雙LVDS屏調試
大家好,
目前嘗試在AIO-3288J板子且使用ubuntu的sdk上點亮雙LVDS的屏,遇到的狀況是黑屏,量測輸出的LVDS訊號發現偶訊號只有0.037伏特左右,而奇訊號有0.8伏特,表示偶訊號沒有正常輸出。
使用的dts文件為rk3288-firefly-aio-lvds.dts,dts中的lvds panel節點設置如下:
&lvds_panel {
status = “okay”;
compatible =“simple-panel”;
power-supply = <&vcc_lcd>;
backlight = <&backlight>;
bus-format = <MEDIA_BUS_FMT_RGB888_1X24>;
enable-delay-ms = <10>;
rockchip,data-mapping = “vesa”;
rockchip,data-width = <24>;
rockchip,output = “duallvds”;
    display-timings {
            native-mode = <&timing0>;
            timing0: timing0 {
                    clock-frequency = <152000000>;
                    hactive = <1920>;
                    vactive = <1200>;
                    hback-porch = <96>;
                    hfront-porch = <32>;
                    vback-porch = <8>;
                    vfront-porch = <36>;
                    hsync-len = <50>;
                    vsync-len = <1>;
                    hsync-active = <0>;
                    vsync-active = <0>;
                    de-active = <1>;
                    pixelclk-active = <0>;
屏的規格如下圖:
參考其他版友的帖,所以其中水平時間參數都拿規格中的值再乘以2,想請教版友們是哪裡設定錯誤導致輸出的LVDS訊號不正確呢?
補充一下,同樣的屏有用一樣的AIO-3288J板子點亮過,只是是android的sdk,dts中的disaply timing參數設定如下:
screen-type = <SCREEN_DUAL_LVDS>;
lvds-format = <LVDS_8BIT_1>;
out-face = <OUT_P888>;
color-mode = <COLOR_RGB>;
hactive = <1920>;
vactive = <1200>;
hback-porch = <48>;
hfront-porch = <16>;
vback-porch = <8>;
hsync-len = <25>;
vsync-len = <1>;
hsync-active = <0>;
vsync-active = <0>;
de-active = <0>;
swap-rb = <0>;
swap-rg = <0>;
swap-gb = <0>;
更新一下給未來也遇到同樣問題的人,如果要輸出雙LVDS訊號的話,需要加上一個參數叫dual-channel,display timing的部分則參考屏的規格書
&lvds {
status = “okay”;
dual-channel;
&lvds_panel {
status = “okay”;
    display-timings {
            timing0: timing0 {
                    clock-frequency = <152000000>; // 因為拿到的屏暫時是60Hz的
                    hactive = <1920>;
                    vactive = <1200>;
                    hback-porch = <48>;
                    vback-porch = <8>;
                    hsync-len = <25>;
                    vsync-len = <1>;
                    hsync-active = <0>;
                    vsync-active = <0>;
                    de-active = <1>;
谢谢分享
不好意思~請問一下!!
SCREEN_DUAL_LVDS 是指RK3288輸出 2port 即(odd &even)點單一個屏
還是如你的標題是給雙LVDS屏應用?
fireman7 发表于 2023-5-10 16:56
不好意思~請問一下!!
還是如你的標題是 …
不好意思,表達不佳,我指的是2 port的單一屏
学习了
