打印信息如下:
DDR Version 1.12 20180518
Channel 0: DDR3, 800MHz
Channel 1: DDR3, 800MHz
256B stride
pmugrf_os_reg[2] = 0x3AA17AA1, stride = 0xD
Boot1: 2018-04-08, version: 1.12
CPUId = 0x0
ChipType = 0x10, 216
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
mmc0:cmd5,32
SdmmcInit=0 0
BootCapSize=0
UserCapSize=7460MB
FwPartOffset=0 , 0
StorageInit ok = 65441
LoadTrustBL
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xa912c
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):65aa5ce
NOTICE: BL31: Built : 10:47:37, Jun 19 2018
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1151): pd status 3e
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-170-gc4654a6 #16 Wed May 30 08:54:30 UTC 2018 aarch64)
INFO: SPSR = 0x3c9
U-Boot 2014.10-RK3399-06 (Jan 25 2019 - 17:16:32)
CPU: rk3399
cpu version = 0
CPU’s clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
aclk_periph_h = 133333333HZ, hclk_periph_h = 66666666HZ, pclk_per iph_h = 33333333HZ
aclk_periph_l0 = 100000000HZ, hclk_periph_l0 = 100000000HZ, pclk_ periph_l0 = 50000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
Reserve memory for trust os.
128 MiB
SdmmcInit = 0 0
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
can’t find dts node for fixed
dwc_otg_check_dpdm: usb bc disconnected
pmic:rk808
can’t find dts node for pwm1
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
invalide header tag
ca head not found
#Boot ver: 2019-01-25#1.12
empty serial no.
normal boot.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
Rockchip UBOOT DRM driver version: develop-v1.0.0
failed to find phy node
failed to find panel driver
no fuel gauge found
rockchip_panel_deinit: failed to find panel deinit funcs
got recovery cmd from misc.
load fdt from resouce.
vendor read error!
Set oem_unlocked=0Secure Boot state: 0
kernel @ 0x00280000 (0x0127d808)
ramdisk @ 0x04bf0000 (0x00865a68)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000004600000, end 0000000004616053 … OK
Add bank:000000000a200000, 00000000ede00000
[ 0.000000] Linux version 4.4.126 (liangkd@tchip-server) (gcc version 6.3.1 2 0170404 (Linaro GCC 6.3-2017.05) ) #226 SMP PREEMPT Wed Feb 13 14:49:52 CST 2019
[ 0.000000] Reserved memory: failed to reserve memory for node ‘stb-devinfo@0 0000000’: base 0x0000000000000000, size 0 MiB
[ 0.000000] cma: Reserved 16 MiB at 0x00000000f7000000
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f6ef0000 s45528 r8192 d322 96 u86016
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag es: 991752
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb= 1 console=ttyFIQ0 androidboot.baseband=N/A androidboot.selinux=permissive androi dboot.veritymode=/dev/block/platform/ff0f0000.dwmmc/by-name/metadata androidboot .hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand: 0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004 000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x0001000 0@0x00010000(kernel),0x00010000@0x00020000(boot),0x00020000@0x00030000(recovery) ,0x00038000@0x00050000(backup),0x00002000@0x00088000(security),0x00100000@0x0008 a000(cache),0x00500000@0x0018a000(system),0x00008000@0x0068a000(metadata),0x0010 0000@0x00692000(vendor),0x00100000@0x00794000(oem),0x00000400@0x00894000(frp),-@ 0x00894400(userdata) storagemedia=emmc uboot_logo=0x02000000@0xf5c00000 loader.t imestamp=2019-01-25_17:16:32 SecureBootCheckOk=0
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes )
[ 0.000000] software IO TLB [mem 0xf6ea8000-0xf6ee8000] (0MB) mapped at [ffff ffc0f6ea8000-ffffffc0f6ee7fff]
[ 0.000000] Memory: 3911380K/4030464K available (11006K kernel code, 1654K rw data, 5376K rodata, 832K init, 1133K bss, 102700K reserved, 16384K cma-reserved)
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 M B)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000 ( 246 G B)
[ 0.000000] .init : 0xffffff8009090000 - 0xffffff8009160000 ( 832 K B)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008b40000 ( 11008 K B)
[ 0.000000] .rodata : 0xffffff8008b40000 - 0xffffff8009090000 ( 5440 K B)
[ 0.000000] .data : 0xffffff8009160000 - 0xffffff80092fd808 ( 1655 K B)
[ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 G B maximum)
[ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc3e00000 ( 61 M B actual)
[ 0.000000] fixed : 0xffffffbffe7fb000 - 0xffffffbffec00000 ( 4116 K B)
[ 0.000000] PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000 ( 16 M B)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc0f8000000 ( 3966 M B)
[ 0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpu s/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[ 0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /c pus/cpu@101[5] }
[ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 43980 46511097ns
[ 0.001868] Calibrating delay loop (skipped), value calculated using timer fr equency.. 48.00 BogoMIPS (lpj=80000)
[ 0.002830] pid_max: default: 32768 minimum: 301
[ 0.003319] Security Framework initialized
[ 0.003706] SELinux: Initializing.
[ 0.004138] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.004766] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.006256] Initializing cgroup subsys memory
[ 0.006689] Initializing cgroup subsys freezer
[ 0.007991] sched-energy: Sched-energy-costs installed from DT
[ 0.008540] CPU0: update cpu_capacity 401
[ 0.008990] ASID allocator initialised with 32768 entries
[ 0.025815] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee2 0000 domain created
[ 0.027056] Platform MSI: /interrupt-controller@fee00000/interrupt-controller @fee20000 domain created
[ 0.039218] Detected VIPT I-cache on CPU1
[ 0.039248] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.039288] CPU1: using LPI pending table @0x00000000f1c00000
[ 0.039330] CPU1: update cpu_capacity 401
[ 0.039334] CPU1: Booted secondary processor [410fd034]
[ 0.049208] Detected VIPT I-cache on CPU2
[ 0.049228] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.049260] CPU2: using LPI pending table @0x00000000f1c30000
[ 0.049288] CPU2: update cpu_capacity 401
[ 0.049291] CPU2: Booted secondary processor [410fd034]
[ 0.059240] Detected VIPT I-cache on CPU3
[ 0.059259] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.059291] CPU3: using LPI pending table @0x00000000f1c70000
[ 0.059317] CPU3: update cpu_capacity 401
[ 0.059320] CPU3: Booted secondary processor [410fd034]
[ 0.069289] Detected PIPT I-cache on CPU4
[ 0.069317] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.069356] CPU4: using LPI pending table @0x00000000f1cc0000
[ 0.069396] CPU4: update cpu_capacity 1024
[ 0.069399] CPU4: Booted secondary processor [410fd082]
[ 0.079314] Detected PIPT I-cache on CPU5
[ 0.079332] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.079368] CPU5: using LPI pending table @0x00000000f1cf0000
[ 0.079394] CPU5: update cpu_capacity 1024
[ 0.079397] CPU5: Booted secondary processor [410fd082]
[ 0.079480] Brought up 6 CPUs
[ 0.091587] SMP: Total of 6 processors activated.
[ 0.092030] CPU features: detected feature: GIC system register CPU interface
[ 0.092701] CPU: All CPU(s) started at EL2
[ 0.093124] alternatives: patching kernel code
[ 0.095417] devtmpfs: initialized
[ 0.115249] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 6370867519511994 ns
[ 0.116223] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.117555] pinctrl core: initialized pinctrl subsystem
[ 0.119551] Failed to find legacy iommu devices
[ 0.120346] NET: Registered protocol family 16
[ 0.121170] schedtune: init normalization constants…
[ 0.121673] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[ 0.122307] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 0.122952] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[ 0.123585] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 0.124217] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 0.124850] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[ 0.125482] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[ 0.126115] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[ 0.126776] schedtune: SYSTEM min_pwr: 121 max_pwr: 4434
[ 0.127409] schedtune: using normalization constants mul: 3862781856 sh1: 1 s h2: 12
[ 0.128149] schedtune: verify normalization constants…
[ 0.128664] schedtune: max_pwr/2^0: 4313 => norm_pwr: 1024
[ 0.129204] schedtune: max_pwr/2^1: 2156 => norm_pwr: 511
[ 0.129743] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[ 0.130290] schedtune: max_pwr/2^3: 539 => norm_pwr: 127
[ 0.130830] schedtune: max_pwr/2^4: 269 => norm_pwr: 63
[ 0.131369] schedtune: max_pwr/2^5: 134 => norm_pwr: 31
[ 0.131909] schedtune: configured to support 5 boost groups
[ 0.140326] cpuidle: using governor ladder
[ 0.150329] cpuidle: using governor menu
[ 0.150724] Registered FIQ tty driver
[ 0.151432] vdso: 2 pages (1 code @ ffffff8008b46000, 1 data @ ffffff80091640 00)
[ 0.152167] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.154209] DMA: preallocated 2048 KiB pool for atomic allocations
[ 0.175229] console [pstore-1] enabled
[ 0.175823] pstore: Registered ramoops as persistent store backend
[ 0.176426] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.179195] fiq debugger fiq mode enabled
[ [ 0.179848] console [ttyFIQ0] enabled
[ 0.180553] bootconsole [uart0] disabled
[ 0.181121] Registered fiq debugger ttyFIQ0
[ 0.217682] iommu: Adding device ff650000.vpu_service to group 0
[ 0.217756] iommu: Adding device ff660000.rkvdec to group 1
[ 0.217827] iommu: Adding device ff670000.iep to group 2
[ 0.217915] iommu: Adding device ff8f0000.vop to group 3
[ 0.217983] iommu: Adding device ff900000.vop to group 4
[ 0.218083] iommu: Adding device ff910000.isp to group 5
[ 0.218155] iommu: Adding device ff920000.isp to group 6
[ 0.218822] rk_iommu ff670800.iommu: can’t get aclk
[ 0.218837] rk_iommu ff670800.iommu: can’t get hclk
[ 0.219680] SCSI subsystem initialized
[ 0.220006] usbcore: registered new interface driver usbfs
[ 0.220055] usbcore: registered new interface driver hub
[ 0.220131] usbcore: registered new device driver usb
[ 0.220478] media: Linux media interface: v0.10
[ 0.220512] Linux video capture interface: v2.00
[ 0.220683] pps_core: LinuxPPS API ver. 1 registered
[ 0.220692] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome tti <giometti@linux.it>
[ 0.220713] PTP clock support registered
[ 0.222265] Advanced Linux Sound Architecture Driver Initialized.
[ 0.222725] Bluetooth: Core ver 2.21
[ 0.222757] NET: Registered protocol family 31
[ 0.222765] Bluetooth: HCI device and connection manager initialized
[ 0.222778] Bluetooth: HCI socket layer initialized
[ 0.222789] Bluetooth: L2CAP socket layer initialized
[ 0.222814] Bluetooth: SCO socket layer initialized
[ 0.223597] rockchip-cpuinfo cpuinfo: Serial : ecb36bd438b500b8
[ 0.224086] clocksource: Switched to clocksource arch_sys_counter
[ 0.265522] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.265769] NET: Registered protocol family 2
[ 0.266192] TCP established hash table entries: 32768 (order: 6, 262144 bytes )
[ 0.266415] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.266641] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.266719] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.266764] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.266944] NET: Registered protocol family 1
[ 0.267803] Trying to unpack rootfs image as initramfs…
[ 0.641365] Freeing initrd memory: 8596K
[ 0.641914] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counte rs available
[ 0.641999] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counte rs available
[ 0.644736] audit: initializing netlink subsys (disabled)
[ 0.644796] audit: type=2000 audit(0.643:1): initialized
[ 0.649870] VFS: Disk quotas dquot_6.6.0
[ 0.649996] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.651017] Registering sdcardfs 0.1
[ 0.651584] fuse init (API version 7.23)
[ 0.652634]
[ 0.652634] TEE Core Framework initialization (ver 1:0.1)
[ 0.652660] TEE armv7 Driver initialization
[ 0.652995] tz_tee_probe: name=“armv7sec”, id=0, pdev_name=“armv7sec.0”
[ 0.653011] TEE core: Alloc the misc device “opteearmtz00” (id=0)
[ 0.653184] TEE Core: Register the misc device “opteearmtz00” (id=0,minor=62)
[ 0.657083] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 45)
[ 0.657106] io scheduler noop registered
[ 0.657269] io scheduler cfq registered (default)
[ 0.658527] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not a ssigned
[ 0.658547] phy phy-ff770000.syscon:usb2-phy@e460.0: Failed to get VBUS suppl y regulator
[ 0.663664] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.663688] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.663702] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 1.184135] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 1.184307] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 1.185249] iep: failed to find iep power down clock source.
[ 1.185890] IEP Power ON
[ 1.186142] IEP Power OFF
[ 1.186258] IEP Driver loaded succesfully
[ 1.186534] Module initialized.
[ 1.186952] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 1.187248] rk-vcodec ff650000.vpu_service: probe device
[ 1.187298] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc0f1f01810
[ 1.187482] rk-vcodec ff650000.vpu_service: allocator is drm
[ 1.187537] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 1.188047] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 1.188062] rk-vcodec ff650000.vpu_service: init success
[ 1.188255] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 1.188662] rk-vcodec ff660000.rkvdec: probe device
[ 1.188705] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc0f1f02010
[ 1.188843] rk-vcodec ff660000.rkvdec: allocator is drm
[ 1.188900] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 1.189256] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 1.189268] rk-vcodec ff660000.rkvdec: init success
[ 1.191006] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-2 41330
[ 1.191025] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chan s-6 Num_Peri-12 Num_Events-12
[ 1.192379] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL33H▒MAC-24 1330
[ 1.192397] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Cha ns-8 Num_Peri-20 Num_Events-16
[ 1.194129] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 1.195863] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 38, base_baud = 1500000) is a 16550A
[ 1.196160] rockchip-pinctrl pinctrl: pin gpio4-19 already requested by fiq-d ebugger; cannot claim for ff1a0000.serial
[ 1.196187] rockchip-pinctrl pinctrl: pin-147 (ff1a0000.serial) status -22
[ 1.196199] rockchip-pinctrl pinctrl: could not request pin 147 (gpio4-19) fr om group uart2c-xfer on device rockchip-pinctrl
[ 1.196209] dw-apb-uart ff1a0000.serial: Error applying setting, reverse thin gs back
[ 1.196486] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 39, base_baud = 1500000) is a 16550A
[ 1.197054] ff370000.serial: ttyS4 at MMIO 0xff370000 (irq = 41, base_baud = 1500000) is a 16550A
[ 1.197430] [drm] Initialized drm 1.1.0 20060810
[ 1.200837] [drm] Rockchip DRM driver version: v1.0.1
[ 1.202922] Unable to detect cache hierarchy for CPU 0
[ 1.210732] brd: module loaded
[ 1.215426] loop: module loaded
[ 1.215944] zram: Added device: zram0
[ 1.216751] SCSI Media Changer driver v0.25
[ 1.217978] register spi return v = :0
[ 1.218016] register firefly_spi_init spi return v = :0
[ 1.218067] tun: Universal TUN/TAP device driver, 1.6
[ 1.218078] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.219014] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 1.219102] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.219122] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 1.219133] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[ 1.219156] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 1.219321] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 1.219333] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.224348] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.224467] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.224478] Ring mode enabled
[ 1.224485] DMA HW capability register supported
[ 1.224491] Normal descriptors
[ 1.224501] RX Checksum Offload Engine supported (type 2)
[ 1.224507] Wake-Up On Lan supported
[ 1.224546] Enable RX Mitigation via HW Watchdog Timer
[ 1.293435] libphy: stmmac: probed
[ 1.293476] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.293486] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.294377] PPP generic driver version 2.4.2
[ 1.294611] PPP BSD Compression module registered
[ 1.294655] PPP Deflate Compression module registered
[ 1.294700] PPP MPPE Compression module registered
[ 1.294755] NET: Registered protocol family 24
[ 1.294828] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) ( 6 bit encapsulation enabled).
[ 1.294837] CSLIP: code copyright 1989 Regents of the University of Californi a.
[ 1.294862] Rockchip WiFi SYS interface (V1.00) …
[ 1.295008] usbcore: registered new interface driver catc
[ 1.295100] usbcore: registered new interface driver kaweth
[ 1.295122] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet dri ver
[ 1.295210] usbcore: registered new interface driver pegasus
[ 1.295266] usbcore: registered new interface driver rtl8150
[ 1.295325] usbcore: registered new interface driver r8152
[ 1.295345] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.295421] usbcore: registered new interface driver hso
[ 1.295483] usbcore: registered new interface driver asix
[ 1.295539] usbcore: registered new interface driver ax88179_178a
[ 1.295597] usbcore: registered new interface driver cdc_ether
[ 1.295690] usbcore: registered new interface driver cdc_eem
[ 1.295746] usbcore: registered new interface driver dm9601
[ 1.295817] usbcore: registered new interface driver smsc75xx
[ 1.295915] usbcore: registered new interface driver smsc95xx
[ 1.295971] usbcore: registered new interface driver gl620a
[ 1.296035] usbcore: registered new interface driver net1080
[ 1.296124] usbcore: registered new interface driver plusb
[ 1.296179] usbcore: registered new interface driver rndis_host
[ 1.296236] usbcore: registered new interface driver cdc_subset
[ 1.296296] usbcore: registered new interface driver zaurus
[ 1.296390] usbcore: registered new interface driver MOSCHIP usb-ethernet dri ver
[ 1.296476] usbcore: registered new interface driver int51x1
[ 1.296572] usbcore: registered new interface driver kalmia
[ 1.296628] usbcore: registered new interface driver ipheth
[ 1.296687] usbcore: registered new interface driver sierra_net
[ 1.296745] usbcore: registered new interface driver cx82310_eth
[ 1.296850] usbcore: registered new interface driver cdc_ncm
[ 1.296906] usbcore: registered new interface driver qmi_wwan
[ 1.296966] usbcore: registered new interface driver cdc_mbim
[ 1.298931] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[ 1.304180] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[ 1.305300] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.305320] ehci-pci: EHCI PCI platform driver
[ 1.305381] ehci-platform: EHCI generic platform driver
[ 1.309194] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.309404] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 1.309594] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 1.317456] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.317591] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.317607] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 1.317617] usb usb1: Product: EHCI Host Controller
[ 1.317627] usb usb1: Manufacturer: Linux 4.4.126 ehci_hcd
[ 1.317636] usb usb1: SerialNumber: fe3c0000.usb
[ 1.318076] hub 1-0:1.0: USB hub found
[ 1.318109] hub 1-0:1.0: 1 port detected
[ 1.318631] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.318662] ohci-platform: OHCI generic platform driver
[ 1.319103] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.319257] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 1.319407] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 1.375007] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.375065] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 1.375080] usb usb2: Product: Generic Platform OHCI controller
[ 1.375093] usb usb2: Manufacturer: Linux 4.4.126 ohci_hcd
[ 1.375105] usb usb2: SerialNumber: fe3e0000.usb
[ 1.375723] hub 2-0:1.0: USB hub found
[ 1.375799] hub 2-0:1.0: 1 port detected
[ 1.377347] usbcore: registered new interface driver cdc_acm
[ 1.377359] cdc_acm: USB Abstract Control Model driver for USB modems and ISD N adapters
[ 1.377469] usbcore: registered new interface driver usblp
[ 1.377541] usbcore: registered new interface driver cdc_wdm
[ 1.377605] usbcore: registered new interface driver uas
[ 1.377707] usbcore: registered new interface driver usb-storage
[ 1.377769] usbcore: registered new interface driver ums-alauda
[ 1.377831] usbcore: registered new interface driver ums-cypress
[ 1.377887] usbcore: registered new interface driver ums-datafab
[ 1.377948] usbcore: registered new interface driver ums_eneub6250
[ 1.378001] usbcore: registered new interface driver ums-freecom
[ 1.378059] usbcore: registered new interface driver ums-isd200
[ 1.378131] usbcore: registered new interface driver ums-jumpshot
[ 1.378188] usbcore: registered new interface driver ums-karma
[ 1.378241] usbcore: registered new interface driver ums-onetouch
[ 1.378302] usbcore: registered new interface driver ums-sddr09
[ 1.378367] usbcore: registered new interface driver ums-sddr55
[ 1.378422] usbcore: registered new interface driver ums-usbat
[ 1.378530] usbcore: registered new interface driver usbserial
[ 1.378585] usbcore: registered new interface driver usbserial_generic
[ 1.378622] usbserial: USB Serial support registered for generic
[ 1.378678] usbcore: registered new interface driver option
[ 1.378718] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.378882] usbcore: registered new interface driver trancevibrator
[ 1.378907] usb20_otg: version 3.10a 21-DEC-2012
[ 1.379185] usb20_host: version 3.10a 21-DEC-2012
[ 1.379925] usbcore: registered new interface driver xpad
[ 1.379991] usbcore: registered new interface driver usb_acecad
[ 1.380043] usbcore: registered new interface driver aiptek
[ 1.380089] usbcore: registered new interface driver gtco
[ 1.380134] usbcore: registered new interface driver hanwang
[ 1.380178] usbcore: registered new interface driver kbtab
[ 1.380192] ==gsl_ts_init==
[ 1.380225] ret=0
[ 1.380656] .. rk pwm remotectl v1.1 init
[ 1.380911] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input 0
[ 1.381274] sensor_register_slave:kxtj9,id=11
[ 1.381295] sensor_register_slave:mma8452,id=17
[ 1.381310] sensor_register_slave:lis3dh,id=7
[ 1.381324] sensor_register_slave:mma7660,id=18
[ 1.381337] sensor_register_slave:lsm303d,id=22
[ 1.381360] sensor_register_slave:gs_mc3230,id=23
[ 1.381368] [Gsensor] gsensor_init
[ 1.381381] sensor_register_slave:mpu6880_acc,id=24
[ 1.381396] sensor_register_slave:mpu6500_acc,id=25
[ 1.381410] sensor_register_slave:lsm330_acc,id=26
[ 1.381420] sensor_register_slave:bma2xx_acc,id=27
[ 1.381431] sensor_register_slave:akm8975,id=30
[ 1.381441] sensor_register_slave:akm8963,id=31
[ 1.381451] sensor_register_slave:l3g4200d,id=45
[ 1.381461] sensor_register_slave:l3g20d,id=46
[ 1.381471] sensor_register_slave:ewtsa,id=47
[ 1.381482] sensor_register_slave:lsm330_gyro,id=51
[ 1.381492] sensor_register_slave:cm3217,id=53
[ 1.381502] sensor_register_slave:cm3218,id=54
[ 1.381512] sensor_register_slave:ls_stk3410,id=62
[ 1.381522] sensor_register_slave:ps_stk3410,id=67
[ 1.382217] i2c /dev entries driver
[ 1.383374] fusb302 4-0022: Can’t get property of role, set role to default D RP
[ 1.391784] fusb302 4-0022: port 0 probe success with role ROLE_MODE_DRP, try _role ROLE_MODE_NONE
[ 1.391855] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80098c e000
[ 1.393375] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 1.393488] fan53555-reg: supplied by vcc5v0_sys
[ 1.395734] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 1.395964] fan53555-reg: supplied by vcc5v0_sys
[ 1.398472] rk808 0-001b: Pmic Chip id: 0x0
[ 1.401892] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.402007] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.402173] DCDC_REG1: supplied by vcc3v3_sys
[ 1.403065] DCDC_REG2: supplied by vcc3v3_sys
[ 1.403765] DCDC_REG3: supplied by vcc3v3_sys
[ 1.404135] DCDC_REG4: supplied by vcc3v3_sys
[ 1.404717] LDO_REG1: supplied by vcc3v3_sys
[ 1.405974] LDO_REG2: supplied by vcc3v3_sys
[ 1.407053] LDO_REG3: supplied by vcc3v3_sys
[ 1.408164] LDO_REG4: supplied by vcc3v3_sys
[ 1.409249] LDO_REG5: supplied by vcc3v3_sys
[ 1.410304] LDO_REG6: supplied by vcc3v3_sys
[ 1.411405] LDO_REG7: supplied by vcc3v3_sys
[ 1.412502] LDO_REG8: supplied by vcc3v3_sys
[ 1.413565] SWITCH_REG1: supplied by vcc3v3_sys
[ 1.413960] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.417851] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 1.418497] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80098d 0000
[ 1.419317] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80098d 2000
[ 1.419481] rockchip-pinctrl pinctrl: pin gpio4-17 already requested by ff940 000.hdmi; cannot claim for ff130000.i2c
[ 1.419528] rockchip-pinctrl pinctrl: pin-145 (ff130000.i2c) status -22
[ 1.419543] rockchip-pinctrl pinctrl: could not request pin 145 (gpio4-17) fr om group i2c3-xfer on device rockchip-pinctrl
[ 1.419555] rk3x-i2c ff130000.i2c: Error applying setting, reverse things bac k
[ 1.420033] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff80098d 4000
[ 1.421378] IR NEC protocol handler initialized
[ 1.421429] IR RC5(x/sz) protocol handler initialized
[ 1.421444] IR RC6 protocol handler initialized
[ 1.421458] IR JVC protocol handler initialized
[ 1.421473] IR Sony protocol handler initialized
[ 1.421487] IR SANYO protocol handler initialized
[ 1.421501] IR Sharp protocol handler initialized
[ 1.421516] IR MCE Keyboard/mouse protocol handler initialized
[ 1.421531] IR XMP protocol handler initialized
[ 1.421838] usbcore: registered new interface driver uvcvideo
[ 1.421882] USB Video Class driver (1.1.1)
[ 1.421902] CamSys driver version: v0.41.0, CamSys head file version: v1.0.0
[ 1.427645] power_supply_register: Expected proper parent device for 'test ac’
[ 1.427819] power_supply_register: Expected proper parent device for 'test battery’
[ 1.428148] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 1.428287] power_supply_register: Expected proper parent device for 'test usb’
[ 1.431775] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, tem perature=2147483647
[ 1.432763] device-mapper: uevent: version 1.0.3
[ 1.433093] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-d evel@redhat.com
[ 1.433256] Bluetooth: HCI UART driver ver 2.3
[ 1.433272] Bluetooth: HCI UART protocol H4 registered
[ 1.433282] Bluetooth: HCI UART protocol LL registered
[ 1.433299] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 1.433321] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1. 2
[ 1.433329] rtk_btusb: Register usb char device interface for BT driver
[ 1.433581] usbcore: registered new interface driver rtk_btusb
[ 1.434221] cpu cpu0: cpu_leakage=24
[ 1.434297] cpu cpu0: cpu_leakage=24
[ 1.446671] cpu cpu0: temp=30555, pvtm=149833 (151098 + -1265)
[ 1.447289] cpu cpu4: cpu_leakage=44
[ 1.447349] cpu cpu4: cpu_leakage=44
[ 1.460329] cpu cpu4: temp=31111, pvtm=156305 (157015 + -710)
[ 1.466720] sdhci: Secure Digital Host Controller Interface driver
[ 1.466769] sdhci: Copyright(c) Pierre Ossman
[ 1.466784] Synopsys Designware Multimedia Card Interface Driver
[ 1.468024] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode .
[ 1.468235] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.468277] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.468357] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.468417] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.468471] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.468482] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.469539] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode .
[ 1.469656] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 1.469695] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 1.469745] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 1.469770] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.469883] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 1.470264] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.470429] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.480924] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.495305] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 1.498003] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.501100] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 1.501122] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 1.524961] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000 Hz, actual 50000000HZ div = 0)
[ 1.525206] mmc0: new high speed SDHC card at address 1234
[ 1.527557] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using A DMA
[ 1.529322] mmcblk0: mmc0:1234 SA08G 7.29 GiB
[ 1.529381] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.531535] mmcblk0: p1
[ 1.532943] usbcore: registered new interface driver usbhid
[ 1.532979] usbhid: USB HID core driver
[ 1.533160] inv_mpu_iio: inv_mpu_init:746
[ 1.534398] ashmem: initialized
[ 1.539738] ff100000.saradc supply vref not found, using dummy regulator
[ 1.542250] rknandbase v1.2 2018-05-08
[ 1.542744] usbcore: registered new interface driver snd-usb-audio
[ 1.544149] rt5640 1-001c: rt5640 have no aux_det_adc_value defined
[ 1.544233] rt5640 1-001c: Can not read property hp-con-gpio
[ 1.544269] rt5640 1-001c: Can not read property: linein-mute.
[ 1.562676] u32 classifier
[ 1.562716] Actions configured
[ 1.562770] Netfilter messages via NETLINK v0.30.
[ 1.562853] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.563334] ctnetlink v0.93: registering with nfnetlink.
[ 1.564216] xt_time: kernel timezone is -0000
[ 1.565606] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.566076] arp_tables: (C) 2002 David S. Miller
[ 1.566737] Initializing XFRM netlink socket
[ 1.567657] NET: Registered protocol family 10
[ 1.569177] mmc1: MAN_BKOPS_EN bit is not set
[ 1.570397] mip6: Mobile IPv6
[ 1.570470] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.572646] sit: IPv6 over IPv4 tunneling driver
[ 1.573571] NET: Registered protocol family 17
[ 1.573628] NET: Registered protocol family 15
[ 1.573692] bridge: automatic filtering via arp/ip/ip6tables has been depreca ted. Update your scripts to load br_netfilter if you need this.
[ 1.574629] Bridge firewalling registered
[ 1.574671] Ebtables v2.0 registered
[ 1.574933] Bluetooth: RFCOMM TTY layer initialized
[ 1.575022] Bluetooth: RFCOMM socket layer initialized
[ 1.575070] Bluetooth: RFCOMM ver 1.11
[ 1.575119] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.575139] Bluetooth: BNEP filters: protocol multicast
[ 1.575164] Bluetooth: BNEP socket layer initialized
[ 1.575186] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.575206] Bluetooth: HIDP socket layer initialized
[ 1.575280] l2tp_core: L2TP core driver, V2.0
[ 1.575314] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.575343] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.575754] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.575825] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[ 1.575847] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.575862] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gp io.
[ 1.575992] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wa ke_irq = 3, flags = 0.
[ 1.576007] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.576031] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.576219] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.576829] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts gpios = 83.
[ 1.576919] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset gpio = 9.
[ 1.576977] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_g pio = 90.
[ 1.577039] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_h ost_irq = 4.
[ 1.577748] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.577804] [BT_RFKILL]: BT_WAKE_HOST IRQ fired
[ 1.577840] [BT_RFKILL]: ** disable irq
[ 1.578074] [BT_RFKILL]: bt_default device registered.
[ 1.578436] sensor_register_slave:mpu6500_gyro,id=49
[ 1.578466] sensor_register_slave:mpu6880_gyro,id=50
[ 1.581535] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[ 1.582441] mmcblk1: mmc1:0001 AJTD4R 14.6 GiB
[ 1.582558] Registered cp15_barrier emulation handler
[ 1.582599] Registered setend emulation handler
[ 1.582895] mmcblk1boot0: mmc1:0001 AJTD4R partition 1 4.00 MiB
[ 1.583427] mmcblk1boot1: mmc1:0001 AJTD4R partition 2 4.00 MiB
[ 1.583864] mmcblk1rpmb: mmc1:0001 AJTD4R partition 3 4.00 MiB
[ 1.584570] parameter: 0x000000000 – 0x000400000 (4 MB)
[ 1.584592] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 1.584604] trust: 0x000800000 – 0x000c00000 (4 MB)
[ 1.584615] misc: 0x000c00000 – 0x001000000 (4 MB)
[ 1.584627] resource: 0x001000000 – 0x002000000 (16 MB)
[ 1.584638] kernel: 0x002000000 – 0x004000000 (32 MB)
[ 1.584648] boot: 0x004000000 – 0x006000000 (32 MB)
[ 1.584659] recovery: 0x006000000 – 0x00a000000 (64 MB)
[ 1.584670] backup: 0x00a000000 – 0x011000000 (112 MB)
[ 1.584681] security: 0x011000000 – 0x011400000 (4 MB)
[ 1.584692] cache: 0x011400000 – 0x031400000 (512 MB)
[ 1.584703] system: 0x031400000 – 0x0d1400000 (2560 MB)
[ 1.584716] metadata: 0x0d1400000 – 0x0d2400000 (16 MB)
[ 1.584726] vendor: 0x0d2400000 – 0x0f2400000 (512 MB)
[ 1.584737] oem: 0x0f2800000 – 0x112800000 (512 MB)
[ 1.584748] frp: 0x112800000 – 0x112880000 (0 MB)
[ 1.584759] userdata: 0x112880000 – 0x3a3a00000 (10513 MB)
[ 1.584863] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[ 1.585822] registered taskstats version 1
[ 1.590030] rockchip ion idev is NULL
[ 1.590059] rga2 ff680000.rga: rga ion client create success!
[ 1.590317] rga: Driver loaded successfully ver:3.02
[ 1.591664] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not a ssigned
[ 1.591702] phy phy-ff770000.syscon:usb2-phy@e450.6: Failed to get VBUS suppl y regulator
[ 1.594006] rockchip-drm display-subsystem: dmc is disabled
[ 1.594459] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 1.594788] rockchip-vop ff900000.vop: unable to request PWM
[ 1.594820] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_compo nent_ops)
[ 1.594890] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 1.595115] rockchip-vop ff8f0000.vop: unable to request PWM
[ 1.595139] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_compo nent_ops)
[ 1.595758] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 1.595803] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 1.595955] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 1.601226] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi rockchip_ops)
[ 1.601950] i2c i2c-10: of_i2c: modalias failure on /dp@fec00000/ports
[ 1.602370] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_com ponent_ops)
[ 1.602393] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.602403] [drm] No driver support for vblank timestamp query.
[ 1.602771] rockchip-drm display-subsystem: connector[HDMI-A-1] can’t found a ny modes
[ 1.602803] rockchip-drm display-subsystem: can’t not find any loader display
[ 1.602820] rockchip-drm display-subsystem: failed to show loader logo
[ 1.603011] Freeing drm_logo memory: 820K
[ 1.603039] rockchip-drm display-subsystem: No connectors reported connected with modes
[ 1.603053] [drm] Cannot find any crtc or sizes - going 1024x768
[ 1.609031] rockchip-drm display-subsystem: fb0: frame buffer device
[ 1.609090] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Dis abling cdn
[ 1.624138] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 1.630264] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 1.630526] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus n umber 3
[ 1.630895] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x11 0 quirks 0x02030010
[ 1.630965] xhci-hcd xhci-hcd.11.auto: irq 234, io mem 0xfe800000
[ 1.631148] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.631175] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 1.631189] usb usb3: Product: xHCI Host Controller
[ 1.631202] usb usb3: Manufacturer: Linux 4.4.126 xhci-hcd
[ 1.631214] usb usb3: SerialNumber: xhci-hcd.11.auto
[ 1.631790] hub 3-0:1.0: USB hub found
[ 1.631841] hub 3-0:1.0: 1 port detected
[ 1.632186] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 1.632374] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus n umber 4
[ 1.632462] usb usb4: We don’t know the algorithms for LPM for this host, dis abling LPM.
[ 1.632589] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.632610] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 1.632623] usb usb4: Product: xHCI Host Controller
[ 1.632635] usb usb4: Manufacturer: Linux 4.4.126 xhci-hcd
[ 1.632647] usb usb4: SerialNumber: xhci-hcd.11.auto
[ 1.633210] hub 4-0:1.0: USB hub found
[ 1.633258] hub 4-0:1.0: 1 port detected
[ 1.635071] xhci-hcd xhci-hcd.11.auto: remove, state 1
[ 1.635144] usb usb4: USB disconnect, device number 1
[ 1.659062] xhci-hcd xhci-hcd.11.auto: Host not halted after 16000 microsecon ds.
[ 1.659109] xhci-hcd xhci-hcd.11.auto: Host controller not halted, aborting r eset.
[ 1.659165] xhci-hcd xhci-hcd.11.auto: USB bus 4 deregistered
[ 1.659344] xhci-hcd xhci-hcd.11.auto: remove, state 1
[ 1.659397] usb usb3: USB disconnect, device number 1
[ 1.659816] xhci-hcd xhci-hcd.11.auto: USB bus 3 deregistered
[ 1.664820] xhci-hcd xhci-hcd.12.auto: xHCI Host Controller
[ 1.665185] xhci-hcd xhci-hcd.12.auto: new USB bus registered, assigned bus n umber 3
[ 1.665593] xhci-hcd xhci-hcd.12.auto: hcc params 0x0220fe64 hci version 0x11 0 quirks 0x02030010
[ 1.665699] xhci-hcd xhci-hcd.12.auto: irq 235, io mem 0xfe900000
[ 1.665883] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.665941] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 1.665954] usb usb3: Product: xHCI Host Controller
[ 1.665966] usb usb3: Manufacturer: Linux 4.4.126 xhci-hcd
[ 1.665978] usb usb3: SerialNumber: xhci-hcd.12.auto
[ 1.666638] hub 3-0:1.0: USB hub found
[ 1.666725] hub 3-0:1.0: 1 port detected
[ 1.667072] xhci-hcd xhci-hcd.12.auto: xHCI Host Controller
[ 1.667348] xhci-hcd xhci-hcd.12.auto: new USB bus registered, assigned bus n umber 4
[ 1.667520] usb usb4: We don’t know the algorithms for LPM for this host, dis abling LPM.
[ 1.667686] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.667702] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 1.667714] usb usb4: Product: xHCI Host Controller
[ 1.667729] usb usb4: Manufacturer: Linux 4.4.126 xhci-hcd
[ 1.667741] usb usb4: SerialNumber: xhci-hcd.12.auto
[ 1.668370] hub 4-0:1.0: USB hub found
[ 1.668475] hub 4-0:1.0: 1 port detected
[ 1.672850] ehci-platform fe380000.usb: EHCI Host Controller
[ 1.673283] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
[ 1.673577] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 1.740835] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 1.741203] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.741275] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 1.741344] usb usb5: Product: EHCI Host Controller
[ 1.741368] usb usb5: Manufacturer: Linux 4.4.126 ehci_hcd
[ 1.741390] usb usb5: SerialNumber: fe380000.usb
[ 1.742768] hub 5-0:1.0: USB hub found
[ 1.742885] hub 5-0:1.0: 1 port detected
[ 1.744623] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 1.745455] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6
[ 1.745830] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 1.748937] usb 1-1: New USB device found, idVendor=1a40, idProduct=0201
[ 1.749007] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.749032] usb 1-1: Product: USB 2.0 Hub [MTT]
[ 1.750462] hub 1-1:1.0: USB hub found
[ 1.750680] hub 1-1:1.0: 7 ports detected
[ 1.802123] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.802221] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 1.802247] usb usb6: Product: Generic Platform OHCI controller
[ 1.802270] usb usb6: Manufacturer: Linux 4.4.126 ohci_hcd
[ 1.802292] usb usb6: SerialNumber: fe3a0000.usb
[ 1.803851] hub 6-0:1.0: USB hub found
[ 1.803930] hub 6-0:1.0: 1 port detected
[ 1.806702] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode .
[ 1.806996] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.807074] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.807137] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.807187] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.807318] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.807341] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.808095] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 1.821022] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.834366] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 1.851681] asoc-simple-card rt5640-sound: rt5640-aif1 ↔ ff890000.i2s mappi ng ok
[ 1.861844] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/ rt5640-sound/sound/card0/input1
[ 1.865379] asoc-simple-card spdif-sound: dit-hifi ↔ ff870000.spdif mapping ok
[ 1.870057] rk-hdmi-dp-sound hdmi-dp-sound: control 3:0:0:ELD:0 is already pr esent
[ 1.870116] hdmi-audio-codec hdmi-audio-codec.10.auto: ASoC: Failed to add EL D: -16
[ 1.872134] rk-hdmi-dp-sound hdmi-dp-sound: multicodec ↔ ff8a0000.i2s mappi ng ok
[ 1.872254] hdmi-audio-codec hdmi-audio-codec.10.auto: ASoC: Failed to create Playback debugfs file
[ 1.877166] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:56:16 UTC (1358499376)
[ 1.878619] It doesn’t contain Rogue gpu
[ 1.881116] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.883102] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.885080] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.888694] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
M▒ 1.906988]
[ 1.947746] mmc_host mmc2: Bus speed (slot 0) = 200000000Hz (slot req 2080000 00Hz, actual 200000000HZ div = 0)
停在此处后,貌似休眠或者死机了。
CPU_B_SLEEP_H,GPU_SLEEP_H板子无法测试。板子换货CPU,之前CPU烧了HDMI接口,请大家帮忙看看是什么问题,谢谢
