kernel启动过程中卡死,有无一些通用的方法能够快速定位卡死在哪里?
一般看log找问题
zyk 发表于 2021-8-11 11:39
一般看log找问题
自己做的板子,按原理图修改好了dts,但是烧录进去后。卡死在kernel启动过程。同样的烧录到aioj板子,也可以启动Android。对比了 log
自己的板子
[ 3.641029] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '14:53:48', on 'Aug 10 2021'.
[ 3.641236] Mali:
[ 3.641238] Mali device driver loaded
[ 3.641256] rkcif rkcif_mipi_lvds: clear unready subdev num: 1
[ 3.641265] rkcif_mipi_lvds: Async subdev notifier completed
[ 3.641276] rkisp rkisp-vir0: clear unready subdev num: 1
[ 3.641527] rkisp0: update sensor failed
卡死
aioj开发板
[ 3.652232] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '14:53:48', on 'Aug 10 2021'.
[ 3.652897] Mali:
[ 3.652901] Mali device driver loaded
[ 3.652965] rkcif rkcif_mipi_lvds: clear unready subdev num: 1
[ 3.652997] rkcif_mipi_lvds: Async subdev notifier completed
[ 3.653032] rkisp rkisp-vir0: clear unready subdev num: 1
[ 3.653740] rkisp0: update sensor failed
[ 3.659380] ret 1024 0
[ 3.660081] ALSA device list:
[ 3.660120] #0: rockchip,hdmi
[ 3.660135] #1: rockchip,rk809-codec
[ 3.663559] Freeing unused kernel memory: 4096K
[ 3.663782] Run /init as init process
[ 3.669645] rockchip-dmc dmc: cpu3 policy NULL
[ 3.733320] init: init first stage started!
[ 3.733680] init: Unable to open /lib/modules, skipping module loading.
[ 3.733815] init: First stage mount skipped (recovery mode)
[ 3.734583] init: [libfs_mgr]ReadFstabFromDt(): failed to read fstab from dt
[ 3.736057] init: Using Android DT directory /proc/device-tree/firmware/android/
往下继续正常
我也卡死在这个位置了,请问楼上解决了吗?
同问,请问怎么解决的
我也卡死在这个位置了,请问楼上有人解决了吗?
接调试串口,提供完整的log信息。
请问卡死的问题定位了吗?我也遇到同样的问题,打印信息也一样
我也遇到这个问题,有定位到问题的同学吗,是不是sdk加密的原因,在厂家的核心板上可以正常运行,自研的板无法正常运行。
请问这个问题有人解决吗?
{:4_89:}同问
DDR Version V1.05 20220224_fix_sd_boot
LPDDR4X, 2112MHz
channel[0] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
channel[1] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
channel[2] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
channel[3] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
change to F1: 528MHz
change to F2: 1068MHz
change to F3: 1560MHz
change to F0: 2112MHz
out
U-Boot SPL board init
U-Boot SPL 2017.09-g40801113c5-211215 #zzz (Jan 20 2022 - 11:13:35)
Failed to set cpub01
Failed to set cpub23
unknown raw ID phN
unrecognized JEDEC id bytes: ff, ff, ff
Trying to boot from MMC2
MMC: no card present
mmc_init: -123, time 0
spl: mmc init failed with error: -123
Trying to boot from MMC1
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking atf-1 0x00040000 … sha256(d13308999f…) + OK
## Checking uboot 0x00200000 … sha256(7ffb58876c…) + OK
## Checking fdt 0x00326918 … sha256(a5e6b35d32…) + OK
## Checking atf-2 0x000f0000 … sha256(5654dd95de…) + OK
## Checking atf-3 0xff100000 … sha256(7be1eaface…) + OK
## Checking atf-4 0xff009000 … sha256(2301cf73be…) + OK
## Checking optee 0x08400000 … sha256(9289764f93…) + OK
Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000)
Total: 88.668 ms
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-297-g5ac4bc169:derrick.huang
NOTICE: BL31: Built : 12:42:49, Mar 8 2022
INFO: timer_hp_init no valid 32k timer source, use normal mode
INFO: idle_st=0x21fff, pd_st=0x11fff9
INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz
INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz
INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz
INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz
INFO: boot cpu mask: 0
INFO: BL31: Initializing BL32
I/TC:
I/TC: OP-TEE version: 3.13.0-628-g3f0f0b052 #hisping.lin (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #4 Fri Jan 14 09:33:37 CST 2022 aarch64
INFO: SPSR = 0x3c9
U-Boot 2017.09(u-boot commit id: )(sdk version: .xml) (Dec 15 2022 - 20:31:49 +0800)
Model: Rockchip RK3588 Evaluation Board
PreSerial: 2, raw, 0xfeb50000
DRAM: 7.7 GiB
Sysmem: init
Relocation Offset: edb50000
Relocation fdt: eb9fa5f0 - eb9fecd8
CR: M/C/I
mmc@fe2c0000: 1, mmc@fe2e0000: 0
Bootdev(atags): mmc 0
MMC0: HS400, 200Mhz
PartType: EFI
DM: v2
boot mode: recovery (misc)
=================begin===================
146010 bytes read in 53 ms (2.6 MiB/s)
DTB(Distro): rk-kernel.dtb
I2c0 speed: 100000Hz
vsel-gpios- not found! Error: -2
en-gpios- not found! Error: -2
vdd_cpu_big1_s0 675000 uV
I2c2 speed: 100000Hz
vdd_npu_s0 850000 uV
spi2: RK806: 2
vdd_gpu_s0 750000 uV
vdd_cpu_lit_s0 750000 uV
vdd_vdenc_s0 init 750000 uV
I2c6 speed: 100000Hz
Model: Firefly ITX-3588J HDMI(Linux)
CLK: (uboot. arm: enter 1200000 KHz, init 1200000 KHz, kernel 0N/A)
b0pll 1200000 KHz
b1pll 1200000 KHz
lpll 1200000 KHz
v0pll 24000 KHz
aupll 786215 KHz
cpll 1500000 KHz
gpll 1188000 KHz
npll 850000 KHz
ppll 100000 KHz
aclk_center_root 702000 KHz
pclk_center_root 200000 KHz
hclk_center_root 396000 KHz
aclk_center_low_root 500000 KHz
aclk_top_root 750000 KHz
pclk_top_root 100000 KHz
aclk_low_top_root 396000 KHz
Net: eth0: ethernet@fe1b0000, eth1: ethernet@fe1c0000
optee api revision: 2.0
Not AVB images, AVB skip
No valid android hdr
Android image load failed
## Booting FIT Image at 0xe91df9c0 with size 0x02619c00
Fdt Ramdisk skip relocation
## Loading kernel from FIT Image at e91df9c0 …
Using ‘conf’ configuration
## Verified-boot: 0
Trying ‘kernel’ kernel subimage
Description: unavailable
Type: Kernel Image
Compression: uncompressed
Data Start: 0xe9203dc0
Data Size: 32778248 Bytes = 31.3 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x00400000
Entry Point: 0x00400000
Hash algo: sha256
Hash value: 37ad05bd962b895842944d1cecc0a8721d23e8b594df9267f4ac9a543fdc0316
Verifying Hash Integrity … sha256+ OK
## Loading ramdisk from FIT Image at e91df9c0 …
Trying ‘ramdisk’ ramdisk subimage
Type: RAMDisk Image
Data Start: 0xeb1467c0
Data Size: 7024050 Bytes = 6.7 MiB
OS: Linux
Load Address: 0x0a200000
Entry Point: unavailable
Hash algo: sha256
Hash value: 818060783fbb7d01a399aed2ecc5bc5457dde2c01d31f4d6980d79dd881954e2
Loading ramdisk from 0xeb1467c0 to 0x0a200000
## Loading fdt from FIT Image at e91df9c0 …
Trying ‘fdt’ fdt subimage
Type: Flat Device Tree
Data Start: 0xe91e01c0
Data Size: 146010 Bytes = 142.6 KiB
Load Address: 0x0a100000
Hash algo: sha256
Hash value: 4bdd964b22ac74ca4247004cf6f8c68c4551d24b015449a2ab2cc03acb0eb58a
Loading fdt from 0x0a100000 to 0x0a100000
Loading Kernel Image from 0xe9203dc0 to 0x00400000 … OK
kernel loaded at 0x00400000, end = 0x02342808
‘reserved-memory’ hdmirx-trans@10000000: addr=10000000 size=10000000
Using Device Tree in place at 000000000a100000, end 000000000a126a59
Adding bank: 0x100000000 - 0x200000000 (size: 0x100000000)
Total: 630.887 ms
[ 0.745236] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[ 0.745260] Linux version 5.10.66 (lidm@ubuntu) (kernel commit id: ) (sdk version: .xml) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 10.3.1 20210621, GNU ld (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 2.36.1.20210621) #3 SMP Thu Dec 15 20:10:46 CST 2022
[ 0.755274] Machine model: Firefly ITX-3588J HDMI(Linux)
[ 0.755344] earlycon: uart8250 at MMIO32 0x00000000feb50000 (options ‘’)
[ 0.759731] printk: bootconsole [uart8250] enabled
[ 0.765498] OF: fdt: Reserved memory: failed to reserve memory for node ‘drm-logo@00000000’: base 0x0000000000000000, size 0 MiB
[ 0.766571] OF: fdt: Reserved memory: failed to reserve memory for node ‘drm-cubic-lut@00000000’: base 0x0000000000000000, size 0 MiB
[ 0.767737] Reserved memory: created CMA memory pool at 0x00000001ff800000, size 8 MiB
[ 0.768464] OF: reserved mem: initialized node cma, compatible id shared-dma-pool
[ 0.769193] Reserved memory: created CMA memory pool at 0x0000000010000000, size 256 MiB
[ 0.769935] OF: reserved mem: initialized node hdmirx-trans@10000000, compatible id shared-dma-pool
[ 0.914061] Zone ranges:
[ 0.914304] DMA [mem 0x0000000000200000-0x00000000ffffffff]
[ 0.914879] DMA32 empty
[ 0.915147] Normal [mem 0x0000000100000000-0x00000001ffffffff]
[ 0.915718] Movable zone start for each node
[ 0.916111] Early memory node ranges
[ 0.916442] node 0: [mem 0x0000000000200000-0x00000000083fffff]
[ 0.917019] node 0: [mem 0x0000000009400000-0x00000000efffffff]
[ 0.917598] node 0: [mem 0x0000000100000000-0x00000001ffffffff]
[ 0.918178] Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff]
[ 0.963566] psci: probing for conduit method from DT.
[ 0.964042] psci: PSCIv1.1 detected in firmware.
[ 0.964468] psci: Using standard PSCI v0.2 function IDs
[ 0.964951] psci: Trusted OS migration not required
[ 0.965401] psci: SMC Calling Convention v1.2
[ 0.966202] percpu: Embedded 30 pages/cpu s85160 r8192 d29528 u122880
[ 0.966992] Detected VIPT I-cache on CPU0
[ 0.967408] CPU features: detected: GIC system register CPU interface
[ 0.968000] CPU features: detected: Virtualization Host Extensions
[ 0.968574] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.969220] alternatives: patching kernel code
[ 0.969964] Built 1 zonelists, mobility grouping on. Total pages: 1995336
[ 0.970602] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.verifiedbootstate=orange ro rootwait earlycon=uart8250,mmio32,0xfeb50000 console=ttyFIQ0 irqchip.gicv3_pseudo_nmi=0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1
[ 0.975274] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.976463] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.977184] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.985084] software IO TLB: mapped [mem 0x00000000ec000000-0x00000000f0000000] (64MB)
[ 1.068893] Memory: 7575196K/8108032K available (16062K kernel code, 3402K rwdata, 5944K rodata, 6528K init, 564K bss, 262500K reserved, 270336K cma-reserved)
[ 1.070342] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 1.070979] ftrace: allocating 60301 entries in 236 pages
[ 1.178380] ftrace: allocated 236 pages with 5 groups
[ 1.179165] rcu: Hierarchical RCU implementation.
[ 1.179603] rcu: RCU event tracing is enabled.
[ 1.180021] Rude variant of Tasks RCU enabled.
[ 1.180440] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 1.187017] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 1.189657] GICv3: GIC: Using split EOI/Deactivate mode
[ 1.190143] GICv3: 480 SPIs implemented
[ 1.190497] GICv3: 0 Extended SPIs implemented
[ 1.190936] GICv3: Distributor has no Range Selector support
[ 1.191463] GICv3: 16 PPIs implemented
[ 1.191854] GICv3: CPU0: found redistributor 0 region 0:0x00000000fe680000
[ 1.192618] ITS [mem 0xfe640000-0xfe65ffff]
[ 1.193061] ITS@0x00000000fe640000: allocated 8192 Devices @1001f0000 (indirect, esz 8, psz 64K, shr 0)
[ 1.193949] ITS@0x00000000fe640000: allocated 32768 Interrupt Collections @100200000 (flat, esz 2, psz 64K, shr 0)
[ 1.194901] ITS: using cache flushing for cmd queue
[ 1.195384] ITS [mem 0xfe660000-0xfe67ffff]
[ 1.195817] ITS@0x00000000fe660000: allocated 8192 Devices @100220000 (indirect, esz 8, psz 64K, shr 0)
[ 1.196703] ITS@0x00000000fe660000: allocated 32768 Interrupt Collections @100230000 (flat, esz 2, psz 64K, shr 0)
[ 1.197654] ITS: using cache flushing for cmd queue
[ 1.198264] GICv3: using LPI property table @0x0000000100240000
[ 1.198955] GIC: using cache flushing for LPI property table
[ 1.199482] GICv3: CPU0: using allocated LPI pending table @0x0000000100250000
[ 1.200328] random: get_random_bytes called from start_kernel+0x3dc/0x5d0 with crng_init=0
[ 1.335530] rockchip_cpuclk_pre_rate_change: limiting alt-divider 36254 to 31
[ 1.340359] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 1.340937] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 1.341947] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 1.344239] Console: colour dummy device 80x25
[ 1.344689] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 1.345653] pid_max: default: 32768 minimum: 301
[ 1.346304] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 1.347038] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 1.350132] rcu: Hierarchical SRCU implementation.
[ 1.351799] Platform MSI: msi-controller@fe640000 domain created
[ 1.352384] Platform MSI: msi-controller@fe660000 domain created
[ 1.353345] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe640000 domain created
[ 1.354141] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe660000 domain created
[ 1.355560] smp: Bringing up secondary CPUs …
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
[ 1.357420] Detected VIPT I-cache on CPU1
[ 1.357467] GICv3: CPU1: found redistributor 100 region 0:0x00000000fe6a0000
[ 1.357491] GICv3: CPU1: using allocated LPI pending table @0x0000000100260000
[ 1.357542] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[ 1.359109] Detected VIPT I-cache on CPU2
[ 1.359152] GICv3: CPU2: found redistributor 200 region 0:0x00000000fe6c0000
[ 1.359176] GICv3: CPU2: using allocated LPI pending table @0x0000000100270000
[ 1.359224] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[ 1.360718] Detected VIPT I-cache on CPU3
[ 1.360757] GICv3: CPU3: found redistributor 300 region 0:0x00000000fe6e0000
[ 1.360780] GICv3: CPU3: using allocated LPI pending table @0x0000000100280000
[ 1.360826] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[ 1.362324] CPU features: detected: Spectre-v4
[ 1.362328] Detected PIPT I-cache on CPU4
[ 1.362344] GICv3: CPU4: found redistributor 400 region 0:0x00000000fe700000
[ 1.362354] GICv3: CPU4: using allocated LPI pending table @0x0000000100290000
[ 1.362379] CPU4: Booted secondary processor 0x0000000400 [0x414fd0b0]
[ 1.363791] Detected PIPT I-cache on CPU5
[ 1.363808] GICv3: CPU5: found redistributor 500 region 0:0x00000000fe720000
[ 1.363818] GICv3: CPU5: using allocated LPI pending table @0x00000001002a0000
[ 1.363845] CPU5: Booted secondary processor 0x0000000500 [0x414fd0b0]
[ 1.365303] Detected PIPT I-cache on CPU6
[ 1.365319] GICv3: CPU6: found redistributor 600 region 0:0x00000000fe740000
[ 1.365329] GICv3: CPU6: using allocated LPI pending table @0x00000001002b0000
[ 1.365355] CPU6: Booted secondary processor 0x0000000600 [0x414fd0b0]
[ 1.366752] Detected PIPT I-cache on CPU7
[ 1.366769] GICv3: CPU7: found redistributor 700 region 0:0x00000000fe760000
[ 1.366779] GICv3: CPU7: using allocated LPI pending table @0x00000001002c0000
[ 1.366804] CPU7: Booted secondary processor 0x0000000700 [0x414fd0b0]
[ 1.366893] smp: Brought up 1 node, 8 CPUs
[ 1.383822] SMP: Total of 8 processors activated.
[ 1.384264] CPU features: detected: Privileged Access Never
[ 1.384786] CPU features: detected: User Access Override
[ 1.385285] CPU features: detected: 32-bit EL0 Support
[ 1.385762] CPU features: detected: Common not Private translations
[ 1.386347] CPU features: detected: RAS Extension Support
[ 1.386865] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 1.387667] CPU features: detected: CRC32 instructions
[ 1.388148] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 1.388800] CPU features: detected: RCpc load-acquire (LDAPR)
[ 1.389449] CPU: All CPU(s) started at EL2
[ 1.391757] devtmpfs: initialized
[ 1.402156] Registered cp15_barrier emulation handler
[ 1.402634] Registered setend emulation handler
[ 1.403129] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 1.404027] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 1.407406] pinctrl core: initialized pinctrl subsystem
[ 1.408325] NET: Registered protocol family 16
[ 1.409703] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 1.410458] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 1.412610] thermal_sys: Registered thermal governor ‘fair_share’
[ 1.412613] thermal_sys: Registered thermal governor ‘step_wise’
[ 1.413486] cpuidle: using governor menu
[ 1.414400] Registered FIQ tty driver
[ 1.414972] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 1.415732] ASID allocator initialised with 65536 entries
[ 1.417854] printk: console [ramoops-1] enabled
[ 1.418272] pstore: Registered ramoops as persistent store backend
[ 1.418839] ramoops: using 0xf0000@0x110000, ecc: 0
[ 1.461890] rockchip-gpio fd8a0000.gpio: probed /pinctrl/gpio@fd8a0000
[ 1.462725] rockchip-gpio fec20000.gpio: probed /pinctrl/gpio@fec20000
[ 1.463547] rockchip-gpio fec30000.gpio: probed /pinctrl/gpio@fec30000
[ 1.464363] rockchip-gpio fec40000.gpio: probed /pinctrl/gpio@fec40000
[ 1.465172] rockchip-gpio fec50000.gpio: probed /pinctrl/gpio@fec50000
[ 1.465798] rockchip-pinctrl pinctrl: probed pinctrl
[ 1.530519] raid6: neonx8 gen() 5459 MB/s
[ 1.587296] raid6: neonx8 xor() 4222 MB/s
[ 1.644080] raid6: neonx4 gen() 5495 MB/s
[ 1.700859] raid6: neonx4 xor() 4253 MB/s
[ 1.757640] raid6: neonx2 gen() 5169 MB/s
[ 1.814422] raid6: neonx2 xor() 4026 MB/s
[ 1.871204] raid6: neonx1 gen() 4466 MB/s
[ 1.927984] raid6: neonx1 xor() 3324 MB/s
[ 1.984778] raid6: int64x8 gen() 1321 MB/s
[ 2.041544] raid6: int64x8 xor() 826 MB/s
[ 2.098326] raid6: int64x4 gen() 1638 MB/s
[ 2.155117] raid6: int64x4 xor() 903 MB/s
[ 2.211888] raid6: int64x2 gen() 2416 MB/s
[ 2.268672] raid6: int64x2 xor() 1327 MB/s
[ 2.325455] raid6: int64x1 gen() 2001 MB/s
[ 2.382238] raid6: int64x1 xor() 1090 MB/s
[ 2.382631] raid6: using algorithm neonx4 gen() 5495 MB/s
[ 2.383127] raid6: … xor() 4253 MB/s, rmw enabled
[ 2.383583] raid6: using neon recovery algorithm
[ 2.384533] fiq_debugger fiq_debugger.0: IRQ fiq not found
[ 2.385041] fiq_debugger fiq_debugger.0: IRQ wakeup not found
[ 2.385570] fiq_debugger_probe: could not install nmi irq handler
[ [ 2.386176] printk: console [ttyFIQ0] enabled
[ 2.386954] printk: bootconsole [uart8250] disabled
[ 2.387486] Registered fiq debugger ttyFIQ0
[ 2.387824] vcc5v0_sys: supplied by vcc12v_dcin
[ 2.387954] vcc5v0_usbdcin: supplied by vcc12v_dcin
[ 2.388086] vcc5v0_usb: supplied by vcc5v0_usbdcin
[ 2.388221] vcc_1v1_nldo_s3: supplied by vcc5v0_sys
[ 2.388542] iommu: Default domain type: Translated
[ 2.388618] rk_iommu fdab9000.iommu: version = 2
[ 2.388971] rk_iommu fdb50800.iommu: version = 2
[ 2.389192] rk_iommu fdb60f00.iommu: version = 2
[ 2.389380] rk_iommu fdb70f00.iommu: version = 2
[ 2.389534] rk_iommu fdb90480.iommu: version = 2
[ 2.389708] rk_iommu fdba0800.iommu: version = 2
[ 2.389880] rk_iommu fdba4800.iommu: version = 2
[ 2.390057] rk_iommu fdba8800.iommu: version = 2
[ 2.390232] rk_iommu fdbac800.iommu: version = 2
[ 2.390403] rk_iommu fdbb0800.iommu: version = 2
[ 2.390574] rk_iommu fdbdf000.iommu: version = 2
[ 2.390833] rk_iommu fdbef000.iommu: version = 2
[ 2.391029] rk_iommu fdcb7f00.iommu: version = 2
[ 2.391180] rk_iommu fdce0800.iommu: version = 2
[ 2.391298] rk_iommu fdd97e00.iommu: version = 2
[ 2.391581] usbcore: registered new interface driver usbfs
[ 2.391601] usbcore: registered new interface driver hub
[ 2.391618] usbcore: registered new device driver usb
[ 2.391657] mc: Linux media interface: v0.10
[ 2.391669] videodev: Linux video capture interface: v2.00
[ 2.391697] pps_core: LinuxPPS API ver. 1 registered
[ 2.391701] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 2.391708] PTP clock support registered
[ 2.391962] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled.
[ 2.391997] arm-scmi firmware:scmi: SCMI Protocol v2.0 ‘rockchip:’ Firmware version 0x0
[ 2.393085] Advanced Linux Sound Architecture Driver Initialized.
[ 2.393288] Bluetooth: Core ver 2.22
[ 2.393302] NET: Registered protocol family 31
[ 2.393305] Bluetooth: HCI device and connection manager initialized
[ 2.393311] Bluetooth: HCI socket layer initialized
[ 2.393316] Bluetooth: L2CAP socket layer initialized
[ 2.393324] Bluetooth: SCO socket layer initialized
[ 2.394575] rockchip-cpuinfo cpuinfo: SoC : 35880000
[ 2.394581] rockchip-cpuinfo cpuinfo: Serial : 441dfbb5ff6d296c
[ 2.395006] clocksource: Switched to clocksource arch_sys_counter
[ 2.716642] NET: Registered protocol family 2
[ 2.716784] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 2.718733] tcp_listen_portaddr_hash hash table entries: 4096 (order: 5, 163840 bytes, linear)
[ 2.718833] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 2.719175] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 2.719980] TCP: Hash tables configured (established 65536 bind 65536)
[ 2.720040] UDP hash table entries: 4096 (order: 6, 393216 bytes, linear)
[ 2.720196] UDP-Lite hash table entries: 4096 (order: 6, 393216 bytes, linear)
[ 2.720418] NET: Registered protocol family 1
[ 2.720802] RPC: Registered named UNIX socket transport module.
[ 2.720807] RPC: Registered udp transport module.
[ 2.720810] RPC: Registered tcp transport module.
[ 2.720814] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.721297] PCI: CLS 0 bytes, default 64
[ 2.721632] Trying to unpack rootfs image as initramfs…
[ 2.898307] Freeing initrd memory: 6856K
[ 2.899279] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 2.902856] Initialise system trusted keyrings
[ 2.902985] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 2.905500] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.905837] NFS: Registering the id_resolver key type
[ 2.905847] Key type id_resolver registered
[ 2.905852] Key type id_legacy registered
[ 2.905867] ntfs: driver 2.1.32 [Flags: R/O].
[ 2.905931] jffs2: version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
[ 2.906006] fuse: init (API version 7.32)
[ 2.906153] SGI XFS with security attributes, no debug enabled
[ 2.927815] NET: Registered protocol family 38
[ 2.927826] xor: measuring software checksum speed
[ 2.929407] 8regs : 6272 MB/sec
[ 2.930592] 32regs : 8340 MB/sec
[ 2.931548] arm64_neon : 10364 MB/sec
[ 2.931553] xor: using function: arm64_neon (10364 MB/sec)
[ 2.931560] Key type asymmetric registered
[ 2.931564] Asymmetric key parser ‘x509’ registered
[ 2.931582] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 2.931736] io scheduler mq-deadline registered
[ 2.931743] io scheduler kyber registered
[ 2.932265] rockchip-csi2-dphy-hw fedc0000.csi2-dphy0-hw: csi2 dphy hw probe successfully!
[ 2.932490] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully!
[ 2.937107] /phy@fed90000: Failed to get clk index: 3 ret: -517
[ 2.938273] mpp_service mpp-srv: unknown mpp version for missing VCS info
[ 2.938282] mpp_service mpp-srv: probe start
[ 2.940326] mpp_vdpu2 fdb50400.vdpu: Adding to iommu group 1
[ 2.940604] mpp_vdpu2 fdb50400.vdpu: probe device
[ 2.940865] mpp_vdpu2 fdb50400.vdpu: probing finish
[ 2.941041] mpp_vepu2 jpege-ccu: probing start
[ 2.941047] mpp_vepu2 jpege-ccu: probing finish
[ 2.941161] mpp_vepu2 fdba0000.jpege-core: Adding to iommu group 5
[ 2.941305] mpp_vepu2 fdba0000.jpege-core: probing start
[ 2.941430] mpp_vepu2 fdba0000.jpege-core: attach ccu success
[ 2.941561] mpp_vepu2 fdba0000.jpege-core: probing finish
[ 2.941643] mpp_vepu2 fdba4000.jpege-core: Adding to iommu group 6
[ 2.941784] mpp_vepu2 fdba4000.jpege-core: probing start
[ 2.941916] mpp_vepu2 fdba4000.jpege-core: attach ccu success
[ 2.942046] mpp_vepu2 fdba4000.jpege-core: probing finish
[ 2.942127] mpp_vepu2 fdba8000.jpege-core: Adding to iommu group 7
[ 2.942251] mpp_vepu2 fdba8000.jpege-core: probing start
[ 2.942377] mpp_vepu2 fdba8000.jpege-core: attach ccu success
[ 2.942512] mpp_vepu2 fdba8000.jpege-core: probing finish
[ 2.942590] mpp_vepu2 fdbac000.jpege-core: Adding to iommu group 8
[ 2.942713] mpp_vepu2 fdbac000.jpege-core: probing start
[ 2.942835] mpp_vepu2 fdbac000.jpege-core: attach ccu success
[ 2.942962] mpp_vepu2 fdbac000.jpege-core: probing finish
[ 2.943208] mpp-iep2 fdbb0000.iep: Adding to iommu group 9
[ 2.943298] mpp-iep2 fdbb0000.iep: probe device
[ 2.943433] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
[ 2.943563] mpp-iep2 fdbb0000.iep: probing finish
[ 2.943736] mpp_jpgdec fdb90000.jpegd: Adding to iommu group 4
[ 2.943889] mpp_jpgdec fdb90000.jpegd: probe device
[ 2.944120] mpp_jpgdec fdb90000.jpegd: probing finish
[ 2.944448] mpp_rkvenc2 rkvenc-ccu: probing start
[ 2.944454] mpp_rkvenc2 rkvenc-ccu: probing finish
[ 2.944558] mpp_rkvenc2 fdbd0000.rkvenc-core: Adding to iommu group 10
[ 2.944732] mpp_rkvenc2 fdbd0000.rkvenc-core: probing start
[ 2.944750] mpp_rkvenc2 fdbd0000.rkvenc-core: link mode task capacity 8
[ 2.944904] mpp_rkvenc2 fdbd0000.rkvenc-core: attach ccu as core 0
[ 2.945040] mpp_rkvenc2 fdbd0000.rkvenc-core: probing finish
[ 2.945113] mpp_rkvenc2 fdbe0000.rkvenc-core: Adding to iommu group 11
[ 2.945306] mpp_rkvenc2 fdbe0000.rkvenc-core: probing start
[ 2.945324] mpp_rkvenc2 fdbe0000.rkvenc-core: link mode task capacity 8
[ 2.945495] mpp_rkvenc2 fdbe0000.rkvenc-core: attach ccu as core 1
[ 2.945629] mpp_rkvenc2 fdbe0000.rkvenc-core: probing finish
[ 2.945748] mpp_service mpp-srv: probe success
[ 2.953529] dma-pl330 fea10000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 2.953537] dma-pl330 fea10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 2.954313] dma-pl330 fea30000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 2.954320] dma-pl330 fea30000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 2.955067] dma-pl330 fed10000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 2.955074] dma-pl330 fed10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 2.956052] rockchip-pvtm fda40000.pvtm: pvtm@0 probed
[ 2.956106] rockchip-pvtm fda50000.pvtm: pvtm@1 probed
[ 2.956153] rockchip-pvtm fda60000.pvtm: pvtm@2 probed
[ 2.956204] rockchip-pvtm fdaf0000.pvtm: pvtm@3 probed
[ 2.956254] rockchip-pvtm fdb30000.pvtm: pvtm@4 probed
[ 2.956789] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 2.957485] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 2.957835] fd890000.serial: ttyS0 at MMIO 0xfd890000 (irq = 25, base_baud = 1500000) is a 16550A
[ 2.958176] febc0000.serial: ttyS9 at MMIO 0xfebc0000 (irq = 82, base_baud = 1500000) is a 16550A
[ 2.959199] random: fast init done
[ 2.959306] random: crng init done
[ 2.960057] rockchip-vop2 fdd90000.vop: Adding to iommu group 14
[ 2.964936] rockchip-vop2 fdd90000.vop: failed to get hdmi0_phy_pll: -517
[ 2.965013] rockchip-vop2 fdd90000.vop: failed to get hdmi1_phy_pll: -517
[ 2.965043] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x5, primary plane phy id: 2
[ 2.965051] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp1 assign plane mask: 0xa, primary plane phy id: 3
[ 2.965069] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x140, primary plane phy id: 8
[ 2.965076] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp3 assign plane mask: 0x280, primary plane phy id: 9
[ 2.965229] [drm] unsupported AFBC format[3231564e]
[ 2.965259] [drm] failed to init overlay plane Cluster0-win1
[ 2.965290] [drm] failed to init overlay plane Cluster1-win1
[ 2.965320] [drm] failed to init overlay plane Cluster2-win1
[ 2.965349] [drm] failed to init overlay plane Cluster3-win1
[ 2.974162] rockchip-drm display-subsystem: bound fdd90000.vop (ops 0xffffffc0110ca440)
[ 2.974693] rockchip-drm display-subsystem: failed to parse loader memory
[ 2.974706] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[ 2.975152] [drm] Initialized rockchip 3.0.0 20140818 for display-subsystem on minor 0
[ 2.979923] brd: module loaded
[ 2.982947] loop: module loaded
[ 2.983147] zram: Added device: zram0
[ 2.983272] lkdtm: No crash points registered, enable through debugfs
[ 2.983417] system_heap: orders[0] = 6
[ 2.983421] system_heap: orders[1] = 4
[ 2.983425] system_heap: orders[2] = 0
[ 2.985014] rockchip-spi feb20000.spi: no high_speed pinctrl state
[ 2.986023] rk806 spi2.0: chip id: RK806,ver:0x2, 0x1
[ 2.986311] rk806 spi2.0: ON: 0x40 OFF:0x0
[ 2.987996] vdd_gpu_s0: supplied by vcc5v0_sys
[ 2.988489] vdd_cpu_lit_s0: supplied by vcc5v0_sys
[ 2.988840] vdd_log_s0: supplied by vcc5v0_sys
[ 2.989229] vdd_vdenc_s0: supplied by vcc5v0_sys
[ 2.989672] vdd_ddr_s0: supplied by vcc5v0_sys
[ 2.989917] vdd2_ddr_s3: supplied by vcc5v0_sys
[ 2.990349] vdd_2v0_pldo_s3: supplied by vcc5v0_sys
[ 2.990613] vcc_3v3_s3: supplied by vcc5v0_sys
[ 2.990915] vddq_ddr_s0: supplied by vcc5v0_sys
[ 2.991425] vcc_1v8_s3: supplied by vcc5v0_sys
[ 2.991824] vdd_0v75_s3: supplied by vcc_1v1_nldo_s3
[ 2.992273] vdd_ddr_pll_s0: supplied by vcc_1v1_nldo_s3
[ 2.992590] avdd_0v75_s0: supplied by vcc_1v1_nldo_s3
[ 2.992914] vdd_0v85_s0: supplied by vcc_1v1_nldo_s3
[ 2.993340] nldo5_s0: supplied by vcc_1v1_nldo_s3
[ 2.993618] avcc_1v8_s0: supplied by vdd_2v0_pldo_s3
[ 2.994071] vcc_1v8_s0: supplied by vdd_2v0_pldo_s3
[ 2.994390] avdd_1v2_s0: supplied by vdd_2v0_pldo_s3
[ 2.994706] vcc_3v3_s0: supplied by vcc5v0_sys
[ 2.995029] vccio_sd_s0: supplied by vcc5v0_sys
[ 2.995361] pldo6_s3: supplied by vcc5v0_sys
[ 2.995619] rk806 spi2.0: no sleep-setting state
[ 2.995624] rk806 spi2.0: no reset-setting pinctrl state
[ 2.995629] rk806 spi2.0: no dvs-setting pinctrl state
[ 2.997188] rockchip-spi feb30000.spi: no high_speed pinctrl state
[ 2.997533] spi-nor spi3.0: w25q128 (16384 Kbytes)
[ 2.998996] libphy: Fixed MDIO Bus: probed
[ 2.999826] rk_gmac-dwmac fe1b0000.ethernet: IRQ eth_lpi not found
[ 2.999960] rk_gmac-dwmac fe1b0000.ethernet: no regulator found
[ 2.999966] rk_gmac-dwmac fe1b0000.ethernet: clock input or output? (output).
[ 2.999971] rk_gmac-dwmac fe1b0000.ethernet: TX delay(0x45).
[ 2.999976] rk_gmac-dwmac fe1b0000.ethernet: Can not read property: rx_delay.
[ 2.999980] rk_gmac-dwmac fe1b0000.ethernet: set rx_delay to 0xffffffff
[ 3.000000] rk_gmac-dwmac fe1b0000.ethernet: integrated PHY? (no).
[ 3.000006] rk_gmac-dwmac fe1b0000.ethernet: cannot get clock mac_clk_rx
[ 3.000012] rk_gmac-dwmac fe1b0000.ethernet: cannot get clock mac_clk_tx
[ 3.000024] rk_gmac-dwmac fe1b0000.ethernet: cannot get clock clk_mac_speed
[ 3.000242] rk_gmac-dwmac fe1b0000.ethernet: init for RGMII_RXID
[ 3.000381] rk_gmac-dwmac fe1b0000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 3.000387] rk_gmac-dwmac fe1b0000.ethernet: DWMAC4/5
[ 3.000393] rk_gmac-dwmac fe1b0000.ethernet: DMA HW capability register supported
[ 3.000397] rk_gmac-dwmac fe1b0000.ethernet: RX Checksum Offload Engine supported
[ 3.000401] rk_gmac-dwmac fe1b0000.ethernet: TX Checksum insertion supported
[ 3.000405] rk_gmac-dwmac fe1b0000.ethernet: Wake-Up On Lan supported
[ 3.000435] rk_gmac-dwmac fe1b0000.ethernet: TSO supported
[ 3.000440] rk_gmac-dwmac fe1b0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 3.000445] rk_gmac-dwmac fe1b0000.ethernet: Enabled Flow TC (entries=2)
[ 3.000449] rk_gmac-dwmac fe1b0000.ethernet: TSO feature enabled
[ 3.000453] rk_gmac-dwmac fe1b0000.ethernet: SPH feature enabled
[ 3.000457] rk_gmac-dwmac fe1b0000.ethernet: Using 32 bits DMA width
[ 3.131672] libphy: stmmac: probed
[ 3.136013] rk_gmac-dwmac fe1c0000.ethernet: IRQ eth_lpi not found
[ 3.136141] rk_gmac-dwmac fe1c0000.ethernet: no regulator found
[ 3.136147] rk_gmac-dwmac fe1c0000.ethernet: clock input or output? (output).
[ 3.136152] rk_gmac-dwmac fe1c0000.ethernet: TX delay(0x42).
[ 3.136156] rk_gmac-dwmac fe1c0000.ethernet: Can not read property: rx_delay.
[ 3.136161] rk_gmac-dwmac fe1c0000.ethernet: set rx_delay to 0xffffffff
[ 3.136172] rk_gmac-dwmac fe1c0000.ethernet: integrated PHY? (no).
[ 3.136178] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_rx
[ 3.136183] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_tx
[ 3.136195] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock clk_mac_speed
[ 3.136410] rk_gmac-dwmac fe1c0000.ethernet: init for RGMII_RXID
[ 3.136545] rk_gmac-dwmac fe1c0000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 3.136550] rk_gmac-dwmac fe1c0000.ethernet: DWMAC4/5
[ 3.136555] rk_gmac-dwmac fe1c0000.ethernet: DMA HW capability register supported
[ 3.136559] rk_gmac-dwmac fe1c0000.ethernet: RX Checksum Offload Engine supported
[ 3.136563] rk_gmac-dwmac fe1c0000.ethernet: TX Checksum insertion supported
[ 3.136567] rk_gmac-dwmac fe1c0000.ethernet: Wake-Up On Lan supported
[ 3.136595] rk_gmac-dwmac fe1c0000.ethernet: TSO supported
[ 3.136599] rk_gmac-dwmac fe1c0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 3.136604] rk_gmac-dwmac fe1c0000.ethernet: Enabled Flow TC (entries=2)
[ 3.136609] rk_gmac-dwmac fe1c0000.ethernet: TSO feature enabled
[ 3.136613] rk_gmac-dwmac fe1c0000.ethernet: SPH feature enabled
[ 3.136617] rk_gmac-dwmac fe1c0000.ethernet: Using 32 bits DMA width
[ 3.268339] libphy: stmmac: probed
[ 3.270984] phy_rtl8211f_led_fixup in
[ 3.292763] usbcore: registered new interface driver rtl8150
[ 3.292788] usbcore: registered new interface driver r8152
[ 3.292805] usbcore: registered new interface driver asix
[ 3.292818] usbcore: registered new interface driver ax88179_178a
[ 3.292830] usbcore: registered new interface driver cdc_ether
[ 3.292844] usbcore: registered new interface driver net1080
[ 3.292857] usbcore: registered new interface driver cdc_subset
[ 3.292869] usbcore: registered new interface driver zaurus
[ 3.292886] usbcore: registered new interface driver cdc_ncm
[ 3.299002] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 3.299061] ehci-pci: EHCI PCI platform driver
[ 3.299136] ehci-platform: EHCI generic platform driver
[ 3.300139] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 3.300169] ohci-platform: OHCI generic platform driver
[ 3.302390] usbcore: registered new interface driver cdc_acm
[ 3.302413] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 3.302521] usbcore: registered new interface driver usbserial_generic
[ 3.302558] usbserial: USB Serial support registered for generic
[ 3.302611] usbcore: registered new interface driver ch341
[ 3.302646] usbserial: USB Serial support registered for ch341-uart
[ 3.302691] usbcore: registered new interface driver cp210x
[ 3.302724] usbserial: USB Serial support registered for cp210x
[ 3.302769] usbcore: registered new interface driver ftdi_sio
[ 3.302802] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 3.302847] usbcore: registered new interface driver keyspan
[ 3.302881] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 3.302914] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 3.302954] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 3.302987] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 3.303034] usbcore: registered new interface driver option
[ 3.303067] usbserial: USB Serial support registered for GSM modem (1-port)
[ 3.303113] usbcore: registered new interface driver oti6858
[ 3.303146] usbserial: USB Serial support registered for oti6858
[ 3.303191] usbcore: registered new interface driver pl2303
[ 3.303224] usbserial: USB Serial support registered for pl2303
[ 3.303275] usbcore: registered new interface driver qcserial
[ 3.303316] usbserial: USB Serial support registered for Qualcomm USB modem
[ 3.303362] usbcore: registered new interface driver sierra
[ 3.303396] usbserial: USB Serial support registered for Sierra USB modem
[ 3.304677] usbcore: registered new interface driver usbtouchscreen
[ 3.306644] input: rk805 pwrkey as /devices/platform/feb20000.spi/spi_master/spi2/spi2.0/rk805-pwrkey.1.auto/input/input0
[ 3.307390] i2c /dev entries driver
[ 3.311348] vdd_cpu_big1_s0: supplied by vcc5v0_sys
[ 3.321541] vdd_npu_s0: supplied by vcc5v0_sys
[ 3.332420] pca953x 6-0021: supply vcc not found, using dummy regulator
[ 3.332601] pca953x 6-0021: using no AI
[ 3.338137] rtc-hym8563 6-0051: rtc information is valid
[ 3.343907] rtc-hym8563 6-0051: registered as rtc0
[ 3.344985] rtc-hym8563 6-0051: setting system clock to 2000-01-01T07:14:40 UTC (946710880)
[ 3.351665] rkcifhw fdce0000.rkcif: Adding to iommu group 13
[ 3.352532] rkcif rkcif-mipi-lvds2: Adding to iommu group 13
[ 3.352587] rkcif rkcif-mipi-lvds2: rkcif driver version: v00.01.0a
[ 3.352727] rkcif rkcif-mipi-lvds2: attach to cif hw node
[ 3.352744] rkcif rkcif-mipi-lvds2: rkcif wait line 0
[ 3.352759] : terminal subdev does not exist
[ 3.352772] : terminal subdev does not exist
[ 3.352784] : terminal subdev does not exist
[ 3.352795] : terminal subdev does not exist
[ 3.352807] : get_remote_sensor: video pad[0] is null
[ 3.352819] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 3.352832] : get_remote_sensor: video pad[0] is null
[ 3.352844] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 3.352856] : get_remote_sensor: video pad[0] is null
[ 3.352867] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 3.352879] : get_remote_sensor: video pad[0] is null
[ 3.352890] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 3.357025] rkcif rkcif-mipi-lvds2: Entity type for entity rockchip-mipi-csi2 was not initialized!
[ 3.357045] rockchip-mipi-csi2: Async registered subdev
[ 3.357073] rockchip-mipi-csi2: probe success, v4l2_dev:rkcif-mipi-lvds2!
[ 3.358424] rkisp_hw fdcb0000.rkisp: Adding to iommu group 12
[ 3.358753] rkisp_hw fdcb0000.rkisp: is_thunderboot: 0
[ 3.358773] rkisp_hw fdcb0000.rkisp: max input:0x0@0fps
[ 3.358788] rkisp_hw fdcb0000.rkisp: Missing rockchip,grf property
[ 3.359916] rkisp rkisp0-vir0: rkisp driver version: v01.08.00
[ 3.360074] rkisp rkisp0-vir0: No memory-region-thunderboot specified
[ 3.360254] rkisp rkisp0-vir0: Entity type for entity rkisp-isp-subdev was not initialized!
[ 3.363521] usbcore: registered new interface driver uvcvideo
[ 3.363536] USB Video Class driver (1.1.1)
[ 3.367164] rockchip-thermal fec00000.tsadc: Missing rockchip,grf property
[ 3.367896] rockchip-thermal fec00000.tsadc: tsadc is probed successfully!
[ 3.368293] device-mapper: ioctl: 4.44.0-ioctl (2021-02-01) initialised: dm-devel@redhat.com
[ 3.368487] Bluetooth: HCI UART driver ver 2.3
[ 3.368493] Bluetooth: HCI UART protocol H4 registered
[ 3.368496] Bluetooth: HCI UART protocol ATH3K registered
[ 3.368517] usbcore: registered new interface driver bfusb
[ 3.368534] usbcore: registered new interface driver btusb
[ 3.368625] cpu cpu0: Failed to get cpu_leakage
[ 3.368804] cpu cpu4: Failed to get cpu_leakage
[ 3.369846] cpu cpu6: Failed to get cpu_leakage
[ 3.371385] cpu cpu0: avs=0
[ 3.371965] cpu cpu4: avs=0
[ 3.372517] cpu cpu6: avs=0
[ 3.372724] cpu cpu0: EM: created perf domain
[ 3.372753] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 3.373098] cpu cpu4: EM: created perf domain
[ 3.373120] cpu cpu4: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 3.379835] cpu cpu6: EM: created perf domain
[ 3.379913] cpu cpu6: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 3.399609] $$$$ mmc_blk_init 3086
[ 3.399609]
[ 3.505032] $$$$ mmc_blk_init 3095
[ 3.505032]
[ 3.505046] $$$$ mmc_blk_init 3102
[ 3.505046]
[ 3.505050] $$$$ mmc_blk_init 3108
[ 3.505050]
[ 3.505055] $$$$ mmc_blk_init 3113
[ 3.505055]
[ 3.505072] $$$$ mmc_blk_init 3115 0
[ 3.505072]
[ 3.505077] $$$ mmc_blk_init init OK
[ 3.505077]
[ 3.505089] sdhci: Secure Digital Host Controller Interface driver
[ 3.505093] sdhci: Copyright(c) Pierre Ossman
[ 3.505097] Synopsys Designware Multimedia Card Interface Driver
[ 3.505521] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.507339] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[ 3.507449] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[ 3.507530] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[ 3.507671] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 67,32 bit host data width,256 deep fifo
[ 3.514704] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
[ 3.514804] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping …
[ 3.515963] hid: raw HID events driver (C) Jiri Kosina
[ 3.516690] usbcore: registered new interface driver usbhid
[ 3.516727] usbhid: USB HID core driver
[ 3.523096] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 3.530903] usbcore: registered new interface driver snd-usb-audio
[ 3.535459] ES8323 3-0011: i2c recv Failed
[ 3.539935] mmc0: SDHCI controller on fe2e0000.mmc [fe2e0000.mmc] using ADMA
[ 3.541717] [AC100] ac101_probe,line:715
[ 3.553347] IPVS: Registered protocols (TCP, UDP)
[ 3.553375] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[ 3.553454] IPVS: ipvs loaded.
[ 3.553460] IPVS: [rr] scheduler registered.
[ 3.553638] Initializing XFRM netlink socket
[ 3.553833] NET: Registered protocol family 10
[ 3.554404] Segment Routing with IPv6
[ 3.554459] NET: Registered protocol family 17
[ 3.554471] NET: Registered protocol family 15
[ 3.554500] Bridge firewalling registered
[ 3.554579] Bluetooth: RFCOMM socket layer initialized
[ 3.554592] Bluetooth: RFCOMM ver 1.11
[ 3.554599] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.554605] Bluetooth: HIDP socket layer initialized
[ 3.554631] [BT_RFKILL]: Enter rfkill_rk_init
[ 3.554636] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 3.554892] Key type dns_resolver registered
[ 3.555361] imx334 5-0037: driver version: 00.01.05
[ 3.555369] imx334 5-0037: @-@ Mnano imx334_probe enter.
[ 3.555450] imx334 5-0037: Failed to get pwdn-gpios
[ 3.555457] imx334 5-0037: could not get default pinstate
[ 3.555462] imx334 5-0037: could not get sleep pinstate
[ 3.555522] imx334 5-0037: Failed to get power regulators
[ 3.555552] imx334 5-0037: Mnano __imx334_power_on enter.n
[ 3.555558] imx334 5-0037: Mnano step1: spi4 clk gpio as input, then delay 1000us??
[ 3.576775] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 3.577951] mmcblk0: mmc0:0001 AKJ41X 233 GiB
[ 3.578540] mmcblk0boot0: mmc0:0001 AKJ41X partition 1 4.00 MiB
[ 3.579060] mmcblk0boot1: mmc0:0001 AKJ41X partition 2 4.00 MiB
[ 3.579415] mmcblk0rpmb: mmc0:0001 AKJ41X partition 3 4.00 MiB, chardev (237:0)
[ 3.583845] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
[ 3.683223] vendor storage:20190527 ret = 0
[ 4.575245] imx334 5-0037: Mnano step2: reset to high, then delay 50us.
[ 4.675411] imx334 5-0037: Mnano step3: make camera clk output.
[ 4.875802] imx334 5-0037: Mnano step4: try regulator???
[ 4.876918] imx334 5-0037: Mnano step5: now i2c can work???
[ 4.876962] imx334 5-0037: Mnano __imx334_power_on exit OK.n
[ 4.877661] imx334 5-0037: Detected imx334 id:000030
[ 4.878012] rockchip-csi2-dphy csi2-dphy0: dphy0 matches m00_b_imx334 5-0037:bus type 5
[ 4.878045] imx334 5-0037: Read 10 regs form 0x3000.
[ 4.882709] imx334 5-0037: reg: 0x3000, value:0x 1.
[ 4.887454] imx334 5-0037: reg: 0x3001, value:0x 0.
[ 4.892194] imx334 5-0037: reg: 0x3002, value:0x 1.
[ 4.896934] imx334 5-0037: reg: 0x3003, value:0x 0.
[ 4.901762] imx334 5-0037: reg: 0x3004, value:0x 0.
[ 4.906507] imx334 5-0037: reg: 0x3005, value:0x 0.
[ 4.911250] imx334 5-0037: reg: 0x3006, value:0x 0.
[ 4.915987] imx334 5-0037: reg: 0x3007, value:0x 0.
[ 4.920726] imx334 5-0037: reg: 0x3008, value:0x 0.
[ 4.925466] imx334 5-0037: reg: 0x3009, value:0x 0.
[ 4.925584] imx334_runtime_suspend enter, for debug, don’t power off.
[ 4.925680] imx334 5-0037: @-@ Mnano imx334_probe exit OK.
[ 4.928004] Loading compiled-in X.509 certificates
[ 4.932351] Btrfs loaded, crc32c=crc32c-generic
[ 4.932841] pstore: Using crash dump compression: deflate
[ 4.933765] rga3_core0 fdb60000.rga: Adding to iommu group 2
[ 4.934460] rga: rga3_core0_irq, irq = 33, match scheduler
[ 4.935399] rga: Driver loaded successfully rga[3] ver:3.0.76831
[ 4.935546] rga: probe successfully
[ 4.936814] rga3_core1 fdb70000.rga: Adding to iommu group 3
[ 4.937462] rga: rga3_core1_irq, irq = 34, match scheduler
[ 4.938259] rga: Driver loaded successfully rga[3] ver:3.0.76831
[ 4.938458] rga: probe successfully
[ 4.939723] rga: rga2_irq, irq = 35, match scheduler
[ 4.940524] rga: Driver loaded successfully rga[3] ver:3.2.63318
[ 4.940658] rga: probe successfully
[ 4.941743] rga: Module initialized. v1.2.0
[ 5.003254] pcie30_avdd1v8: supplied by avcc_1v8_s0
[ 5.004219] mali fb000000.gpu: Kernel DDK version g10p0-01eac0
[ 5.004322] pcie30_avdd0v75: supplied by avdd_0v75_s0
[ 5.005386] mali fb000000.gpu: Failed to get gpu_leakage
[ 5.006525] input: adc-keys as /devices/platform/adc-keys/input/input1
[ 5.006619] mali fb000000.gpu: avs=0
[ 5.009586] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 132; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
[ 5.009875] mali fb000000.gpu: r0p0 status 5 is unknown; treating as r0p0 status 0
[ 5.009908] mali fb000000.gpu: GPU identified as 0x7 arch 10.8.6 r0p0 status 0
[ 5.010014] mali fb000000.gpu: No priority control manager is configured
[ 5.010028] mali fb000000.gpu: No memory group manager is configured
[ 5.010061] mali fb000000.gpu: Protected memory allocator not available
[ 5.010876] mali fb000000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 5.011904] mali fb000000.gpu: Couldn’t find power_model DT node matching ‘arm,mali-simple-power-model’
[ 5.011932] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.static-coefficient = 1*[0]
[ 5.012314] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.dynamic-coefficient = 1*[0]
[ 5.012653] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.ts = 4*[0]
[ 5.012996] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.thermal-zone = ‘’
[ 5.016160] mali fb000000.gpu: Using configured power model mali-lodx-power-model, and fallback mali-simple-power-model
[ 5.016549] mali fb000000.gpu: Probed as mali0
[ 5.019776] [AC100] ac101_codec_probe,line:655
[ 5.020352] [AC100] set_configuration,line:336,write reg:0 val:123[101]
[ 5.021352] [AC100] set_configuration,line:336,write reg:0 val:123[101]
[ 5.125711] [AC100] set_configuration,line:340,write reg:1 val:14f[141]
[ 5.126856] [AC100] set_configuration,line:340,write reg:1 val:14f[14f]
[ 5.127498] [AC100] set_configuration,line:342,write reg:58 val:e880[880]
[ 5.128591] [AC100] set_configuration,line:342,write reg:58 val:e880[e880]
[ 5.128636] [AC100] ac101_set_fll, line:246, pll_id:1, freq_in:12288000, freq_out:24576000
[ 5.129252] [AC100] ac101_set_fll,line:267,update_bits reg:3 val:0[0]
[ 5.130463] [AC100] ac101_set_fll,line:267,update_bits reg:3 val:0[0]
[ 5.130488] [AC100] ac101_set_fll, line:289, m:1, n_i:6, n_f:0
[ 5.131104] [AC100] ac101_set_fll,line:291,update_bits reg:1 val:100[14f]
[ 5.132312] [AC100] ac101_set_fll,line:291,update_bits reg:1 val:100[14f]
[ 5.132965] [AC100] ac101_set_fll,line:293,update_bits reg:2 val:60[0]
[ 5.134642] [AC100] ac101_set_fll,line:293,update_bits reg:2 val:60[60]
[ 5.135281] [AC100] ac101_set_fll,line:294,update_bits reg:2 val:0[60]
[ 5.136495] [AC100] ac101_set_fll,line:294,update_bits reg:2 val:0[60]
[ 5.137132] [AC100] ac101_set_fll,line:295,update_bits reg:2 val:8000[60]
[ 5.138809] [AC100] ac101_set_fll,line:295,update_bits reg:2 val:8000[8060]
[ 5.139446] [AC100] ac101_set_fll,line:297,update_bits reg:3 val:8000[0]
[ 5.141118] [AC100] ac101_set_fll,line:297,update_bits reg:3 val:8000[8000]
[ 5.141759] [AC100] ac101_set_fll,line:298,update_bits reg:3 val:300[8000]
[ 5.143438] [AC100] ac101_set_fll,line:298,update_bits reg:3 val:300[8300]
[ 5.144070] [AC100] ac101_set_fll,line:301,snd_soc_component_read(component, PLL_CTRL2):8060
[ 5.144688] [AC100] set_configuration,line:352,write reg:4 val:800c[0]
[ 5.145797] [AC100] set_configuration,line:352,write reg:4 val:800c[800c]
[ 5.146416] [AC100] set_configuration,line:354,write reg:5 val:800c[0]
[ 5.147504] [AC100] set_configuration,line:354,write reg:5 val:800c[800c]
[ 5.148118] [AC100] set_configuration,line:356,write reg:6 val:8000[0]
[ 5.149207] [AC100] set_configuration,line:356,write reg:6 val:8000[8000]
[ 5.149844] [AC100] set_configuration,line:360,write reg:10 val:8890[0]
[ 5.150929] [AC100] set_configuration,line:360,write reg:10 val:8890[8890]
[ 5.151564] [AC100] set_configuration,line:362,write reg:11 val:c000[0]
[ 5.152651] [AC100] set_configuration,line:362,write reg:11 val:c000[c000]
[ 5.153283] [AC100] set_configuration,line:364,write reg:12 val:c000[0]
[ 5.154366] [AC100] set_configuration,line:364,write reg:12 val:c000[c000]
[ 5.155084] [AC100] set_configuration,line:367,write reg:13 val:2200[0]
[ 5.156187] [AC100] set_configuration,line:367,write reg:13 val:2200[2200]
[ 5.156798] [AC100] set_configuration,line:372,write reg:51 val:408[0]
[ 5.157852] [AC100] set_configuration,line:372,write reg:51 val:408[408]
[ 5.158462] [AC100] set_configuration,line:374,write reg:40 val:8000[0]
[ 5.159511] [AC100] set_configuration,line:374,write reg:40 val:8000[8000]
[ 5.160120] [AC100] set_configuration,line:376,write reg:50 val:bbc0[3340]
[ 5.161176] [AC100] set_configuration,line:376,write reg:50 val:bbc0[bbc0]
[ 5.161790] [AC100] set_configuration,line:381,write reg:4c val:8800[0]
[ 5.162844] [AC100] set_configuration,line:381,write reg:4c val:8800[8800]
[ 5.163453] [AC100] set_configuration,line:383,write reg:48 val:8000[0]
[ 5.164505] [AC100] set_configuration,line:383,write reg:48 val:8000[8000]
[ 5.165131] [AC100] set_configuration,line:385,write reg:54 val:102[0]
[ 5.166209] [AC100] set_configuration,line:385,write reg:54 val:102[102]
[ 5.166844] [AC100] set_configuration,line:388,write reg:53 val:f080[f80]
[ 5.167929] [AC100] set_configuration,line:388,write reg:53 val:f080[f080]
[ 5.168571] [AC100] set_configuration,line:389,write reg:3 val:8b08[8300]
[ 5.169657] [AC100] set_configuration,line:389,write reg:3 val:8b08[8b08]
[ 5.170290] [AC100] set_configuration,line:390,write reg:56 val:c3c1[1]
[ 5.171375] [AC100] set_configuration,line:390,write reg:56 val:c3c1[c3c1]
[ 5.172010] [AC100] set_configuration,line:396,update_bits reg:3 val:800[8b08]
[ 5.173219] [AC100] set_configuration,line:396,update_bits reg:3 val:800[8b08]
[ 5.173851] [AC100] set_configuration,line:397,update_bits reg:3 val:8[8b08]
[ 5.175067] [AC100] set_configuration,line:397,update_bits reg:3 val:8[8b08]
[ 5.175705] [AC100] set_configuration,line:403,write reg:58 val:eabd[e880]
[ 5.176791] [AC100] set_configuration,line:403,write reg:58 val:eabd[eabd]
[ 5.177039] $$$$$$$$$ac101_set_dai_sysclk 0x0, freq=8134407
[ 5.195886] rkcif rkcif-mipi-lvds2: clear unready subdev num: 1
[ 5.196198] rkcif-mipi-lvds2: Async subdev notifier completed
[ 5.196358] rkisp0-vir0: Async subdev notifier completed
[ 5.197147] RKNPU fdab0000.npu: Adding to iommu group 0
[ 5.197535] RKNPU fdab0000.npu: RKNPU: rknpu iommu is enabled, using iommu mode
[ 5.198774] RKNPU fdab0000.npu: can’t request region for resource [mem 0xfdab0000-0xfdabffff]
[ 5.198795] RKNPU fdab0000.npu: can’t request region for resource [mem 0xfdac0000-0xfdacffff]
[ 5.198808] RKNPU fdab0000.npu: can’t request region for resource [mem 0xfdad0000-0xfdadffff]
[ 5.199079] [drm] Initialized rknpu 0.6.4 20211227 for fdab0000.npu on minor 1
[ 5.201339] RKNPU fdab0000.npu: Failed to get npu_leakage
[ 5.204099] RKNPU fdab0000.npu: avs=0
[ 5.204648] RKNPU fdab0000.npu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 5.213026] RKNPU fdab0000.npu: failed to find power_model node
[ 5.213081] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
[ 5.213104] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
[ 5.214713] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.222004] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 5.223087] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 5.223108] cfg80211: failed to load regulatory.db
[ 5.225420] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[ 5.227447] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 405; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, built at ‘19:53:55’, on ‘Dec 15 2022’.
[ 5.228555] Mali:
[ 5.228562] Mali device driver loaded
[ 5.228592] rkisp rkisp0-vir0: clear unready subdev num: 0
v 5.231872]
我也遇到这个问题了,卡死这了
firefly_zhongw 发表于 2021-12-29 18:13
接调试串口,提供完整的log信息。
请问为什么会卡死呢,琢磨了很久没有搞懂为啥会进不去系统,求大神指点一二,多谢
DDR Version V1.13 20220218
ddrconfig:15
DDR4, 324MHz
BW=32 Col=10 Bk=4 BG=2 CS0 Row=17 CS=1 Die BW=16 Size=4096MB
tdqss: cs0 dqs0: 48ps, dqs1: -24ps, dqs2: -72ps, dqs3: -96ps,
change to: 324MHz
clk skew:0x84
PHY drv:clk:37,ca:37,DQ:37,odt:0
vrefinner:50%, vrefout:50%
dram drv:34,odt:0
change to: 528MHz
clk skew:0x84
PHY drv:clk:37,ca:37,DQ:37,odt:139
vrefinner:50%, vrefout:61%
dram drv:34,odt:120
change to: 780MHz
clk skew:0x84
dram drv:34,odt:120
change to: 1560MHz(final freq)
clk skew:0x84
dram drv:34,odt:120
cs 0:
the read training result:
DQS0:0x33, DQS1:0x31, DQS2:0x2e, DQS3:0x31,
min : 0xc 0xc 0xc 0x8 0x2 0x3 0x3 0x3 , 0xa 0xa 0x2 0x6 0x8 0xb 0xa 0x8 ,
0x4 0x8 0x9 0x6 0x3 0x2 0x2 0x3 , 0xa 0x4 0x6 0x2 0x8 0xa 0x6 0x8 ,
mid :0x26 0x25 0x25 0x22 0x1b 0x1b 0x1b 0x1c ,0x23 0x24 0x1b 0x20 0x22 0x24 0x24 0x21 ,
0x1f 0x22 0x23 0x20 0x1e 0x1d 0x1c 0x1c ,0x23 0x1e 0x21 0x1c 0x22 0x24 0x20 0x21 ,
max :0x40 0x3e 0x3f 0x3c 0x34 0x34 0x34 0x35 ,0x3c 0x3e 0x34 0x3a 0x3c 0x3e 0x3e 0x3b ,
0x3a 0x3d 0x3e 0x3a 0x39 0x38 0x37 0x36 ,0x3d 0x38 0x3c 0x36 0x3d 0x3e 0x3a 0x3a ,
range:0x34 0x32 0x33 0x34 0x32 0x31 0x31 0x32 ,0x32 0x34 0x32 0x34 0x34 0x33 0x34 0x33 ,
0x36 0x35 0x35 0x34 0x36 0x36 0x35 0x33 ,0x33 0x34 0x36 0x34 0x35 0x34 0x34 0x32 ,
the write training result:
DQS0:0x8d, DQS1:0x80, DQS2:0x76, DQS3:0x71,
min :0x79 0x78 0x79 0x79 0x6e 0x6a 0x6f 0x70 0x75 ,0x6d 0x6e 0x6a 0x6e 0x6a 0x6b 0x6d 0x70 0x6a ,
0x68 0x68 0x6b 0x6c 0x68 0x5f 0x62 0x64 0x63 ,0x5e 0x59 0x60 0x59 0x5d 0x59 0x5b 0x61 0x5e ,
mid :0x8d 0x8c 0x8e 0x8b 0x80 0x7f 0x81 0x83 0x89 ,0x81 0x83 0x7c 0x80 0x7f 0x81 0x81 0x85 0x7b ,
0x7b 0x7d 0x7d 0x7d 0x7b 0x74 0x75 0x78 0x78 ,0x72 0x6d 0x72 0x6d 0x70 0x70 0x70 0x73 0x73 ,
max :0xa1 0xa0 0xa3 0x9e 0x93 0x95 0x94 0x96 0x9e ,0x95 0x98 0x8e 0x92 0x94 0x97 0x95 0x9a 0x8d ,
0x8f 0x93 0x8f 0x8f 0x8e 0x89 0x89 0x8c 0x8e ,0x87 0x82 0x84 0x81 0x84 0x87 0x86 0x85 0x89 ,
range:0x28 0x28 0x2a 0x25 0x25 0x2b 0x25 0x26 0x29 ,0x28 0x2a 0x24 0x24 0x2a 0x2c 0x28 0x2a 0x23 ,
0x27 0x2b 0x24 0x23 0x26 0x2a 0x27 0x28 0x2b ,0x29 0x29 0x24 0x28 0x27 0x2e 0x2b 0x24 0x2b ,
out
U-Boot SPL 2017.09 (Feb 22 2023 - 11:15:16)
rk3568_sdmmc_set_clk,rate=400000
unknown raw ID phN
MMC error: The cmd index is 1, ret is -110…
mmc_init: -95, time 13
## Verified-boot: 0
## Checking atf-1 0x00040000 … sha256(fe4f274c06…) + OK
## Checking uboot 0x00a00000 … sha256(a59d9c1c7f…) + OK
## Checking fdt 0x00b313a0 … sha256(9679fe2a45…) + OK
## Checking atf-2 0x00068000 … sha256(8d44036095…) + OK
## Checking atf-3 0xfdcd0000 … sha256(e410275b51…) + OK
## Checking atf-4 0xfdcc9000 … sha256(990c53fc01…) + OK
## Checking atf-5 0x00066000 … sha256(315a4195a9…) + OK
## Checking optee 0x08400000 … sha256(66bbd17352…) + OK
Total: 144.669 ms
NOTICE: BL31: v2.3():v2.3-181-gc9a647cae:cl
NOTICE: BL31: Built : 10:55:41, Oct 18 2021
INFO: pmu v1 is valid
INFO: dfs DDR fsp_param[0].freq_mhz= 1560MHz
I/TC:
I/TC: OP-TEE version: 3.13.0-641-g4167319d3 #hisping.lin (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #8 Wed Mar 16 15:14:56 CST 2022 aarch64
INFO: SPSR = 0x3c9
U-Boot 2017.09 (Feb 22 2023 - 11:15:16 +0800)
Model: Rockchip RK3568 Evaluation Board
PreSerial: 2, raw, 0xfe660000
DRAM: 4 GiB
Sysmem: init
Relocation Offset: ed347000
Relocation fdt: eb9f9088 - eb9fece8
CR: M/C/I
MMC0: HS200, 200Mhz
PartType: EFI
DM: v1
Android 11.0, Build 2021.8, v2
Found DTB in recovery part
DTB: rk-kernel.dtb
HASH(c): OK
ANDROID: fdt overlay OK
vdd_cpu init 900000 uV
PMIC: RK8090 (on=0x40, off=0x00)
vdd_logic init 900000 uV
vdd_gpu init 900000 uV
vdd_npu init 900000 uV
io-domain: OK
Model: ROC-RK3568-PC HDMI (Android)
VOP have 1 active VP
vp0 have layer nr:6[0 2 4 1 3 5 ], primary plane: 4
vp1 have layer nr:0, primary plane: 0
vp2 have layer nr:0, primary plane: 0
disp info 0, type:11, id:0
xfer: num: 2, addr: 0x50
base_parameter.mode:0x0
mode:1920x1080
hdmi@fe0a0000: detailed mode clock 148500 kHz, flags[5]
H: 1920 2008 2052 2200
V: 1080 1084 1089 1125
bus_format: 2025
VOP update mode to: 1920x1080p0, type: HDMI0 for VP0
rockchip_vop2_init:No hdmiphypll clk0 found, use system clk
rockchip_vop2_init:No hdmiphypll clk1 found, use system clk
VOP VP0 enable Smart0[500x501->500x501@710x289] fmt[2] addr[0xedf20000]
CEA mode used vic=16
final pixclk = 148500000 tmdsclk = 148500000
PHY powered down in 0 iterations
PHY PLL locked 1 iterations
apll 1416000 KHz
dpll 780000 KHz
gpll 1188000 KHz
cpll 1000000 KHz
npll 1200000 KHz
vpll 24000 KHz
hpll 148000 KHz
ppll 200000 KHz
armclk 1416000 KHz
aclk_bus 150000 KHz
pclk_bus 100000 KHz
aclk_top_high 500000 KHz
aclk_top_low 400000 KHz
hclk_top 150000 KHz
pclk_top 100000 KHz
aclk_perimid 300000 KHz
hclk_perimid 150000 KHz
pclk_pmu 100000 KHz
Net: eth1: ethernet@fe010000, eth0: ethernet@fe2a0000
Vboot=0, AVB images, AVB verify
read_is_device_unlocked() ops returned that device is UNLOCKED
avb_footer.c:41: ERROR: Footer magic is incorrect.
avb_vbmeta_image.c:65: ERROR: Magic is incorrect.
avb_slot_verify.c:773: ERROR: recovery: Error verifying vbmeta image: invalid vbmeta header
Verify recovery with vbmeta.
avb_slot_verify.c:762: ERROR: vbmeta: Error verifying vbmeta image: OK_NOT_SIGNED
get image from preloaded partition…
ANDROID: Hash OK
Could not find “system” partition
Booting IMAGE kernel at 0x00280000 with fdt at 0x0a100000…
## Booting Android Image at 0x0027f800 …
Kernel: 0x00280000 - 0x02053008 (30541 KiB)
ramdisk: 0x0a200000 - 0x0c7c6195 (38681 KiB)
## Flattened Device Tree blob at 0x0a100000
XIP Kernel Image from 0x00280000 to 0x00280000 … OK
kernel loaded at 0x00280000, end = 0x02053008
‘reserved-memory’ linux,cma: addr=10000000 size=800000
Using Device Tree in place at 000000000a100000, end 000000000a124a0f
vp0, plane_mask:0x3f, primary-id:4, curser-id:-1
vp1, plane_mask:0x0, primary-id:0, curser-id:-1
vp2, plane_mask:0x0, primary-id:0, curser-id:-1
Adding bank: 0x1f0000000 - 0x200000000 (size: 0x10000000)
Total: 1718.704 ms
[ 0.000000] Linux version 4.19.219 (haylrn@haylrn-virtual-machine) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05), GNU ld (Linaro_Binutils-2017.05) 2.27.0.20161019) #12 SMP PREEMPT Wed Feb 22 11:41:03 CST 2023
[ 0.000000] Machine model: ROC-RK3568-PC HDMI (Android)
[ 0.000000] earlycon: uart8250 at MMIO32 0x00000000fe660000 (options ‘’)
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000010000000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] percpu: Embedded 24 pages/cpu s58968 r8192 d31144 u98304
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1027656
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.dtb_idx=0 androidboot.dtbo_idx=0 androidboot.verifiedbootstate=orange androidboot.serialno=74fcd61a77064c11 console=ttyFIQ0 androidboot.baseband=N/A androidboot.wificountrycode=CN androidboot.veritymode=enforcing androidboot.hardware=rk30board androidboot.console=ttyFIQ0 androidboot.verifiedbootstate=orange firmware_class.path=/vendor/etc/firmware init=/init rootwait ro loop.max_part=7 androidboot.selinux=permissive buildvariant=userdebug earlycon=uart8250,mmio32,0xfe660000 androidboot.boot_devices=fe310000.sdhci,usbhost/fd000000.dwc3/xhci-hcd.5.auto,fd880000.usb,fd800000.usb,fe2b0000.dwmmc,fc800000.sata,3c0800000.pcie,3c0000000.pcie
[ 0.000000] software IO TLB: mapped [mem 0xe9f00000-0xedf00000] (64MB)
[ 0.000000] Memory: 3940224K/4175872K available (15166K kernel code, 2060K rwdata, 9148K rodata, 4096K init, 932K bss, 227456K reserved, 8192K cma-reserved)
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] ITS@0x00000000fd440000: allocated 8192 Devices @210000 (indirect, esz 8, psz 64K, shr 0)
[ 0.000000] ITS@0x00000000fd440000: allocated 32768 Interrupt Collections @220000 (flat, esz 2, psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x0000000000230000
[ 0.000000] CPU0: using LPI pending table @0x0000000000240000
[ 0.000000] random: random: get_random_bytes called from start_kernel+0x36c/0x4f0 with crng_init=0
[ 0.000003] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.001619] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.002587] pid_max: default: 32768 minimum: 301
[ 0.003094] Security Framework initialized
[ 0.003485] SELinux: Initializing.
[ 0.003891] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.004529] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.006395] ASID allocator initialised with 32768 entries
[ 0.006999] rcu: Hierarchical SRCU implementation.
[ 0.007826] Platform MSI: interrupt-controller@fd440000 domain created
[ 0.008868] PCI/MSI: /interrupt-controller@fd400000/interrupt-controller@fd440000 domain created
[ 0.010362] smp: Bringing up secondary CPUs …
[ 0.011940] Detected VIPT I-cache on CPU1
[ 0.011967] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[ 0.012005] CPU1: using LPI pending table @0x0000000000250000
[ 0.012042] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[ 0.013269] Detected VIPT I-cache on CPU2
[ 0.013292] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[ 0.013326] CPU2: using LPI pending table @0x0000000000260000
[ 0.013355] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[ 0.014543] Detected VIPT I-cache on CPU3
[ 0.014563] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[ 0.014601] CPU3: using LPI pending table @0x0000000000270000
[ 0.014628] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[ 0.014707] smp: Brought up 1 node, 4 CPUs
[ 0.021676] SMP: Total of 4 processors activated.
[ 0.022120] CPU features: detected: GIC system register CPU interface
[ 0.022724] CPU features: detected: Privileged Access Never
[ 0.023257] CPU features: detected: LSE atomic instructions
[ 0.023780] CPU features: detected: User Access Override
[ 0.024278] CPU features: detected: 32-bit EL0 Support
[ 0.024759] CPU features: detected: RAS Extension Support
[ 0.032118] CPU: All CPU(s) started at EL2
[ 0.032530] alternatives: patching kernel code
[ 0.036951] devtmpfs: initialized
[ 0.053000] Trying to unpack rootfs image as initramfs…
[ 0.053556] Registered cp15_barrier emulation handler
[ 0.054037] Registered setend emulation handler
[ 0.054801] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.055727] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.056499] pinctrl core: initialized pinctrl subsystem
[ 0.057834] NET: Registered protocol family 16
[ 0.058914] schedtune: configured to support 6 boost groups
[ 0.059552] audit: initializing netlink subsys (disabled)
[ 0.060279] audit: type=2000 audit(0.056:1): state=initialized audit_enabled=0 res=1
[ 0.062425] cpuidle: using governor menu
[ 0.062819] Registered FIQ tty driver
[ 0.063777] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.064668] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.067744] console [pstore-1] enabled
[ 0.068284] pstore: Registered ramoops as persistent store backend
[ 0.068870] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.089074] rockchip-gpio fdd60000.gpio: probed gpio0 (fdd60000.gpio)
[ 0.090130] rockchip-gpio fe740000.gpio: probed gpio1 (fe740000.gpio)
[ 0.091132] rockchip-gpio fe750000.gpio: probed gpio2 (fe750000.gpio)
[ 0.092117] rockchip-gpio fe760000.gpio: probed gpio3 (fe760000.gpio)
[ 0.093109] rockchip-gpio fe770000.gpio: probed gpio4 (fe770000.gpio)
[ 0.093815] rockchip-pinctrl pinctrl: probed pinctrl
[ 0.102988] cryptd: max_cpu_qlen set to 1000
[[ 0.105063] console [ttyFIQ0] enabled
[ 0.105743] bootconsole [uart8250] disabled
[ 0.106304] Registered fiq debugger ttyFIQ0
[ 0.107020] vcc3v3_sys: supplied by dc_12v
[ 0.107263] vcc5v0_sys: supplied by dc_12v
[ 0.107496] vcc5v0_usb: supplied by dc_12v
[ 0.107816] vcc5v0_host: supplied by vcc5v0_usb
[ 0.108073] vcc3v3_lcd0_n: supplied by vcc3v3_sys
[ 0.108323] vcc3v3_lcd1_n: supplied by vcc3v3_sys
[ 0.108559] vcc2v5-sys: supplied by vcc3v3_sys
[ 0.108799] pcie30_avdd0v9: supplied by vcc3v3_sys
[ 0.109032] pcie30_avdd1v8: supplied by vcc3v3_sys
[ 0.109363] vcc3v3_pcie: supplied by dc_12v
[ 0.109503] vcc3v3_bu: supplied by vcc5v0_sys
[ 0.110879] rk_iommu fde4b000.iommu: version = 2
[ 0.111321] rk_iommu fdea0800.iommu: version = 2
[ 0.111582] rk_iommu fded0480.iommu: version = 2
[ 0.111880] rk_iommu fdee0800.iommu: version = 2
[ 0.112141] rk_iommu fdef0800.iommu: version = 2
[ 0.112372] rk_iommu fdf40f00.iommu: version = 2
[ 0.112653] rk_iommu fdf80800.iommu: version = 2
[ 0.112897] rk_iommu fdff1a00.iommu: version = 2
[ 0.113130] rk_iommu fe043e00.iommu: version = 2
[ 0.113782] SCSI subsystem initialized
[ 0.113990] usbcore: registered new interface driver usbfs
[ 0.114043] usbcore: registered new interface driver hub
[ 0.114084] usbcore: registered new device driver usb
[ 0.114459] media: Linux media interface: v0.10
[ 0.114501] videodev: Linux video capture interface: v2.00
[ 0.114567] pps_core: LinuxPPS API ver. 1 registered
[ 0.114581] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.114604] PTP clock support registered
[ 0.114847] arm-scmi firmware:scmi: SCMI Protocol v2.0 ‘rockchip:’ Firmware version 0x0
[ 0.117387] Advanced Linux Sound Architecture Driver Initialized.
[ 0.117784] Bluetooth: Core ver 2.22
[ 0.117841] NET: Registered protocol family 31
[ 0.117856] Bluetooth: HCI device and connection manager initialized
[ 0.117873] Bluetooth: HCI socket layer initialized
[ 0.117887] Bluetooth: L2CAP socket layer initialized
[ 0.117919] Bluetooth: SCO socket layer initialized
[ 0.118305] rockchip-cpuinfo cpuinfo: SoC : 35682000
[ 0.118323] rockchip-cpuinfo cpuinfo: Serial : f5146071691ab9bd
[ 0.119386] clocksource: Switched to clocksource arch_sys_counter
[ 0.170774] VFS: Disk quotas dquot_6.6.0
[ 0.170869] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.180850] loop: module loaded
[ 0.181152] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.181445] NET: Registered protocol family 2
[ 0.181629] IP idents hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.182981] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes)
[ 0.183031] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.183215] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.183604] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.183736] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.183797] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.183955] NET: Registered protocol family 1
[ 0.186356] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.187950] Initialise system trusted keyrings
[ 0.188164] workingset: timestamp_bits=45 max_order=20 bucket_order=0
[ 0.192096] Registering sdcardfs 0.1
[ 0.192400] utf8_selftest: All 154 tests passed
[ 0.192421] fuse init (API version 7.27)
[ 0.193547]
[ 0.193547] TEE Core Framework initialization (ver 1:0.1)
[ 0.193586] TEE armv7 Driver initialization
[ 0.194044] tz_tee_probe: name=“armv7sec”, id=0, pdev_name=“armv7sec.0”
[ 0.194065] TEE core: Alloc the misc device “opteearmtz00” (id=0)
[ 0.194228] TEE Core: Register the misc device “opteearmtz00” (id=0,minor=62)
[ 0.195370] Key type asymmetric registered
[ 0.195389] Asymmetric key parser ‘x509’ registered
[ 0.195429] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.195445] io scheduler noop registered
[ 0.195571] io scheduler cfq registered (default)
[ 0.195588] io scheduler mq-deadline registered
[ 0.195601] io scheduler kyber registered
[ 0.195691] io scheduler bfq registered
[ 0.196701] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully!
[ 0.196834] rockchip-csi2-dphy-hw fe870000.csi2-dphy-hw: csi2 dphy hw probe successfully!
[ 0.198569] phy phy-fe8b0000.usb2-phy.0: Linked as a consumer to regulator.5
[ 0.198705] phy phy-fe8b0000.usb2-phy.1: Linked as a consumer to regulator.5
[ 0.198795] phy phy-fe8b0000.usb2-phy.1: No vbus specified for otg port
[ 0.205967] iep: Module initialized.
[ 0.206103] mpp_service mpp-srv: 98ba077b36 author: Firefly 2022-04-15 improve ddr and pcie stability
[ 0.206122] mpp_service mpp-srv: probe start
[ 0.206862] iommu: Adding device fdf40000.rkvenc to group 5
[ 0.206900] mpp_rkvenc fdf40000.rkvenc: Linked as a consumer to fdf40f00.iommu
[ 0.207073] mpp_rkvenc fdf40000.rkvenc: probing start
[ 0.207468] mpp_rkvenc fdf40000.rkvenc: venc regulator not ready, retry
[ 0.207487] rkvenc_init:1199: failed to add venc devfreq
[ 0.208894] iommu: Adding device fdea0400.vdpu to group 1
[ 0.208935] mpp_vdpu2 fdea0400.vdpu: Linked as a consumer to fdea0800.iommu
[ 0.209089] mpp_vdpu2 fdea0400.vdpu: probe device
[ 0.209668] mpp_vdpu2 fdea0400.vdpu: probing finish
[ 0.210209] iommu: Adding device fdee0000.vepu to group 3
[ 0.210236] mpp_vepu2 fdee0000.vepu: Linked as a consumer to fdee0800.iommu
[ 0.210404] mpp_vepu2 fdee0000.vepu: probe device
[ 0.210881] mpp_vepu2 fdee0000.vepu: probing finish
[ 0.211374] iommu: Adding device fdef0000.iep to group 4
[ 0.211407] mpp-iep2 fdef0000.iep: Linked as a consumer to fdef0800.iommu
[ 0.211525] mpp-iep2 fdef0000.iep: probe device
[ 0.211919] mpp-iep2 fdef0000.iep: allocate roi buffer failed
[ 0.212074] mpp-iep2 fdef0000.iep: probing finish
[ 0.212536] iommu: Adding device fded0000.jpegd to group 2
[ 0.212568] mpp_jpgdec fded0000.jpegd: Linked as a consumer to fded0480.iommu
[ 0.212694] mpp_jpgdec fded0000.jpegd: probe device
[ 0.213219] mpp_jpgdec fded0000.jpegd: probing finish
[ 0.213749] iommu: Adding device fdf80200.rkvdec to group 6
[ 0.213780] mpp_rkvdec2 fdf80200.rkvdec: Linked as a consumer to fdf80800.iommu
[ 0.213984] mpp_rkvdec2 fdf80200.rkvdec: probing start
[ 0.214154] mpp_rkvdec2 fdf80200.rkvdec: 16 task capacity link mode detected
[ 0.214444] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_a is not found!
[ 0.214464] rkvdec2_init:661: No niu aclk reset resource define
[ 0.214479] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_h is not found!
[ 0.214490] rkvdec2_init:664: No niu hclk reset resource define
[ 0.214641] mpp_rkvdec2 fdf80200.rkvdec: sram_start 0x00000000fdcc0000
[ 0.214658] mpp_rkvdec2 fdf80200.rkvdec: rcb_iova 0x0000000010000000
[ 0.214671] mpp_rkvdec2 fdf80200.rkvdec: sram_size 45056
[ 0.214684] mpp_rkvdec2 fdf80200.rkvdec: rcb_size 65536
[ 0.214697] mpp_rkvdec2 fdf80200.rkvdec: min_width 512
[ 0.214748] mpp_rkvdec2 fdf80200.rkvdec: link mode probe finish
[ 0.214814] mpp_rkvdec2 fdf80200.rkvdec: probing finish
[ 0.215129] mpp_service mpp-srv: probe success
[ 0.219533] dma-pl330 fe530000.dmac: Loaded driver for PL330 DMAC-241330
[ 0.219566] dma-pl330 fe530000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.221129] dma-pl330 fe550000.dmac: Loaded driver for PL330 DMAC-241330
[ 0.221162] dma-pl330 fe550000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.222128] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 0.223151] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.223885] fe670000.serial: ttyS3 at MMIO 0xfe670000 (irq = 66, base_baud = 1500000) is a 16550A
[ 0.224337] fe680000.serial: ttyS4 at MMIO 0xfe680000 (irq = 67, base_baud = 1500000) is a 16550A
[ 0.224726] fe6b0000.serial: ttyS7 at MMIO 0xfe6b0000 (irq = 68, base_baud = 1500000) is a 16550A
[ 0.225107] fe6c0000.serial: ttyS8 at MMIO 0xfe6c0000 (irq = 69, base_baud = 1500000) is a 16550A
[ 0.225474] fe6d0000.serial: ttyS9 at MMIO 0xfe6d0000 (irq = 70, base_baud = 1500000) is a 16550A
[ 0.227220] random: fast init done
[ 0.227510] random: crng init done
[ 0.227687] iommu: Adding device fe040000.vop to group 8
[ 0.227728] rockchip-vop2 fe040000.vop: Linked as a consumer to fe043e00.iommu
[ 0.231293] rockchip-drm display-subsystem: Linked as a consumer to fe040000.vop
[ 0.232102] rockchip-drm display-subsystem: Linked as a consumer to fe0a0000.hdmi
[ 0.233460] rockchip-drm display-subsystem: defer getting devfreq
[ 0.233701] vp0: rgb_pixelclk: 0
[ 0.233723] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x3f, primary plane phy id: 4
[ 0.233748] vp1: rgb_pixelclk: 0
y plane phy id: -1
[ 0.233780] vp2: rgb_pixelclk: 0
[ 0.233795] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x0, primary plane phy id: -1
[ 0.234173] [drm] unsupported AFBC format[3432564e]
[ 0.234379] rockchip-drm display-subsystem: bound fe040000.vop (ops vop2_component_ops)
[ 0.234569] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 0.235113] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[ 0.235633] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops dw_hdmi_rockchip_ops)
[ 0.235650] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.235656] [drm] No driver support for vblank timestamp query.
[ 0.351448] [drm] Initialized rockchip 2.0.0 20140818 for display-subsystem on minor 0
[ 0.356245] mali fde60000.gpu: Kernel DDK version g7p1-01bet0
[ 0.356362] mali fde60000.gpu: Device initialization Deferred
[ 0.356407] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.362138] brd: module loaded
[ 0.362498] zram: Added device: zram0
[ 0.363248] SCSI Media Changer driver v0.25
[ 0.364320] ahci fc800000.sata: forcing port_map 0x0 → 0x1
[ 0.364377] ahci fc800000.sata: AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl platform mode
[ 0.364389] ahci fc800000.sata: flags: ncq sntf pm led clo only pmp fbs pio slum part ccc apst
[ 0.364414] ahci fc800000.sata: port 0 is not capable of FBS
[ 0.365037] scsi host0: ahci
[ 0.365335] ata1: SATA max UDMA/133 mmio [mem 0xfc800000-0xfc800fff] port 0x100 irq 11
[ 0.366676] register firefly_spi_init spi return v = :0
[ 0.367210] libphy: Fixed MDIO Bus: probed
[ 0.367391] tun: Universal TUN/TAP device driver, 1.6
[ 0.367579] CAN device driver interface
[ 0.369790] rk_gmac-dwmac fe010000.ethernet: no regulator found
[ 0.369822] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).
[ 0.369832] rk_gmac-dwmac fe010000.ethernet: TX delay(0x3e).
[ 0.369840] rk_gmac-dwmac fe010000.ethernet: RX delay(0x32).
[ 0.369851] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[ 0.369889] rk_gmac-dwmac fe010000.ethernet: clock input from PHY
[ 0.374915] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[ 0.374986] rk_gmac-dwmac fe010000.ethernet: [stmmac_dvr_probe-4362]led_status_value = 0x6940
[ 0.375198] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 0.375213] rk_gmac-dwmac fe010000.ethernet: DWMAC4/5
[ 0.375235] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[ 0.375248] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[ 0.375259] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[ 0.375270] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[ 0.375312] rk_gmac-dwmac fe010000.ethernet: TSO supported
[ 0.375327] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 0.375341] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[ 0.506087] libphy: stmmac: probed
[ 0.506371] mdio_bus stmmac-1: MDIO device at address 0 is missing.
[ 0.507382] rk_gmac-dwmac fe2a0000.ethernet: no regulator found
[ 0.507411] rk_gmac-dwmac fe2a0000.ethernet: clock input or output? (input).
[ 0.507421] rk_gmac-dwmac fe2a0000.ethernet: TX delay(0x4a).
[ 0.507428] rk_gmac-dwmac fe2a0000.ethernet: RX delay(0x2e).
[ 0.507439] rk_gmac-dwmac fe2a0000.ethernet: integrated PHY? (no).
[ 0.507471] rk_gmac-dwmac fe2a0000.ethernet: clock input from PHY
[ 0.512499] rk_gmac-dwmac fe2a0000.ethernet: init for RGMII
[ 0.512575] rk_gmac-dwmac fe2a0000.ethernet: [stmmac_dvr_probe-4362]led_status_value = 0x6940
[ 0.512815] rk_gmac-dwmac fe2a0000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 0.512835] rk_gmac-dwmac fe2a0000.ethernet: DWMAC4/5
[ 0.512851] rk_gmac-dwmac fe2a0000.ethernet: DMA HW capability register supported
[ 0.512863] rk_gmac-dwmac fe2a0000.ethernet: RX Checksum Offload Engine supported
[ 0.512876] rk_gmac-dwmac fe2a0000.ethernet: TX Checksum insertion supported
[ 0.512887] rk_gmac-dwmac fe2a0000.ethernet: Wake-Up On Lan supported
[ 0.512928] rk_gmac-dwmac fe2a0000.ethernet: TSO supported
[ 0.512943] rk_gmac-dwmac fe2a0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 0.512957] rk_gmac-dwmac fe2a0000.ethernet: TSO feature enabled
[ 0.646083] libphy: stmmac: probed
[ 0.646408] phy_rtl8211f_led_fixup in
[ 0.667914] PPP generic driver version 2.4.2
[ 0.668091] PPP BSD Compression module registered
[ 0.668107] PPP Deflate Compression module registered
[ 0.668142] PPP MPPE Compression module registered
[ 0.668156] NET: Registered protocol family 24
[ 0.668182] PPTP driver version 0.8.5
[ 0.668438] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 0.668446] CSLIP: code copyright 1989 Regents of the University of California.
[ 0.668539] usbcore: registered new interface driver catc
[ 0.668595] usbcore: registered new interface driver kaweth
[ 0.668609] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 0.668652] usbcore: registered new interface driver pegasus
[ 0.668694] usbcore: registered new interface driver rtl8150
[ 0.668735] usbcore: registered new interface driver r8152
[ 0.668750] hso: drivers/net/usb/hso.c: Option Wireless
[ 0.668809] usbcore: registered new interface driver hso
[ 0.668852] usbcore: registered new interface driver asix
[ 0.668895] usbcore: registered new interface driver ax88179_178a
[ 0.668940] usbcore: registered new interface driver cdc_ether
[ 0.668975] usbcore: registered new interface driver cdc_eem
[ 0.669016] usbcore: registered new interface driver dm9601
[ 0.669059] usbcore: registered new interface driver smsc75xx
[ 0.669105] usbcore: registered new interface driver smsc95xx
[ 0.669147] usbcore: registered new interface driver gl620a
[ 0.669187] usbcore: registered new interface driver net1080
[ 0.669223] usbcore: registered new interface driver plusb
[ 0.669265] usbcore: registered new interface driver rndis_host
[ 0.669309] usbcore: registered new interface driver cdc_subset
[ 0.669350] usbcore: registered new interface driver zaurus
[ 0.669427] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 0.669467] usbcore: registered new interface driver int51x1
[ 0.669510] usbcore: registered new interface driver kalmia
[ 0.669554] usbcore: registered new interface driver ipheth
[ 0.669593] usbcore: registered new interface driver sierra_net
[ 0.669633] usbcore: registered new interface driver cx82310_eth
[ 0.669678] usbcore: registered new interface driver cdc_ncm
[ 0.669727] usbcore: registered new interface driver qmi_wwan_q
[ 0.669771] usbcore: registered new interface driver qmi_wwan
[ 0.669813] usbcore: registered new interface driver cdc_mbim
[ 0.670891] dwc3 fcc00000.dwc3: Failed to get clk ‘ref’: -2
[ 0.671637] dwc3 fd000000.dwc3: Failed to get clk ‘ref’: -2
[ 0.673463] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.673485] ehci-pci: EHCI PCI platform driver
[ 0.673554] ehci-platform: EHCI generic platform driver
[ 0.675808] ehci-platform fd800000.usb: EHCI Host Controller
[ 0.675992] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 1
[ 0.676156] ehci-platform fd800000.usb: irq 12, io mem 0xfd800000
[ 0.679275] ata1: SATA link down (SStatus 0 SControl 300)
[ 0.689430] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00
[ 0.689625] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.689644] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.689657] usb usb1: Product: EHCI Host Controller
[ 0.689670] usb usb1: Manufacturer: Linux 4.19.219 ehci_hcd
[ 0.689681] usb usb1: SerialNumber: fd800000.usb
[ 0.690104] hub 1-0:1.0: USB hub found
[ 0.690151] hub 1-0:1.0: 1 port detected
[ 0.692639] ehci-platform fd880000.usb: EHCI Host Controller
[ 0.692859] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 2
[ 0.692996] ehci-platform fd880000.usb: irq 14, io mem 0xfd880000
[ 0.706117] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00
[ 0.706305] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.706324] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.706339] usb usb2: Product: EHCI Host Controller
[ 0.706352] usb usb2: Manufacturer: Linux 4.19.219 ehci_hcd
[ 0.706364] usb usb2: SerialNumber: fd880000.usb
[ 0.706781] hub 2-0:1.0: USB hub found
[ 0.706832] hub 2-0:1.0: 1 port detected
[ 0.707494] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.707531] ohci-platform: OHCI generic platform driver
[ 0.707765] ohci-platform fd840000.usb: Generic Platform OHCI controller
[ 0.707947] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 3
[ 0.708091] ohci-platform fd840000.usb: irq 13, io mem 0xfd840000
[ 0.766939] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[ 0.766971] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.766979] usb usb3: Product: Generic Platform OHCI controller
[ 0.766986] usb usb3: Manufacturer: Linux 4.19.219 ohci_hcd
[ 0.766992] usb usb3: SerialNumber: fd840000.usb
[ 0.767449] hub 3-0:1.0: USB hub found
[ 0.767499] hub 3-0:1.0: 1 port detected
[ 0.767944] ohci-platform fd8c0000.usb: Generic Platform OHCI controller
[ 0.768114] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 4
[ 0.768262] ohci-platform fd8c0000.usb: irq 15, io mem 0xfd8c0000
[ 0.826940] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[ 0.826970] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.826977] usb usb4: Product: Generic Platform OHCI controller
[ 0.826984] usb usb4: Manufacturer: Linux 4.19.219 ohci_hcd
[ 0.826991] usb usb4: SerialNumber: fd8c0000.usb
[ 0.827421] hub 4-0:1.0: USB hub found
[ 0.827468] hub 4-0:1.0: 1 port detected
[ 0.828830] usbcore: registered new interface driver cdc_acm
[ 0.828852] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.828923] usbcore: registered new interface driver usblp
[ 0.828981] usbcore: registered new interface driver cdc_wdm
[ 0.829224] usbcore: registered new interface driver uas
[ 0.829313] usbcore: registered new interface driver usb-storage
[ 0.829361] usbcore: registered new interface driver ums-alauda
[ 0.829434] usbcore: registered new interface driver ums-cypress
[ 0.829479] usbcore: registered new interface driver ums-datafab
[ 0.829526] usbcore: registered new interface driver ums_eneub6250
[ 0.829569] usbcore: registered new interface driver ums-freecom
[ 0.829611] usbcore: registered new interface driver ums-isd200
[ 0.829654] usbcore: registered new interface driver ums-jumpshot
[ 0.829695] usbcore: registered new interface driver ums-karma
[ 0.829738] usbcore: registered new interface driver ums-onetouch
[ 0.829785] usbcore: registered new interface driver ums-sddr09
[ 0.829828] usbcore: registered new interface driver ums-sddr55
[ 0.829870] usbcore: registered new interface driver ums-usbat
[ 0.829956] usbcore: registered new interface driver usbserial_generic
[ 0.829987] usbserial: USB Serial support registered for generic
[ 0.830033] usbcore: registered new interface driver option
[ 0.830062] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.830204] usbcore: registered new interface driver trancevibrator
[ 0.830732] usbcore: registered new interface driver xpad
[ 0.830785] usbcore: registered new interface driver usb_acecad
[ 0.830836] usbcore: registered new interface driver aiptek
[ 0.830883] usbcore: registered new interface driver gtco
[ 0.830922] usbcore: registered new interface driver hanwang
[ 0.830968] usbcore: registered new interface driver kbtab
[ 0.831055] [HXTP] himax_hx83102_init
[ 0.831069] [HXTP] himax_hx83102_probe:Enter
[ 0.831081] [HXTP] Himax common touch panel driver init
[ 0.831127] cyttsp5_loader_init: Parade TTSP FW Loader Driver (Built TTDA.03.08.874312) rc=0
[ 0.831137] cyttsp5_device_access_init: Parade TTSP Device Access Driver (Built TTDA.03.08.874312) rc=0
[ 0.831519] .. rk pwm remotectl v2.0 init
[ 0.831758] input: fe6e0030.pwm as /devices/platform/fe6e0030.pwm/input/input0
[ 0.832060] remotectl-pwm fe6e0030.pwm: pwm version is 0x2130000
[ 0.832118] remotectl-pwm fe6e0030.pwm: Controller support pwrkey capture
[ 0.833480] i2c /dev entries driver
[ 0.835306] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[ 0.837059] vdd_cpu: supplied by vcc5v0_sys
[ 0.841826] rk808 0-0020: chip id: 0x8090
[ 0.841883] rk808 0-0020: No cache defaults, reading back from HW
[ 0.865590] rk808 0-0020: source: on=0x40, off=0x00
[ 0.865629] rk808 0-0020: support dcdc3 fb mode:-22, 63
[ 0.865639] rk808 0-0020: support pmic reset mode:0,0
[ 0.870815] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 0.870858] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 0.871266] vdd_logic: supplied by vcc3v3_sys
[ 0.871921] vdd_gpu: supplied by vcc3v3_sys
[ 0.872178] vcc_ddr: supplied by vcc3v3_sys
[ 0.872437] vdd_npu: supplied by vcc3v3_sys
[ 0.873040] vcc_1v8: supplied by vcc3v3_sys
[ 0.873279] vdda0v9_image: supplied by vcc3v3_sys
[ 0.873861] vdda_0v9: supplied by vcc3v3_sys
[ 0.874106] vdda0v9_pmu: supplied by vcc3v3_sys
[ 0.874345] vccio_acodec: supplied by vcc3v3_sys
[ 0.874934] vccio_sd: supplied by vcc3v3_sys
[ 0.875181] vcc3v3_pmu: supplied by vcc3v3_sys
[ 0.875760] vcca_1v8: supplied by vcc3v3_sys
[ 0.876009] vcca1v8_pmu: supplied by vcc3v3_sys
[ 0.876302] vcca1v8_image: supplied by vcc3v3_sys
[ 0.876894] vcc_3v3: supplied by vcc3v3_sys
[ 0.877456] vcc3v3_sd: supplied by vcc3v3_sys
[ 0.877823] rk817-battery rk817-battery: Failed to find matching dt id
[ 0.878045] rk817-charger rk817-charger: Failed to find matching dt id
[ 0.881135] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input1
[ 0.881572] rk808-rtc rk808-rtc: device is disabled
[ 0.881601] rk808-rtc: probe of rk808-rtc failed with error -22
[ 0.882546] fusb302 0-0022: Can’t get property of role, set role to default DRP
[ 0.885763] fusb302 0-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 0.885902] input: Typec_Headphone as /devices/platform/fdd40000.i2c/i2c-0/0-0022/input/input2
[ 0.897258] rtc-hym8563 5-0051: rtc core: registered hym8563 as rtc0
[ 0.898310] rtc-hym8563 5-0051: setting system clock to 2017-01-01 12:00:00 UTC (1483272000)
[ 0.899807] gsensor_mc3230 5-004c: sensor_register_device: gs_mc3230, id = 27
[ 0.899838] i2c i2c-5: sensor_probe: gs_mc3230,0000000092154bf0
[ 0.899868] gsensor_mc3230 5-004c: sensor_chip_init:gs_mc3230:devid=0x0,ops=0x00000000589da154
[ 0.939598] [Gsensor] init_3230_ctl_data 457 : error: -6
[ 0.939630] gsensor_mc3230 5-004c: sensor_initial:fail to init sensor
[ 0.939639] gsensor_mc3230 5-004c: sensor_chip_init:fail to init sensor
[ 0.939647] i2c i2c-5: sensor_probe failed -2
[ 0.939647]
[ 0.941534] iommu: Adding device fdff0000.rkisp to group 7
[ 0.941581] rkisp_hw fdff0000.rkisp: Linked as a consumer to fdff1a00.iommu
[ 0.941759] rkisp_hw fdff0000.rkisp: is_thunderboot: 0
[ 0.941779] rkisp_hw fdff0000.rkisp: max input:0x0@0fps
[ 0.941809] rkisp_hw fdff0000.rkisp: can’t request region for resource [mem 0xfdff0000-0xfdffffff]
[ 0.942530] rkisp rkisp-vir0: rkisp driver version: v01.07.00
[ 0.942607] rkisp rkisp-vir0: No memory-region-thunderboot specified
[ 0.942837] rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized!
[ 0.942862] rkisp rkisp-vir0: Entity type for entity rkisp-csi-subdev was not initialized!
[ 0.944442] usbcore: registered new interface driver uvcvideo
[ 0.944467] USB Video Class driver (1.1.1)
[ 0.944735] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.26
[ 0.944762] rockchip-iodomain fdc20000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_pmu
[ 0.944849] rockchip-iodomain fdc20000.syscon:io-domains: pmuio2(3300000 uV) supplied by vcc3v3_pmu
[ 0.944924] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.24
[ 0.944955] rockchip-iodomain fdc20000.syscon:io-domains: vccio1(3300000 uV) supplied by vccio_acodec
[ 0.945054] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.25
[ 0.945086] rockchip-iodomain fdc20000.syscon:io-domains: vccio3(3300000 uV) supplied by vccio_sd
[ 0.945151] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.20
[ 0.945181] rockchip-iodomain fdc20000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8
[ 0.945253] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.30
[ 0.945284] rockchip-iodomain fdc20000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc_3v3
[ 0.945367] rockchip-iodomain fdc20000.syscon:io-domains: vccio6(1800000 uV) supplied by vcc_1v8
[ 0.945442] rockchip-iodomain fdc20000.syscon:io-domains: vccio7(3300000 uV) supplied by vcc_3v3
[ 0.946915] __power_supply_register: Expected proper parent device for ‘test_ac’
[ 0.947077] __power_supply_register: Expected proper parent device for ‘test_battery’
[ 0.947288] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 0.947369] __power_supply_register: Expected proper parent device for ‘test_usb’
[ 0.949565] rockchip-thermal fe710000.tsadc: tsadc is probed successfully!
[ 0.950604] device-mapper: uevent: version 1.0.3
[ 0.950841] device-mapper: ioctl: 4.39.0-ioctl (2018-04-03) initialised: dm-devel@redhat.com
[ 0.951037] device-mapper: verity-avb: AVB error handler initialized with vbmeta device:
[ 0.951060] Bluetooth: HCI UART driver ver 2.3
[ 0.951073] Bluetooth: HCI UART protocol H4 registered
[ 0.951371] cpu cpu0: leakage=29
[ 0.951420] cpu cpu0: pvtm = 89090, from nvmem
[ 0.951439] cpu cpu0: pvtm-volt-sel=1
[ 0.952211] cpu cpu0: Linked as a consumer to regulator.15
[ 0.952267] cpu cpu0: Dropping the link to regulator.15
[ 0.952859] cpu cpu0: Linked as a consumer to regulator.15
[ 0.953500] cpu cpu0: avs=0
[ 0.953553] energy_model: pd0: hertz/watts ratio non-monotonically decreasing: em_cap_state 2 >= em_cap_state1
[ 0.953735] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 0.957178] cpu cpu0: failed to find power_model node
[ 0.958468] sdhci: Secure Digital Host Controller Interface driver
[ 0.958495] sdhci: Copyright(c) Pierre Ossman
[ 0.958507] Synopsys Designware Multimedia Card Interface Driver
[ 0.959525] dwmmc_rockchip fe000000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.959593] dwmmc_rockchip fe000000.dwmmc: Using internal DMA controller.
[ 0.959610] dwmmc_rockchip fe000000.dwmmc: Version ID is 270a
[ 0.959661] dwmmc_rockchip fe000000.dwmmc: DW MMC controller at irq 42,32 bit host data width,256 deep fifo
[ 0.959776] dwmmc_rockchip fe000000.dwmmc: allocated mmc-pwrseq
[ 0.959796] mmc_host mmc3: card is non-removable.
[ 1.076424] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 1.090761] dwmmc_rockchip fe2b0000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.090942] dwmmc_rockchip fe2b0000.dwmmc: Using internal DMA controller.
[ 1.090978] dwmmc_rockchip fe2b0000.dwmmc: Version ID is 270a
[ 1.091092] dwmmc_rockchip fe2b0000.dwmmc: DW MMC controller at irq 51,32 bit host data width,256 deep fifo
[ 1.091364] dwmmc_rockchip fe2b0000.dwmmc: Linked as a consumer to regulator.31
[ 1.091481] dwmmc_rockchip fe2b0000.dwmmc: Linked as a consumer to regulator.25
[ 1.103916] mmc_host mmc0: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 1.105522] Freeing initrd memory: 38680K
[ 1.116634] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.118083] mmc2: Unknown controller version (5). You may experience problems.
[ 1.124481] mmc3: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.126245] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.128037] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.130993] mmc3: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.148631] mmc2: SDHCI controller on fe310000.sdhci [fe310000.sdhci] using ADMA
[ 1.153891] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.157320] usbcore: registered new interface driver usbhid
[ 1.157344] usbhid: USB HID core driver
[ 1.157442] ion_device_add_heap: ion_system_contig_heap id=0 type=1
[ 1.157468] orders[0] = 6
[ 1.157481] orders[1] = 4
[ 1.157487] orders[2] = 0
[ 1.157774] ion_device_add_heap: ion_system_heap id=1 type=0
[ 1.157793] ion_device_add_heap: linux,cma id=2 type=4
[ 1.158040] ashmem: initialized
[ 1.158381] rockchip,bus bus-npu: Linked as a consumer to regulator.16
[ 1.158457] rockchip,bus bus-npu: Failed to get leakage
[ 1.158519] rockchip,bus bus-npu: pvtm = 89090, from nvmem
[ 1.158540] rockchip,bus bus-npu: pvtm-volt-sel=1
[ 1.158839] rockchip,bus bus-npu: avs=0
[ 1.162386] rockchip-saradc fe720000.saradc: Linked as a consumer to regulator.27
[ 1.162965] optee: probing for conduit method from DT.
[ 1.162993] optee: revision 3.13 (4167319d)
[ 1.163472] optee: initialized driver
[ 1.163503] rksfc_base v1.1 2016-01-08
[ 1.164227] rksfc fe300000.sfc: rksfc_probe clk rate = 50000000
[ 1.164288] rkflash_dev_init enter
[ 1.164311] sfc nor id: ff ff ff
[ 1.164323] rkflash[1] is invalid
[ 1.164928] usbcore: registered new interface driver snd-usb-audio
[ 1.167184] rk817-codec rk817-codec: DMA mask not set
100
[ 1.168030] invalid rk817->hp_det_gpio: -2
[ 1.168042] invalid gpio: -2
[ 1.172296] rk-hdmi-sound hdmi-sound: i2s-hifi ↔ fe400000.i2s mapping ok
[ 1.173793] netem: version 1.3
[ 1.173817] u32 classifier
[ 1.173824] Actions configured
[ 1.174364] xt_time: kernel timezone is -0000
[ 1.174447] gre: GRE over IPv4 demultiplexor driver
[ 1.174461] IPv4 over IPsec tunneling driver
[ 1.175081] Initializing XFRM netlink socket
[ 1.175114] IPsec XFRM device driver
[ 1.175426] NET: Registered protocol family 10
[ 1.176258] Segment Routing with IPv6
[ 1.176334] mip6: Mobile IPv6
[ 1.176774] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 1.177255] NET: Registered protocol family 17
[ 1.177281] NET: Registered protocol family 15
[ 1.177327] Bridge firewalling registered
[ 1.177386] can: controller area network core (rev 20170425 abi 9)
[ 1.177467] NET: Registered protocol family 29
[ 1.177489] can: raw protocol (rev 20170425)
[ 1.177500] can: broadcast manager protocol (rev 20170425 t)
[ 1.177513] can: netlink gateway (rev 20170425) max_hops=1
[ 1.177741] Bluetooth: RFCOMM TTY layer initialized
[ 1.177758] Bluetooth: RFCOMM socket layer initialized
[ 1.177793] Bluetooth: RFCOMM ver 1.11
[ 1.177808] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.177816] Bluetooth: BNEP filters: protocol multicast
[ 1.177827] Bluetooth: BNEP socket layer initialized
[ 1.177835] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.177844] Bluetooth: HIDP socket layer initialized
[ 1.177867] l2tp_core: L2TP core driver, V2.0
[ 1.177879] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.177887] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.177895] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.178350] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.178388] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6275s
[ 1.178397] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.178402] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.178426] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 124, flags = 0.
[ 1.178438] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 1.178447] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.178456] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1
[ 1.178464] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.178889] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 73.
[ 1.178912] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 96.
[ 1.178926] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 98.
[ 1.178939] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 97.
[ 1.178987] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.179053] [BT_RFKILL]: ** disable irq
[ 1.179155] [BT_RFKILL]: bt_default device registered.
[ 1.179417] flash vendor_init_thread!
[ 1.179430] flash vendor storage:20170308 ret = -1
[ 1.180982] registered taskstats version 1
[ 1.180995] Loading compiled-in X.509 certificates
[ 1.181079] Key type ._fscrypt registered
[ 1.181092] Key type .fscrypt registered
[ 1.181100] Key type fscrypt-provisioning registered
[ 1.181363] pstore: Using compression: deflate
[ 1.182080] rk-pcie 3c0800000.pcie: Linked as a consumer to regulator.11
[ 1.182624] rga2: Driver loaded successfully ver:3.2.63318
[ 1.182912] rga2: Module initialized.
[ 1.183466] mmc2: new HS200 MMC card at address 0001
[ 1.184545] mmcblk2: mmc2:0001 A3A561 57.6 GiB
[ 1.185303] mmcblk2boot0: mmc2:0001 A3A561 partition 1 4.00 MiB
[ 1.185963] mmcblk2boot1: mmc2:0001 A3A561 partition 2 4.00 MiB
[ 1.186279] mmcblk2rpmb: mmc2:0001 A3A561 partition 3 16.0 MiB, chardev (237:0)
[ 1.188916] mmcblk2: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 1.192778] rochchip_p3phy_init: lock failed 0x6890000, check input refclk and power supply
[ 1.192811] phy phy-fe8c0000.phy.5: phy init failed → -110
[ 1.192819] rk-pcie 3c0800000.pcie: fail to init phy, err -110
[ 1.192828] rk-pcie 3c0800000.pcie: phy init failed
[ 1.203730] phy phy-fe8a0000.usb2-phy.6: Linked as a consumer to regulator.5
[ 1.203892] phy phy-fe8a0000.usb2-phy.7: No vbus specified for otg port
[ 1.204850] mpp_rkvenc fdf40000.rkvenc: probing start
[ 1.205247] mpp_rkvenc fdf40000.rkvenc: Linked as a consumer to regulator.16
[ 1.205271] mpp_rkvenc fdf40000.rkvenc: Failed to get leakage
[ 1.205314] mpp_rkvenc fdf40000.rkvenc: pvtm = 89090, from nvmem
[ 1.205327] mpp_rkvenc fdf40000.rkvenc: pvtm-volt-sel=1
[ 1.205454] mpp_rkvenc fdf40000.rkvenc: avs=0
[ 1.205548] mpp_rkvenc fdf40000.rkvenc: failed to find power_model node
[ 1.205560] mpp_rkvenc fdf40000.rkvenc: failed to initialize power model
[ 1.205569] mpp_rkvenc fdf40000.rkvenc: failed to get dynamic-coefficient
[ 1.205876] mpp_rkvenc fdf40000.rkvenc: probing finish
[ 1.206505] dwc3 fcc00000.dwc3: Failed to get clk ‘ref’: -2
[ 1.206507] mali fde60000.gpu: Kernel DDK version g7p1-01bet0
[ 1.206654] mali fde60000.gpu: Linked as a consumer to regulator.17
[ 1.206755] mali fde60000.gpu: dev_pm_opp_set_regulators: no regulator (shadercores) found: -19
[ 1.206830] mali fde60000.gpu: leakage=8
[ 1.206866] mali fde60000.gpu: pvtm = 89090, from nvmem
[ 1.207186] mali fde60000.gpu: avs=0
] : 112; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
[ 1.207476] mali fde60000.gpu: GPU identified as 0x2 arch 7.4.0 r1p0 status 0
[ 1.207542] mali fde60000.gpu: No priority control manager is configured
[ 1.207571] mali fde60000.gpu: No memory group manager is configured
[ 1.208028] mali fde60000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 1.208732] mali fde60000.gpu: Probed as mali0
[ 1.209845] dwc3 fd000000.dwc3: Failed to get clk ‘ref’: -2
[ 1.213643] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[ 1.213872] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 5
[ 1.214010] xhci-hcd xhci-hcd.5.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000011002010010
[ 1.214046] xhci-hcd xhci-hcd.5.auto: irq 85, io mem 0xfd000000
[ 1.214272] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.214284] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.214293] usb usb5: Product: xHCI Host Controller
[ 1.214302] usb usb5: Manufacturer: Linux 4.19.219 xhci-hcd
[ 1.214310] usb usb5: SerialNumber: xhci-hcd.5.auto
[ 1.214656] hub 5-0:1.0: USB hub found
[ 1.214692] hub 5-0:1.0: 1 port detected
[ 1.214895] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[ 1.215044] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 6
[ 1.215062] xhci-hcd xhci-hcd.5.auto: Host supports USB 3.0 SuperSpeed
[ 1.215125] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.215233] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 1.215244] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.215253] usb usb6: Product: xHCI Host Controller
[ 1.215261] usb usb6: Manufacturer: Linux 4.19.219 xhci-hcd
[ 1.215269] usb usb6: SerialNumber: xhci-hcd.5.auto
[ 1.215342] mmc_host mmc3: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[ 1.215554] hub 6-0:1.0: USB hub found
[ 1.215587] hub 6-0:1.0: 1 port detected
[ 1.216134] input: adc-keys as /devices/platform/adc-keys/input/input3
[ 1.216679] rockchip-dmc dmc: Linked as a consumer to regulator.16
[ 1.216760] rockchip-dmc dmc: leakage=58
[ 1.216776] rockchip-dmc dmc: leakage-volt-sel=0
[ 1.216809] rockchip-dmc dmc: pvtm = 89090, from nvmem
[ 1.216822] rockchip-dmc dmc: pvtm-volt-sel=1
[ 1.216930] rockchip-dmc dmc: avs=0
[ 1.216947] rockchip-dmc dmc: current ATF version 0x101
[ 1.217545] rockchip-dmc dmc: normal_rate = 780000000
[ 1.217553] rockchip-dmc dmc: reboot_rate = 1560000000
[ 1.217565] rockchip-dmc dmc: suspend_rate = 324000000
[ 1.217575] rockchip-dmc dmc: video_4k_rate = 780000000
[ 1.217584] rockchip-dmc dmc: video_4k_10b_rate = 780000000
[ 1.217592] rockchip-dmc dmc: boost_rate = 1560000000
[ 1.217601] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 1560000000
[ 1.217609] rockchip-dmc dmc: performance_rate = 1560000000
[ 1.217627] rockchip-dmc dmc: failed to get vop pn to msch rl
[ 1.217739] rockchip-dmc dmc: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 1.217778] rockchip-dmc dmc: could not find power_model node
[ 1.240601] asoc-simple-card rk809-sound: rk817-hifi ↔ fe410000.i2s mapping ok
[ 1.240658] asoc-simple-card rk809-sound: ASoC: no source widget found for MICBIAS1
Mic Jack
[ 1.240679] asoc-simple-card rk809-sound: ASoC: no sink widget found for IN1P
[ 1.240688] asoc-simple-card rk809-sound: ASoC: Failed to add route Mic Jack → direct → IN1P
[ 1.240697] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOL
[ 1.240707] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOL → direct → Headphone Jack
[ 1.240718] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOR
[ 1.240727] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOR → direct → Headphone Jack
[ 1.244251] register spi return v = :0
[ 1.247426] It doesn’t contain Rogue gpu
[ 1.248638] iommu: Adding device fde40000.npu to group 0
[ 1.248697] RKNPU fde40000.npu: Linked as a consumer to fde4b000.iommu
[ 1.249713] RKNPU fde40000.npu: RKNPU: rknpu iommu is enabled, using iommu mode
[ 1.249949] RKNPU fde40000.npu: Linked as a consumer to regulator.19
[ 1.249986] RKNPU fde40000.npu: can’t request region for resource [mem 0xfde40000-0xfde4ffff]
[ 1.250906] [drm] Initialized rknpu 0.4.2 20210701 for fde40000.npu on minor 1
[ 1.251380] RKNPU fde40000.npu: leakage=4
[ 1.251419] RKNPU fde40000.npu: pvtm = 89090, from nvmem
[ 1.251959] RKNPU fde40000.npu: avs=0
[ 1.252657] RKNPU fde40000.npu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 1.252694] RKNPU fde40000.npu: failed to find power_model node
[ 1.252763] RKNPU fde40000.npu: RKNPU: failed to initialize power model
[ 1.252771] RKNPU fde40000.npu: RKNPU: failed to get dynamic-coefficient
[ 1.253652] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 1.255056] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 1.255275] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 1.255293] cfg80211: failed to load regulatory.db
[ 1.257502] rockchip-pm rockchip-suspend: not set pwm-regulator-config
417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, built at ‘11:29:26’, on ‘Feb 22 2023’.
[ 1.260056] Mali:
[ 1.260059] Mali device driver loaded
[ 1.260539] xc7160 4-001b: T-chip firefly camera driver version: 00.01.02
[ 1.261118] xc7160 4-001b: Failed to get power-gpios, maybe no use
[ 1.261263] xc7160 4-001b: 4-001b supply avdd not found, using dummy regulator
[ 1.261406] xc7160 4-001b: Linked as a consumer to regulator.0
[ 1.261434] xc7160 4-001b: 4-001b supply dovdd not found, using dummy regulator
[ 1.261487] xc7160 4-001b: 4-001b supply dvdd not found, using dummy regulator
[ 1.261536] xc7160 4-001b: could not get default pinstate
[ 1.261548] xc7160 4-001b: could not get sleep pinstate
[ 1.261571] xc7160 4-001b: Success to get xc7160 endpoint data lanes, dts uses 4 lanes
[ 1.261579] xc7160 4-001b: xc7160 num data lanes is 4
[ 1.314784] vendor storage:20190527 ret = 0
[ 1.317418] devfreq fde60000.gpu: Couldn’t update frequency transition information.
[ 1.344960] dwmmc_rockchip fe000000.dwmmc: Successfully tuned phase to 270
[ 1.345934] mmc3: new ultra high speed SDR104 SDIO card at address 0001
[ 1.462807] usb 5-1: new high-speed USB device number 2 using xhci-hcd
[ 1.604400] usb 5-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
[ 1.604428] usb 5-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.604436] usb 5-1: Product: USB2.0 Hub
[ 1.663703] hub 5-1:1.0: USB hub found
[ 1.664080] hub 5-1:1.0: 4 ports detected
[ 1.946244] usb 5-1.4: new low-speed USB device number 3 using xhci-hcd
[ 1.965927] xc7160 4-001b: write XC7160_REG_HIGH_SELECT failed
[ 1.966495] xc7160: probe of 4-001b failed with error -5
[ 1.966638] rkisp rkisp-vir0: clear unready subdev num: 5
[ 1.966666] rockchip-csi2-dphy0: No link between dphy and sensor
[ 1.967682] rockchip-csi2-dphy0: No link between dphy and sensor
[ 1.967707] rkisp-vir0: update sensor failed
v 1.974420]
2.040656] usb 5-1.4: New USB device found, idVendor=413c, idProduct=301a, bcdDevice= 1.00
[ 2.040687] usb 5-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.040696] usb 5-1.4: Product: Dell MS116 USB Optical Mouse
[ 2.040703] usb 5-1.4: Manufacturer: PixArt
