【AIO-3399-JD4】sdk编译ubuntu16.04,img烧写不正常
按照wiki,下载官网的ubuntu16.04镜像,放入sdk指定路径下,修改配置文件,并执行build.sh aio-3399-jd4-ubuntu.mk。将生成的整体固件,烧写到开发板后,报如下错误。
[    4.600589] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=300
[    4.601196] dhd_bus_devreset:  WLAN OFF DONE
[    4.602408] wifi_platform_set_power = 0
[    4.602785] ======== PULL WL_REG_ON(-1) LOW! ========
OK[    4.603232] [WLAN_RFKILL]: rockchip_wifi_power: 0
[    4.603680] [WLAN_RFKILL]: wifi shut off power.
[    4.604082] dhdsdio_probe : the lock is released.
[    4.604757] dhd_module_init: Exit err=0
Debug: configfs_init
mkdir: can't create directory '/sys/kernel/config/usb_gadget/rockchip/functions/uac1.gs0': No such file or directory
mkdir: can't create directory '/sys/kernel/config/usb_gadget/rockchip/functions/uac2.gs0': No such file or directory
[    4.627810] file system registered
mkdir: can't create directory '/sys/kernel/config/usb_gadget/rockchip/functions/mtp.gs0': No such file or directory
mkdir: can't create directory '/sys/kernel/config/usb_gadget/rockchip/functions/rndis.gs0': No such file or directory
[    4.637183] Mass Storage Function, version: 2009/09/11
[    4.637685] LUN: removable file: (no medium)
mkdir: can't create directory '/sys/kernel/config/usb_gadget/rockchip/functions/uvc.gs6': No such file or directory
[    4.658878] read descriptors
[    4.659143] read strings
sh: write error: No such device
Starting input-event-daemon: input-event-daemon: Start parsing /etc/input-event-daemon.conf...
input-event-daemon: Adding device: /dev/input/event0...
input-event-daemon: Adding device: /dev/input/event1...
input-event-daemon: Adding device: /dev/input/event2...
input-event-daemon: Start listening on 3 devices...
done
/etc/init.d/rcS: line 28: alsactl: not found
[root@buildroot:/]# rotate degree: 0 - none, 1 - right, 2 - down, 3 - left.
current rotate degree is : 0
Ui upgrade
recovery filesystem table
  0 (null) /tmp ramdisk (null) (null) (null)
  1 /dev/root / ext2 rw,noauto 0 1
  2 proc /proc proc defaults 0 0
  3 devpts /dev/pts devpts defaults,gid=5,mode=620 0 0
  4 tmpfs /dev/shm tmpfs mode=0777 0 0
  5 tmpfs /tmp tmpfs mode=1777 0 0
  6 tmpfs /run tmpfs mode=0755,nosuid,nodev 0 0
  7 sysfs /sys sysfs defaults 0 0
  8 debug /sys/kernel/debug debugfs defaults 0 0
  9 pstore /sys/fs/pstore pstore defaults 0 0
  10 /dev/block/by-name/misc /misc emmc defaults 0 0
  11 /dev/block/by-name/oem /oem ext2 defaults 0 2
  12 /dev/block/by-name/userdata /userdata ext4 defaults 0 2
buf = /dev/block/by-name/misc
 ### get mount_ponit = /dev/block/by-name/misc ###
emmc_point is /dev/mmcblk1
sd_point is (null)
sd_point_2 is (null)
Recovery start....................
read cmdline
>>> Boot from non-SDcard
devices is not MTD.
I:Boot command: boot-recovery
I:Got arguments from boot message
devices is not MTD.
Command: "recovery" "--wipe_all"
Formatting /userdata...
No link to path!!!
No link to path!!!
format '/dev/block/by-name/userdata' to ext4 filesystem
executing '/sbin/mke2fs'
[    8.202692] random: nonblocking pool is initialized
过几十秒后会自动重启,之后一直打印:
[ 11.473465] mali ff9a0000.gpu: Stride passed to job_submit doesn’t match kernel
同时HDMI也无输出。
有遇见过的么???
另外,使用配套资料里面的:AIO-3399-JD4\固件\Ubuntu\ubuntu18.04\Public*.img,一切正常,HDMI也正常。硬件上应该没有问题
