rv1126使用buildroot生成的rootfs,启动报错
尝试了两个版本:
  1. 使用buildroot生成的rootfs.img更新后,系统启动报错:
  2. 使用官方提供的rootfs.img文件更新后,系统启动报错;
请教一下,是否有人清楚原因?
报错内容如下:
Bus::Error - Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory
dbserver[3279]: dbserver version 1.0
dbserver[3279]: [dbserver][main]:dbserver init finish
DBus::Error - Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory
storage_manager[899]: [db_monitor.c][db_monitor_init]:dbserver_get_storage_config, wait dbserver.
dbus[3279]: arguments to dbus_connection_get_object_path_data() were incorrect, assertion “connection != NULL” failed in file dbus-connection.c line 5904.
This is normally a bug in some application using the D-Bus library.
D-Bus not built with -rdynamic so unable to print a backtrace
dbserver 缺少文件,请问你烧得哪个固件呢?
https://www.t-firefly.com/doc/download/101.html
这个链接里的固件,只是更新了rootfs
cat /proc/verison;
cat /proc/device-tree/model;看一看 log
板蓝根 发表于 2021-6-7 11:02
cat /proc/verison;
串口上不停的刷这个,系统根本进不去{:5_241:}
那把 串口log 发我一下
板蓝根 发表于 2021-6-7 11:45
那把 串口log 发我一下
我贴在一楼的就是串口输出的log,一直重复刷这些信息
完整的串口 log, 从启动到开机
板蓝根 发表于 2021-6-7 14:03
完整的串口 log, 从启动到开机
[BEGIN] 2021/6/7 14:22:14
Connecting to COM3…
Connected.
[ 0.375742] ehci-platform ffe00000.usb: USB 2.0 started, EHCI 1.00
[ 0.376077] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.376112] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.376138] usb usb1: Product: EHCI Host Controller
[ 0.376161] usb usb1: Manufacturer: Linux 4.19.111 ehci_hcd
[ 0.376184] usb usb1: SerialNumber: ffe00000.usb
[ 0.377055] hub 1-0:1.0: USB hub found
[ 0.377141] hub 1-0:1.0: 1 port detected
[ 0.377911] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.377969] ohci-platform: OHCI generic platform driver
[ 0.378626] ohci-platform ffe10000.usb: Generic Platform OHCI controller
[ 0.378695] ohci-platform ffe10000.usb: new USB bus registered, assigned bus number 2
[ 0.378923] ohci-platform ffe10000.usb: irq 68, io mem 0xffe10000
[ 0.436671] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[ 0.436721] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.436742] usb usb2: Product: Generic Platform OHCI controller
[ 0.436783] usb usb2: Manufacturer: Linux 4.19.111 ohci_hcd
[ 0.436808] usb usb2: SerialNumber: ffe10000.usb
[ 0.437621] hub 2-0:1.0: USB hub found
[ 0.437700] hub 2-0:1.0: 1 port detected
[ 0.439512] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 0.439585] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 3
[ 0.439858] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000001002010010
[ 0.439965] xhci-hcd xhci-hcd.0.auto: irq 79, io mem 0xffd00000
[ 0.440446] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.440482] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.440508] usb usb3: Product: xÿr·ll˷񮋛k
[ 0.460950] DCDC_REG4: supplied by vcc5v0_sys
[ 0.461474] DCDC_REG5: supplied by vcc5v0_sys
[ 0.462097] LDO_REG1: supplied by vcc_buck5
[ 0.462777] LDO_REG2: supplied by vcc_buck5
[ 0.463305] LDO_REG3: supplied by vcc_buck5
[ 0.463805] LDO_REG4: supplied by vcc_buck5
[ 0.464296] LDO_REG5: supplied by vcc_buck5
[ 0.464809] LDO_REG6: supplied by vcc_buck5
[ 0.464901] vcc_dvdd: Bringing 1100000uV into 1200000-1200000uV
[ 0.465493] LDO_REG7: supplied by vcc5v0_sys
[ 0.466083] LDO_REG8: supplied by vcc5v0_sys
[ 0.466744] LDO_REG9: supplied by vcc5v0_sys
[ 0.467350] SWITCH_REG1: supplied by vcc5v0_sys
[ 0.467814] SWITCH_REG2: supplied by vcc3v3_sys
[ 0.470107] input: rk805 pwrkey as /devices/platform/ff3f0000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input0
[ 0.473068] rk808-rtc rk808-rtc: registered as rtc0
[ 0.473672] rk808-rtc rk808-rtc: setting system clock to 2017-08-04 09:00:03 UTC (1501837203)
tۃk
[ 0.487321] rkisp᙮|&[KFK3+f+K{sцf䅆䄖
[ 0.487566] rkisp rkisp-vir0: No memory-region-thunderboot specified
[ 0.487851] rkisp rkisp-vir0: Enti󭳩ty rkisp-isp-subdev was not 隳Ӗ{kF{k
Ksцŋs[+#6{s«k+F{&+;«c
£{sF
՛ 0.497012] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.11
[ 0.500291] rockchip-thermal ff5f0000.tsadc: tsadc trimmed value = -1
[ 0.500690] rockchip-thermal ff5f0000.tsadc: tsadc is probed successfully!
[ 0.501169] rockchip-thermal ff5f8000.tsadc: tsadc trimmed value = -3
[ 0.501427] rockchip-thermal ff5f8000.tsadc: tsadc is probed successfully!
[ 0.502458] Bluetooth: HCI UART driver ver 2.3
[ 0.502498] Bluetooth: HCI UART protocol H4 registered
[ 0.502852] cpu cpu0: bin=0
[ 0.502910] cpu cpu0: leakage=1.750
[ 0.503055] cpu cpu0: Linked as a consumer to regulator.9
[ 0.514743] cpu cpu0: temp=50400, pvtm=99066 (98897 + 169)
[ 0.514886] cpu cpu0: pvtm-volt-sel=1
[ 0.514992] cpu cpu0: Dropping the link to regulator.9
[ 0.515066] cpu cpu0: bin-scale=5
[ 0.515523] cpu cpu0: Linked as a consumer to regulator.9
[ 0.515608] cpu cpu0: Dropping the link to regulator.9
[ 0.515914] cpu cpu0: Linked as a consumer to regulator.9
[ 0.517117] cpu cpu0: avs=0
[ 0.517603] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 0.517650] cpu cpu0: failed to read out thermal zone (-22)
[ 0.518493] cpu cpu0: failed to find power_model node
[ 0.518578] cpuidle: enable-method property ‘psci’ found operations
[ 0.518668] cpuidle: enable-method property ‘psci’ found operations
[ 0.518744] cpuidle: enable-method property ‘psci’ found operations
[ 0.518809] cpuidle: enable-method property ‘psci’ found operations
[ 0.519586] Synopsys Designware Multimedia Card Interface Driver
[ 0.520113] dwmmc_rockchip ffc50000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.520163] dwmmc_rockchip ffc50000.dwmmc: Using internal DMA controller.
[ 0.520181] dwmmc_rockchip ffc50000.dwmmc: Version ID is 270a
[ 0.520233] dwmmc_rockchip ffc50000.dwmmc: DW MMC controller at irq 62,32 bit host data width,256 deep fifo
[ 0.520359] mmc_host mmc0: card is non-removable.
[ 0.546004] dwmmc_rockchip ffc60000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.546077] dwmmc_rockchip ffc60000.dwmmc: Using internal DMA controller.
[ 0.546091] dwmmc_rockchip ffc60000.dwmmc: Version ID is 270a
[ 0.546144] dwmmc_rockchip ffc60000.dwmmc: DW MMC controller at irq 63,32 bit host data width,256 deep fifo
[ 0.546272] dwmmc_rockchip ffc60000.dwmmc: Linked as a consumer to regulator.20
[ 0.559129] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.572638] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.572732] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[ 0.572746] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[ 0.572847] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 64,32 bit host data width,256 deep fifo
[ 0.572990] dwmmc_rockchip ffc70000.dwmmc: allocated mmc-pwrseq
[ 0.573004] mmc_host mmc1: card is non-removable.
[ 0.576163] mmc_host mmc0: Bus speed (slot 0) = 198000000Hz (slot req 200000000Hz, actual 198000000HZ div = 0)
[ 0.576201] dwmmc_rockchip ffc50000.dwmmc: Successfully tuned phase to 90
[ 0.576306] mmc0: new HS200 MMC card at address 0001
[ 0.577640] mmcblk0: mmc0:0001 8GTF4R 7.28 GiB
[ 0.578337] mmcblk0boot0: mmc0:0001 8GTF4R partition 1 4.00 MiB
[ 0.579141] mmcblk0boot1: mmc0:0001 8GTF4R partition 2 4.00 MiB
[ 0.579971] mmcblk0rpmb: mmc0:0001 8GTF4R partition 3 512 KiB, chardev (241:0)
[ 0.585762] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.587360] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
[ 0.599435] usbcore: registered new interface driver usbkbd
[ 0.599497] usbcore: registered new interface driver usbmouse
[ 0.600599] rockchip-saradc ff5e0000.saradc: Linked as a consumer to regulator.16
[ 0.601351] rksfc_base v1.1 2016-01-08
[ 0.601733] rksfc ffc90000.sfc: rksfc_probe clk rate = 79200000
[ 0.601792] rkflash_dev_init enter
[ 0.601811] sfc nor id: 0 0 0
[ 0.601821] rkflash[1] is invalid
[ 0.601823] rkflash_dev_init enter
[ 0.601845] sfc_nand id: 0 0 0
[ 0.601853] rkflash[2] is invalid
[ 0.605556] rk817-codec rk817-codec: DMA mask not set
[ 0.605759] rk817_codec_parse_dt_property: rk809 have no io-channels defined
[ 0.609045] NET: Registered protocol family 17
[ 0.609140] NET: Registered protocol family 15
[ 0.609543] Bluetooth: RFCOMM TTY layer initialized
[ 0.609588] Bluetooth: RFCOMM socket layer initialized
[ 0.609619] Bluetooth: RFCOMM ver 1.11
[ 0.609635] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 0.609648] Bluetooth: HIDP socket layer initialized
[ 0.609658] [BT_RFKILL]: Enter rfkill_rk_init
[ 0.609667] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 0.609931] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 0.609973] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6236
[ 0.609983] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 0.609993] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 0.610046] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 8, flags = 0.
[ 0.610079] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 0.610091] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 0.610419] [BT_RFKILL]: bluetooth_platdata_parse_dt: get pr[ 0.647991] mpp_rkvenc ffbb0000.rkvenc: probing start
[ 0.648476] mpp_rkvenc ffbb0000.rkvenc: Linked as a consumer to regulator.8
[ 0.648518] mpp_rkvenc ffbb0000.rkvenc: bin=0
[ 0.648541] mpp_rkvenc ffbb0000.rkvenc: leakage=1.375
[ 0.648585] mpp_rkvenc ffbb0000.rkvenc: Failed to get pvtm
[ 0.648610] mpp_rkvenc ffbb0000.rkvenc: bin-scale=37
[ 0.648882] mpp_rkvenc ffbb0000.rkvenc: avs=0
[ 0.649140] mpp_rkvenc ffbb0000.rkvenc: failed to find power_model node
[ 0.649159] mpp_rkvenc ffbb0000.rkvenc: failed to initialize power model
[ 0.649299] mpp_rkvenc ffbb0000.rkvenc: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 0.649323] mpp_rkvenc ffbb0000.rkvenc: failed to read out thermal zone (-22)
[ 0.649834] mpp_rkvenc ffbb0000.rkvenc: probing finish
[ 0.651700] rockchip-drm display-subsystem: devfreq is not set
[ 0.651968] rockchip-drm display-subsystem: bound ffb00000.vop (ops 0xb0a3dec0)
[ 0.652017] rockchip-drm display-subsystem: bound ffb30000.dsi (ops 0xb0a445ec)
[ 0.652032] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.652041] [drm] No driver support for vblank timestamp query.
[ 0.658598] [drm] Initialized rockchip 2.0.0 20140818 for display-subsystem on minor 0
[ 0.659082] input: adc-keys as /devices/platform/adc-keys/input/inpÿ[ 0.858109] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=88.32
[ 0.858187] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 0.858216] usb 1-1: Product: USB2.0 Hub
[ 0.975946] wifi_platform_bus_enumerate device present 1
[ 0.976003] ======== Card detection to detect SDIO card! ========
[ 0.976027] mmc1:mmc host rescan start!
[ 0.992656] bcmsdh_register: register client driver
[ 0.995190] bcmsdh_sdmmc_probe: Enter num=1
[ 0.995711] bcmsdh_sdmmc_probe: Enter num=2
[ 0.995753] bus num (host idx)=1, slot num (rca)=1
[ 0.995784] found adapter info ‘DHD generic adapter’
[ 0.995886] sdioh_attach: set sd_f2_blocksize 256
[ 0.995960] sdioh_attach: sd clock rate = 0
[ 0.996310] dhdsdio_probe : no mutex held. set lock
[ 0.996335] ircut cam_ircut: driver version: 00.01.00
[ 0.996500] F1 signature read @0x18000000=0x1542a9a6
[ 0.998126] ircut cam_ircut: failed get pulse-width,use dafult value 100
[ 0.998283] ircut cam_ircut: Failed to get ircut-open-gpios
[ 1.001287] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x2 pkg:0x4
[ 1.003257] DHD: dongle ram size is set to 524288(orig 524288) at 0x0
[ 1.003428] [dhd] dhd_conf_set_chiprev : chip=0xa9a6, chiprev=2
[ 1.003606] [dhd] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 1.003929] [dhd] CFG80211-ERROR) wl_setup_wiphy : SAE support
[ 1.004486] [dhd] CFG80211-ERROR) wl_init_prof : wl_init_prof: No profile
[ 1.006227] dhd_attach(): thread:dhd_watchdog_thread:5d started
[ 1.007064] dhd_attach(): thread:dhd_dpc:5e started
[ 1.007983] dhd_attach(): thread:dhd_rxf:5f started
[ 1.008018] dhd_deferred_work_init: work queue initialized
[ 1.008033] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 → mode 2
[ 1.008103] dhd_bus_set_default_min_res_mask: Unhandled chip id
[ 1.011823] sdioh_cis_read: func_cis_ptr[0]=0x1070
[ 1.054294] Dongle Host Driver, version 1.579.77.41.22 (r-20191105-2)(20191120-1)
[ 1.054834] Register interface [wlan0] MAC: d4:9c:dd:75:34:7e
[ 1.054834]
[ 1.054903] dhd_tcpack_suppress_set: TCP ACK Suppress mode 2 → mode 0
[ 1.054931] dhd_wl_ioctl: returning as busstate=0
[ 1.054946] dhd_dbg_detach_pkt_monitor, 2204
[ 1.054959] dhd_bus_devreset: == Power OFF ==
[ 1.055217] bcmsdh_oob_intr_unregister: Enter
[ 1.055234] bcmsdh_oob_intr_unregister: irq is not registered
[ 1.055253] dhd_txglom_enable: enable 0
[ 1.055266] dhd_bus_devreset: WLAN OFF DONE
[ 1.055322] wifi_platform_set_power = 0
[ 1.055338] ======== PULL WL_REG_ON(-1) LOW! ========
[ 1.055351] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 1.055371] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 1.055383] dhdsdio_probe : the lock is released.
[ 1.055968] ircut cam_ircut: driver version: 00.01.00
[ 1.056212] dhd_module_init: Exit err=0
[ 1.056466] ircut cam_ircut: failed get pulse-width,use dafult value 100
[ 1.056548] ircut cam_ircut: Failed to get ircut-open-gpios
[ 1.149297] usb 1-1.3: new high-speed USB device number 3 using ehci-platform
[ 1.258243] usb 1-1.3: New USB device found, idVendor=0bda, idProduct=8152, bcdDevice=20.00
[ 1.258316] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.258336] usb 1-1.3: Product: USB 10/100 LAN
[ 1.258354] usb 1-1.3: Manufacturer: Realtek
[ 1.258372] usb 1-1.3: SerialNumber: 00E04C7D6DF8
[ 1.264461] ircut cam_ircut: driver version: 00.01.00
[ 1.264821] ircut cam_ircut: failed get pulse-width,use dafult value 100
[ 1.264928] ircut cam_ircut: Failed to get ircut-open-gpios
[ 1.346025] usb 1-1.3: reset high-speed USB device number 3 using ehci-platform
[ 1.543921] r8152 1-1.3:1.0 eth1: v2.12.0 (2019/04/29)
[ 1.543996] r8152 1-1.3:1.0 eth1: This product is covered by one or more of the following patents:
[ 1.543996] US6,570,884, US6,115,776, and US6,327,625.
[ 1.543996]
[ 1.545243] ircut cam_ircut: driver version: 00.01.00
[ 1.545749] ircut cam_ircut: failed get pulse-width,use dafult value 100
[ 1.545903] ircut cam_ircut: Failed to get ircut-open-gpios
[ 1.599285] gsl_ts_probe–1377, i2c_master_recv fail
[ 1.599532] ret=0
[ 1.601370] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 1.618655] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 1.619149] rkcif rkcif_mipi_lvds: clear unready subdev num: 1
[ 1.619440] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 1.619464] cfg80211: failed to load regulatory.db
[ 1.619977] rkcif_mipi_lvds: Async subdev notifier completed
[ 1.620028] rkisp rkisp-vir0: clear unready subdev num: 1
[ 1.621372] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 1.621404] rkisp0: update sensor failed
[ 1.622800] dwmmc_rockchip ffc50000.dwmmc: Successfully tuned phase to 270
[ 1.624315] dwmmc_rockchip ffc50000.dwmmc: Successfully tuned phase to 90
[ 1.624781] ret 1024 0
[ 1.625446] ALSA device list:
[ 1.625490] #0: rockchip,rk809-codec
[ 1.625504] #7: Loopback 1
[ 1.627442] Freeing unused kernel memory: 1024K
[ 1.627766] Run /init as init process
Loading, please wait…
Couldn’t get a file descriptor referring to the console
starting version 237
/scripts/init-top/console_setup: line 134: can’t create /dev/tty1: No such device or address
/scripts/init-top/console_setup: line 1: can’t open /dev/tty1: No such device or address
/scripts/init-top/console_setup: line 1: can’t create /dev/tty2: No such device or address
/scripts/init-top/console_setup: line 1: can’t open /dev/tty2: No such device or address
/scripts/init-top/console_setup: line 1: can’t create /dev/tty3: No such device or address
/scripts/init-top/console_setup: line 1: can’t open /dev/tty3: No such device or address
/scripts/init-top/console_setup: line 1: can’t create /dev/tty4: No such device or address
/scripts/init-top/console_setup: line 1: can’t open /dev/tty4: No such device or address
/scripts/init-top/console_setup: line 1: can’t create /dev/tty5: No such device or address
/scripts/init-top/console_setup: line 1: can’t open /dev/tty5: No such device or address
/scripts/init-top/console_setup: line 1: can’t create /dev/tty6: No such device or address
/scripts/init-top/console_setup: line 1: can’t open /dev/tty6: No such device or address
Begin: Loading essential drivers … done.
Begin: Running /scripts/init-premount … done.
Begin: Running /scripts/local-premount … done.
Warning: fsck not present, so skipping root file system
[ 4.178960] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
done.
Begin: Running /scripts/local-bottom … done.
Begin: Running /scripts/init-bottom … Warning: overlayroot: configuring overlayroot with driver=overlay mode=device opts=‘dev=PARTLABEL=userdata,fstype=ext4,mkfs=1’ per kernel cmdline
[ 4.338516] EXT4-fs (mmcblk0p8): warning: mounting unchecked fs, running e2fsck is recommended
[ 4.342280] EXT4-fs (mmcblk0p8): mounted filesystem without journal. Opts: (null)
[[: missing ]]
ln: /root/var/lib/docker: File exists
Success: overlayroot: configured root with ‘device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1’ using overlay per kernel cmdline
Warning: Something odd, no /lib/modules/4.19.111 in initramfs.
done.
mount: mounting proc on /proc failed: Device or resource busy
NAME=Buildroot
VERSION=2018.02-rc3-g1e7d09e-dirty
ID=buildroot
VERSION_ID=2018.02-rc3
PRETTY_NAME=“Buildroot 2018.02-rc3”
Starting logging: OK
chown: invalid user: ‘avahi.avahi’
/usr/bin/modetest
Populating /dev using udev: [ 4.716073] udevd[429]: starting version 3.2.7
[ 4.750894] udevd[430]: starting eudev-3.2.7
[ 4.882976] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 4.883089] stream_cif_mipi_id1: update sensor info failed -19
[ 4.883408] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 4.883466] stream_cif_mipi_id0: update sensor info failed -19
[ 4.892831] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 4.892890] stream_cif_mipi_id3: update sensor info failed -19
[ 4.904479] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 4.917163] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 4.917237] stream_cif_mipi_id2: update sensor info failed -19
done
Initializing random number generator… done.
Will now mount all partitions in /etc/fstab
Note: Create /.skip_fsck to skip fsck
  • The check might take a while if didn’t shutdown properly!
    Handling misc: /dev/mmcblk0p2 /misc emmc defaults 0
    Unsupported file system emmc for /dev/mmcblk0p2
    Handling oem: /dev/mmcblk0p7 /oem ext2 defaults 2
    Checking /dev/mmcblk0p7(ext2)
    e2fsck 1.43.9 (8-Feb-2018)
    oem: recovering journal
    oem: clean, 392/48000 files, 165813/196608 blocks
    Mounting /dev/mmcblk0p7(ext2) on /oem
    [ 5.685471] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
    Handling userdata: /dev/mmcblk0p8 /userdata ext2 defaults 2
    Checking /dev/mmcblk0p8(ext2)
    /dev/mmcblk0p8 is in use.
    e2fsck: Cannot continue, aborting.
Mounting /dev/mmcblk0p8(ext2) on /userdata
Log saved to /tmp/mountall.log
1+0 records in
1+0 records out
100 bytes copied, 0.00111038 s, 90.1 kB/s
Starting system message bus: dbus[750]: Unknown username “avahi” in message bus configuration file
dbus-daemon[750]: Failed to start message bus: Could not get UID and GID for username “dbus”
done
Starting connman … done.
[ 9.456594] EXT4-fs error (device mmcblk0p8): ext4_mb_generate_buddy:747: group 0, block bitmap and bg descriptor inconsistent: 7771 vs 7783 free clusters
Timeout reached while wating for return value
Could not receive return value from daemon process.
Starting dropbear sshd: OK
Starting fcgiwrap daemon: OK
Starting nginx…
Debug: configfs_init
[ 26.333732] file system registered
mkdir: cannot create directory ‘/sys/kernel/config/usb_gadget/rockchip/functions/mtp.gs0’: No such file or directory
[ 26.360986] using random self ethernet address
[ 26.361041] using random host ethernet address
mkdir: cannot create directory ‘/sys/kernel/config/usb_gadget/rockchip/functions/acm.gs6’: No such file or directory
[ 26.379742] Mass Storage Function, version: 2009/09/11
[ 26.379813] LUN: removable file: (no medium)
mkdir: cannot create directory ‘/sys/kernel/config/usb_gadget/rockchip/functions/hid.usb0’: No such file or directory
sh: write error: No such device
insmod NPU modules: [ 27.549843] galcore: loading out-of-tree module taints kernel.
[ 27.557614] galcore: npu init.
[ 27.558383] galcore: start npu probe.
[ 27.558511] galcore ffbc0000.npu: Linked as a consumer to regulator.8
[ 27.558690] npu: platform_get_irq irq = 66
[ 27.558706] npu: platform_get_resource registerMemBase = ffbc0000, registerMemSize = 4000
[ 27.558720] Galcore version 6.4.3.5.293908
[ 27.558729] Galcore options:
[ 27.558739] irqLine = 66
[ 27.558748] registerMemBase = 0xFFBC0000
[ 27.558758] registerMemSize = 0x00004000
[ 27.558768] contiguousSize = 0x00400000
[ 27.558777] contiguousBase = 0x0
[ 27.558787] externalSize = 0x00000000
[ 27.558796] externalBase = 0x0
[ 27.558805] exclusiveSize = 0x00000000
[ 27.558815] exclusiveBase = 0x0
[ 27.558824] bankSize = 0x00000000
[ 27.558834] fastClear = -1
[ 27.558843] compression = 15
[ 27.558853] powerManagement = 1
[ 27.558862] baseAddress = 0x00000000
[ 27.558869] physSize = 0x00000000
[ 27.558875] recovery = 1
[ 27.558882] stuckDump = 0
[ 27.558888] gpuProfiler = 1
[ 27.558899] userClusterMask = 0x0
[ 27.558909] GPU smallBatch = 1
[ 27.558918] allMapInOne = 1
[ 27.558927] irqs =
[ 27.558930] 66,
[ 27.558939] -1,
[ 27.558948] -1,
[ 27.558995] -1,
[ 27.559013] -1,
[ 27.559040] -1,
[ 27.559076] -1,
[ 27.559117] -1,
[ 27.559124] -1,
[ 27.559131] -1,
[ 27.559138]
[ 27.559154] registerBases =
[ 27.559157] 0xFFBC0000,
[ 27.559171] 0x00000000,
[ 27.559184] 0x00000000,
[ 27.559199] 0x00000000,
[ 27.559214] 0x00000000,
[ 27.559231] 0x00000000,
[ 27.559245] 0x00000000,
[ 27.559254] 0x00000000,
[ 27.559264] 0x00000000,
[ 27.559273] 0x00000000,
[ 27.559282]
[ 27.559301] registerSizes =
[ 27.559303] 0x00004000,
[ 27.559314] 0x00000000,
[ 27.559323] 0x00000000,
[ 27.559332] 0x00000000,
[ 27.559342] 0x00000000,
[ 27.559351] 0x00000000,
[ 27.559360] 0x00000000,
[ 27.559366] 0x00000000,
[ 27.559372] 0x00000000,
[ 27.559382] 0x00000000,
[ 27.559392]
[ 27.559426] chipIDs =
[ 27.559430] 0xFFFFFFFF,
[ 27.559443] 0xFFFFFFFF,
[ 27.559453] 0xFFFFFFFF,
[ 27.559468] 0xFFFFFFFF,
[ 27.559485] 0xFFFFFFFF,
[ 27.559501] 0xFFFFFFFF,
[ 27.559511] 0xFFFFFFFF,
[ 27.559521] 0xFFFFFFFF,
[ 27.559530] 0xFFFFFFFF,
[ 27.559541] 0xFFFFFFFF,
[ 27.559550]
[ 27.559569] core 0 internal sRAMBases =
[ 27.559571] 0xFFFFFFFFFFFFFFFF,
[ 27.559599] 0xFFFFFFFFFFFFFFFF,
[ 27.559606]
[ 27.559618] core 1 internal sRAMBases =
[ 27.559619] 0xFFFFFFFFFFFFFFFF,
[ 27.559634] 0xFFFFFFFFFFFFFFFF,
[ 27.559643]
[ 27.559658] core 2 internal sRAMBases =
[ 27.559660] 0xFFFFFFFFFFFFFFFF,
[ 27.559669] 0xFFFFFFFFFFFFFFFF,
[ 27.559678]
[ 27.559697] core 3 internal sRAMBases =
[ 27.559699] 0xFFFFFFFFFFFFFFFF,
[ 27.559708] 0xFFFFFFFFFFFFFFFF,
[ 27.559718]
[ 27.559736] core 4 internal sRAMBases =
[ 27.559737] 0xFFFFFFFFFFFFFFFF,
[ 27.559747] 0xFFFFFFFFFFFFFFFF,
[ 27.559756]
[ 27.559774] core 5 internal sRAMBases =
[ 27.559776] 0xFFFFFFFFFFFFFFFF,
[ 27.559786] 0xFFFFFFFFFFFFFFFF,
[ 27.559795]
[ 27.559813] core 6 internal sRAMBases =
[ 27.559815] 0xFFFFFFFFFFFFFFFF,
[ 27.559825] 0xFFFFFFFFFFFFFFFF,
[ 27.559834]
[ 27.559844] core 7 internal sRAMBases =
[ 27.559846] 0xFFFFFFFFFFFFFFFF,
[ 27.559858] 0xFFFFFFFFFFFFFFFF,
[ 27.559868]
[ 27.559886] core 8 internal sRAMBases =
[ 27.559888] 0xFFFFFFFFFFFFFFFF,
[ 27.559898] 0xFFFFFFFFFFFFFFFF,
[ 27.559907]
[ 27.559925] core 9 internal sRAMBases =
[ 27.559927] 0xFFFFFFFFFFFFFFFF,
[ 27.559937] 0xFFFFFFFFFFFFFFFF,
[ 27.559946]
[ 27.559963] External sRAMBases =
[ 27.559966] 0xffffffffffffffff,
[ 27.559975] 0xffffffffffffffff,
[ 27.559984]
[ 27.560015] mmuPageTablePool = 1
[ 27.560031] mmuDynamicMap = 1
[ 27.560045] isrPoll = 0x00000000
[ 27.560061] Build options:
[ 27.560074] gcdGPU_TIMEOUT = 20000
[ 27.560087] gcdGPU_2D_TIMEOUT = 4000
[ 27.560103] gcdINTERRUPT_STATISTIC = 1
[ 27.563116] Galcore Info: ContiguousBase=0x7f950000 ContiguousSize=0x400000
[ 27.568162] Galcore Info: MMU mapped core 0 SRAM[0] hardware virtual address=0x400000 size=0x40000
[ 27.568203] Galcore Info: MMU mapped core 0 SRAM[1] hardware virtual address=0x440000 size=0x40000
[ 27.569427] NN flop resetting…
[ 27.574821] galcore ffbc0000.npu: Init npu devfreq
[ 27.574866] galcore ffbc0000.npu: bin=0
[ 27.574904] galcore ffbc0000.npu: leakage=1.250
[ 27.586842] galcore ffbc0000.npu: temp=49600, pvtm=98810 (98810 + 0)
[ 27.587105] galcore ffbc0000.npu: pvtm-volt-sel=1
[ 27.587163] galOK
core ffbc0000.npu: bin-scale=23
[ 27.588089] galcore ffbc0000.npu: avs=0
[ 27.588716] galcore ffbc0000.npu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 27.588773] galcore ffbc0000.npu: failed to read out thermal zone (-22)
[ 27.588939] galcore ffbc0000.npu: failed to find power_model node
[ 27.589019] galcore ffbc0000.npu: failed to initialize power model
[ 27.594561] ircut cam_ircut: driver version: 00.01.00
[ 27.594906] ircut cam_ircut: failed get pulse-width,use dafult value 100
[ 27.595077] ircut cam_ircut: Failed to get ircut-open-gpios
[ 27.627975] ircut cam_ircut: driver version: 00.01.00
[ 27.628281] ircut cam_ircut: failed get pulse-width,use dafult value 100
[ 27.628334] ircut cam_ircut: Failed to get ircut-open-gpios
[ 27.628628] Generic PHY stmmac-0:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[ 27.629541] rk_gmac-dwmac ffc40000.ethernet: rk_get_eth_addr: mac address: 92:24:55:9e:2c:7e
[ 27.629586] rk_gmac-dwmac ffc40000.ethernet: device MAC address 92:24:55:9e:2c:7e
[ 27.639633] dwmac4: Master AXI performs any burst length
[ 27.639815] rk_gmac-dwmac ffc40000.ethernet eth0: No Safety Features support found
[ 27.639845] rk_gmac-dwmac ffc40000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[ 27.640597] rk_gmac-dwmac ffc40000.ethernet eth0: registered PTP clock
[ 27.649331] ircut cam_ircut: driver version: 00.01.00
[ 27.649630] ircut cam_ircut: failed get pulse-width,use dafult value 100
[ 27.649729] ircut cam_ircut: Failed to get ircut-open-gpios
[ 27.650329] Generic PHY stmmac-0:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[ 27.671084] dwmac4: Master AXI performs any burst length
[ 27.671149] rk_gmac-dwmac ffc40000.ethernet eth0: No Safety Features support found
[ 27.671171] rk_gmac-dwmac ffc40000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[ 27.671384] rk_gmac-dwmac ffc40000.ethernet eth0: registered PTP clock
[ 27.710708] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 27.718626] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 27.726152] rockchip-mipi-dphy-rx: No link between dphy and sensor
net.core.wmem_max = 1572864
dbserver[885]: dbserver version 1.0
dbserver[885]: [dbserver][main]:dbserver init finish
dbus[885]: arguments to dbus_connection_get_object_path_data() were incorrect, assertion “connection != NULL” failed in file dbus-connection.c line 5904.
netserver: /lib/libstdc++.so.6: no version information available (required by /usr/lib/libdbus-c+±1.so.0)
[main.c][main]:The path of nginx.conf is not specified, use the default path
storage_manager: /lib/libstdc++.so.6: no version information available (required by /usr/lib/libdbus-c+±1.so.0)
storage_manager[898]: storage_manager version 1.0
storage_manager[898]: [main.c][main_init]:storage_manager init
storage_manager[898]: [db_monitor.c][db_monitor_init]:dbserver_get_storage_config, wait dbserver.
[ 27.923060] EXT4-fs error (device mmcblk0p8): ext4_mb_generate_buddy:747: group 252, block bitmap and bg descriptor inconsistent: 4132 vs 4164 free clusters
最关键那一段没有截取到呀,我要看出厂固件版本,请进入串口窗口后在掉电上电重启,再截取 log
刚才从官方固件地址下载固件文件后,全部分区做了升级,板子启动串口没有任何输出了。
请问这怎么处理?
正常升级的话串口不会没有输出,请试试能否正常进入升级模式,如果不可以需要进入 Maskrom 模式抢救。
  1. 如果版本比较新的板子,通过短路表面预留的两个焊盘,重新上电就可以进入 Maskrom 重新升级了。如果不行请尝试需要如附件所示位置飞线然后短接地,然后重新上电,就可以进入 Maskrom
  2. 如果上述方法都不行,或者不具备条件,可以寄回检测,如果只是烧错 loader 导致的寄回重新刷出厂固件就可以恢复了
  1. …
升级之前要先擦除flash?这一步是必须的吗?
重来没有说过必须擦除,Maskrom 只是防止设备因为不当操作变砖的最后抢救方法
Starting system message bus: done
Starting network: OK
No state is present for card Loopback
Found hardware: “Loopback” “Loopback Mixer” “” “” “”
Hardware is initialized using a generic method
isp sensor is os04a10,enable HDR
[ 5.798944] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 5.798999] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 5.799020] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 5.799039] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 5.799057] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 5.799092] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 5.799109] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 5.807036] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 5.807104] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 5.807135] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 5.807156] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 5.807174] rockchip-mipi-dphy-rx: No camera_max_width=
camera_malx_height=
[ 5.807225] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 5.807241] rockchip-mipi-dphy-rx: No link between dphy and sensor
insmod NPU modules: [ 5.830263] galcore: loading out-of-tree module taints kernel.
killall: adbd: no process killed
[ 5.838487] galcore: npu init.
[ 5.839624] galcore: start npu probe.
[ 5.839962] galcore ffbc0000.npu: Linked as a consumer to regulator.8
[ 5.840229] npu: platform_get_irq irq = 66
[ 5.840258] npu: platform_get_resource registerMemBase = ffbc0000, registerMemSize = 4000
[ 5.840278] Galcore version 6.4.3.5.293908
[ 5.840286] Galcore options:
[ 5.840292] irqLine = 66
[ 5.840302] registerMemBase = 0xFFBC0000
[ 5.840311] registerMemSize = 0x00004000
[ 5.840321] contiguousSize = 0x00400000
[ 5.840330] contiguousBase = 0x0
[ 5.840339] externalSize = 0x00000000
[ 5.840345] externalBase = 0x0
[ 5.840356] exclusiveSize = 0x00000000
[ 5.840370] exclusiveBase = 0x0
[ 5.840381] bankSize = 0x00000000
[ 5.840401] fastClear = -1
[ 5.840413] compression = 15
[ 5.840421] powerManagement = 1
[ 5.840428] baseAddress = 0x00000000
[ 5.840437] physSize = 0x00000000
[ 5.840446] recovery = 1
[ 5.840455] stuckDump = 0
[ 5.840465] gpuProfiler = 1
[ 5.840472] userClusterMask = 0x0
[ 5.840482] GPU smallBatch = 1
[ 5.840491] allMapInOne = 1
[ 5.840503] irqs =
[ 5.840507] 66,
[ 5.840513] -1,
[ 5.840518] -1,
[ 5.840533] -1,
[ 5.840542] -1,
[ 5.840551] -1,
[ 5.840559] -1,
[ 5.840568] -1,
[ 5.840617] -1,
[ 5.840628] -1,
[ 5.840635]
[ 5.840647]killall: ntpd: no process kil led
registerBases =
[ 5.840648] 0xFFBC0000,
[ 5.840656] 0x00000000,
[ 5.840664] 0x00000000,
[ 5.840671] 0x00000000,
[ 5.840679] 0x00000000,
[ 5.840687] 0x00000000,
[ 5.840694] 0x00000000,
[ 5.840702] 0x00000000,
[ 5.840709] 0x00000000,
[ 5.840717] 0x00000000,
[ 5.840724]
[ 5.840735] registerSizes =
[ 5.840736] 0x00004000,
[ 5.840742] 0x0000dbserver[779]: dbserver versi0on 1.0
000,
[ 5.840747] 0x00000000,
[ 5.840757] 0x00000000,
[ 5.840776] 0x00000000,
[ 5.840786] 0x00000000,
[ 5.840794] 0x00000000,
[ 5.840801] 0x00000000,
[ 5.840809] 0x00000000,
[ 5.840821] 0x00000000,
[ 5.840833]
[ 5.840844] chipIDs =
[ 5.840846] 0xFFFFFFFF,
[ 5.840854] 0xFFFFFFFF,
[ 5.840861] 0xFFFFFFFF,
[ 5.840869] 0xFFFFFFFF,
[ 5.840876] 0xFFFFFFFF,
[ 5.840883] 0xFFFFFFFF,
[ 5.840890] 0xFFFFFFFF,
[ 5.840897] 0xFFFFFFFF,
[ 5.840905] 0xFFFFFFFF,
[ 5.840912] 0xFFFFFFFF,
[ 5.840919]
[ 5.840930] core 0 internal sRAMBases =
[ 5.840932] 0xFFFFFFFFFFFFFFFF,
[ 5.840941] 0xFFFFFFFFFFFFFFFF,
[ 5.840948]
[ 5.840962] core 1 internal sRAMBases =
[ 5.840964] 0xFFFFFFFFFFFFFFFF,
[ 5.840970] 0xFFFFFFFFFFFFFFFF,
[ 5.840975]
[ 5.840988] core 2 internal sRAMBases =
[ 5.840989] 0xFFFFFFFFFFFFFFFF,
[ 5.841003] 0xFFFFFFFFFFFFFFFF,
[ 5.841014]
[ 5.841026] core 3 internal sRAMBases =
[ 5.841028] 0xFFFFFFFFFFFFFFFF,
[ 5.841036] 0xFFFFFFFFFFFFFFFF,
[ 5.841050]
[ 5.841064] core 4 internal sRAMBases =
[ 5.841066] 0xFFFFFFFFFFFFFFFF,
[ 5.841073] 0xFFFFFFFFFFFFFFFF,
[ 5.841080]
[ 5.841091] core 5 internal sRAMBases =
[ 5.841093] 0xFFFFFFFFFFFFFFFF,
[ 5.841100] 0xFFFFFFFFFFFFFFFF,
[ 5.841108]
[ 5.841119] core 6 internal sRAMBases =
[ 5.841120] 0xFFFFFFFFFFFFFFFF,
[ 5.841127] 0xFFFFFFFFFFFFFFFF,
[ 5.841135]
[ 5.841146] core 7 internal sRAMBases =
[ 5.841147] 0xFFFFFFFFkillall: connmand: no processF killed
FFFFFFF,
[ 5.841156] 0xFFFFFFFFFFFFFFFF,
[ 5.841163]
[ 5.841173] core 8 internal sRAMBases =
[ 5.841175] 0xFFFFFFFFFFFFFFFF,
[ 5.841182] 0xFFFFFFFFFFFFFFFF,
[ media get entity by name: rkcif-lvds-subdev is null
media get entity by name: rkcif-lite-lvds-subdev is null
5.841189]
[ 5.84120media get entity by name: rkis0p]- m pcofrbec -9s uibndterv is null
media get entity by name: rkisp_dmapath is null
media get entity by name: rockcnhip-mipi-dphy-rx is null
al sRAMBases =
[ 5.841202] 0xFFFFFFFFFFFFFFFF,
[ 5.841208] 0xFFFFFFFFFFFFFFFF,
[ 5.841213]
[ 5.841225] External sRAMBases =[ispserver][parse_args]:## need_sync_db: 0
get_media_info]:get cam_num 0
[isp
server][rkaiq_get_media_info]:media get sys_path: /dev/media0
media get entity by name: rkisp-isp-subdev is null
media get entity by name: rkisp-[input-params is null
media get entity by name: rkisp-statistics is null
OK
media get entity by name: rkispp_input_params is null
[ispserver][rkaiq_get_media_info]:media get sys_path: /dev/media1
5.841229] 0xffffffffffffffff,
[ 5.841242] 0xfffffffffffffff[ispserver][rkaiq_get_devname]:get rkisp-isp-subdev devnamfe: /dev/v4l-subdev3
[ispserv,er][rkaiq_get_devname]:get rki sp-input-params devname: /dev/video15
cs devname: /dev/video14vname]:get rkisp-statisti
dbs
erver[779]: [dbserver][main]:dbserver init finish
[ 5.841251]
p 5.841263] mmuPageTablePool = media get entity by name: rki1s
p[
i n5p.u8t4_1p2a7r0a]ms is null
[ispserver][rkaiq_ get_media_info]:media get sys_path: /dev/media2
mmuDynamicMap = 1
[ 5.841283] isr[ispserver][rkaiq_get_devname]:get rkispp_input_params devPname: /dev/video23
[ispserver][rkaiq_get_media_info]:media lget sys_path: /dev/media3
l [ispserver][rkaiq_get_media_info]:media get sys_path: /dev/ media4
[ispserver][rkaiq_get_media_info]:media get sys_path: /dev/media5
dbserver[779]: [dbserver][main]:dbserver dbus register finish
[ispserver][r kaiq_get_media_info]:media get sys_path: /dev/media6
[isp server][rkaiq_get_media_info]:media get sys_path: /dev/media7
killall: dropbear: no pr ocess killed
[ispserver][rk aiq_get_media_info]:media get sys_path: /dev/media8
[ispserv er][rkaiq_get_media_info] = 0x0:media get sys_path: /dev/medi0a9
[ispserver][rkaiq_get_media_0info]:cam id 0 find_sensor 0 f0ind_isp 0 find_ispp 0
[ispserver][rkaiq_get_media_info]:cam 00id 1 find_sensor 0 find_isp 1 0find_ispp 1
[ 5.841293] Build options:
[ 5.841301] gcdGPU_TIMEOUT = 20000
[ 5.841308] gcdGPU_2D_TIMEOUT = 4000
[ 5.841316] gcdINTERRUPT_STATISTIC = 1
[ 5.844421] Galcore Info: ContiguousBase=0x7f950000 ContiguousSize=0x400000
[ 5.849486] Galcore Info: MMU mapped core 0 SRAM[0] hardware virtual address=0x400000 size=0x40000
[ 5.849523] Galcore Info: MMU mapped core 0 SRAM[1] hardware virtual address=0x440000 size=0x40000
[ 5.850584] NN flop resetting…
[ 5.856022] galcore ffbc0000.npu: Init npu devfreq
[ispserver][main]:call_fun_ip[c_demo_server init
5.856081] galcore ffbc0000.npu: bin=0
[ 5.856131] galcore ffbc0000.npu: leakage=0.875
[ 5.867933] galcore ffbc0000.npu: temp=45500, pvtm=95425 (95425 + 0)
[ 5.868184] galcore ffbc0000.npu: pvtm-volt-sel=open system watchdog
[ 5.868238] galcore ffbc0000.npu: bin-scale=23
[ 5.868949] galcore ffbc0000.npu: avs=0
[ 5.870811] galcore ffbc0000.npu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 5.870904] galcore ffbc0000.npu: failed to read out thermal zone (-22)
[ 5.871065] galcore ffbc0000.npu: failed to find power_model node
[ 5.871084] galcore ffbc0000.npu: failed to initialize power model
[ 5.875588] ircut cam_ircut: driver version: 00.01.00
[ 5.877964] ircut cam_ircut: failed get pulse-width,use dafult value 100
[ 5.878058] ircut cam_ircut: Failed to get ircut-open-gpios
[root@RV1126_RV1109:/]# killall: rknn_server: no process killed
umount: can’t unmount /sys/kernel/config: Invalid argument
[ 6.242002] using random self ethernet address
[ 6.242052] using random host ethernet address
config uvc and rndis…
[ 6.260807] file system registered
adb on++++++ 3
umount: can’t unmount /dev/usb-ffs/adb: No such file or directory
[ 6.311133] read descriptors
[ 6.311186] read strings
config usb0 IP…
ifconfig: SIOCSIFADDR: No such device
ifconfig: SIOCGIFFLAGS: No such device
usb irq:
/oem/aicamera.sh: line 78: can’t create /proc/irq//smp_affinity_list: nonexistent directory
Rga built version:1.04 1aab590+2021-04-20 18:18:52
[uvc_app][main]:VERSION:SDK V1.33 Apr 20 2021 19:27:55 media_set:0x1
uvc_app[894]: uvc_app version 1.0.0
media get entity by name: rkisp-mpfbc-subdev is null
media get entity by name: rockchip-mipi-dphy-rx is null
mpp[895]: [(null)][main]:parse_args done!
mpp[895]: [(null)][main]:create aiserver instance done
mpp[895]: [shm_control_uvc][initialize]:shmWriteQueue InitForWrite(ret=1)
mpp[895]: [shm_control_uvc][initialize]:shmReadQueue InitForRead(ret=1)
mpp[895]: [(null)][setupTaskGraph]:AIServer: mFlagDBusServer = 1
mpp[895]: [shm_control_uvc][debugLoop]:enter
mpp[895]: [(null)][setupTaskGraph]:AIServer: mFlagDBusDbServer = 0
mpp[895]: [(null)][setupTaskGraph]:AIServer: RegisterMediaControl start ok
rockit log level 3
RTUVCGraph 09:00:30-992 {setCameraParams :472} Cannot get max width from getenv, use default(2560)
RTUVCGraph 09:00:30-992 {setCameraParams :478} Cannot get max height from getenv, use default(1440)
uvc_app[894]: [uvc_app][check_uvc_video_id]:Please configure uvc…
[eptz]:EPTZ VERSION 1.0.3 ,log_level[2]
[eptz]:read /etc/eptz_zoom.conf file…
[eptz]:read clip_ratio_data from 720 file
[eptz]:eptz_geometric_support status 0
[eptz]:eptzConfigInit successful
smart_display_service[970]: smart_display_service version 1.0.0
smart_display_service[970]: [smart_display_service][ShmControl]:read shm success
smart_display_service[970]: [smart_display_service][rndis_start_tcp_threads]:rndis_start_tcp_threads mEventRvThread enter
smart_display_service[970]: [smart_display_service][send_process_loop]:—send_process_loop
mpp[895]: [AISceneDirector][setup]:preload scene nn resource in
mpp[895]: [AISceneDirector][setup]:preload scene nn resource ok
mpp[895]: [(null)][main]:aiserver->setupTaskGraph(); done
set governor ondemand ok
烧写了启动挂在这里,串口没反应了
这是已经启动了的,请确认串口是否有错?接错的话无法进行串口操作
