调试信息如下:
Device 0: unknown device
No ethernet found.
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
请问是哪个型号的板子,刷的什么版本固件,板子刚到手时能正常开机启动吗?
麻烦发一下完整的log
RX DQS Train result:
cs0, DQS0:cyc:2,oph:3,dll:14
cs0, DQS1:cyc:2,oph:3,dll:23
cs0, DQS2:cyc:2,oph:3,dll:12
cs0, DQS3:cyc:2,oph:3,dll:24
cs1, DQS0:cyc:2,oph:3,dll:1
cs1, DQS1:cyc:2,oph:3,dll:8
cs1, DQS2:cyc:2,oph:3,dll:4
cs1, DQS3:cyc:2,oph:3,dll:16
change to: 1056MHz(final freq)
PHY drv:clk:0x1a,0x1a,ca:0x1a,0x1a,DQ:0x1e,0x1e,odt:0x0,0xa
vrefinner:0x55, vrefout:0x100
dram drv:40,odt:80
vref_ca:00000071
minca:0x7d,ck:0x80,ab:0x80,0x80, min_ck:0x3
get_clk_dqs_def_val: tdqs2dq:434
clk:0x43, clk_delta:-61,max_freq:1056
skew.dqs[0][0]:0x3d
skew.dqs[0][1]:0x30
skew.dqs[0][2]:0x37
skew.dqs[0][3]:0x26
skew.dqs[1][0]:0x3d
skew.dqs[1][1]:0x33
skew.dqs[1][2]:0x37
skew.dqs[1][3]:0x2a
cs 0:
U-Boot SPL board init
U-Boot SPL 2017.09-ga1f6fc00a0-210413 #ldq (Apr 13 2021 - 11:35:00)
[09:59:38.264]收←◆Trying to boot from MMC2
mmc_init: -95, time 10
Trying to boot from MMC1
MMC error: The cmd index is 0, ret is -110
mmc_init: -110, time 5
spl: mmc init failed with error: -110
Trying to boot from MTD2
## Verified-boot: 0
## Checking atf-1 0x00040000 … sha256+ OK
[09:59:38.311]收←◆## Checking uboot 0x00a00000 … sha256+ OK
## Checking fdt 0x00b1da90 … sha256+ OK
## Checking atf-2 0xfdcc9000 … sha256+ OK
## Checking atf-3 0xfdcd0000 … sha256+ OK
## Checking optee 0x08400000 … sha256+ OK
Total: 536.289 ms
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-126-g6b10c1bb5:zwx
NOTICE: BL31: Built : 13:56:18, May 8 2021
INFO: pmu v1 is valid
INFO: dfs DDR fsp_param[0].freq_mhz= 1056MHz
INFO: boot cpu mask: 0
INFO: BL31: Initializing BL32
[09:59:38.423]收←◆I/TC:
I/TC: Start rockchip platform init
I/TC: Rockchip release version: 1.0
I/TC: OP-TEE version: 3.6.0-307-g0b06ae94 #1 Fri May 7 01:52:27 UTC 2021 aarch64
I/TC: Initialized
INFO: SPSR = 0x3c9
[09:59:38.500]收←◆
U-Boot 2017.09-g46559b16d4 #liuth (Jun 24 2021 - 16:17:07 +0800)
Model: Firefly RK3568 Board
PreSerial: 2, raw, 0xfe660000
DRAM: 4 GiB
Sysmem: init
Relocation Offset: ed35b000, fdt: eb9f8778
[09:59:38.549]收←◆Using default environment
SF: Detected sfc_nor with page size 256 Bytes, erase size 4 KiB, total 16 MiB
Bootdev(atags): mtd 2
PartType: EFI
boot mode: recovery (misc)
FIT: No fdt blob
No resource partition
Failed to load DTB
Failed to get kernel dtb, ret=-19
io-domain: OK
rockchip_set_ethaddr: vendor_storage_write failed -5
rockchip_set_serialno: could not find efuse/otp device
apll 816000 KHz
dpll 528000 KHz
gpll 1188000 KHz
cpll 1000000 KHz
npll 24000 KHz
vpll 24000 KHz
hpll 24000 KHz
ppll 100000 KHz
armclk 816000 KHz
aclk_bus 150000 KHz
pclk_bus 50000 KHz
aclk_top_high 300000 KHz
aclk_top_low 200000 KHz
hclk_top 150000 KHz
pclk_top 50000 KHz
aclk_perimid 300000 KHz
hclk_perimid 150000 KHz
pclk_pmu 50000 KHz
Net: No ethernet found.
## Booting FIT Image FIT: No fit blob
FIT: No FIT image
optee api revision: 2.0
Not AVB images, AVB skip
No valid android hdr
Android image load failed
no mmc device at slot 1
no mmc device at slot 0
starting USB…
Bus dwc3@fcc00000: usb maximum-speed not found
[09:59:38.972]收←◆Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
Bus dwc3@fd000000: usb maximum-speed not found
[09:59:39.372]收←◆Register 2000140 NbrPorts 2
USB XHCI 1.10
scanning bus dwc3@fcc00000 for devices…
[09:59:40.489]收←◆1 USB Device(s) found
scanning bus dwc3@fd000000 for devices…
[09:59:41.611]收←◆1 USB Device(s) found
scanning usb for storage devices… 0 Storage Device(s) found
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
[09:59:41.630]收←◆.cfg/000
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-rockchip
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
BootLoader 模式下无法刷板子 只能在MaskRom模式下刷固件
使用附件loader,记得解压
使用最新ubuntu固件Firefly | 让科技更简单,让生活更智能
参考4. 切换升级存储器 — Firefly Wiki
先进入maskrom模式,高级功能,下载loader
然后读取存储列表,切换到spinor,擦除所有
再切换到emmc,擦除所有
最后回到升级固件页面,升级固件
rk356x_spl_loader_v1.07.111.zip (304 KB)
已完成,主要是spinor没擦除
{:4_211:}
