rk3399 emmc启动一半卡死
请问各位,做的新板emmc启动到一半就卡死什么原因?:、
U-Boot 2017.09-ge9a3933-dirty (Apr 15 2021 - 16:25:25 +0800)
Model: Firefly-RK3399 Board
PreSerial: 2
DRAM: 2 GiB
Sysmem: init
Relocation Offset is: 7dbeb000
Bootdev(atags): mmc 0
MMC0: HS400, 150Mhz
PartType: EFI
get part misc fail -1
boot mode: None
Load FDT from boot part
DTB: rk-kernel.dtb
I2c speed: 400000Hz
PMIC: RK808
vdd_center 900000 uV
vdd_cpu_l 900000 uV
vdd_log 900000 uV
In: serial
Out: serial
Err: serial
Model: Firefly-RK3399 Board (Linux Opensource)
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 24000 KHz, init 24000 KHz, kernel 0N/A)
aplll 816000 KHz
apllb 24000 KHz
dpll 800000 KHz
cpll 24000 KHz
gpll 800000 KHz
npll 600000 KHz
vpll 24000 KHz
aclk_perihp 133333 KHz
hclk_perihp 66666 KHz
pclk_perihp 33333 KHz
aclk_perilp0 266666 KHz
hclk_perilp0 88888 KHz
pclk_perilp0 44444 KHz
hclk_perilp1 100000 KHz
pclk_perilp1 50000 KHz
Net: No ethernet found.
Could not find misc partition
Fdt Ramdisk skip relocation
Booting IMAGE kernel at 0x00280000 with fdt at 0x8300000…
## Booting Android Image at 0x0027f800 …
Kernel load addr 0x00280000 size 11609 KiB
## Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
XIP Kernel Image … OK
‘reserved-memory’ region@110000: addr=110000 size=f0000
Using Device Tree in place at 0000000008300000, end 000000000831c4fc
Can’t find file:logo_kernel.bmp
Total: 2558.59 ms
[ 0.000000] Linux version 4.4.179-ga179e62-dirty (root@ubuntu) ((HEAD: a179e620b38958254c1f74d283a9cf853ae20813) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #119 SMP
Thu May 6 11:30:26 CST 2021[ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07fee0000 s45440 r8192 d32384 u86016
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.slot_suffix= androidboot.serialno=8e8ce1ab30f7a197 rw roo
twait earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 console=ttyFIQ0 root=PARTUUID=614e0000-0000 rootfstype=ext4 coherent_pool=1m systemd.gpt_auto=0[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] software IO TLB: mapped [mem 0x7fe98000-0x7fed8000] (0MB)
[ 0.000000] Memory: 2012876K/2064384K available (7230K kernel code, 920K rwdata, 2668K rodata, 768K init, 1829K bss, 51508K reserved, 0K cma-reserved)
[ 0.000000] .init : 0xffffff8008a30000 - 0xffffff8008af0000 ( 768 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008790000 ( 7232 KB)
[ 0.000000] .rodata : 0xffffff8008790000 - 0xffffff8008a30000 ( 2688 KB)
[ 0.000000] .data : 0xffffff8008af0000 - 0xffffff8008bd6008 ( 921 KB)
[ 0.010315] Console: colour dummy device 80x25
[ 0.015213] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.026494] pid_max: default: 32768 minimum: 301
[ 0.031648] Security Framework initialized
[ 0.036208] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.043572] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.052113] Initializing cgroup subsys io
[ 0.056533] Initializing cgroup subsys memory
[ 0.061340] Initializing cgroup subsys devices
[ 0.066226] Initializing cgroup subsys freezer
[ 0.071110] Initializing cgroup subsys perf_event
[ 0.076280] Initializing cgroup subsys pids
[ 0.080897] ftrace: allocating 27026 entries in 106 pages
[ 0.155805] sched-energy: Sched-energy-costs installed from DT
[ 0.162225] CPU0: update cpu_capacity 401
[ 0.166702] ASID allocator initialised with 32768 entries
[ 0.174819] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.185001] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.196502] Detected VIPT I-cache on CPU1
[ 0.196534] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.196564] CPU1: using LPI pending table @0x000000007d060000
[ 0.196607] CPU1: update cpu_capacity 401
[ 0.196611] CPU1: Booted secondary processor [410fd034]
[ 0.197159] Detected VIPT I-cache on CPU2
[ 0.197181] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.197209] CPU2: using LPI pending table @0x000000007d080000
[ 0.197237] CPU2: update cpu_capacity 401
[ 0.197240] CPU2: Booted secondary processor [410fd034]
[ 0.197782] Detected VIPT I-cache on CPU3
[ 0.197803] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.197829] CPU3: using LPI pending table @0x000000007d0e0000
[ 0.197856] CPU3: update cpu_capacity 401
[ 0.197859] CPU3: Booted secondary processor [410fd034]
[ 0.198420] Detected PIPT I-cache on CPU4
[ 0.198448] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.198487] CPU4: using LPI pending table @0x000000007d110000
[ 0.198526] CPU4: update cpu_capacity 1024
[ 0.198529] CPU4: Booted secondary processor [410fd082]
[ 0.199088] Detected PIPT I-cache on CPU5
[ 0.199106] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.199142] CPU5: using LPI pending table @0x000000007d140000
[ 0.199167] CPU5: update cpu_capacity 1024
[ 0.199170] CPU5: Booted secondary processor [410fd082]
[ 0.199264] Brought up 6 CPUs
[ 0.341649] SMP: Total of 6 processors activated.
[ 0.346816] CPU features: detected feature: GIC system register CPU interface
[ 0.354654] CPU features: detected feature: 32-bit EL0 Support
[ 0.361062] CPU: All CPU(s) started at EL2
[ 0.365600] alternatives: patching kernel code
[ 0.371845] devtmpfs: initialized
[ 0.392883] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.403598] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.410966] xor: measuring software checksum speed
[ 0.425906] 8regs : 2856.000 MB/sec
[ 0.439983] 8regs_prefetch: 2556.000 MB/sec
[ 0.454061] 32regs : 3208.000 MB/sec
[ 0.468139] 32regs_prefetch: 2848.000 MB/sec
[ 0.473206] xor: using function: 32regs (3208.000 MB/sec)
[ 0.479143] pinctrl core: initialized pinctrl subsystem
[ 0.485600] NET: Registered protocol family 16
[ 0.495528] cpuidle: using governor ladder
[ 0.504052] cpuidle: using governor menu
[ 0.508379] Registered FIQ tty driver
[ 0.512571] vdso: 2 pages (1 code @ ffffff8008796000, 1 data @ ffffff8008af4000)
[ 0.520715] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.528692] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.559884] console [pstore-1] enabled
[ 0.564000] pstore: Registered ramoops as persistent store backend
[ 0.570786] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.579162] console [ttyFIQ0] enabled
[ 0.586845] bootconsole [uart0] disabled
[ 0.595253] Registered fiq debugger ttyFIQ0
[ 0.626088] raid6: int64x1 gen() 468 MB/s
[ 0.647223] raid6: int64x1 xor() 414 MB/s
[ 0.668336] raid6: int64x2 gen() 675 MB/s
[ 0.689436] raid6: int64x2 xor() 599 MB/s
[ 0.710564] raid6: int64x4 gen() 980 MB/s
[ 0.731648] raid6: int64x4 xor() 673 MB/s
[ 0.752771] raid6: int64x8 gen() 781 MB/s
[ 0.773865] raid6: int64x8 xor() 632 MB/s
[ 0.794991] raid6: neonx1 gen() 964 MB/s
[ 0.816107] raid6: neonx1 xor() 669 MB/s
[ 0.837252] raid6: neonx2 gen() 1277 MB/s
[ 0.858342] raid6: neonx2 xor() 980 MB/s
[ 0.879470] raid6: neonx4 gen() 1730 MB/s
[ 0.900565] raid6: neonx4 xor() 1214 MB/s
[ 0.921682] raid6: neonx8 gen() 1687 MB/s
[ 0.942789] raid6: neonx8 xor() 1261 MB/s
[ 0.947068] raid6: using algorithm neonx4 gen() 1730 MB/s
[ 0.952468] raid6: … xor() 1214 MB/s, rmw enabled
[ 0.957433] raid6: using intx1 recovery algorithm
[ 0.966937] iommu: Adding device ff650000.vpu_service to group 0
[ 0.973029] iommu: Adding device ff660000.rkvdec to group 1
[ 0.978719] iommu: Adding device ff8f0000.vop to group 2
[ 0.984124] iommu: Adding device ff900000.vop to group 3
[ 0.989530] iommu: Adding device ff910000.rkisp1 to group 4
[ 0.995211] iommu: Adding device ff920000.rkisp1 to group 5
[ 1.001292] rk_iommu ff650800.iommu: can’t get sclk
[ 1.006438] rk_iommu ff660480.iommu: can’t get sclk
[ 1.011535] rk_iommu ff8f3f00.iommu: can’t get sclk
[ 1.016598] rk_iommu ff903f00.iommu: can’t get sclk
[ 1.021668] rk_iommu ff914000.iommu: can’t get sclk
[ 1.026734] rk_iommu ff924000.iommu: can’t get sclk
[ 1.031915] SCSI subsystem initialized
[ 1.035781] usbcore: registered new interface driver usbfs
[ 1.041308] usbcore: registered new interface driver hub
[ 1.046721] usbcore: registered new device driver usb
[ 1.051833] media: Linux media interface: v0.10
[ 1.056398] Linux video capture interface: v2.00
[ 1.062695] rockchip-cpuinfo cpuinfo: Serial : 8e8ce1ab30f7a197
[ 1.069128] clocksource: Switched to clocksource arch_sys_counter
[ 1.112920] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 1.122063] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 1.130343] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 1.141659] Initialise system trusted keyring
[ 1.153063] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.159143] ntfs: driver 2.1.32 [Flags: R/O].
[ 1.163865] fuse init (API version 7.23)
[ 1.168147] SGI XFS with security attributes, no debug enabled
[ 1.179509] Key type asymmetric registered
[ 1.183636] Asymmetric key parser ‘x509’ registered
[ 1.188675] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 1.196225] io scheduler noop registered
[ 1.200183] io scheduler deadline registered
[ 1.204506] io scheduler cfq registered (default)
[ 1.210740] phy phy-ff770000.syscon:usb2-phy@e450.1: Failed to get VBUS supply regulator
[ 1.220180] phy phy-ff770000.syscon:usb2-phy@e460.3: Failed to get VBUS supply regulator
[ 1.234410] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 1.240872] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 1.247273] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 1.253633] rockchip-pcie f8000000.pcie: missing “memory-region” property
[ 1.260431] PCI host bridge /pcie@f8000000 ranges:
[ 1.265245] MEM 0xfa000000..0xfbdfffff → 0xfa000000
[ 1.270398] IO 0xfbe00000..0xfbefffff → 0xfbe00000
[ 2.283149] pll lock timeout!
[ 2.286159] phy phy-pcie-phy.7: phy poweron failed → -22
[ 2.291668] rockchip-pcie f8000000.pcie: fail to power on phy, err -22
[ 2.298210] rockchip-pcie f8000000.pcie: deferred probe failed
[ 2.304179] rockchip-pcie: probe of f8000000.pcie failed with error -22
[ 2.311747] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 2.318403] rk-vcodec ff650000.vpu_service: probe device
[ 2.324043] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[ 2.331707] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 2.338681] rk-vcodec ff650000.vpu_service: init success
[ 2.344266] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 2.350573] rk-vcodec ff660000.rkvdec: probe device
[ 2.355676] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[ 2.362512] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 2.369059] rk-vcodec ff660000.rkvdec: init success
[ 2.375424] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 2.383009] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 2.393656] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 2.401240] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 2.411638] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 2.420244] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 2.427227] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
[ 2.436605] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 37, base_baud = 1500000) is a 16550A
[ 2.445891] ff370000.serial: ttyS4 at MMIO 0xff370000 (irq = 43, base_baud = 1500000) is a 16550A
[ 2.455813] [drm] Initialized drm 1.1.0 20060810
[ 2.461739] [drm] Rockchip DRM driver version: v1.0.1
[ 2.467248] Unable to detect cache hierarchy for CPU 0
[ 2.473201] brd: module loaded
[ 2.481515] loop: module loaded
[ 2.485232] zram: Added device: zram0
[ 2.488924] lkdtm: No crash points registered, enable through debugfs
[ 2.496246] ---------spi-rockchip.c: pdev->id=0, dev_name=spi_flash(fpga1/2)
[ 2.503322] rockchip-spi ff1c0000.spi: no high_speed pinctrl state
[ 2.510231] rockchip-spi ff1d0000.spi: no high_speed pinctrl state
[ 2.517114] rockchip-spi ff1e0000.spi: no high_speed pinctrl state
[ 2.524170] ---------spi-rockchip.c: pdev->id=4, dev_name=fpga1 r/w
[ 2.530464] rockchip-spi ff1f0000.spi: no high_speed pinctrl state
[ 2.541167] dwc3_gadget_init_hw_endpoints,num = 6
[ 2.545889] dwc3_gadget_init_hw_endpoints,init 0 ep0out
[ 2.551125] dwc3_gadget_init_hw_endpoints,init 2 ep1out
[ 2.556365] dwc3_gadget_init_hw_endpoints,init 4 ep2out
[ 2.561606] dwc3_gadget_init_hw_endpoints,init 6 ep3out
[ 2.566846] dwc3_gadget_init_hw_endpoints,init 8 ep4out
[ 2.572087] dwc3_gadget_init_hw_endpoints,init 10 ep5out
[ 2.577411] dwc3_gadget_init_hw_endpoints,num = 7
[ 2.582127] dwc3_gadget_init_hw_endpoints,init 1 ep0in
[ 2.587275] dwc3_gadget_init_hw_endpoints,init 3 ep1in
[ 2.592430] dwc3_gadget_init_hw_endpoints,init 5 ep2in
[ 2.597585] dwc3_gadget_init_hw_endpoints,init 7 ep3in
[ 2.602740] dwc3_gadget_init_hw_endpoints,init 9 ep4in
[ 2.607902] dwc3_gadget_init_hw_endpoints,init 11 ep5in
[ 2.613172] dwc3_gadget_init_hw_endpoints,init 13 ep6in
[ 2.619179] rockchip-dwc3 usb0: fail to get drvdata hcd
[ 2.848543] phy phy-ff770000.syscon:usb2-phy@e450.1: charger = USB_SDP_CHARGER
[ 2.860260] rockchip-dwc3 usb1: fail to get drvdata hcd
[ 2.867498] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 2.874114] ehci-pci: EHCI PCI platform driver
[ 2.878655] ehci-platform: EHCI generic platform driver
[ 2.887793] ehci-platform fe380000.usb: EHCI Host Controller
[ 2.893720] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[ 2.901705] ehci-platform fe380000.usb: irq 26, io mem 0xfe380000
[ 2.913161] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 2.919578] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.926391] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.933629] usb usb1: Product: EHCI Host Controller
[ 2.938519] usb usb1: Manufacturer: Linux 4.4.179-ga179e62-dirty ehci_hcd
[ 2.945322] usb usb1: SerialNumber: fe380000.usb
[ 2.950599] hub 1-0:1.0: USB hub found
[ 2.954465] hub 1-0:1.0: 1 port detected
[ 2.962344] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 2.968215] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[ 2.976162] ehci-platform fe3c0000.usb: irq 28, io mem 0xfe3c0000
[ 2.988148] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 2.994480] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.001280] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.008508] usb usb2: Product: EHCI Host Controller
[ 3.013401] usb usb2: Manufacturer: Linux 4.4.179-ga179e62-dirty ehci_hcd
[ 3.020193] usb usb2: SerialNumber: fe3c0000.usb
[ 3.025293] hub 2-0:1.0: USB hub found
[ 3.029087] hub 2-0:1.0: 1 port detected
[ 3.033627] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 3.039843] ohci-platform: OHCI generic platform driver
[ 3.045403] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 3.052277] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[ 3.060217] ohci-platform fe3a0000.usb: irq 27, io mem 0xfe3a0000
[ 3.121286] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.128084] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.135322] usb usb3: Product: Generic Platform OHCI controller
[ 3.141247] usb usb3: Manufacturer: Linux 4.4.179-ga179e62-dirty ohci_hcd
[ 3.148038] usb usb3: SerialNumber: fe3a0000.usb
[ 3.153109] hub 3-0:1.0: USB hub found
[ 3.156907] hub 3-0:1.0: 1 port detected
[ 3.161416] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 3.168319] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[ 3.176232] ohci-platform fe3e0000.usb: irq 29, io mem 0xfe3e0000
[ 3.237268] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.244066] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.251292] usb usb4: Product: Generic Platform OHCI controller
[ 3.257215] usb usb4: Manufacturer: Linux 4.4.179-ga179e62-dirty ohci_hcd
[ 3.264030] usb usb4: SerialNumber: fe3e0000.usb
[ 3.269088] hub 4-0:1.0: USB hub found
[ 3.272887] hub 4-0:1.0: 1 port detected
[ 3.277819] usbcore: registered new interface driver cdc_acm
[ 3.283493] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 3.291542] usbcore: registered new interface driver cdc_wdm
[ 3.297252] usbcore: registered new interface driver uas
[ 3.302667] usbcore: registered new interface driver usb-storage
[ 3.308752] usbcore: registered new interface driver usbserial
[ 3.314621] usbcore: registered new interface driver usbserial_generic
[ 3.321188] usbserial: USB Serial support registered for generic
[ 3.327236] usbcore: registered new interface driver ch341
[ 3.332750] usbserial: USB Serial support registered for ch341-uart
[ 3.339060] usbcore: registered new interface driver cp210x
[ 3.344666] usbserial: USB Serial support registered for cp210x
[ 3.350650] usbcore: registered new interface driver ftdi_sio
[ 3.356426] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 3.363873] usbcore: registered new interface driver keyspan
[ 3.369569] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 3.377432] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 3.384767] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 3.392099] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 3.399449] usbcore: registered new interface driver option
[ 3.405059] usbserial: USB Serial support registered for GSM modem (1-port)
[ 3.412205] usbcore: registered new interface driver oti6858
[ 3.417900] usbserial: USB Serial support registered for oti6858
[ 3.423944] usbcore: registered new interface driver pl2303
[ 3.429571] usbserial: USB Serial support registered for pl2303
[ 3.435541] usbcore: registered new interface driver qcserial
[ 3.441318] usbserial: USB Serial support registered for Qualcomm USB modem
[ 3.448331] usbcore: registered new interface driver sierra
[ 3.453938] usbserial: USB Serial support registered for Sierra USB modem
[ 3.461008] .. rk pwm remotectl v1.1 init
[ 3.465274] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 3.473383] i2c /dev entries driver
[ 3.478321] rk808 0-001b: Pmic Chip id: 0x0
[ 3.485927] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 3.492187] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 3.498482] DCDC_REG1: supplied by vcc3v3_sys
[ 3.503656] DCDC_REG2: supplied by vcc3v3_sys
[ 3.508646] DCDC_REG3: supplied by vcc3v3_sys
[ 3.513364] DCDC_REG4: supplied by vcc3v3_sys
[ 3.518243] LDO_REG1: supplied by vcc3v3_sys
[ 3.523681] LDO_REG2: supplied by vcc3v3_sys
[ 3.528986] LDO_REG3: supplied by vcc3v3_sys
[ 3.534316] LDO_REG4: supplied by vcc3v3_sys
[ 3.539615] LDO_REG5: supplied by vcc3v3_sys
[ 3.544921] LDO_REG6: supplied by vcc3v3_sys
[ 3.550242] LDO_REG7: supplied by vcc3v3_sys
[ 3.555550] LDO_REG8: supplied by vcc3v3_sys
[ 3.560867] SWITCH_REG1: supplied by vcc3v3_sys
[ 3.565734] SWITCH_REG2: supplied by vcc3v3_sys
[ 3.573673] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 3.580829] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff8009048000
[ 3.588810] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff800904a000
[ 3.596872] rk3x-i2c ff120000.i2c: Initialized RK3xxx I2C bus at ffffff800904c000
[ 3.604786] rk3x-i2c ff140000.i2c: Initialized RK3xxx I2C bus at ffffff800904e000
[ 3.612858] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff8009050000
[ 3.621405] IR NEC protocol handler initialized
[ 3.626529] rkisp1 ff910000.rkisp1: rkisp1 driver version: v00.01.04
[ 3.632911] rkisp1 ff910000.rkisp1: Missing rockchip,grf property
[ 3.639378] ---------rkisp1_register_isp_subdev
[ 3.643922] ---------run rkisp1_isp_sd_init_default_fmt
[ 3.649155] ---------rkisp1_isp_sd_init_default_fmt -->out_fmt.fmt_type=2
[ 3.657162] rkisp1 ff920000.rkisp1: rkisp1 driver version: v00.01.04
[ 3.663538] rkisp1 ff920000.rkisp1: Missing rockchip,grf property
[ 3.669999] ---------rkisp1_register_isp_subdev
[ 3.674542] ---------run rkisp1_isp_sd_init_default_fmt
[ 3.679775] ---------rkisp1_isp_sd_init_default_fmt -->out_fmt.fmt_type=2
[ 3.687679] usbcore: registered new interface driver uvcvideo
[ 3.693440] USB Video Class driver (1.1.1)
[ 3.699442] Boot mode: coldboot
[ 3.703679] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 3.712618] rockchip-thermal ff260000.tsadc: tsadc is probed successfully!
[ 3.720559] cpu cpu0: bin=1
[ 3.723415] cpu cpu0: leakage=20
[ 3.738780] cpu cpu0: temp=40555, pvtm=141616 (141731 + -115)
[ 3.744760] cpu cpu0: pvtm-volt-sel=0
[ 3.748487] cpu cpu0: bin-scale=34
[ 3.752224] cpu cpu4: bin=1
[ 3.755077] cpu cpu4: leakage=31
[ 3.758361] cpu cpu4: Failed to get reg
[ 3.762217] cpu cpu4: bin-scale=17
[ 3.766667] cpu cpu0: avs=0
[ 3.769571] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 3.776557] cpu cpu0: failed to find power_model node
[ 3.782033] cpu cpu4: Failed to set regulator for cpu4: -517
[ 3.787944] cpu cpu5: Failed to set regulator for cpu5: -517
[ 3.794370] sdhci: Secure Digital Host Controller Interface driver
[ 3.800560] sdhci: Copyright(c) Pierre Ossman
[ 3.804932] Synopsys Designware Multimedia Card Interface Driver
[ 3.811912] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 3.819181] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 3.825983] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 3.831774] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 24,32 bit host data width,256 deep fifo
[ 3.841552] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 3.850136] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 3.857760] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 3.876474] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 3.896415] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 3.902641] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.910106] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 3.916124] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 3.949322] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 3.957995] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.963909] usbcore: registered new interface driver usbhid
[ 3.969512] usbhid: USB HID core driver
[ 3.973533] inv_mpu_iio: inv_mpu_init:746
[ 3.980551] mipi_csi_raw 2-0036: driver version: 00.01.01
[ 3.986383] mipi_csi_raw 2-0036: could not get default pinstate
[ 3.992319] mipi_csi_raw 2-0036: could not get sleep pinstate
[ 4.000071] mipi_csi_raw 2-0036: grgbanking mipi_csi_raw port
[ 4.006768] ---------rkisp1.c: fmt->code=0x3001
[ 4.011316] ---------dev.c: fmt.format.code =MEDIA_BUS_FMT_SBGGR8_1X8
[ 4.017756] ---------rkisp1.c: fmt->code=0x3001
[ 4.022291] ---------dev.c: w=512,h=34,isp_ver=0
[ 4.026913] ---------dev.c: RKISP1_STREAM_MP->V4L2_PIX_FMT_SBGGR8
[ 4.033022] ---------dev.c: RKISP1_STREAM_SP->V4L2_PIX_FMT_YUYV
[ 4.038946] rkisp1: Async subdev notifier completed
[ 4.043856] ---------mipi_csi_raw.c->runtime_suspend
[ 4.048911] mipi_csi_raw 2-0046: driver version: 00.01.01
[ 4.054435] mipi_csi_raw 2-0046: Failed to init controls(-34)
[ 4.062009] mipi_csi_raw 2-0046: grgbanking mipi_csi_raw port
[ 4.068908] ---------rkisp1.c: fmt->code=0x3001
[ 4.073460] ---------dev.c: fmt.format.code =MEDIA_BUS_FMT_SBGGR8_1X8
[ 4.079905] ---------rkisp1.c: fmt->code=0x3001
[ 4.084444] ---------dev.c: w=800,h=4800,isp_ver=0
[ 4.089247] ---------dev.c: RKISP1_STREAM_MP->V4L2_PIX_FMT_SBGGR8
[ 4.095351] ---------dev.c: RKISP1_STREAM_SP->V4L2_PIX_FMT_YUYV
[ 4.101277] rkisp1: Async subdev notifier completed
[ 4.106259] ---------mipi_csi_raw.c->runtime_suspend
[ 4.111607] Registered cp15_barrier emulation handler
[ 4.116800] Registered setend emulation handler
[ 4.122260] Loading compiled-in X.509 certificates
[ 4.123205] mmc1: new HS400 MMC card at address 0001
[ 4.124280] mmcblk1: mmc1:0001 Biwin 6.96 GiB
[ 4.125163] mmcblk1boot0: mmc1:0001 Biwin partition 1 4.00 MiB
[ 4.126015] mmcblk1boot1: mmc1:0001 Biwin partition 2 4.00 MiB
[ 4.126918] mmcblk1rpmb: mmc1:0001 Biwin partition 3 4.00 MiB
[ 4.130567] mmcblk1: p1 p2 p3 p4 p5
[ 4.160517] Btrfs loaded
[ 4.164221] rga2: Driver loaded successfully ver:3.02
[ 4.169589] rga2: Module initialized.
[ 4.179334] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[ 4.185546] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 5
[ 4.193398] xhci-hcd xhci-hcd.4.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 4.202152] xhci-hcd xhci-hcd.4.auto: irq 238, io mem 0xfe800000
[ 4.208363] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.215163] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.222390] usb usb5: Product: xHCI Host Controller
[ 4.227276] usb usb5: Manufacturer: Linux 4.4.179-ga179e62-dirty xhci-hcd
[ 4.234068] usb usb5: SerialNumber: xhci-hcd.4.auto
[ 4.239911] hub 5-0:1.0: USB hub found
[ 4.243740] hub 5-0:1.0: 1 port detected
[ 4.247987] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[ 4.253766] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 6
[ 4.261503] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 4.269695] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 4.276495] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.283722] usb usb6: Product: xHCI Host Controller
[ 4.288608] usb usb6: Manufacturer: Linux 4.4.179-ga179e62-dirty xhci-hcd
[ 4.295399] usb usb6: SerialNumber: xhci-hcd.4.auto
[ 4.300852] hub 6-0:1.0: USB hub found
[ 4.304664] hub 6-0:1.0: 1 port detected
[ 4.308959] dwc3_gadget_init_hw_endpoints,num = 6
[ 4.313689] dwc3_gadget_init_hw_endpoints,init 0 ep0out
[ 4.318930] dwc3_gadget_init_hw_endpoints,init 2 ep1out
[ 4.324177] dwc3_gadget_init_hw_endpoints,init 4 ep2out
[ 4.329423] dwc3_gadget_init_hw_endpoints,init 6 ep3out
[ 4.334663] dwc3_gadget_init_hw_endpoints,init 8 ep4out
[ 4.339904] dwc3_gadget_init_hw_endpoints,init 10 ep5out
[ 4.345248] dwc3_gadget_init_hw_endpoints,num = 7
[ 4.349974] dwc3_gadget_init_hw_endpoints,init 1 ep0in
[ 4.355136] dwc3_gadget_init_hw_endpoints,init 3 ep1in
[ 4.360292] dwc3_gadget_init_hw_endpoints,init 5 ep2in
[ 4.365447] dwc3_gadget_init_hw_endpoints,init 7 ep3in
[ 4.370603] dwc3_gadget_init_hw_endpoints,init 9 ep4in
[ 4.375758] dwc3_gadget_init_hw_endpoints,init 11 ep5in
[ 4.380998] dwc3_gadget_init_hw_endpoints,init 13 ep6in
[ 4.387151] xhci-hcd xhci-hcd.4.auto: remove, state 1
[ 4.391521] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[ 4.391711] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 7
[ 4.391860] xhci-hcd xhci-hcd.5.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 4.391903] xhci-hcd xhci-hcd.5.auto: irq 239, io mem 0xfe900000
[ 4.392107] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.392113] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.392138] usb usb7: Product: xHCI Host Controller
[ 4.392142] usb usb7: Manufacturer: Linux 4.4.179-ga179e62-dirty xhci-hcd
[ 4.392147] usb usb7: SerialNumber: xhci-hcd.5.auto
[ 4.392624] hub 7-0:1.0: USB hub found
[ 4.392649] hub 7-0:1.0: 1 port detected
[ 4.392938] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[ 4.393073] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 8
[ 4.393164] usb usb8: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 4.393251] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003
[ 4.393256] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.393260] usb usb8: Product: xHCI Host Controller
[ 4.393265] usb usb8: Manufacturer: Linux 4.4.179-ga179e62-dirty xhci-hcd
[ 4.393268] usb usb8: SerialNumber: xhci-hcd.5.auto
[ 4.393728] hub 8-0:1.0: USB hub found
[ 4.393757] hub 8-0:1.0: 1 port detected
[ 4.463803] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:09 UTC (1358499009)
[ 4.480788] vcc_sd: disabling
[ 4.480796] vcc_mipi: disabling
[ 4.480800] dvdd_1v2: disabling
u? 4.484142]
[ 4.539775] usb usb6: USB disconnect, device number 1
[ 4.568823] xhci-hcd xhci-hcd.4.auto: Host not halted after 16000 microseconds.
[ 4.576130] xhci-hcd xhci-hcd.4.auto: Host controller not halted, aborting reset.
[ 4.583629] xhci-hcd xhci-hcd.4.auto: USB bus 6 deregistered
也出现同样问题,楼主解决吗?
解决了吗
