萌新求助
在用NFS挂在Ubuntu18的文件系统的时候,遇到下面这个问题,请求大神帮忙解决一下。
[ OK ] Created slice system-systemd\x2dbacklight.slice.
Starting Load/Save Screen Backlight…ightness of backlight:backlight…
Starting Load/Save RF Kill Switch Status…
[ OK ] Started Tell Plymouth To Write Out Runtime Data.
[ OK ] Started Load/Save Screen Backlight Brightness of backlight:backlight.
[ OK ] Started Load/Save RF Kill Switch Status.
[ OK ] Started Create Volatile Files and Directories.
Starting Update UTMP about System Boot/Shutdown…
Starting Network Time Synchronization…
Starting Network Name Resolution…
[FAILED] Failed to start Network Time Synchronization.
See ‘systemctl status systemd-timesyncd.service’ for details.
[ OK ] Stopped Network Time Synchronization.
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Network Name Resolution.
[ OK ] Reached target Host and Network Name Lookups.
[ OK ] Reached target System Initialization.
[ OK ] Reached target Paths.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting LSB: automatic crash report generation…
Starting start S11-npu service…
[ OK ] Started Set the CPU Frequency Scaling governor.
[ OK ] Started D-Bus System Message Bus.
Starting Network Manager…
[ OK ] Started Regular background program processing daemon.
Starting WPA supplicant…
Starting Resize root filesystem to fit available disk space…
Starting Adbd for linux…
Starting Modem Manager…
Starting System Logging Service…
Starting Avahi mDNS/DNS-SD Stack…
Starting Accounts Service…
Starting Restore /etc/resolv.conf i…fore the ppp link was shut down…
Starting rkisp 3A engine…
Starting Bluetooth service…
Starting Save/Restore Sound Card State…
Starting Disk Manager…
Starting Login Service…
[ OK ] Reached target System Time Synchronized.
[ OK ] Started Discard unused blocks once a week.
[ OK ] Started Daily apt download activities.
[ OK ] Started Daily apt upgrade and clean activities.
[ OK ] Reached target Timers.
[ OK ] Started start S11-npu service.
[ OK ] Started Restore /etc/resolv.conf if…before the ppp link was shut down.
[ OK ] Started WPA supplicant.
Starting Discard unused blocks…
[ OK ] Started Bluetooth service.
[ OK ] Reached target Bluetooth.
[ OK ] Started rkisp 3A engine.
[ OK ] Started Login Service.
[ OK ] Started Discard unused blocks.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started System Logging Service.
[ OK ] Started Save/Restore Sound Card State.
Starting Authorization Manager…
[ 63.966043] rtk_btusb: btusb_open hdev->promisc ==0
Starting Hostname Service…
[ OK ] Started LSB: automatic crash report generation.
[ OK ] Started Adbd for linux.
[ OK ] Started Hostname Service.
[ OK ] Started Authorization Manager.
[ OK ] Started Accounts Service.
[ OK ] Started Disk Manager.
[ OK ] Started Modem Manager.
[ OK ] Started Resize root filesystem to fit available disk space.
Starting Network Manager Script Dispatcher Service…
Starting Setup rockchip platform environment…
[ OK ] Started Network Manager Script Dispatcher Service.
[ ***] (2 of 2) A start job is running for… environment (1min 17s / no limit)[ 240.299951] INFO: task systemd-journal:206 blocked for more than 120 seconds.
[ 240.300638] Not tainted 4.4.194-g50f0a60241aa-dirty #3
[ 240.301144] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[ 240.302568] Kernel panic - not syncing: hung_task: blocked tasks
[ 240.303115] CPU: 5 PID: 39 Comm: khungtaskd Not tainted 4.4.194-g50f0a60241aa-dirty #3
[ 240.303820] Hardware name: Firefly roc-rk3399-pc PLUS (DT)
[ 240.304310] Call trace:
[ 240.304547] [] dump_backtrace+0x0/0x220
[ 240.305043] [] show_stack+0x24/0x30
[ 240.305503] [] dump_stack+0x94/0xbc
[ 240.305964] [] panic+0xe4/0x238
[ 240.306402] [] watchdog+0x2ec/0x304
[ 240.306862] [] kthread+0xdc/0xec
[ 240.307297] [] ret_from_fork+0x10/0x20
[ 240.307877] CPU4: stopping
[ 240.308147] CPU: 4 PID: 0 Comm: swapper/4 Not tainted 4.4.194-g50f0a60241aa-dirty #3
[ 240.308843] Hardware name: Firefly roc-rk3399-pc PLUS (DT)
[ 240.309334] Call trace:
[ 240.309576] [] dump_backtrace+0x0/0x220
[ 240.310074] [] show_stack+0x24/0x30
可以试一下给Ubuntu文件系统设置静态ip,然后再nfs加载
