换64G emmc的的设计,linux卡在下面,求助求助
[ 1.230850] pwm-regulator vdd-log: Failed to get PWM: -517
[ 1.232396] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:04 UTC (1358499004)
[ 1.236199] mmc1: clock 400000Hz busmode 2 powermode 2 cs 0 Vdd 7 width 1 timing 0
[ 1.249975] vcc_sd: disabling
[ 1.250257] vcc_mipi: disabling
[ 1.250540] dvdd_1v2: disabling
[ 1.252172] mmc1: clock 400000Hz busmode 2 powermode 2 cs 0 Vdd 7 width 8 timing 0
[ 1.256390] mmc1: clock 400000Hz busmode 2 powermode 2 cs 0 Vdd 7 width 8 timing 9
[ 1.258273] mmc1: clock 100000000Hz busmode 2 powermode 2 cs 0 Vdd 7 width 8 timing 9
[ 1.263213] mmc1: clock 100000000Hz busmode 2 powermode 2 cs 0 Vdd 7 width 8 timing 1
[ 1.265175] mmc1: clock 52000000Hz busmode 2 powermode 2 cs 0 Vdd 7 width 8 timing 1
[ 1.268458] mmc1: clock 52000000Hz busmode 2 powermode 2 cs 0 Vdd 7 width 8 timing 10
[ 1.270428] mmc1: clock 100000000Hz busmode 2 powermode 2 cs 0 Vdd 7 width 8 timing 10
[ 1.273770] mmc1: new HS400 MMC card at address 0001
[ 1.275427] mmcblk1: mmc1:0001 S0J58X 59.3 GiB
[ 1.276267] mmcblk1boot0: mmc1:0001 S0J58X partition 1 31.5 MiB
[ 1.277846] mmcblk1boot1: mmc1:0001 S0J58X partition 2 31.5 MiB
[ 1.279237] mmcblk1rpmb: mmc1:0001 S0J58X partition 3 4.00 MiB
[ 1.288446] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8
[ 1.294063] pwm-regulator vdd-log: Failed to get PWM: -517
[ 1.724590] vendor storage:20190527 ret = 0
u�
是参考瑞芯微box做的板子,烧录firefy开发板时提供的linux固件,FIREFLY-RK3399-UBUNTU-LINUXROOT-GPT-20210629-1533.img,跑到这里突然就停了,电流也下降了一些,量最小系统供电都正常。请大侠帮忙看看。
你的是16G自己更换的64G存储吗?
请问解决了吗?我也遇到不能启动,原来是16g更换了64g,原来的系统复制过来也不行,可以进loader,屏幕没显示,要么就是卡灯泡标,也可以烧录系统,能成功,重启就不行了,
跟你一样,换了个emmc也卡在kernel了,sd卡启动就没有问题,怀疑是emmc驱动的问题
不是怀疑,驱动问题了。
请问楼主该问题怎么解决的?
系统与EMMC进行了绑定加密,自行更换后验证不通过,系统起不来,这就是原因
使用rk3588原厂系统就可以,启动正常。
请问有大佬解决这个问题了吗?可否分享一下,解决办法,卡了好久了。
