Project ERROR: Cannot run target compiler ‘aarch64-rockchip-linux-gnu-g++’. Output:
Maybe you forgot to setup the environment?
aarch64-rockchip-linux-gnu-g++ -v
Using built-in specs.
COLLECT_GCC=/home/winner/work/pk3586/rk356x_linux_release_20210511/prebuilts/gcc/linux-x86/aarch64/gcc-buildroot-9.3.0-2020.03-x86_64_aarch64-rockchip-linux-gnu/bin/aarch64-rockchip-linux-gnu-g++.br_real
COLLECT_LTO_WRAPPER=/home/winner/work/pk3586/rk356x_linux_release_20210511/prebuilts/gcc/linux-x86/aarch64/gcc-buildroot-9.3.0-2020.03-x86_64_aarch64-rockchip-linux-gnu/bin/../libexec/gcc/aarch64-rockchip-linux-gnu/9.3.0/lto-wrapper
Target: aarch64-rockchip-linux-gnu
Configured with: ./configure --prefix=/home/yhx/RK356X/SDK/buildroot/output/rockchip_toolchain/host --sysconfdir=/home/yhx/RK356X/SDK/buildroot/output/rockchip_toolchain/host/etc --enable-static --target=aarch64-rockchip-linux-gnu --with-sysroot=/home/yhx/RK356X/SDK/buildroot/output/rockchip_toolchain/host/aarch64-rockchip-linux-gnu/sysroot --enable-__cxa_atexit --with-gnu-ld --disable-libssp --disable-multilib --disable-decimal-float --with-gmp=/home/yhx/RK356X/SDK/buildroot/output/rockchip_toolchain/host --with-mpc=/home/yhx/RK356X/SDK/buildroot/output/rockchip_toolchain/host --with-mpfr=/home/yhx/RK356X/SDK/buildroot/output/rockchip_toolchain/host --with-pkgversion=‘Buildroot 2018.02-rc3-g548dfbfc13-dirty’ --with-bugurl=http://bugs.buildroot.net/ --disable-libquadmath --enable-tls --enable-plugins --enable-lto --enable-threads --with-isl=/home/yhx/RK356X/SDK/buildroot/output/rockchip_toolchain/host --with-abi=lp64 --with-cpu=cortex-a55 --enable-languages=c,c++ --with-build-time-tools=/home/yhx/RK356X/SDK/buildroot/output/rockchip_toolchain/host/aarch64-rockchip-linux-gnu/bin --enable-shared --enable-libgomp
Thread model: posix
gcc version 9.3.0 (Buildroot 2018.02-rc3-g548dfbfc13-dirty)
