编译buildroot出错Command exited with non-zero status 1
2020-11-06T15:52:26 /usr/bin/install -m 0644 support/misc/target-dir-warning.txt /data/rk312x_linux_beta_v0.1_200513/buildroot/output/rockchip_rk3126c_dpf/target/THIS_IS_NOT_YOUR_ROOT_FILESYSTEM
2020-11-06T15:52:26 >>> Generating root filesystem image rootfs.tar
2020-11-06T15:52:26 rm -rf /data/rk312x_linux_beta_v0.1_200513/buildroot/output/rockchip_rk3126c_dpf/build/buildroot-fs
2020-11-06T15:52:26 mkdir -p /data/rk312x_linux_beta_v0.1_200513/buildroot/output/rockchip_rk3126c_dpf/build/buildroot-fs
2020-11-06T15:52:26 echo ‘#!/bin/sh’ > /data/rk312x_linux_beta_v0.1_200513/buildroot/output/rockchip_rk3126c_dpf/build/buildroot-fs/fakeroot.fs
2020-11-06T15:52:26 echo “set -e” >> /data/rk312x_linux_beta_v0.1_200513/buildroot/output/rockchip_rk3126c_dpf/build/buildroot-fs/fakeroot.fs
2020-11-06T15:52:26 echo “chown -h -R 0:0 /data/rk312x_linux_beta_v0.1_200513/buildroot/output/rockchip_rk3126c_dpf/target” >> /data/rk312x_linux_beta_v0.1_200513/buildroot/output/rockchip_rk3126c_dpf/build/buildroot-fs/fakeroot.fs
2020-11-06T15:52:26 printf ’ dbus -1 dbus -1 * /var/run/dbus - dbus DBus messagebus usern - - input -1 * - - - Input device groupnn’ >> /data/rk312x_linux_beta_v0.1_200513/buildroot/output/rockchip_rk3126c_dpf/build/buildroot-fs/users_table.txt
2020-11-06T15:52:26 PATH=“/data/rk312x_linux_beta_v0.1_200513/buildroot/output/rockchip_rk3126c_dpf/host/bin:/data/rk312x_linux_beta_v0.1_200513/buildroot/output/rockchip_rk3126c_dpf/host/sbin:/home/wzp/bin:/home/wzp/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin” /data/rk312x_linux_beta_v0.1_200513/buildroot/support/scripts/mkusers /data/rk312x_linux_beta_v0.1_200513/buildroot/output/rockchip_rk3126c_dpf/build/buildroot-fs/users_table.txt /data/rk312x_linux_beta_v0.1_200513/buildroot/output/rockchip_rk3126c_dpf/target >> /data/rk312x_linux_beta_v0.1_200513/buildroot/output/rockchip_rk3126c_dpf/build/buildroot-fs/fakeroot.fs
2020-11-06T15:52:26 cat system/device_table.txt > /data/rk312x_linux_beta_v0.1_200513/buildroot/output/rockchip_rk3126c_dpf/build/buildroot-fs/device_table.txt
2020-11-06T15:52:26 printf ’ /bin/busybox f 4755 0 0 - - - - -n /usr/libexec/dbus-daemon-launch-helper f 4755 0 0 - - - - -n /dev/console c 622 0 0 5 1 - - -nn’ >> /data/rk312x_linux_beta_v0.1_200513/buildroot/output/rockchip_rk3126c_dpf/build/buildroot-fs/device_table.txt
2020-11-06T15:52:26 echo “/data/rk312x_linux_beta_v0.1_200513/buildroot/output/rockchip_rk3126c_dpf/host/bin/makedevs -d /data/rk312x_linux_beta_v0.1_200513/buildroot/output/rockchip_rk3126c_dpf/build/buildroot-fs/device_table.txt /data/rk312x_linux_beta_v0.1_200513/buildroot/output/rockchip_rk3126c_dpf/target” >> /data/rk312x_linux_beta_v0.1_200513/buildroot/output/rockchip_rk3126c_dpf/build/buildroot-fs/fakeroot.fs
2020-11-06T15:52:26 printf ’ (cd /data/rk312x_linux_beta_v0.1_200513/buildroot/output/rockchip_rk3126c_dpf/target; find -print0 | LC_ALL=C sort -z | tar -cf /data/rk312x_linux_beta_v0.1_200513/buildroot/output/rockchip_rk3126c_dpf/images/rootfs.tar --null --no-recursion -T - --numeric-owner)n’ >> /data/rk312x_linux_beta_v0.1_200513/buildroot/output/rockchip_rk3126c_dpf/build/buildroot-fs/fakeroot.fs
2020-11-06T15:52:26 chmod a+x /data/rk312x_linux_beta_v0.1_200513/buildroot/output/rockchip_rk3126c_dpf/build/buildroot-fs/fakeroot.fs
2020-11-06T15:52:26 rm -f /data/rk312x_linux_beta_v0.1_200513/buildroot/output/rockchip_rk3126c_dpf/target/THIS_IS_NOT_YOUR_ROOT_FILESYSTEM
2020-11-06T15:52:26 PATH=“/data/rk312x_linux_beta_v0.1_200513/buildroot/output/rockchip_rk3126c_dpf/host/bin:/data/rk312x_linux_beta_v0.1_200513/buildroot/output/rockchip_rk3126c_dpf/host/sbin:/home/wzp/bin:/home/wzp/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin” /data/rk312x_linux_beta_v0.1_200513/buildroot/output/rockchip_rk3126c_dpf/host/bin/fakeroot – /data/rk312x_linux_beta_v0.1_200513/buildroot/output/rockchip_rk3126c_dpf/build/buildroot-fs/fakeroot.fs
2020-11-06T15:52:26 rootdir=/data/rk312x_linux_beta_v0.1_200513/buildroot/output/rockchip_rk3126c_dpf/target
2020-11-06T15:52:26 table=‘/data/rk312x_linux_beta_v0.1_200513/buildroot/output/rockchip_rk3126c_dpf/build/buildroot-fs/device_table.txt’
you take 0:00.80 to build builroot
====Build buildroot failed!====
希望大神指导
同问~~,我也遇到这个问题
