc3d70200 count:0 mapcount:0 mapping:ffffffc0f07292a0 index:0x27
[ 4.105396] flags: 0x10268(uptodate|lru|active|arch_1|mappedtodisk)
[ 4.105414] page dumped because: PAGE_FLAGS_CHECK_AT_FREE flag(s) set
[ 4.105419] bad because of flags:
[ 4.105424] flags: 0x60(lru|active)
[ 4.105459] Call trace:
[ 4.105467] [] dump_backtrace+0x0/0x1cc
[ 4.105475] [] show_stack+0x14/0x1c
[ 4.105483] [] dump_stack+0x94/0xb4
[ 4.105491] [] ba[[[[u[[[ 4.107874] BUG: [[[[[[[[[lf[[[l[[[0[[r[[[[[[[ 4.115483] BUG: Bad page map in process ip6tables pte:2[[[[[[[[[[[[[[[ [[[[f[[[[u[[[[|[[[[[[[[[|[[[[[[[D
[ 4.170892] configfs-gadget gadget: high-speed config #1: b
[ 4.170999] android_work: sent uevent USB_STATE=CONFIGURED
[ 7.692554] usb-ext-charge usb-charge: adc value = 297
[ 7.692569] usb-ext-charge usb-charge: usb status 1 battery_online 0 poe_online 0
[ 25.135817] INFO: rcu_preempt self-detected stall on CPU
[ 25.135857] 2-…: (6300 ticks this GP) idle=1b1/140000000000001/0 softirq=478/479 fqs=3150
[ 25.135865] (t=6301 jiffies g=25 c=24 q=199)
[ 25.135877] Task dump for CPU 2:
[ 25.135882] ip6tables R running task 0 441 260 0x00000002
[ 25.135896] Call trace:
[ 25.135913] [] dump_backtrace+0x0/0x1cc
[ 25.135923] [] show_stack+0x14/0x1c
[ 25.135934] [] sched_show_task+0xc8/0xd4
[ 25.135944] [] dump_cpu_task+0x40/0x4c
[ 25.135953] [] rcu_dump_cpu_stacks+0x88/0xb8
[ 25.135964] [] rcu_check_callbacks+0x304/0x8e4
[ 25.135977] [] update_process_times+0x2c/0x54
[ 25.135989] [] tick_sched_timer+0x6c/0xa8
[ 25.135999] [] __hrtimer_run_queues+0x1b0/0x358
[ 25.136008] [] hrtimer_interrupt+0x9c/0x1bc
[ 25.136022] [] arch_timer_handler_phys+0x2c/0x38
[ 25.136033] [] handle_percpu_devid_irq+0xe4/0x1e0
[ 25.136041] [] generic_handle_irq+0x1c/0x2c
[ 25.136048] [] __handle_domain_irq+0x80/0xac
[ 25.136057] [] gic_handle_irq+0xbc/0x154
[ 25.136064] Exception stack(0xffffffc0e128fac0 to 0xffffffc0e128fbf0)
[ 25.136073] fac0: ffffffbdc3d70440 0000000000000000 ffffffc0f6ff0820 ffffff80090b6000
[ 25.136081] fae0: 0000000000000200 cb88537fdc8ba667 ffffffbdc3d7049c 0000000000000000
[ 25.136090] fb00: 0000000000000220 0000000000000002 0000000000000000 0000000000000000
[ 25.136098] fb20: ffffffc0f0730490 0000000000000040 0000000000000000 0000000000000000
[ 25.136106] fb40: 0000000000000000 0000000000000000 0000000000000000 000000000000003f
[ 25.136114] fb60: ffffffc0f0730278 ffffffc0e128fd00 ffffff80090b6000 ffffffc0ec502200
[ 25.136123] fb80: ffffffc0f0738240 ffffffc0eeff4630 ffffffc0f0738248 0000007f8c65f000
[ 25.136130] fba0: 00000000e1281000 ffffffc0e128fbf0 ffffff800816b854 ffffffc0e128fbf0
[ 25.136139] fbc0: ffffff800816b734 0000000080400145 ffffffc0e128fbf0 ffffff800816b854
[ 25.136146] fbe0: 0000008000000000 ffffff800816b868
[ 25.136154] [] el1_irq+0xe0/0x170
[ 25.136163] [] filemap_map_pages+0x8c/0x234
[ 25.136174] [] handle_mm_fault+0x4b4/0xe5c
[ 25.136185] [] do_page_fault+0x1cc/0x350
[ 25.136193] [] do_translation_fault+0x44/0xc0
[ 25.136201] [] do_mem_abort+0x50/0xc4
[ 25.136207] Exception stack(0xffffffc0e128fe00 to 0xffffffc0e128ff30)
[ 25.136215] fe00: 0000000000000000 00000040ede8d000 ffffffffffffffff 0000007f8c66e350
[ 25.136223] fe20: 0000000020000000 0000007e5a79502c 0000000060000000 0000000000000015
[ 25.136232] fe40: 000000000000011d 00000000000000dd ffffff8008ae2000 ffffffc0e11da700
[ 25.136240] fe60: ffffffffffffffff ffffffc0ec502c00 ffffff80090b6000 0000007fd25f2b40
[ 25.136249] fe80: ffffffc0e128fea0 ffffff8008089060 0000000000000000 0000000000000008
[ 25.136256] fea0: 0000000000000000 ffffff8008082814 0000000000000000 cb88537fdc8ba667
[ 25.136265] fec0: 0000007fdf5185b0 0000000000000000 0000000000000000 0000000000000000
[ 25.136273] fee0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 25.136281] ff00: 00000056c6822740 0000000000006c64 0000007fdf518720 0000000000000000
[ 25.136288] ff20: 0000000000000000 0000000000000000
[ 25.136295] [] el0_da+0x20/0x24
[ 32.052488] NMI watchdog: BUG: soft lockup - CPU#2 stuck for 22s! [ip6tables:441]
[ 32.052513]
[ 32.052545] PC is at filemap_map_pages+0x94/0x234
[ 32.052552] LR is at filemap_map_pages+0x1ac/0x234
[ 32.052558] pc : [] lr : [] pstate: 80400145
[ 32.052564] sp : ffffffc0e128fbf0
[ 32.052569] x29: ffffffc0e128fbf0 x28: 00000000e1281000
[ 32.052580] x27: 0000007f8c65f000 x26: ffffffc0f0738248
[ 32.052589] x25: ffffffc0eeff4630 x24: ffffffc0f0738240
[ 32.052599] x23: ffffffc0ec502200 x22: ffffff80090b6000
[ 32.052609] x21: ffffffc0e128fd00 x20: ffffffc0f0730278
[ 32.052618] x19: 000000000000003f x18: 0000000000000000
[ 32.052630] x17: 0000000000000000 x16: 0000000000000000
[ 32.052642] x15: 0000000000000000 x14: 0000000000000000
[ 32.052654] x13: 0000000000000040 x12: ffffffc0f0730490
[ 32.052667] x11: 0000000000000000 x10: 0000000000000000
[ 32.052679] x9 : 0000000000000002 x8 : 0000000000000220
[ 32.052690] x7 : 0000000000000000 x6 : ffffffbdc3d7049c
[ 32.052699] x5 : cb88537fdc8ba667 x4 : 0000000000000200
[ 32.052708] x3 : ffffff80090b6000 x2 : ffffffc0f6ff0820
[ 32.052718] x1 : 0000000000000000 x0 : ffffffbdc3d70440
[ 32.052728]
[ 32.052728] PC: 0xffffff800816b6bc:
[ 32.052735] b6bc aa0003f9 a90363f7 a90153f3 f9452ac0 aa0103f5 f9405337 d2800014 f9002bfb
[ 32.052763] b6dc f9003fa0 f9407ef8 f940083b 97fe4230 f94006a0 9100231a f90033bf f90037a0
[ 32.052790] b6fc b4000d54 f94033a1 f94016a0 eb00003f 54000169 97fe42ac f9403fa1 f9452ac0
[ 32.052816] b71c eb00003f 54000d00 97fccbef 92400401 b50000c1 b9401c01 350000c1 f9400280
[ 32.052842] b73c b5ffff60 1400004a 36000920 17fffff2 11000422 93407c23 91007006 93407c42
[ 32.052868] b75c f98000d1 885f7cc4 4a030085 350000a5 8805fcc2 35ffff85 d5033bbf 2a0303e4
[ 32.052895] b77c 6b01009f 54000060 2a0403e1 17ffffeb f9400293 eb13001f 54000060 9400340c
[ 32.052921] b79c 17ffffe7 f9400260 361805e0 d50339bf f9400260 37880580 52800000 aa1303e1
[ 32.052948]
[ 32.052948] LR: 0xffffff800816b7d4:
[ 32.052954] b7d4 36180420 d50339bf f9400301 f9400a60 f9402821 d1000421 b2402c21 91000421
[ 32.052981] b7f4 eb81301f 54000302 f94006a1 cb010000 f9401aa1 d37df000 8b000023 f8606820
[ 32.053007] b814 b5000220 b940b6e0 34000060 51000400 b900b6e0 f9400a60 aa1303e2 f94006a1
[ 32.053033] b834 52800004 52800005 cb010001 aa1903e0 8b013361 94009e59 aa1303e0 97fffe3d
[ 32.053058] b854 14000005 aa1303e0 97fffe3a aa1303e0 940033d9 f94033b3 f94016a0 eb00027f
[ 32.053085] b874 54fff4e0 f94037a0 cb130013 d1000673 eb1f027f 540000ed f94033a0 91000400
[ 32.053111] b894 f90033a0 f8408e80 b5fff300 17fffff8 aa1a03e0 910183a1 52800002 94086b36
[ 32.053137] b8b4 aa0003f4 b5fff240 17ffff95 a94153f3 a9425bf5 a94363f7 a9446bf9 f9402bfb
[ 32.053165]
[ 32.053165] SP: 0xffffffc0e128fb70:
[ 32.053171] fb70 090b6000 ffffff80 ec502200 ffffffc0 f0738240 ffffffc0 eeff4630 ffffffc0
[ 32.053197] fb90 f0738248 ffffffc0 8c65f000 0000007f e1281000 00000000 e128fbf0 ffffffc0
[ 32.053223] fbb0 0816b854 ffffff80 e128fbf0 ffffffc0 0816b73c ffffff80 80400145 00000000
[ 32.053249] fbd0 e128fbf0 ffffffc0 0816b854 ffffff80 00000000 00000080 0816b868 ffffff80
[ 32.053275] fbf0 e128fc70 ffffffc0 08194944 ffffff80 eeff4630 ffffffc0 8c65f000 0000007f
[ 32.053301] fc10 e2160318 ffffffc0 00000000 00000000 e12812f8 ffffffc0 090b6000 ffffff80
[ 32.053327] fc30 00000054 00000000 090b6000 ffffff80 c384a070 ffffffbd 08204740 ffffff80
[ 32.053354] fc50 00000001 00000000 00000040 00000000 e128fc70 ffffffc0 dc8ba667 cb88537f
[ 32.053381]
[ 32.053381] X0: 0xffffffbdc3d703c0:
[ 32.053387] 03c0 0001026c 00000000 f0738240 ffffffc0 00000003 00000000 ffffffff 00000000
[ 32.053413] 03e0 c3d70420 ffffffbd c0134220 ffffffbd 00000000 00000000 00000000 00000000
[ 32.053439] 0400 0001026c 00000000 f0738240 ffffffc0 00000002 00000000 ffffffff 00000000
[ 32.053466] 0420 c3d70460 ffffffbd c3d703e0 ffffffbd 00000000 00000000 00000000 00000000
[ 32.053491] 0440 0001026c 00000000 f0738240 ffffffc0 00000001 00000000 ffffffff 00000000
[ 32.053518] 0460 c011f260 ffffffbd c3d70420 ffffffbd 00000000 00000000 00000000 00000000
[ 32.053544] 0480 0001026c 00000000 f0738240 ffffffc0 00000000 00000000 ffffffff 00000000
[ 32.053570] 04a0 c3d74c60 ffffffbd c3c06760 ffffffbd 00000000 00000000 00000000 00000000
[ 32.053597]
[ 32.053597] X2: 0xffffffc0f6ff07a0:
[ 32.053604] 07a0 00000000 00000000 f6ff07a8 ffffffc0 f6ff07a8 ffffffc0 00060006 00000000
[ 32.053630] 07c0 f6ff07c0 ffffffc0 f6ff07c0 ffffffc0 00000000 00000000 f6ff07d8 ffffffc0
[ 32.053656] 07e0 f6ff07d8 ffffffc0 00000000 00000000 f6ff07f0 ffffffc0 f6ff07f0 ffffffc0
[ 32.053682] 0800 00020002 00000000 f6ff0808 ffffffc0 f6ff0808 ffffffc0 00040004 00000000
[ 32.053708] 0820 f6ff0820 ffffffc0 f6ff0820 ffffffc0 00040004 00000000 f6ff0838 ffffffc0
[ 32.053734] 0840 f6ff0838 ffffffc0 00000000 00000000 f6ff0850 ffffffc0 f6ff0850 ffffffc0
[ 32.053760] 0860 00020002 00000000 f6ff0868 ffffffc0 f6ff0868 ffffffc0 00060006 00000000
[ 32.053786] 0880 f6ff0880 ffffffc0 f6ff0880 ffffffc0 00020002 00000000 f6ff0898 ffffffc0
[ 32.053813]
[ 32.053813] X3: 0xffffff80090b5f80:
[ 32.053819] 5f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 32.053845] 5fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 32.053871] 5fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 32.053897] 5fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 32.053923] 6000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 32.053949] 6020 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 32.053974] 6040 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 32.054000] 6060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 32.054028]
[ 32.054028] X6: 0xffffffbdc3d7041c:
[ 32.054034] 041c 00000000 c3d70460 ffffffbd c3d703e0 ffffffbd 00000000 00000000 00000000
[ 32.054060] 043c 00000000 0001026c 00000000 f0738240 ffffffc0 00000001 00000000 ffffffff
[ 32.054086] 045c 00000000 c011f260 ffffffbd c3d70420 ffffffbd 00000000 00000000 00000000
[ 32.054112] 047c 00000000 0001026c 00000000 f0738240 ffffffc0 00000000 00000000 ffffffff
[ 32.054138] 049c 00000000 c3d74c60 ffffffbd c3c06760 ffffffbd 00000000 00000000 00000000
[ 32.054164] 04bc 00000000 00010268 00000000 f07292a0 ffffffc0 00000003 00000000 ffffffff
[ 32.054190] 04dc 00000000 c3d70520 ffffffbd c3d77660 ffffffbd 00000000 00000000 00000000
[ 32.054217] 04fc 00000000 00010268 00000000 f07292a0 ffffffc0 00000002 00000000 ffffffff
[ 32.054245]
[ 32.054245] X12: 0xffffffc0f0730410:
[ 32.054251] 0410 c0135600 ffffffbd c0135640 ffffffbd c0135680 ffffffbd c01356c0 ffffffbd
[ 32.054277] 0430 c0135700 ffffffbd c0135740 ffffffbd c0135780 ffffffbd c01357c0 ffffffbd
[ 32.054304] 0450 c0135800 ffffffbd c0135840 ffffffbd c0135880 ffffffbd c01358c0 ffffffbd
[ 32.054330] 0470 00000000 00000000 00000000 00000000 00000000 00000000 f0730490 ffffffc0
[ 32.054356] 0490 00000002 00000003 00000000 00000000 00000000 00000000 f07304a8 ffffffc0
[ 32.054382] 04b0 f07304a8 ffffffc0 f0730248 ffffffc0 f0730920 ffffffc0 f146a6c8 ffffffc0
[ 32.054408] 04d0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 32.054433] 04f0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 32.054463]
[ 32.054463] X20: 0xffffffc0f07301f8:
[ 32.054469] 01f8 f06af690 ffffffc0 f06af6a8 ffffffc0 f06af6c0 ffffffc0 f06af6d8 ffffffc0
[ 32.054495] 0218 f06af6f0 ffffffc0 f06af708 ffffffc0 00000000 00000000 00000000 00000000
[ 32.054521] 0238 00000000 00000000 00000000 00000000 00000001 00000040 f0730490 ffffffc0
[ 32.054547] 0258 00000000 00000000 f0730260 ffffffc0 f0730260 ffffffc0 c3d70480 ffffffbd
[ 32.054573] 0278 c3d70440 ffffffbd c3d70400 ffffffbd c3d703c0 ffffffbd c0134200 ffffffbd
[ 32.054599] 0298 c0134240 ffffffbd c0134280 ffffffbd c01342c0 ffffffbd c0134300 ffffffbd
[ 32.054625] 02b8 c0134340 ffffffbd c0134380 ffffffbd c01343c0 ffffffbd c0134400 ffffffbd
[ 32.054651] 02d8 c0134440 ffffffbd c0134480 ffffffbd c01344c0 ffffffbd c0134500 ffffffbd
[ 32.054678]
[ 32.054678] X21: 0xffffffc0e128fc80:
[ 32.054685] fc80 e128fec0 ffffffc0 8c65f020 0000007f 00000054 00000000 92000007 00000000
[ 32.054710] fca0 e11da700 ffffffc0 f01cf740 ffffffc0 00000024 00000000 00020000 00000000
[ 32.054737] fcc0 f01cf7a8 ffffffc0 eeff4630 ffffffc0 090ebbe0 ffffff80 00000001 00000000
[ 32.054763] fce0 8c65f000 0000007f 090b6000 ffffff80 090b8358 ffffff80 000002f8 00000000
[ 32.054789] fd00 00000054 ffffffc0 00000000 00000000 8c65f000 0000007f 08096854 ffffff80
[ 32.054815] fd20 e128fec0 ffffffc0 0000000f 00000000 e12812f8 ffffffc0 dc8ba667 cb88537f
[ 32.054841] fd40 e128fdb0 ffffffc0 08096a60 ffffff80 8c65f020 0000007f 92000007 00000000
[ 32.054867] fd60 8c65f020 0000007f e128fec0 ffffffc0 08ae70b8 ffffff80 00000024 00000000
[ 32.054895]
[ 32.054895] X22: 0xffffff80090b5f80:
[ 32.054901] 5f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 32.054926] 5fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 32.054952] 5fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 32.054978] 5fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 32.055004] 6000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 32.055029] 6020 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 32.055055] 6040 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 32.055081] 6060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 32.055108]
[ 32.055108] X23: 0xffffffc0ec502180:
[ 32.055114] 2180 00000000 00000000 00000000 00000000 00000000 00000000 f0056180 ffffffc0
[ 32.055140] 21a0 00000000 00000000 00000000 00000000 00000000 00000000 ffffffff ffffffff
[ 32.055166] 21c0 00000000 00000000 f1249a60 ffffffc0 f0afacc0 ffffffc0 ec5021d8 ffffffc0
[ 32.055192] 21e0 ec5021d8 ffffffc0 ec5021e8 ffffffc0 ec5021e8 ffffffc0 f06f5298 ffffffc0
[ 32.055218] 2200 00000000 00000000 00000000 00000000 f1d403a0 ffffffc0 f054eb40 ffffffc0
[ 32.055245] 2220 f07380e8 ffffffc0 08afa440 ffffff80 00000000 00000000 00000002 00000000
[ 32.055270] 2240 00020020 0002801d 00000001 00000000 ec502250 ffffffc0 ec502250 ffffffc0
[ 32.055296] 2260 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 32.055323]
[ 32.055323] X24: 0xffffffc0f07381c0:
[ 32.055329] 81c0 00000000 00000000 00000000 00000000 f2466cd8 ffffffc0 f07381d8 ffffffc0
[ 32.055356] 81e0 f07381d8 ffffffc0 f07381e8 ffffffc0 f07381e8 ffffffc0 f0729258 ffffffc0
[ 32.055382] 8200 f0738610 ffffffc0 f054ebf0 ffffffc0 00000000 00000000 00000000 00000000
[ 32.055408] 8220 00000001 00000000 ffffffce 00000000 08afa440 ffffff80 00000000 00000000
[ 32.055434] 8240 f07380e8 ffffffc0 00000002 02080020 f0730491 ffffffc0 08b908b9 00000000
[ 32.055460] 8260 f01a3058 ffffffc0 00000000 00000000 f0738270 ffffffc0 f0738270 ffffffc0
[ 32.055486] 8280 00000000 00000000 00000000 00000000 000000a8 00000000 00000000 00000000
[ 32.055512] 82a0 00000000 00000000 08afa680 ffffff80 024200ca 00000000 00000000 00000000
[ 32.055539]
[ 32.055539] X25: 0xffffffc0eeff45b0:
[ 32.055545] 45b0 eee155a0 ffffffc0 00006000 00000000 ec53c9c0 ffffffc0 00000f53 00200000
[ 32.055571] 45d0 00000075 00000000 ec43b479 ffffffc0 00000000 00000000 00000000 00000000
[ 32.055598] 45f0 00000001 00000000 eeff45f8 ffffffc0 eeff45f8 ffffffc0 00000000 00000000
[ 32.055624] 4610 08afa2d8 ffffff80 00000000 00000000 ec502300 ffffffc0 00000000 00000000
[ 32.055650] 4630 8c65f000 0000007f 8c70a000 0000007f eeff4bb0 ffffffc0 eeff4c60 ffffffc0
[ 32.055677] 4650 eeff4f40 ffffffc0 eeff4700 ffffffc0 eeff4440 ffffffc0 c5d84000 00000028
[ 32.055703] 4670 f01cf740 ffffffc0 00000f53 00200000 00000875 00000000 eeeaf5d8 ffffffc0
[ 32.055729] 4690 00000000 00000000 00000000 00000000 000000aa 00000000 eeff46a8 ffffffc0
[ 32.055756]
[ 32.055756] X26: 0xffffffc0f07381c8:
[ 32.055763] 81c8 00000000 00000000 f2466cd8 ffffffc0 f07381d8 ffffffc0 f07381d8 ffffffc0
[ 32.055789] 81e8 f07381e8 ffffffc0 f07381e8 ffffffc0 f0729258 ffffffc0 f0738610 ffffffc0
[ 32.055816] 8208 f054ebf0 ffffffc0 00000000 00000000 00000000 00000000 00000001 00000000
[ 32.055843] 8228 ffffffce 00000000 08afa440 ffffff80 00000000 00000000 f07380e8 ffffffc0
[ 32.055870] 8248 00000002 02080020 f0730491 ffffffc0 08b908b9 00000000 f01a3058 ffffffc0
[ 32.055896] 8268 00000000 00000000 f0738270 ffffffc0 f0738270 ffffffc0 00000000 00000000
[ 32.055922] 8288 00000000 00000000 000000a8 00000000 00000000 00000000 00000000 00000000
[ 32.055948] 82a8 08afa680 ffffff80 024200ca 00000000 00000000 00000000 f07382c0 ffffffc0
[ 32.055975]
[ 32.055975] X29: 0xffffffc0e128fb70:
[ 32.055982] fb70 090b6000 ffffff80 ec502200 ffffffc0 f0738240 ffffffc0 eeff4630 ffffffc0
[ 32.056008] fb90 f0738248 ffffffc0 8c65f000 0000007f e1281000 00000000 e128fbf0 ffffffc0
[ 32.056034] fbb0 0816b854 ffffff80 e128fbf0 ffffffc0 0816b73c ffffff80 80400145 00000000
[ 32.056060] fbd0 e128fbf0 ffffffc0 0816b854 ffffff80 00000000 00000080 0816b868 ffffff80
[ 32.056086] fbf0 e128fc70 ffffffc0 08194944 ffffff80 eeff4630 ffffffc0 8c65f000 0000007f
[ 32.056113] fc10 e2160318 ffffffc0 00000000 00000000 e12812f8 ffffffc0 090b6000 ffffff80
[ 32.056138] fc30 00000054 00000000 090b6000 ffffff80 c384a070 ffffffbd 08204740 ffffff80
[ 32.056164] fc50 00000001 00000000 00000040 00000000 e128fc70 ffffffc0 dc8ba667 cb88537f
[ 32.056190]
