rk3288怎么支持GPS
现在用AP6476将firefly的AP6335替换掉了,请问firefly支不支持AP6476的GPS功能,要支持的怎么支持?
  1. 硬件部分,参考附件!
  2. Kernel Driver部分
    Device Drivers->Network Device Support->Wireless LAN->AP6476
  3. Android部分(以4.4为例)
    2.1
    device/rockchip/rk3288/wifi_bt.mk文件中,修改如下:
BOARD_CONNECTIVITY_VENDOR := Broadcom
BOARD_CONNECTIVITY_MODULE := ap6xxx_gps
2.2
device/rockchip/rksdk/BoardConfig.mk文件中,
# product has GPS or not
BOARD_HAS_GPS := true
2.3
device/rockchip/common/gps/rk30_gps.mk文件,修改如下:
CUR_PATH := device/rockchip/common/gps
ifeq ($(strip $(BLUETOOTH_USE_BPLUS)),true)
PRODUCT_COPY_FILES +=
device/rockchip/common/gps/ap6xxx/gps.default.so:system/lib/hw/gps.default.so
device/rockchip/common/gps/ap6xxx/glgps:system/bin/glgps
device/rockchip/common/gps/ap6xxx/gpslogd:system/bin/gpslogd
device/rockchip/common/gps/ap6xxx/gpsconfig.xml:system/etc/gps/gpsconfig.xml
device/common/gps/gps.conf_AS_SUPL:system/etc/gps.conf
endif
2.4
device/rockchip/rksdk/init.rk30board.rc文件中,确保如下设置:
# AP6476 GPS permission
chmod 755 /system/bin/glgps
chown root system /system/bin/glgps
chmod 644 /system/lib/hw/gps.default.so
chown root system /system/lib/hw/gps.default.so
mkdir /data/gps
chmod 770 /data/gps
chown system net_bt_stack /data/gps
mkdir /data/gps/log
chmod 0777 /data/gps/log
chown system net_bt_stack /data/gps/log
on property:ro.rk.btchip=broadcom.bplus
start gpsd
service gpsd /system/bin/glgps -c /system/etc/gps/gpsconfig.xml
class main
disabled
user root
group system
重新make,用GPS软件进行测试;
AP6XXX-PIN-TO-PIN-DESIGN-1V8-HOST-IO-V1.7-03182013.pdf.pdf (143 KB)
:slight_smile:
GPS怎么和wifi模块扯上关系了。小白不懂啊
感谢
