问题描述: rknn.init_runtime(target=‘rk3568’),执行失败,日志如下,目前docker里通过adb链接3568设备,但是触发崩溃
固件版本:AIO-3568J_Android11_HDMI_210715
rknn-tool2版本:rknn-toolkit2-1.1.0b5
Init runtime environment
all device(s) with adb mode:
7901XYKX21
(['7901XYKX21'], [])
I target set by user is: rk3568
I Starting ntp or adb, target is RK3568, host is None
I Start adb...
I Connect to Device success!
I NPUTransfer: Starting NPU Transfer Client, Transfer version 2.1.0 (b5861e7@2020-11-23T11:50:36)
D NPUTransfer: Transfer spec = local:transfer_proxy
D NPUTransfer: ERROR: socket read fd = 3, n = -1: Connection reset by peer
D NPUTransfer: Transfer client closed, fd = 3
E RKNNAPI: rknn_init, driver open fail! ret = -9(ERROR_PIPE)!
E init_runtime: Catch exception when init runtime!
E init_runtime: Traceback (most recent call last):
E init_runtime: File "rknn/api/rknn_base.py", line 2483, in rknn.api.rknn_base.RKNNBase.init_runtime
E init_runtime: File "rknn/api/rknn_runtime.py", line 369, in rknn.api.rknn_runtime.RKNNRuntime.build_graph
E init_runtime: Exception: RKNN init failed. error code: RKNN_ERR_DEVICE_UNAVAILABLE
E init_runtime: Current device id is: None
W init_runtime: ===================== WARN(3) =====================
File "test.py", line 92, in <module>
ret = rknn.init_runtime(target='rk3568')
File "/usr/local/lib/python3.6/dist-packages/rknn/api/rknn.py", line 324, in init_runtime
self.rknn_log.e("Current device id is: {}".format(device_id))
File "rknn/api/rknn_log.py", line 105, in rknn.api.rknn_log.RKNNLog.e
ValueError: Current device id is: None
