root@firefly:/home/firefly/gtk-spice/spice-gtk-0.35# apt-get install libgtk-3-dev
Reading package lists… Done
Building dependency tree
You might want to run ‘apt --fix-broken install’ to correct these.
The following packages have unmet dependencies:
libegl1 : Depends: libglvnd0 (= 1.0.0-2ubuntu2.2) but 1.0.0-2ubuntu2.3 is to be installed
libgles2 : Depends: libglvnd0 (= 1.0.0-2ubuntu2.2) but 1.0.0-2ubuntu2.3 is to be installed
libgtk-3-dev : Depends: gir1.2-gtk-3.0 (= 3.22.30-1ubuntu4) but 3.22.30-1ubuntu1 is to be installed
Depends: libgdk-pixbuf2.0-dev (>= 2.30.0) but it is not going to be installed
Depends: libpango1.0-dev (>= 1.40.5) but it is not going to be installed
Depends: libatk1.0-dev (>= 2.15.1) but it is not going to be installed
Depends: libatk-bridge2.0-dev but it is not going to be installed
Depends: libcairo2-dev (>= 1.14.0) but it is not going to be installed
Depends: libfontconfig1-dev but it is not going to be installed
Depends: libx11-dev but it is not going to be installed
Depends: libxext-dev but it is not going to be installed
Depends: libxinerama-dev but it is not going to be installed
Depends: libxi-dev but it is not going to be installed
Depends: libxrandr-dev but it is not going to be installed
Depends: libxcursor-dev but it is not going to be installed
Depends: libxfixes-dev but it is not going to be installed
Depends: libxcomposite-dev but it is not going to be installed
Depends: libxdamage-dev but it is not going to be installed
Depends: libwayland-dev (>= 1.9.91) but it is not going to be installed
Depends: wayland-protocols (>= 1.9) but it is not going to be installed
Depends: libxkbcommon-dev but it is not going to be installed
E: Unmet dependencies. Try ‘apt --fix-broken install’ with no packages (or specify a solution).
root@firefly:/home/firefly/gtk-spice/spice-gtk-0.35# apt --fix-broken install
Correcting dependencies… Done
The following additional packages will be installed:
libegl1 libgles2
The following packages will be upgraded:
libegl1 libgles2
2 upgraded, 0 newly installed, 0 to remove and 443 not upgraded.
88 not fully installed or removed.
Need to get 0 B/44.3 kB of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database … 102120 files and directories currently installed.)
Preparing to unpack …/libgles2_1.0.0-2ubuntu2.3_armhf.deb …
Unpacking libgles2:armhf (1.0.0-2ubuntu2.3) over (1.0.0-2ubuntu2.2) …
dpkg: error processing archive /var/cache/apt/archives/libgles2_1.0.0-2ubuntu2.3_armhf.deb (–unpack):
trying to overwrite ‘/usr/lib/arm-linux-gnueabihf/libGLESv2.so.2.0.0’, which is also in package libmali-rk-midgard-t76x-r14p0-r1p0:armhf 1.6-1
Preparing to unpack …/libegl1_1.0.0-2ubuntu2.3_armhf.deb …
Unpacking libegl1:armhf (1.0.0-2ubuntu2.3) over (1.0.0-2ubuntu2.2) …
dpkg: error processing archive /var/cache/apt/archives/libegl1_1.0.0-2ubuntu2.3_armhf.deb (–unpack):
trying to overwrite ‘/usr/lib/arm-linux-gnueabihf/libEGL.so.1.0.0’, which is also in package libmali-rk-midgard-t76x-r14p0-r1p0:armhf 1.6-1
E: Sub-process /usr/bin/dpkg returned an error code (1)
报错,如果强制覆盖的话,可以解决编译问题但是 系统中原生的 gtk、egl等库就被覆盖了
如果覆盖之后,egl就用不了GPU渲染而是采用的CPU,请问如何解决这个问题,谢谢。
