ROC-RK3399-PC-PLUS industry版本编译出错
ROC-RK3399-PC-PLUS industry版本,按照官方全编命令:./FFTools/make.sh -d rk3399-roc-pc-plus -j8 -l rk3399_roc_pc_plus-userdebug,编译时出错,出错时的log信息如下:
[ 41% 20739/50425] target C: libhardware_legacy <= hardware/libhardware_legacy/wifi/wifi.c
hardware/libhardware_legacy/wifi/wifi.c:382:56: warning: comparison of integers of different signs: ‘typeof (write(fd, buf, strlen(buf) + 1))’ (aka ‘long’) and ‘unsigned long’ [-Wsign-compare]
if (TEMP_FAILURE_RETRY(write(fd, buf, strlen(buf)+1)) != strlen(buf)+1) {
1 warning generated.
[ 42% 21564/50425] target C++: libskia_static <= external/skia/src/codec/SkWebpCodec.cpp
external/skia/src/codec/SkWebpCodec.cpp:239:36: warning: ‘&&’ within ‘||’ [-Wlogical-op-parentheses]
|| rowsDecoded && *rowsDecoded <= 0) {
external/skia/src/codec/SkWebpCodec.cpp:239:36: note: place parentheses around the ‘&&’ expression to silence this warning
[ 42% 21572/50425] Ensure Jack server is installed and started
FAILED: /bin/bash -c “(prebuilts/sdk/tools/jack-admin install-server prebuilts/sdk/tools/jack-launcher.jar prebuilts/sdk/tools/jack-server-4.8.ALPHA.jar 2>&1 || (exit 0) ) && (JACK_SERVER_VM_ARGUMENTS="-Dfile.encoding=UTF-8 -XX:+TieredCompilation" prebuilts/sdk/tools/jack-admin start-server 2>&1 || exit 0 ) && (prebuilts/sdk/tools/jack-admin update server prebuilts/sdk/tools/jack-server-4.8.ALPHA.jar 4.8.ALPHA 2>&1 || exit 0 ) && (prebuilts/sdk/tools/jack-admin update jack prebuilts/sdk/tools/jacks/jack-2.28.RELEASE.jar 2.28.RELEASE || exit 47; prebuilts/sdk/tools/jack-admin update jack prebuilts/sdk/tools/jacks/jack-3.36.CANDIDATE.jar 3.36.CANDIDATE || exit 47; prebuilts/sdk/tools/jack-admin update jack prebuilts/sdk/tools/jacks/jack-4.7.BETA.jar 4.7.BETA || exit 47 )”
Writing client settings in /home/kevin/.jack-settings
Installing jack server in “/home/kevin/.jack-server”
Warning:
The JKS keystore uses a proprietary format. It is recommended to migrate to PKCS12 which is an industry standard format using “keytool -importkeystore -srckeystore /home/kevin/.jack-server/server.jks -destkeystore /home/kevin/.jack-server/server.jks -deststoretype pkcs12”.
Warning:
The JKS keystore uses a proprietary format. It is recommended to migrate to PKCS12 which is an industry standard format using “keytool -importkeystore -srckeystore /home/kevin/.jack-server/client.jks -destkeystore /home/kevin/.jack-server/client.jks -deststoretype pkcs12”.
Launching Jack server java -XX:MaxJavaStackTraceDepth=-1 -Djava.io.tmpdir=/tmp -Dfile.encoding=UTF-8 -XX:+TieredCompilation -cp /home/kevin/.jack-server/launcher.jar com.android.jack.launcher.ServerLauncher
Jack server failed to (re)start, try ‘jack-diagnose’ or see Jack server log
SSL error when connecting to the Jack server. Try ‘jack-diagnose’
[ 42% 21572/50425] target C++: libskia_static <= external/skia/src/core/SkBitmap.cpp
ninja: build stopped: subcommand failed.
build/core/ninja.mk:148: recipe for target ‘ninja_wrapper’ failed
make: *** [ninja_wrapper] Error 1
kevin@kevin-virtual-machine:~/proj/firefly-rk3399-Industry$
请参考如下
https://www.cnblogs.com/blogs-of-lxl/p/11589521.html
jpchen 发表于 2021-5-10 08:45
请参考如下
根据这个帖子,还是没有解决
