进入板子并输入getprop 命令,返回如下系统配置信息:
rk3399_firefly_aio:/ $ getprop
getprop
[UserVolumeLabel]: [RockChips]
[camera2.portability.force_api]: [1]
[crashlogd.processing.ongoing]: [0]
[crashlogd.token]: [1]
[dalvik.vm.appimageformat]: [lz4]
[dalvik.vm.boot-dex2oat-threads]: [2]
[dalvik.vm.dex2oat-Xms]: [64m]
[dalvik.vm.dex2oat-Xmx]: [512m]
[dalvik.vm.dex2oat-threads]: [2]
[dalvik.vm.heapgrowthlimit]: [192m]
[dalvik.vm.heapmaxfree]: [8m]
[dalvik.vm.heapminfree]: [512k]
[dalvik.vm.heapsize]: [512m]
[dalvik.vm.heapstartsize]: [16m]
[dalvik.vm.heaptargetutilization]: [0.75]
[dalvik.vm.image-dex2oat-Xms]: [64m]
[dalvik.vm.image-dex2oat-Xmx]: [64m]
[dalvik.vm.image-dex2oat-threads]: [2]
[dalvik.vm.isa.arm.features]: [default]
[dalvik.vm.isa.arm.variant]: [cortex-a53.a57]
[dalvik.vm.isa.arm64.features]: [default]
[dalvik.vm.isa.arm64.variant]: [cortex-a53]
[dalvik.vm.lockprof.threshold]: [500]
[dalvik.vm.stack-trace-file]: [/data/anr/traces.txt]
[dalvik.vm.usejit]: [true]
[dalvik.vm.usejitprofiles]: [true]
[debug.atrace.tags.enableflags]: [0]
[debug.force_rtl]: [0]
[debug.nfc.fw_download]: [false]
[debug.nfc.se]: [false]
[dev.bootcomplete]: [1]
[devicetest.bootcomplete]: [true]
[gsm.current.phone-type]: [1]
[gsm.network.type]: [Unknown]
[gsm.operator.alpha]:
[gsm.operator.iso-country]:
[gsm.operator.isroaming]: [false]
[gsm.operator.numeric]:
[gsm.sim.operator.alpha]:
[gsm.sim.operator.iso-country]:
[gsm.sim.operator.numeric]:
[gsm.sim.state]: [NOT_READY]
[gsm.version.ril-impl]: [Quectel_Android_RIL_SR01A40V36]
[init.svc.adbd]: [running]
[init.svc.akmd]: [stopped]
[init.svc.ap_log_srv]: [stopped]
[init.svc.ap_logfs]: [stopped]
[init.svc.apk_logfs]: [running]
[init.svc.audioserver]: [running]
[init.svc.bootanim]: [stopped]
[init.svc.cameraserver]: [running]
[init.svc.catlog]: [running]
[init.svc.console]: [running]
[init.svc.crashlogd]: [running]
[init.svc.debuggerd]: [running]
[init.svc.debuggerd64]: [running]
[init.svc.drm]: [running]
[init.svc.drmservice]: [stopped]
[init.svc.earlylogs]: [stopped]
[init.svc.fsud]: [running]
[init.svc.gatekeeperd]: [running]
[init.svc.healthd]: [running]
[init.svc.installd]: [running]
[init.svc.keystore]: [running]
[init.svc.lmkd]: [running]
[init.svc.log-watch]: [running]
[init.svc.logd]: [running]
[init.svc.logd-reinit]: [stopped]
[init.svc.media]: [running]
[init.svc.mediacodec]: [running]
[init.svc.mediadrm]: [running]
[init.svc.mediaextractor]: [running]
[init.svc.mode_switch]: [stopped]
[init.svc.netd]: [running]
[init.svc.p2p_supplicant]: [running]
[init.svc.perfprofd]: [running]
[init.svc.ril-daemon]: [running]
[init.svc.servicemanager]: [running]
[init.svc.surfaceflinger]: [running]
[init.svc.tp_mode_switch]: [stopped]
[init.svc.ueventd]: [running]
[init.svc.up_eth0]: [stopped]
[init.svc.vm_daemon]: [running]
[init.svc.vold]: [running]
[init.svc.zygote]: [running]
[init.svc.zygote_secondary]: [running]
[keyguard.no_require_sim]: [true]
[log.tag.WifiHAL]: [D]
[logd.logpersistd.enable]: [true]
[media.audio.slice]: [0]
[net.bt.name]: [Android]
[net.change]: [net.qtaguid_enabled]
[net.hostname]: [android-e3d424f6a9e1eada]
[net.qtaguid_enabled]: [1]
[net.tcp.default_init_rwnd]: [60]
[persist.core.enabled]: [0]
[persist.crashlogd.root]: [/data/logs]
[persist.hdmi.ui.state]: [1]
[persist.intel.logger.rot_cnt]: [20]
[persist.intel.logger.rot_size]: [5000]
[persist.net.ethernet.mode]: [normal]
[persist.service.apklogfs.enable]: [1]
[persist.service.aplogfs.enable]: [0]
[persist.sys.alarm.fixed]:
[persist.sys.alarm.strategy]: [none]
[persist.sys.boot.check]: [false]
[persist.sys.cat_log]: [1]
[persist.sys.dalvik.vm.lib.2]: [libart.so]
[persist.sys.first_booting]: [false]
[persist.sys.framebuffer.main]: [1920x1080]
[persist.sys.hid]:
[persist.sys.locale]: [zh-Hans-CN]
[persist.sys.profiler_ms]: [0]
[persist.sys.strictmode.visual]: [false]
[persist.sys.timezone]: [Asia/Shanghai]
[persist.sys.ui.hw]: [true]
[persist.sys.usb.config]: [mtp,adb]
[persist.sys.usbcamera.status]:
[persist.sys.webview.vmsize]: [118564800]
[persist.tegra.nvmmlite]: [1]
[persist.usb.mode]: [2]
[pm.dexopt.ab-ota]: [speed-profile]
[pm.dexopt.bg-dexopt]: [speed-profile]
[pm.dexopt.boot]: [verify-profile]
[pm.dexopt.core-app]: [speed]
[pm.dexopt.first-boot]: [interpret-only]
[pm.dexopt.forced-dexopt]: [speed]
[pm.dexopt.install]: [interpret-only]
[pm.dexopt.nsys-library]: [speed]
[pm.dexopt.shared-apk]: [speed]
[ril.function.dataonly]: [1]
[rild.libargs]: [-d /dev/ttyACM0]
[rild.libpath]: [/system/lib/libril-rk29-dataonly.so]
[ro.adb.secure]: [0]
[ro.allow.mock.location]: [0]
[ro.audio.monitorOrientation]: [true]
[ro.baseband]: [N/A]
[ro.board.platform]: [rk3399]
[ro.boot.baseband]: [N/A]
[ro.boot.console]: [ttyFIQ0]
[ro.boot.hardware]: [rk30board]
[ro.boot.mode]: [emmc]
[ro.boot.noril]: [true]
[ro.boot.oem_unlocked]: [0]
[ro.boot.selinux]: [permissive]
[ro.bootimage.build.date]: [2020骞?05鏈?25鏃?鏄熸湡涓
续上:
[ro.bootimage.build.date.utc]: [1590371728]
[ro.bootimage.build.fingerprint]: [Android/rk3399_firefly_aio/rk3399_firefly_aio:7.1.2/NHG47K/lisd05250955:userdebug/test-keys]
[ro.bootloader]: [unknown]
[ro.bootmode]: [emmc]
[ro.bt.bdaddr_path]: [/data/misc/bluetooth/bdaddr]
[ro.build.characteristics]: [tablet]
[ro.build.date]: [2020骞?05鏈?25鏃?鏄熸湡涓
续上:
[ro.build.date.utc]: [1590371728]
[ro.build.description]: [rk3399_firefly_aio-userdebug 7.1.2 NHG47K eng.lisd.20200525.095528 test-keys]
[ro.build.display.id]: [rk3399_firefly_aio-userdebug 7.1.2 NHG47K eng.lisd.20200525.095528 test-keys]
[ro.build.fingerprint]: [Android/rk3399_firefly_aio/rk3399_firefly_aio:7.1.2/NHG47K/lisd05250955:userdebug/test-keys]
[ro.build.flavor]: [rk3399_firefly_aio-userdebug]
[ro.build.host]: [tchip-server]
[ro.build.id]: [NHG47K]
[ro.build.product]: [rk3399_firefly_aio]
[ro.build.tags]: [test-keys]
[ro.build.type]: [userdebug]
[ro.build.user]: [lisd]
[ro.build.version.all_codenames]: [REL]
[ro.build.version.base_os]:
[ro.build.version.codename]: [REL]
[ro.build.version.incremental]: [eng.lisd.20200525.095528]
[ro.build.version.preview_sdk]: [0]
[ro.build.version.release]: [7.1.2]
[ro.build.version.sdk]: [25]
[ro.build.version.security_patch]: [2017-04-05]
[ro.carrier]: [unknown]
续上:
[ro.com.android.dataroaming]: [true]
[ro.config.alarm_alert]: [Alarm_Classic.ogg]
[ro.config.enable.remotecontrol]: [false]
[ro.config.notification_sound]: [pixiedust.ogg]
[ro.config.ringtone]: [Ring_Synth_04.ogg]
[ro.crypto.state]: [unencrypted]
[ro.dalvik.vm.native.bridge]: [0]
[ro.debuggable]: [1]
[ro.default.size]: [100]
[ro.device_owner]: [false]
[ro.enable_boot_charger_mode]: [0]
[ro.expect.recovery_id]: [0x8bd67fd10c63b6d59561cc7fa8610390cf447b11000000000000000000000000]
[ro.factory.hasGPS]: [false]
[ro.factory.hasUMS]: [false]
[ro.factory.storage_suppntfs]: [true]
[ro.factory.tool]: [0]
[ro.factory.without_battery]: [false]
[ro.firefly.build.fingerprint]: [rk3399_firefly_aio/industry-71/V1.2.2005250955/7feed822ccc8]
[ro.hardware]: [rk30board]
[ro.hwui.disable_scissor_opt]: [true]
[ro.hwui.drop_shadow_cache_size]: [6]
[ro.hwui.gradient_cache_size]: [1]
[ro.hwui.layer_cache_size]: [48]
[ro.hwui.path_cache_size]: [32]
[ro.hwui.r_buffer_cache_size]: [8]
[ro.hwui.text_large_cache_height]: [1024]
[ro.hwui.text_large_cache_width]: [2048]
[ro.hwui.text_small_cache_height]: [1024]
[ro.hwui.text_small_cache_width]: [1024]
[ro.hwui.texture_cache_flushrate]: [0.4]
[ro.hwui.texture_cache_size]: [72]
[ro.intel.logger]: [/system/vendor/bin/logcatext]
[ro.opengles.version]: [196610]
[ro.product.board]: [rk30sdk]
[ro.product.brand]: [Android]
[ro.product.cpu.abi]: [arm64-v8a]
[ro.product.cpu.abilist]: [arm64-v8a,armeabi-v7a,armeabi]
[ro.product.cpu.abilist32]: [armeabi-v7a,armeabi]
[ro.product.cpu.abilist64]: [arm64-v8a]
[ro.product.device]: [rk3399_firefly_aio]
[ro.product.first_api_level]: [25]
[ro.product.fwtype]: [1]
[ro.product.locale]: [en-US]
[ro.product.manufacturer]: [rockchip]
[ro.product.model]: [AIO-3399J]
[ro.product.name]: [rk3399_firefly_aio]
[ro.product.ota.host]: [http://fota.t-chip.com.cn]
[ro.product.ota.style]: [2]
[ro.product.usbfactory]: [rockchip_usb]
[ro.product.version]: [1.2]
[ro.revision]: [0]
[ro.ril.ecclist]: [112,911]
[ro.rk.LowBatteryBrightness]: [true]
[ro.rk.MassStorage]: [false]
[ro.rk.bt_enable]: [true]
[ro.rk.def_brightness]: [200]
[ro.rk.displayd.enable]: [false]
[ro.rk.flash_enable]: [true]
[ro.rk.hdmi_enable]: [true]
[ro.rk.homepage_base]: [http://www.t-firefly.com/zh/]
[ro.rk.install_non_market_apps]: [true]
[ro.rk.screenoff_time]: [2147483647]
[ro.rk.screenshot_enable]: [true]
[ro.rk.soc]: [rk3399]
[ro.rk.systembar.tabletUI]: [false]
[ro.rk.systembar.voiceicon]: [true]
[ro.rksdk.version]: [RK30_ANDROID7.1.2-SDK-v1.00.00]
[ro.runtime.firstboot]: [1358499016926]
[ro.safemode.disabled]: [true]
[ro.secure]: [1]
[ro.serialno]: [766007T7A7]
[ro.service.default_logfs]: [apklogfs]
[ro.sf.fakerotation]: [false]
[ro.sf.hwrotation]: [0]
[ro.sf.lcd_density]: [213]
[ro.support.lossless.bitstream]: [true]
[ro.sys.sdcardfs]: [true]
[ro.target.product]: [tablet]
[ro.tether.denied]: [false]
[ro.udisk.visible]: [true]
[ro.usb.connect2pc]: [true]
[ro.usb.default_mtp]: [true]
[ro.wifi.channels]:
[ro.zygote]: [zygote64_32]
[security.perf_harden]: [1]
[selinux.reload_policy]: [1]
[service.bootanim.exit]: [1]
[sf.power.control]: [1]
[sys.boot_completed]: [1]
[sys.bootvideo.closed]: [1]
[sys.camera.callprocess]: [cameraserver]
[sys.cts_camera.status]: [false]
[sys.device_locked.status]: [0]
[sys.dropbox.max_size_kb]: [4096]
[sys.dump.binder_stats.anr]: [1]
[sys.dump.binder_stats.uiwdt]: [1]
[sys.ggralloc.commit]: [commit-id:7feed82]
[sys.ggralloc.version]: [1.0.6]
[sys.ghwc.commit]: [commit-id:7feed82]
[sys.ghwc.version]: [0.57-rk3399-MID]
[sys.gmali.fbdc_target]: [1]
续上:
[sys.gmali.version]: [r18p0-01rel0-x-6@0]
[sys.hdmiin.resolution]: [false]
[sys.hwc.compose_policy]: [6]
[sys.hwc.device.aux]:
[sys.hwc.device.main]:
[sys.hwc.device.primary]: [HDMI-A]
[sys.logbootcomplete]: [1]
[sys.resolution.changed]: [false]
[sys.rkadb.root]: [0]
[sys.secureboot]: [false]
[sys.serialno]: [766007T7A7]
[sys.status.hidebar_enable]: [false]
[sys.sysctl.extra_free_kbytes]: [24300]
[sys.usb.config]: [mtp,adb]
[sys.usb.configfs]: [1]
[sys.usb.controller]: [fe800000.dwc3]
[sys.usb.ffs.ready]: [1]
[sys.usb.state]: [mtp,adb]
[sys.wallpaper.rgb565]: [0]
[sys_graphic.TC358749XBG.ver]: [0x0.0x3.0x0]
[sys_graphic.cam_camboard.ver]: [0x0.0xf.0x0]
[sys_graphic.cam_drv_camsys.ver]: [0x0.0x0.0x1]
[sys_graphic.cam_hal.ver]: [0x2.0x0.0x0]
[sys_graphic.cam_isi.ver]: [0x0.0xe.0x0]
[sys_graphic.cam_libisp.ver]: [0x3.0x1.0x0]
[sys_graphic.cam_otp_awb]: [false]
[sys_graphic.cam_otp_awb_enable]: [false]
[sys_graphic.cam_otp_lsc]: [false]
[sys_graphic.cam_otp_lsc_enable]: [false]
[sys_graphic.cam_trace]: [0]
[telephony.lteOnCdmaDevice]: [0]
[testing.mediascanner.skiplist]: [/mnt/shell/emulated/Android/]
[vold.has_adoptable]: [1]
[vold.post_fs_data_done]: [1]
[wifi.interface]: [wlan0]
[wifi.supplicant_scan_interval]: [15]
完
请问:
其中有 [sys_graphic.TC358749XBG.ver]: [0x0.0x3.0x0] 这条信息。请问一下,对HDMI IN进行了什么配置后,这条信息才会显示在这里的?谢谢~
