mount错误日志:
FUSE exfat 1.2.6
ERROR: fsync failed: Input/output error.
内核错误日志:
user.err kernel: [ 4098.106625] mmcblk0: error -110 requesting status
user.warn kernel: [ 4098.111422] blk_update_request: 8 callbacks suppressed
user.err kernel: [ 4098.116643] blk_update_request: I/O error, dev mmcblk0, sector 2048
user.warn kernel: [ 4098.122953] buffer_io_error: 8 callbacks suppressed
user.err kernel: [ 4098.127893] Buffer I/O error on dev mmcblk0p1, logical block 0, lost async page write
user.warn kernel: [ 4098.136876] VFS: Dirty inode writeback failed for block device mmcblk0p1 (err=-5).
user.warn kernel: [ 4098.145918] mmc_blk_cmd_recovery: 5 callbacks suppressed
user.err kernel: [ 4098.151323] mmcblk0: error -110 sending status command, retrying
user.err kernel: [ 4098.157492] mmcblk0: error -110 sending status command, retrying
user.err kernel: [ 4098.163594] mmcblk0: error -110 sending status command, aborting
user.info kernel: [ 4098.178561] rockchip-iodomain ff140000.syscon:io-domains: Setting to 3300000 done
user.debug kernel: [ 4098.186875] vccio_sd: ramp_delay not set
user.info kernel: [ 4098.186898] rockchip-iodomain ff140000.syscon:io-domains: Setting to 3300000 done
user.info kernel: [ 4098.205698] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
user.info kernel: [ 4098.271311] rockchip-iodomain ff140000.syscon:io-domains: Setting to 3300000 done
user.debug kernel: [ 4098.280002] vccio_sd: ramp_delay not set
user.info kernel: [ 4098.280043] rockchip-iodomain ff140000.syscon:io-domains: Setting to 1800000 done
user.info kernel: [ 4098.303536] mmc_host mmc0: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0)
user.info kernel: [ 4098.694830] dwmmc_rockchip ff370000.dwmmc: Successfully tuned phase to 69
user.warn kernel: [ 4098.701694] mmc0: tried to reset card
