前几天整了摄像头驱动,发现没有报错以后就点开linux下自带的qcamera打算试试,结果还是报错,没法使用。{:4_89:}
以下是log,大神麻烦帮忙看看怎么解决。
QLauncher start "qcamera"
"rkisp1_mainpath"
"rkisp1_selfpath"
Using Wayland-EGL
mpi: mpp version: Without VCS info
mpp_rt: NOT found ion allocator
mpp_rt: found drm allocator
(qcamera:623): GStreamer-CRITICAL **: gst_value_set_fraction_range_full: assertion 'gst_util_fraction_compare (numerator_start, denominator_start, numerator_end, denominator_end) < 0' failed
"rkisp1_mainpath"
"rkisp1_selfpath"
Using Wayland-EGL
xkbcommon: ERROR: couldn't find a Compose file for locale "zh_CN.utf8"
Using the 'xdg-shell-v6' shell integration
Unable to query the parameter info: "Invalid argument"
(qcamera:636): GStreamer-CRITICAL **: gst_value_set_fraction_range_full: assertion 'gst_util_fraction_compare (numerator_start, denominator_start, numerator_end, denominator_end) < 0' failed
CameraBin error: "Internal data stream error."
