使用 gitlab 上的源碼 , edp 螢幕無法點亮
可以開進android 主畫面, ADB shell 亦正常, 但 7.85 edp 螢幕黑屏,
希望求解大神!
源碼 : https://gitlab.com/TeeFirefly/FireNow-Nougat/tree/firefly-rk3399
kernel log :
[ 0.000000] Linux version 4.4.103 (nvt04573@oaalnx16) (gcc version 4.9 20150123 (prerelease) (GCC) ) #1 SMP PREEMPT Tue Apr 20 09:30:33 CST 2021
[ 0.000000] On node 0 totalpages: 516096
[ 0.000000] DMA zone: 8184 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 516096 pages, LIFO batch:31
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07eef8000 s45504 r8192 d32320 u86016
[ 0.000000] pcpu-alloc: s45504 r8192 d32320 u86016 alloc=21*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x0000C000@0x00010000(kernel),0x00010000@0x0001C000(boot),0x00010000@0x0002C000(recovery),0x00038000@0x0003C000(backup),0x00040000@0x00074000(cache),0x00300000@0x000B4000(system),0x00008000@0x003B4000(metadata),0x00002000@0x003BC000(baseparamer),-@0x003BE000(userdata) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2021-04-20_10:33:16 hdmi.vic=-1 SecureBootCheckOk=0
[ 0.000000] software IO TLB [mem 0x7eeb0000-0x7eef0000] (0MB) mapped at [ffffffc07eeb0000-ffffffc07eeeffff]
[ 0.000000] Memory: 1988588K/2064384K available (11006K kernel code, 1640K rwdata, 5256K rodata, 832K init, 1073K bss, 59412K reserved, 16384K cma-reserved)
[ 0.000000] .init : 0xffffff8009070000 - 0xffffff8009140000 ( 832 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008b40000 ( 11008 KB)
[ 0.000000] .rodata : 0xffffff8008b40000 - 0xffffff8009070000 ( 5312 KB)
[ 0.000000] .data : 0xffffff8009140000 - 0xffffff80092da008 ( 1641 KB)
[ 0.001927] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.002891] pid_max: default: 32768 minimum: 301
[ 0.003406] Security Framework initialized
[ 0.003796] SELinux: Initializing.
[ 0.004170] SELinux: Starting in permissive mode
[ 0.004210] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.004839] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.006273] Initializing cgroup subsys freezer
[ 0.006701] Initializing cgroup subsys debug
[ 0.008001] sched-energy: Sched-energy-costs installed from DT
[ 0.008551] CPU0: update cpu_capacity 401
[ 0.009004] ASID allocator initialised with 65536 entries
[ 0.025830] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.027081] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.039227] Detected VIPT I-cache on CPU1
[ 0.039260] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.039295] CPU1: using LPI pending table @0x000000000a3f0000
[ 0.039337] CPU1: update cpu_capacity 401
[ 0.039340] CPU1: Booted secondary processor [410fd034]
[ 0.049224] Detected VIPT I-cache on CPU2
[ 0.049243] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.049276] CPU2: using LPI pending table @0x000000007c020000
[ 0.049304] CPU2: update cpu_capacity 401
[ 0.049307] CPU2: Booted secondary processor [410fd034]
[ 0.059261] Detected VIPT I-cache on CPU3
[ 0.059280] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.059312] CPU3: using LPI pending table @0x000000007c060000
[ 0.059339] CPU3: update cpu_capacity 401
[ 0.059343] CPU3: Booted secondary processor [410fd034]
[ 0.069311] Detected PIPT I-cache on CPU4
[ 0.069340] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.069379] CPU4: using LPI pending table @0x000000007c0a0000
[ 0.069419] CPU4: update cpu_capacity 1024
[ 0.069422] CPU4: Booted secondary processor [410fd082]
[ 0.079333] Detected PIPT I-cache on CPU5
[ 0.079350] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.079386] CPU5: using LPI pending table @0x000000007c0e0000
[ 0.079413] CPU5: update cpu_capacity 1024
[ 0.079417] CPU5: Booted secondary processor [410fd082]
[ 0.079502] Brought up 6 CPUs
[ 0.091609] SMP: Total of 6 processors activated.
[ 0.092051] CPU features: detected feature: GIC system register CPU interface
[ 0.092721] CPU: All CPU(s) started at EL2
[ 0.093144] alternatives: patching kernel code
[ 0.095237] devtmpfs: initialized
[ 0.115989] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.116964] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.118291] pinctrl core: initialized pinctrl subsystem
[ 0.120319] Failed to find legacy iommu devices
[ 0.121136] NET: Registered protocol family 16
[ 0.121920] schedtune: init normalization constants…
[ 0.122424] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[ 0.123059] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 0.123704] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[ 0.124338] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 0.124972] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 0.125606] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[ 0.126239] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[ 0.126872] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[ 0.127511] schedtune: SYSTEM min_pwr: 121 max_pwr: 4434
[ 0.128145] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[ 0.128886] schedtune: verify normalization constants…
[ 0.129403] schedtune: max_pwr/2^0: 4313 => norm_pwr: 1024
[ 0.129944] schedtune: max_pwr/2^1: 2156 => norm_pwr: 511
[ 0.130485] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[ 0.131032] schedtune: max_pwr/2^3: 539 => norm_pwr: 127
[ 0.131573] schedtune: max_pwr/2^4: 269 => norm_pwr: 63
[ 0.132114] schedtune: max_pwr/2^5: 134 => norm_pwr: 31
[ 0.132655] schedtune: configured to support 5 boost groups
[ 0.141068] cpuidle: using governor ladder
[ 0.151071] cpuidle: using governor menu
[ 0.151464] Registered FIQ tty driver
[ 0.152136] vdso: 2 pages (1 code @ ffffff8008b46000, 1 data @ ffffff8009144000)
[ 0.152878] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.154939] DMA: preallocated 2048 KiB pool for atomic allocations
[ 0.169365] gpiochip_add: registered GPIOs 0 to 31 on device: gpio0
[ 0.169436] gpiochip_add: registered GPIOs 32 to 63 on device: gpio1
[ 0.169499] gpiochip_add: registered GPIOs 64 to 95 on device: gpio2
[ 0.169564] gpiochip_add: registered GPIOs 96 to 127 on device: gpio3
[ 0.169632] gpiochip_add: registered GPIOs 128 to 159 on device: gpio4
[ 0.175895] console [pstore0] enabled
[ 0.176491] pstore: Registered ramoops as persistent store backend
[ 0.177095] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.179941] fiq debugger fiq mode enabled
[ 0.180596] console [ttyFIQ0] enabled
[ 0.181298] bootconsole [uart0] disabled
[ 0.182200] Registered fiq debugger ttyFIQ0
[ 0.212341] Rockchip hdmi driver version 2.0
[ 0.212341] .
[ 0.212823] of_get_named_gpiod_flags: parsed ‘rockchip,power-ctrl’ property of node ‘/rockchip-suspend[0]’ - status (0)
[ 0.212872] of_get_named_gpiod_flags: parsed ‘rockchip,power-ctrl’ property of node ‘/rockchip-suspend[1]’ - status (0)
[ 0.213125] of_get_named_gpiod_flags: can’t parse ‘gpio’ property of node ‘/vcc3v3-sys[0]’
[ 0.213422] of_get_named_gpiod_flags: parsed ‘gpio’ property of node ‘/vcc5v0-host-regulator[0]’ - status (0)
[ 0.213608] of_get_named_gpiod_flags: can’t parse ‘gpio’ property of node ‘/vcc5v0-sys[0]’
[ 0.213755] of_get_named_gpiod_flags: can’t parse ‘gpio’ property of node ‘/vcc-phy-regulator[0]’
[ 0.213978] of_get_named_gpiod_flags: parsed ‘gpio’ property of node ‘/vcc3v3-pcie-regulator[0]’ - status (0)
[ 0.214212] of_get_named_gpiod_flags: parsed ‘gpio’ property of node ‘/vcc3v3-3g-regulator[0]’ - status (0)
[ 0.214625] iommu: Adding device ff650000.vpu_service to group 0
[ 0.214728] iommu: Adding device ff660000.rkvdec to group 1
[ 0.214795] iommu: Adding device ff670000.iep to group 2
[ 0.214890] iommu: Adding device ff8f0000.vop to group 3
[ 0.214967] iommu: Adding device ff900000.vop to group 4
[ 0.215078] iommu: Adding device ff910000.isp to group 5
[ 0.215155] iommu: Adding device ff920000.isp to group 6
[ 0.215843] rk_iommu ff670800.iommu: can’t get aclk
[ 0.215863] rk_iommu ff670800.iommu: can’t get hclk
[ 0.216732] SCSI subsystem initialized
[ 0.216899] libata version 3.00 loaded.
[ 0.217064] usbcore: registered new interface driver usbfs
[ 0.217116] usbcore: registered new interface driver hub
[ 0.217194] usbcore: registered new device driver usb
[ 0.217579] media: Linux media interface: v0.10
[ 0.217620] Linux video capture interface: v2.00
[ 0.217754] pps_core: LinuxPPS API ver. 1 registered
[ 0.217767] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.217793] PTP clock support registered
[ 0.219271] Advanced Linux Sound Architecture Driver Initialized.
[ 0.219735] Bluetooth: Core ver 2.21
[ 0.219783] NET: Registered protocol family 31
[ 0.219794] Bluetooth: HCI device and connection manager initialized
[ 0.219812] Bluetooth: HCI socket layer initialized
[ 0.219826] Bluetooth: L2CAP socket layer initialized
[ 0.219854] Bluetooth: SCO socket layer initialized
[ 0.220876] rockchip-cpuinfo cpuinfo: Serial : d4d2aca27303f432
[ 0.221345] clocksource: Switched to clocksource arch_sys_counter
[ 0.265509] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.265748] NET: Registered protocol family 2
[ 0.266168] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.266310] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 0.266588] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.266666] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.266728] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.266903] NET: Registered protocol family 1
[ 0.266947] PCI: CLS 0 bytes, default 64
[ 0.267416] Trying to unpack rootfs image as initramfs…
[ 0.356460] Freeing initrd memory: 1716K
[ 0.356981] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.357074] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.359689] audit: initializing netlink subsys (disabled)
[ 0.359756] audit: type=2000 audit(0.356:1): initialized
[ 0.364787] VFS: Disk quotas dquot_6.6.0
[ 0.364907] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.366285] fuse init (API version 7.23)
[ 0.366994] SELinux: Registering netfilter hooks
[ 0.367386]
[ 0.367386] TEE Core Framework initialization (ver 1:0.1)
[ 0.367419] TEE armv7 Driver initialization
[ 0.367794] tz_tee_probe: name=“armv7sec”, id=0, pdev_name=“armv7sec.0”
[ 0.367811] TEE core: Alloc the misc device “opteearmtz00” (id=0)
[ 0.368031] TEE Core: Register the misc device “opteearmtz00” (id=0,minor=62)
[ 0.371981] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.372007] io scheduler noop registered
[ 0.372179] io scheduler cfq registered (default)
[ 0.373407] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: GPIO lookup for consumer otg-vbus
[ 0.373421] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: using device tree for GPIO lookup
[ 0.373433] of_get_named_gpiod_flags: can’t parse ‘otg-vbus-gpios’ property of node ‘/syscon@ff770000/usb2-phy@e460[0]’
[ 0.373442] of_get_named_gpiod_flags: can’t parse ‘otg-vbus-gpio’ property of node ‘/syscon@ff770000/usb2-phy@e460[0]’
[ 0.373452] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: using lookup tables for GPIO lookup
[ 0.373462] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: lookup for GPIO otg-vbus failed
[ 0.373471] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned
[ 0.378255] rockchip-pcie f8000000.pcie: GPIO lookup for consumer ep
[ 0.378271] rockchip-pcie f8000000.pcie: using device tree for GPIO lookup
[ 0.378301] of_get_named_gpiod_flags: parsed ‘ep-gpios’ property of node ‘/pcie@f8000000[0]’ - status (0)
[ 0.378534] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.378561] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.378584] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 0.901432] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 0.902181] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 0.903412] pwm-backlight backlight: GPIO lookup for consumer enable
[ 0.903425] pwm-backlight backlight: using device tree for GPIO lookup
[ 0.903437] of_get_named_gpiod_flags: can’t parse ‘enable-gpios’ property of node ‘/backlight[0]’
[ 0.903448] of_get_named_gpiod_flags: can’t parse ‘enable-gpio’ property of node ‘/backlight[0]’
[ 0.903459] pwm-backlight backlight: using lookup tables for GPIO lookup
[ 0.903470] pwm-backlight backlight: lookup for GPIO enable failed
[ 0.903495] backlight supply power not found, using dummy regulator
[ 0.905153] iep: failed to find iep power down clock source.
[ 0.906203] IEP Power ON
[ 0.906660] IEP Power OFF
[ 0.907006] IEP Driver loaded succesfully
[ 0.907640] Module initialized.
[ 0.908279] rk-vcodec ff650000.vpu_service: probe device
[ 0.908338] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc07c2fe410
[ 0.908518] rk-vcodec ff650000.vpu_service: allocator is drm
[ 0.908576] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 0.909077] rk-vcodec ff650000.vpu_service: init success
[ 0.909679] rk-vcodec ff660000.rkvdec: probe device
[ 0.909724] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc07c2fec10
[ 0.909856] rk-vcodec ff660000.rkvdec: allocator is drm
[ 0.909912] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 0.910227] rk-vcodec ff660000.rkvdec: init success
[ 0.911937] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.911958] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.913299] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.913318] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.914341] pwm-regulator vdd-log: GPIO lookup for consumer enable
[ 0.914351] pwm-regulator vdd-log: using device tree for GPIO lookup
[ 0.914362] of_get_named_gpiod_flags: can’t parse ‘enable-gpios’ property of node ‘/vdd-log[0]’
[ 0.914371] of_get_named_gpiod_flags: can’t parse ‘enable-gpio’ property of node ‘/vdd-log[0]’
[ 0.914381] pwm-regulator vdd-log: using lookup tables for GPIO lookup
[ 0.914390] pwm-regulator vdd-log: lookup for GPIO enable failed
[ 0.914967] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 0.916569] console [ttyS0] disabled
[ 0.916618] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
[ 0.917214] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 37, base_baud = 1500000) is a 16550A
[ 0.917787] ff370000.serial: ttyS4 at MMIO 0xff370000 (irq = 40, base_baud = 1500000) is a 16550A
[ 0.918205] [drm:drm_core_init] Initialized drm 1.1.0 20060810
[ 0.922843] of_get_named_gpiod_flags: parsed ‘gpios’ property of node ‘/edp-panel/power_ctr/lcd-en[0]’ - status (0)
[ 0.922879] of_get_named_gpiod_flags: parsed ‘gpios’ property of node ‘/edp-panel/power_ctr/lcd-rst[0]’ - status (0)
[ 0.922902] edp-panel supply power not found, using dummy regulator
[ 0.922960] panel-simple edp-panel: GPIO lookup for consumer enable
[ 0.922969] panel-simple edp-panel: using device tree for GPIO lookup
[ 0.922979] of_get_named_gpiod_flags: can’t parse ‘enable-gpios’ property of node ‘/edp-panel[0]’
[ 0.922988] of_get_named_gpiod_flags: can’t parse ‘enable-gpio’ property of node ‘/edp-panel[0]’
[ 0.922997] panel-simple edp-panel: using lookup tables for GPIO lookup
[ 0.923006] panel-simple edp-panel: lookup for GPIO enable failed
[ 0.923015] panel-simple edp-panel: GPIO lookup for consumer reset
[ 0.923023] panel-simple edp-panel: using device tree for GPIO lookup
[ 0.923031] of_get_named_gpiod_flags: can’t parse ‘reset-gpios’ property of node ‘/edp-panel[0]’
[ 0.923040] of_get_named_gpiod_flags: can’t parse ‘reset-gpio’ property of node ‘/edp-panel[0]’
[ 0.923048] panel-simple edp-panel: using lookup tables for GPIO lookup
[ 0.923056] panel-simple edp-panel: lookup for GPIO reset failed
[ 0.923518] mali ff9a0000.gpu: Failed to get regulator
[ 0.923539] mali ff9a0000.gpu: Power control initialization failed
[ 0.923856] Unable to detect cache hierarchy from DT for CPU 0
[ 0.938621] brd: module loaded
[ 0.943398] loop: module loaded
[ 0.943914] zram: Added device: zram0
[ 0.944524] SCSI Media Changer driver v0.25
[ 0.945717] rockchip-pinctrl pinctrl: pin gpio1-8 already requested by ff370000.serial; cannot claim for ff1d0000.spi
[ 0.945745] rockchip-pinctrl pinctrl: pin-40 (ff1d0000.spi) status -22
[ 0.945767] rockchip-pinctrl pinctrl: could not request pin 40 (gpio1-8) from group spi1-tx on device rockchip-pinctrl
[ 0.945794] rockchip-spi ff1d0000.spi: Error applying setting, reverse things back
[ 0.945938] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[ 0.945955] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[ 0.946576] register spi return v = :0
[ 0.946632] tun: Universal TUN/TAP device driver, 1.6
[ 0.946643] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.947544] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 0.947638] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 0.947658] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 0.947674] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[ 0.947701] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 0.947870] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 0.952890] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 0.953014] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.953025] Ring mode enabled
[ 0.953034] DMA HW capability register supported
[ 0.953044] Normal descriptors
[ 0.953056] RX Checksum Offload Engine supported (type 2)
[ 0.953067] Wake-Up On Lan supported
[ 0.953110] Enable RX Mitigation via HW Watchdog Timer
[ 0.953209] of_get_named_gpiod_flags: parsed ‘snps,reset-gpio’ property of node ‘/ethernet@fe300000[0]’ - status (0)
[ 1.020745] libphy: stmmac: probed
[ 1.020786] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.020802] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.021684] PPP generic driver version 2.4.2
[ 1.021873] PPP BSD Compression module registered
[ 1.021889] PPP Deflate Compression module registered
[ 1.021921] PPP MPPE Compression module registered
[ 1.021939] NET: Registered protocol family 24
[ 1.021977] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.021990] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.022059] usbcore: registered new interface driver mt7601u
[ 1.022081] Rockchip WiFi SYS interface (V1.00) …
[ 1.022144] usbcore: registered new interface driver catc
[ 1.022192] usbcore: registered new interface driver kaweth
[ 1.022214] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.022255] usbcore: registered new interface driver pegasus
[ 1.022298] usbcore: registered new interface driver rtl8150
[ 1.022341] usbcore: registered new interface driver r8152
[ 1.022356] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.022413] usbcore: registered new interface driver hso
[ 1.022464] usbcore: registered new interface driver asix
[ 1.022508] usbcore: registered new interface driver ax88179_178a
[ 1.022552] usbcore: registered new interface driver cdc_ether
[ 1.022598] usbcore: registered new interface driver cdc_eem
[ 1.022641] usbcore: registered new interface driver dm9601
[ 1.022695] usbcore: registered new interface driver smsc75xx
[ 1.022745] usbcore: registered new interface driver smsc95xx
[ 1.022787] usbcore: registered new interface driver gl620a
[ 1.022831] usbcore: registered new interface driver net1080
[ 1.022873] usbcore: registered new interface driver plusb
[ 1.022920] usbcore: registered new interface driver rndis_host
[ 1.022964] usbcore: registered new interface driver cdc_subset
[ 1.023009] usbcore: registered new interface driver zaurus
[ 1.023053] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.023110] usbcore: registered new interface driver int51x1
[ 1.023156] usbcore: registered new interface driver kalmia
[ 1.023199] usbcore: registered new interface driver ipheth
[ 1.023245] usbcore: registered new interface driver sierra_net
[ 1.023290] usbcore: registered new interface driver cx82310_eth
[ 1.023341] usbcore: registered new interface driver cdc_ncm
[ 1.023389] usbcore: registered new interface driver qmi_wwan
[ 1.023434] usbcore: registered new interface driver cdc_mbim
[ 1.024642] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[ 1.028886] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[ 1.029536] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.029555] ehci-pci: EHCI PCI platform driver
[ 1.029615] ehci-platform: EHCI generic platform driver
[ 1.033492] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.033523] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 1.033698] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 1.041378] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.041510] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.041528] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.041542] usb usb1: Product: EHCI Host Controller
[ 1.041555] usb usb1: Manufacturer: Linux 4.4.103 ehci_hcd
[ 1.041567] usb usb1: SerialNumber: fe3c0000.usb
[ 1.042062] hub 1-0:1.0: USB hub found
[ 1.042097] hub 1-0:1.0: 1 port detected
[ 1.042616] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.042648] ohci-platform: OHCI generic platform driver
[ 1.043112] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.043143] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 1.043272] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 1.098926] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.098964] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.098981] usb usb2: Product: Generic Platform OHCI controller
[ 1.098995] usb usb2: Manufacturer: Linux 4.4.103 ohci_hcd
[ 1.099008] usb usb2: SerialNumber: fe3e0000.usb
[ 1.099673] hub 2-0:1.0: USB hub found
[ 1.099716] hub 2-0:1.0: 1 port detected
[ 1.101106] usbcore: registered new interface driver cdc_acm
[ 1.101119] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.101200] usbcore: registered new interface driver usblp
[ 1.101263] usbcore: registered new interface driver cdc_wdm
[ 1.101324] usbcore: registered new interface driver uas
[ 1.101459] usbcore: registered new interface driver usb-storage
[ 1.101516] usbcore: registered new interface driver ums-alauda
[ 1.101575] usbcore: registered new interface driver ums-cypress
[ 1.101632] usbcore: registered new interface driver ums-datafab
[ 1.101686] usbcore: registered new interface driver ums_eneub6250
[ 1.101740] usbcore: registered new interface driver ums-freecom
[ 1.101795] usbcore: registered new interface driver ums-isd200
[ 1.101850] usbcore: registered new interface driver ums-jumpshot
[ 1.101903] usbcore: registered new interface driver ums-karma
[ 1.101958] usbcore: registered new interface driver ums-onetouch
[ 1.102017] usbcore: registered new interface driver ums-sddr09
[ 1.102072] usbcore: registered new interface driver ums-sddr55
[ 1.102127] usbcore: registered new interface driver ums-usbat
[ 1.102235] usbcore: registered new interface driver usbserial
[ 1.102285] usbcore: registered new interface driver usbserial_generic
[ 1.102324] usbserial: USB Serial support registered for generic
[ 1.102381] usbcore: registered new interface driver ch341
[ 1.102423] usbserial: USB Serial support registered for ch341-uart
[ 1.102481] usbcore: registered new interface driver cp210x
[ 1.102522] usbserial: USB Serial support registered for cp210x
[ 1.102594] usbcore: registered new interface driver option
[ 1.102632] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.102794] usbcore: registered new interface driver pl2303
[ 1.102832] usbserial: USB Serial support registered for pl2303
[ 1.102905] usbcore: registered new interface driver trancevibrator
[ 1.102923] usb20_otg: version 3.10a 21-DEC-2012
[ 1.103213] usb20_host: version 3.10a 21-DEC-2012
[ 1.103883] usbcore: registered new interface driver xpad
[ 1.103957] usbcore: registered new interface driver usb_acecad
[ 1.104021] usbcore: registered new interface driver aiptek
[ 1.104084] usbcore: registered new interface driver gtco
[ 1.104146] usbcore: registered new interface driver hanwang
[ 1.104207] usbcore: registered new interface driver kbtab
[ 1.104223] ==gsl_ts_init==
[ 1.104263] ret=0
[ 1.104973] .. rk pwm remotectl v1.1 init
[ 1.105290] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 1.105905] sensor_register_slave:mma8452,id=17
[ 1.105925] sensor_register_slave:lis3dh,id=7
[ 1.105943] sensor_register_slave:mma7660,id=18
[ 1.105960] sensor_register_slave:lsm303d,id=22
[ 1.105976] sensor_register_slave:gs_mc3230,id=23
[ 1.105985] [Gsensor] gsensor_init
[ 1.106002] sensor_register_slave:mpu6880_acc,id=24
[ 1.106019] sensor_register_slave:mpu6500_acc,id=25
[ 1.106035] sensor_register_slave:lsm330_acc,id=26
[ 1.106053] sensor_register_slave:akm8975,id=29
[ 1.106069] sensor_register_slave:akm8963,id=30
[ 1.106086] sensor_register_slave:l3g4200d,id=44
[ 1.106102] sensor_register_slave:l3g20d,id=45
[ 1.106119] sensor_register_slave:ewtsa,id=46
[ 1.106135] sensor_register_slave:lsm330_gyro,id=50
[ 1.106152] sensor_register_slave:cm3217,id=52
[ 1.106168] sensor_register_slave:cm3218,id=53
[ 1.107126] i2c /dev entries driver
[ 1.108644] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 1.108760] fan53555-reg: supplied by vcc5v0_sys
[ 1.110697] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 1.110766] fan53555-reg: supplied by vcc5v0_sys
[ 1.112913] rk808 0-001b: Pmic Chip id: 0x0
[ 1.116399] rk808 0-001b: GPIO lookup for consumer dvs
[ 1.116412] rk808 0-001b: using device tree for GPIO lookup
[ 1.116426] of_get_named_gpiod_flags: can’t parse ‘dvs-gpios’ property of node ‘/i2c@ff3c0000/pmic@1b[0]’
[ 1.116438] of_get_named_gpiod_flags: can’t parse ‘dvs-gpio’ property of node ‘/i2c@ff3c0000/pmic@1b[0]’
[ 1.116449] rk808 0-001b: using lookup tables for GPIO lookup
[ 1.116460] rk808 0-001b: lookup for GPIO dvs failed
[ 1.116472] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.116488] rk808 0-001b: GPIO lookup for consumer dvs
[ 1.116497] rk808 0-001b: using device tree for GPIO lookup
[ 1.116508] of_get_named_gpiod_flags: can’t parse ‘dvs-gpios’ property of node ‘/i2c@ff3c0000/pmic@1b[1]’
[ 1.116519] of_get_named_gpiod_flags: can’t parse ‘dvs-gpio’ property of node ‘/i2c@ff3c0000/pmic@1b[1]’
[ 1.116530] rk808 0-001b: using lookup tables for GPIO lookup
[ 1.116539] rk808 0-001b: lookup for GPIO dvs failed
[ 1.116550] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.116659] DCDC_REG1: supplied by vcc3v3_sys
[ 1.117526] DCDC_REG2: supplied by vcc3v3_sys
[ 1.118205] DCDC_REG3: supplied by vcc3v3_sys
[ 1.118474] DCDC_REG4: supplied by vcc3v3_sys
[ 1.118942] LDO_REG1: supplied by vcc3v3_sys
[ 1.120165] LDO_REG2: supplied by vcc3v3_sys
[ 1.121196] LDO_REG3: supplied by vcc3v3_sys
[ 1.122222] LDO_REG4: supplied by vcc3v3_sys
[ 1.123281] LDO_REG5: supplied by vcc3v3_sys
[ 1.124314] LDO_REG6: supplied by vcc3v3_sys
[ 1.125342] LDO_REG7: supplied by vcc3v3_sys
[ 1.126370] LDO_REG8: supplied by vcc3v3_sys
[ 1.127426] SWITCH_REG1: supplied by vcc3v3_sys
[ 1.127699] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.131886] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 1.132453] of_get_named_gpiod_flags: parsed ‘pmic,hold-gpio’ property of node ‘/i2c@ff3c0000/pmic@1b[0]’ - status (0)
[ 1.132515] of_get_named_gpiod_flags: parsed ‘pmic,stby-gpio’ property of node ‘/i2c@ff3c0000/pmic@1b[0]’ - status (0)
[ 1.132569] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80098ac000
[ 1.133363] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80098ae000
[ 1.133486] rockchip-pinctrl pinctrl: pin gpio4-17 already requested by ff940000.hdmi; cannot claim for ff130000.i2c
[ 1.133504] rockchip-pinctrl pinctrl: pin-145 (ff130000.i2c) status -22
[ 1.133520] rockchip-pinctrl pinctrl: could not request pin 145 (gpio4-17) from group i2c3-xfer on device rockchip-pinctrl
[ 1.133536] rk3x-i2c ff130000.i2c: Error applying setting, reverse things back
[ 1.133996] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff80098b0000
[ 1.135070] fusb302 4-0022: GPIO lookup for consumer int-n
[ 1.135084] fusb302 4-0022: using device tree for GPIO lookup
[ 1.135122] of_get_named_gpiod_flags: parsed ‘int-n-gpios’ property of node ‘/i2c@ff3d0000/fusb30x@22[0]’ - status (0)
[ 1.135149] fusb302 4-0022: GPIO lookup for consumer vbus-5v
[ 1.135159] fusb302 4-0022: using device tree for GPIO lookup
[ 1.135189] of_get_named_gpiod_flags: parsed ‘vbus-5v-gpios’ property of node ‘/i2c@ff3d0000/fusb30x@22[0]’ - status (0)
[ 1.135216] fusb302 4-0022: GPIO lookup for consumer vbus-other
[ 1.135227] fusb302 4-0022: using device tree for GPIO lookup
[ 1.135238] of_get_named_gpiod_flags: can’t parse ‘vbus-other-gpios’ property of node ‘/i2c@ff3d0000/fusb30x@22[0]’
[ 1.135249] of_get_named_gpiod_flags: can’t parse ‘vbus-other-gpio’ property of node ‘/i2c@ff3d0000/fusb30x@22[0]’
[ 1.135260] fusb302 4-0022: using lookup tables for GPIO lookup
[ 1.135271] fusb302 4-0022: lookup for GPIO vbus-other failed
[ 1.135283] fusb302 4-0022: GPIO lookup for consumer discharge
[ 1.135292] fusb302 4-0022: using device tree for GPIO lookup
[ 1.135303] of_get_named_gpiod_flags: can’t parse ‘discharge-gpios’ property of node ‘/i2c@ff3d0000/fusb30x@22[0]’
[ 1.135313] of_get_named_gpiod_flags: can’t parse ‘discharge-gpio’ property of node ‘/i2c@ff3d0000/fusb30x@22[0]’
[ 1.135324] fusb302 4-0022: using lookup tables for GPIO lookup
[ 1.135334] fusb302 4-0022: lookup for GPIO discharge failed
[ 1.135345] fusb302 4-0022: GPIO lookup for consumer charge-en
[ 1.135355] fusb302 4-0022: using device tree for GPIO lookup
[ 1.135365] of_get_named_gpiod_flags: can’t parse ‘charge-en-gpios’ property of node ‘/i2c@ff3d0000/fusb30x@22[0]’
[ 1.135376] of_get_named_gpiod_flags: can’t parse ‘charge-en-gpio’ property of node ‘/i2c@ff3d0000/fusb30x@22[0]’
[ 1.135386] fusb302 4-0022: using lookup tables for GPIO lookup
[ 1.135397] fusb302 4-0022: lookup for GPIO charge-en failed
[ 1.138968] fusb302 4-0022: Can’t get property of role, set role to default DRP
[ 1.147865] fusb302 4-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 1.148045] GSLX680 Enter gsl_ts_probe
[ 1.153463] fusb302 4-0022: port 0, state 3
[ 1.348028] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 1.364857] fusb302 4-0022: port 0, state 6
[ 1.366721] fusb302 4-0022: port 0, state 19
[ 1.366732] fusb302 4-0022: CC connected in CC2 as UFP
[ 1.369173] fusb302 4-0022: port 0, state 20
[ 1.369182] fusb302 4-0022: port 0
[ 1.369190] fusb302 4-0022: orientation 1
[ 1.369198] fusb302 4-0022: power_role 0
[ 1.369205] fusb302 4-0022: data_role 0
[ 1.369212] fusb302 4-0022: cc 1
[ 1.369219] fusb302 4-0022: pd 0
[ 1.369226] fusb302 4-0022: enter_mode 0
[ 1.369233] fusb302 4-0022: pin support 0
[ 1.369241] fusb302 4-0022: pin def 0
[ 1.369248] fusb302 4-0022: attention 0
[ 1.370724] fusb302 4-0022: port 0, state 21
[ 1.458061] gsl_ts_probe–1305, i2c_master_recv fail
[ 1.458261] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80098b2000
[ 1.459483] IR NEC protocol handler initialized
[ 1.459499] IR RC5(x/sz) protocol handler initialized
[ 1.459513] IR RC6 protocol handler initialized
[ 1.459527] IR JVC protocol handler initialized
[ 1.459541] IR Sony protocol handler initialized
[ 1.459555] IR SANYO protocol handler initialized
[ 1.459568] IR Sharp protocol handler initialized
[ 1.459583] IR MCE Keyboard/mouse protocol handler initialized
[ 1.459597] IR XMP protocol handler initialized
[ 1.459899] usbcore: registered new interface driver uvcvideo
[ 1.459910] USB Video Class driver (1.1.1)
[ 1.459929] CamSys driver version: v0.38.0, CamSys head file version: v1.0.0
[ 1.471505] __power_supply_register: Expected proper parent device for ‘test_ac’
[ 1.471736] __power_supply_register: Expected proper parent device for ‘test_battery’
[ 1.472000] usb 1-1: New USB device found, idVendor=1a40, idProduct=0201
[ 1.472018] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.472032] usb 1-1: Product: USB 2.0 Hub [MTT]
[ 1.472160] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 1.472340] __power_supply_register: Expected proper parent device for ‘test_usb’
[ 1.472756] hub 1-1:1.0: USB hub found
[ 1.472872] hub 1-1:1.0: 7 ports detected
[ 1.475933] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 1.482597] device-mapper: uevent: version 1.0.3
[ 1.483050] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 1.483307] Bluetooth: HCI UART driver ver 2.3
[ 1.483321] Bluetooth: HCI UART protocol H4 registered
[ 1.483367] Bluetooth: HCI UART protocol LL registered
[ 1.483386] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 1.483398] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[ 1.483409] rtk_btusb: Register usb char device interface for BT driver
[ 1.483702] usbcore: registered new interface driver rtk_btusb
[ 1.484277] cpu cpu0: leakage=21
[ 1.502113] cpu cpu0: temp=39375, pvtm=144043 (144273 + -230)
[ 1.502539] cpu cpu0: pvtm-sel=1
[ 1.502948] cpu cpu4: leakage=37
[ 1.515266] cpu cpu4: temp=39375, pvtm=151614 (151756 + -142)
[ 1.515419] cpu cpu4: pvtm-sel=1
[ 1.520958] sdhci: Secure Digital Host Controller Interface driver
[ 1.521006] sdhci: Copyright(c) Pierre Ossman
[ 1.521025] Synopsys Designware Multimedia Card Interface Driver
[ 1.522283] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.522446] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.522468] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.522525] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.522567] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.522624] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.522637] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.522659] dwmmc_rockchip fe310000.dwmmc: GPIO lookup for consumer wp
[ 1.522670] dwmmc_rockchip fe310000.dwmmc: using device tree for GPIO lookup
[ 1.522683] of_get_named_gpiod_flags: can’t parse ‘wp-gpios’ property of node ‘/dwmmc@fe310000[0]’
[ 1.522694] of_get_named_gpiod_flags: can’t parse ‘wp-gpio’ property of node ‘/dwmmc@fe310000[0]’
[ 1.522705] dwmmc_rockchip fe310000.dwmmc: using lookup tables for GPIO lookup
[ 1.522716] dwmmc_rockchip fe310000.dwmmc: lookup for GPIO wp failed
[ 1.523829] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.523928] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 1.523948] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 1.523999] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 1.524026] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.524151] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 1.524176] dwmmc_rockchip fe320000.dwmmc: GPIO lookup for consumer cd
[ 1.524187] dwmmc_rockchip fe320000.dwmmc: using device tree for GPIO lookup
[ 1.524200] of_get_named_gpiod_flags: can’t parse ‘cd-gpios’ property of node ‘/dwmmc@fe320000[0]’
[ 1.524211] of_get_named_gpiod_flags: can’t parse ‘cd-gpio’ property of node ‘/dwmmc@fe320000[0]’
[ 1.524221] dwmmc_rockchip fe320000.dwmmc: using lookup tables for GPIO lookup
[ 1.524232] dwmmc_rockchip fe320000.dwmmc: lookup for GPIO cd failed
[ 1.524245] dwmmc_rockchip fe320000.dwmmc: GPIO lookup for consumer wp
[ 1.524254] dwmmc_rockchip fe320000.dwmmc: using device tree for GPIO lookup
[ 1.524265] of_get_named_gpiod_flags: can’t parse ‘wp-gpios’ property of node ‘/dwmmc@fe320000[0]’
[ 1.524276] of_get_named_gpiod_flags: can’t parse ‘wp-gpio’ property of node ‘/dwmmc@fe320000[0]’
[ 1.524286] dwmmc_rockchip fe320000.dwmmc: using lookup tables for GPIO lookup
[ 1.524296] dwmmc_rockchip fe320000.dwmmc: lookup for GPIO wp failed
[ 1.524484] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.524820] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.538067] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.552518] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 1.552834] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.553350] sdhci-arasan fe330000.sdhci: GPIO lookup for consumer wp
[ 1.553362] sdhci-arasan fe330000.sdhci: using device tree for GPIO lookup
[ 1.553373] of_get_named_gpiod_flags: can’t parse ‘wp-gpios’ property of node ‘/sdhci@fe330000[0]’
[ 1.553383] of_get_named_gpiod_flags: can’t parse ‘wp-gpio’ property of node ‘/sdhci@fe330000[0]’
[ 1.553392] sdhci-arasan fe330000.sdhci: using lookup tables for GPIO lookup
[ 1.553402] sdhci-arasan fe330000.sdhci: lookup for GPIO wp failed
[ 1.554642] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 1.554656] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 1.584770] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 1.585794] of_get_named_gpiod_flags: parsed ‘gpios’ property of node ‘/leds/power[0]’ - status (0)
[ 1.585996] of_get_named_gpiod_flags: parsed ‘gpios’ property of node ‘/leds/user[0]’ - status (0)
[ 1.586467] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.591296] usbcore: registered new interface driver usbhid
[ 1.591321] usbhid: USB HID core driver
[ 1.591669] of_get_named_gpiod_flags: parsed ‘irq-gpio’ property of node ‘/i2c@ff3d0000/mpu@68[0]’ - status (0)
[ 1.591708] inv-mpu-iio 4-0068: int_config=0,level_shifter=0,client.addr=68,client.irq=6b
[ 1.591724] inv-mpu-iio 4-0068: 0
[ 1.591735] inv-mpu-iio 4-0068: -1
[ 1.591746] inv-mpu-iio 4-0068: 0
[ 1.591756] inv-mpu-iio 4-0068: -1
[ 1.591767] inv-mpu-iio 4-0068: 0
[ 1.591777] inv-mpu-iio 4-0068: 0
[ 1.591788] inv-mpu-iio 4-0068: 0
[ 1.591798] inv-mpu-iio 4-0068: 0
[ 1.591809] inv-mpu-iio 4-0068: -1
[ 1.591820] inv-mpu-iio 4-0068:
[ 1.591828] inv_mpu_iio: secondary_i2c_addr=0
[ 1.592322] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 1.633396] mmc1: MAN_BKOPS_EN bit is not set
[ 1.648331] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[ 1.649563] mmcblk1: mmc1:0001 AJTD4R 14.6 GiB
[ 1.650456] mmcblk1boot0: mmc1:0001 AJTD4R partition 1 4.00 MiB
[ 1.651325] mmcblk1boot1: mmc1:0001 AJTD4R partition 2 4.00 MiB
[ 1.652190] mmcblk1rpmb: mmc1:0001 AJTD4R partition 3 4.00 MiB
[ 1.652742] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 1.652756] trust: 0x000800000 – 0x000c00000 (4 MB)
[ 1.652769] misc: 0x000c00000 – 0x001000000 (4 MB)
[ 1.652781] resource: 0x001000000 – 0x002000000 (16 MB)
[ 1.652792] kernel: 0x002000000 – 0x003800000 (24 MB)
[ 1.652804] boot: 0x003800000 – 0x005800000 (32 MB)
[ 1.652816] recovery: 0x005800000 – 0x007800000 (32 MB)
[ 1.652828] backup: 0x007800000 – 0x00e800000 (112 MB)
[ 1.652840] cache: 0x00e800000 – 0x016800000 (128 MB)
[ 1.652851] system: 0x016800000 – 0x076800000 (1536 MB)
[ 1.652863] metadata: 0x076800000 – 0x077800000 (16 MB)
[ 1.652875] baseparamer: 0x077800000 – 0x077c00000 (4 MB)
[ 1.652887] userdata: 0x077c00000 – 0x3a3a00000 (12990 MB)
[ 1.652956] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13
[ 1.695419] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 1.799045] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 1.873959] fusb302 4-0022: port 0, state 26
[ 1.886934] fusb302 4-0022: port 0, state 28
[ 1.892677] fusb302 4-0022: port 0, state 29
[ 1.901965] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 2.005718] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 2.109044] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 2.212380] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 2.315744] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 2.419051] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 2.522429] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 2.582106] fusb302 4-0022: port 0, state 19
[ 2.588582] fusb302 4-0022: port 0, state 20
[ 2.591675] fusb302 4-0022: port 0, state 21
[ 2.729147] i2c i2c-4: inv_mpu_probe failed -6
[ 2.729239] inv-mpu-iio: probe of 4-0068 failed with error -5
[ 2.729342] inv_mpu_iio: inv_mpu_init:746
[ 2.731249] ashmem: initialized
[ 2.735841] ff100000.saradc supply vref not found, using dummy regulator
[ 2.740420] rknandbase v1.1 2016-11-08
[ 2.741901] usbcore: registered new interface driver snd-usb-audio
[ 2.745019] rt5640 1-001c: rt5640 have no aux_det_adc_value defined
[ 2.745111] of_get_named_gpiod_flags: parsed ‘hp-con-gpio’ property of node ‘/i2c@ff110000/rt5640@1c[0]’ - status (0)
[ 2.745175] of_get_named_gpiod_flags: can’t parse ‘hp-det-gpio’ property of node ‘/i2c@ff110000/rt5640@1c[0]’
[ 2.745198] rt5640 1-001c: Can not read property hp-con-gpio
[ 2.745224] rt5640 1-001c: Can not read property: linein-mute.
[ 2.745251] of_get_named_gpiod_flags: can’t parse ‘realtek,ldo1-en-gpios’ property of node ‘/i2c@ff110000/rt5640@1c[0]’
[ 2.773907] u32 classifier
[ 2.774231] Actions configured
[ 2.774735] Netfilter messages via NETLINK v0.30.
[ 2.775329] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 2.776733] ctnetlink v0.93: registering with nfnetlink.
[ 2.778888] xt_time: kernel timezone is -0000
[ 2.781966] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.782881] arp_tables: (C) 2002 David S. Miller
[ 2.784727] Initializing XFRM netlink socket
[ 2.785811] NET: Registered protocol family 10
[ 2.787509] mip6: Mobile IPv6
[ 2.787819] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.791859] sit: IPv6 over IPv4 tunneling driver
[ 2.792797] NET: Registered protocol family 17
[ 2.793228] NET: Registered protocol family 15
[ 2.793668] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 2.796972] Bridge firewalling registered
[ 2.797353] Ebtables v2.0 registered
[ 2.798243] Bluetooth: RFCOMM TTY layer initialized
[ 2.798706] Bluetooth: RFCOMM socket layer initialized
[ 2.799209] Bluetooth: RFCOMM ver 1.11
[ 2.799570] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.800057] Bluetooth: BNEP filters: protocol multicast
[ 2.800537] Bluetooth: BNEP socket layer initialized
[ 2.800995] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.801539] Bluetooth: HIDP socket layer initialized
[ 2.802048] l2tp_core: L2TP core driver, V2.0
[ 2.802086] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 2.802102] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.802575] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 2.802662] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[ 2.802672] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 2.802681] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 2.802693] of_get_named_gpiod_flags: can’t parse ‘WIFI,poweren_gpio’ property of node ‘/wireless-wlan[0]’
[ 2.802701] of_get_named_gpiod_flags: can’t parse ‘WIFI,vbat_gpio’ property of node ‘/wireless-wlan[0]’
[ 2.802710] of_get_named_gpiod_flags: can’t parse ‘WIFI,reset_gpio’ property of node ‘/wireless-wlan[0]’
[ 2.802764] of_get_named_gpiod_flags: parsed ‘WIFI,host_wake_irq’ property of node ‘/wireless-wlan[0]’ - status (0)
[ 2.802772] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 2.802781] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 2.802794] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 2.802863] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.803366] of_get_named_gpiod_flags: parsed ‘uart_rts_gpios’ property of node ‘/wireless-bluetooth[0]’ - status (0)
[ 2.803376] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 2.803390] of_get_named_gpiod_flags: can’t parse ‘BT,power_gpio’ property of node ‘/wireless-bluetooth[0]’
[ 2.803415] of_get_named_gpiod_flags: parsed ‘BT,reset_gpio’ property of node ‘/wireless-bluetooth[0]’ - status (0)
[ 2.803423] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 2.803449] of_get_named_gpiod_flags: parsed ‘BT,wake_gpio’ property of node ‘/wireless-bluetooth[0]’ - status (0)
[ 2.803457] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 2.803482] of_get_named_gpiod_flags: parsed ‘BT,wake_host_irq’ property of node ‘/wireless-bluetooth[0]’ - status (0)
[ 2.803489] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 2.804104] [BT_RFKILL]: Request irq for bt wakeup host
[ 2.804169] [BT_RFKILL]: ** disable irq
[ 2.804318] [BT_RFKILL]: bt_default device registered.
[ 2.804804] sensor_register_slave:mpu6880_gyro,id=49
[ 2.806472] Registered cp15_barrier emulation handler
[ 2.806648] Registered setend emulation handler
[ 2.807446] registered taskstats version 1
[ 2.808775] rockchip ion idev is NULL
[ 2.808793] rga2 ff680000.rga: rga ion client create success!
[ 2.809057] rga: Driver loaded successfully ver:3.02
[ 2.810719] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: GPIO lookup for consumer otg-vbus
[ 2.810732] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: using device tree for GPIO lookup
[ 2.810744] of_get_named_gpiod_flags: can’t parse ‘otg-vbus-gpios’ property of node ‘/syscon@ff770000/usb2-phy@e450[0]’
[ 2.810754] of_get_named_gpiod_flags: can’t parse ‘otg-vbus-gpio’ property of node ‘/syscon@ff770000/usb2-phy@e450[0]’
[ 2.810763] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: using lookup tables for GPIO lookup
[ 2.810773] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: lookup for GPIO otg-vbus failed
[ 2.810783] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not assigned
[ 2.813514] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 2.813765] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 2.813999] rockchip-dp ff970000.edp: failed to get vcc regulator: -19
[ 2.814011] rockchip-dp ff970000.edp: failed to get vccio regulator: -19
[ 2.814089] rockchip-dp ff970000.edp: no DP phy configured
[ 2.814124] of_get_named_gpiod_flags: can’t parse ‘hpd-gpios’ property of node ‘/edp@ff970000[0]’
[ 2.814134] of_get_named_gpiod_flags: can’t parse ‘samsung,hpd-gpio’ property of node ‘/edp@ff970000[0]’
[ 2.850486] vendor storage:20160801 ret = 0
[ 2.860643] rockchip-drm display-subsystem: bound ff970000.edp (ops rockchip_dp_component_ops)
[ 2.861914] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 2.862540] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 2.863313] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 2.866244] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[ 2.867488] i2c i2c-10: of_i2c: modalias failure on /dp@fec00000/ports
[ 2.868702] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 2.869487] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops)
[ 2.870217] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.870939] [drm:drm_vblank_init] No driver support for vblank timestamp query.
[ 2.906756] rockchip-drm display-subsystem: fb0: frame buffer device
[ 2.920710] mali ff9a0000.gpu: leakage=25
[ 2.934074] mali ff9a0000.gpu: temp=40000, pvtm=121299 (121345 + -46)
[ 2.935560] mali ff9a0000.gpu: pvtm-sel=1
[ 2.937245] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 2.938579] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 284; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 2.940061] mali ff9a0000.gpu: Probed as mali0
[ 2.945324] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 2.945462] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 3
[ 2.946044] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 2.946150] xhci-hcd xhci-hcd.10.auto: irq 234, io mem 0xfe800000
[ 2.946490] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.946523] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.946550] usb usb3: Product: xHCI Host Controller
[ 2.946575] usb usb3: Manufacturer: Linux 4.4.103 xhci-hcd
[ 2.946599] usb usb3: SerialNumber: xhci-hcd.10.auto
[ 2.947831] hub 3-0:1.0: USB hub found
[ 2.947918] hub 3-0:1.0: 1 port detected
[ 2.948594] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 2.948639] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 4
[ 2.948797] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 2.949052] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.949084] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.949111] usb usb4: Product: xHCI Host Controller
[ 2.949135] usb usb4: Manufacturer: Linux 4.4.103 xhci-hcd
[ 2.949159] usb usb4: SerialNumber: xhci-hcd.10.auto
[ 2.950369] hub 4-0:1.0: USB hub found
[ 2.950454] hub 4-0:1.0: 1 port detected
[ 2.954121] xhci-hcd xhci-hcd.10.auto: remove, state 1
[ 2.954187] usb usb4: USB disconnect, device number 1
[ 2.978863] xhci-hcd xhci-hcd.10.auto: Host not halted after 16000 microseconds.
[ 2.978945] xhci-hcd xhci-hcd.10.auto: Host controller not halted, aborting reset.
[ 2.980482] xhci-hcd xhci-hcd.10.auto: USB bus 4 deregistered
[ 2.981014] xhci-hcd xhci-hcd.10.auto: remove, state 1
[ 2.981497] usb usb3: USB disconnect, device number 1
[ 2.982577] xhci-hcd xhci-hcd.10.auto: USB bus 3 deregistered
[ 2.989099] rockchip-dwc3 usb@fe800000: USB peripheral connected
[ 2.989904] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 2.990438] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 3
[ 2.991547] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 2.992383] xhci-hcd xhci-hcd.11.auto: irq 235, io mem 0xfe900000
[ 2.993087] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.993707] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.994360] usb usb3: Product: xHCI Host Controller
[ 2.994809] usb usb3: Manufacturer: Linux 4.4.103 xhci-hcd
[ 2.995311] usb usb3: SerialNumber: xhci-hcd.11.auto
[ 2.996398] hub 3-0:1.0: USB hub found
[ 2.996773] hub 3-0:1.0: 1 port detected
[ 2.997421] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 2.997943] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 4
[ 2.998700] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 2.999512] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.999531] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.999542] usb usb4: Product: xHCI Host Controller
[ 2.999552] usb usb4: Manufacturer: Linux 4.4.103 xhci-hcd
[ 2.999562] usb usb4: SerialNumber: xhci-hcd.11.auto
[ 3.002535] hub 4-0:1.0: USB hub found
[ 3.002575] hub 4-0:1.0: 1 port detected
[ 3.005691] ehci-platform fe380000.usb: EHCI Host Controller
[ 3.005727] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
[ 3.005983] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 3.014733] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 3.014893] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.014907] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.014918] usb usb5: Product: EHCI Host Controller
[ 3.014929] usb usb5: Manufacturer: Linux 4.4.103 ehci_hcd
[ 3.014939] usb usb5: SerialNumber: fe380000.usb
[ 3.018458] hub 5-0:1.0: USB hub found
[ 3.018499] hub 5-0:1.0: 1 port detected
[ 3.019352] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 3.019382] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6
[ 3.019581] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 3.075621] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.075648] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.075662] usb usb6: Product: Generic Platform OHCI controller
[ 3.075675] usb usb6: Manufacturer: Linux 4.4.103 ohci_hcd
[ 3.075688] usb usb6: SerialNumber: fe3a0000.usb
[ 3.078843] hub 6-0:1.0: USB hub found
[ 3.078893] hub 6-0:1.0: 1 port detected
[ 3.080466] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 3.080594] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 3.080615] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 3.080656] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 3.080684] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 3.080741] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 3.080754] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 3.080778] dwmmc_rockchip fe310000.dwmmc: GPIO lookup for consumer wp
[ 3.080788] dwmmc_rockchip fe310000.dwmmc: using device tree for GPIO lookup
[ 3.080802] of_get_named_gpiod_flags: can’t parse ‘wp-gpios’ property of node ‘/dwmmc@fe310000[0]’
[ 3.080813] of_get_named_gpiod_flags: can’t parse ‘wp-gpio’ property of node ‘/dwmmc@fe310000[0]’
[ 3.080824] dwmmc_rockchip fe310000.dwmmc: using lookup tables for GPIO lookup
[ 3.080835] dwmmc_rockchip fe310000.dwmmc: lookup for GPIO wp failed
[ 3.081090] platform sdio-pwrseq: GPIO lookup for consumer reset
[ 3.081101] platform sdio-pwrseq: using device tree for GPIO lookup
[ 3.081132] of_get_named_gpiod_flags: parsed ‘reset-gpios’ property of node ‘/sdio-pwrseq[0]’ - status (0)
[ 3.081168] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 3.093949] fusb302 4-0022: port 0, state 28
[ 3.098184] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 3.098907] fusb302 4-0022: port 0, state 29
[ 3.111462] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 3.112246] of_get_named_gpiod_flags: can’t parse ‘simple-audio-card,hp-det-gpio’ property of node ‘/hdmi-sound[0]’
[ 3.112263] of_get_named_gpiod_flags: can’t parse ‘simple-audio-card,mic-det-gpio’ property of node ‘/hdmi-sound[0]’
[ 3.113118] asoc-simple-card hdmi-sound: i2s-hifi ↔ ff8a0000.i2s mapping ok
[ 3.115754] of_get_named_gpiod_flags: can’t parse ‘simple-audio-card,hp-det-gpio’ property of node ‘/rt5640-sound[0]’
[ 3.115782] of_get_named_gpiod_flags: can’t parse ‘simple-audio-card,mic-det-gpio’ property of node ‘/rt5640-sound[0]’
[ 3.129621] asoc-simple-card rt5640-sound: rt5640-aif1 ↔ ff890000.i2s mapping ok
[ 3.135762] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card1/input1
[ 3.137856] of_get_named_gpiod_flags: can’t parse ‘simple-audio-card,hp-det-gpio’ property of node ‘/spdif-sound[0]’
[ 3.137880] of_get_named_gpiod_flags: can’t parse ‘simple-audio-card,mic-det-gpio’ property of node ‘/spdif-sound[0]’
[ 3.139895] asoc-simple-card spdif-sound: dit-hifi ↔ ff870000.spdif mapping ok
[ 3.141871] otg_wakelock_init: No USB transceiver found
[ 3.143685] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:05 UTC (1358499005)
[ 3.146600] It doesn’t contain Rogue gpu
[ 3.156434] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 3.158147] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.159836] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.162834] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 3.166432] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
[ 3.178149] ret 1024
[ 3.179167] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 414; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, built at ‘09:29:49’, on ‘Apr 20 2021’.
[ 3.181429] Mali: Mali device driver loaded
[ 3.182176] of_get_named_gpiod_flags: parsed ‘gpios’ property of node ‘/rockchip-key/power-key[0]’ - status (0)
[ 3.182201] of_get_named_gpiod_flags: parsed ‘gpios’ property of node ‘/rockchip-key/power-key[0]’ - status (0)
[ 3.182375] input: rk29-keypad as /devices/platform/rockchip-key/input/input2
[ 3.184308] ALSA device list:
[ 3.184606] #0: rockchip,hdmi
[ 3.184907] #1: rockchip,rt5640-codec
[ 3.185266] #2: ROCKCHIP,SPDIF
[ 3.186071] Freeing unused kernel memory: 832K
[ 3.188739] init: init first stage started!
[ 3.190439] init: init second stage started!
[ 3.193287] init: Setting ro.rk.soc=rk3399
[ 3.193762] init: OK,EMMC DRIVERS INIT OK
[ 3.194154] init: property_set(“ro.boot.mode”, “emmc”) failed
[ 3.194778] init: property_set(“ro.hardware”, “rk30board”) failed
[ 3.195378] init: Running restorecon…
[ 3.195860] init: waitpid failed: No child processes
[ 3.196662] init: (Loading properties from /default.prop took 0.00s.)
[ 3.199000] init: /init.rc: 588: invalid keyword ‘echo’
[ 3.199968] init: (Parsing /init.environ.rc took 0.00s.)
[ 3.200930] init: (Parsing /init.usb.rc took 0.00s.)
[ 3.202560] init: (Parsing init.rk30board.bootmode.emmc.rc took 0.00s.)
[ 3.204059] init: (Parsing init.rk30board.usb.rc took 0.00s.)
[ 3.204633] init: (Parsing init.rk30board.environment.rc took 0.00s.)
[ 3.205300] init: could not import file ‘/init.stt_trace.rc’ from ‘/init.debug.rc’: No such file or directory
[ 3.206384] init: (Parsing /init.logs.rc took 0.00s.)
[ 3.206937] init: (Parsing /init.crashlogd.rc took 0.00s.)
[ 3.207523] init: (Parsing /init.coredump.rc took 0.00s.)
[ 3.208095] init: (Parsing /init.log-watch.rc took 0.00s.)
[ 3.208654] init: (Parsing /init.kernel.rc took 0.00s.)
[ 3.209239] init: (Parsing /init.debug-charging.rc took 0.00s.)
[ 3.209784] init: (Parsing /init.debug.rc took 0.00s.)
[ 3.210268] init: (Parsing init.rockchip.rc took 0.01s.)
[ 3.211323] init: (Parsing init.connectivity.rc took 0.00s.)
[ 3.212078] init: (Parsing init.box.samba.rc took 0.00s.)
[ 3.212696] init: (Parsing init.rk3399.rc took 0.00s.)
[ 3.213296] init: init.box.rc: 25: invalid keyword ‘ioprio’
[ 3.213827] init: (Parsing init.box.rc took 0.00s.)
[ 3.214314] init: could not import file ‘init.car.rc’ from ‘/init.rk30board.rc’: No such file or directory
[ 3.214356] init: could not import file ‘init.optee.rc’ from ‘/init.rk30board.rc’: No such file or directory
[ 3.214378] init: (Parsing /init.rk30board.rc took 0.01s.)
[ 3.217446] init: (Parsing /init.usb.configfs.rc took 0.00s.)
[ 3.217578] init: (Parsing /init.zygote64_32.rc took 0.00s.)
[ 3.217598] init: (Parsing /init.rc took 0.02s.)
[ 3.217654] mmc_host mmc2: Bus speed (slot 0) = 200000000Hz (slot req 208000000Hz, actual 200000000HZ div = 0)
[ 3.217988] init: Starting service ‘ueventd’…
[ 3.219455] init: write_file: Unable to open ‘/proc/self/coredump_filter’: No such file or directory
[ 3.219514] init: write_file: Unable to open ‘/proc/sys/kernel/panic_on_stackoverflow’: No such file or directory
[ 3.223250] ueventd: ueventd started!
[ 3.224909] ueventd: invalid gid ‘trace’
[ 3.263871] init: Waiting for /dev/.coldboot_done…
[ 3.329701] ueventd: Coldboot took 0.10s.
[ 3.335130] init: Waiting for /dev/.coldboot_done took 0.07s.
[ 3.335257] init: /dev/hw_random not found
[ 3.335883] keychord: using input dev ff420030.pwm for fevent
[ 3.335892] keychord: using input dev rk29-keypad for fevent
[ 3.340565] init: write_file: Unable to open ‘/proc/cpu/alignment’: No such file or directory
[ 3.348284] Registered swp emulation handler
[ 3.348478] init: write_file: Unable to open ‘/sys/module/rockchip_pm/parameters/policy’: No such file or directory
[ 3.348980] init: /dev/hw_random not found
[ 3.349107] init: write_file: Unable to open ‘/sys/block/mmcblk0/bdi/read_ahead_kb’: No such file or directory
[ 3.349708] fs_mgr: Warning: unknown flag resize
[ 3.352972] EXT4-fs (mmcblk1p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 3.353812] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/system,target=/system,type=ext4)=0
[ 3.355440] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/cache,/cache,ext4)=-1: No such file or directory
[ 3.356979] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/cache
[ 3.363616] random: e2fsck: uninitialized urandom read (40 bytes read, 52 bits of entropy available)
[ 3.401507] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 3.401507]
[ 3.402088] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/cache: recovering journal
[ 3.402088]
[ 3.402935] e2fsck: Superblock last mount time is in the future.
[ 3.402935]
[ 3.403603] e2fsck: (by less than a day, probably due to the hardware clock being incorrectly set) Fix? yes
[ 3.403603]
[ 3.404612] e2fsck:
[ 3.404612]
[ 3.404953] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/cache: clean, 21/8192 files, 1591/32768 blocks (check in 3 mounts)
[ 3.404953]
[ 3.408586] EXT4-fs (mmcblk1p9): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 3.408663] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/cache,target=/cache,type=ext4)=0
[ 3.409270] EXT4-fs (mmcblk1p11): Ignoring removed nomblk_io_submit option
[ 3.411733] EXT4-fs (mmcblk1p11): recovery complete
[ 3.411757] EXT4-fs (mmcblk1p11): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[ 3.411810] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/metadata,/metadata,ext4)=0: Success
[ 3.426316] fs_mgr: check_fs(): unmount(/metadata) succeeded
[ 3.426362] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/metadata
[ 3.428238] random: e2fsck: uninitialized urandom read (40 bytes read, 56 bits of entropy available)
[ 3.436943] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 3.436943]
[ 3.437013] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/metadata: clean, 11/1024 files, 1102/4096 blocks (check in 2 mounts)
[ 3.437013]
[ 3.439633] EXT4-fs (mmcblk1p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 3.439702] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/metadata,target=/metadata,type=ext4)=0
[ 3.439773] fs_mgr: Running /system/bin/fsck.f2fs -a /dev/block/platform/fe330000.sdhci/by-name/userdata
[ 3.442292] fsck.f2fs: executing /system/bin/fsck.f2fs failed: No such file or directory
[ 3.442292]
[ 3.442324] fsck.f2fs: fsck.f2fs terminated by exit(255)
[ 3.442324]
[ 3.493083] F2FS-fs (mmcblk1p13): recover_inode: ino = 9c0, name = mediacenter.db-wal
[ 3.493218] F2FS-fs (mmcblk1p13): recover_data: ino = 9c0 (i_size: recover) recovered = 3, err = 0
[ 3.493232] F2FS-fs (mmcblk1p13): recover_inode: ino = 9c2, name = shortcuts.xml
[ 3.495175] F2FS-fs (mmcblk1p13): recover_dentry: ino = 9c2, name = shortcuts.xml, dir = 46a, err = 0
[ 3.495202] F2FS-fs (mmcblk1p13): recover_data: ino = 9c2 (i_size: recover) recovered = 0, err = 0
[ 3.495212] F2FS-fs (mmcblk1p13): recover_inode: ino = 9c0, name = mediacenter.db-wal
[ 3.495263] F2FS-fs (mmcblk1p13): recover_data: ino = 9c0 (i_size: recover) recovered = 2, err = 0
[ 3.495274] F2FS-fs (mmcblk1p13): recover_inode: ino = 9c3, name = drop189.tmp
[ 3.495889] F2FS-fs (mmcblk1p13): recover_dentry: ino = 9c3, name = drop189.tmp, dir = 5a, err = 0
[ 3.495926] F2FS-fs (mmcblk1p13): recover_data: ino = 9c3 (i_size: recover) recovered = 0, err = 0
[ 3.498564] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/userdata,target=/data,type=f2fs)=0
[ 3.501597] init: (Parsing /system/etc/init/atrace.rc took 0.00s.)
[ 3.501872] init: (Parsing /system/etc/init/audioserver.rc took 0.00s.)
[ 3.502073] init: (Parsing /system/etc/init/bootanim.rc took 0.00s.)
[ 3.502365] init: (Parsing /system/etc/init/bootstat.rc took 0.00s.)
[ 3.502584] init: (Parsing /system/etc/init/cameraserver.rc took 0.00s.)
[ 3.502771] init: (Parsing /system/etc/init/debuggerd.rc took 0.00s.)
[ 3.502960] init: (Parsing /system/etc/init/debuggerd64.rc took 0.00s.)
[ 3.503170] init: (Parsing /system/etc/init/drmserver.rc took 0.00s.)
[ 3.503445] init: (Parsing /system/etc/init/dumpstate.rc took 0.00s.)
[ 3.503646] init: (Parsing /system/etc/init/gatekeeperd.rc took 0.00s.)
[ 3.503875] init: (Parsing /system/etc/init/init-debug.rc took 0.00s.)
[ 3.504084] init: (Parsing /system/etc/init/installd.rc took 0.00s.)
[ 3.504293] init: (Parsing /system/etc/init/keystore.rc took 0.00s.)
[ 3.504503] init: (Parsing /system/etc/init/lmkd.rc took 0.00s.)
[ 3.504923] init: (Parsing /system/etc/init/logcatd.rc took 0.00s.)
[ 3.505206] init: (Parsing /system/etc/init/logd.rc took 0.00s.)
[ 3.505423] init: (Parsing /system/etc/init/mdnsd.rc took 0.00s.)
[ 3.505616] init: (Parsing /system/etc/init/mediacodec.rc took 0.00s.)
[ 3.505805] init: (Parsing /system/etc/init/mediadrmserver.rc took 0.00s.)
[ 3.506011] init: (Parsing /system/etc/init/mediaextractor.rc took 0.00s.)
[ 3.506217] init: (Parsing /system/etc/init/mediaserver.rc took 0.00s.)
[ 3.506420] init: (Parsing /system/etc/init/mtpd.rc took 0.00s.)
[ 3.506614] init: (Parsing /system/etc/init/netd.rc took 0.00s.)
[ 3.506802] init: (Parsing /system/etc/init/perfprofd.rc took 0.00s.)
[ 3.506998] init: (Parsing /system/etc/init/racoon.rc took 0.00s.)
[ 3.507217] init: ignored duplicate definition of service 'ril-daemon’init: (Parsing /system/etc/init/rild.rc took 0.00s.)
[ 3.507470] init: (Parsing /system/etc/init/servicemanager.rc took 0.00s.)
[ 3.507679] init: (Parsing /system/etc/init/surfaceflinger.rc took 0.00s.)
[ 3.507910] init: (Parsing /system/etc/init/uncrypt.rc took 0.00s.)
[ 3.508168] init: (Parsing /system/etc/init/vdc.rc took 0.00s.)
[ 3.508429] init: (Parsing /system/etc/init/vold.rc took 0.00s.)
[ 3.509483] init: property_set(“ro.board.platform”, “rk3399”) failed
[ 3.509868] init: property_set(“ro.rk.screenoff_time”, “2147483647”) failed
[ 3.510026] init: property_set(“ro.rk.screenshot_enable”, “true”) failed
[ 3.510132] init: (Loading properties from /system/build.prop took 0.00s.)
[ 3.510172] init: (Loading properties from /vendor/build.prop took 0.00s.)
[ 3.510205] init: (Loading properties from /factory/factory.prop took 0.00s.)
[ 3.510297] fs_mgr: Warning: unknown flag resize
[ 3.510379] init: /recovery not specified in fstab
[ 3.510474] init: Starting service ‘healthd’…
[ 3.510855] init: cannot find ‘/system/bin/displayd’ (No such file or directory), disabling ‘displayd’
[ 3.511430] init: Starting service ‘earlylogs’…
[ 3.511854] init: Starting service ‘zygote’…
[ 3.512138] init: Starting service ‘zygote_secondary’…
[ 3.512451] init: Starting service ‘lmkd’…
[ 3.512817] init: Starting service ‘servicemanager’…
[ 3.513283] init: Starting service ‘surfaceflinger’…
[ 3.514276] init: Starting service ‘vold’…
[ 3.514989] binder: 202:202 transaction failed 29189/-22, size 0-0 line 2951
[ 3.516123] random: surfaceflinger: uninitialized urandom read (40 bytes read, 62 bits of entropy available)
[ 3.516357] random: elogs.sh: uninitialized urandom read (40 bytes read, 62 bits of entropy available)
[ 3.516443] random: lmkd: uninitialized urandom read (40 bytes read, 62 bits of entropy available)
[ 3.520181] init: insmod: open(“/system/lib/modules/ump.ko”) failed: No such file or directoryinit: insmod: open(“/system/lib/modules/mali.ko”) failed: No such file or directoryinit: insmod: open(“/system/lib/modules/mali_kbase.ko”) failed: No such file or directoryinit: insmod: open(“/system/lib/modules/rk30_mirroring.ko”) failed: No such file or directory
[ 3.520413] random: servicemanager: uninitialized urandom read (40 bytes read, 63 bits of entropy available)
[ 3.522927] init: finit_module for “/system/lib/modules/rk29-ipp.ko” failed: Exec format errorinit: Service ‘earlylogs’ (pid 203) exited with status 0
[ 3.523204] init: insmod: open(“/system/lib/modules/pvrsrvkm.ko”) failed: No such file or directoryinit: finit_module for “/drmboot.ko” failed: Exec format errorfs_mgr: Warning: unknown flag resize
[ 3.523839] random: vold: uninitialized urandom read (40 bytes read, 63 bits of entropy available)
[ 3.524230] random: app_process64: uninitialized urandom read (40 bytes read, 63 bits of entropy available)
[ 3.524858] zram0: detected capacity change from 0 to 533413888
[ 3.526076] random: app_process32: uninitialized urandom read (40 bytes read, 63 bits of entropy available)
[ 3.528354] random: mkswap: uninitialized urandom read (40 bytes read, 63 bits of entropy available)
[ 3.548259] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
[ 3.549395] init: Starting service ‘debuggerd’…
[ 3.549959] init: Starting service ‘debuggerd64’…
[ 3.552940] init: Not bootcharting.
[ 3.608382] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 245
[ 3.609633] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 3.609661] mmc2: new ultra high speed SDR104 SDIO card at address 0001
[ 3.787424] fusb302 4-0022: port 0, state 19
[ 3.789266] fusb302 4-0022: port 0, state 20
[ 3.790630] fusb302 4-0022: port 0, state 21
[ 3.820112] fs_mgr: Warning: unknown flag resize
[ 3.874069] init: Failed to reload policy
[ 3.874223] init: Starting service ‘exec 1 (/system/bin/tzdatacheck)’…
[ 3.881500] init: Service ‘exec 1 (/system/bin/tzdatacheck)’ (pid 224) exited with status 0
[ 3.888477] init: write_file: Unable to open ‘/proc/sys/kernel/core_pattern’: No such file or directory
[ 3.888740] init: (Loading properties from /data/local.prop took 0.00s.)
[ 3.897384] init: Starting service ‘logd’…
[ 3.897739] init: Starting service ‘logd-reinit’…
[ 3.898617] init: write_file: Unable to open ‘/proc/sys/vm/min_free_order_shift’: No such file or directory
[ 3.900194] init: write_file: Unable to open ‘/proc/sys/vm/lazy_vfree_tlb_flush_all_threshold’: No such file or directory
[ 3.901489] init: Starting service ‘fsud’…
[ 3.921916] init: Starting service ‘vm_daemon’…
[ 3.922673] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 3.922696] init: write: cannot expand ‘${ro.serialno}’
[ 3.922935] file system registered
[ 3.927067] using random self ethernet address
[ 3.927119] using random host ethernet address
[ 3.927200] init: write_file: Unable to open ‘/config/usb_gadget/g1/functions/rndis.gs4/wceis’: Permission denied
[ 3.931751] init: Starting service ‘console’…
[ 3.932668] init: Starting service ‘adbd’…
[ 3.935424] init: Starting service ‘ap_log_srv’…
[ 3.936079] init: cannot find ‘/system/bin/update_verifier’ (No such file or directory), disabling ‘exec 2 (/system/bin/update_verifier)’
[ 3.936190] init: Starting service ‘ril-daemon’…
[ 3.936593] init: cannot find ‘/system/bin/install-recovery.sh’ (No such file or directory), disabling ‘flash_recovery’
[ 3.936648] init: Starting service ‘drmservice’…
[ 3.937269] init: cannot find ‘/system/bin/bplus_helper’ (No such file or directory), disabling ‘bplus_helper’
[ 3.937313] init: Starting service ‘up_eth0’…
[ 3.937788] init: cannot find ‘/system/bin/rk_store_keybox’ (No such file or directory), disabling ‘rk_store_keybox’
[ 3.937865] init: Starting service ‘akmd’…
[ 3.941809] init: Starting service ‘audioserver’…
[ 3.942680] init: Starting service ‘cameraserver’…
[ 3.943238] init: Starting service ‘drm’…
[ 3.943712] init: Starting service ‘installd’…
[ 3.944588] init: Starting service ‘keystore’…
[ 3.949615] init: Starting service ‘mediacodec’…
[ 3.950319] init: Starting service ‘mediadrm’…
[ 3.950668] init: couldn’t write 261 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[ 3.950917] init: Starting service ‘mediaextractor’…
[ 3.952422] rk_gmac-dwmac fe300000.ethernet: rk_get_eth_addr: mac address: 5a:db:d5:39:cc:de
[ 3.952456] eth0: device MAC address 5a:db:d5:39:cc:de
[ 3.952934] logd.auditd: start
[ 3.953022] logd.klogd: 3951653956
[ 3.961813] init: Starting service ‘media’…
[ 3.962527] init: Starting service ‘netd’…
[ 3.963866] init: Starting service ‘crashlogd’…
[ 3.964454] init: Starting service ‘log-watch’…
[ 3.968838] init: Starting service ‘gatekeeperd’…
[ 3.969358] init: Starting service ‘perfprofd’…
[ 3.980759] logd.daemon: reinit
[ 3.989829] init: Service ‘logd-reinit’ (pid 239) exited with status 0
[ 3.989910] init: Service ‘up_eth0’ (pid 257) exited with status 0
[ 3.989998] init: Service ‘akmd’ (pid 259) exited with status 254
[ 3.990374] ret = ffffffffffffffff
[ 3.993449] init: property ‘sys.serialno’ doesn’t exist while expanding ‘${sys.serialno}’
[ 3.993476] init: setprop: cannot expand ‘${sys.serialno}’
[ 3.996408] init: Service ‘drmservice’ (pid 256) exited with status 0
[ 4.090643] init: Starting service ‘apk_logfs’…
[ 4.092938] init: Service ‘ap_log_srv’ (pid 254) exited with status 0
[ 4.154822] read descriptors
[ 4.154851] read strings
[ 4.292043] fusb302 4-0022: port 0, state 0
[ 4.292056] fusb302 4-0022: PD disabled
[ 4.392336] init: Starting service ‘bootanim’…
[ 4.419211] android_work: sent uevent USB_STATE=CONNECTED
[ 4.439331] configfs-gadget gadget: high-speed config #1: b
[ 4.439467] android_work: sent uevent USB_STATE=CONFIGURED
[ 4.476336] Freeing drm_logo memory: 488K
[ 4.500486] init: Untracked pid 330 exited with status 0
[ 4.516113] healthd: BatteryCurrentNowPath not found
[ 4.516142] healthd: BatteryCycleCountPath not found
[ 4.557630] init: Untracked pid 340 exited with status 0
[ 4.808277] random: nonblocking pool is initialized
[ 4.924088] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff910000[0]’ - status (0)
[ 4.924108] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff910000[0]’ - status (0)
[ 4.935647] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 4.935835] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 4.945867] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff920000[0]’ - status (0)
[ 4.945888] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff920000[0]’ - status (0)
[ 4.945894] gpio-54 (camsys_gpio): gpiod_request: status -16
[ 4.946149] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 4.946171] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 4.946180] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 4.946190] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 4.946197] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 4.958622] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 4.958811] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 4.975328] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff910000[0]’ - status (0)
[ 4.975399] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff910000[0]’ - status (0)
[ 4.975413] gpio-54 (camsys_gpio): gpiod_request: status -16
[ 4.990794] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 4.990982] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 5.003734] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff920000[0]’ - status (0)
[ 5.003767] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff920000[0]’ - status (0)
[ 5.003774] gpio-54 (camsys_gpio): gpiod_request: status -16
[ 5.003849] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 5.003899] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 5.003909] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 5.003922] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 5.003929] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 5.016821] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 5.017007] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 5.046270] E:camsys_i2c_write(84): i2c write dev(addr:0x78) failed!,err = -6
[ 5.073658] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff910000[0]’ - status (0)
[ 5.073697] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff910000[0]’ - status (0)
[ 5.073704] gpio-54 (camsys_gpio): gpiod_request: status -16
[ 5.084694] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 5.084920] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 5.095332] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff920000[0]’ - status (0)
[ 5.095363] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff920000[0]’ - status (0)
[ 5.095370] gpio-54 (camsys_gpio): gpiod_request: status -16
[ 5.095425] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 5.095467] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 5.095478] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 5.095490] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 5.095535] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 5.106799] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 5.107132] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 5.117573] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff910000[0]’ - status (0)
[ 5.117607] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff910000[0]’ - status (0)
[ 5.117613] gpio-54 (camsys_gpio): gpiod_request: status -16
[ 5.130663] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 5.131037] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 5.143802] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff920000[0]’ - status (0)
[ 5.143835] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff920000[0]’ - status (0)
[ 5.143842] gpio-54 (camsys_gpio): gpiod_request: status -16
[ 5.143899] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 5.143942] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 5.143951] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 5.143961] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 5.144005] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 5.157016] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 5.157211] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 5.184071] E:camsys_i2c_write(84): i2c write dev(addr:0x78) failed!,err = -6
[ 5.212343] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff910000[0]’ - status (0)
[ 5.212382] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff910000[0]’ - status (0)
[ 5.212389] gpio-54 (camsys_gpio): gpiod_request: status -16
[ 5.225290] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 5.225511] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 5.237078] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff920000[0]’ - status (0)
[ 5.237111] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff920000[0]’ - status (0)
[ 5.237118] gpio-54 (camsys_gpio): gpiod_request: status -16
[ 5.237175] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 5.237217] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 5.237226] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 5.237236] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 5.237280] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 5.248267] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 5.248491] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 5.259128] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff910000[0]’ - status (0)
[ 5.259163] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff910000[0]’ - status (0)
[ 5.259170] gpio-54 (camsys_gpio): gpiod_request: status -16
[ 5.273160] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 5.273381] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 5.286247] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff920000[0]’ - status (0)
[ 5.286281] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff920000[0]’ - status (0)
[ 5.286288] gpio-54 (camsys_gpio): gpiod_request: status -16
[ 5.286343] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 5.286386] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 5.286396] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 5.286406] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 5.286449] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 5.299930] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 5.300306] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 5.331395] E:camsys_i2c_write(84): i2c write dev(addr:0x78) failed!,err = -6
[ 5.812378] capability: warning: `main’ uses 32-bit capabilities (legacy support in use)
[ 6.535394] init: property_set(“ro.build.fingerprint”, “rockchip/rk3399_firefly_edp_box/rk3399_firefly_edp_box:7.1.2/NHG47K/eng.nvt04573.20210420.093529:userdebug/test-keys”) failed
[ 8.263007] acc_open
[ 8.263045] acc_release
[ 9.140288] phy phy-ff770000.syscon:usb2-phy@e450.6: charger = USB_CDP_CHARGER
[ 9.244110] android_work: sent uevent USB_STATE=DISCONNECTED
[ 9.245110] configfs-gadget gadget: unbind function ‘mtp’/ffffffc079d3d600
[ 9.245145] configfs-gadget gadget: unbind function ‘Function FS Gadget’/ffffffc0760dda38
[ 9.245201] android_work: did not send uevent (0 0 (null))
[ 9.418752] dwhdmi-rockchip ff940000.hdmi: Rate 0 missing; compute N dynamically
[ 9.451388] android_work: did not send uevent (0 0 (null))
[ 9.500351] android_work: sent uevent USB_STATE=CONNECTED
[ 9.519580] configfs-gadget gadget: high-speed config #1: b
[ 9.519752] android_work: sent uevent USB_STATE=CONFIGURED
[ 9.662291] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff910000[0]’ - status (0)
[ 9.662310] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff910000[0]’ - status (0)
[ 9.662316] gpio-54 (camsys_gpio): gpiod_request: status -16
[ 9.673061] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 9.673235] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 9.686244] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff920000[0]’ - status (0)
[ 9.686277] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff920000[0]’ - status (0)
[ 9.686284] gpio-54 (camsys_gpio): gpiod_request: status -16
[ 9.686516] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 9.686600] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 9.686633] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 9.686658] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 9.686747] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 9.699057] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 9.699314] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 9.709728] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff910000[0]’ - status (0)
[ 9.709761] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff910000[0]’ - status (0)
[ 9.709768] gpio-54 (camsys_gpio): gpiod_request: status -16
[ 9.722843] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 9.723535] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 9.736830] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff920000[0]’ - status (0)
[ 9.736864] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff920000[0]’ - status (0)
[ 9.736872] gpio-54 (camsys_gpio): gpiod_request: status -16
[ 9.736937] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 9.736986] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 9.736996] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 9.737009] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 9.737059] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 9.749999] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 9.750202] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 9.779013] E:camsys_i2c_write(84): i2c write dev(addr:0x78) failed!,err = -6
[ 9.809351] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff910000[0]’ - status (0)
[ 9.809381] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff910000[0]’ - status (0)
[ 9.809388] gpio-54 (camsys_gpio): gpiod_request: status -16
[ 9.820977] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 9.821232] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 9.833286] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff920000[0]’ - status (0)
[ 9.833335] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff920000[0]’ - status (0)
[ 9.833343] gpio-54 (camsys_gpio): gpiod_request: status -16
[ 9.833469] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 9.833511] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 9.833527] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 9.833541] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 9.833609] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 9.848843] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 9.849431] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 9.859967] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff910000[0]’ - status (0)
[ 9.860001] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff910000[0]’ - status (0)
[ 9.860007] gpio-54 (camsys_gpio): gpiod_request: status -16
[ 9.873214] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 9.874511] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 9.888268] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff920000[0]’ - status (0)
[ 9.888298] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff920000[0]’ - status (0)
[ 9.888305] gpio-54 (camsys_gpio): gpiod_request: status -16
[ 9.888357] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 9.889296] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 9.889310] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 9.889320] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 9.889363] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 9.905392] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 9.906069] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 9.933938] E:camsys_i2c_write(84): i2c write dev(addr:0x78) failed!,err = -6
[ 9.973614] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff910000[0]’ - status (0)
[ 9.973646] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff910000[0]’ - status (0)
[ 9.973652] gpio-54 (camsys_gpio): gpiod_request: status -16
[ 9.984966] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 9.985728] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 9.997069] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff920000[0]’ - status (0)
[ 9.997112] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff920000[0]’ - status (0)
[ 9.997120] gpio-54 (camsys_gpio): gpiod_request: status -16
[ 9.997178] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 9.998163] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 9.998204] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 9.998216] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 9.998275] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 10.011883] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 10.012583] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 10.023655] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff910000[0]’ - status (0)
[ 10.023684] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff910000[0]’ - status (0)
[ 10.023691] gpio-54 (camsys_gpio): gpiod_request: status -16
[ 10.036894] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 10.037573] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 10.051946] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff920000[0]’ - status (0)
[ 10.052002] of_get_named_gpiod_flags: parsed ‘rockchip,gpios’ property of node ‘/isp@ff920000[0]’ - status (0)
[ 10.052010] gpio-54 (camsys_gpio): gpiod_request: status -16
[ 10.052110] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 10.053073] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 10.053660] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 10.054641] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 10.054761] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 10.069538] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 10.070276] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 10.098083] E:camsys_i2c_write(84): i2c write dev(addr:0x78) failed!,err = -6
[ 10.748706] init: cannot find ‘/system/bin/glgps’ (No such file or directory), disabling ‘gpsd’
[ 10.748938] init: Starting service ‘mode_switch’…
[ 10.750268] init: Starting service ‘exec 3 (/system/bin/bootstat)’…
[ 10.765913] init: Service ‘exec 3 (/system/bin/bootstat)’ (pid 1030) exited with status 0
[ 10.766940] init: Starting service ‘exec 4 (/system/bin/bootstat)’…
[ 10.782992] init: Service ‘exec 4 (/system/bin/bootstat)’ (pid 1039) exited with status 0
[ 10.783271] init: Starting service ‘exec 5 (/system/bin/bootstat)’…
[ 10.786853] init: Service ‘mode_switch’ (pid 1029) exited with status 1
[ 10.796255] init: Service ‘exec 5 (/system/bin/bootstat)’ (pid 1042) exited with status 0
[ 10.796475] init: Starting service ‘exec 6 (/system/bin/bootstat)’…
[ 10.814177] init: Service ‘exec 6 (/system/bin/bootstat)’ (pid 1043) exited with status 0
[ 12.608413] init: Service ‘bootanim’ is being killed…
[ 12.668524] init: Service ‘bootanim’ (pid 319) killed by signal 9
[ 13.211044] init: Untracked pid 1258 exited with status 0
[ 13.246108] init: Untracked pid 1266 exited with status 0
[ 13.735810] mtp_open
[ 14.011034] init: Untracked pid 1261 exited with status 0
[ 14.015226] init: Untracked pid 1269 exited with status 0
