根据官方全编命令,log提示如下:
[ 26% 6027/23162] Ensure Jack server is installed and started
FAILED: /bin/bash -c “(prebuilts/sdk/tools/jack-admin install-server prebuilts/sdk/tools/jack-launcher.jar prebuilts/sdk/tools/jack-server-4.8.ALPHA.jar 2>&1 || (exit 0) ) && (JACK_SERVER_VM_ARGUMENTS="-Dfile.encoding=UTF-8 -XX:+TieredCompilation" prebuilts/sdk/tools/jack-admin start-server 2>&1 || exit 0 ) && (prebuilts/sdk/tools/jack-admin update server prebuilts/sdk/tools/jack-server-4.8.ALPHA.jar 4.8.ALPHA 2>&1 || exit 0 ) && (prebuilts/sdk/tools/jack-admin update jack prebuilts/sdk/tools/jacks/jack-2.28.RELEASE.jar 2.28.RELEASE || exit 47; prebuilts/sdk/tools/jack-admin update jack prebuilts/sdk/tools/jacks/jack-3.36.CANDIDATE.jar 3.36.CANDIDATE || exit 47; prebuilts/sdk/tools/jack-admin update jack prebuilts/sdk/tools/jacks/jack-4.7.BETA.jar 4.7.BETA || exit 47 )”
Jack server already installed in “/home/kevin/.jack-server”
Launching Jack server java -XX:MaxJavaStackTraceDepth=-1 -Djava.io.tmpdir=/tmp -Dfile.encoding=UTF-8 -XX:+TieredCompilation -cp /home/kevin/.jack-server/launcher.jar com.android.jack.launcher.ServerLauncher
Jack server failed to (re)start, try ‘jack-diagnose’ or see Jack server log
No Jack server running. Try ‘jack-admin start-server’
[ 26% 6027/23162] target Package: framework-res
可以参考
https://dev.t-firefly.com/forum.php?mod=viewthread&tid=103472&highlight=Jack%2Bserver
ubuntu 版本建议ubuntu16 或 ubuntu18
jpchen 发表于 2021-5-11 16:21
可以参考
这个问题我发这个贴子之前查了很多资料,差不多搞了一周时间,终于搞定了。
总结一下做个记录:
编译环境:Ubuntu 16.04 TLS
Android版本:Android7.1 Industry
解决办法:
①根据官方全编命令第一次编译出错,显示为:No Jack server running. Try 'jack-admin start-server’时,进入目录:/etc/java-8-openjdk/security/,将java.security文件中的TLSv1, TLSv1.1删除。(即jdk.tls.disabledAlgorithms=SSLv3, TLSv1, TLSv1.1, RC4, DES, MD5withRSA, 改为:jdk.tls.disabledAlgorithms=SSLv3, RC4, DES, MD5withRSA)
②若不是第一次编译时出错,而是根据网上别的帖子更改过环境变量或者其他东西,建议将代码删除后,根据官方步骤重新解压编译后,再根据①修改,一般能一次性解决问题。(网上帖子中的方法我都尝试过,改了这里那里又会有问题,无法彻底解决)
总结一下做个记录:
编译环 …
环境配置好,一般都会比较顺便,同时也有部分意外的问题出现{:4_211:}
