RV1126 安装 RKNN Toolkit Lite 的方法
RKNN Toolkit Lite 的文件目录在 SDK/external/rknn-toolkit/rknn-toolkit-lite/rknn-toolkit-lite-v1.7.0.dev_0cfb22
或者直接使用 git 拉取代码:git clone https://gitlab.com/firefly-linux/external/rknn-toolkit.git -b rv1126_rv1109/firefly
测试环境使用 RV1126 主机。文件系统是 Firefly Debian10。以下操作均 RV112 上执行。
Firefly Debian10 固件 RKNN Toolkit Lite 安装步骤:
一、 安装依赖 numpy / psutils / ruamel.yaml
# 如果没有装 pip3 ,请先用 sudo apt-get update && sudo apt-get install python3-pip 装下
pip3 install numpy==1.16.3
pip3 install psutil==5.6.2
pip3 install ruamel.yaml==0.15.81
二、 安装 opencv-python 。用 pip3 安装会一直失败,所以直接在网上下载包。
# 先装以下依赖, wget 用到的两个 deb 包已经放在 rknn-toolkit-lite-v1.7.0.dev_0cfb22/requires/ 目录下
sudo apt-get install multiarch-support
wget http://security.debian.org/debian-security/pool/updates/main/j/jasper/libjasper1_1.900.1-debian1-2.4+deb8u6_armhf.deb
sudo dpkg -i libjasper1_1.900.1-debian1-2.4+deb8u6_armhf.deb
wget http://security.debian.org/debian-security/pool/updates/main/j/jasper/libjasper-dev_1.900.1-debian1-2.4+deb8u6_armhf.deb
sudo dpkg -i libjasper-dev_1.900.1-debian1-2.4+deb8u6_armhf.deb
sudo apt-get install libhdf5-dev
sudo apt-get install libatlas-base-dev
sudo apt-get install libqtgui4
sudo apt-get install libqt4-test
pip3 install rknn-toolkit-lite-v1.7.0.dev_0cfb22/requires/opencv_python-4.0.1.24-cp37-cp37m-linux_armv7l.whl
三、安装 RKNN Toolkit Lite
# 使用以下命令安装RKNN Toolkit Lite
pip3 install rknn-toolkit-lite-v1.7.0.dev_0cfb22/packages/rknn_toolkit_lite-1.7.0.dev_0cfb22-cp37-cp37m-linux_armv7l.whl
四、跑 example
cd rknn-toolkit-lite-v1.7.0.dev_0cfb22/examples-lite/inference_with_lite
python3 test.py
结果输出如下:
# 结果输出如下:
root@firefly:/home/firefly/rknn-toolkit-lite-v1.7.0.dev_0cfb22/examples-lite/inference_with_lite# python3 test.py
→ list devices:
None devices connected.
done
→ query support target platform
Target platforms filled in RKNN model: [‘RV1109’]
Target platforms supported by this RKNN model: [‘RK1109’, ‘RK1126’, ‘RV1109’, ‘RV1126’]
done
→ Load RKNN model
done
→ Init runtime environment
done
→ get sdk version:
RKNN VERSION:
API: librknn_runtime version 1.6.0 (6523e57 build: 2021-01-15 15:56:31 base: 1126)
DRV: 6.4.3.5.293908
done
→ Running model
resnet18
-----TOP 5-----
[812]: 0.9993900656700134
[404]: 0.0004593880439642817
[657 833]: 2.9284517950145528e-05
[895]: 1.850890475907363e-05
done
点赞!
为啥我的RV1126板子 只能通过172.16网段与主机连接,不能直接上网,安装python环境很麻烦啊
你确定你刷的是 debian10 固件?
板蓝根 发表于 2021-6-25 10:32
点赞!
你买的板子是型号是 CORE-1126-JD4 吗?
Debian10 适配的是 CORE-1126-JD4 / CORE-1109-JD4
板子为core-1126-jd4。镜像为官方2021年4月19号的build镜像搭配debian10的三个文件。
按照上面方法装的环境,跑example。报错如下:firefly@firefly:/opt/rknn-toolkit-lite/rknn-toolkit-lite-v1.7.0.dev_0cfb22/examp
les-lite/inference_with_lite$ python3 test.py
→ list devices:
done
done
→ Load RKNN model
done
[ 1] Failed to open device: No such file or directory, Try again…
[ 2] Failed to open device: No such file or directory, Try again…
[ 3] Failed to open device: No such file or directory, Try again…
[ 4] Failed to open device: No such file or directory, Try again…
[ 5] _OpenDevice(1086): FATAL: Failed to open device, errno=No such file or directory.
跑 rknn 必须使用 sudo 管理员权限
请问,rv1126 对yolov3进行模型预测,能实现视频实时效果吗?最高能到多少帧。
没有试过
799959745 发表于 2022-4-11 10:45
没有试过
那用什么算法能达到视频实时效果,有试过吗?
没有试过,需要自行尝试研发
按照上面方法装的环 …
请问你刷的是这个镜像吗?从官方百度云盘下载后的路径是:AIO-RV1126(1109)-JD4\Debian10\debian10_2021_0429_1902\debian10
里面就3个文件:
但我看到刷固件工具中需要指定以下这么多个文件,这个怎么选择与上述3个文件对应呢?
按照上面方法装的环 …
我一样遇到这个问题。原因是跑这个rknn真只能在root用户下跑。所以所有的pip3安装必须先切换到root用户下进行。。。然后就没有问题了。
这家的文档的水平真不敢恭维,惜字如金。他们的目标对象应该只是做底层的资深嵌入式工程师。想拿来玩和只想快速在上面做应用的小白就不要折腾它了。。。
说的太对了{:4_105:}
--> Load RKNN model
done
--> Init runtime environment
E Catch exception when init runtime!
E Traceback (most recent call last):
  File "/usr/local/lib/python3.7/dist-packages/rknnlite/api/rknn_lite.py", line 144, in init_runtime
    async_mode=async_mode, rknn2precompile=rknn2precompile)
  File "rknnlite/api/rknn_runtime.py", line 292, in rknnlite.api.rknn_runtime.RKNNRuntime.__init__
  File "rknnlite/api/rknn_runtime.py", line 491, in rknnlite.api.rknn_runtime.RKNNRuntime._load_library
  File "rknnlite/api/rknn_runtime.py", line 486, in rknnlite.api.rknn_runtime.RKNNRuntime._get_rknn_api_lib_path
Exception: Unsupported run platform: Linux armv7l
Init runtime environment failed
我这里提示 不支持 armv7l ,怎么回事?
root@439f7c3e208f:/opt/devel/rknn-toolkit/rknn-toolkit-lite/examples/inference_with_lite# python3 test.py
--> Load RKNN model
done
librknn_runtime version 1.7.1 (97198ce build: 2021-11-24 09:32:17 base: 1131)
done
--> Running model
resnet18
-----TOP 5-----
done
终于,在docker下,成功跑通,不过,这个运行速度好像很慢很慢。
  1. Dockerfile:
FROM debian:buster
RUN apt update
RUN apt install python3-opencv git python3-pip -y
RUN /usr/bin/python3 -m pip install --upgrade pip
COPY ./rknn_toolkit_lite-1.7.1-cp37-cp37m-linux_armv7l.whl /tmp
RUN pip3 install /tmp/rknn_toolkit_lite-1.7.1-cp37-cp37m-linux_armv7l.whl
RUN rm -rf /tmp/rknn_toolkit_lite-1.7.1-cp37-cp37m-linux_armv7l.whl
RUN apt install libdrm-dev -y
COPY ./lib/* /usr/lib
  1. copy rknpu driver files to build directory:
cp rknpu/drivers/linux-armhf-puma/usr/lib .
cp rknn-toolkit/rknn-toolkit-lite/packages/rknn_toolkit_lite-1.7.1-cp37-cp37m-linux_armv7l.whl .
  1. docker build and run command:
docker build . -t debian10-python3-opencv:latest
docker run -it --rm --name rv1126 --privileged -v /dev/dri/card0:/dev/dri/card0 -v /opt/devel/:/opt/devel debian10-python3-opencv /bin/bash
这是运行的效果:耗时25秒左右。
real 0m24.747suser 0m24.492s
sys 0m0.705s
root@743eeb4de2f7:/opt/devel/rknn-toolkit/rknn-toolkit-lite/examples/inference_with_lite# time python3 test.py
--> list devices:
done
--> query support target platform
Target platforms filled in RKNN model:         ['RV1109']
Target platforms supported by this RKNN model: ['RV1109', 'RK1109', 'RV1126', 'RK1126']
done
--> Load RKNN model
done
done
--> get sdk version:
RKNN VERSION:
  API: librknn_runtime version 1.7.1 (97198ce build: 2021-11-24 09:32:17 base: 1131)
  DRV: 6.4.6.5.351518
done
--> Running model
resnet18
-----TOP 5-----
done
同样的环境,跑 C 版本的demo,耗时只需要 0.7秒。差距大了{:5_241:}
root@743eeb4de2f7:/opt/devel/yolov5_detect_demo_release# time ./yolov5_detect_demo
time_use is 126.657997
car @ (258 909 583 1109) 0.841335
car @ (534 736 739 859) 0.831931
bus  @ (930 413 1206 531) 0.818415
car @ (1766 578 1872 657) 0.810571
car @ (721 760 927 921) 0.792803
car @ (563 950 801 1115) 0.770443
car @ (956 809 1138 968) 0.752421
car @ (801 991 1071 1115) 0.719339
person @ (1431 619 1461 686) 0.699269
car @ (0 495 137 598) 0.674166
person @ (1819 651 1863 739) 0.639357
car @ (1208 431 1261 472) 0.632317
car @ (862 402 936 469) 0.618040
car @ (1781 446 1845 504) 0.575020
person @ (1543 677 1590 771) 0.561444
person @ (375 481 399 528) 0.538842
car @ (1684 431 1737 478) 0.505462
motorbike  @ (1508 748 1564 836) 0.475376
person @ (1200 589 1232 677) 0.471330
car @ (1839 451 1878 501) 0.438286
traffic light @ (1587 548 1608 607) 0.411564
car @ (715 390 777 425) 0.394160
truck  @ (472 451 745 557) 0.392559
car @ (812 416 874 469) 0.387184
car @ (466 425 575 481) 0.358873
car @ (1622 410 1669 454) 0.350634
car @ (1481 331 1578 378) 0.340664
car @ (1191 357 1235 404) 0.321087
real        0m0.690s
user        0m0.454s
sys        0m0.191s
