RK3399-JD4在编译Builldroot时,根据教程在device/rockchip/rk3399/ 目录下找不到./build.sh aio-3399-jd4-buildroot文件,怎么解决。
执行 ./build.sh aio-3399-jd4-buildroot.mk
用哪个build.sh执行,现在文件夹下面没有build.sh文件。
如果用rk3399_linux_release_v2.5.1_20210301目录下的会出现找不到.BoardConfig.mk文件的错
./build.sh: line 94: rk3399_linux_release_v2.5.1_20210301/device/rockchip/.BoardConfig.mk: No such file or directory
./build.sh: …
在 SDK 根目录下执行:./build.sh aio-3399-jd4-buildroot.mk
没有的话,可以手动链接一下:
cd device/rockchip/
ln -sf rk3399/aio-3399-jd4-buildroot.mk .BoardConfig.mk
时间的蝴蝶 发表于 2021-8-6 14:17
在 SDK 根目录下执行:./build.sh aio-3399-jd4-buildroot.mk没有的话,可以手动链接一下:
谢谢,这步已经完成,在编译recovery的时候报错:
Done in 1h 14min 56s (error code: 2)
Command exited with non-zero status 2
you take 1:14:58 to build recovery
ERROR: Running build_recovery failed!
ERROR: exit code 2 from line 661:
/usr/bin/time -f “you take %E to build recovery” $COMMON_DIR/mk-ramdisk.sh recovery.img $RK_CFG_RECOVERY
你这 log 没有有效信息呀,发下完整 log
看着像下载网址有问题;
2021-08-06T14:51:00 /root/prject/buildroot/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/host/bin/aarch64-buildroot-linux-gnu-gcc -fPIC -shared -Wl,-soname,liblockfile.so.1 -o liblockfile.so lockfile.o -lc
2021-08-06T14:51:00 e[01me[Klockfile.c:e[me[K In function ‘e[01me[Klockfile_create_save_tmplocke[me[K’:
2021-08-06T14:51:00 e[01me[Klockfile.c:250:44:e[me[K e[01;35me[Kwarning: e[me[K’e[01me[K%se[me[K’ directive output may be truncated writing up to 255 bytes into a region of size between 17 and 23 [e[01;35me[K-Wformat-truncation=e[me[K]
2021-08-06T14:51:00 snprintf(p, TMPLOCKFILENAMESZ, “%s%0d%0xe[01;35me[K%se[me[K”, TMPLOCKSTR,
2021-08-06T14:51:00 e[01;35me[K^~e[me[K
2021-08-06T14:51:00 e[01me[Klockfile.c:253:4:e[me[K
2021-08-06T14:51:00 e[32me[Ksysnamee[me[K);
2021-08-06T14:51:00 e[32me[K~e[me[K
2021-08-06T14:51:00 e[01me[Klockfile.c:250:2:e[me[K e[01;36me[Knote: e[me[K’e[01me[Ksnprintfe[me[K’ output between 10 and 271 bytes into a destination of size 32
2021-08-06T14:51:00 e[01;36me[Ksnprintf(p, TMPLOCKFILENAMESZ, “%s%0d%0x%s”, TMPLOCKSTR,e[me[K
2021-08-06T14:51:00 e[01;36me[K^~e[me[Ke[me[K
2021-08-06T14:51:00 e[01;36me[K TMPLOCKPIDSZ, (int)getpid(),e[me[K
2021-08-06T14:51:00 e[01;36me[K TMPLOCKTIMESZ, (int)time(NULL) & 15,e[me[K
2021-08-06T14:51:00 e[01;36me[Ke[me[K~~~~~~e[me[K
2021-08-06T14:51:00 e[01;36me[K sysname)e[me[K;
2021-08-06T14:51:00 /root/prject/buildroot/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/host/bin/aarch64-buildroot-linux-gnu-gcc -o dotlockfile dotlockfile.o xlockfile.o
2021-08-06T14:51:00 e[7m>>> liblockfile 1.09 Installing to staging directorye[27m
2021-08-06T14:51:00 mkdir -p /root/prject/buildroot/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/host/aarch64-buildroot-linux-gnu/sysroot/usr/share/man/man1 /root/prject/buildroot/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/host/aarch64-buildroot-linux-gnu/sysroot/usr/share/man/man3
2021-08-06T14:51:00 rm -f /root/prject/buildroot/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/host/aarch64-buildroot-linux-gnu/sysroot/usr/lib/liblockfile.so
2021-08-06T14:51:00 PATH=“/root/prject/buildroot/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/host/bin:/root/prject/buildroot/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/host/sbin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin” /usr/bin/make -j2 -C /root/prject/buildroot/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/build/liblockfile-1.09 ROOT=/root/prject/buildroot/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/host/aarch64-buildroot-linux-gnu/sysroot install
2021-08-06T14:51:00 install -m 644 lockfile.h maillock.h /root/prject/buildroot/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/host/aarch64-buildroot-linux-gnu/sysroot/usr/include
2021-08-06T14:51:00 install -m 2755 dotlockfile /root/prject/buildroot/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/host/aarch64-buildroot-linux-gnu/sysroot/usr/bin; install -m 644 *.1 /root/prject/buildroot/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/host/aarch64-buildroot-linux-gnu/sysroot/usr/share/man/man1
2021-08-06T14:51:00 install -m 644 .3 /root/prject/buildroot/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/host/aarch64-buildroot-linux-gnu/sysroot/usr/share/man/man3
2021-08-06T14:51:00 install -m 755 liblockfile.so /root/prject/buildroot/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/host/aarch64-buildroot-linux-gnu/sysroot/usr/lib/liblockfile.so.1.0
2021-08-06T14:51:00 ln -s liblockfile.so.1.0 /root/prject/buildroot/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/host/aarch64-buildroot-linux-gnu/sysroot/usr/lib/liblockfile.so
2021-08-06T14:51:00 if test “/root/prject/buildroot/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/host/aarch64-buildroot-linux-gnu/sysroot” = “”; then /sbin/ldconfig; fi
2021-08-06T14:51:00 ln -sf liblockfile.so /root/prject/buildroot/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/host/aarch64-buildroot-linux-gnu/sysroot/usr/lib/liblockfile.so.1
2021-08-06T14:51:00 e[7m>>> liblockfile 1.09 Fixing libtool filese[27m
2021-08-06T14:51:01 e[7m>>> liblockfile 1.09 Installing to targete[27m
2021-08-06T14:51:01 cp -a /root/prject/buildroot/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/host/aarch64-buildroot-linux-gnu/sysroot/usr/lib/liblockfile.so /root/prject/buildroot/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/target/usr/lib
2021-08-06T14:51:02 e[7m>>> libpng 1.6.37 Downloadinge[27m
2021-08-06T14:51:02 --2021-08-06 14:51:02-- http://downloads.sourceforge.net/project/libpng/libpng16/1.6.37/libpng-1.6.37.tar.xz
2021-08-06T14:51:02 Resolving downloads.sourceforge.net (downloads.sourceforge.net)… 204.68.111.105
2021-08-06T14:51:02 Connecting to downloads.sourceforge.net (downloads.sourceforge.net)|204.68.111.105|:80… connected.
2021-08-06T14:51:02 HTTP request sent, awaiting response… 302 Found
2021-08-06T14:51:02 Location: https://udomain.dl.sourceforge.net/project/libpng/libpng16/1.6.37/libpng-1.6.37.tar.xz [following]
2021-08-06T14:51:02 --2021-08-06 14:51:02-- https://udomain.dl.sourceforge.net/project/libpng/libpng16/1.6.37/libpng-1.6.37.tar.xz
2021-08-06T14:51:02 Resolving udomain.dl.sourceforge.net (udomain.dl.sourceforge.net)… 203.135.147.10
2021-08-06T14:51:06 Connecting to udomain.dl.sourceforge.net (udomain.dl.sourceforge.net)|203.135.147.10|:443… failed: Connection refused.
2021-08-06T14:51:06 --2021-08-06 14:51:06-- http://sources.buildroot.net/libpng-1.6.37.tar.xz
2021-08-06T14:51:06 Resolving sources.buildroot.net (sources.buildroot.net)… 104.26.1.37, 104.26.0.37, 172.67.72.56, …
2021-08-06T14:51:06 Connecting to sources.buildroot.net (sources.buildroot.net)|104.26.1.37|:80… connected.
2021-08-06T14:51:07 HTTP request sent, awaiting response… 404 Not Found
2021-08-06T14:51:07 2021-08-06 14:51:07 ERROR 404: Not Found.
2021-08-06T14:51:07
2021-08-06T14:51:07 package/pkg-generic.mk:166: recipe for target ‘/root/prject/buildroot/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/build/libpng-1.6.37/.stamp_downloaded’ failed
2021-08-06T14:51:07 make[1]: *** [/root/prject/buildroot/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/build/libpng-1.6.37/.stamp_downloaded] Error 1
2021-08-06T14:51:07 /root/prject/buildroot/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/Makefile:16: recipe for target ‘_all’ failed
2021-08-06T14:51:07 make: *** [_all] Error 2
已经编译成功谢谢支持{:4_121:}。建议把编译buildroot所需的空间大小写一下。我这边第一次编译只开了80G的内存,不够用,后面又加的,增加了一些麻烦。
