PX30 linux 256MB DDR3 UBOOT启动不了
硬件平台:firefly px30
SDK: firefly px30 linux sdk
问题描述:更换板子DDR容量为256MB 发现uboot启动不了,未更换前可以正常启动,log如下:
@▒▒L▒▒▒▒▒▒DDR V1.15 20200511
D3,256MB,333MHz
bw      col     bk      row     cs      dbw
32      10      8       13      1       16
Boot1 Release Time: Nov 20 2019 15:02:03, version: 1.22
chip_id:50583330_0,0
SdmmcInit=0 NOT PRESENT
...2578 @ nand_flash_init
...nandc_init enter... 00000000ff3b0000
0:80f00 2081 101003 27 200
g_nandc_ver...9
mmc Ext_csd, ret=0 ,
 Ext[226]=20, bootSize=2000,
                        Ext[215]=0, Ext[214]=74, Ext[213]=80, Ext[212]=0,cap =748000 REL=1f
mmc2:cmd19,100
emmc bus: 0x8
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=3728MB
FwPartOffset=2000 , 2000
UsbBoot ...94285
powerOn 747066
SoftReset, 24184046 us
DDR V1.15 20200511
SRX
D3,256MB,333MHz
32      10      8       13      1       16
Boot1 Release Time: Nov 20 2019 14:41:00, version: 1.22
ChipType = 0x12, 458
mmc2:cmd19,100
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=3728MB
StorageInit ok = 9215
SecureMode = 0
Secure read PBA: 0x4
Secure read PBA: 0x404
Secure read PBA: 0x804
Secure read PBA: 0xc04
Secure read PBA: 0x1004
atags_set_bootdev: ret:(0)
GPT part:  0, name:            uboot, start:0x4000, size:0x2000
GPT part:  1, name:            trust, start:0x6000, size:0x2000
GPT part:  2, name:             misc, start:0x8000, size:0x2000
GPT part:  3, name:             boot, start:0xa000, size:0x10000
GPT part:  4, name:         recovery, start:0x1a000, size:0x10000
GPT part:  5, name:             fpga, start:0x3a000, size:0x10000
GPT part:  6, name:           rootfs, start:0x5a000, size:0x200000
GPT part:  7, name:         userdata, start:0x25a000, size:0x4edfdf
find part:uboot OK. first_lba:0x4000.
find part:trust OK. first_lba:0x6000.
LoadTrust Addr:0x6000
No find bl30.bin
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0xd6430
RunBL31 0x40000 @ 71251 us
INFO:    Preloader serial: 2
NOTICE:  BL31: v1.3(debug):857e9c1b4
NOTICE:  BL31: Built : 11:50:33, Aug 21 2020
NOTICE:  BL31:Rockchip release version: v1.0
INFO:    ARM GICv2 driver initialized
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 1
INFO:    plat_rockchip_pmu_init: pd status f00e
INFO:    BL31: Initializing runtime services
INFO:    BL31: Initializing BL32
I/TC:
I/TC: Start rockchip platform init
I/TC: Rockchip release version: 1.1
I/TC: OP-TEE version: 3.6.0-284-g82765277 #12 Thu Sep 17 03:47:31 UTC 2020 aarch64
I/TC: Initialized
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2017.09 (May 29 2021 - 17:36:04 +0800)
Model: Rockchip PX30 EVB
PreSerial: 2
DRAM:  224 MiB
Sysmem: init
ERROR: Failed to allocate 0xe226980 bytes below 0x10000000.
Sysmem Error: Failed to alloc "U-Boot" at 0x01dd9680 - 0x10000000
sysmem_dump_all:
    memory.rgn[0].addr     = 0x00200000 - 0x08400000 (size: 0x08200000)
    memory.rgn[1].addr     = 0x0a200000 - 0x10000000 (size: 0x05e00000)
    memory.total           = 0x0e000000 (224 MiB. 0 KiB)
    framework malloc_r     = 192 MiB
    framework malloc_f     =   8 KiB
    allocated.total        = 0x00000000 (0 MiB. 0 KiB)
    LMB.allocated[0].addr  = 0x00000000 - 0x00000000 (size: 0x00000000)
    reserved.core.total    = 0x00000000 (0 MiB. 0 KiB)
Sysmem Error: Failed to reserve sysmem for U-Boot framework
sysmem_dump_all:
Sysmem Warn: Maybe malloc size 192 MiB is too large?
initcall sequence 00000000002922a8 failed at call 00000000002788b4 (err=-12)
