DIY_IMG_原板_RK3399.log
DDR Version 1.24 20191016
soft reset
SRX
Channel 0: DDR3, 800MHz
Channel 1: DDR3, 800MHz
256B stride
Boot1 Release Time: May 29 2020 17:36:36, version: 1.26
CPUId = 0x0
ChipType = 0x10, 429
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=60906MB
FwPartOffset=2000 , 0
run on sd0
StorageInit ok = 78329
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
atags_set_bootdev: ret:(0)
GPT part: 2, name: misc, start:0x8000, size:0x2000
GPT part: 3, name: boot, start:0xa000, size:0x10000
GPT part: 4, name: recovery, start:0x1a000, size:0x10000
GPT part: 5, name: backup, start:0x2a000, size:0x10000
GPT part: 6, name: rootfs, start:0x5a000, size:0x5dbe00
GPT part: 7, name: userdata, start:0x635e00, size:0x70bf1df
find part:uboot OK. first_lba:0x4000.
find part:trust OK. first_lba:0x6000.
Trust Addr:0x6000, 0x58334c42
No find bl30.bin
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0xe3098
RunBL31 0x40000 @ 247454 us
NOTICE: BL31: v1.3(release):845ee93
NOTICE: BL31: Built : 15:51:11, Jul 22 2020
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1196): pd status 3e
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-266-gee81607c #1 Mon Aug 17 09:23:30 UTC 2020 aarch64)
INFO: SPSR = 0x3c9
U-Boot 2017.09-gc56bc3a030 #root (May 12 2021 - 11:29:17 +0800)
Model: ROC-RK3399-PC Board
PreSerial: 2
DRAM: 2 GiB
Sysmem: init
Relocation Offset: 7dbec000, fdt: 7bdd5728
I2c0 speed: 400000Hz
PMIC: RK808
vdd_center 900000 uV
vdd_cpu_l 900000 uV
vdd_log init 1100000 uV
MMC: dwmmc@fe320000: 1, sdhci@fe330000: 0
In: serial
Out: serial
Err: serial
switch to partitions #0, OK
mmc1 is current device
Found IDB in SDcard
Bootdev(atags): mmc 1
MMC1: Legacy, 50Mhz
PartType: EFI
boot mode: normal
Found DTB in boot part
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
aplll 816000 KHz
apllb 816000 KHz
dpll 800000 KHz
cpll 24000 KHz
gpll 800000 KHz
npll 600000 KHz
vpll 24000 KHz
aclk_perihp 133333 KHz
hclk_perihp 66666 KHz
pclk_perihp 33333 KHz
aclk_perilp0 266666 KHz
hclk_perilp0 88888 KHz
pclk_perilp0 44444 KHz
hclk_perilp1 100000 KHz
pclk_perilp1 50000 KHz
Net: eth0: ethernet@fe300000
DTB: rk-kernel.dtb
HASH(c): OK
Android header version 0
Booting IMAGE kernel at 0x00280000 with fdt at 0x08300000…
Fdt Ramdisk skip relocation
## Booting Android Image at 0x0027f800 …
Kernel load addr 0x00280000 size 19455 KiB
RAM disk load addr 0x0a200000 size 8657 KiB
## Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
XIP Kernel Image from 0x00280000 to 0x00280000 … OK
Using Device Tree in place at 0000000008300000, end 000000000831cade
No file: logo_kernel.bmp
Total: 3106.568 ms
[ 0.000000] Linux version 4.4.194-g50f0a60241aa-dirty (root@bw-MS-7C52) (firefly: 50f0a60241aa6c9af65d5bdbdaae40df4cd77be3) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #6 SMP Tue May 11 17:10:44 CST 2021
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07fedf000 s46312 r8192 d31512 u86016
[ 0.000000] Kernel command line: storagemedia=sd androidboot.storagemedia=sd androidboot.mode=normal androidboot.slot_suffix= androidboot.serialno=4eaf29be85563b5e ro rootwait earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1
[ 0.000000] software IO TLB: mapped [mem 0x7fe97000-0x7fed7000] (0MB)
[ 0.000000] Memory: 1996272K/2064384K available (11902K kernel code, 1662K rwdata, 4688K rodata, 1152K init, 1920K bss, 68112K reserved, 0K cma-reserved)
[ 0.000000] .init : 0xffffff80090c0000 - 0xffffff80091e0000 ( 1152 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008c20000 ( 11904 KB)
[ 0.000000] .rodata : 0xffffff8008c20000 - 0xffffff80090c0000 ( 4736 KB)
[ 0.000000] .data : 0xffffff80091e0000 - 0xffffff800937f808 ( 1663 KB)
[ 0.000000] ITS: allocated 65536 Devices @7d480000 (psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x000000007d410000
[ 0.000000] CPU0: using LPI pending table @0x000000007d420000
[ 0.002201] Console: colour dummy device 80x25
[ 0.002641] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.003627] pid_max: default: 32768 minimum: 301
[ 0.004148] Security Framework initialized
[ 0.004609] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.005249] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.006594] Initializing cgroup subsys io
[ 0.007000] Initializing cgroup subsys memory
[ 0.007439] Initializing cgroup subsys devices
[ 0.007870] Initializing cgroup subsys freezer
[ 0.008308] Initializing cgroup subsys perf_event
[ 0.008763] Initializing cgroup subsys net_prio
[ 0.009200] Initializing cgroup subsys pids
[ 0.009629] ftrace: allocating 44598 entries in 175 pages
[ 0.115542] sched-energy: Sched-energy-costs installed from DT
[ 0.116106] CPU0: update cpu_capacity 401
[ 0.116548] ASID allocator initialised with 32768 entries
[ 0.120156] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.121485] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.123671] Detected VIPT I-cache on CPU1
[ 0.123700] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.123724] CPU1: using LPI pending table @0x000000007d6a0000
[ 0.123761] CPU1: update cpu_capacity 401
[ 0.123765] CPU1: Booted secondary processor [410fd034]
[ 0.124296] Detected VIPT I-cache on CPU2
[ 0.124316] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.124338] CPU2: using LPI pending table @0x000000007d6d0000
[ 0.124364] CPU2: update cpu_capacity 401
[ 0.124367] CPU2: Booted secondary processor [410fd034]
[ 0.124899] Detected VIPT I-cache on CPU3
[ 0.124919] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.124941] CPU3: using LPI pending table @0x000000007d730000
[ 0.124966] CPU3: update cpu_capacity 401
[ 0.124969] CPU3: Booted secondary processor [410fd034]
[ 0.125501] Detected PIPT I-cache on CPU4
[ 0.125525] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.125558] CPU4: using LPI pending table @0x000000007d760000
[ 0.125592] CPU4: update cpu_capacity 1024
[ 0.125595] CPU4: Booted secondary processor [410fd082]
[ 0.126129] Detected PIPT I-cache on CPU5
[ 0.126147] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.126178] CPU5: using LPI pending table @0x000000007d790000
[ 0.126203] CPU5: update cpu_capacity 1024
[ 0.126207] CPU5: Booted secondary processor [410fd082]
[ 0.126288] Brought up 6 CPUs
[ 0.138634] SMP: Total of 6 processors activated.
[ 0.139085] CPU features: detected feature: GIC system register CPU interface
[ 0.139772] CPU features: detected feature: 32-bit EL0 Support
[ 0.140331] CPU: All CPU(s) started at EL2
[ 0.140757] alternatives: patching kernel code
[ 0.142525] devtmpfs: initialized
[ 0.160659] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.161617] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.162646] xor: measuring software checksum speed
[ 0.172498] 8regs : 2856.000 MB/sec
[ 0.182553] 8regs_prefetch: 2564.000 MB/sec
[ 0.192606] 32regs : 3208.000 MB/sec
[ 0.202659] 32regs_prefetch: 2848.000 MB/sec
[ 0.203106] xor: using function: 32regs (3208.000 MB/sec)
[ 0.203637] pinctrl core: initialized pinctrl subsystem
[ 0.205819] Failed to find legacy iommu devices
[ 0.206618] NET: Registered protocol family 16
[ 0.212125] cpuidle: using governor ladder
[ 0.216133] cpuidle: using governor menu
[ 0.216524] Registered FIQ tty driver
[ 0.217279] vdso: 2 pages (1 code @ ffffff8008c26000, 1 data @ ffffff80091e4000)
[ 0.218004] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.219066] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.243677] console [pstore-1] enabled
[ 0.244046] pstore: Registered ramoops as persistent store backend
[ 0.244638] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.247907] console [ttyFIQ0] enabled
[ 0.248595] bootconsole [uart0] disabled
[ 0.249520] Registered fiq debugger ttyFIQ0
[ 0.280161] raid6: int64x1 gen() 468 MB/s
[ 0.297226] raid6: int64x1 xor() 412 MB/s
[ 0.314341] raid6: int64x2 gen() 675 MB/s
[ 0.331417] raid6: int64x2 xor() 597 MB/s
[ 0.348500] raid6: int64x4 gen() 980 MB/s
[ 0.365588] raid6: int64x4 xor() 673 MB/s
[ 0.382711] raid6: int64x8 gen() 781 MB/s
[ 0.399756] raid6: int64x8 xor() 630 MB/s
[ 0.416858] raid6: neonx1 gen() 964 MB/s
[ 0.433944] raid6: neonx1 xor() 675 MB/s
[ 0.451057] raid6: neonx2 gen() 1277 MB/s
[ 0.468127] raid6: neonx2 xor() 980 MB/s
[ 0.485210] raid6: neonx4 gen() 1730 MB/s
[ 0.502285] raid6: neonx4 xor() 1166 MB/s
[ 0.519383] raid6: neonx8 gen() 1691 MB/s
[ 0.536471] raid6: neonx8 xor() 1234 MB/s
[ 0.536855] raid6: using algorithm neonx4 gen() 1730 MB/s
[ 0.537336] raid6: … xor() 1166 MB/s, rmw enabled
[ 0.537777] raid6: using intx1 recovery algorithm
[ 0.543475] iommu: Adding device ff650000.vpu_service to group 0
[ 0.544090] iommu: Adding device ff660000.rkvdec to group 1
[ 0.544704] iommu: Adding device ff8f0000.vop to group 2
[ 0.545269] iommu: Adding device ff900000.vop to group 3
[ 0.545840] iommu: Adding device ff910000.rkisp1 to group 4
[ 0.546425] iommu: Adding device ff920000.rkisp1 to group 5
[ 0.547414] rk_iommu ff650800.iommu: can’t get sclk
[ 0.548102] rk_iommu ff660480.iommu: can’t get sclk
[ 0.548737] rk_iommu ff8f3f00.iommu: can’t get sclk
[ 0.549340] rk_iommu ff903f00.iommu: can’t get sclk
[ 0.549933] rk_iommu ff914000.iommu: can’t get sclk
[ 0.550541] rk_iommu ff924000.iommu: can’t get sclk
[ 0.551314] SCSI subsystem initialized
[ 0.552011] usbcore: registered new interface driver usbfs
[ 0.552534] usbcore: registered new interface driver hub
[ 0.553102] usbcore: registered new device driver usb
[ 0.553610] media: Linux media interface: v0.10
[ 0.554057] Linux video capture interface: v2.00
[ 0.554548] pps_core: LinuxPPS API ver. 1 registered
[ 0.554990] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.555821] PTP clock support registered
[ 0.557307] Advanced Linux Sound Architecture Driver Initialized.
[ 0.558318] Bluetooth: Core ver 2.21
[ 0.558654] NET: Registered protocol family 31
[ 0.559060] Bluetooth: HCI device and connection manager initialized
[ 0.559632] Bluetooth: HCI socket layer initialized
[ 0.560073] Bluetooth: L2CAP socket layer initialized
[ 0.560543] Bluetooth: SCO socket layer initialized
[ 0.561471] nfc: nfc_init: NFC Core ver 0.1
[ 0.561877] NET: Registered protocol family 39
[ 0.562388] rockchip-cpuinfo cpuinfo: Serial : 4eaf29be85563b5e
[ 0.563582] clocksource: Switched to clocksource arch_sys_counter
[ 0.613269] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.614178] NET: Registered protocol family 2
[ 0.614973] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.615754] TCP bind hash table entries: 16384 (order: 7, 524288 bytes)
[ 0.616789] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.617437] UDP hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.618061] UDP-Lite hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.618889] NET: Registered protocol family 1
[ 0.619543] RPC: Registered named UNIX socket transport module.
[ 0.620084] RPC: Registered udp transport module.
[ 0.620503] RPC: Registered tcp transport module.
[ 0.620929] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.622176] Trying to unpack rootfs image as initramfs…
[ 1.033378] Freeing initrd memory: 8656K
[ 1.034314] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 1.035138] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 1.039095] Initialise system trusted keyring
[ 1.047517] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.048827] NFS: Registering the id_resolver key type
[ 1.049296] Key type id_resolver registered
[ 1.049690] Key type id_legacy registered
[ 1.050065] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 1.051337] ntfs: driver 2.1.32 [Flags: R/O].
[ 1.052107] fuse init (API version 7.23)
[ 1.052809] SGI XFS with security attributes, no debug enabled
[ 1.058535] NET: Registered protocol family 38
[ 1.058973] Key type asymmetric registered
[ 1.059341] Asymmetric key parser ‘x509’ registered
[ 1.059939] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.060737] io scheduler noop registered
[ 1.061094] io scheduler deadline registered
[ 1.061508] io scheduler cfq registered (default)
[ 1.066795] ace test_init function.
[ 1.067281] ace test_init end.ret=0
[ 1.067994] radar end.ret=0
[ 1.070778] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 1.071364] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 1.071972] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 1.072531] rockchip-pcie f8000000.pcie: missing “memory-region” property
[ 1.073147] PCI host bridge /pcie@f8000000 ranges:
[ 1.073705] MEM 0xfa000000..0xfbdfffff → 0xfa000000
[ 1.074163] IO 0xfbe00000..0xfbefffff → 0xfbe00000
[ 1.616642] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 1.617255] rockchip-pcie f8000000.pcie: deferred probe failed
[ 1.617998] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 1.619407] backlight supply power not found, using dummy regulator
[ 1.620560] Module initialized.
[ 1.621280] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 1.622150] rk-vcodec ff650000.vpu_service: probe device
[ 1.622882] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[ 1.624028] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 1.624664] rk-vcodec ff650000.vpu_service: init success
[ 1.625384] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 1.626349] rk-vcodec ff660000.rkvdec: probe device
[ 1.626982] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[ 1.627925] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 1.628506] rk-vcodec ff660000.rkvdec: init success
[ 1.630379] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.631068] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 1.633266] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.633954] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.635795] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 1.637616] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 1.638782] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 38, base_baud = 1500000) is a 16550A
[ 1.641297] [drm] Initialized drm 1.1.0 20060810
[ 1.645660] [drm] Rockchip DRM driver version: v1.0.1
[ 1.648281] mali ff9a0000.gpu: Failed to get regulator
[ 1.648748] mali ff9a0000.gpu: Power control initialization failed
[ 1.649659] Unable to detect cache hierarchy for CPU 0
[ 1.650950] brd: module loaded
[ 1.656457] loop: module loaded
[ 1.657286] zram: Added device: zram0
[ 1.657903] lkdtm: No crash points registered, enable through debugfs
[ 1.658591] Loading dl1825 driver
[ 1.660479] rockchip-spi ff1d0000.spi: no high_speed pinctrl state
[ 1.661557] m25p80 spi32766.0: unrecognized JEDEC id bytes: ff, ff, ff
[ 1.662159] m25p80: probe of spi32766.0 failed with error -2
[ 1.663074] register spi return v = :0
[ 1.663905] tun: Universal TUN/TAP device driver, 1.6
[ 1.664358] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.665951] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.666596] rk_gmac-dwmac fe300000.ethernet: TX delay(0x2e).
[ 1.667098] rk_gmac-dwmac fe300000.ethernet: RX delay(0x13).
[ 1.667623] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 1.668344] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 1.668967] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.674518] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.675144] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.675607] Ring mode enabled
[ 1.675888] DMA HW capability register supported
[ 1.676294] Normal descriptors
[ 1.676608] RX Checksum Offload Engine supported (type 2)
[ 1.677094] TX Checksum insertion supported
[ 1.677477] Wake-Up On Lan supported
[ 1.677845] Enable RX Mitigation via HW Watchdog Timer
[ 1.747780] libphy: stmmac: probed
[ 1.748095] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.748675] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.750517] usbcore: registered new interface driver rndis_wlan
[ 1.751324] Rockchip WiFi SYS interface (V1.00) …
[ 1.751941] usbcore: registered new interface driver rtl8150
[ 1.752500] usbcore: registered new interface driver r8152
[ 1.753060] usbcore: registered new interface driver asix
[ 1.753604] usbcore: registered new interface driver ax88179_178a
[ 1.754196] usbcore: registered new interface driver cdc_ether
[ 1.754781] usbcore: registered new interface driver rndis_host
[ 1.755386] usbcore: registered new interface driver cdc_ncm
[ 1.755947] usbcore: registered new interface driver qmi_wwan
[ 1.756505] usbcore: registered new interface driver cdc_mbim
[ 1.759002] rockchip-dwc3 usb0: failed to get drvdata dwc3
[ 1.760967] rockchip-dwc3 usb1: failed to get drvdata dwc3
[ 1.762904] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.763499] ehci-pci: EHCI PCI platform driver
[ 1.763992] ehci-platform: EHCI generic platform driver
[ 1.765371] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.765953] ohci-platform: OHCI generic platform driver
[ 1.767600] usbcore: registered new interface driver cdc_acm
[ 1.768102] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.768854] usbcore: registered new interface driver cdc_wdm
[ 1.769386] usbcore: registered new interface driver uas
[ 1.769920] usbcore: registered new interface driver usb-storage
[ 1.770524] usbcore: registered new interface driver usbserial
[ 1.771087] usbcore: registered new interface driver usbserial_generic
[ 1.771700] usbserial: USB Serial support registered for generic
[ 1.772262] usbcore: registered new interface driver ch341
[ 1.772781] usbserial: USB Serial support registered for ch341-uart
[ 1.773365] usbcore: registered new interface driver cp210x
[ 1.773895] usbserial: USB Serial support registered for cp210x
[ 1.774445] usbcore: registered new interface driver ftdi_sio
[ 1.774986] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.775678] usbcore: registered new interface driver keyspan
[ 1.776197] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 1.776921] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 1.777598] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 1.778264] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 1.778950] usbcore: registered new interface driver option
[ 1.779468] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.780123] usbcore: registered new interface driver oti6858
[ 1.780654] usbserial: USB Serial support registered for oti6858
[ 1.781215] usbcore: registered new interface driver pl2303
[ 1.781747] usbserial: USB Serial support registered for pl2303
[ 1.782296] usbcore: registered new interface driver qcserial
[ 1.782838] usbserial: USB Serial support registered for Qualcomm USB modem
[ 1.783479] usbcore: registered new interface driver sierra
[ 1.784012] usbserial: USB Serial support registered for Sierra USB modem
[ 1.785682] usbcore: registered new interface driver usbtouchscreen
[ 1.786506] .. rk pwm remotectl v1.1 init
[ 1.787119] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 1.788196] sensor_register_slave:mma8452,id=17
[ 1.788628] sensor_register_slave:lis3dh,id=7
[ 1.789017] sensor_register_slave:mma7660,id=18
[ 1.789427] sensor_register_slave:lsm303d,id=22
[ 1.789848] sensor_register_slave:gs_mc3230,id=23
[ 1.790266] [Gsensor] gsensor_init
[ 1.790594] sensor_register_slave:mpu6880_acc,id=24
[ 1.791028] sensor_register_slave:mpu6500_acc,id=25
[ 1.791461] sensor_register_slave:lsm330_acc,id=26
[ 1.791903] sensor_register_slave:akm8975,id=30
[ 1.792313] sensor_register_slave:akm8963,id=31
[ 1.792731] sensor_register_slave:l3g4200d,id=45
[ 1.793142] sensor_register_slave:l3g20d,id=46
[ 1.793541] sensor_register_slave:ewtsa,id=47
[ 1.793937] sensor_register_slave:lsm330_gyro,id=51
[ 1.794371] sensor_register_slave:cm3217,id=53
[ 1.794777] sensor_register_slave:cm3218,id=54
[ 1.795699] i2c /dev entries driver
[ 1.797235] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 1.797921] fan53555-reg: supplied by vcc5v0_sys
[ 1.800467] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 1.801148] fan53555-reg: supplied by vcc5v0_sys
[ 1.803743] rk808 0-001b: Pmic Chip id: 0x0
[ 1.806834] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.807435] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.808076] DCDC_REG1: supplied by vcc3v3_sys
[ 1.809238] DCDC_REG2: supplied by vcc3v3_sys
[ 1.810243] DCDC_REG3: supplied by vcc3v3_sys
[ 1.810960] DCDC_REG4: supplied by vcc3v3_sys
[ 1.811839] LDO_REG1: supplied by vcc3v3_sys
[ 1.813373] LDO_REG2: supplied by vcc3v3_sys
[ 1.814803] LDO_REG3: supplied by vcc3v3_sys
[ 1.816198] LDO_REG4: supplied by vcc3v3_sys
[ 1.817628] LDO_REG5: supplied by vcc3v3_sys
[ 1.819034] LDO_REG6: supplied by vcc3v3_sys
[ 1.820427] LDO_REG7: supplied by vcc3v3_sys
[ 1.821866] LDO_REG8: supplied by vcc3v3_sys
[ 1.823271] SWITCH_REG1: supplied by vcc3v3_sys
[ 1.824028] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.827846] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 1.828920] rk808 0-001b: Can not read property pmic,stby-gpio
[ 1.829469] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80095e6000
[ 1.830857] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80095ee000
[ 1.832080] rk3x-i2c ff120000.i2c: Initialized RK3xxx I2C bus at ffffff80095fe000
[ 1.833865] fusb302 7-0022: Can’t get property of role, set role to default DRP
[ 2.833614] rk3x-i2c ff160000.i2c: timeout, ipd: 0x00, state: 1
[ 2.834145] fusb302 7-0022: fusb302 send extcon to disable vbus 5v
[ 3.834602] rk3x-i2c ff160000.i2c: timeout, ipd: 0x00, state: 1
[ 4.834614] rk3x-i2c ff160000.i2c: timeout, ipd: 0x00, state: 1
[ 5.834615] rk3x-i2c ff160000.i2c: timeout, ipd: 0x00, state: 1
[ 6.834611] rk3x-i2c ff160000.i2c: timeout, ipd: 0x00, state: 1
[ 7.834611] rk3x-i2c ff160000.i2c: timeout, ipd: 0x00, state: 1
[ 8.834610] rk3x-i2c ff160000.i2c: timeout, ipd: 0x00, state: 1
[ 9.834610] rk3x-i2c ff160000.i2c: timeout, ipd: 0x00, state: 1
[ 10.834610] rk3x-i2c ff160000.i2c: timeout, ipd: 0x00, state: 1
[ 11.834609] rk3x-i2c ff160000.i2c: timeout, ipd: 0x00, state: 1
[ 12.834609] rk3x-i2c ff160000.i2c: timeout, ipd: 0x00, state: 1
[ 13.834609] rk3x-i2c ff160000.i2c: timeout, ipd: 0x00, state: 1
[ 14.834610] rk3x-i2c ff160000.i2c: timeout, ipd: 0x00, state: 1
[ 15.834609] rk3x-i2c ff160000.i2c: timeout, ipd: 0x00, state: 1
[ 16.834610] rk3x-i2c ff160000.i2c: timeout, ipd: 0x00, state: 1
[ 17.834609] rk3x-i2c ff160000.i2c: timeout, ipd: 0x00, state: 1
[ 18.834609] rk3x-i2c ff160000.i2c: timeout, ipd: 0x00, state: 1
[ 19.834609] rk3x-i2c ff160000.i2c: timeout, ipd: 0x00, state: 1
[ 19.835489] fusb302 7-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 19.836456] input: Typec_Headphone as /devices/platform/ff160000.i2c/i2c-7/7-0022/input/input1
[ 20.837645] rk3x-i2c ff160000.i2c: timeout, ipd: 0x00, state: 1
[ 20.838178] mp8859 7-0066: failed to set slew_rate
[ 20.838626] mp8859 7-0066: register ext0 dev0
[ 20.839190] mp8859 7-0066: mp8859 probe successful
[ 20.840074] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at ffffff80097c2000
[ 20.842553] fusb302 4-0022: Can’t get property of role, set role to default DRP
[ 20.852570] fusb302 4-0022: port 1 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 20.853594] input: Typec_Headphone as /devices/platform/ff3d0000.i2c/i2c-4/4-0022/input/input2
[ 20.854609] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80097c4000
[ 20.857026] IR NEC protocol handler initialized
[ 20.858570] rkisp1 ff910000.rkisp1: rkisp1 driver version: v00.01.05
[ 20.859173] rkisp1 ff910000.rkisp1: Missing rockchip,grf property
[ 20.862077] rkisp1 ff920000.rkisp1: rkisp1 driver version: v00.01.05
[ 20.862680] rkisp1 ff920000.rkisp1: Missing rockchip,grf property
[ 20.865462] usbcore: registered new interface driver npu_acm
[ 20.866068] usbcore: registered new interface driver uvcvideo
[ 20.866593] USB Video Class driver (1.1.1)
[ 20.867051] cw201x 2-0062: design_capacity missing!
[ 21.866631] rk3x-i2c ff120000.i2c: timeout, ipd: 0x00, state: 1
[ 21.867161] cw_bat_probe cw_init error
[ 21.867512] cw201x: probe of 2-0062 failed with error -110
[ 21.870847] Boot mode: normal
[ 21.873213] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 21.874220] rockchip-thermal ff260000.tsadc: tsadc is probed successfully!
[ 21.875798] dw_wdt ff848000.watchdog: Should better to setup a ‘resets’ property in dt, that must been named with reset
[ 21.877621] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 21.878604] Bluetooth: Virtual HCI driver ver 1.5
[ 21.879173] Bluetooth: HCI UART driver ver 2.3
[ 21.879588] Bluetooth: HCI UART protocol H4 registered
[ 21.880043] Bluetooth: HCI UART protocol LL registered
[ 21.880496] Bluetooth: HCI UART protocol ATH3K registered
[ 21.881060] usbcore: registered new interface driver bfusb
[ 21.881622] usbcore: registered new interface driver btusb
[ 21.882770] cpu cpu0: bin=1
[ 21.883099] cpu cpu0: leakage=23
[ 21.896424] cpu cpu0: temp=36250, pvtm=146450 (147025 + -575)
[ 21.897334] cpu cpu0: pvtm-volt-sel=1
[ 21.897753] cpu cpu0: bin-scale=34
[ 21.898465] cpu cpu4: bin=1
[ 21.898860] cpu cpu4: leakage=40
[ 21.911935] cpu cpu4: temp=36875, pvtm=154931 (155286 + -355)
[ 21.913373] cpu cpu4: pvtm-volt-sel=1
[ 21.913787] cpu cpu4: bin-scale=17
[ 21.915739] cpu cpu0: avs=0
[ 21.916137] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 21.917683] cpu cpu0: failed to find power_model node
[ 21.919479] cpu cpu4: avs=0
[ 21.919896] cpu cpu4: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 21.922210] cpu cpu4: failed to find power_model node
[ 21.923868] sdhci: Secure Digital Host Controller Interface driver
[ 21.924412] sdhci: Copyright(c) Pierre Ossman
[ 21.924829] Synopsys Designware Multimedia Card Interface Driver
[ 21.926634] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 21.927296] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 21.927922] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 21.928479] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 21.929475] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 21.930039] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 21.931871] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 21.932528] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 21.933161] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 21.933725] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 21.934605] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 21.935942] vccio_sd: unsupportable voltage range: 3300000-3000000uV
[ 21.936527] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 21.937229] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 21.950481] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 21.963992] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 21.965006] sdhci-pltfm: SDHCI platform and OF driver helper
[ 21.967445] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 21.967990] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 21.998741] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 22.000770] hidraw: raw HID events driver (C) Jiri Kosina
[ 22.001901] usbcore: registered new interface driver usbhid
[ 22.002397] usbhid: USB HID core driver
[ 22.002949] inv_mpu_iio: inv_mpu_init:746
[ 22.007479] usbcore: registered new interface driver snd-usb-audio
[ 22.013473] rockchip-cdndp-sound dp-sound: ASoC: CODEC DAI spdif-hifi not registered
[ 22.014174] rockchip-cdndp-sound dp-sound: rockchip_sound_probe snd_soc_register_card fail -517
[ 22.015063] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 22.016049] IPVS: Registered protocols (TCP, UDP)
[ 22.016512] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[ 22.017274] IPVS: Creating netns size=2104 id=0
[ 22.017719] IPVS: ipvs loaded.
[ 22.018007] IPVS: [rr] scheduler registered.
[ 22.018679] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 22.019238] Initializing XFRM netlink socket
[ 22.020244] NET: Registered protocol family 10
[ 22.021829] NET: Registered protocol family 17
[ 22.022252] NET: Registered protocol family 15
[ 22.022696] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 22.023835] Bridge firewalling registered
[ 22.024619] Bluetooth: RFCOMM socket layer initialized
[ 22.025099] Bluetooth: RFCOMM ver 1.11
[ 22.025458] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 22.025997] Bluetooth: HIDP socket layer initialized
[ 22.026494] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 22.027246] [BT_RFKILL]: Enter rfkill_rk_init
[ 22.027855] Key type dns_resolver registered
[ 22.028491] sensor_register_slave:mpu6880_gyro,id=50
[ 22.029637] ov13850 1-0036: driver version: 00.01.03
[ 22.033381] ov13850 1-0036: write SCCB_ID failed
[ 22.034085] ov13850: probe of 1-0036 failed with error -5
[ 22.035058] ov13850 1-0046: driver version: 00.01.03
[ 22.038239] ov13850 1-0046: write SCCB_ID failed
[ 22.038825] ov13850: probe of 1-0046 failed with error -5
[ 22.040320] Registered cp15_barrier emulation handler
[ 22.040875] Registered setend emulation handler
[ 22.042334] Loading compiled-in X.509 certificates
[ 22.044918] Btrfs loaded
[ 22.046287] rga2: Driver loaded successfully ver:3.02
[ 22.047111] rga2: Module initialized.
[ 22.048468] phy phy-ff770000.syscon:usb2-phy@e450.3: Failed to get VBUS supply regulator
[ 22.050385] phy phy-ff770000.syscon:usb2-phy@e460.5: Failed to get VBUS supply regulator
[ 22.052654] rockchip-drm display-subsystem: dmc is disabled
[ 22.052720] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[ 22.053437] mmcblk1: mmc1:0001 AJTD4R 14.6 GiB
[ 22.053967] mmcblk1boot0: mmc1:0001 AJTD4R partition 1 4.00 MiB
[ 22.054388] mmcblk1boot1: mmc1:0001 AJTD4R partition 2 4.00 MiB
[ 22.054859] mmcblk1rpmb: mmc1:0001 AJTD4R partition 3 4.00 MiB
[ 22.056008] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 22.056833] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8008ce2730)
[ 22.057614] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 22.058353] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8008ce2730)
[ 22.059484] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 22.060117] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 22.060901] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 22.063312] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffffff8008cd6f88)
[ 22.064604] i2c i2c-10: of_i2c: modalias failure on /dp@fec00000/ports
[ 22.065540] rockchip-drm display-subsystem: bound fec00000.dp (ops 0xffffff8008cd7fb8)
[ 22.066257] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 22.066852] [drm] No driver support for vblank timestamp query.
[ 22.067620] rockchip-drm display-subsystem: connector[HDMI-A-1] can’t found any modes
[ 22.068340] rockchip-drm display-subsystem: can’t not find any loader display
[ 22.069009] rockchip-drm display-subsystem: failed to show loader logo
[ 22.069759] Freeing drm_logo memory: 616K
[ 22.070135] rockchip-drm display-subsystem: No connectors reported connected with modes
[ 22.070861] [drm] Cannot find any crtc or sizes - going 1024x768
[ 22.079080] Console: switching to colour frame buffer device 128x48
[ 22.083744] rockchip-drm display-subsystem: fb0: frame buffer device
[ 22.089741] mali ff9a0000.gpu: leakage=29
[ 22.103040] mali ff9a0000.gpu: temp=36875, pvtm=121780 (122010 + -230)
[ 22.105001] mali ff9a0000.gpu: pvtm-volt-sel=1
[ 22.106717] mali ff9a0000.gpu: avs=0
[ 22.108110] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 22.109394] mali ff9a0000.gpu: Protected mode not available
[ 22.111210] mali ff9a0000.gpu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 22.111999] mali ff9a0000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
[ 22.113277] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 423; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 22.115872] mali ff9a0000.gpu: Probed as mali0
[ 22.121898] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 22.123032] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 1
[ 22.124056] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 22.124987] xhci-hcd xhci-hcd.10.auto: irq 230, io mem 0xfe800000
[ 22.126104] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 22.126753] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 22.127411] usb usb1: Product: xHCI Host Controller
[ 22.127886] usb usb1: Manufacturer: Linux 4.4.194-g50f0a60241aa-dirty xhci-hcd
[ 22.128543] usb usb1: SerialNumber: xhci-hcd.10.auto
[ 22.130322] hub 1-0:1.0: USB hub found
[ 22.130870] hub 1-0:1.0: 1 port detected
[ 22.132262] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 22.133248] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 2
[ 22.134127] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 22.135127] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 22.135776] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 22.136434] usb usb2: Product: xHCI Host Controller
[ 22.136909] usb usb2: Manufacturer: Linux 4.4.194-g50f0a60241aa-dirty xhci-hcd
[ 22.137566] usb usb2: SerialNumber: xhci-hcd.10.auto
[ 22.139874] hub 2-0:1.0: USB hub found
[ 22.140313] hub 2-0:1.0: 1 port detected
[ 22.143986] xhci-hcd xhci-hcd.10.auto: remove, state 1
[ 22.144490] usb usb2: USB disconnect, device number 1
[ 22.162228] xhci-hcd xhci-hcd.10.auto: Host not halted after 16000 microseconds.
[ 22.162672] dwmmc_rockchip fe320000.dwmmc: Unexpected interrupt latency
[ 22.163484] xhci-hcd xhci-hcd.10.auto: Host controller not halted, aborting reset.
[ 22.164259] xhci-hcd xhci-hcd.10.auto: USB bus 2 deregistered
[ 22.166835] xhci-hcd xhci-hcd.10.auto: remove, state 1
[ 22.167318] usb usb1: USB disconnect, device number 1
[ 22.168871] xhci-hcd xhci-hcd.10.auto: USB bus 1 deregistered
[ 22.170166] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 22.170924] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 1
[ 22.171756] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 22.172569] xhci-hcd xhci-hcd.11.auto: irq 231, io mem 0xfe900000
[ 22.173370] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 22.173997] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 22.174644] usb usb1: Product: xHCI Host Controller
[ 22.175085] usb usb1: Manufacturer: Linux 4.4.194-g50f0a60241aa-dirty xhci-hcd
[ 22.175731] usb usb1: SerialNumber: xhci-hcd.11.auto
[ 22.176788] hub 1-0:1.0: USB hub found
[ 22.177153] hub 1-0:1.0: 1 port detected
[ 22.177803] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 22.178545] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 2
[ 22.179345] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 22.180176] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 22.180790] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 22.181425] usb usb2: Product: xHCI Host Controller
[ 22.181886] usb usb2: Manufacturer: Linux 4.4.194-g50f0a60241aa-dirty xhci-hcd
[ 22.182521] usb usb2: SerialNumber: xhci-hcd.11.auto
[ 22.183618] hub 2-0:1.0: USB hub found
[ 22.183982] hub 2-0:1.0: 1 port detected
[ 22.184905] xhci-hcd xhci-hcd.11.auto: remove, state 1
[ 22.185382] usb usb2: USB disconnect, device number 1
[ 22.186607] xhci-hcd xhci-hcd.11.auto: USB bus 2 deregistered
[ 22.187359] xhci-hcd xhci-hcd.11.auto: remove, state 1
[ 22.187847] usb usb1: USB disconnect, device number 1
[ 22.189025] xhci-hcd xhci-hcd.11.auto: USB bus 1 deregistered
[ 22.192349] ehci-platform fe380000.usb: EHCI Host Controller
[ 22.193150] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[ 22.193974] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 22.199648] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 22.200381] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 22.200997] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 22.201643] usb usb1: Product: EHCI Host Controller
[ 22.202084] usb usb1: Manufacturer: Linux 4.4.194-g50f0a60241aa-dirty ehci_hcd
[ 22.202728] usb usb1: SerialNumber: fe380000.usb
[ 22.203841] hub 1-0:1.0: USB hub found
[ 22.204203] hub 1-0:1.0: 1 port detected
[ 22.208907] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 22.209775] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[ 22.210607] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 22.216784] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 22.217568] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 22.218193] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 22.218837] usb usb2: Product: EHCI Host Controller
[ 22.219297] usb usb2: Manufacturer: Linux 4.4.194-g50f0a60241aa-dirty ehci_hcd
[ 22.219954] usb usb2: SerialNumber: fe3c0000.usb
[ 22.221139] hub 2-0:1.0: USB hub found
[ 22.221502] hub 2-0:1.0: 1 port detected
[ 22.222846] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 22.223821] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[ 22.224683] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 22.233169] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 22.234459] rockchip-iodomain ff770000.syscon:io-domains: Setting to 1800000 done
[ 22.261361] mmc_host mmc0: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0)
[ 22.280197] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 22.280848] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 22.281507] usb usb3: Product: Generic Platform OHCI controller
[ 22.282074] usb usb3: Manufacturer: Linux 4.4.194-g50f0a60241aa-dirty ohci_hcd
[ 22.282753] usb usb3: SerialNumber: fe3a0000.usb
[ 22.284834] hub 3-0:1.0: USB hub found
[ 22.285248] hub 3-0:1.0: 1 port detected
[ 22.287569] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 22.289251] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[ 22.290196] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 22.346081] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 22.346729] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 22.347389] usb usb4: Product: Generic Platform OHCI controller
[ 22.347957] usb usb4: Manufacturer: Linux 4.4.194-g50f0a60241aa-dirty ohci_hcd
[ 22.348637] usb usb4: SerialNumber: fe3e0000.usb
[ 22.350539] hub 4-0:1.0: USB hub found
[ 22.351022] hub 4-0:1.0: 1 port detected
[ 22.353108] input: adc-keys as /devices/platform/adc-keys/input/input3
[ 22.356689] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 22.357397] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 22.358056] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 22.358649] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 22.359770] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 22.360333] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 22.361737] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 22.375735] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 22.389321] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 22.392489] asoc-simple-card hdmi-sound: i2s-hifi ↔ ff8a0000.i2s mapping ok
[ 22.395993] rockchip-cdndp-sound dp-sound: spdif-hifi ↔ ff870000.spdif mapping ok
[ 22.396763] hdmi-audio-codec hdmi-audio-codec.9.auto: ASoC: Failed to create Playback debugfs file
[ 22.398516] input: rockchip-cdndp-sound DP Jack as /devices/platform/dp-sound/sound/card1/input4
[ 22.402033] input: gpio-keys as /devices/platform/gpio-keys/input/input5
[ 22.403478] ==gsl_ts_init==
[ 22.403912] ret=0
[ 22.406028] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:55 UTC (1358499055)
[ 22.434287] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 22.436483] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 22.438637] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 22.442097] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 22.446143] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
[ 22.449468] vcc_mipi: disabling
[ 22.449796] dvdd_1v2: disabling
[ 22.500419] mmc_host mmc2: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 22.513538] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0.
[ 22.517745] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 22.518288] mmc2: new ultra high speed SDR104 SDIO card at address 0001
[ 22.523751] usb 2-1: new high-speed USB device number 2 using ehci-platform
[ 22.536880] vendor storage:20190527 ret = 0
[ 22.587896] dwmmc_rockchip fe320000.dwmmc: Successfully tuned phase to 231
[ 22.588561] mmc0: new ultra high speed SDR104 SDXC card at address aaaa
[ 22.591062] mmcblk0: mmc0:aaaa SD64G 59.5 GiB
[ 22.609902] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
[ 22.640549] usb 2-1: New USB device found, idVendor=1a40, idProduct=0201
[ 22.641233] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 22.641906] usb 2-1: Product: USB 2.0 Hub [MTT]
[ 22.643883] hub 2-1:1.0: USB hub found
[ 22.644460] hub 2-1:1.0: 7 ports detected
[ 23.449911] rk3x-i2c ff160000.i2c: timeout, ipd: 0x00, state: 1
[ 23.454755] ret 1024
[ 23.456539] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, built at ‘14:42:19’, on ‘May 11 2021’.
[ 23.459360] Mali: Mali device driver loaded
[ 23.460317] rkisp1 ff910000.rkisp1: clear unready subdev num: 1
[ 23.462969] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 23.463542] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 23.464172] rkisp1: update sensor failed
[ 23.464552] rkisp1 ff920000.rkisp1: clear unready subdev num: 1
[ 23.466827] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 23.467400] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 23.468030] rkisp1: update sensor failed
[ 23.469907] ALSA device list:
[ 23.470192] #0: rockchip,hdmi
[ 23.470484] #1: rockchip-cdndp-sound
[ 23.472015] Freeing unused kernel memory: 1152K
Loading, please wait…
/dev/console is Ok
starting version 237
Begin: Loading essential drivers … done.
Begin: Running /scripts/init-premount … done.
Begin: Running /scripts/local-premount … done.
Warning: fsck not present, so skipping root file system
[ 24.856163] EXT4-fs (mmcblk0p7): INFO: recovery required on readonly filesystem
[ 24.856866] EXT4-fs (mmcblk0p7): write access will be enabled during recovery
[ 24.861957] EXT4-fs (mmcblk0p7): recovery complete
[ 24.891933] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
done.
Begin: Running /scripts/local-bottom … done.
Begin: Running /scripts/init-bottom … Warning: overlayroot: configuring overlayroot with driver=overlay mode=device opts=‘dev=PARTLABEL=userdata,fstype=ext4,mkfs=1’ per kernel cmdline
[ 25.175591] EXT4-fs (mmcblk0p8): recovery complete
[ 25.177206] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: (null)
Success: overlayroot: configured root with ‘device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1’ using overlay per kernel cmdline
Warning: Something odd, no /lib/modules/4.4.194-g50f0a60241aa-dirty in initramfs.
done.
[ 25.510380] random: nonblocking pool is initialized
[ 25.746092] systemd[1]: System time before build time, advancing clock.
[ 25.753786] cgroup: cgroup2: unknown option “nsdelegate”
[ 25.772838] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 25.776274] systemd[1]: Detected architecture arm64.
Welcome to Ubuntu 18.04.4 LTS!
[ 25.793645] systemd[1]: Set hostname to .
[ 26.078480] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 26.080073] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 26.473701] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 26.479294] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 26.480908] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 26.487198] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 26.488785] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 26.489895] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 26.503304] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 26.517282] systemd[1]: Mounting POSIX Message Queue File System…
[ 26.518301] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 26.599168] systemd[1]: Starting Create Static Device Nodes in /dev…
[ 26.609386] systemd[1]: Starting udev Coldplug all Devices…
[ 26.611870] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 26.612769] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 26.613794] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 26.650809] systemd[1]: Starting Set the console keyboard layout…
[ 26.652517] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 26.713832] systemd[1]: Starting Load Kernel Modules…
[ 26.735059] systemd[1]: Reached target User and Group Name Lookups.
[ OK ] Reached target User and Group Name Lookups.
[ 26.736664] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 26.740831] systemd[1]: Starting Journal Service…
[ 26.741913] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 26.747016] systemd[1]: Mounting Kernel Debug File System…
[ 26.754071] systemd[1]: Started Remount Root and Kernel File Systems.
[ OK ] Started Remount Root and Kernel File Systems.
[ 26.757868] systemd[1]: Mounted POSIX Message Queue File System.
[ OK ] Mounted POSIX Message Queue File System.
[ 26.760995] systemd[1]: Started Create Static Device Nodes in /dev.
[ OK ] Started Create Static Device Nodes in /dev.
[ 26.764872] systemd[1]: Mounted Kernel Debug File System.
[ OK ] Mounted Kernel Debug File System.
[ 26.770457] systemd[1]: Started Load Kernel Modules.
[ OK ] Started Load Kernel Modules.
[ 26.774881] systemd[1]: Starting Apply Kernel Variables…
[ 26.780151] systemd[1]: Mounting FUSE Control File System…
[ 26.787439] systemd[1]: Mounting Kernel Configuration File System…
[ 26.793073] systemd[1]: Starting Load/Save Random Seed…
Starting udev Kernel Device Manager…
[ OK ] Started Apply Kernel Variables.
[ OK ] Mounted FUSE Control File System.
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Load/Save Random Seed.
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Set the console keyboard layout.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Reached target Local Encrypted Volumes.
[ OK ] Reached target Local File Systems (Pre).
[ OK ] Reached target Local File Systems.
Starting Tell Plymouth To Write Out Runtime Data…
Starting Set console font and keymap…
[ OK ] Started Tell Plymouth To Write Out Runtime Data.
[ OK ] Started Set console font and keymap.
[ OK ] Reached target Sound Card.
[ OK ] Created slice system-systemd\x2dbacklight.slice.
Starting Load/Save Screen Backlight…ightness of backlight:backlight…
[ OK ] Started Load/Save Screen Backlight Brightness of backlight:backlight.
[ OK ] Started Journal Service.
Starting Flush Journal to Persistent Storage…
[ OK ] Started Flush Journal to Persistent Storage.
Starting Create Volatile Files and Directories…
[ OK ] Started Create Volatile Files and Directories.
Starting Network Name Resolution…
Starting Network Time Synchronization…
Starting Update UTMP about System Boot/Shutdown…
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Network Name Resolution.
[ OK ] Reached target Host and Network Name Lookups.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Initialization.
Starting Docker Socket for the API.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Reached target Paths.
[ OK ] Reached target System Time Synchronized.
[ OK ] Started Daily apt download activities.
[ OK ] Started Daily apt upgrade and clean activities.
[ OK ] Started Discard unused blocks once a week.
[ OK ] Reached target Timers.
[ OK ] Listening on Docker Socket for the API.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting System Logging Service…
Starting LSB: automatic crash report generation…
Starting Login Service…
Starting Modem Manager…
[ OK ] Started Regular background program processing daemon.
Starting Disk Manager…
Starting Accounts Service…
Starting rkisp 3A engine…
Starting Adbd for linux…
[ OK ] Started D-Bus System Message Bus.
[ OK ] Started Login Service.
Starting Avahi mDNS/DNS-SD Stack…
Starting Dispatcher daemon for systemd-networkd…
Starting Save/Restore Sound Card State…
[ OK ] Started Set the CPU Frequency Scaling governor.
Starting Network Manager…
Starting WPA supplicant…
Starting Restore /etc/resolv.conf i…fore the ppp link was shut down…
[ OK ] Started System Logging Service.
[ OK ] Started rkisp 3A engine.
[ OK ] Found device /dev/ttyFIQ0.
[ OK ] Started Restore /etc/resolv.conf if…before the ppp link was shut down.
[ OK ] Started Save/Restore Sound Card State.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started WPA supplicant.
Starting Authorization Manager…
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ OK ] Started LSB: automatic crash report generation.
[ OK ] Started Authorization Manager.
[ OK ] Started Accounts Service.
[ OK ] Started Modem Manager.
Starting Hostname Service…
[ OK ] Started Hostname Service.
[ OK ] Started Disk Manager.
[ OK ] Started Adbd for linux.
Starting Network Manager Script Dispatcher Service…
[ OK ] Started Network Manager Script Dispatcher Service.
[ OK ] Started Dispatcher daemon for systemd-networkd.
[ OK ] Started Network Manager.
[ OK ] Reached target Network.
Starting OpenBSD Secure Shell server…
Starting Permit User Sessions…
Starting /etc/rc.local Compatibility…
[ OK ] Started Permit User Sessions.
Starting Light Display Manager…
[ OK ] Started /etc/rc.local Compatibility.
Starting Hold until boot process finishes up…
[ OK ] Started Hold until boot process finishes up.
Starting Set console scheme…
[ OK ] Started Serial Getty on ttyFIQ0.
[ OK ] Started Set console scheme.
[ OK ] Created slice system-getty.slice.
[ OK ] Started Getty on tty1.
[ OK ] Reached target Login Prompts.
[ OK ] Started OpenBSD Secure Shell server.
[ OK ] Reached target Multi-User System.
[ OK ] Started Light Display Manager.
[ OK ] Reached target Graphical Interface.
Starting Update UTMP about System Runlevel Changes…
[ OK ] Started Update UTMP about System Runlevel Changes.
Ubuntu 18.04.4 LTS firefly ttyFIQ0
firefly login: root (automatic login)
Last login: Sun Jan 28 23:58:22 CST 2018 on ttyFIQ0
| () __ ___ / | | _
| | | | '/ _ \ || | | | |
| | | | | | __/ | | || |
|| ||_| _|| ||_, |
|__/
Welcome to Ubuntu 18.04.4 LTS (GNU/Linux 4.4.194-g50f0a60241aa-dirty aarch64)
System information as of Sun Jan 28 23:58:23 CST 2018
System load: 0.70 0.16 0.05 Up time: 0 min
