ubuntu18如何安装obs
试了网上很多方法安装obs时都失败了
错误提示:E:Unable to locate package obs-studio
听说需要移植编译,不知道对不对,请教正确的安装方法。
没有 arm 版本的,要找下其它源 或 手动编译;
https://github.com/obsproject/obs-studio/wiki/Install-Instructions#linux-build-directions
参考网站的方法编译后运行报错,估计是RK3568用不了这个东西
root@firefly:/usr/bin# obs
Rga built version:06fc7c4
arm_release_ver of this libmali is ‘g2p0-01eac0’, rk_so_ver is ‘4’.
Attempted path: share/obs/obs-studio/locale/en-US.ini
Attempted path: /usr/share/obs/obs-studio/locale/en-US.ini
Attempted path: share/obs/obs-studio/locale.ini
Attempted path: /usr/share/obs/obs-studio/locale.ini
Attempted path: share/obs/obs-studio/themes/Dark.qss
Attempted path: /usr/share/obs/obs-studio/themes/Dark.qss
info: Physical Cores: 4, Logical Cores: 4
info: Physical Memory: 1841MB Total, 760MB Free
info: Kernel Version: Linux 4.19.193
info: Distribution: “Ubuntu” “18.04”
info: Window System: X11.0, Vendor: The X.Org Foundation, Version: 1.20.4
info: Portable mode: false
Attempted path: share/obs/obs-studio/themes/Dark/no_sources.svg
Attempted path: /usr/share/obs/obs-studio/themes/Dark/no_sources.svg
QMetaObject::connectSlotsByName: No matching signal for on_advAudioProps_clicked()
QMetaObject::connectSlotsByName: No matching signal for on_advAudioProps_destroyed()
QMetaObject::connectSlotsByName: No matching signal for on_actionGridMode_triggered()
QMetaObject::connectSlotsByName: No matching signal for on_program_customContextMenuRequested(QPoint)
info: OBS 0.0.1 (linux)
info: ---------------------------------
info: audio settings reset:
samples per sec: 44100
speakers: 2
info: Initializing OpenGL…
libGL error: failed to create dri screen
libGL error: failed to load driver: rockchip
Segmentation fault
看样子是不行
