购买的开发板下载网址的目标码无法启动
购买的开发板下载网址的目标码无法启动
DDR Version V1.05 20201214
DDR4, 328MHz
BW=32 Col=10 Bk=4 BG=2 CS0 Row=16 CS=1 Die BW=16 Size=2048MB
change to: 328MHz
change to: 528MHz
change to: 784MHz
change to: 924MHz(final freq)
out
U-Boot SPL board init
U-Boot SPL 2017.09-gfc1f7cd4bc #lvsx (Apr 27 2021 - 15:57:31)
unknown raw ID phN
Trying to boot from MMC2
mmc_init: -95, time 10
Trying to boot from MMC1
Magic is incorrect.
Error validating A/B metadata from disk. Resetting and writing new A/B metadata to disk.
## Verified-boot: 0
## Checking optee 0x08400000 … sha256+ OK
## Checking uboot 0x00400000 … sha256+ OK
## Checking fdt 0x004b1de8 … sha256+ OK
Jumping to U-Boot(0x00400000) via OP-TEE(0x08400000)
Total: 154.354 ms
I/TC:
I/TC: cpu feature:0x0
I/TC: cpu_st=0xe0
I/TC: OP-TEE version: 3.6.0-300-g380b79bf #35 Sat Oct 17 03:53:58 UTC 2020 arm
I/TC: Next entry point address: 0x00400000
I/TC: Initialized
U-Boot 2017.09-gfc1f7cd4bc #lvsx (Apr 27 2021 - 15:57:31 +0800)
Model: Rockchip RV1126 Evaluation Board
PreSerial: 2, raw, 0xff570000
DRAM: 2 GiB
Sysmem: init
Relocation Offset: 00000000, fdt: 7bcf9bd8
dwmmc@ffc50000: 0, dwmmc@ffc60000: 1
Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
boot mode: None
DTB: rk-kernel.dtb
HASH(c): OK
I2c0 speed: 400000Hz
PMIC: RK8090 (on=0x40, off=0x00)
vdd_npu_vepu 800000 uV
vdd_arm 800000 uV
io-domain: OK
Can’t get crtc id, default set to id = 0
Model: Firefly Core-RV1126-JD4 Board
Using display timing dts
Detailed mode clock 70000 kHz, flags[a]
H: 0800 0980 0990 1000
V: 1280 1288 1292 1296
bus_format: 1009
final DSI-Link bandwidth: 500 Mbps x 4
apll 816000 KHz
dpll 462000 KHz
gpll 1188000 KHz
cpll 500000 KHz
hpll 1400000 KHz
aclk_pdbus 500000 KHz
hclk_pdbus 198000 KHz
pclk_pdbus 99000 KHz
aclk_pdphp 297000 KHz
hclk_pdphp 198000 KHz
hclk_pdaudio 148500 KHz
hclk_pdcore 198000 KHz
pclk_pdpmu 99000 KHz
Net: eth0: ethernet@ffc40000
## Booting FIT Image at 0x7ab469c0 with size 0x00fb0200
Fdt Ramdisk skip relocation
## Loading kernel from FIT Image at 7ab469c0 …
Using ‘conf’ configuration
optee api revision: 2.0
## Verified-boot: 0
Trying ‘kernel’ kernel subimage
Description: unavailable
Type: Kernel Image
Compression: uncompressed
Data Start: 0x7ab5ffc0
Data Size: 7185144 Bytes = 6.9 MiB
Architecture: ARM
OS: Linux
Load Address: 0x02008000
Entry Point: 0x02008000
Hash algo: sha256
Hash value: 5b5b231b956645ad48ea4cb58f13dc9ca5a28068f1b37ad1cadab573c594f1f6
Verifying Hash Integrity … sha256+ OK
## Loading ramdisk from FIT Image at 7ab469c0 …
Trying ‘ramdisk’ ramdisk subimage
Type: RAMDisk Image
Data Start: 0x7b23a3c0
Data Size: 9160505 Bytes = 8.7 MiB
Architecture: ARM
OS: Linux
Load Address: 0x0a200000
Entry Point: unavailable
Hash algo: sha256
Hash value: 34c8dbec64a0c800281419dccd445b0b6ff60dcb9c431584b823cc4088347bde
Loading ramdisk from 0x7b23a3c0 to 0x0a200000
## Loading fdt from FIT Image at 7ab469c0 …
Trying ‘fdt’ fdt subimage
Type: Flat Device Tree
Data Start: 0x7ab471c0
Data Size: 101609 Bytes = 99.2 KiB
Architecture: ARM
Load Address: 0x08300000
Hash algo: sha256
Hash value: 7386f9af7df2f2becbb497af7f9cec3b32975ccb162dfd4d670e861551106682
Loading fdt from 0x08300000 to 0x08300000
Booting using the fdt blob at 0x08300000
Loading Kernel Image from 0x7ab5ffc0 to 0x02008000 … OK
‘reserved-memory’ ramoops@8000000: addr=8000000 size=100000
Using Device Tree in place at 08300000, end 0831bce8
Adding bank: 0x00000000 - 0x08400000 (size: 0x08400000)
Adding bank: 0x08648000 - 0x80000000 (size: 0x779b8000)
Total: 1070.914 ms
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Linux version 4.19.111 (lvsx@tchip14) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #21 SMP PREEMPT Sun Apr 25 14:30:55 CST 2021
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] OF: fdt: Machine model: Firefly Core-RV1126-JD4 Board
[ 0.000000] earlycon: uart8250 at MMIO32 0xff570000 (options ‘’)
[ 0.000000] Reserved memory: created CMA memory pool at 0x7f800000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x6dc00000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node isp, compatible id shared-dma-pool
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] percpu: Embedded 15 pages/cpu s32204 r8192 d21044 u61440
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 521656
[ 0.000000] Kernel command line: user_debug=31 storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal ro rootwait earlycon=uart8250,mmio32,0xff570000 console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 cgroup_enable=memory swapaccount=1 snd_aloop.index=7
[ 0.000000] Memory: 1780824K/2094816K available (9216K kernel code, 415K rwdata, 2432K rodata, 1024K init, 943K bss, 43656K reserved, 270336K cma-reserved, 777000K highmem)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xb0000000 - 0xf0000000 (1024 MB)
[ 0.000000] pkmap : 0xafe00000 - 0xb0000000 ( 2 MB)
[ 0.000000] modules : 0xaf000000 - 0xafe00000 ( 14 MB)
[ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (10208 kB)
[ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (1024 kB)
[ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 416 kB)
[ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 944 kB)
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] random: random: get_random_bytes called from start_kernel+0x328/0x4ac with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[ 0.000010] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000760] Switching to timer-based delay loop, resolution 41ns
[ 0.002624] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.003587] pid_max: default: 4096 minimum: 301
[ 0.004191] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.004821] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.006242] CPU: Testing write buffer coherency: ok
[ 0.007065] /cpus/cpu@f00 missing clock-frequency property
[ 0.007590] /cpus/cpu@f01 missing clock-frequency property
[ 0.008112] /cpus/cpu@f02 missing clock-frequency property
[ 0.008636] /cpus/cpu@f03 missing clock-frequency property
[ 0.009154] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.010447] Setting up static identity map for 0x100000 - 0x100060
[ 0.011201] rcu: Hierarchical SRCU implementation.
[ 0.012291] smp: Bringing up secondary CPUs …
[ 0.013644] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.014662] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.015605] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.015739] smp: Brought up 1 node, 4 CPUs
[ 0.017790] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.018374] CPU: All CPU(s) started in SVC mode.
[ 0.019782] devtmpfs: initialized
[ 0.046987] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.047054] Unpacking initramfs…
[ 0.048365] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.049275] futex hash table entries: 16 (order: -2, 1024 bytes)
[ 0.050082] pinctrl core: initialized pinctrl subsystem
[ 0.051939] NET: Registered protocol family 16
[ 0.053306] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.056013] cpuidle: using governor menu
[ 0.056416] Registered FIQ tty driver
[ 0.057514] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.058291] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.061093] console [pstore-1] enabled
[ 0.061726] pstore: Registered ramoops as persistent store backend
[ 0.062308] ramoops: attached 0x100000@0x8000000, ecc: 0/0
[ 0.110403] cryptd: max_cpu_qlen set to 1000
[ 0.111841] fiq debugger fiq mode enabled
[[ 0.112641] console [ttyFIQ0] enabled
[ 0.113318] bootconsole [uart8250] disabled
[ 0.113997] Registered fiq debugger ttyFIQ0
[ 0.114652] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[ 0.120213] rk_iommu ffb00f00.iommu: version = 1
[ 0.120849] rk_iommu ffb20800.iommu: version = 1
[ 0.121316] rk_iommu ffb60e00.iommu: version = 1
[ 0.122043] rk_iommu ffb80480.iommu: version = 1
[ 0.122610] rk_iommu ffb90800.iommu: version = 1
[ 0.123106] rk_iommu ffbb0f00.iommu: version = 1
[ 0.124191] SCSI subsystem initialized
[ 0.124529] usbcore: registered new interface driver usbfs
[ 0.124629] usbcore: registered new interface driver hub
[ 0.124820] usbcore: registered new device driver usb
[ 0.124994] media: Linux media interface: v0.10
[ 0.125070] videodev: Linux video capture interface: v2.00
[ 0.125148] pps_core: LinuxPPS API ver. 1 registered
[ 0.125172] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.125216] PTP clock support registered
[ 0.126711] Advanced Linux Sound Architecture Driver Initialized.
[ 0.127381] Bluetooth: Core ver 2.22
[ 0.127470] NET: Registered protocol family 31
[ 0.127495] Bluetooth: HCI device and connection manager initialized
[ 0.127525] Bluetooth: HCI socket layer initialized
[ 0.127553] Bluetooth: L2CAP socket layer initialized
[ 0.127613] Bluetooth: SCO socket layer initialized
[ 0.128155] rockchip-cpuinfo cpuinfo: SoC : 11260000
[ 0.128195] rockchip-cpuinfo cpuinfo: Serial : 816d45f4d95bb7a1
[ 0.129401] clocksource: Switched to clocksource arch_sys_counter
[ 0.131993] NET: Registered protocol family 2
[ 0.132927] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.132992] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.133143] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.133348] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.133514] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.133590] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.133837] NET: Registered protocol family 1
[ 0.135925] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.138719] Initialise system trusted keyrings
[ 0.139001] workingset: timestamp_bits=29 max_order=19 bucket_order=0
[ 0.146474] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.149272] Key type asymmetric registered
[ 0.149315] Asymmetric key parser ‘x509’ registered
[ 0.149424] bounce: pool size: 64 pages
[ 0.149517] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.149545] io scheduler noop registered
[ 0.149567] io scheduler deadline registered
[ 0.149754] io scheduler cfq registered (default)
[ 0.149785] io scheduler mq-deadline registered
[ 0.149808] io scheduler kyber registered
[ 0.149965] io scheduler bfq registered
[ 0.154170] phy phy-ff4c0000.usb2-phy.1: Linked as a consumer to regulator.5
[ 0.155981] phy phy-ff4c8000.usb2-phy.2: Linked as a consumer to regulator.4
[ 0.159961] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[ 0.160115] pwm-backlight backlight: Linked as a consumer to regulator.0
[ 0.160545] mpp_service mpp-srv: 4cdfd254f099 author: Yandong Lin 2021-02-21 video: rockchip: mpp: Fix irq state err.
[ 0.160581] mpp_service mpp-srv: probe start
[ 0.161517] iommu: Adding device ffb80000.rkvdec to group 3
[ 0.161579] mpp_rkvdec ffb80000.rkvdec: Linked as a consumer to ffb80480.iommu
[ 0.161790] mpp_rkvdec ffb80000.rkvdec: probing start
[ 0.162476] mpp_rkvdec ffb80000.rkvdec: shared_niu_a is not found!
[ 0.162511] rkvdec_init:1182: No niu aclk reset resource define
[ 0.162536] mpp_rkvdec ffb80000.rkvdec: shared_niu_h is not found!
[ 0.162557] rkvdec_init:1185: No niu hclk reset resource define
[ 0.162913] mpp_rkvdec ffb80000.rkvdec: probing finish
[ 0.163662] iommu: Adding device ffbb0000.rkvenc to group 5
[ 0.163722] mpp_rkvenc ffbb0000.rkvenc: Linked as a consumer to ffbb0f00.iommu
[ 0.164037] mpp_rkvenc ffbb0000.rkvenc: probing start
[ 0.164653] mpp_rkvenc ffbb0000.rkvenc: venc regulator not ready, retry
[ 0.164688] rkvenc_init:1194: failed to add venc devfreq
[ 0.165809] iommu: Adding device ffb90400.vdpu to group 4
[ 0.165874] mpp_vdpu2 ffb90400.vdpu: Linked as a consumer to ffb90800.iommu
[ 0.165983] mpp_vdpu2 ffb90400.vdpu: probe device
[ 0.166563] mpp_vdpu2 ffb90400.vdpu: reset_group->rw_sem_on=0
[ 0.166619] mpp_vdpu2 ffb90400.vdpu: reset_group->rw_sem_on=0
[ 0.166878] mpp_vdpu2 ffb90400.vdpu: probing finish
[ 0.167525] iommu: Adding device ffb90000.vepu to group 4
[ 0.167586] mpp_vepu2 ffb90000.vepu: Linked as a consumer to ffb90800.iommu
[ 0.167712] mpp_vepu2 ffb90000.vepu: probe device
[ 0.168211] mpp_vepu2 ffb90000.vepu: reset_group->rw_sem_on=0
[ 0.168242] mpp_vepu2 ffb90000.vepu: reset_group->rw_sem_on=0
[ 0.168516] mpp_vepu2 ffb90000.vepu: probing finish
[ 0.169069] iommu: Adding device ffb20000.iep to group 1
[ 0.169128] mpp-iep2 ffb20000.iep: Linked as a consumer to ffb20800.iommu
[ 0.169244] mpp-iep2 ffb20000.iep: probe device
[ 0.170055] mpp-iep2 ffb20000.iep: allocate roi buffer failed
[ 0.170337] mpp-iep2 ffb20000.iep: probing finish
[ 0.170586] mpp_service mpp-srv: probe success
[ 0.175750] dma-pl330 ff4e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.175791] dma-pl330 ff4e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.178226] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 0.179125] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.180095] ff560000.serial: ttyS0 at MMIO 0xff560000 (irq = 32, base_baud = 1500000) is a 16550A
[ 0.182882] random: fast init done
[ 0.183414] random: crng init done
[ 0.183483] iommu: Adding device ffb00000.vop to group 0
[ 0.183536] rockchip-vop ffb00000.vop: Linked as a consumer to ffb00f00.iommu
[ 0.187704] rockchip-drm display-subsystem: Linked as a consumer to ffb00000.vop
[ 0.188765] rockchip-drm display-subsystem: Linked as a consumer to ffb30000.dsi
[ 0.190143] rockchip-drm display-subsystem: devfreq is not set
[ 0.190653] rockchip-drm display-subsystem: bound ffb00000.vop (ops 0xb0a3dec0)
[ 0.190743] dw-mipi-dsi ffb30000.dsi: [drm:dw_mipi_dsi_bind] ERROR Failed to find panel or bridge: -517
[ 0.190781] rockchip-drm display-subsystem: failed to bind ffb30000.dsi (ops 0xb0a445ec): -517
[ 0.191050] rockchip-drm display-subsystem: master bind failed: -517
[ 0.196209] panel-simple-dsi ffb30000.dsi.0: Linked as a consumer to regulator.1
[ 0.196286] panel-simple-dsi ffb30000.dsi.0: ffb30000.dsi.0 supply vsp not found, using dummy regulator
[ 0.196406] panel-simple-dsi ffb30000.dsi.0: Linked as a consumer to regulator.0
[ 0.196459] panel-simple-dsi ffb30000.dsi.0: ffb30000.dsi.0 supply vsn not found, using dummy regulator
[ 0.204544] loop: module loaded
[ 0.205280] zram: Added device: zram0
[ 0.207844] libphy: Fixed MDIO Bus: probed
[ 0.209883] rk_gmac-dwmac ffc40000.ethernet: no regulator found
[ 0.209934] rk_gmac-dwmac ffc40000.ethernet: clock input or output? (output).
[ 0.209957] rk_gmac-dwmac ffc40000.ethernet: TX delay(0x2a).
[ 0.209980] rk_gmac-dwmac ffc40000.ethernet: RX delay(0x1a).
[ 0.210012] rk_gmac-dwmac ffc40000.ethernet: integrated PHY? (no).
[ 0.215117] rk_gmac-dwmac ffc40000.ethernet: init for RGMII
[ 0.215438] rk_gmac-dwmac ffc40000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 0.215474] rk_gmac-dwmac ffc40000.ethernet: DWMAC4/5
[ 0.215501] rk_gmac-dwmac ffc40000.ethernet: DMA HW capability register supported
[ 0.215525] rk_gmac-dwmac ffc40000.ethernet: RX Checksum Offload Engine supported
[ 0.215547] rk_gmac-dwmac ffc40000.ethernet: TX Checksum insertion supported
[ 0.215569] rk_gmac-dwmac ffc40000.ethernet: Wake-Up On Lan supported
[ 0.215641] rk_gmac-dwmac ffc40000.ethernet: TSO supported
[ 0.215666] rk_gmac-dwmac ffc40000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 0.215686] rk_gmac-dwmac ffc40000.ethernet: TSO feature enabled
[ 0.352816] libphy: stmmac: probed
[ 0.354832] PPP generic driver version 2.4.2
[ 0.355150] PPP BSD Compression module registered
[ 0.355181] PPP Deflate Compression module registered
[ 0.355221] PPP MPPE Compression module registered
[ 0.355245] NET: Registered protocol family 24
[ 0.355368] usbcore: registered new interface driver r8152
[ 0.355455] usbcore: registered new interface driver asix
[ 0.355543] usbcore: registered new interface driver ax88179_178a
[ 0.355614] usbcore: registered new interface driver cdc_ether
[ 0.355683] usbcore: registered new interface driver net1080
[ 0.355756] usbcore: registered new interface driver cdc_subset
[ 0.355825] usbcore: registered new interface driver zaurus
[ 0.355923] usbcore: registered new interface driver cdc_ncm
[ 0.355996] usbcore: registered new interface driver qmi_wwan
[ 0.357860] dwc3 ffd00000.dwc3: Failed to get clk ‘ref’: -2
[ 0.363204] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.363244] ehci-platform: EHCI generic platform driver
[ 0.366873] ehci-platform ffe00000.usb: EHCI Host Controller
[ 0.366946] ehci-platform ffe00000.usb: new USB bus registered, assigned bus number 1
[ 0.367180] ehci-platform ffe00000.usb: irq 67, io mem 0xffe00000
[ 0.379447] ehci-platform ffe00000.usb: USB 2.0 started, EHCI 1.00
[ 0.379802] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.379838] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.379864] usb usb1: Product: EHCI Host Controller
[ 0.379889] usb usb1: Manufacturer: Linux 4.19.111 ehci_hcd
[ 0.379913] usb usb1: SerialNumber: ffe00000.usb
[ 0.380732] hub 1-0:1.0: USB hub found
[ 0.380813] hub 1-0:1.0: 1 port detected
[ 0.381598] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.381659] ohci-platform: OHCI generic platform driver
[ 0.382295] ohci-platform ffe10000.usb: Generic Platform OHCI controller
[ 0.382347] ohci-platform ffe10000.usb: new USB bus registered, assigned bus number 2
[ 0.382574] ohci-platform ffe10000.usb: irq 68, io mem 0xffe10000
[ 0.440439] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[ 0.440492] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.440513] usb usb2: Product: Generic Platform OHCI controller
[ 0.440533] usb usb2: Manufacturer: Linux 4.19.111 ohci_hcd
[ 0.440570] usb usb2: SerialNumber: ffe10000.usb
[ 0.441437] hub 2-0:1.0: USB hub found
[ 0.441519] hub 2-0:1.0: 1 port detected
[ 0.443400] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 0.443473] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 3
[ 0.443737] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000001002010010
[ 0.443836] xhci-hcd xhci-hcd.0.auto: irq 79, io mem 0xffd00000
[ 0.444317] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.444351] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.444377] usb usb3: Product: xHCI Host Controller
[ 0.444401] usb usb3: Manufacturer: Linux 4.19.111 xhci-hcd
[ 0.444424] usb usb3: SerialNumber: xhci-hcd.0.auto
[ 0.445200] hub 3-0:1.0: USB hub found
[ 0.445279] hub 3-0:1.0: 1 port detected
[ 0.445853] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 0.445910] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 4
[ 0.445950] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 0.446109] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 0.446327] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 0.446361] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.446386] usb usb4: Product: xHCI Host Controller
[ 0.446410] usb usb4: Manufacturer: Linux 4.19.111 xhci-hcd
[ 0.446434] usb usb4: SerialNumber: xhci-hcd.0.auto
[ 0.447185] hub 4-0:1.0: USB hub found
[ 0.447261] hub 4-0:1.0: config failed, hub doesn’t have any ports! (err -19)
[ 0.447781] usbcore: registered new interface driver cdc_wdm
[ 0.447977] usbcore: registered new interface driver usb-storage
[ 0.448142] usbcore: registered new interface driver option
[ 0.448205] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.449543] i2c /dev entries driver
[ 0.451520] rk808 0-0020: chip id: 0x8090
[ 0.451637] rk808 0-0020: No cache defaults, reading back from HW
[ 0.458058] rk808 0-0020: source: on=0x40, off=0x00
[ 0.458108] rk808 0-0020: support dcdc3 fb mode:-22, -1329999256
[ 0.458138] rk808 0-0020: support pmic reset mode:0,0
[ 0.462624] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 0.462809] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 0.462929] DCDC_REG1: supplied by vcc5v0_sys
[ 0.463654] DCDC_REG2: supplied by vcc5v0_sys
[ 0.464309] DCDC_REG3: supplied by vcc5v0_sys
[ 0.464829] DCDC_REG4: supplied by vcc5v0_sys
[ 0.465344] DCDC_REG5: supplied by vcc5v0_sys
[ 0.465975] LDO_REG1: supplied by vcc_buck5
[ 0.466681] LDO_REG2: supplied by vcc_buck5
[ 0.467191] LDO_REG3: supplied by vcc_buck5
[ 0.467684] LDO_REG4: supplied by vcc_buck5
[ 0.468196] LDO_REG5: supplied by vcc_buck5
[ 0.468684] LDO_REG6: supplied by vcc_buck5
[ 0.468782] vcc_dvdd: Bringing 1100000uV into 1200000-1200000uV
[ 0.469357] LDO_REG7: supplied by vcc5v0_sys
[ 0.469936] LDO_REG8: supplied by vcc5v0_sys
[ 0.470623] LDO_REG9: supplied by vcc5v0_sys
[ 0.471251] SWITCH_REG1: supplied by vcc5v0_sys
[ 0.471710] SWITCH_REG2: supplied by vcc3v3_sys
[ 0.474109] input: rk805 pwrkey as /devices/platform/ff3f0000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input0
[ 0.477201] rk808-rtc rk808-rtc: registered as rtc0
[ 0.477822] rk808-rtc rk808-rtc: setting system clock to 2017-08-04 09:00:03 UTC (1501837203)
[ 0.480339] pca953x 1-0020: 1-0020 supply vcc not found, using dummy regulator
[ 0.480463] pca953x 1-0020: Linked as a consumer to regulator.0
[ 0.480684] pca953x 1-0020: failed reading register
[ 0.480789] pca953x 1-0020: Dropping the link to regulator.0
[ 0.482666] ircut cam_ircut: driver version: 00.01.00
[ 0.482999] ircut cam_ircut: failed get pulse-width,use dafult value 100
[ 0.483081] ircut cam_ircut: Failed to get ircut-open-gpios
[ 0.483657] ERROR: could not get clock /mipi-csi2@ffb10000:srst_csihost_p(1)
[ 0.483695] rockchip-mipi-csi2: failed to get rst clock, maybe useless
[ 0.483977] rockchip-mipi-csi2: probe success, v4l2_dev:(null)!
[ 0.485364] rkcifhw ffae0000.rkcif: no iommu attached, using non-iommu buffers
[ 0.485425] rkcifhw ffae0000.rkcif: assigned reserved memory node isp
[ 0.485578] rkcif rkcif_dvp: rkcif driver version: v00.01.09
[ 0.485692] rkcif rkcif_dvp: attach to cif hw node
[ 0.485723] rkcif rkcif_dvp: no iommu attached, using non-iommu buffers
[ 0.485754] rkcif rkcif_dvp: assigned reserved memory node isp
[ 0.486347] rkcif_dvp: Failed to register subdev notifier(-19)
[ 0.486763] rkcif rkcif_dvp: detach to cif hw node
[ 0.486886] rkcif rkcif_mipi_lvds: rkcif driver version: v00.01.09
[ 0.487007] rkcif rkcif_mipi_lvds: attach to cif hw node
[ 0.487040] rkcif rkcif_mipi_lvds: no iommu attached, using non-iommu buffers
[ 0.487078] rkcif rkcif_mipi_lvds: assigned reserved memory node isp
[ 0.488098] rkcif rkcif_mipi_lvds: Entity type for entity rockchip-mipi-csi2 was not initialized!
[ 0.490582] rkisp_hw ffb50000.rkisp: is_thunderboot: 0
[ 0.490631] rkisp_hw ffb50000.rkisp: Missing rockchip,grf property
[ 0.490977] rkisp_hw ffb50000.rkisp: iommu is disabled, using non-iommu buffers
[ 0.491028] rkisp_hw ffb50000.rkisp: assigned reserved memory node isp
[ 0.491358] rkisp rkisp-vir0: rkisp driver version: v01.04.01
[ 0.491602] rkisp rkisp-vir0: No memory-region-thunderboot specified
[ 0.491879] rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized!
[ 0.491915] rkisp rkisp-vir0: Entity type for entity rkisp-csi-subdev was not initialized!
[ 0.491950] rkisp rkisp-vir0: Entity type for entity rkisp-bridge-ispp was not initialized!
[ 0.495552] iommu: Adding device ffb60000.rkispp to group 2
[ 0.495631] rkispp_hw ffb60000.rkispp: Linked as a consumer to ffb60e00.iommu
[ 0.496348] rkispp_hw ffb60000.rkispp: max input:0x0@0fps
[ 0.496394] rkispp_hw ffb60000.rkispp: can’t request region for resource [mem 0xffb60000-0xffb7ffff]
[ 0.496945] rkispp rkispp-vir0: rkispp driver version: v01.04.01
[ 0.500140] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.20
[ 0.500278] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.16
[ 0.500474] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.23
[ 0.500763] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.14
[ 0.500880] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.11
[ 0.504133] rockchip-thermal ff5f0000.tsadc: tsadc trimmed value = 0
[ 0.504520] rockchip-thermal ff5f0000.tsadc: tsadc is probed successfully!
[ 0.504999] rockchip-thermal ff5f8000.tsadc: tsadc trimmed value = 0
[ 0.505283] rockchip-thermal ff5f8000.tsadc: tsadc is probed successfully!
[ 0.506315] Bluetooth: HCI UART driver ver 2.3
[ 0.506352] Bluetooth: HCI UART protocol H4 registered
[ 0.506702] cpu cpu0: bin=0
[ 0.506752] cpu cpu0: leakage=1.125
[ 0.506917] cpu cpu0: Linked as a consumer to regulator.9
[ 0.518527] cpu cpu0: temp=38000, pvtm=95984 (95971 + 13)
[ 0.518676] cpu cpu0: pvtm-volt-sel=1
[ 0.518784] cpu cpu0: Dropping the link to regulator.9
[ 0.518859] cpu cpu0: bin-scale=5
[ 0.519332] cpu cpu0: Linked as a consumer to regulator.9
[ 0.519476] cpu cpu0: Dropping the link to regulator.9
[ 0.519740] cpu cpu0: Linked as a consumer to regulator.9
[ 0.520962] cpu cpu0: avs=0
[ 0.521427] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 0.521477] cpu cpu0: failed to read out thermal zone (-22)
[ 0.522423] cpu cpu0: failed to find power_model node
[ 0.522867] cpuidle: enable-method property ‘psci’ found operations
[ 0.522973] cpuidle: enable-method property ‘psci’ found operations
[ 0.523050] cpuidle: enable-method property ‘psci’ found operations
[ 0.523121] cpuidle: enable-method property ‘psci’ found operations
[ 0.523779] Synopsys Designware Multimedia Card Interface Driver
[ 0.524296] dwmmc_rockchip ffc50000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.524349] dwmmc_rockchip ffc50000.dwmmc: Using internal DMA controller.
[ 0.524367] dwmmc_rockchip ffc50000.dwmmc: Version ID is 270a
[ 0.524427] dwmmc_rockchip ffc50000.dwmmc: DW MMC controller at irq 62,32 bit host data width,256 deep fifo
[ 0.524553] mmc_host mmc0: card is non-removable.
[ 0.536342] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.549827] dwmmc_rockchip ffc60000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.549894] dwmmc_rockchip ffc60000.dwmmc: Using internal DMA controller.
[ 0.549908] dwmmc_rockchip ffc60000.dwmmc: Version ID is 270a
[ 0.549960] dwmmc_rockchip ffc60000.dwmmc: DW MMC controller at irq 63,32 bit host data width,256 deep fifo
[ 0.550090] dwmmc_rockchip ffc60000.dwmmc: Linked as a consumer to regulator.20
[ 0.562900] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.576321] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.576412] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[ 0.576521] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[ 0.576582] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 64,32 bit host data width,256 deep fifo
[ 0.576714] dwmmc_rockchip ffc70000.dwmmc: allocated mmc-pwrseq
[ 0.576727] mmc_host mmc1: card is non-removable.
[ 0.579081] mmc_host mmc0: Bus speed (slot 0) = 198000000Hz (slot req 200000000Hz, actual 198000000HZ div = 0)
[ 0.579116] dwmmc_rockchip ffc50000.dwmmc: Successfully tuned phase to 90
[ 0.579187] mmc0: new HS200 MMC card at address 0001
[ 0.580639] mmcblk0: mmc0:0001 8GTF4R 7.28 GiB
[ 0.581271] mmcblk0boot0: mmc0:0001 8GTF4R partition 1 4.00 MiB
[ 0.581881] mmcblk0boot1: mmc0:0001 8GTF4R partition 2 4.00 MiB
[ 0.582105] mmcblk0rpmb: mmc0:0001 8GTF4R partition 3 512 KiB, chardev (241:0)
[ 0.586226] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9
[ 0.589590] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.603569] usbcore: registered new interface driver usbkbd
[ 0.603640] usbcore: registered new interface driver usbmouse
[ 0.604658] rockchip-saradc ff5e0000.saradc: Linked as a consumer to regulator.16
[ 0.605353] rksfc_base v1.1 2016-01-08
[ 0.605754] rksfc ffc90000.sfc: rksfc_probe clk rate = 79200000
[ 0.605819] rkflash_dev_init enter
[ 0.605835] sfc nor id: 0 0 0
[ 0.605846] rkflash[1] is invalid
[ 0.605848] rkflash_dev_init enter
[ 0.605868] sfc_nand id: 0 0 0
[ 0.605876] rkflash[2] is invalid
[ 0.610118] rk817-codec rk817-codec: DMA mask not set
[ 0.610243] rk817_codec_parse_dt_property: rk809 have no io-channels defined
[ 0.613955] NET: Registered protocol family 17
[ 0.614020] NET: Registered protocol family 15
[ 0.614468] Bluetooth: RFCOMM TTY layer initialized
[ 0.614521] Bluetooth: RFCOMM socket layer initialized
[ 0.614553] Bluetooth: RFCOMM ver 1.11
[ 0.614566] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 0.614580] Bluetooth: HIDP socket layer initialized
[ 0.614589] [BT_RFKILL]: Enter rfkill_rk_init
[ 0.614598] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 0.614865] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 0.614909] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6236
[ 0.614920] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 0.614929] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 0.614984] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 8, flags = 0.
[ 0.615014] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 0.615022] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 0.615332] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 48.
[ 0.615358] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 7.
[ 0.615395] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 5.
[ 0.615406] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[ 0.615448] [BT_RFKILL]: Request irq for bt wakeup host
[ 0.615550] [BT_RFKILL]: ** disable irq
[ 0.615656] [BT_RFKILL]: bt shut off power
[ 0.615702] [BT_RFKILL]: bt_default device registered.
[ 0.616477] flash vendor_init_thread!
[ 0.616505] flash vendor storage:20170308 ret = -1
[ 0.616827] os04a10 1-0036: driver version: 00.01.04
[ 0.616854] os04a10 1-0036: Get hdr mode failed! no hdr default
[ 0.617028] os04a10 1-0036: could not get sleep pinstate
[ 0.617175] os04a10 1-0036: Linked as a consumer to regulator.11
[ 0.617234] os04a10 1-0036: Linked as a consumer to regulator.16
[ 0.617305] os04a10 1-0036: Linked as a consumer to regulator.18
[ 0.617552] clk_mipicsi_out2io_fracdiv p_rate(297000000) is low than rate(24000000)*20, use integer or half-div
[ 0.626996] os04a10 1-0036: Unexpected sensor id(000000), ret(-5)
[ 0.627195] os04a10 1-0036: Dropping the link to regulator.11
[ 0.627362] os04a10 1-0036: Dropping the link to regulator.16
[ 0.627476] os04a10 1-0036: Dropping the link to regulator.18
[ 0.628037] Registering SWP/SWPB emulation handler
[ 0.628889] Loading compiled-in X.509 certificates
[ 0.629961] rga2: Driver loaded successfully ver:3.02
[ 0.630243] rga2: Module initialized.
[ 0.633344] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 0.635374] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.636225] vendor storage:20190527 ret = 0
[ 0.636954] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.639916] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 0.644268] mmc1: queuing unknown CIS tuple 0x81 (9 bytes)
[ 0.649489] Freeing initrd memory: 8948K
[ 0.653412] mpp_rkvenc ffbb0000.rkvenc: probing start
[ 0.654161] mpp_rkvenc ffbb0000.rkvenc: Linked as a consumer to regulator.8
[ 0.654244] mpp_rkvenc ffbb0000.rkvenc: bin=0
[ 0.654271] mpp_rkvenc ffbb0000.rkvenc: leakage=1.0
[ 0.654340] mpp_rkvenc ffbb0000.rkvenc: Failed to get pvtm
[ 0.654366] mpp_rkvenc ffbb0000.rkvenc: bin-scale=37
[ 0.654647] mpp_rkvenc ffbb0000.rkvenc: avs=0
[ 0.654868] mpp_rkvenc ffbb0000.rkvenc: failed to find power_model node
[ 0.654882] mpp_rkvenc ffbb0000.rkvenc: failed to initialize power model
[ 0.655000] mpp_rkvenc ffbb0000.rkvenc: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 0.655024] mpp_rkvenc ffbb0000.rkvenc: failed to read out thermal zone (-22)
[ 0.655437] mpp_rkvenc ffbb0000.rkvenc: probing finish
[ 0.657568] rockchip-drm display-subsystem: devfreq is not set
[ 0.657896] rockchip-drm display-subsystem: bound ffb00000.vop (ops 0xb0a3dec0)
[ 0.657967] rockchip-drm display-subsystem: bound ffb30000.dsi (ops 0xb0a445ec)
[ 0.657986] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.657996] [drm] No driver support for vblank timestamp query.
[ 0.678869] [drm] Initialized rockchip 2.0.0 20140818 for display-subsystem on minor 0
[ 0.679764] input: adc-keys as /devices/platform/adc-keys/input/input1
[ 0.681118] ircut cam_ircut: driver version: 00.01.00
[ 0.682185] ircut cam_ircut: failed get pulse-width,use dafult value 100
[ 0.682304] ircut cam_ircut: Failed to get ircut-open-gpios
[ 0.690897] asoc-simple-card rk809-sound: rk817-hifi ↔ ff800000.i2s mapping ok
[ 0.690963] asoc-simple-card rk809-sound: ASoC: no source widget found for MICBIAS1
[ 0.690979] asoc-simple-card rk809-sound: ASoC: Failed to add route MICBIAS1 → direct → Mic Jack
[ 0.690995] asoc-simple-card rk809-sound: ASoC: no sink widget found for IN1P
[ 0.691009] asoc-simple-card rk809-sound: ASoC: Failed to add route Mic Jack → direct → IN1P
[ 0.691024] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOL
[ 0.691038] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOL → direct → Headphone Jack
[ 0.691060] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOR
[ 0.691085] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOR → direct → Headphone Jack
[ 0.692612] input: rockchip,rk809-codec Headphone Jack as /devices/platform/rk809-sound/sound/card0/input2
[ 0.693883] ircut cam_ircut: driver version: 00.01.00
[ 0.694124] ircut cam_ircut: failed get pulse-width,use dafult value 100
[ 0.694197] ircut cam_ircut: Failed to get ircut-open-gpios
[ 0.695089] ircut cam_ircut: driver version: 00.01.00
[ 0.695325] ircut cam_ircut: failed get pulse-width,use dafult value 100
[ 0.695390] ircut cam_ircut: Failed to get ircut-open-gpios
[ 0.696904] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.22 (r-20191105-2)(20191120-1)
[ 0.696947] ======== dhd_wlan_init_plat_data ========
[ 0.696964] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 0.697082] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=106, oob_irq_flags=0x414
[ 0.697101] dhd_wlan_init_gpio: WL_REG_ON=-1
[ 0.697116] dhd_wifi_platform_load: Enter
[ 0.697133] Power-up adapter ‘DHD generic adapter’
[ 0.697185] wifi_platform_set_power = 1
[ 0.697204] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 0.697219] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 0.697235] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 0.697237] ==gsl_ts_init==
[ 0.697330] GSLX680 Enter gsl_ts_probe
[ 0.697349] ==kzalloc success=
[ 0.712794] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 0.759528] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 0.774333] mmc1: new high speed SDIO card at address 0001
[ 0.775079] ircut cam_ircut: driver version: 00.01.00
[ 0.775317] ircut cam_ircut: failed get pulse-width,use dafult value 100
[ 0.775387] ircut cam_ircut: Failed to get ircut-open-gpios
[ 0.775946] ircut cam_ircut: driver version: 00.01.00
[ 0.776190] ircut cam_ircut: failed get pulse-width,use dafult value 100
[ 0.776248] ircut cam_ircut: Failed to get ircut-open-gpios
[ 0.865139] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=88.32
[ 0.865220] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 0.865255] usb 1-1: Product: USB2.0 Hub
[ 0.868597] hub 1-1:1.0: USB hub found
[ 0.869169] hub 1-1:1.0: 4 ports detected
[ 0.874785] ircut cam_ircut: driver version: 00.01.00
[ 0.875128] ircut cam_ircut: failed get pulse-width,use dafult value 100
[ 0.875293] ircut cam_ircut: Failed to get ircut-open-gpios
[ 1.003331] wifi_platform_bus_enumerate device present 1
[ 1.003394] ======== Card detection to detect SDIO card! ========
[ 1.003417] mmc1:mmc host rescan start!
[ 1.019978] bcmsdh_register: register client driver
[ 1.021459] bcmsdh_sdmmc_probe: Enter num=1
[ 1.022371] bcmsdh_sdmmc_probe: Enter num=2
[ 1.022385] ircut cam_ircut: driver version: 00.01.00
[ 1.022447] bus num (host idx)=1, slot num (rca)=1
[ 1.022469] found adapter info ‘DHD generic adapter’
[ 1.022565] sdioh_attach: set sd_f2_blocksize 256
[ 1.022679] sdioh_attach: sd clock rate = 0
[ 1.023397] dhdsdio_probe : no mutex held. set lock
[ 1.023654] F1 signature read @0x18000000=0x1542a9a6
[ 1.023771] ircut cam_ircut: failed get pulse-width,use dafult value 100
[ 1.023911] ircut cam_ircut: Failed to get ircut-open-gpios
[ 1.028224] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x2 pkg:0x4
[ 1.029939] DHD: dongle ram size is set to 524288(orig 524288) at 0x0
[ 1.030229] [dhd] dhd_conf_set_chiprev : chip=0xa9a6, chiprev=2
[ 1.030633] [dhd] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 1.031233] [dhd] CFG80211-ERROR) wl_setup_wiphy : SAE support
[ 1.031982] [dhd] CFG80211-ERROR) wl_init_prof : wl_init_prof: No profile
[ 1.033562] dhd_attach(): thread:dhd_watchdog_thread:5d started
[ 1.034531] dhd_attach(): thread:dhd_dpc:5e started
[ 1.035531] dhd_attach(): thread:dhd_rxf:5f started
[ 1.035568] dhd_deferred_work_init: work queue initialized
[ 1.035580] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 → mode 2
[ 1.035630] dhd_bus_set_default_min_res_mask: Unhandled chip id
[ 1.039231] sdioh_cis_read: func_cis_ptr[0]=0x1070
[ 1.055720] Dongle Host Driver, version 1.579.77.41.22 (r-20191105-2)(20191120-1)
[ 1.056306] Register interface [wlan0] MAC: d4:9c:dd:74:f3:b4
[ 1.056306]
[ 1.056419] dhd_tcpack_suppress_set: TCP ACK Suppress mode 2 → mode 0
[ 1.056441] dhd_wl_ioctl: returning as busstate=0
[ 1.056455] dhd_dbg_detach_pkt_monitor, 2204
[ 1.056471] dhd_bus_devreset: == Power OFF ==
[ 1.056828] bcmsdh_oob_intr_unregister: Enter
[ 1.056858] bcmsdh_oob_intr_unregister: irq is not registered
[ 1.056880] dhd_txglom_enable: enable 0
[ 1.056894] dhd_bus_devreset: WLAN OFF DONE
[ 1.056954] wifi_platform_set_power = 0
[ 1.056969] ======== PULL WL_REG_ON(-1) LOW! ========
[ 1.056983] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 1.057005] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 1.057020] dhdsdio_probe : the lock is released.
[ 1.057485] ircut cam_ircut: driver version: 00.01.00
[ 1.057631] dhd_module_init: Exit err=0
[ 1.057706] ircut cam_ircut: failed get pulse-width,use dafult value 100
[ 1.057772] ircut cam_ircut: Failed to get ircut-open-gpios
[ 1.163070] usb 1-1.3: new high-speed USB device number 3 using ehci-platform
[ 1.271346] usb 1-1.3: New USB device found, idVendor=0bda, idProduct=8152, bcdDevice=20.00
[ 1.271411] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.271432] usb 1-1.3: Product: USB 10/100 LAN
[ 1.271450] usb 1-1.3: Manufacturer: Realtek
[ 1.271469] usb 1-1.3: SerialNumber: 00E04C95A865
[ 1.277335] ircut cam_ircut: driver version: 00.01.00
[ 1.277720] ircut cam_ircut: failed get pulse-width,use dafult value 100
[ 1.277846] ircut cam_ircut: Failed to get ircut-open-gpios
[ 1.356483] usb 1-1.3: reset high-speed USB device number 3 using ehci-platform
[ 1.573002] r8152 1-1.3:1.0 eth1: v2.12.0 (2019/04/29)
[ 1.573079] r8152 1-1.3:1.0 eth1: This product is covered by one or more of the following patents:
[ 1.573079] US6,570,884, US6,115,776, and US6,327,625.
[ 1.573079]
[ 1.574326] ircut cam_ircut: driver version: 00.01.00
[ 1.576346] ircut cam_ircut: failed get pulse-width,use dafult value 100
[ 1.576507] ircut cam_ircut: Failed to get ircut-open-gpios
[ 1.626392] gsl_ts_probe–1377, i2c_master_recv fail
[ 1.626633] ret=0
[ 1.628477] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 1.646706] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 1.647118] rkcif rkcif_mipi_lvds: clear unready subdev num: 1
[ 1.647339] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 1.647358] cfg80211: failed to load regulatory.db
[ 1.647972] rkcif_mipi_lvds: Async subdev notifier completed
[ 1.648007] rkisp rkisp-vir0: clear unready subdev num: 1
[ 1.648318] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 1.648330] rkisp0: update sensor failed
[ 1.648816] dwmmc_rockchip ffc50000.dwmmc: Successfully tuned phase to 270
[ 1.648996] dwmmc_rockchip ffc50000.dwmmc: Successfully tuned phase to 90
[ 1.649230] ret 1024 0
[ 1.649428] ALSA device list:
[ 1.649448] #0: rockchip,rk809-codec
[ 1.649465] #7: Loopback 1
[ 1.650475] Freeing unused kernel memory: 1024K
[ 1.650820] Run /init as init process
Loading, please wait…
Couldn’t get a file descriptor referring to the console
starting version 237
/scripts/init-top/console_setup: line 134: can’t create /dev/tty1: No such device or address
/scripts/init-top/console_setup: line 1: can’t open /dev/tty1: No such device or address
/scripts/init-top/console_setup: line 1: can’t create /dev/tty2: No such device or address
/scripts/init-top/console_setup: line 1: can’t open /dev/tty2: No such device or address
/scripts/init-top/console_setup: line 1: can’t create /dev/tty3: No such device or address
/scripts/init-top/console_setup: line 1: can’t open /dev/tty3: No such device or address
/scripts/init-top/console_setup: line 1: can’t create /dev/tty4: No such device or address
/scripts/init-top/console_setup: line 1: can’t open /dev/tty4: No such device or address
/scripts/init-top/console_setup: line 1: can’t create /dev/tty5: No such device or address
/scripts/init-top/console_setup: line 1: can’t open /dev/tty5: No such device or address
/scripts/init-top/console_setup: line 1: can’t create /dev/tty6: No such device or address
/scripts/init-top/console_setup: line 1: can’t open /dev/tty6: No such device or address
Begin: Loading essential drivers … done.
Begin: Running /scripts/init-premount … done.
Begin: Running /scripts/local-premount … done.
Warning: fsck not present, so skipping root file system
[ 4.225393] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
done.
Begin: Running /scripts/local-bottom … done.
Begin: Running /scripts/init-bottom … Warning: overlayroot: configuring overlayroot with driver=overlay mode=device opts=‘dev=PARTLABEL=userdata,fstype=ext4,mkfs=1’ per kernel cmdline
[ 4.361141] EXT4-fs (mmcblk0p8): warning: mounting unchecked fs, running e2fsck is recommended
[ 4.362809] EXT4-fs (mmcblk0p8): mounted filesystem without journal. Opts: (null)
[[: missing ]]
ln: /root/var/lib/docker: File exists
Success: overlayroot: configured root with ‘device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1’ using overlay per kernel cmdline
Warning: Something odd, no /lib/modules/4.19.111 in initramfs.
done.
mount: mounting proc on /proc failed: Device or resource busy
Starting init…
set performance OK
NAME=Buildroot
VERSION=2018.02-rc3-02921-g1aab590-dirty
ID=buildroot
VERSION_ID=2018.02-rc3
PRETTY_NAME=“Buildroot 2018.02-rc3”
Starting logging: OK
/usr/bin/modetest
Populating /dev using udev: [ 4.685192] udevd[437]: starting version 3.2.7
[ 4.692077] udevd[437]: specified group ‘kvm’ unknown
[ 4.712697] udevd[438]: starting eudev-3.2.7
[ 4.839350] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 4.839428] stream_cif_mipi_id0: update sensor info failed -19
[ 4.842339] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 4.842386] stream_cif_mipi_id1: update sensor info failed -19
[ 4.843976] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 4.846333] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 4.846421] stream_cif_mipi_id2: update sensor info failed -19
[ 4.848201] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 4.848236] stream_cif_mipi_id3: update sensor info failed -19
done
Initializing random number generator… done.
Will now mount all partitions in /etc/fstab
Note: Create /.skip_fsck to skip fsck
  • The check might take a while if didn’t shutdown properly!
    Handling misc: /dev/mmcblk0p2 /misc emmc defaults 0
    Unsupported file system emmc for /dev/mmcblk0p2
    Handling oem: /dev/mmcblk0p7 /oem ext2 defaults 2
    Checking /dev/mmcblk0p7(ext2)
    e2fsck 1.43.9 (8-Feb-2018)
    oem: recovering journal
    Superblock last mount time is in the future.
    (by less than a day, probably due to the hardware clock being incorrectly set)
    oem: clean, 99/49152 files, 52178/196608 blocks
    Mounting /dev/mmcblk0p7(ext2) on /oem
    [ 5.503628] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
    Handling userdata: /dev/mmcblk0p8 /userdata ext2 defaults 2
    Checking /dev/mmcblk0p8(ext2)
    /dev/mmcblk0p8 is in use.
    e2fsck: Cannot continue, aborting.
Mounting /dev/mmcblk0p8(ext2) on /userdata
Log saved to /tmp/mountall.log
Starting system message bus: done
Starting network: OK
No state is present for card Loopback
Found hardware: “Loopback” “Loopback Mixer” “” “” “”
Hardware is initialized using a generic method
isp sensor is os04a10,enable HDR
[ 5.828696] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 5.828748] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 5.828769] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 5.828788] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 5.828807] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 5.828841] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 5.828858] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 5.837612] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 5.837680] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 5.837703] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 5.837722] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 5.837741] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 5.837789] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 5.83c7a8m1e1r]a _rmax_width=
camera_max_heighto=
insmod NPU modules: [ 5.861932] galcore: loading out-of-tree module taints kernel.
killall: adbd: no process killed
[ 5.869965] galcore: npu init.
[ 5.870829] galcore: start npu probe.
[ 5.870971] galcore ffbc0000.npu: Linked as a consumer to regulator.8
[ 5.871261] npu: platform_get_irq irq = 66
[ 5.871281] npu: platform_get_resource registerMemBase = ffbc0000, registerMemSize = 4000
[ 5.871295] Galcore version 6.4.3.5.293908
[ 5.871305] Galcore options:
[ 5.871313] irqLine = 66
[ 5.871321] registerMemBase = 0xFFBC0000
[ 5.871329] registerMemSize = 0x00004000
[ 5.871337] contiguousSize = 0x00400000
[ 5.871345] contiguousBase = 0x0
[ 5.871352] externalSize = 0x00000000
[ 5.871360] externalBase = 0x0
[ 5.871367] exclusikillall: ntpd: no process killed
veSize = 0x00000000
[ 5.871376] exclusiveBase = 0x0
[ 5.871384] bankSize = 0x00000000
[ 5.871392] fastClear = -1
[ 5.871399] compression = 15
[ 5.871406] powerManagement = 1
[ 5.871413] baseAddress = 0x00000000
[ 5.871420] physSize = 0x00000000
[ 5.871427] recovdbserver[789]: dbserver version 1.0
ery = 1
[ 5.871435] stuckDump = 0
[ 5.871442] gpuProfiler = 1
[ 5.871450] userClusterMask = 0x0
[ 5.871457] GPU smallBatch = 1
[ 5.871465] allMapInOne = 1
[ 5.871472] irqs =
[ 5.871474] 66,
[ 5.871480] -1,
[ 5.871485] -1,
[ 5.871490] -1,
[ 5.871498] -1,
[ 5.871505] -1,
[ 5.871512] -1,
[ 5.871519] -1,
[ 5.871527] -1,
[ 5.871572] -1,
[ 5.871582]
[ 5.871596] registerBases =
[ 5.871598] 0xFFBC0000,
[ 5.871606] 0x00000000,
[ 5.871613] 0x00000000,
[ 5.871620] 0x00000000,
[ 5.871627] 0x00000000,
[ 5.871634] 0x00000000,
[ 5.871642] 0x00000000,
[ 5.871649] 0x00000000,
[ 5.871655] 0x00000000,
[ 5.871662] 0x00000000,
[ 5.871669]
[ 5.871680] registerSizes =
[ 5.871682] 0x00004000,
[ 5.871689] 0x00000000,
[ 5.871696] 0x00000000,
[ 5.871703] 0x00000000,
[ 5.871708] 0x00000000,
[ 5.871713] 0x00000000,
[ 5.871719] 0x00000000,
[ 5.871727] 0x00000000,
[ 5.871734] 0x00000000,
[ 5.871741] 0x00000000,
[ 5.871748]
[ 5.871761] chipIDs =
[ 5.871763] 0xFFFFFFFF,
[ 5.871770] 0xFFFFFFFF,
[ 5.871777] 0xFFFFFFFF,
[ 5.871784] 0xFFFFFFFF,
[ 5.871792] 0xFFFFFFFF,
[ 5.871799] 0xFFFFFFFF,
[ 5.871806] 0xFFFFFFFF,
[ 5.871813] 0xFFFFFFFF,
[ 5.871820] 0xFFFFFFFF,
[ 5.871828] 0xFFFFFFFF,
[ 5.871834]
[ 5.871845] core 0 internal sRAMBases =
[ 5.871847] 0xFFFFFFFFFFFFFFFF,
[ 5.871854] 0xFFFFFFFFFkillall: connmand: no procesFs killed
FFFFFF,
[ 5.871861]
[ 5.871873] core 1 internal sRAMBases =
[ 5.871874] 0xFFFFFFFFFFFFFFFF,
[ 5.871882] 0xFFFFFFFFFFFFFFFF,
[ 5.871890]
[ 5.871900] core 2 internal sRAMBases =
[ 5.871902] 0xFFFFFFFFFFFFFFFF,
[ 5.871909] 0xFFFFFFFFFFFFFFFF,
[ 5.871916]
[ 5.871927] core 3 internal sRAMBases =
[ 5.8719media get entity by name: rkcif-lvds-subdev is null
media get enti2ty by name: rkcif-lite-lvds-subdev8 is null
[ 5.871936] 0xFFFFFFFFFFFFFFFF,
[ 5.871941]
[ 5.871949] core 4 intermedia get entity by name: rknaisp-mpfbc-subdev is null
medlia get entity by name: rkisp _dmapath is null
media get estity by name: rockchip-mipi-dphy-rx is null
AMBases =
[ 5.871950] 0xFFFFFFFFFFFFFFFF,
[ 5.871958] 0xFFFFFFFFFFFFFFFF,
[ 5.871965]
[ 5.871976] core 5 internal sRAMBases[ispserver][parse_args]:## ne ed_sync_db: 0
[ispserver][rk=aiq_get_media_info]:get cam_n um 0
dia_info]:media get sys_path:
/dev/media0
5.871977] 0xFFFFFFFFFFmFeFdFiFaF Fg,e t
e[ntity by name: rkisp-isp-subde v is null
dbserver[789]: [d bserver][main]:dbserver init finish
media get entity by name: rkisp-i5.87nput-params is null
media get entity1985] 0xFFFFFFFFFFFFFFFF,
[ 5.871991]
[ by name: rkisp-statistics is null
media get entity by name: rkispp_5.input_params is n872002] core 6 internal sRAMBases ull
[ispserver][rkaiq_get_media_info]:media get sys_path: /dev/media1=
[ 5.872004] 0xFFFFFFFFFFFFFFFF,
[ 5.872011] 0xFFFF[ispserver][rkaiq_get_devname]:get rkisp-isp-subdev devnameF: /dev/v4l-subdev3
[ispserver][rkaiq_get_devname]:get rkisFp-input-params devname: /dev/video15
[ispserver][rkaiq_get_devname]:get rkisp-statistics devname: /dev/video14
dbserver[789]:F [dbserver][main]:dbserver dbFus register finish
media get entity by name: rkispp_input_params is null
[ispserver][rkaiq_geFt_media_info]:media get sys_path: /dev/media2
FFFFFFF,
[ 5.872018]
[ 5.872028] cor[espserver][rkaiq_get_devname]: get rkispp_input_params devn7ame: /dev/video23
killall: dropbear: no process killed
[ispserver][rkaiq_get_media_info] internal sRAMBases =
[ :media get sys_path: /dev/media3
[ispserver][rkaiq_get_media_info]5.872030] 0xFFFFFFFFFFFFFFFF,
[ 5.87203:media get sys_path: /dev/media74
OK
[ispserver][rkaiq_get_media_info]:media get sys_path: /dev/media5
[ispserver][rkai] 0xFFFFFFFFFFFFFFFF,
[ 5.872045] q_get_media_info]:media get sys_path: /dev/media6
][rkaiq_get_media_info]:media get sys_path: /dev/media7
[ [ispserver][rkaiq_get_media_in fo]:media get sys_path: /dev/media8
[ispserver][rkaiq_get_media_info]:media get sys_path: / ev/media9
[ispserver][rkaiq_g5et_media_info]:cam id 0 find_sensor 0 find_isp 0 find_ispp 0
[ispserver][rkaiq_get_media_i.nfo]:cam id 1 find_sensor 0 find_isp 1 find_ispp 1
872056] open system watchdog
core 8 internal sRAMBases =
[ 5.872057] 0xFFFFFFFFFFFFFFFF,
[ 5.872064] 0xFFFFFFFFFFFFFFFF,
[ 5.872071]
[ 5.872082] core 9 internal sRAMBases =
[ 5.872084] 0xFFFFFFFFFFFFFFFF,
[ 5.872091] 0xFFFFFFFFFFFFFFFF,
[ 5.872098]
[ 5.872108] External sRAMBases =
[ 5.872110] 0xffffffffffffffff,
[ 5.872118] 0xffffffffffffffff,
[ 5.872124]
[ 5.872135] mmuPageTablePool = 1
[ 5.872142] mmuDynamic[ispserver][main]:call_fun_ipc_deMmo_server init
ap = 1
[ 5.872150] isrPoll = 0x00000000
[ 5.872156] Build options:
[ 5.872164] gcdGPU_TIMEOUT = 20000
[ 5.872169] gcdGPU_2D_TIMEOUT = 4000
[ 5.872175] gcdINTERRUPT_STATISTIC = 1
[ 5.875593] Galcore Info: ContiguousBase=0x7f950000 ContiguousSize=0x400000
[ 5.881940] Galcore Info: MMU mapped core 0 SRAM[0] hardware virtual address=0x400000 size=0x40000
[ 5.881973] Galcore Info: MMU mapped core 0 SRAM[1] hardware virtual address=0x440000 size=0x40000
[ 5.883342] NN flop resetting…
[ 5.889308] galcore ffbc0000.npu: Init npu devfreq
[ 5.889369] galcore ffbc0000.npu: bin=0
[ 5.889465] galcore ffbc0000.npu: leakage=0.875
[ 5.906216] galcore ffbc0000.npu: temp=39700, pvtm=95344 (95344 + 0)
[ 5.906501] galcore ffbc0000.npu: pvtm-volt-sel=1
[ 5.906565] galcore ffbc0000.npu: bin-scale=23
[ 5.907334] galcore ffbc0000.npu: avs=0
[ 5.908637] galcore ffbc0000.npu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 5.908673] galcore ffbc0000.npu: failed to read out thermal zone (-22)
[ 5.908769] galcore ffbc0000.npu: failed to find power_model node
[ 5.908788] galcore ffbc0000.npu: failed to initialize power model
[ 5.914539] ircut cam_ircut: driver version: 00.01.00
[ 5.915719] ircut cam_ircut: failed get pulse-width,use dafult value 100
[ 5.915813] ircut cam_ircut: Failed to get ircut-open-gpios
killall: rknn_server: no process killed
[root@RV1126_RV1109:/]# umount: can’t unmount /sys/kernel/config: Invalid argument
[ 6.273851] using random self ethernet address
[ 6.273903] using random host ethernet address
config uvc and rndis…
[ 6.292631] file system registered
adb on++++++ 3
umount: can’t unmount /dev/usb-ffs/adb: No such file or directory
[ 6.341798] read descriptors
[ 6.341854] read strings
sh: write error: No such device
config usb0 IP…
ifconfig: SIOCSIFADDR: No such device
ifconfig: SIOCGIFFLAGS: No such device
usb irq:
/oem/aicamera.sh: line 78: can’t create /proc/irq//smp_affinity_list: nonexistent directory
Rga built version:1.04 1aab590+2021-04-20 18:18:52
[uvc_app][main]:VERSION:SDK V1.33 Apr 20 2021 19:27:55 media_set:0x1
uvc_app[905]: uvc_app version 1.0.0
media get entity by name: rkcif-lite-lvds-subdev is null
media get entity by name: rkisp-mpfbc-subdev is null
media get entity by name: rkisp_dmapath is null
media get entity by name: rockchip-mipi-dphy-rx is null
mpp[906]: [(null)][main]:parse_args done!
mpp[906]: [(null)][main]:create aiserver instance done
mpp[906]: [shm_control_uvc][initialize]:shmWriteQueue InitForWrite(ret=1)
mpp[906]: [shm_control_uvc][initialize]:shmReadQueue InitForRead(ret=1)
mpp[906]: [(null)][setupTaskGraph]:AIServer: mFlagDBusServer = 1
mpp[906]: [shm_control_uvc][debugLoop]:enter
mpp[906]: [(null)][setupTaskGraph]:AIServer: mFlagDBusDbServer = 0
mpp[906]: [(null)][setupTaskGraph]:AIServer: RegisterMediaControl start ok
rockit log level 3
RTUVCGraph 09:00:10-017 {setCameraParams :472} Cannot get max width from getenv, use default(2560)
RTUVCGraph 09:00:10-018 {setCameraParams :478} Cannot get max height from getenv, use default(1440)
uvc_app[905]: [uvc_app][check_uvc_video_id]:Please configure uvc…
[eptz]:EPTZ VERSION 1.0.3 ,log_level[2]
[eptz]:read /etc/eptz_zoom.conf file…
[eptz]:read clip_ratio_data from 720 file
[eptz]:eptz_geometric_support status 0
[eptz]:eptzConfigInit successful
smart_display_service[981]: smart_display_service version 1.0.0
smart_display_service[981]: [smart_display_service][ShmControl]:read shm success
smart_display_service[981]: [smart_display_service][rndis_start_tcp_threads]:rndis_start_tcp_threads mEventRvThread enter
smart_display_service[981]: [smart_display_service][send_process_loop]:—send_process_loop
mpp[906]: [AISceneDirector][setup]:preload scene nn resource in
mpp[906]: [AISceneDirector][setup]:preload scene nn resource ok
mpp[906]: [(null)][main]:aiserver->setupTaskGraph(); done
set governor ondemand ok
1.没搞清楚你的问题是什么,“购买的开发板下载网址的目标码无法启动”什么意思?
2.看着你2楼发的log,已经成功启动了
2.看着你2楼发的log,已 …
成功启动了,但是串口输入没反应
zhou2008_5 发表于 2021-6-17 14:30
成功启动了,但是串口输入没反应
Starting dnsmasq:
dnsmasq: failed to create listening socket for port 53: Address already in use
FAIL
Exiting, name server cannot be used: Temporary failure in name resolution (-3) 4 Aug 09:01:12 ntpdate[890]: name server cannot be used: Temporary failure in name resolution (-3)
[ 7.910899] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 7.919022] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 7.927462] rockchip-mipi-dphy-rx: No link between dphy and sensor
net.core.wmem_max = 1572864
dbserver[911]: dbserver version 1.0
SQL error: no such table: NetworkVersion
SQL error: no such table: NetworkIP
SQL error: no such table: NetworkService
SQL error: no such table: NetworkPower
SQL error: no such table: ntp
SQL error: no such table: zone
SQL error: no such table: port
netserver[917]: netserver version 1.0
netserver[917]: [main.c][main]:The path of nginx.conf is not specified, use the default path
DBus::Error - The name rockchip.dbserver was not provided by any .service files
storage_manager[924]: storage_manager version 1.0
storage_manager[924]: [main.c][main_init]:storage_manager init
storage_manager[924]: [db_monitor.c][db_monitor_init]:dbserver_get_storage_config, wait dbserver.
SQL error: no such table: StorageVersion
SQL error: no such table: StorageDiskPath
SQL error: no such table: StorageMediaFolder
SQL error: no such table: StorageConfig
SQL error: no such table: StoragePlanSnap
SQL error: no such table: StorageAdvancePara
SQL error: no such table: MediaVersion
SQL error: no such table: video
SQL error: no such table: video_advanced_enc
SQL error: no such table: video_region_clip
SQL error: no such table: audio
SQL error: no such table: stream_url
SQL error: no such table: image_scenario
SQL error: no such table: image_adjustment
SQL error: no such table: image_exposure
SQL error: no such table: image_night_to_day
SQL error: no such table: image_blc
SQL error: no such table: image_white_blance
SQL error: no such table: image_enhancement
SQL error: no such table: image_video_adjustment
SQL error: no such table: normalized_screen_size
SQL error: no such table: osd
SQL error: no such table: roi
SQL error: no such table: profile
SQL error: no such table: video_source
SQL error: no such table: video_source_configuration
SQL error: no such table: metadata
start rknn server, version:1.6.0 (159d2d3 build: 2021-01-12 17:29:40)
I NPUTransfer: Starting NPU Transfer Server, Transfer version 2.1.0 (b5861e7@2020-11-23T11:51:07)
SQL error: no such table: SystemVersion
SQL error: no such table: SystemDeviceInfo
SQL error: no such table: SystemPara
SQL error: no such table: SystemUser
SQL error: no such table: SystemDiscovery
SQL error: no such table: SystemScopes
SQL error: no such table: EventVersion
SQL error: no such table: EventTriggers
SQL error: no such table: EventSchedules
SQL error: no such table: RegionalInvasion
SQL error: no such table: MoveDetection
SQL error: no such table: FaceConfig
SQL error: no such table: FaceList
SQL error: no such table: FaceSnapshotRecord
SQL error: no such table: FaceControlRecord
SQL error: no such table: SmartCover
SQL error: no such table: SmartCoverOverlay
SQL error: no such table: Notification
SQL error: no such table: PeripheralsVersion
SQL error: no such table: PeripheralsRelay
SQL error: no such table: PeripheralsWeigen
SQL error: no such table: PeripheralsFillLight
dbserver[911]: [dbserver][main]:dbserver init finish
dbserver[911]: [dbserver][main]:dbserver dbus register finish
storage_manager[924]: [main.c][main_init]:storage_manager init finish
storage_manager[924]: [manage.c][signal_update_media_path]:storage_manager signal_update_media_path, { }
netserver[917]: [netctl.c][populate_vpnconnection_hash]:Error getting VPN connections: The name net.connman.vpn was not provided by any .service files
ispserver[943]: ispserver version 1.0.0
ispserver[943]: [ispserver][rkaiq_get_media_info]:get cam_num 0
ispserver[943]: [ispserver][rkaiq_get_media_info]:media get sys_path: /dev/media0
media get entity by name: rkisp-isp-subdev is null
media get entity by name: rkisp-input-params is null
media get entity by name: rkisp-statistics is null
ispserver[943]: [ispserver][rkaiq_get_media_info]:media get sys_path: /dev/media1
ispserver[943]: [ispserver][rkaiq_get_devname]:get rkisp-isp-subdev devname: /dev/v4l-subdev3
ispserver[943]: [ispserver][rkaiq_get_devname]:get rkisp-input-params devname: /dev/video15
ispserver[943]: [ispserver][rkaiq_get_devname]:get rkisp-statistics devname: /dev/video14
ispserver[943]: [ispserver][rkaiq_get_media_info]:media get sys_path: /dev/media2
ispserver[943]: [ispserver][rkaiq_get_devname]:get rkispp_input_params devname: /dev/video23
ispserver[943]: [ispserver][rkaiq_get_media_info]:media get sys_path: /dev/media3
ispserver[943]: [ispserver][rkaiq_get_media_info]:media get sys_path: /dev/media4
ispserver[943]: [ispserver][rkaiq_get_media_info]:media get sys_path: /dev/media5
ispserver[943]: [ispserver][rkaiq_get_media_info]:media get sys_path: /dev/media6
ispserver[943]: [ispserver][rkaiq_get_media_info]:media get sys_path: /dev/media7
ispserver[943]: [ispserver][rkaiq_get_media_info]:media get sys_path: /dev/media8
ispserver[943]: [ispserver][rkaiq_get_media_info]:media get sys_path: /dev/media9
ispserver[943]: [ispserver][rkaiq_get_media_info]:cam id 0 find_sensor 0 find_isp 1 find_ispp 1
ispserver[943]: [ispserver][rkaiq_get_media_info]:cam id 1 find_sensor 0 find_isp 0 find_ispp 0
ispserver[943]: [ispserver][main]:call_fun_ipc_demo_server init
card0-DSI-1
find display
not HDMI
card 0: rockchiprk809co [rockchip,rk809-codec], device 0: ff800000.i2s-rk817-hifi rk817-hifi-0 [ff800000.i2s-rk817-hifi rk817-hifi-0]
find sound card
ash: 1: unknown operand
Filesystem volume name: media
prepare_part /userdata/media
fsck /userdata/media
media was not cleanly unmounted, check forced.
Pass 1: Checking inodes, blocks, and sizes
Rga built version:1.04 1e7d09e+2021-04-28 18:09:49
mpp[951]: [mediaserver.cpp][parse_args]:mediaserver_log_level is 2
##RKMEDIA Log level: 2
[RKMEDIA][SYS][Info]:text is all=2
[RKMEDIA][SYS][Info]:module is all, log_level is 2
mediaserver[951]: mediaserver version 1.0.0
mediaserver[264]: start config: /oem/usr/share/mediaserver/rv1109/ipc-display-firefly.conf
mediaserver[951]: [flow_manager.cpp][ConfigParse]:flow manager parse config
mediaserver[951]: [flow_parser.cpp][SyncReOpenFlow]:flowunit: source_1 copy pipe id 0, flow id 0
mediaserver[951]: [flow_parser.cpp][SyncReOpenFlow]:flowunit: audio_enc_0 copy pipe id 0, flow id 0
mediaserver[951]: [flow_parser.cpp][GetPipeIndex]:find type 1 in pipe_index 0
mediaserver[951]: [flow_parser.cpp][GetPipeIndex]:find type 1 in pipe_index 1
mediaserver[951]: [flow_parser.cpp][GetPipeIndex]:find type 14 in pipe_index 1
mediaserver[951]: [flow_parser.cpp][GetPipeIndex]:find type 1 in pipe_index 2
mediaserver[951]: [flow_unit.cpp][SetEncodeType]:Not Support
mediaserver[951]: [flow_unit.cpp][SetSampleFormat]:Not Support
mediaserver[951]: [flow_manager.cpp][SyncDBConfig]:select region invade database id 0
mediaserver[951]: [flow_db_protocol.cpp][GetMoveDetectRegions]:md_pipe_index is 1
mediaserver[951]: [flow_db_protocol.cpp][GetMoveDetectRegions]:pipe[0] no found md_flow
mediaserver[951]: [flow_manager.cpp][SyncDBConfig]:md_roi_rect is null
mediaserver[951]: [flow_db_protocol.cpp][GetMoveDetectRegions]:md_flow belongs to the pipe, height is 480, width is 640
mediaserver[951]: [flow_db_protocol.cpp][GetMoveDetectRegions]:move detection is disabled
mediaserver[951]: [flow_db_protocol.cpp][GetMoveDetectRegions]:pipe[2] no found md_flow
mediaserver[951]: [flow_db_protocol.cpp][GetMoveDetectRegions]:pipe[3] no found md_flow
mediaserver[951]: [flow_manager.cpp][SyncDBConfig]:select smart_cover_db { “iReturn”: 0, “sErrMsg”: “”, “jData”: [ { “id”: 0, “iFaceEnabled”: 0, “iFaceRecognitionEnabled”: 0, “iStreamOverlayEnabled”: 0, “iImageOverlayEnabled”: 0, “iInfoOverlayEnabled”: 0, “sTargetImageType”: “head”, “iWidthRatio”: 10, “iFaceHeightRatio”: 10, “iBodyHeightRatio”: 10, “sImageQuality”: “good” } ] }
mediaserver[951]: [flow_manager.cpp][SyncDBConfig]:select smart_cover_db { “iReturn”: 0, “sErrMsg”: “”, “jData”: }
mediaserver[951]: [flow_manager.cpp][SyncDBConfig]:select rtsp_db { “iReturn”: 0, “sErrMsg”: “”, “jData”: [ { “id”: 3, “sProtocol”: “RTSP”, “iPortNo”: 554 } ] }
mediaserver[951]: [flow_manager.cpp][SyncDBConfig]:select rtmp_db { “iReturn”: 0, “sErrMsg”: “”, “jData”: [ { “id”: 4, “sProtocol”: “RTMP”, “iPortNo”: 1935 } ] }
mediaserver[951]: [flow_parser.cpp][SyncRTMPDBData]:rtmp old path is rtmp://127.0.0.1:1935/live/substream
mediaserver[951]: [flow_parser.cpp][SyncRTMPDBData]:rtmp new path is rtmp://127.0.0.1:1935/live/substream
mediaserver[951]: [flow_manager.cpp][SyncDBConfig]:select scenario_db { “iReturn”: 0, “sErrMsg”: “”, “jData”: [ { “id”: 0, “sScenario”: “normal” } ] }
mediaserver[951]: [flow_manager.cpp][SyncDBConfig]:select enhance_db { “iReturn”: 0, “sErrMsg”: “”, “jData”: [ { “id”: 0, “sNoiseReduceMode”: “default”, “iDenoiseLevel”: 50, “iSpatialDenoiseLevel”: 50, “iTemporalDenoiseLevel”: 50, “sDehaze”: “close”, “iDehazeLevel”: 0, “sDIS”: “close”, “sGrayScaleMode”: “[0-255]”, “iImageRotation”: 0, “sFEC”: “close”, “sDistortionCorrection”: “close”, “iFecLevel”: 100, “iLdchLevel”: 0 } ] }
mediaserver[951]: [flow_parser.cpp][GetPipeIndex]:find type 1 in pipe_index 3
mediaserver[951]: [flow_parser.cpp][SyncSmartEncorde]:smart is close, disable target and min bps
mediaserver[951]: [flow_manager.cpp][CreatePipes]:flow manager create flow pipe
[RKMEDIA][SYS][Info]:RKAIQ: parsing /dev/media0
[RKMEDIA][SYS][Info]:RKAIQ: parsing /dev/media1
[RKMEDIA][SYS][Info]:RKAIQ: model(rkisp0): isp_info(0): isp-subdev entity name: /dev/v4l-subdev3
[RKMEDIA][SYS][Info]:RKAIQ: parsing /dev/media2
[RKMEDIA][SYS][Info]:RKAIQ: model(rkispp0): ispp_info(0): ispp-subdev entity name: /dev/v4l-subdev0
[RKMEDIA][SYS][Info]:#V4l2Stream: camraID:0, Device:rkispp_m_bypass
[RKMEDIA][SYS][Warn]:camera_id: 0, chn: rkispp_m_bypass
[RKMEDIA][SYS][Info]:#V4l2Stream: camera id:0, VideoNode:
[RKMEDIA][SYS][Error]:V4L2-CTX: open failed No such file or directory
[RKMEDIA][VI][Info]:Create stream v4l2_capture_stream failed
[RKMEDIA][VI][Info]:#SourceStreamFlow: stream off…
[RKMEDIA][VI][Info]:#SourceStreamFlow: read thread exit sucessfully!
[RKMEDIA][VI][Info]:#SourceStreamFlow: stream reset sucessfully!
mediaserver[951]: [flow_pipe.cpp][CreateFlow]:Create flow source_stream failed
mediaserver[951]: [flow_pipe.cpp][CreateFlow]:flow param :
name=v4l2_capture_stream
width=2688
height=1520
virtual_width=2688
virtual_height=1520
device=rkispp_m_bypass
frame_num=6
height=1520
output_data_type=image:nv12
use_libv4l2=1
v4l2_capture_type=VIDEO_CAPTURE
v4l2_mem_type=MEMORY_DMABUF
virtual_height=1520
virtual_width=2688
width=2688
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
media: 22/327040 files (0.0% non-contiguous), 23097/1306619 blocks
[ 12.082047] EXT4-fs (mmcblk0p9): mounting ext2 file system using the ext4 subsystem
[ 12.093455] EXT4-fs (mmcblk0p9): mounted filesystem without journal. Opts: (null)
storage_manager[924]: [uevent_monitor.c][uevent_monitor_thread]:uevent_monitor_thread /dev/mmcblk0p9 change
Starting input-event-daemon: input-event-daemon: Start parsing /etc/input-event-daemon.conf…
input-event-daemon: Adding device: /dev/input/event0…
input-event-daemon: Adding device: /dev/input/event1…
input-event-daemon: Adding device: /dev/input/event2…
input-event-daemon: Start listening on 3 devices…
done
[root@RV1126_RV1109:/]# storage_manager[924]: [manage.c][file_manage_thread]:MSG_CMD_DEV_CHANGE /dev/mmcblk0p9
storage_manager[924]: [manage.c][signal_update_disks_status]:storage_manager signal_update_disks_status, [ { “id”: 3, “sMountPath”: “/userdata/media”, “sName”: “Emmc”, “sDev”: “/dev/block/by-name/media”, “sAttributes”: “rw,relatime”, “sType”: “ext2”, “iStatus”: 1, “iMediaSize”: 0, “iTotalSize”: 5144332, “iFreeSize”: 5134088, “iFormatStatus”: 0, “iFormatProg”: 0, “sFormatErr”: “” } ]
串口输入没反应一般就是串口接反了,3条线 gnd tx rx ,tx在中间,所以接翻了输出也会有的,但是输入就不行
tx、rx反了不正常打印出信息了,那上面的输出信息,终端输入没反应了
那就把你的串口线反转试一下呀
