在ubuntu1604下使用Linux_Upgrade_Tool下载编译好的固件时发生错误,以下内容来自于Linux_Upgrade_Tool的log文件。请大佬指教!
19:08:45 Current process in /home/firefly/prj/tools/linux/Linux_Upgrade_Tool/Linux_Upgrade_Tool
19:08:45 Using /home/firefly/.config/upgrade_tool/config.ini
19:08:45 Command Line: ./upgrade_tool uf /home/firefly/prj/Firefly-RK3308/rockdev/update.img
19:08:45 Current Device Location ID:11
19:08:45 Test Device Start
19:08:50 Error:RKU_Write failed,err=-7
19:08:50 ERROR:TestDevice–>RKU_TestDeviceReady failed,RetCode(-3)
19:08:56 Error:RKU_Write failed,err=-7
19:08:56 ERROR:TestDevice–>RKU_TestDeviceReady failed,RetCode(-3)
19:09:02 Error:RKU_Write failed,err=-7
19:09:02 ERROR:TestDevice–>RKU_TestDeviceReady failed,RetCode(-3)
19:09:03 Test Device Fail
19:09:03 Command mode out
