启动信息如下:
DDR Version 1.24 20191016
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x6
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFC
CS = 1
MR0=0x18
MR4=0x1
MR5=0x6
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFC
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x6
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFC
CS = 1
MR0=0x18
MR4=0x1
MR5=0x6
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFC
channel 0 training pass!
channel 1 training failed!
change freq to 416MHz 0,1
Channel 0: LPDDR4,416MHz
Channel 1: LPDDR4,416MHz
W FF != R
Cap error!
no stride
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x6
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFC
CS = 1
MR0=0x18
MR4=0x1
MR5=0x6
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFC
channel 0, cs 0, advanced training done
channel 0, cs 1, advanced training done
change freq to 856MHz 1,0
pmugrf_os_reg[2] = 0x1000EAA1, stride = 0x17
ddr_set_rate to 328MHZ
ddr_set_rate to 666MHZ
ddr_set_rate to 416MHZ, ctl_index 0
ddr_set_rate to 856MHZ, ctl_index 1
support 416 856 328 666 MHz, current 856MHz
Boot1 Release Time: May 29 2020 17:36:36, version: 1.26
CPUId = 0x0
ChipType = 0x10, 347
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=29820MB
FwPartOffset=2000 , 100000
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=59376MB
FwPartOffset=0 , 0
StorageInit ok = 174698
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
atags_set_bootdev: ret:(0)
GPT part: 2, name: misc, start:0x8000, size:0x2000
GPT part: 3, name: boot, start:0xa000, size:0x10000
GPT part: 4, name: recovery, start:0x1a000, size:0x10000
GPT part: 5, name: backup, start:0x2a000, size:0x10000
GPT part: 6, name: rootfs, start:0x5a000, size:0x588400
GPT part: 7, name: userdata, start:0x5e2400, size:0x345bbdf
find part:uboot OK. first_lba:0x4000.
find part:trust OK. first_lba:0x6000.
Trust Addr:0x6000, 0x58334c42
No find bl30.bin
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0xe3098
RunBL31 0x40000 @ 216151 us
NOTICE: BL31: v1.3(release):845ee93
NOTICE: BL31: Built : 15:51:11, Jul 22 2020
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1196): pd status 3e
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-266-gee81607c #1 Mon Aug 17 09:23:30 UTC 2020 aarch64)
INFO: SPSR = 0x3c9
U-Boot 2017.09-gc56bc3a030 #root (Apr 08 2021 - 10:43:12 -0400)
Model: ROC-RK3399-PC Board
PreSerial: 2
DRAM: 2 GiB
Sysmem: init
Relocation Offset: 7dbec000, fdt: 7bdd5728
I2c0 speed: 400000Hz
PMIC: RK808
vdd_center 900000 uV
vdd_cpu_l 900000 uV
vdd_log init 1100000 uV
MMC: dwmmc@fe320000: 1, sdhci@fe330000: 0
In: serial
Out: serial
Err: serial
Bootdev(atags): mmc 0
MMC0: HS400, 150Mhz
PartType: EFI
boot mode: recovery (misc)
Found DTB in recovery part
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
aplll 816000 KHz
apllb 816000 KHz
dpll 856000 KHz
cpll 24000 KHz
gpll 800000 KHz
npll 600000 KHz
vpll 24000 KHz
aclk_perihp 133333 KHz
hclk_perihp 66666 KHz
pclk_perihp 33333 KHz
aclk_perilp0 266666 KHz
hclk_perilp0 88888 KHz
pclk_perilp0 44444 KHz
hclk_perilp1 100000 KHz
pclk_perilp1 50000 KHz
Net: eth0: ethernet@fe300000
DTB: rk-kernel.dtb
HASH(c): OK
Android header version 0
Booting IMAGE kernel at 0x00280000 with fdt at 0x08300000…
Fdt Ramdisk skip relocation
## Booting Android Image at 0x0027f800 …
Kernel load addr 0x00280000 size 22341 KiB
RAM disk load addr 0x0a200000 size 6740 KiB
## Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
XIP Kernel Image from 0x00280000 to 0x00280000 … OK
Using Device Tree in place at 0000000008300000, end 000000000831ce3e
No file: logo_kernel.bmp
Total: 2046.102 ms
[ 0.000000] Linux version 4.4.194-g50f0a60241aa (root@jxust-Lenovo-G500) (firefly: 50f0a60241aa6c9af65d5bdbdaae40df4cd77be3) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #1 SMP Sun Apr 4 08:58:02 EDT 2021
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07fedd000 s46312 r8192 d31512 u86016
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.slot_suffix= androidboot.serialno=be78f3397e9e435f ro rootwait earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1
[ 0.000000] software IO TLB: mapped [mem 0x7fe94000-0x7fed4000] (0MB)
[ 0.000000] Memory: 1995200K/2064384K available (13950K kernel code, 1796K rwdata, 5308K rodata, 1216K init, 2009K bss, 69184K reserved, 0K cma-reserved)
[ 0.000000] .init : 0xffffff8009360000 - 0xffffff8009490000 ( 1216 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008e20000 ( 13952 KB)
[ 0.000000] .rodata : 0xffffff8008e20000 - 0xffffff8009360000 ( 5376 KB)
[ 0.000000] .data : 0xffffff8009490000 - 0xffffff8009651008 ( 1797 KB)
[ 0.000000] ITS: allocated 65536 Devices @7d480000 (psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x000000007d410000
[ 0.000000] CPU0: using LPI pending table @0x000000007d420000
[ 0.002267] Console: colour dummy device 80x25
[ 0.002708] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.003696] pid_max: default: 32768 minimum: 301
[ 0.004218] Security Framework initialized
[ 0.004678] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.005317] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.006683] Initializing cgroup subsys io
[ 0.007091] Initializing cgroup subsys memory
[ 0.007531] Initializing cgroup subsys devices
[ 0.007962] Initializing cgroup subsys freezer
[ 0.008402] Initializing cgroup subsys perf_event
[ 0.008854] Initializing cgroup subsys net_prio
[ 0.009292] Initializing cgroup subsys pids
[ 0.009722] ftrace: allocating 50498 entries in 198 pages
[ 0.130216] sched-energy: Sched-energy-costs installed from DT
[ 0.130781] CPU0: update cpu_capacity 401
[ 0.131219] ASID allocator initialised with 32768 entries
[ 0.134957] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.136306] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.138634] Detected VIPT I-cache on CPU1
[ 0.138668] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.138698] CPU1: using LPI pending table @0x000000007d6c0000
[ 0.138751] CPU1: update cpu_capacity 401
[ 0.138755] CPU1: Booted secondary processor [410fd034]
[ 0.139566] Detected VIPT I-cache on CPU2
[ 0.139597] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.139626] CPU2: using LPI pending table @0x000000007d6f0000
[ 0.139675] CPU2: update cpu_capacity 401
[ 0.139679] CPU2: Booted secondary processor [410fd034]
[ 0.140476] Detected VIPT I-cache on CPU3
[ 0.140506] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.140535] CPU3: using LPI pending table @0x000000007d740000
[ 0.140582] CPU3: update cpu_capacity 401
[ 0.140586] CPU3: Booted secondary processor [410fd034]
[ 0.141369] Detected PIPT I-cache on CPU4
[ 0.141393] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.141429] CPU4: using LPI pending table @0x000000007d770000
[ 0.141464] CPU4: update cpu_capacity 1024
[ 0.141467] CPU4: Booted secondary processor [410fd082]
[ 0.142136] Detected PIPT I-cache on CPU5
[ 0.142161] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.142197] CPU5: using LPI pending table @0x000000007d7b0000
[ 0.142231] CPU5: update cpu_capacity 1024
[ 0.142235] CPU5: Booted secondary processor [410fd082]
[ 0.142341] Brought up 6 CPUs
[ 0.154671] SMP: Total of 6 processors activated.
[ 0.155121] CPU features: detected feature: GIC system register CPU interface
[ 0.155808] CPU features: detected feature: 32-bit EL0 Support
[ 0.156365] CPU: All CPU(s) started at EL2
[ 0.156794] alternatives: patching kernel code
[ 0.158585] devtmpfs: initialized
[ 0.178017] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.178973] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.180116] xor: measuring software checksum speed
[ 0.190552] 8regs : 2856.000 MB/sec
[ 0.200608] 8regs_prefetch: 2564.000 MB/sec
[ 0.210660] 32regs : 3204.000 MB/sec
[ 0.220716] 32regs_prefetch: 2848.000 MB/sec
[ 0.221164] xor: using function: 32regs (3204.000 MB/sec)
[ 0.221697] pinctrl core: initialized pinctrl subsystem
[ 0.223986] Failed to find legacy iommu devices
[ 0.224802] NET: Registered protocol family 16
[ 0.229463] cpuidle: using governor ladder
[ 0.233477] cpuidle: using governor menu
[ 0.233871] Registered FIQ tty driver
[ 0.234731] vdso: 2 pages (1 code @ ffffff8008e26000, 1 data @ ffffff8009494000)
[ 0.235472] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.236549] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.260964] console [pstore-1] enabled
[ 0.261327] pstore: Registered ramoops as persistent store backend
[ 0.261925] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.265340] console [ttyFIQ0] enabled
[ 0.266029] bootconsole [uart0] disabled
[ 0.266964] Registered fiq debugger ttyFIQ0
[ 0.316342] raid6: int64x1 gen() 468 MB/s
[ 0.333378] raid6: int64x1 xor() 410 MB/s
[ 0.350514] raid6: int64x2 gen() 675 MB/s
[ 0.367559] raid6: int64x2 xor() 595 MB/s
[ 0.384652] raid6: int64x4 gen() 964 MB/s
[ 0.401740] raid6: int64x4 xor() 664 MB/s
[ 0.418858] raid6: int64x8 gen() 781 MB/s
[ 0.435948] raid6: int64x8 xor() 628 MB/s
[ 0.453050] raid6: neonx1 gen() 964 MB/s
[ 0.470113] raid6: neonx1 xor() 669 MB/s
[ 0.487208] raid6: neonx2 gen() 1273 MB/s
[ 0.504315] raid6: neonx2 xor() 996 MB/s
[ 0.521406] raid6: neonx4 gen() 1730 MB/s
[ 0.538499] raid6: neonx4 xor() 1177 MB/s
[ 0.555607] raid6: neonx8 gen() 1695 MB/s
[ 0.572681] raid6: neonx8 xor() 1255 MB/s
[ 0.573071] raid6: using algorithm neonx4 gen() 1730 MB/s
[ 0.573547] raid6: … xor() 1177 MB/s, rmw enabled
[ 0.573988] raid6: using intx1 recovery algorithm
[ 0.579868] iommu: Adding device ff650000.vpu_service to group 0
[ 0.580490] iommu: Adding device ff660000.rkvdec to group 1
[ 0.581095] iommu: Adding device ff8f0000.vop to group 2
[ 0.581665] iommu: Adding device ff900000.vop to group 3
[ 0.582234] iommu: Adding device ff910000.rkisp1 to group 4
[ 0.582830] iommu: Adding device ff920000.rkisp1 to group 5
[ 0.583814] rk_iommu ff650800.iommu: can’t get sclk
[ 0.584488] rk_iommu ff660480.iommu: can’t get sclk
[ 0.585130] rk_iommu ff8f3f00.iommu: can’t get sclk
[ 0.585730] rk_iommu ff903f00.iommu: can’t get sclk
[ 0.586330] rk_iommu ff914000.iommu: can’t get sclk
[ 0.586915] rk_iommu ff924000.iommu: can’t get sclk
[ 0.587707] SCSI subsystem initialized
[ 0.588406] usbcore: registered new interface driver usbfs
[ 0.588931] usbcore: registered new interface driver hub
[ 0.589496] usbcore: registered new device driver usb
[ 0.590016] media: Linux media interface: v0.10
[ 0.590465] Linux video capture interface: v2.00
[ 0.590949] pps_core: LinuxPPS API ver. 1 registered
[ 0.591391] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.592221] PTP clock support registered
[ 0.593725] Advanced Linux Sound Architecture Driver Initialized.
[ 0.594747] Bluetooth: Core ver 2.21
[ 0.595094] NET: Registered protocol family 31
[ 0.595501] Bluetooth: HCI device and connection manager initialized
[ 0.596074] Bluetooth: HCI socket layer initialized
[ 0.596514] Bluetooth: L2CAP socket layer initialized
[ 0.596984] Bluetooth: SCO socket layer initialized
[ 0.597918] nfc: nfc_init: NFC Core ver 0.1
[ 0.598325] NET: Registered protocol family 39
[ 0.598842] rockchip-cpuinfo cpuinfo: Serial : be78f3397e9e435f
[ 0.600197] clocksource: Switched to clocksource arch_sys_counter
[ 0.655907] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.656833] NET: Registered protocol family 2
[ 0.657666] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.658451] TCP bind hash table entries: 16384 (order: 7, 524288 bytes)
[ 0.659573] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.660253] UDP hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.660882] UDP-Lite hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.661752] NET: Registered protocol family 1
[ 0.662446] RPC: Registered named UNIX socket transport module.
[ 0.662969] RPC: Registered udp transport module.
[ 0.663403] RPC: Registered tcp transport module.
[ 0.663822] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.665113] Trying to unpack rootfs image as initramfs…
[ 1.039607] Freeing initrd memory: 6736K
[ 1.040712] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 1.041526] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 1.045444] Initialise system trusted keyring
[ 1.053812] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.055117] NFS: Registering the id_resolver key type
[ 1.055604] Key type id_resolver registered
[ 1.055978] Key type id_legacy registered
[ 1.056359] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 1.057653] ntfs: driver 2.1.32 [Flags: R/O].
[ 1.058416] fuse init (API version 7.23)
[ 1.059087] SGI XFS with security attributes, no debug enabled
[ 1.064976] NET: Registered protocol family 38
[ 1.065412] Key type asymmetric registered
[ 1.065782] Asymmetric key parser ‘x509’ registered
[ 1.066403] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.067220] io scheduler noop registered
[ 1.067579] io scheduler deadline registered
[ 1.067997] io scheduler cfq registered (default)
[ 1.070011] phy phy-ff770000.syscon:usb2-phy@e460.1: Failed to get VBUS supply regulator
[ 1.075460] ace test_init function.
[ 1.075953] ace test_init end.ret=0
[ 1.076666] radar end.ret=0
[ 1.079456] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 1.080053] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 1.080660] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 1.081240] rockchip-pcie f8000000.pcie: missing “memory-region” property
[ 1.081848] PCI host bridge /pcie@f8000000 ranges:
[ 1.082300] MEM 0xfa000000..0xfbdfffff → 0xfa000000
[ 1.082758] IO 0xfbe00000..0xfbefffff → 0xfbe00000
[ 1.625259] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 1.625873] rockchip-pcie f8000000.pcie: deferred probe failed
[ 1.626607] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 1.628075] backlight supply power not found, using dummy regulator
[ 1.629266] Module initialized.
[ 1.629983] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 1.630844] rk-vcodec ff650000.vpu_service: probe device
[ 1.631565] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[ 1.632729] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 1.633362] rk-vcodec ff650000.vpu_service: init success
[ 1.634078] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 1.635035] rk-vcodec ff660000.rkvdec: probe device
[ 1.635665] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[ 1.636608] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 1.637205] rk-vcodec ff660000.rkvdec: init success
[ 1.639083] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.639772] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 1.642012] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.642700] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.644571] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 1.646458] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 1.647655] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 38, base_baud = 1500000) is a 16550A
[ 1.650271] [drm] Initialized drm 1.1.0 20060810
[ 1.654766] [drm] Rockchip DRM driver version: v1.0.1
[ 1.657501] mali ff9a0000.gpu: Failed to get regulator
[ 1.657957] mali ff9a0000.gpu: Power control initialization failed
[ 1.658875] Unable to detect cache hierarchy for CPU 0
[ 1.660145] brd: module loaded
[ 1.665844] loop: module loaded
[ 1.666693] zram: Added device: zram0
[ 1.667330] lkdtm: No crash points registered, enable through debugfs
[ 1.668287] Loading dl1825 driver
[ 1.670174] rockchip-spi ff1d0000.spi: no high_speed pinctrl state
[ 1.671339] m25p80 spi32766.0: w25q128 (16384 Kbytes)
[ 1.675491] register spi return v = :0
[ 1.676328] tun: Universal TUN/TAP device driver, 1.6
[ 1.676782] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.678393] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.679022] rk_gmac-dwmac fe300000.ethernet: TX delay(0x2e).
[ 1.679537] rk_gmac-dwmac fe300000.ethernet: RX delay(0x13).
[ 1.680052] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 1.680777] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 1.681399] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.686951] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.687574] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.688027] Ring mode enabled
[ 1.688317] DMA HW capability register supported
[ 1.688722] Normal descriptors
[ 1.689028] RX Checksum Offload Engine supported (type 2)
[ 1.689521] TX Checksum insertion supported
[ 1.689904] Wake-Up On Lan supported
[ 1.690269] Enable RX Mitigation via HW Watchdog Timer
[ 1.758216] libphy: stmmac: probed
[ 1.758533] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.759103] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.761065] usbcore: registered new interface driver rtl8192cu
[ 1.761680] usbcore: registered new interface driver rndis_wlan
[ 1.762545] usbcore: registered new interface driver mt7601u
[ 1.763124] Rockchip WiFi SYS interface (V1.00) …
[ 1.763690] usbcore: registered new interface driver rtl8150
[ 1.764255] usbcore: registered new interface driver r8152
[ 1.764787] usbcore: registered new interface driver asix
[ 1.765311] usbcore: registered new interface driver ax88179_178a
[ 1.765889] usbcore: registered new interface driver cdc_ether
[ 1.766464] usbcore: registered new interface driver rndis_host
[ 1.767050] usbcore: registered new interface driver cdc_ncm
[ 1.767598] usbcore: registered new interface driver qmi_wwan
[ 1.768140] usbcore: registered new interface driver cdc_mbim
[ 1.770115] rockchip-dwc3 usb0: failed to get drvdata dwc3
[ 1.873769] rockchip-typec-phy ff800000.phy: wait pma ready timeout
[ 1.974383] rockchip-typec-phy ff800000.phy: wait pma ready timeout
[ 2.074992] rockchip-typec-phy ff800000.phy: wait pma ready timeout
[ 2.175603] rockchip-typec-phy ff800000.phy: wait pma ready timeout
[ 2.276225] rockchip-typec-phy ff800000.phy: wait pma ready timeout
[ 2.276786] phy phy-ff800000.phy.4: phy poweron failed → -110
[ 2.277389] dwc3 fe900000.dwc3: failed to initialize core
[ 2.277923] dwc3: probe of fe900000.dwc3 failed with error -110
[ 2.278538] rockchip-dwc3 usb1: failed to get drvdata dwc3
[ 2.280142] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 2.280749] ehci-pci: EHCI PCI platform driver
[ 2.281207] ehci-platform: EHCI generic platform driver
[ 2.285542] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 2.286264] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 2.287059] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 2.293215] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 2.293910] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.294528] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.295167] usb usb1: Product: EHCI Host Controller
[ 2.295608] usb usb1: Manufacturer: Linux 4.4.194-g50f0a60241aa ehci_hcd
[ 2.296208] usb usb1: SerialNumber: fe3c0000.usb
[ 2.297083] hub 1-0:1.0: USB hub found
[ 2.297477] hub 1-0:1.0: 1 port detected
[ 2.298419] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 2.298978] ohci-platform: OHCI generic platform driver
[ 2.299955] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 2.300768] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 2.301568] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 2.356369] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.356976] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.357628] usb usb2: Product: Generic Platform OHCI controller
[ 2.358152] usb usb2: Manufacturer: Linux 4.4.194-g50f0a60241aa ohci_hcd
[ 2.358752] usb usb2: SerialNumber: fe3e0000.usb
[ 2.359591] hub 2-0:1.0: USB hub found
[ 2.359955] hub 2-0:1.0: 1 port detected
[ 2.361327] usbcore: registered new interface driver cdc_acm
[ 2.361828] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.362583] usbcore: registered new interface driver cdc_wdm
[ 2.363122] usbcore: registered new interface driver uas
[ 2.363685] usbcore: registered new interface driver usb-storage
[ 2.364305] usbcore: registered new interface driver usbserial
[ 2.364854] usbcore: registered new interface driver usbserial_generic
[ 2.365467] usbserial: USB Serial support registered for generic
[ 2.366035] usbcore: registered new interface driver ch341
[ 2.366553] usbserial: USB Serial support registered for ch341-uart
[ 2.367147] usbcore: registered new interface driver cp210x
[ 2.367681] usbserial: USB Serial support registered for cp210x
[ 2.368263] usbcore: registered new interface driver ftdi_sio
[ 2.368793] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.369534] usbcore: registered new interface driver keyspan
[ 2.370053] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 2.370778] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 2.371455] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 2.372125] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 2.372818] usbcore: registered new interface driver option
[ 2.373349] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.374069] usbcore: registered new interface driver oti6858
[ 2.374599] usbserial: USB Serial support registered for oti6858
[ 2.375167] usbcore: registered new interface driver pl2303
[ 2.375696] usbserial: USB Serial support registered for pl2303
[ 2.376270] usbcore: registered new interface driver qcserial
[ 2.376801] usbserial: USB Serial support registered for Qualcomm USB modem
[ 2.377470] usbcore: registered new interface driver sierra
[ 2.377988] usbserial: USB Serial support registered for Sierra USB modem
[ 2.379784] usbcore: registered new interface driver usbtouchscreen
[ 2.380660] .. rk pwm remotectl v1.1 init
[ 2.381277] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 2.382333] sensor_register_slave:mma8452,id=17
[ 2.382747] sensor_register_slave:lis3dh,id=7
[ 2.383137] sensor_register_slave:mma7660,id=18
[ 2.383561] sensor_register_slave:lsm303d,id=22
[ 2.383973] sensor_register_slave:gs_mc3230,id=23
[ 2.384400] [Gsensor] gsensor_init
[ 2.384733] sensor_register_slave:mpu6880_acc,id=24
[ 2.385169] sensor_register_slave:mpu6500_acc,id=25
[ 2.385613] sensor_register_slave:lsm330_acc,id=26
[ 2.386048] sensor_register_slave:akm8975,id=30
[ 2.386467] sensor_register_slave:akm8963,id=31
[ 2.386879] sensor_register_slave:l3g4200d,id=45
[ 2.387301] sensor_register_slave:l3g20d,id=46
[ 2.387702] sensor_register_slave:ewtsa,id=47
[ 2.388102] sensor_register_slave:lsm330_gyro,id=51
[ 2.388546] sensor_register_slave:cm3217,id=53
[ 2.388946] sensor_register_slave:cm3218,id=54
[ 2.389826] i2c /dev entries driver
[ 2.391386] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 2.392073] fan53555-reg: supplied by vcc5v0_sys
[ 2.394882] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 2.395557] fan53555-reg: supplied by vcc5v0_sys
[ 2.398386] rk808 0-001b: Pmic Chip id: 0x0
[ 2.401819] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 2.402438] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 2.403075] DCDC_REG1: supplied by vcc3v3_sys
[ 2.404251] DCDC_REG2: supplied by vcc3v3_sys
[ 2.405256] DCDC_REG3: supplied by vcc3v3_sys
[ 2.405973] DCDC_REG4: supplied by vcc3v3_sys
[ 2.406883] LDO_REG1: supplied by vcc3v3_sys
[ 2.408454] LDO_REG2: supplied by vcc3v3_sys
[ 2.409839] LDO_REG3: supplied by vcc3v3_sys
[ 2.411273] LDO_REG4: supplied by vcc3v3_sys
[ 2.412679] LDO_REG5: supplied by vcc3v3_sys
[ 2.414092] LDO_REG6: supplied by vcc3v3_sys
[ 2.415538] LDO_REG7: supplied by vcc3v3_sys
[ 2.416950] LDO_REG8: supplied by vcc3v3_sys
[ 2.418376] SWITCH_REG1: supplied by vcc3v3_sys
[ 2.419131] SWITCH_REG2: supplied by vcc3v3_sys
[ 2.420005] rk808-rtc rk808-rtc: device is disabled
[ 2.420457] rk808-rtc: probe of rk808-rtc failed with error -22
[ 2.421007] rk808 0-001b: Can not read property pmic,hold-gpio
[ 2.421550] rk808 0-001b: Can not read property pmic,stby-gpio
[ 2.424656] rtc-hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 2.425598] rtc-hym8563 0-0051: probe successed !
[ 2.426044] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff8009ace000
[ 2.427559] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff8009ad0000
[ 2.428753] rk3x-i2c ff120000.i2c: Initialized RK3xxx I2C bus at ffffff8009ad2000
[ 2.433745] fusb302 7-0022: port 0 probe success with role ROLE_MODE_DFP, try_role ROLE_MODE_NONE
[ 2.434701] input: Typec_Headphone as /devices/platform/ff160000.i2c/i2c-7/7-0022/input/input1
[ 2.435947] mp8859 7-0066: failed to set slew_rate
[ 2.436396] mp8859 7-0066: register ext0 dev0
[ 2.436952] mp8859 7-0066: mp8859 probe successful
[ 2.437419] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at ffffff8009ad4000
[ 2.438659] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff8009ad6000
[ 2.440527] IR NEC protocol handler initialized
[ 2.441762] rkisp1 ff910000.rkisp1: rkisp1 driver version: v00.01.05
[ 2.442365] rkisp1 ff910000.rkisp1: Missing rockchip,grf property
[ 2.444407] rkisp1 ff920000.rkisp1: rkisp1 driver version: v00.01.05
[ 2.444995] rkisp1 ff920000.rkisp1: Missing rockchip,grf property
[ 2.446947] usbcore: registered new interface driver npu_acm
[ 2.447533] usbcore: registered new interface driver uvcvideo
[ 2.448043] USB Video Class driver (1.1.1)
[ 2.448482] cw201x 2-0062: design_capacity missing!
[ 2.449085] cw_bat_probe cw_init error
[ 2.451410] Boot mode: normal
[ 2.453249] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 2.454204] rockchip-thermal ff260000.tsadc: tsadc is probed successfully!
[ 2.455425] dw_wdt ff848000.watchdog: Should better to setup a ‘resets’ property in dt, that must been named with reset
[ 2.456978] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.457934] rtk_btusb: Realtek Bluetooth USB driver ver 3.1.a2fd257.20190430-133301
[ 2.458623] rtk_btcoex: rtk_btcoex_init: version: 1.2
[ 2.459075] rtk_btcoex: create workqueue
[ 2.459432] rtk_btcoex: Coex over UDP
[ 2.460018] rtk_btcoex: alloc buffers 1792, 2432 for ev and l2
[ 2.460631] usbcore: registered new interface driver rtk_btusb
[ 2.461159] Bluetooth: Virtual HCI driver ver 1.5
[ 2.461709] Bluetooth: HCI UART driver ver 2.3
[ 2.462108] Bluetooth: HCI UART protocol H4 registered
[ 2.462576] Bluetooth: HCI UART protocol LL registered
[ 2.463030] Bluetooth: HCI UART protocol ATH3K registered
[ 2.463564] usbcore: registered new interface driver bfusb
[ 2.464104] usbcore: registered new interface driver btusb
[ 2.465098] cpu cpu0: bin=1
[ 2.465422] cpu cpu0: leakage=18
[ 2.477790] cpu cpu0: temp=24444, pvtm=143786 (145741 + -1955)
[ 2.478516] cpu cpu0: pvtm-volt-sel=1
[ 2.478895] cpu cpu0: bin-scale=34
[ 2.479510] cpu cpu4: bin=1
[ 2.479818] cpu cpu4: leakage=32
[ 2.503835] cpu cpu4: temp=32, pvtm=181549 (184460 + -2911)
[ 2.504438] cpu cpu4: pvtm-volt-sel=4
[ 2.504809] cpu cpu4: bin-scale=17
[ 2.506260] cpu cpu0: avs=0
[ 2.506623] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 2.507214] cpu cpu0: failed to read out thermal zone (-11)
[ 2.508131] cpu cpu0: failed to find power_model node
[ 2.509524] cpu cpu4: avs=0
[ 2.509882] cpu cpu4: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 2.510473] cpu cpu4: failed to read out thermal zone (-11)
[ 2.512301] cpu cpu4: failed to find power_model node
[ 2.513604] sdhci: Secure Digital Host Controller Interface driver
[ 2.514149] sdhci: Copyright(c) Pierre Ossman
[ 2.514550] Synopsys Designware Multimedia Card Interface Driver
[ 2.515964] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.516648] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 2.517274] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 2.517822] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.518790] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 2.519347] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 2.520824] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.521502] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 2.522116] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 2.522674] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 2.523550] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.524720] vccio_sd: unsupportable voltage range: 3300000-3000000uV
[ 2.525315] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 2.525977] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 2.539226] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
卡在这里不动,求各位大神帮忙看看。
