使用工具SD_Firmware_Tool1.56 刷RK Firmware到SD卡启动后一直都Recovery mode
使用下载的RK Firmware如下:
ROC-RK3328-CC-UBUNTU18.04-GPT-20200730-1744.img
ROC-RK3328-CC-UBUNTU18.04-GPT-20190430-1052.img
使用SDK按照步骤编译打包后与下载的包运行结果一致,实际加载的看上去是一个ramdisk(任何修改后重启丢失),而不是SD卡上的rootfs(ext4),感觉是SDK的默认的一些配置与这个板子不匹配。
想要确认下这个具体是什么原因,如何修正。
运行的log如下:
DDR version 1.16 20190528
DDR4
333MHz
Bus Width=32 Col=10 Bank=4 Bank Group=2 Row=16/16 CS=2 Die Bus-Width=16 Size=4096MB
ddrconfig:19
Boot1 Release Time: May 13 2019 17:34:36, version: 2.50
ChipType = 0x11, 246
mmc2:cmd1,400
emmc reinit
mmc2:cmd1,400
emmc reinit
mmc2:cmd1,400
SdmmcInit=2 1
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=30436MB
FwPartOffset=2000 , 0
run on sd0
StorageInit ok = 27732
Raw SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
atags_set_bootdev: ret:(0)
GPT part: 2, name: misc, start:0x8000, size:0x2000
GPT part: 3, name: boot, start:0xa000, size:0x10000
GPT part: 4, name: recovery, start:0x1a000, size:0x10000
GPT part: 5, name: backup, start:0x2a000, size:0x10000
GPT part: 6, name: rootfs, start:0x5a000, size:0x588400
GPT part: 7, name: userdata, start:0x5e2400, size:0x358ffdf
find part:uboot OK. first_lba:0x4000.
find part:trust OK. first_lba:0x6000.
LoadTrust Addr:0x6000
No find bl30.bin
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0xd18e4
RunBL31 0x10000
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-230-g6c76e8a9 #189 Mon Nov 18 06:49:51 UTC 2019 aarch64)
INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.4
U-Boot 2017.09 (Jun 19 2021 - 17:36:40 +0800)
Model: Firefly ROC-RK3328-CC
PreSerial: 2
DRAM: 4 GiB
Sysmem: init
Relocation Offset is: fcbf2000
no mmc device at slot 1
do_rkimg_test found IDB in SDcard
rksdmmc@ff500000: 1 (SD), rksdmmc@ff520000: 0
Bootdev(atags): mmc 1
MMC1: Legacy, 50Mhz
PartType: EFI
boot mode: recovery
Load FDT from recovery part
DTB: rk-kernel.dtb
start get public phy
use default hdmi phy table
inno hdmi phy init success, save it
Warn: can’t find connect driver
In: serial
Out: serial
Err: serial
enter Recovery mode!
xfer: num: 2, addr: 0x50
mode:1920x1080
CEA mode used vic=16
final pixclk = 148500000 tmdsclk = 148500000
start Inno HDMI PHY Power On
tmdsclock = 148500000; chipversion = 2
CLK: (sync kernel. arm: enter 600000 KHz, init 600000 KHz, kernel 0N/A)
apll 400000 KHz
dpll 664000 KHz
cpll 1200000 KHz
gpll 491009 KHz
npll 600000 KHz
armclk 600000 KHz
aclk_bus 150000 KHz
hclk_bus 75000 KHz
pclk_bus 75000 KHz
aclk_peri 150000 KHz
hclk_peri 75000 KHz
pclk_peri 75000 KHz
Net:
Warning: ethernet@ff540000 (eth0) using random MAC address - 7e:ad:53:15:44:dd
eth0: ethernet@ff540000
Fdt Ramdisk skip relocation
Booting IMAGE kernel at 0x00280000 with fdt at 0x8300000…
## Booting Android Image at 0x0027f800 …
Kernel load addr 0x00280000 size 21265 KiB
RAM disk load addr 0x0a200000 size 6741 KiB
## Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
XIP Kernel Image … OK
Using Device Tree in place at 0000000008300000, end 0000000008315539
Adding bank: 0x0a200000 - 0xff000000 (size: 0xf4e00000)
Can’t find file:logo_kernel.bmp
Total: 4844.867 ms
[ 0.000000] Linux version 4.4.194 (ubuntu@ubuntu-VirtualBox) (firefly: 5ec9d42e6faa76c084b451ee3783601547339a60 update) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #1 SMP Sat Jun 19 17:29:02 CST 2021
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0fef1f000 s46312 r8192 d31512 u86016
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1019976
[ 0.000000] Kernel command line: storagemedia=sd androidboot.storagemedia=sd androidboot.mode=normal androidboot.slot_suffix= androidboot.serialno=cc18e729917efda1 rockchip_jtag ro rootwait earlyprintk=uart8250-32bit,0xff130000 swiotlb=1 kpti=0 console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1
[ 0.000000] software IO TLB: mapped [mem 0xfeed6000-0xfef16000] (0MB)
[ 0.000000] Memory: 4041532K/4145152K available (13182K kernel code, 1808K rwdata, 5076K rodata, 1152K init, 1975K bss, 103620K reserved, 0K cma-reserved)
[ 0.000000] .init : 0xffffff8009260000 - 0xffffff8009380000 ( 1152 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008d60000 ( 13184 KB)
[ 0.000000] .rodata : 0xffffff8008d60000 - 0xffffff8009260000 ( 5120 KB)
[ 0.000000] .data : 0xffffff8009380000 - 0xffffff8009544008 ( 1809 KB)
[ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc3fc0000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc0ff000000 ( 4078 MB)
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000009] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.001498] Console: colour dummy device 80x25
[ 0.001536] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.001560] pid_max: default: 32768 minimum: 301
[ 0.001688] Security Framework initialized
[ 0.001796] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.001813] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002998] Initializing cgroup subsys io
[ 0.003027] Initializing cgroup subsys memory
[ 0.003073] Initializing cgroup subsys devices
[ 0.003102] Initializing cgroup subsys freezer
[ 0.003123] Initializing cgroup subsys perf_event
[ 0.003149] Initializing cgroup subsys net_prio
[ 0.003168] Initializing cgroup subsys pids
[ 0.003212] ftrace: allocating 48310 entries in 189 pages
[ 0.145302] sched-energy: CPU device node has no sched-energy-costs
[ 0.145332] Invalid sched_group_energy for CPU0
[ 0.145341] CPU0: update cpu_capacity 1024
[ 0.145432] ASID allocator initialised with 32768 entries
[ 0.152511] Detected VIPT I-cache on CPU1
[ 0.152590] Invalid sched_group_energy for CPU1
[ 0.152596] CPU1: update cpu_capacity 1024
[ 0.152602] CPU1: Booted secondary processor [410fd034]
[ 0.153500] Detected VIPT I-cache on CPU2
[ 0.153559] Invalid sched_group_energy for CPU2
[ 0.153566] CPU2: update cpu_capacity 1024
[ 0.153574] CPU2: Booted secondary processor [410fd034]
[ 0.154457] Detected VIPT I-cache on CPU3
[ 0.154510] Invalid sched_group_energy for CPU3
[ 0.154516] CPU3: update cpu_capacity 1024
[ 0.154522] CPU3: Booted secondary processor [410fd034]
[ 0.154649] Brought up 4 CPUs
[ 0.154721] SMP: Total of 4 processors activated.
[ 0.154737] CPU features: kernel page table isolation forced OFF by command line option
[ 0.154751] CPU features: detected feature: 32-bit EL0 Support
[ 0.154768] CPU: All CPU(s) started at EL2
[ 0.154818] alternatives: patching kernel code
[ 0.155171] Invalid sched_group_energy for CPU3
[ 0.155186] Invalid sched_group_energy for Cluster3
[ 0.155198] Invalid sched_group_energy for CPU2
[ 0.155211] Invalid sched_group_energy for Cluster2
[ 0.155223] Invalid sched_group_energy for CPU1
[ 0.155232] Invalid sched_group_energy for Cluster1
[ 0.155243] Invalid sched_group_energy for CPU0
[ 0.155253] Invalid sched_group_energy for Cluster0
[ 0.156235] devtmpfs: initialized
[ 0.188894] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.188943] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.189735] xor: measuring software checksum speed
[ 0.199705] 8regs : 1080.000 MB/sec
[ 0.209782] 8regs_prefetch: 968.000 MB/sec
[ 0.219862] 32regs : 1456.000 MB/sec
[ 0.229944] 32regs_prefetch: 1224.000 MB/sec
[ 0.229956] xor: using function: 32regs (1456.000 MB/sec)
[ 0.230003] pinctrl core: initialized pinctrl subsystem
[ 0.233888] Failed to find legacy iommu devices
[ 0.234788] NET: Registered protocol family 16
[ 0.240175] cpuidle: using governor ladder
[ 0.244210] cpuidle: using governor menu
[ 0.244255] Registered FIQ tty driver
[ 0.245607] vdso: 2 pages (1 code @ ffffff8008d66000, 1 data @ ffffff8009384000)
[ 0.245668] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.245909] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.278891] genirq: Setting trigger mode 8 for irq 178 failed (gic_set_type+0x0/0x64)
[ 0.338480] console [ttyFIQ0] enabled
[ 0.339252] Registered fiq debugger ttyFIQ0
[ 0.433882] raid6: int64x1 gen() 195 MB/s
[ 0.451189] raid6: int64x1 xor() 181 MB/s
[ 0.468334] raid6: int64x2 gen() 324 MB/s
[ 0.485404] raid6: int64x2 xor() 259 MB/s
[ 0.502661] raid6: int64x4 gen() 468 MB/s
[ 0.519767] raid6: int64x4 xor() 330 MB/s
[ 0.536977] raid6: int64x8 gen() 394 MB/s
[ 0.554146] raid6: int64x8 xor() 302 MB/s
[ 0.571304] raid6: neonx1 gen() 359 MB/s
[ 0.588508] raid6: neonx1 xor() 353 MB/s
[ 0.605637] raid6: neonx2 gen() 562 MB/s
[ 0.622806] raid6: neonx2 xor() 455 MB/s
[ 0.640008] raid6: neonx4 gen() 753 MB/s
[ 0.657204] raid6: neonx4 xor() 558 MB/s
[ 0.674356] raid6: neonx8 gen() 769 MB/s
[ 0.691521] raid6: neonx8 xor() 566 MB/s
[ 0.691902] raid6: using algorithm neonx8 gen() 769 MB/s
[ 0.692376] raid6: … xor() 566 MB/s, rmw enabled
[ 0.692826] raid6: using intx1 recovery algorithm
[ 0.693859] mpp venc_srv: mpp_probe enter
[ 0.694261] mpp venc_srv: init success
[ 0.697216] vcc_sd: regulator get failed, ret=-517
[ 0.698751] vcc_host_5v: supplied by vcc_sys
[ 0.702393] iommu: Adding device ff350000.vpu_service to group 0
[ 0.703029] iommu: Adding device ff351000.avsd to group 1
[ 0.703637] iommu: Adding device ff360000.rkvdec to group 2
[ 0.704233] iommu: Adding device ff330000.h265e to group 3
[ 0.704839] iommu: Adding device ff340000.vepu to group 4
[ 0.705417] iommu: Adding device ff370000.vop to group 5
[ 0.706659] rk_iommu ff350800.iommu: can’t get sclk
[ 0.707654] rk_iommu ff360480.iommu: can’t get aclk
[ 0.708108] rk_iommu ff360480.iommu: can’t get hclk
[ 0.708585] rk_iommu ff360480.iommu: can’t get sclk
[ 0.709361] rk_iommu ff330200.iommu: can’t get sclk
[ 0.710124] rk_iommu ff340800.iommu: can’t get sclk
[ 0.710780] rk_iommu ff373f00.iommu: can’t get sclk
[ 0.712076] SCSI subsystem initialized
[ 0.713226] usbcore: registered new interface driver usbfs
[ 0.713841] usbcore: registered new interface driver hub
[ 0.714465] usbcore: registered new device driver usb
[ 0.715082] media: Linux media interface: v0.10
[ 0.715556] Linux video capture interface: v2.00
[ 0.716101] pps_core: LinuxPPS API ver. 1 registered
[ 0.716552] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.717406] PTP clock support registered
[ 0.720196] Advanced Linux Sound Architecture Driver Initialized.
[ 0.721879] Bluetooth: Core ver 2.21
[ 0.722264] NET: Registered protocol family 31
[ 0.722670] Bluetooth: HCI device and connection manager initialized
[ 0.723260] Bluetooth: HCI socket layer initialized
[ 0.723706] Bluetooth: L2CAP socket layer initialized
[ 0.724191] Bluetooth: SCO socket layer initialized
[ 0.726155] rockchip-cpuinfo cpuinfo: Serial : cc18e729917efda1
[ 0.728628] clocksource: Switched to clocksource arch_sys_counter
[ 0.858481] NET: Registered protocol family 2
[ 0.859872] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.861018] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes)
[ 0.863239] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.864051] UDP hash table entries: 2048 (order: 5, 196608 bytes)
[ 0.864936] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes)
[ 0.866212] NET: Registered protocol family 1
[ 0.867327] RPC: Registered named UNIX socket transport module.
[ 0.867904] RPC: Registered udp transport module.
[ 0.868330] RPC: Registered tcp transport module.
[ 0.868772] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.870379] Trying to unpack rootfs image as initramfs…
[ 1.582793] Freeing initrd memory: 6740K
[ 1.585023] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 1.591237] Initialise system trusted keyring
[ 1.612900] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.615285] NFS: Registering the id_resolver key type
[ 1.615808] Key type id_resolver registered
[ 1.616193] Key type id_legacy registered
[ 1.616579] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 1.618912] ntfs: driver 2.1.32 [Flags: R/O].
[ 1.620248] fuse init (API version 7.23)
[ 1.621433] SGI XFS with security attributes, no debug enabled
[ 1.631839] NET: Registered protocol family 38
[ 1.632276] Key type asymmetric registered
[ 1.632693] Asymmetric key parser ‘x509’ registered
[ 1.633550] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.634504] io scheduler noop registered
[ 1.634901] io scheduler deadline registered
[ 1.635364] io scheduler cfq registered (default)
[ 1.639106] phy phy-ff450000.syscon:usb2-phy@100.1: Failed to get VBUS supply regulator
[ 1.641309] rockchip-u3phy ff470000.usb3-phy: Failed to get VBUS supply regulator
[ 1.644892] rockchip-u3phy ff470000.usb3-phy: Rockchip u3phy initialized successfully
[ 1.646916] inno-hdmi-phy ff430000.hdmiphy: phy had been powered up
[ 1.650095] ace test_init function.
[ 1.650593] ace test_init end.ret=0
[ 1.651399] radar end.ret=0
[ 1.653638] Module initialized.
[ 1.654405] rk-vcodec vpu_combo: no regulator for vcodec
[ 1.655288] rk-vcodec vpu_combo: failed on clk_get clk_cabac
[ 1.655844] rk-vcodec vpu_combo: failed on clk_get clk_core
[ 1.656443] platform ff350000.vpu_service: probe device
[ 1.657406] platform ff350000.vpu_service: drm allocator with mmu enabled
[ 1.659268] platform ff351000.avsd: probe device
[ 1.660277] platform ff351000.avsd: drm allocator with mmu enabled
[ 1.663283] rk-vcodec vpu_combo: could not find power_model node
[ 1.663860] rk-vcodec vpu_combo: init success
[ 1.664737] rk-vcodec ff360000.rkvdec: no regulator for vcodec
[ 1.665316] rk-vcodec ff360000.rkvdec: parent devfreq retry
[ 1.667020] probe device ff330000.h265e
[ 1.667882] mpp_dev ff330000.h265e: try to get iommu dev ffffffc0fa3ed810
[ 1.669071] mpp_dev ff330000.h265e: resource ready, register device
[ 1.670277] probe device ff340000.vepu
[ 1.671083] mpp_dev ff340000.vepu: try to get iommu dev ffffffc0fa3ee010
[ 1.672171] mpp_dev ff340000.vepu: resource ready, register device
[ 1.677288] dma-pl330 ff1f0000.dmac: Loaded driver for PL330 DMAC-241330
[ 1.677930] dma-pl330 ff1f0000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.680148] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 1.682286] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 1.684006] ff120000.serial: ttyS1 at MMIO 0xff120000 (irq = 12, base_baud = 1500000) is a 16550A
[ 1.687194] [drm] Initialized drm 1.1.0 20060810
[ 1.692407] [drm] Rockchip DRM driver version: v1.0.1
[ 1.693224] rockchip-drm display-subsystem: devfreq is not set
[ 1.694300] rockchip-vop ff370000.vop: failed to get vop register byname
[ 1.694976] rockchip-vop ff370000.vop: missing rockchip,grf property
[ 1.695880] rockchip-drm display-subsystem: bound ff370000.vop (ops 0xffffff8008e213f8)
[ 1.697081] i2c i2c-4: of_i2c: modalias failure on /hdmi@ff3c0000/ports
[ 1.697703] dwhdmi-rockchip ff3c0000.hdmi: registered DesignWare HDMI I2C bus driver
[ 1.698532] dwhdmi-rockchip ff3c0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (inno_dw_hdmi_phy2)
[ 1.701272] rockchip-drm display-subsystem: bound ff3c0000.hdmi (ops 0xffffff8008e164c8)
[ 1.702031] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.702639] [drm] No driver support for vblank timestamp query.
[ 1.914093] get_framebuffer_by_node: failed to get logo,offset
[ 2.173809] Freeing drm_logo memory: 616K
[ 2.245387] Console: switching to colour frame buffer device 240x67
[ 2.312977] rockchip-drm display-subsystem: fb0: frame buffer device
[ 2.323839] Unable to detect cache hierarchy for CPU 0
[ 2.326319] brd: module loaded
[ 2.340176] loop: module loaded
[ 2.341956] zram: Added device: zram0
[ 2.342901] lkdtm: No crash points registered, enable through debugfs
[ 2.347316] register spi return v = :0
[ 2.347757] register firefly_spi_init spi return v = :0
[ 2.351597] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 2.352478] rk_gmac-dwmac ff540000.ethernet: clock input or output? (input).
[ 2.353145] rk_gmac-dwmac ff540000.ethernet: TX delay(0x28).
[ 2.353678] rk_gmac-dwmac ff540000.ethernet: RX delay(0x16).
[ 2.354200] rk_gmac-dwmac ff540000.ethernet: integrated PHY? (no).
[ 2.355001] rk_gmac-dwmac ff540000.ethernet: cannot get clock clk_mac_speed
[ 2.355638] rk_gmac-dwmac ff540000.ethernet: clock input from PHY
[ 2.361205] rk_gmac-dwmac ff540000.ethernet: init for RGMII
[ 2.361926] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 2.362375] Ring mode enabled
[ 2.362673] DMA HW capability register supported
[ 2.363075] Normal descriptors
[ 2.363387] RX Checksum Offload Engine supported (type 2)
[ 2.363892] Wake-Up On Lan supported
[ 2.364317] rk_gmac-dwmac ff540000.ethernet: rk_get_eth_addr: rk_vendor_read eth mac address failed (-1)
[ 2.365219] rk_gmac-dwmac ff540000.ethernet: rk_get_eth_addr: generate random eth mac address: 1e:8d:dc:f4:24:4b
[ 2.366133] rk_gmac-dwmac ff540000.ethernet: rk_get_eth_addr: rk_vendor_write eth mac address failed (-1)
[ 2.367004] rk_gmac-dwmac ff540000.ethernet: rk_get_eth_addr: mac address: 1e:8d:dc:f4:24:4b
[ 2.367772] eth%d: device MAC address 1e:8d:dc:f4:24:4b
[ 2.368246] Enable RX Mitigation via HW Watchdog Timer
[ 2.442445] libphy: stmmac: probed
[ 2.442801] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 2.443380] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 2.446114] usbcore: registered new interface driver rtl8192cu
[ 2.446762] usbcore: registered new interface driver rndis_wlan
[ 2.447776] usbcore: registered new interface driver mt7601u
[ 2.448436] Rockchip WiFi SYS interface (V1.00) …
[ 2.449075] usbcore: registered new interface driver rtl8150
[ 2.449695] usbcore: registered new interface driver r8152
[ 2.450287] usbcore: registered new interface driver asix
[ 2.450881] usbcore: registered new interface driver ax88179_178a
[ 2.451510] usbcore: registered new interface driver cdc_ether
[ 2.452125] usbcore: registered new interface driver rndis_host
[ 2.452813] usbcore: registered new interface driver cdc_ncm
[ 2.453396] usbcore: registered new interface driver qmi_wwan
[ 2.454006] usbcore: registered new interface driver cdc_mbim
[ 2.457453] phy phy-ff470000.usb3-phy.2: u3phy u2 power on
[ 2.458035] phy phy-ff470000.usb3-phy.3: u3phy u3 power on
[ 2.460235] ff580000.usb supply vusb_d not found, using dummy regulator
[ 2.460989] ff580000.usb supply vusb_a not found, using dummy regulator
[ 2.474577] dwc2 ff580000.usb: DWC OTG Controller
[ 2.475099] dwc2 ff580000.usb: new USB bus registered, assigned bus number 1
[ 2.475828] dwc2 ff580000.usb: irq 42, io mem 0xff580000
[ 2.476703] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.477313] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.477979] usb usb1: Product: DWC OTG Controller
[ 2.478408] usb usb1: Manufacturer: Linux 4.4.194 dwc2_hsotg
[ 2.478934] usb usb1: SerialNumber: ff580000.usb
[ 2.480556] hub 1-0:1.0: USB hub found
[ 2.480983] hub 1-0:1.0: 1 port detected
[ 2.483243] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 2.483884] ehci-pci: EHCI PCI platform driver
[ 2.484446] ehci-platform: EHCI generic platform driver
[ 2.487921] ehci-platform ff5c0000.usb: EHCI Host Controller
[ 2.488878] ehci-platform ff5c0000.usb: new USB bus registered, assigned bus number 2
[ 2.489854] ehci-platform ff5c0000.usb: irq 43, io mem 0xff5c0000
[ 2.495663] ehci-platform ff5c0000.usb: USB 2.0 started, EHCI 1.00
[ 2.496601] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.497241] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.497903] usb usb2: Product: EHCI Host Controller
[ 2.498346] usb usb2: Manufacturer: Linux 4.4.194 ehci_hcd
[ 2.498862] usb usb2: SerialNumber: ff5c0000.usb
[ 2.500435] hub 2-0:1.0: USB hub found
[ 2.500849] hub 2-0:1.0: 1 port detected
[ 2.502217] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 2.502852] ohci-platform: OHCI generic platform driver
[ 2.504151] ohci-platform ff5d0000.usb: Generic Platform OHCI controller
[ 2.505293] ohci-platform ff5d0000.usb: new USB bus registered, assigned bus number 3
[ 2.506255] ohci-platform ff5d0000.usb: irq 44, io mem 0xff5d0000
[ 2.561978] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.562595] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.563263] usb usb3: Product: Generic Platform OHCI controller
[ 2.563812] usb usb3: Manufacturer: Linux 4.4.194 ohci_hcd
[ 2.564311] usb usb3: SerialNumber: ff5d0000.usb
[ 2.565923] hub 3-0:1.0: USB hub found
[ 2.566318] hub 3-0:1.0: 1 port detected
[ 2.568748] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 2.569738] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 4
[ 2.570769] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x04210010
[ 2.571655] xhci-hcd xhci-hcd.9.auto: irq 181, io mem 0xff600000
[ 2.572719] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.573367] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.574036] usb usb4: Product: xHCI Host Controller
[ 2.574480] usb usb4: Manufacturer: Linux 4.4.194 xhci-hcd
[ 2.574997] usb usb4: SerialNumber: xhci-hcd.9.auto
[ 2.576708] hub 4-0:1.0: USB hub found
[ 2.577117] hub 4-0:1.0: 1 port detected
[ 2.578206] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 2.579175] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 5
[ 2.580034] usb usb5: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 2.580993] usb usb5: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.581649] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.582291] usb usb5: Product: xHCI Host Controller
[ 2.582755] usb usb5: Manufacturer: Linux 4.4.194 xhci-hcd
[ 2.583253] usb usb5: SerialNumber: xhci-hcd.9.auto
[ 2.584894] hub 5-0:1.0: USB hub found
[ 2.585298] hub 5-0:1.0: 1 port detected
[ 2.586705] usbcore: registered new interface driver cdc_acm
[ 2.587214] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.588051] usbcore: registered new interface driver cdc_wdm
[ 2.588680] usbcore: registered new interface driver uas
[ 2.589435] usbcore: registered new interface driver usb-storage
[ 2.590218] usbcore: registered new interface driver usbserial
[ 2.590838] usbcore: registered new interface driver usbserial_generic
[ 2.591476] usbserial: USB Serial support registered for generic
[ 2.592125] usbcore: registered new interface driver ch341
[ 2.592697] usbserial: USB Serial support registered for ch341-uart
[ 2.593359] usbcore: registered new interface driver cp210x
[ 2.593936] usbserial: USB Serial support registered for cp210x
[ 2.594644] usbcore: registered new interface driver ftdi_sio
[ 2.595221] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.596297] usbcore: registered new interface driver keyspan
[ 2.596883] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 2.597653] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 2.598361] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 2.599090] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 2.599872] usbcore: registered new interface driver option
[ 2.600419] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.601727] usbcore: registered new interface driver oti6858
[ 2.602303] usbserial: USB Serial support registered for oti6858
[ 2.602959] usbcore: registered new interface driver pl2303
[ 2.603514] usbserial: USB Serial support registered for pl2303
[ 2.604220] usbcore: registered new interface driver qcserial
[ 2.604812] usbserial: USB Serial support registered for Qualcomm USB modem
[ 2.605571] usbcore: registered new interface driver sierra
[ 2.606141] usbserial: USB Serial support registered for Sierra USB modem
[ 2.609215] usbcore: registered new interface driver usbtouchscreen
[ 2.610514] .. rk pwm remotectl v1.1 init
[ 2.611643] input: ff1b0030.pwm as /devices/platform/ff1b0030.pwm/input/input0
[ 2.613384] sensor_register_slave:mma8452,id=17
[ 2.613846] sensor_register_slave:lis3dh,id=7
[ 2.614258] sensor_register_slave:mma7660,id=18
[ 2.614690] sensor_register_slave:lsm303d,id=22
[ 2.615106] sensor_register_slave:gs_mc3230,id=23
[ 2.615534] [Gsensor] gsensor_init
[ 2.615889] sensor_register_slave:mpu6880_acc,id=24
[ 2.616342] sensor_register_slave:mpu6500_acc,id=25
[ 2.616809] sensor_register_slave:lsm330_acc,id=26
[ 2.617250] sensor_register_slave:akm8975,id=30
[ 2.617681] sensor_register_slave:akm8963,id=31
[ 2.618097] sensor_register_slave:l3g4200d,id=45
[ 2.618526] sensor_register_slave:l3g20d,id=46
[ 2.618956] sensor_register_slave:ewtsa,id=47
[ 2.619359] sensor_register_slave:lsm330_gyro,id=51
[ 2.619826] sensor_register_slave:cm3217,id=53
[ 2.620245] sensor_register_slave:cm3218,id=54
[ 2.621714] i2c /dev entries driver
[ 2.625904] rk808 1-0018: Pmic Chip id: 0x8050
[ 2.627470] rk808 1-0018: source: on=0x40, off=0x00
[ 2.645326] vcc_sd: supplied by vcc_io
[ 2.652962] vdd_11: Bringing 1000000uV into 1100000-1100000uV
[ 2.657136] rk808 1-0018: register rk8050 regulators
[ 2.658199] rk8xx-gpio rk8xx-gpio: register rk8050 gpio successful
[ 2.659178] rk8xx-pwrkey rk8xx-pwrkey: device is disabled
[ 2.659707] rk8xx-pwrkey: probe of rk8xx-pwrkey failed with error -22
[ 2.670425] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 2.671941] rk808 1-0018: Can not read property pmic,hold-gpio
[ 2.672480] rk808 1-0018: Can not read property pmic,stby-gpio
[ 2.673089] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at ffffff8009fd4000
[ 2.676188] IR NEC protocol handler initialized
[ 2.677910] usbcore: registered new interface driver npu_acm
[ 2.678681] usbcore: registered new interface driver uvcvideo
[ 2.679205] USB Video Class driver (1.1.1)
[ 2.685378] Boot mode: coldboot
[ 2.686928] rockchip-thermal ff250000.tsadc: Missing tshut mode property, using default (cru)
[ 2.687740] rockchip-thermal ff250000.tsadc: Missing tshut-polarity property, using default (low)
[ 2.688986] rockchip-thermal ff250000.tsadc: tsadc is probed successfully!
[ 2.692006] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.693150] Bluetooth: Virtual HCI driver ver 1.5
[ 2.693920] Bluetooth: HCI UART driver ver 2.3
[ 2.694337] Bluetooth: HCI UART protocol H4 registered
[ 2.694821] Bluetooth: HCI UART protocol LL registered
[ 2.695282] Bluetooth: HCI UART protocol ATH3K registered
[ 2.695784] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 2.696526] usbcore: registered new interface driver bfusb
[ 2.697186] usbcore: registered new interface driver btusb
[ 2.698351] cpu cpu0: leakage=7
[ 2.698672] cpu cpu0: leakage-volt-sel=0
[ 2.699336] cpu cpu0: Failed to get pvtm
[ 2.702212] cpu cpu0: avs=0
[ 2.702562] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[ 2.704840] cpu cpu0: failed to find power_model node
[ 2.705917] sdhci: Secure Digital Host Controller Interface driver
[ 2.706468] sdhci: Copyright(c) Pierre Ossman
[ 2.706928] Synopsys Designware Multimedia Card Interface Driver
[ 2.709369] dwmmc_rockchip ff500000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.710095] dwmmc_rockchip ff500000.dwmmc: Using internal DMA controller.
[ 2.710749] dwmmc_rockchip ff500000.dwmmc: Version ID is 270a
[ 2.711365] dwmmc_rockchip ff500000.dwmmc: DW MMC controller at irq 39,32 bit host data width,256 deep fifo
[ 2.712289] dwmmc_rockchip ff500000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.714173] rockchip-iodomain ff100000.syscon:io-domains: Setting to 3300000 done
[ 2.714936] gpio-regulator: set GRF_SOC_CON10 bit 1 to 0
[ 2.715419] enter gpio_regulator_set_voltage line 111 ,gpio=25 state=0
[ 2.716036] rockchip-iodomain ff100000.syscon:io-domains: Setting to 3300000 done
[ 2.729369] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.742978] dwmmc_rockchip ff500000.dwmmc: 1 slots initialized
[ 2.744974] dwmmc_rockchip ff520000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.745709] dwmmc_rockchip ff520000.dwmmc: Using internal DMA controller.
[ 2.746350] dwmmc_rockchip ff520000.dwmmc: Version ID is 270a
[ 2.747007] dwmmc_rockchip ff520000.dwmmc: DW MMC controller at irq 40,32 bit host data width,256 deep fifo
[ 2.762095] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.775742] dwmmc_rockchip ff520000.dwmmc: 1 slots initialized
[ 2.776703] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.780172] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.834667] usb 1-1: new low-speed USB device number 2 using dwc2
[ 3.005488] usb 1-1: New USB device found, idVendor=046d, idProduct=c31c
[ 3.006126] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.006788] usb 1-1: Product: USB Keyboard
[ 3.007167] usb 1-1: Manufacturer: Logitech
[ 3.281630] dwmmc_rockchip ff520000.dwmmc: Busy; trying anyway
[ 3.282169] mmc_host mmc1: Timeout sending command (cmd 0x202000 arg 0x0 status 0x0)
[ 3.288882] input: Logitech USB Keyboard as /devices/platform/ff580000.usb/usb1/1-1/1-1:1.0/0003:046D:C31C.0001/input/input1
[ 3.290380] mmc_host mmc0: Bus speed (slot 0) = 25000000Hz (slot req 25000000Hz, actual 25000000HZ div = 0)
[ 3.291373] mmc0: new SD card at address d555
[ 3.292706] mmcblk0: mmc0:d555 SD032 30.6 MiB
[ 3.296735] mmc_host mmc1: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[ 3.341809] hid-generic 0003:046D:C31C.0001: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-ff580000.usb-1/input0
[ 3.356217] input: Logitech USB Keyboard as /devices/platform/ff580000.usb/usb1/1-1/1-1:1.1/0003:046D:C31C.0002/input/input2
[ 3.408338] hid-generic 0003:046D:C31C.0002: input,hiddev0,hidraw1: USB HID v1.10 Device [Logitech USB Keyboard] on usb-ff580000.usb-1/input1
[ 3.409652] usbcore: registered new interface driver usbhid
[ 3.410149] usbhid: USB HID core driver
[ 3.410702] inv_mpu_iio: inv_mpu_init:746
[ 3.413003] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[ 3.417458] usbcore: registered new interface driver snd-usb-audio
[ 3.419569] rk3328-codec ff410000.codec: rk3328 have no io-channels defined
[ 3.420262] rk3328-codec ff410000.codec: spk_depop_time use default value.
[ 3.425939] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 3.427314] IPVS: Registered protocols (TCP, UDP)
[ 3.427855] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[ 3.428689] IPVS: Creating netns size=2104 id=0
[ 3.429146] IPVS: ipvs loaded.
[ 3.429428] IPVS: [rr] scheduler registered.
[ 3.430220] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.430844] Initializing XFRM netlink socket
[ 3.432188] NET: Registered protocol family 10
[ 3.433969] NET: Registered protocol family 17
[ 3.434410] NET: Registered protocol family 15
[ 3.434874] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 3.436030] Bridge firewalling registered
[ 3.436580] Bluetooth: RFCOMM socket layer initialized
[ 3.437097] Bluetooth: RFCOMM ver 1.11
[ 3.437455] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.437997] Bluetooth: HIDP socket layer initialized
[ 3.438518] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 3.439413] [BT_RFKILL]: Enter rfkill_rk_init
[ 3.440088] Key type dns_resolver registered
[ 3.440705] sensor_register_slave:mpu6880_gyro,id=50
[ 3.442354] Registered cp15_barrier emulation handler
[ 3.442828] Registered setend emulation handler
[ 3.444230] Loading compiled-in X.509 certificates
[ 3.447517] Btrfs loaded
[ 3.449270] rga2: Driver loaded successfully ver:4.00
[ 3.450055] rga2: Module initialized.
[ 3.450412] pvtm list NULL
[ 3.451531] rk-vcodec ff360000.rkvdec: no regulator for vcodec
[ 3.452122] rk-vcodec ff360000.rkvdec: parent devfreq retry
[ 3.454014] rockchip-dmc dmc: current ATF version 0x101!
[ 3.454489] rockchip-dmc dmc: read tf version 0x101!
[ 3.457017] rockchip-dmc dmc: leakage=6
[ 3.457382] rockchip-dmc dmc: leakage-volt-sel=0
[ 3.457971] rockchip-dmc dmc: Failed to get pvtm
[ 3.459002] rockchip-dmc dmc: avs=0
[ 3.459355] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[ 3.459945] rockchip-dmc dmc: failed to get vop pn to msch rl
[ 3.460807] rockchip-dmc dmc: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[ 3.473413] devfreq dmc: Couldn’t update frequency transition information.
[ 3.495244] asoc-simple-card sound: rk3328-hifi ↔ ff010000.i2s mapping ok
[ 3.497598] asoc-simple-card hdmi-sound: i2s-hifi ↔ ff000000.i2s mapping ok
[ 3.499129] rk-vcodec ff360000.rkvdec: no regulator for vcodec
[ 3.499680] rk-vcodec ff360000.rkvdec: parent devfreq is ok
[ 3.500552] rk-vcodec ff360000.rkvdec: probe device
[ 3.501337] rk-vcodec ff360000.rkvdec: drm allocator with mmu enabled
[ 3.502465] rk-vcodec ff360000.rkvdec: init success
[ 3.503345] ==gsl_ts_init==
[ 3.503656] ret=0
[ 3.505612] rk808-rtc rk808-rtc: setting system clock to 2016-01-21 08:50:09 UTC (1453366209)
[ 3.815618] dwmmc_rockchip ff520000.dwmmc: Busy; trying anyway
[ 3.816146] mmc_host mmc1: Timeout sending command (cmd 0x202000 arg 0x0 status 0x0)
[ 3.830682] mmc_host mmc1: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[ 4.349614] dwmmc_rockchip ff520000.dwmmc: Busy; trying anyway
[ 4.350141] mmc_host mmc1: Timeout sending command (cmd 0x202000 arg 0x0 status 0x0)
[ 4.364684] mmc_host mmc1: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0)
[ 4.884610] dwmmc_rockchip ff520000.dwmmc: Busy; trying anyway
[ 4.885133] mmc_host mmc1: Timeout sending command (cmd 0x202000 arg 0x0 status 0x0)
[ 6.446694] vendor storage:20190527 ret = -1
[ 7.522668] ret 1024
[ 7.523369] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, built at ‘17:15:44’, on ‘Jun 19 2021’.
[ 7.525463] mali-utgard ff300000.gpu: mali_platform_device->num_resources = 9
[ 7.526136] mali-utgard ff300000.gpu: resource[0].start = 0x0x00000000ff300000
[ 7.526811] mali-utgard ff300000.gpu: resource[1].start = 0x0x00000000ff300000
[ 7.527464] mali-utgard ff300000.gpu: resource[2].start = 0x0x0000000000000012
[ 7.528136] mali-utgard ff300000.gpu: resource[3].start = 0x0x0000000000000013
[ 7.528808] mali-utgard ff300000.gpu: resource[4].start = 0x0x0000000000000014
[ 7.529462] mali-utgard ff300000.gpu: resource[5].start = 0x0x0000000000000015
[ 7.530135] mali-utgard ff300000.gpu: resource[6].start = 0x0x0000000000000016
[ 7.530812] mali-utgard ff300000.gpu: resource[7].start = 0x0x0000000000000017
[ 7.531465] mali-utgard ff300000.gpu: resource[8].start = 0x0x0000000000000018
[ 7.532135] D : [File] : drivers/gpu/arm/mali400/mali/platform/rk/rk.c; [Line] : 623; [Func] : mali_platform_device_init(); to add platform_specific_data to platform_device_of_mali.
[ 7.534004] mali-utgard ff300000.gpu: leakage=6
[ 7.534432] mali-utgard ff300000.gpu: leakage-volt-sel=0
[ 7.535153] mali-utgard ff300000.gpu: Failed to get pvtm
[ 7.536388] mali-utgard ff300000.gpu: avs=0
[ 7.537181] mali-utgard ff300000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[ 7.541196] Mali: Mali device driver loaded
[ 7.543796] ALSA device list:
[ 7.544082] #0: rockchip,rk3328
[ 7.544383] #1: rockchip,hdmi
[ 7.545534] Freeing unused kernel memory: 1152K
/dev/console is OK
NAME=Buildroot
VERSION=2018.02-rc3-g80a212549f
ID=buildroot
VERSION_ID=2018.02-rc3
PRETTY_NAME=“Buildroot 2018.02-rc3”
Starting logging: OK
Populating /dev using udev: [ 7.595279] udevd[161]: starting version 3.2.7
[ 7.596283] random: udevd: uninitialized urandom read (16 bytes read, 97 bits of entropy available)
[ 7.597319] random: udevd: uninitialized urandom read (16 bytes read, 97 bits of entropy available)
[ 7.598215] random: udevd: uninitialized urandom read (16 bytes read, 97 bits of entropy available)
[ 7.599108] random: udevd: uninitialized urandom read (16 bytes read, 97 bits of entropy available)
[ 7.600021] random: udevd: uninitialized urandom read (16 bytes read, 97 bits of entropy available)
[ 7.603094] udevd[161]: specified group ‘kvm’ unknown
[ 7.611014] udevd[162]: starting eudev-3.2.7
[ 7.630490] random: udevd: uninitialized urandom read (16 bytes read, 97 bits of entropy available)
[ 7.636738] devfreq ff300000.gpu: Couldn’t update frequency transition information.
[ 7.696765] random: udevd: uninitialized urandom read (16 bytes read, 98 bits of entropy available)
done
Initializing random number generator… [ 7.787474] random: dd: uninitialized urandom read (512 bytes read, 101 bits of entropy available)
done.
realpath: /dev/block/by-name/misc: No such file or directory
Not a normal boot, only mount basic file systems
Log saved to /tmp/mountall.log
cmdline=storagemedia=sd androidboot.storagemedia=sd androidboot.mode=normal androidboot.slot_suffix= androidboot.serialno=cc18e729917efda1 rockchip_jtag ro rootwait earlyprintk=uart8250-32bit,0xff130000 swiotlb=1 kpti=0 console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1
Starting network:
read console from cmdline is /dev/ttyFIQ0
Starting recovery on Thu Jan 21 08:50:13 2016
Noui upgrade
recovery filesystem table
0 (null) /tmp ramdisk (null) (null) (null)
1 /dev/root / ext2 rw,noauto 0 1
2 proc /proc proc defaults 0 0
3 devpts /dev/pts devpts defaults,gid=5,mode=620 0 0
4 tmpfs /dev/shm tmpfs mode=0777 0 0
5 tmpfs /tmp tmpfs mode=1777 0 0
6 tmpfs /run tmpfs mode=0755,nosuid,nodev 0 0
7 sysfs /sys sysfs defaults 0 0
8 debug /sys/kernel/debug debugfs defaults 0 0
9 pstore /sys/fs/pstore pstore defaults 0 0
10 /dev/block/by-name/misc /misc emmc defaults 0 0
11 /dev/block/by-name/oem /oem ext2 defaults 0 2
12 /dev/block/by-name/userdata /userdata ext4 defaults 0 2
buf = /dev/block/by-name/misc
### get mount_ponit = /dev/block/by-name/misc ###
stat /dev/block/by-name/misc try 1: No such file or directory
OK
Debug: configfs_init
mkdir: can’t create directory ‘/sys/kernel/config/usb_gadget/rockchip/functions/uac1.gs0’: No such file or directory
mkdir: can’t create directory ‘/sys/kernel/config/usb_gadget/rockchip/functions/uac2.gs0’: No such file or directory
[ 7.871070] file system registered
mkdir: can’t create directory ‘/sys/kernel/config/usb_gadget/rockchip/functions/mtp.gs0’: No such file or directory
mkdir: can’t create directory ‘/sys/kernel/config/usb_gadget/rockchip/functions/rndis.gs0’: No such file or directory
[ 7.884525] Mass Storage Function, version: 2009/09/11
[ 7.885042] LUN: removable file: (no medium)
mkdir: can’t create directory ‘/sys/kernel/config/usb_gadget/rockchip/functions/uvc.gs6’: No such file or directory
[ 7.910730] read descriptors
[ 7.910996] read strings
stat /dev/block/by-name/misc try 2: No such file or directory
sh: write error: No such device
cat: can’t open ‘/proc/device-tree/wireless-wlan/wifi_chip_type’: No such file or directory
sh: rtl8723ds: unknown operand
[ 9.321721] random: nonblocking pool is initialized
stat /dev/block/by-name/misc try 3: No such file or directory
/usr/bin/bt_alsa: line 3: hciconfig: not found
/usr/bin/bt_alsa: line 4: hciconfig: not found
/usr/bin/bt_alsa: line 5: hciconfig: not found
stat /dev/block/by-name/misc try 4: No such file or directory
/usr/bin/bt_alsa: line 7: bluealsa: not found
stat /dev/block/by-name/misc try 5: No such file or directory
Starting input-event-daemon: /usr/bin/bt_alsa: line 9: bluealsa-aplay: not found
input-event-daemon: Start parsing /etc/input-event-daemon.conf…
input-event-daemon: Adding device: /dev/input/event0…
input-event-daemon: Adding device: /dev/input/event1…
input-event-daemon: Adding device: /dev/input/event2…
input-event-daemon: Start listening on 3 devices…
done
[root@buildroot:/]# stat /dev/block/by-name/misc try 6: No such file or directory
stat /dev/block/by-name/misc try 7: No such file or directory
stat /dev/block/by-name/misc try 8: No such file or directory
stat /dev/block/by-name/misc try 9: No such file or directory
stat /dev/block/by-name/misc try 10: No such file or directory
failed to stat /dev/block/by-name/misc
emmc_point is
sd_point is (null)
sd_point_2 is /dev/mmcblk0
read cmdline
Boot from non-SDcard
Now is SD.
I:Now is MTD.
E:Can’t find misc
No link to path!!!
E:failed to mount /userdata (No such file or directory)
E:Can’t mount /userdata/recovery/command
Now is SD.
I:Now is MTD.
E:Can’t find misc
Command: “/usr/bin/recovery”
No link to path!!!
E:Can’t mount /userdata/recovery/log
E:Can’t open /userdata/recovery/log
No link to path!!!
E:Can’t mount /userdata/recovery/last_log
E:Can’t open /userdata/recovery/last_log
Now is SD.
I:Now is MTD.
E:Can’t find misc
No link to path!!!
W:Can’t unlink /userdata/recovery/command
[ 29.075695] usb 1-1: USB disconnect, device number 2
input-event-daemon: read(/dev/input/event1): No such device
input-event-daemon: read(/dev/input/event2): No such device
